  4. Nach Update auf Admin 5.8 Startet Biobroker nicht mehr
    5.2k
120 Beiträge 7 Kommentatoren 13.3k Aufrufe 5 Beobachtet
  • M michaelxhoffmann
    @crunchip
    Verzeihung für die verspätete Rückmeldung.
    host.raspberrypi
    2023-08-30 16:29:02.653	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-30 16:29:02.653	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
    host.raspberrypi
    2023-08-30 16:29:02.652	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
    host.raspberrypi
    2023-08-30 16:29:02.651	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
    2023-08-30 16:28:55.213	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-30 16:28:55.213	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
    host.raspberrypi
    2023-08-30 16:28:55.212	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
    host.raspberrypi
    2023-08-30 16:28:55.211	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
    host.raspberrypi
    2023-08-30 16:28:52.231	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
    host.raspberrypi
    2023-08-30 16:28:52.230	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
    host.raspberrypi
    2023-08-30 16:28:52.230	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
    2023-08-30 16:21:32.979  - info: weatherunderground.0 (47533) State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
    2023-08-30 16:21:35.102  - info: weatherunderground.0 (47533) Terminated (NO_ERROR): Without reason
    2023-08-30 16:21:35.674  - info: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    2023-08-30 16:21:42.789  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:21:58.866  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:23:00.223  - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 47889
    2023-08-30 16:23:04.126  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:23:20.225  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:23:32.270  - warn: zigbee.0 (1093) Device '0x680ae2fffe06e802' announced itself
    2023-08-30 16:23:38.649  - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
    2023-08-30 16:24:25.470  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:24:41.741  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:24:52.207  - warn: zigbee.0 (1093) Device '0x680ae2fffe06e802' announced itself
    2023-08-30 16:25:46.955  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:25:58.028  - warn: zigbee.0 (1093) Device '0x680ae2fffe06e802' announced itself
    2023-08-30 16:26:03.046  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:26:54.035  - info: zigbee.0 (1093) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"1a86","pnpId":"usb-1a86_USB_Serial-if00-port0","vendorId":"1a86","productId":"7523"},{"path":"/dev/ttyAMA0"}]
    2023-08-30 16:27:08.297  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:27:24.373  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:28:31.154  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:28:50.499  - info: host.raspberrypi instance system.adapter.socketio.0 started with pid 48906
    2023-08-30 16:28:51.678  - info: host.raspberrypi "system.adapter.socketio.0" disabled
    2023-08-30 16:28:51.679  - info: host.raspberrypi stopInstance system.adapter.socketio.0 (force=false, process=true)
    2023-08-30 16:28:52.066  - info: host.raspberrypi stopInstance system.adapter.socketio.0 send kill signal
    2023-08-30 16:28:52.228  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1080
    2023-08-30 16:28:52.229  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2023-08-30 16:28:52.229  - error: host.raspberrypi Caught by controller[0]:   ^
    2023-08-30 16:28:52.229  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
    2023-08-30 16:28:52.229  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2023-08-30 16:28:52.230  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
    2023-08-30 16:28:52.230  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
    2023-08-30 16:28:52.230  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
    2023-08-30 16:28:52.230  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-08-30 16:28:52.230  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:121:18)
    2023-08-30 16:28:52.230  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
    2023-08-30 16:28:52.231  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-08-30 16:28:52.231  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2023-08-30 16:28:52.231  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
    2023-08-30 16:28:52.231  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
    2023-08-30 16:28:52.231  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
    2023-08-30 16:28:52.231  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2023-08-30 16:28:52.231  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
    2023-08-30 16:28:52.231  - error: host.raspberrypi Caught by controller[0]: }
    2023-08-30 16:28:52.232  - error: host.raspberrypi Caught by controller[0]: Node.js v18.17.1
    2023-08-30 16:28:52.232  - info: host.raspberrypi instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-08-30 16:28:53.342  - info: host.raspberrypi "system.adapter.socketio.0" enabled
    2023-08-30 16:28:53.746  - info: host.raspberrypi instance system.adapter.socketio.0 started with pid 48913
    2023-08-30 16:28:55.210  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1080
    2023-08-30 16:28:55.210  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2023-08-30 16:28:55.210  - error: host.raspberrypi Caught by controller[0]:   ^
    2023-08-30 16:28:55.211  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
    2023-08-30 16:28:55.211  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2023-08-30 16:28:55.211  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
    2023-08-30 16:28:55.211  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
    2023-08-30 16:28:55.211  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
    2023-08-30 16:28:55.211  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-08-30 16:28:55.211  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:121:18)
    2023-08-30 16:28:55.212  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
    2023-08-30 16:28:55.212  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-08-30 16:28:55.212  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2023-08-30 16:28:55.212  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
    2023-08-30 16:28:55.212  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
    2023-08-30 16:28:55.212  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
    2023-08-30 16:28:55.212  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2023-08-30 16:28:55.213  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
    2023-08-30 16:28:55.213  - error: host.raspberrypi Caught by controller[0]: }
    2023-08-30 16:28:55.213  - error: host.raspberrypi Caught by controller[0]: Node.js v18.17.1
    2023-08-30 16:28:55.213  - error: host.raspberrypi instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-08-30 16:28:55.213  - info: host.raspberrypi Rebuild for adapter system.adapter.socketio.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2023-08-30 16:28:58.122  - info: host.raspberrypi "system.adapter.web.0" disabled
    2023-08-30 16:29:00.294  - info: host.raspberrypi "system.adapter.web.0" enabled
    2023-08-30 16:29:00.940  - info: host.raspberrypi instance system.adapter.web.0 started with pid 48931
    2023-08-30 16:29:02.650  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1080
    2023-08-30 16:29:02.651  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2023-08-30 16:29:02.651  - error: host.raspberrypi Caught by controller[0]:   ^
    2023-08-30 16:29:02.651  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
    2023-08-30 16:29:02.651  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2023-08-30 16:29:02.651  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
    2023-08-30 16:29:02.651  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
    2023-08-30 16:29:02.651  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
    2023-08-30 16:29:02.652  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-08-30 16:29:02.652  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:121:18)
    2023-08-30 16:29:02.652  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
    2023-08-30 16:29:02.652  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-08-30 16:29:02.652  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2023-08-30 16:29:02.652  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
    2023-08-30 16:29:02.652  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
    2023-08-30 16:29:02.652  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
    2023-08-30 16:29:02.653  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2023-08-30 16:29:02.653  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
    2023-08-30 16:29:02.653  - error: host.raspberrypi Caught by controller[0]: }
    2023-08-30 16:29:02.653  - error: host.raspberrypi Caught by controller[0]: Node.js v18.17.1
    2023-08-30 16:29:02.653  - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-08-30 16:29:02.653  - info: host.raspberrypi Rebuild for adapter system.adapter.web.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2023-08-30 16:29:36.406  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:29:52.530  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:30:00.225  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 49017
    2023-08-30 16:30:04.268  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 49032
    2023-08-30 16:30:15.920  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-08-30 16:30:22.444  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-30 16:30:57.809  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:31:13.877  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:32:19.137  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:32:35.231  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:33:40.478  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:33:56.568  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:35:01.824  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:35:17.928  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:36:23.184  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:36:39.238  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:37:44.523  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    2023-08-30 16:38:00.738  - warn: zigbee.0 (1093) Device '0xec1bbdfffeac297a' announced itself
    crunchipC Abwesend
    crunchipC Abwesend
    @michaelxhoffmann dann mach es mit dem socketio genauso wie mit dem web
    iobroker rebuild socketio --install
      michaelxhoffmann
      @crunchip Hallo, das brachte leider keinen Erfolg. Weder web noch socketio lassen sich zum ordnungsgemässen Betrieb überreden
      	2023-08-31 13:01:34.504	warn	adapter "socketio" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
      host.raspberrypi
      2023-08-31 13:01:34.503	info	system.adapter.socketio.0 will be rebuilt
      host.raspberrypi
      2023-08-31 13:01:34.503	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
      host.raspberrypi
      2023-08-31 13:01:34.503	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi
      2023-08-31 13:01:34.502	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
      host.raspberrypi
      2023-08-31 13:01:34.501	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
      host.raspberrypi
      2023-08-31 13:01:34.500	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
      host.raspberrypi
      2023-08-31 13:01:32.964	info	instance system.adapter.socketio.0 started with pid 209364
      host.raspberrypi
      2023-08-31 13:01:32.565	info	"system.adapter.socketio.0" enabled
      Homematic CCU2 - Raspberry Pi 4 - IOS (siri) - Amazon Echo 3rd Gen.
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        crunchipC Abwesend
        crunchipC Abwesend
        @michaelxhoffmann dann deinstalliere den Adapter socketio und installiere neu
          michaelxhoffmann
          schrieb am zuletzt editiert von michaelxhoffmann
          @crunchip Gleiches Resultat :( Socket verbindet sich nicht mit dem Host Nun kommt noch dazu dass sich socket nicht mit dem Dienst verbindet
            crunchipC Abwesend
            crunchipC Abwesend
            @michaelxhoffmann Logausgabe und Instanz Einstellungen deines web und socketio
            Edit
            zusätzlich noch
            iob list instances
            und
            sudo netstat -tulpen
              michaelxhoffmann
              Protokoll zum socketio:
              host.raspberrypi
              2023-08-31 13:28:50.935	warn	adapter "socketio" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
              host.raspberrypi
              2023-08-31 13:28:50.935	info	system.adapter.socketio.0 will be rebuilt
              host.raspberrypi
              2023-08-31 13:28:50.934	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
              host.raspberrypi
              2023-08-31 13:28:50.934	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.raspberrypi
              2023-08-31 13:28:50.934	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
              host.raspberrypi
              2023-08-31 13:28:50.933	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
              host.raspberrypi
              2023-08-31 13:28:50.932	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
              host.raspberrypi
              2023-08-31 13:28:49.509	info	instance system.adapter.socketio.0 started with pid 5371
              host.raspberrypi
              2023-08-31 13:28:16.619	warn	adapter "socketio" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
              host.raspberrypi
              2023-08-31 13:28:16.618	info	system.adapter.socketio.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.12"})
              host.raspberrypi
              2023-08-31 13:28:16.617	info	Adapter system.adapter.socketio.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
              host.raspberrypi
              2023-08-31 13:28:16.617	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.raspberrypi
              2023-08-31 13:28:16.616	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
              host.raspberrypi
              2023-08-31 13:28:16.614	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
              host.raspberrypi
              2023-08-31 13:28:16.611	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
              host.raspberrypi
              2023-08-31 13:28:14.475	info	instance system.adapter.socketio.0 started with pid 5256
              host.raspberrypi
              2023-08-31 13:26:50.110	info	system.adapter.socketio.0 will be rebuilt
              host.raspberrypi
              2023-08-31 13:26:50.109	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
              host.raspberrypi
              2023-08-31 13:26:50.108	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.raspberrypi
              2023-08-31 13:26:50.107	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
              host.raspberrypi
              2023-08-31 13:26:50.103	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
              host.raspberrypi
              2023-08-31 13:26:50.100	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
              host.raspberrypi
              2023-08-31 13:26:47.178	info	instance system.adapter.socketio.0 started with pid 4379
              host.raspberrypi
              2023-08-31 13:26:39.441	info	iobroker host.raspberrypi object system.adapter.socketio.0 created
              host.raspberrypi
              2023-08-31 13:26:39.364	info	iobroker host.raspberrypi Set default value of socketio.0.info.connection: false
              host.raspberrypi
              2023-08-31 13:26:39.347	info	iobroker host.raspberrypi Set default value of socketio.0.info.connected:
              host.raspberrypi
              2023-08-31 13:26:39.319	info	iobroker host.raspberrypi object socketio.0.info.connection created
              host.raspberrypi
              2023-08-31 13:26:39.295	info	iobroker host.raspberrypi object socketio.0.info.connected created
              host.raspberrypi
              2023-08-31 13:26:39.031	info	iobroker host.raspberrypi object socketio.0.info created
              host.raspberrypi
              2023-08-31 13:26:39.010	info	iobroker host.raspberrypi object system.adapter.socketio.0.logLevel created
              host.raspberrypi
              2023-08-31 13:26:38.985	info	iobroker host.raspberrypi object system.adapter.socketio.0.sigKill created
              host.raspberrypi
              2023-08-31 13:26:38.959	info	iobroker host.raspberrypi object system.adapter.socketio.0.eventLoopLag created
              host.raspberrypi
              2023-08-31 13:26:38.934	info	iobroker host.raspberrypi object system.adapter.socketio.0.outputCount created
              host.raspberrypi
              2023-08-31 13:26:38.876	info	iobroker host.raspberrypi object system.adapter.socketio.0.inputCount created
              host.raspberrypi
              2023-08-31 13:26:38.817	info	iobroker host.raspberrypi object system.adapter.socketio.0.uptime created
              host.raspberrypi
              2023-08-31 13:26:38.791	info	iobroker host.raspberrypi object system.adapter.socketio.0.memRss created
              host.raspberrypi
              2023-08-31 13:26:38.710	info	iobroker host.raspberrypi object system.adapter.socketio.0.memHeapTotal created
              host.raspberrypi
              2023-08-31 13:26:38.673	info	iobroker host.raspberrypi object system.adapter.socketio.0.memHeapUsed created
              host.raspberrypi
              2023-08-31 13:26:38.636	info	iobroker host.raspberrypi object system.adapter.socketio.0.cputime created
              host.raspberrypi
              2023-08-31 13:26:38.609	info	iobroker host.raspberrypi object system.adapter.socketio.0.cpu created
              host.raspberrypi
              2023-08-31 13:26:38.483	info	iobroker host.raspberrypi object system.adapter.socketio.0.compactMode created
              host.raspberrypi
              2023-08-31 13:26:38.441	info	iobroker host.raspberrypi object system.adapter.socketio.0.connected created
              host.raspberrypi
              2023-08-31 13:26:38.414	info	iobroker host.raspberrypi object system.adapter.socketio.0.alive created
              host.raspberrypi
              2023-08-31 13:26:38.283	info	iobroker host.raspberrypi create instance socketio
              host.raspberrypi
              2023-08-31 13:26:31.577	info	iobroker add socketio --host raspberrypi
              Protokoll zum web.0
              2023-08-31 13:28:17.085	info	Rebuild for adapter system.adapter.web.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
              host.raspberrypi
              2023-08-31 13:28:17.085	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.raspberrypi
              2023-08-31 13:28:17.085	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
              host.raspberrypi
              2023-08-31 13:28:17.083	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
              host.raspberrypi
              2023-08-31 13:28:17.082	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
              host.raspberrypi
              2023-08-31 13:28:14.431	info	instance system.adapter.web.0 started with pid 5255
              host.raspberrypi
              2023-08-31 13:26:37.811	info	iobroker Adapter "system.adapter.web.0" restarted.
              host.raspberrypi
              2023-08-31 13:26:37.787	info	"system.adapter.web.0" enabled
              host.raspberrypi
              2023-08-31 13:26:37.733	info	"system.adapter.web.0" disabled
              host.raspberrypi
              2023-08-31 13:26:08.830	warn	adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
              host.raspberrypi
              2023-08-31 13:26:08.830	info	system.adapter.web.0 will be rebuilt
              host.raspberrypi
              2023-08-31 13:26:08.829	info	Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
              host.raspberrypi
              2023-08-31 13:26:08.829	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.raspberrypi
              2023-08-31 13:26:08.829	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
              host.raspberrypi
              2023-08-31 13:26:08.828	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
              host.raspberrypi
              2023-08-31 13:26:08.827	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
              host.raspberrypi
              2023-08-31 13:26:07.128	info	instance system.adapter.web.0 started with pid 3767
              host.raspberrypi
              2023-08-31 13:25:34.497	warn	adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
              host.raspberrypi
              2023-08-31 13:25:34.496	info	system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.12"})
              host.raspberrypi
              2023-08-31 13:25:34.495	info	Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
              host.raspberrypi
              2023-08-31 13:25:34.494	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.raspberrypi
              2023-08-31 13:25:34.493	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
              host.raspberrypi
              2023-08-31 13:25:34.490	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
              host.raspberrypi
              2023-08-31 13:25:34.472	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
              host.raspberrypi
              2023-08-31 13:25:32.619	info	instance system.adapter.web.0 started with pid 3505
              + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
              + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
              + system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
              + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
              + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
                system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
              + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
              + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
              + system.adapter.logparser.0              : logparser             : raspberrypi                              -  enabled
              + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
                system.adapter.material.0               : material              : raspberrypi                              - disabled
              + system.adapter.milight-smart-light.0    : milight-smart-light   : raspberrypi                              -  enabled
                system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
              + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
              + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
              + system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
              + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
              + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3307
              + system.adapter.sql.1                    : sql                   : raspberrypi                              -  enabled, port: 3306
              + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
              + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
              + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
              + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
              + instance is alive
              tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       18486      1579/io.jarvis.0
              tcp        0      0 192.168.178.45:12001    0.0.0.0:*               LISTEN      1001       15018      1150/io.hm-rpc.1
              tcp        0      0 192.168.178.45:12010    0.0.0.0:*               LISTEN      1001       14269      1164/io.hm-rpc.2
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13841      541/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14545      501/iobroker.js-con
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13867      501/iobroker.js-con
              tcp        0      0 192.168.178.45:18701    0.0.0.0:*               LISTEN      1001       14246      1112/io.hm-rpc.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          13843      541/sshd: /usr/sbin
              tcp6       0      0 :::34915                :::*                    LISTEN      1001       17657      1523/io.yahka.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15493      865/io.admin.0
              tcp6       0      0 :::8091                 :::*                    LISTEN      1001       18044      1605/io.lovelace.0
              tcp6       0      0 :::8088                 :::*                    LISTEN      1001       18715      1654/io.terminal.0
              udp        0      0 0.0.0.0:45324           0.0.0.0:*                           1001       17550      1396/io.broadlink2.
              udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       15928      1396/io.broadlink2.
              udp        0      0 0.0.0.0:47924           0.0.0.0:*                           108        1818       399/avahi-daemon: r
              udp        0      0 0.0.0.0:46297           0.0.0.0:*                           1001       17696      1598/io.milight-sma
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1816       399/avahi-daemon: r
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12861      739/dhcpcd
              udp        0      0 0.0.0.0:43222           0.0.0.0:*                           1001       15931      1396/io.broadlink2.
              udp6       0      0 :::546                  :::*                                0          12873      739/dhcpcd
              udp6       0      0 :::5353                 :::*                                108        1817       399/avahi-daemon: r
              udp6       0      0 :::59241                :::*                                108        1819       399/avahi-daemon: r
              An dieser Stelle schon mal danke für die Arbeit die Du dir machst :)
              HomoranH crunchipC 3 Antworten Letzte Antwort
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                Protokoll zum web.0
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                + instance is alive
                @michaelxhoffmann sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
                hast du wirklich den Adapter gelöscht, oder nur die Instanz?
                M crunchipC 2 Antworten Letzte Antwort
                  michaelxhoffmann
                  @homoran Ich habe die Instanz gelöscht, dann den Adapter, anschließend habe ich den Adapter erneut installiert und die Instanz neu erstellt
                    das log sagt aber was anderes 🤔
                    ich nehme nicht an, dass du danach noch schnell die node-version verändert hast.
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      Protokoll zum web.0
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      + instance is alive
                      bei web steht das selbe
                        michaelxhoffmann
                        @homoran Die nodeversion? Ich wüsste nicht wie ich das sollte :) OK Was ich natürlich nicht gemacht habe ist ein Neustart des Raspis nach dem löschen des Adapters.
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          Protokoll zum web.0
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          host.raspberrypi
                          + instance is alive
                          crunchipC Abwesend
                          crunchipC Abwesend
                          cd /opt/iobroker/node_modules/iobroker.web
                            hast du diese Installation irgendwoher kopiert, oder Teile davon?
                              michaelxhoffmann
                              #66
                              @homoran Ich wüsste es zumindest nicht. Das lief alles einwandfrei bis zu dem Tag als ich den Admin auf 6.8.0 aktualisieren wollte
                                crunchipC Abwesend
                                crunchipC Abwesend
                                #67
                                @homoran irgendwann mal bei etwas falsch abgebogen
                                https://forum.iobroker.net/post/1035886
                                  #68
                                  @crunchip Detektiv!
                                    @crunchip Detektiv!
                                    michaelxhoffmann
                                    #69
                                    @homoran Mit anderen Worten ich habe es ver....?
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      #70
                                      @michaelxhoffmann nö, noch nicht ganz
                                      hast du oben erwähnten Befehl ausgeführt?
                                        michaelxhoffmann
                                        #71
                                        @crunchip Ja
                                        pi@raspberrypi:/opt/iobroker/node_modules/iobroker.web $ npm install --production
                                        npm WARN config production Use `--omit=dev` instead.
                                        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                        added 137 packages, and audited 139 packages in 1m
                                        10 packages are looking for funding
                                          run `npm fund` for details
                                        3 moderate severity vulnerabilities
                                        To address all issues (including breaking changes), run:
                                          npm audit fix --force
                                        Run `npm audit` for details.
                                          @crunchip Ja
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #72
                                          @michaelxhoffmann ok, dann nochmal im selben Verzeichnis
                                          npm install --omit=dev
                                          anschließend
                                          cd /opt/iobroker/node_modules/iobroker.socketio
