  4. Nach Update auf Admin 5.8 Startet Biobroker nicht mehr
    5.2k
120 Beiträge 7 Kommentatoren 13.3k Aufrufe 5 Beobachtet
  • M michaelxhoffmann
    Protokoll zum socketio:
    host.raspberrypi
    2023-08-31 13:28:50.935	warn	adapter "socketio" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
    host.raspberrypi
    2023-08-31 13:28:50.935	info	system.adapter.socketio.0 will be rebuilt
    host.raspberrypi
    2023-08-31 13:28:50.934	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
    host.raspberrypi
    2023-08-31 13:28:50.934	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-31 13:28:50.934	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
    host.raspberrypi
    2023-08-31 13:28:50.933	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
    host.raspberrypi
    2023-08-31 13:28:50.932	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
    host.raspberrypi
    2023-08-31 13:28:49.509	info	instance system.adapter.socketio.0 started with pid 5371
    host.raspberrypi
    2023-08-31 13:28:16.619	warn	adapter "socketio" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
    host.raspberrypi
    2023-08-31 13:28:16.618	info	system.adapter.socketio.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.12"})
    host.raspberrypi
    2023-08-31 13:28:16.617	info	Adapter system.adapter.socketio.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
    host.raspberrypi
    2023-08-31 13:28:16.617	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-31 13:28:16.616	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
    host.raspberrypi
    2023-08-31 13:28:16.614	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
    host.raspberrypi
    2023-08-31 13:28:16.611	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
    host.raspberrypi
    2023-08-31 13:28:14.475	info	instance system.adapter.socketio.0 started with pid 5256
    host.raspberrypi
    2023-08-31 13:26:50.110	info	system.adapter.socketio.0 will be rebuilt
    host.raspberrypi
    2023-08-31 13:26:50.109	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
    host.raspberrypi
    2023-08-31 13:26:50.108	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-31 13:26:50.107	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
    host.raspberrypi
    2023-08-31 13:26:50.103	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
    host.raspberrypi
    2023-08-31 13:26:50.100	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
    host.raspberrypi
    2023-08-31 13:26:47.178	info	instance system.adapter.socketio.0 started with pid 4379
    host.raspberrypi
    2023-08-31 13:26:39.441	info	iobroker host.raspberrypi object system.adapter.socketio.0 created
    host.raspberrypi
    2023-08-31 13:26:39.364	info	iobroker host.raspberrypi Set default value of socketio.0.info.connection: false
    host.raspberrypi
    2023-08-31 13:26:39.347	info	iobroker host.raspberrypi Set default value of socketio.0.info.connected:
    host.raspberrypi
    2023-08-31 13:26:39.319	info	iobroker host.raspberrypi object socketio.0.info.connection created
    host.raspberrypi
    2023-08-31 13:26:39.295	info	iobroker host.raspberrypi object socketio.0.info.connected created
    host.raspberrypi
    2023-08-31 13:26:39.031	info	iobroker host.raspberrypi object socketio.0.info created
    host.raspberrypi
    2023-08-31 13:26:39.010	info	iobroker host.raspberrypi object system.adapter.socketio.0.logLevel created
    host.raspberrypi
    2023-08-31 13:26:38.985	info	iobroker host.raspberrypi object system.adapter.socketio.0.sigKill created
    host.raspberrypi
    2023-08-31 13:26:38.959	info	iobroker host.raspberrypi object system.adapter.socketio.0.eventLoopLag created
    host.raspberrypi
    2023-08-31 13:26:38.934	info	iobroker host.raspberrypi object system.adapter.socketio.0.outputCount created
    host.raspberrypi
    2023-08-31 13:26:38.876	info	iobroker host.raspberrypi object system.adapter.socketio.0.inputCount created
    host.raspberrypi
    2023-08-31 13:26:38.817	info	iobroker host.raspberrypi object system.adapter.socketio.0.uptime created
    host.raspberrypi
    2023-08-31 13:26:38.791	info	iobroker host.raspberrypi object system.adapter.socketio.0.memRss created
    host.raspberrypi
    2023-08-31 13:26:38.710	info	iobroker host.raspberrypi object system.adapter.socketio.0.memHeapTotal created
    host.raspberrypi
    2023-08-31 13:26:38.673	info	iobroker host.raspberrypi object system.adapter.socketio.0.memHeapUsed created
    host.raspberrypi
    2023-08-31 13:26:38.636	info	iobroker host.raspberrypi object system.adapter.socketio.0.cputime created
    host.raspberrypi
    2023-08-31 13:26:38.609	info	iobroker host.raspberrypi object system.adapter.socketio.0.cpu created
    host.raspberrypi
    2023-08-31 13:26:38.483	info	iobroker host.raspberrypi object system.adapter.socketio.0.compactMode created
    host.raspberrypi
    2023-08-31 13:26:38.441	info	iobroker host.raspberrypi object system.adapter.socketio.0.connected created
    host.raspberrypi
    2023-08-31 13:26:38.414	info	iobroker host.raspberrypi object system.adapter.socketio.0.alive created
    host.raspberrypi
    2023-08-31 13:26:38.283	info	iobroker host.raspberrypi create instance socketio
    host.raspberrypi
    2023-08-31 13:26:31.577	info	iobroker add socketio --host raspberrypi
    Protokoll zum web.0
    2023-08-31 13:28:17.085	info	Rebuild for adapter system.adapter.web.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.raspberrypi
    2023-08-31 13:28:17.085	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-31 13:28:17.085	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
    host.raspberrypi
    2023-08-31 13:28:17.083	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
    host.raspberrypi
    2023-08-31 13:28:17.082	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
    host.raspberrypi
    2023-08-31 13:28:14.431	info	instance system.adapter.web.0 started with pid 5255
    host.raspberrypi
    2023-08-31 13:26:37.811	info	iobroker Adapter "system.adapter.web.0" restarted.
    host.raspberrypi
    2023-08-31 13:26:37.787	info	"system.adapter.web.0" enabled
    host.raspberrypi
    2023-08-31 13:26:37.733	info	"system.adapter.web.0" disabled
    host.raspberrypi
    2023-08-31 13:26:08.830	warn	adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
    host.raspberrypi
    2023-08-31 13:26:08.830	info	system.adapter.web.0 will be rebuilt
    host.raspberrypi
    2023-08-31 13:26:08.829	info	Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
    host.raspberrypi
    2023-08-31 13:26:08.829	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-31 13:26:08.829	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
    host.raspberrypi
    2023-08-31 13:26:08.828	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
    host.raspberrypi
    2023-08-31 13:26:08.827	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
    host.raspberrypi
    2023-08-31 13:26:07.128	info	instance system.adapter.web.0 started with pid 3767
    host.raspberrypi
    2023-08-31 13:25:34.497	warn	adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
    host.raspberrypi
    2023-08-31 13:25:34.496	info	system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.12"})
    host.raspberrypi
    2023-08-31 13:25:34.495	info	Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
    host.raspberrypi
    2023-08-31 13:25:34.494	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-31 13:25:34.493	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
    host.raspberrypi
    2023-08-31 13:25:34.490	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
    host.raspberrypi
    2023-08-31 13:25:34.472	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
    host.raspberrypi
    2023-08-31 13:25:32.619	info	instance system.adapter.web.0 started with pid 3505
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
    + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
    + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
    + system.adapter.logparser.0              : logparser             : raspberrypi                              -  enabled
    + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
      system.adapter.material.0               : material              : raspberrypi                              - disabled
    + system.adapter.milight-smart-light.0    : milight-smart-light   : raspberrypi                              -  enabled
      system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
    + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3307
    + system.adapter.sql.1                    : sql                   : raspberrypi                              -  enabled, port: 3306
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
    + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
    + instance is alive
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       18486      1579/io.jarvis.0
    tcp        0      0 192.168.178.45:12001    0.0.0.0:*               LISTEN      1001       15018      1150/io.hm-rpc.1
    tcp        0      0 192.168.178.45:12010    0.0.0.0:*               LISTEN      1001       14269      1164/io.hm-rpc.2
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13841      541/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14545      501/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13867      501/iobroker.js-con
    tcp        0      0 192.168.178.45:18701    0.0.0.0:*               LISTEN      1001       14246      1112/io.hm-rpc.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13843      541/sshd: /usr/sbin
    tcp6       0      0 :::34915                :::*                    LISTEN      1001       17657      1523/io.yahka.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15493      865/io.admin.0
    tcp6       0      0 :::8091                 :::*                    LISTEN      1001       18044      1605/io.lovelace.0
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       18715      1654/io.terminal.0
    udp        0      0 0.0.0.0:45324           0.0.0.0:*                           1001       17550      1396/io.broadlink2.
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       15928      1396/io.broadlink2.
    udp        0      0 0.0.0.0:47924           0.0.0.0:*                           108        1818       399/avahi-daemon: r
    udp        0      0 0.0.0.0:46297           0.0.0.0:*                           1001       17696      1598/io.milight-sma
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1816       399/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12861      739/dhcpcd
    udp        0      0 0.0.0.0:43222           0.0.0.0:*                           1001       15931      1396/io.broadlink2.
    udp6       0      0 :::546                  :::*                                0          12873      739/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        1817       399/avahi-daemon: r
    udp6       0      0 :::59241                :::*                                108        1819       399/avahi-daemon: r
    An dieser Stelle schon mal danke für die Arbeit die Du dir machst :)
    @michaelxhoffmann sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
    hast du wirklich den Adapter gelöscht, oder nur die Instanz?
    M crunchipC 2 Antworten Letzte Antwort
      michaelxhoffmann
      @homoran Ich habe die Instanz gelöscht, dann den Adapter, anschließend habe ich den Adapter erneut installiert und die Instanz neu erstellt
      Homematic CCU2 - Raspberry Pi 4 - IOS (siri) - Amazon Echo 3rd Gen.
        das log sagt aber was anderes 🤔
        ich nehme nicht an, dass du danach noch schnell die node-version verändert hast.
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          Protokoll zum web.0
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          + instance is alive
          bei web steht das selbe
            michaelxhoffmann
            @homoran Die nodeversion? Ich wüsste nicht wie ich das sollte :) OK Was ich natürlich nicht gemacht habe ist ein Neustart des Raspis nach dem löschen des Adapters.
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              Protokoll zum web.0
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              + instance is alive
              crunchipC Abwesend
              crunchipC Abwesend
              cd /opt/iobroker/node_modules/iobroker.web
                hast du diese Installation irgendwoher kopiert, oder Teile davon?
                  michaelxhoffmann
                  #66
                  @homoran Ich wüsste es zumindest nicht. Das lief alles einwandfrei bis zu dem Tag als ich den Admin auf 6.8.0 aktualisieren wollte
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #67
                    @homoran irgendwann mal bei etwas falsch abgebogen
                    https://forum.iobroker.net/post/1035886
                      #68
                      @crunchip Detektiv!
                        @crunchip Detektiv!
                        michaelxhoffmann
                        #69
                        @homoran Mit anderen Worten ich habe es ver....?
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #70
                          @michaelxhoffmann nö, noch nicht ganz
                          hast du oben erwähnten Befehl ausgeführt?
                            michaelxhoffmann
                            #71
                            @crunchip Ja
                            pi@raspberrypi:/opt/iobroker/node_modules/iobroker.web $ npm install --production
                            npm WARN config production Use `--omit=dev` instead.
                            npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                            added 137 packages, and audited 139 packages in 1m
                            10 packages are looking for funding
                              run `npm fund` for details
                            3 moderate severity vulnerabilities
                            To address all issues (including breaking changes), run:
                              npm audit fix --force
                            Run `npm audit` for details.
                              @crunchip Ja
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #72
                              @michaelxhoffmann ok, dann nochmal im selben Verzeichnis
                              npm install --omit=dev
                              anschließend
                              cd /opt/iobroker/node_modules/iobroker.socketio
                                anschließend
                                michaelxhoffmann
                                schrieb am zuletzt editiert von michaelxhoffmann
                                #73
                                @crunchip
                                Jo gemacht:
                                pi@raspberrypi:/opt/iobroker/node_modules/iobroker.web $ npm install --omit=dev
                                up to date, audited 139 packages in 5s
                                pi@raspberrypi:/opt/iobroker/node_modules/iobroker.socketio $ npm install --omit=dev
                                added 62 packages, and audited 64 packages in 28s
                                3 packages are looking for funding
                                1 moderate severity vulnerability
                                Socketio immer noch rot :(
                                  @crunchip
                                  Jo gemacht:
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #74
                                  @michaelxhoffmann ok, sollten dann jetzt wieder laufen
                                  eventuell auch mal
                                  sudo reboot
                                    eventuell auch mal
                                    sudo reboot
                                    michaelxhoffmann
                                    #75
                                    @crunchip nope :( Instanz bleibt rot
                                      #76
                                      @crunchip nope :( Adapter bleibt rot
                                      und was steht im log?????
                                        michaelxhoffmann
                                        #77
                                        @homoran ```
                                        host.raspberrypi
                                        2023-08-31 14:10:03.959	info	object deleted system.adapter.socketio.0
                                        host.raspberrypi
                                        2023-08-31 14:10:00.888	info	iobroker host.raspberrypi Counted 3 states (system.adapter.socketio.0.*) from states
                                        host.raspberrypi
                                        2023-08-31 14:10:00.751	info	iobroker host.raspberrypi Counted 2 states (io.socketio.0.*) from states
                                        host.raspberrypi
                                        2023-08-31 14:10:00.711	info	iobroker host.raspberrypi Counted 14 states of system.adapter.socketio.0
                                        host.raspberrypi
                                        2023-08-31 14:10:00.641	info	iobroker host.raspberrypi Counted 2 states of socketio.0
                                        host.raspberrypi
                                        2023-08-31 14:10:00.571	info	iobroker host.raspberrypi Counted 1 channels of socketio.0
                                        host.raspberrypi
                                        2023-08-31 14:10:00.442	info	iobroker host.raspberrypi Counted 1 instances of socketio.0
                                        host.raspberrypi
                                        2023-08-31 14:10:00.003	info	iobroker Delete instance "socketio.0"
                                        host.raspberrypi
                                        2023-08-31 14:09:54.509	info	iobroker del socketio.0
                                        host.raspberrypi
                                        2023-08-31 14:09:08.373	info	system.adapter.socketio.0 will be rebuilt
                                        host.raspberrypi
                                        2023-08-31 14:09:08.373	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
                                        host.raspberrypi
                                        2023-08-31 14:09:08.373	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        host.raspberrypi
                                        2023-08-31 14:09:08.372	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
                                        host.raspberrypi
                                        2023-08-31 14:09:08.371	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
                                        host.raspberrypi
                                        2023-08-31 14:09:08.370	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
                                        host.raspberrypi
                                        2023-08-31 14:09:04.753	info	instance system.adapter.socketio.0 started with pid 1994
                                        jarvis.0
                                        2023-08-31 14:09:02.390	info	Connection: WebSocket opened on port 8400 using http...
                                        crunchipC HomoranH 3 Antworten Letzte Antwort
                                          @homoran ```
                                          host.raspberrypi
                                          host.raspberrypi
                                          host.raspberrypi
                                          host.raspberrypi
                                          host.raspberrypi
                                          host.raspberrypi
                                          host.raspberrypi
                                          host.raspberrypi
                                          host.raspberrypi
                                          host.raspberrypi
                                          host.raspberrypi
                                          host.raspberrypi
                                          host.raspberrypi
                                          host.raspberrypi
                                          host.raspberrypi
                                          host.raspberrypi
                                          jarvis.0
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #78
                                          @michaelxhoffmann nur socketio und web funktioniert jetzt?
