  4. Nach Update auf Admin 5.8 Startet Biobroker nicht mehr
    5.2k
120 Beiträge 7 Kommentatoren 13.3k Aufrufe 5 Beobachtet
    @michaelxhoffmann sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
    Muss ich die instanz löschen und neu installieren?
    hast du doch sozusagen mit diesem Befehl
    was zeigt das log?
    michaelxhoffmann
    schrieb am zuletzt editiert von michaelxhoffmann
    @crunchip
    Verzeihung für die verspätete Rückmeldung.
    host.raspberrypi
    2023-08-30 16:29:02.653	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-30 16:29:02.653	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
    host.raspberrypi
    2023-08-30 16:29:02.652	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
    host.raspberrypi
    2023-08-30 16:29:02.651	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
    2023-08-30 16:28:55.213	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-30 16:28:55.213	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
    host.raspberrypi
    2023-08-30 16:28:55.212	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
    host.raspberrypi
    2023-08-30 16:28:55.211	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
    host.raspberrypi
    2023-08-30 16:28:52.231	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
    host.raspberrypi
    2023-08-30 16:28:52.230	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
    host.raspberrypi
    2023-08-30 16:28:52.230	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
    2023-08-30 16:21:32.979  - info: weatherunderground.0 (47533) State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-08-30 16:21:35.102  - info: weatherunderground.0 (47533) Terminated (NO_ERROR): Without reason
    2023-08-30 16:21:35.674  - info: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    2023-08-30 16:21:42.789  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:21:58.866  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:23:00.223  - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 47889
    2023-08-30 16:23:04.126  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:23:20.225  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:23:32.270  - warn: zigbee.0 (1093) Device '0x680ae2fffe06e802' announced itself
    2023-08-30 16:23:38.649  - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
    2023-08-30 16:24:25.470  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:24:41.741  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:24:52.207  - warn: zigbee.0 (1093) Device '0x680ae2fffe06e802' announced itself
    2023-08-30 16:25:46.955  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:25:58.028  - warn: zigbee.0 (1093) Device '0x680ae2fffe06e802' announced itself
    2023-08-30 16:26:03.046  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:26:54.035  - info: zigbee.0 (1093) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"},{"path":"/dev/ttyAMA0"}]
    2023-08-30 16:27:08.297  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:27:24.373  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:28:31.154  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:28:50.499  - info: host.raspberrypi instance system.adapter.socketio.0 started with pid 48906
    2023-08-30 16:28:51.678  - info: host.raspberrypi "system.adapter.socketio.0" disabled
    2023-08-30 16:28:51.679  - info: host.raspberrypi stopInstance system.adapter.socketio.0 (force=false, process=true)
    2023-08-30 16:28:52.066  - info: host.raspberrypi stopInstance system.adapter.socketio.0 send kill signal
    2023-08-30 16:28:52.228  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1080
    2023-08-30 16:28:52.229  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2023-08-30 16:28:52.229  - error: host.raspberrypi Caught by controller[0]:   ^
    2023-08-30 16:28:52.229  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
    2023-08-30 16:28:52.229  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2023-08-30 16:28:52.230  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
    2023-08-30 16:28:52.230  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
    2023-08-30 16:28:52.230  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
    2023-08-30 16:28:52.230  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-08-30 16:28:52.230  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:121:18)
    2023-08-30 16:28:52.230  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
    2023-08-30 16:28:52.231  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-08-30 16:28:52.231  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2023-08-30 16:28:52.231  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
    2023-08-30 16:28:52.231  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
    2023-08-30 16:28:52.231  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
    2023-08-30 16:28:52.231  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2023-08-30 16:28:52.231  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
    2023-08-30 16:28:52.231  - error: host.raspberrypi Caught by controller[0]: }
    2023-08-30 16:28:52.232  - error: host.raspberrypi Caught by controller[0]: Node.js v18.17.1
    2023-08-30 16:28:52.232  - info: host.raspberrypi instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-08-30 16:28:53.342  - info: host.raspberrypi "system.adapter.socketio.0" enabled
    2023-08-30 16:28:53.746  - info: host.raspberrypi instance system.adapter.socketio.0 started with pid 48913
    2023-08-30 16:28:55.210  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1080
    2023-08-30 16:28:55.210  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2023-08-30 16:28:55.210  - error: host.raspberrypi Caught by controller[0]:   ^
    2023-08-30 16:28:55.211  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
    2023-08-30 16:28:55.211  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2023-08-30 16:28:55.211  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
    2023-08-30 16:28:55.211  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
    2023-08-30 16:28:55.211  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
    2023-08-30 16:28:55.211  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-08-30 16:28:55.211  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:121:18)
    2023-08-30 16:28:55.212  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
    2023-08-30 16:28:55.212  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-08-30 16:28:55.212  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2023-08-30 16:28:55.212  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
    2023-08-30 16:28:55.212  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
    2023-08-30 16:28:55.212  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
    2023-08-30 16:28:55.212  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2023-08-30 16:28:55.213  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
    2023-08-30 16:28:55.213  - error: host.raspberrypi Caught by controller[0]: }
    2023-08-30 16:28:55.213  - error: host.raspberrypi Caught by controller[0]: Node.js v18.17.1
    2023-08-30 16:28:55.213  - error: host.raspberrypi instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-08-30 16:28:55.213  - info: host.raspberrypi Rebuild for adapter system.adapter.socketio.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2023-08-30 16:28:58.122  - info: host.raspberrypi "system.adapter.web.0" disabled
    2023-08-30 16:29:00.294  - info: host.raspberrypi "system.adapter.web.0" enabled
    2023-08-30 16:29:00.940  - info: host.raspberrypi instance system.adapter.web.0 started with pid 48931
    2023-08-30 16:29:02.650  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1080
    2023-08-30 16:29:02.651  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2023-08-30 16:29:02.651  - error: host.raspberrypi Caught by controller[0]:   ^
    2023-08-30 16:29:02.651  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
    2023-08-30 16:29:02.651  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2023-08-30 16:29:02.651  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
    2023-08-30 16:29:02.651  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
    2023-08-30 16:29:02.651  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
    2023-08-30 16:29:02.652  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-08-30 16:29:02.652  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:121:18)
    2023-08-30 16:29:02.652  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
    2023-08-30 16:29:02.652  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-08-30 16:29:02.652  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2023-08-30 16:29:02.652  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
    2023-08-30 16:29:02.652  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
    2023-08-30 16:29:02.652  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
    2023-08-30 16:29:02.653  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2023-08-30 16:29:02.653  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
    2023-08-30 16:29:02.653  - error: host.raspberrypi Caught by controller[0]: }
    2023-08-30 16:29:02.653  - error: host.raspberrypi Caught by controller[0]: Node.js v18.17.1
    2023-08-30 16:29:02.653  - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-08-30 16:29:02.653  - info: host.raspberrypi Rebuild for adapter system.adapter.web.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2023-08-30 16:29:36.406  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:29:52.530  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:30:00.225  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 49017
    2023-08-30 16:30:04.268  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 49032
    2023-08-30 16:30:15.920  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-08-30 16:30:22.444  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-30 16:30:57.809  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:31:13.877  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:32:19.137  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:32:35.231  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:33:40.478  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:33:56.568  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:35:01.824  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:35:17.928  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:36:23.184  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:36:39.238  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:37:44.523  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:38:00.738  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    Homematic CCU2 - Raspberry Pi 4 - IOS (siri) - Amazon Echo 3rd Gen.
    • M michaelxhoffmann
      @crunchip
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      crunchipC Abwesend
      crunchipC Abwesend
      @michaelxhoffmann dann mach es mit dem socketio genauso wie mit dem web
      iobroker rebuild socketio --install
        michaelxhoffmann
        @crunchip Hallo, das brachte leider keinen Erfolg. Weder web noch socketio lassen sich zum ordnungsgemässen Betrieb überreden
        	2023-08-31 13:01:34.504	warn	adapter "socketio" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
        host.raspberrypi
        2023-08-31 13:01:34.503	info	system.adapter.socketio.0 will be rebuilt
        host.raspberrypi
        2023-08-31 13:01:34.503	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
        host.raspberrypi
        2023-08-31 13:01:34.503	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.raspberrypi
        2023-08-31 13:01:34.502	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
        host.raspberrypi
        2023-08-31 13:01:34.501	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
        host.raspberrypi
        2023-08-31 13:01:34.500	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
        host.raspberrypi
        2023-08-31 13:01:32.964	info	instance system.adapter.socketio.0 started with pid 209364
        host.raspberrypi
        2023-08-31 13:01:32.565	info	"system.adapter.socketio.0" enabled
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          crunchipC Abwesend
          crunchipC Abwesend
          @michaelxhoffmann dann deinstalliere den Adapter socketio und installiere neu
            michaelxhoffmann
            @crunchip Gleiches Resultat :( Socket verbindet sich nicht mit dem Host Nun kommt noch dazu dass sich socket nicht mit dem Dienst verbindet
              crunchipC Abwesend
              crunchipC Abwesend
              @michaelxhoffmann Logausgabe und Instanz Einstellungen deines web und socketio
              Edit
              zusätzlich noch
              iob list instances
              und
              sudo netstat -tulpen
                michaelxhoffmann
                Protokoll zum socketio:
                host.raspberrypi
                2023-08-31 13:28:50.935	warn	adapter "socketio" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                host.raspberrypi
                2023-08-31 13:28:50.935	info	system.adapter.socketio.0 will be rebuilt
                host.raspberrypi
                2023-08-31 13:28:50.934	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
                host.raspberrypi
                2023-08-31 13:28:50.934	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.raspberrypi
                2023-08-31 13:28:50.934	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
                host.raspberrypi
                2023-08-31 13:28:50.933	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
                host.raspberrypi
                2023-08-31 13:28:50.932	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
                host.raspberrypi
                2023-08-31 13:28:49.509	info	instance system.adapter.socketio.0 started with pid 5371
                host.raspberrypi
                2023-08-31 13:28:16.619	warn	adapter "socketio" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                host.raspberrypi
                2023-08-31 13:28:16.618	info	system.adapter.socketio.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.12"})
                host.raspberrypi
                2023-08-31 13:28:16.617	info	Adapter system.adapter.socketio.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
                host.raspberrypi
                2023-08-31 13:28:16.617	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.raspberrypi
                2023-08-31 13:28:16.616	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
                host.raspberrypi
                2023-08-31 13:28:16.614	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
                host.raspberrypi
                2023-08-31 13:28:16.611	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
                host.raspberrypi
                2023-08-31 13:28:14.475	info	instance system.adapter.socketio.0 started with pid 5256
                host.raspberrypi
                2023-08-31 13:26:50.110	info	system.adapter.socketio.0 will be rebuilt
                host.raspberrypi
                2023-08-31 13:26:50.109	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
                host.raspberrypi
                2023-08-31 13:26:50.108	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.raspberrypi
                2023-08-31 13:26:50.107	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
                host.raspberrypi
                2023-08-31 13:26:50.103	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
                host.raspberrypi
                2023-08-31 13:26:50.100	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
                host.raspberrypi
                2023-08-31 13:26:47.178	info	instance system.adapter.socketio.0 started with pid 4379
                host.raspberrypi
                2023-08-31 13:26:39.441	info	iobroker host.raspberrypi object system.adapter.socketio.0 created
                host.raspberrypi
                2023-08-31 13:26:39.364	info	iobroker host.raspberrypi Set default value of socketio.0.info.connection: false
                host.raspberrypi
                2023-08-31 13:26:39.347	info	iobroker host.raspberrypi Set default value of socketio.0.info.connected:
                host.raspberrypi
                2023-08-31 13:26:39.319	info	iobroker host.raspberrypi object socketio.0.info.connection created
                host.raspberrypi
                2023-08-31 13:26:39.295	info	iobroker host.raspberrypi object socketio.0.info.connected created
                host.raspberrypi
                2023-08-31 13:26:39.031	info	iobroker host.raspberrypi object socketio.0.info created
                host.raspberrypi
                2023-08-31 13:26:39.010	info	iobroker host.raspberrypi object system.adapter.socketio.0.logLevel created
                host.raspberrypi
                2023-08-31 13:26:38.985	info	iobroker host.raspberrypi object system.adapter.socketio.0.sigKill created
                host.raspberrypi
                2023-08-31 13:26:38.959	info	iobroker host.raspberrypi object system.adapter.socketio.0.eventLoopLag created
                host.raspberrypi
                2023-08-31 13:26:38.934	info	iobroker host.raspberrypi object system.adapter.socketio.0.outputCount created
                host.raspberrypi
                2023-08-31 13:26:38.876	info	iobroker host.raspberrypi object system.adapter.socketio.0.inputCount created
                host.raspberrypi
                2023-08-31 13:26:38.817	info	iobroker host.raspberrypi object system.adapter.socketio.0.uptime created
                host.raspberrypi
                2023-08-31 13:26:38.791	info	iobroker host.raspberrypi object system.adapter.socketio.0.memRss created
                host.raspberrypi
                2023-08-31 13:26:38.710	info	iobroker host.raspberrypi object system.adapter.socketio.0.memHeapTotal created
                host.raspberrypi
                2023-08-31 13:26:38.673	info	iobroker host.raspberrypi object system.adapter.socketio.0.memHeapUsed created
                host.raspberrypi
                2023-08-31 13:26:38.636	info	iobroker host.raspberrypi object system.adapter.socketio.0.cputime created
                host.raspberrypi
                2023-08-31 13:26:38.609	info	iobroker host.raspberrypi object system.adapter.socketio.0.cpu created
                host.raspberrypi
                2023-08-31 13:26:38.483	info	iobroker host.raspberrypi object system.adapter.socketio.0.compactMode created
                host.raspberrypi
                2023-08-31 13:26:38.441	info	iobroker host.raspberrypi object system.adapter.socketio.0.connected created
                host.raspberrypi
                2023-08-31 13:26:38.414	info	iobroker host.raspberrypi object system.adapter.socketio.0.alive created
                host.raspberrypi
                2023-08-31 13:26:38.283	info	iobroker host.raspberrypi create instance socketio
                host.raspberrypi
                2023-08-31 13:26:31.577	info	iobroker add socketio --host raspberrypi
                Protokoll zum web.0
                2023-08-31 13:28:17.085	info	Rebuild for adapter system.adapter.web.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                host.raspberrypi
                2023-08-31 13:28:17.085	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.raspberrypi
                2023-08-31 13:28:17.085	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                host.raspberrypi
                2023-08-31 13:28:17.083	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                host.raspberrypi
                2023-08-31 13:28:17.082	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                host.raspberrypi
                2023-08-31 13:28:14.431	info	instance system.adapter.web.0 started with pid 5255
                host.raspberrypi
                2023-08-31 13:26:37.811	info	iobroker Adapter "system.adapter.web.0" restarted.
                host.raspberrypi
                2023-08-31 13:26:37.787	info	"system.adapter.web.0" enabled
                host.raspberrypi
                2023-08-31 13:26:37.733	info	"system.adapter.web.0" disabled
                host.raspberrypi
                2023-08-31 13:26:08.830	warn	adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                host.raspberrypi
                2023-08-31 13:26:08.830	info	system.adapter.web.0 will be rebuilt
                host.raspberrypi
                2023-08-31 13:26:08.829	info	Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
                host.raspberrypi
                2023-08-31 13:26:08.829	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.raspberrypi
                2023-08-31 13:26:08.829	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                host.raspberrypi
                2023-08-31 13:26:08.828	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                host.raspberrypi
                2023-08-31 13:26:08.827	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                host.raspberrypi
                2023-08-31 13:26:07.128	info	instance system.adapter.web.0 started with pid 3767
                host.raspberrypi
                2023-08-31 13:25:34.497	warn	adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                host.raspberrypi
                2023-08-31 13:25:34.496	info	system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.12"})
                host.raspberrypi
                2023-08-31 13:25:34.495	info	Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
                host.raspberrypi
                2023-08-31 13:25:34.494	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.raspberrypi
                2023-08-31 13:25:34.493	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                host.raspberrypi
                2023-08-31 13:25:34.490	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                host.raspberrypi
                2023-08-31 13:25:34.472	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                host.raspberrypi
                2023-08-31 13:25:32.619	info	instance system.adapter.web.0 started with pid 3505
                + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                  system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                + system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
                + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
                + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
                  system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                  system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
                + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
                + system.adapter.logparser.0              : logparser             : raspberrypi                              -  enabled
                + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
                  system.adapter.material.0               : material              : raspberrypi                              - disabled
                + system.adapter.milight-smart-light.0    : milight-smart-light   : raspberrypi                              -  enabled
                  system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
                + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                + system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
                + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                  system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3307
                + system.adapter.sql.1                    : sql                   : raspberrypi                              -  enabled, port: 3306
                + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                  system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                  system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                  system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                  system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                  system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
                + instance is alive
                tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       18486      1579/io.jarvis.0
                tcp        0      0 192.168.178.45:12001    0.0.0.0:*               LISTEN      1001       15018      1150/io.hm-rpc.1
                tcp        0      0 192.168.178.45:12010    0.0.0.0:*               LISTEN      1001       14269      1164/io.hm-rpc.2
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13841      541/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14545      501/iobroker.js-con
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13867      501/iobroker.js-con
                tcp        0      0 192.168.178.45:18701    0.0.0.0:*               LISTEN      1001       14246      1112/io.hm-rpc.0
                tcp6       0      0 :::22                   :::*                    LISTEN      0          13843      541/sshd: /usr/sbin
                tcp6       0      0 :::34915                :::*                    LISTEN      1001       17657      1523/io.yahka.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15493      865/io.admin.0
                tcp6       0      0 :::8091                 :::*                    LISTEN      1001       18044      1605/io.lovelace.0
                tcp6       0      0 :::8088                 :::*                    LISTEN      1001       18715      1654/io.terminal.0
                udp        0      0 0.0.0.0:45324           0.0.0.0:*                           1001       17550      1396/io.broadlink2.
                udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       15928      1396/io.broadlink2.
                udp        0      0 0.0.0.0:47924           0.0.0.0:*                           108        1818       399/avahi-daemon: r
                udp        0      0 0.0.0.0:46297           0.0.0.0:*                           1001       17696      1598/io.milight-sma
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1816       399/avahi-daemon: r
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12861      739/dhcpcd
                udp        0      0 0.0.0.0:43222           0.0.0.0:*                           1001       15931      1396/io.broadlink2.
                udp6       0      0 :::546                  :::*                                0          12873      739/dhcpcd
                udp6       0      0 :::5353                 :::*                                108        1817       399/avahi-daemon: r
                udp6       0      0 :::59241                :::*                                108        1819       399/avahi-daemon: r
                An dieser Stelle schon mal danke für die Arbeit die Du dir machst :)
                HomoranH crunchipC 3 Antworten Letzte Antwort
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  Protokoll zum web.0
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  + instance is alive
                  hast du wirklich den Adapter gelöscht, oder nur die Instanz?
                  M crunchipC 2 Antworten Letzte Antwort
                    michaelxhoffmann
                    @homoran Ich habe die Instanz gelöscht, dann den Adapter, anschließend habe ich den Adapter erneut installiert und die Instanz neu erstellt
                      das log sagt aber was anderes 🤔
                      ich nehme nicht an, dass du danach noch schnell die node-version verändert hast.
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        Protokoll zum web.0
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        + instance is alive
                        bei web steht das selbe
                          michaelxhoffmann
                          @homoran Die nodeversion? Ich wüsste nicht wie ich das sollte :) OK Was ich natürlich nicht gemacht habe ist ein Neustart des Raspis nach dem löschen des Adapters.
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            Protokoll zum web.0
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            + instance is alive
                            crunchipC Abwesend
                            crunchipC Abwesend
                            cd /opt/iobroker/node_modules/iobroker.web
                              hast du diese Installation irgendwoher kopiert, oder Teile davon?
                                michaelxhoffmann
                                #66
                                @homoran Ich wüsste es zumindest nicht. Das lief alles einwandfrei bis zu dem Tag als ich den Admin auf 6.8.0 aktualisieren wollte
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #67
                                  @homoran irgendwann mal bei etwas falsch abgebogen
                                  https://forum.iobroker.net/post/1035886
                                    #68
                                    @crunchip Detektiv!
                                      @crunchip Detektiv!
                                      michaelxhoffmann
                                      #69
                                      @homoran Mit anderen Worten ich habe es ver....?
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #70
                                        @michaelxhoffmann nö, noch nicht ganz
                                        hast du oben erwähnten Befehl ausgeführt?
                                          michaelxhoffmann
                                          #71
                                          @crunchip Ja
                                          pi@raspberrypi:/opt/iobroker/node_modules/iobroker.web $ npm install --production
                                          npm WARN config production Use `--omit=dev` instead.
                                          npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                          added 137 packages, and audited 139 packages in 1m
                                          10 packages are looking for funding
                                            run `npm fund` for details
                                          3 moderate severity vulnerabilities
                                          To address all issues (including breaking changes), run:
                                            npm audit fix --force
                                          Run `npm audit` for details.
