  4. Update des admin Moduls auf 6.8.0 schlug fehl.
    5.2k
55 Beiträge 8 Kommentatoren 5.8k Aufrufe 6 Beobachtet
    @arnulf
    iob diag
    sagt nun zu der Kiste?
    Arnulf
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     13:59:20 up  1:09,  3 users,  load average: 1.25, 2.47, 2.67
    CPU threads: 4
    Raspberry only:
    throttled=0x70000
    Other values than 0x0 hint to temperature/voltage problems
    temp=64.5'C
    volt=1.3000V
    *** Time and Time Zones ***
                   Local time: Sat 2023-08-26 13:59:21 CEST
               Universal time: Sat 2023-08-26 11:59:21 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            921M        617M         59M         15M        245M        234M
    Swap:            99M         99M        0.0K
    Total:          1.0G        717M         59M
              921 M total memory
              617 M used memory
              198 M active memory
              507 M inactive memory
               59 M free memory
               18 M buffer memory
              226 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       29G  4.8G   24G  17% /
    devtmpfs       devtmpfs  333M     0  333M   0% /dev
    tmpfs          tmpfs     461M   12M  450M   3% /dev/shm
    tmpfs          tmpfs     185M  1.1M  184M   1% /run
    /dev/mmcblk0p1 vfat      255M   61M  195M  24% /boot
    tmpfs          tmpfs      93M   20K   93M   1% /run/user/1000
    [Sat Aug 26 12:49:31 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c1dab352-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sat Aug 26 12:49:34 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Sat Aug 26 12:49:34 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Sat Aug 26 12:49:37 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Sat Aug 26 12:49:37 2023] EXT4-fs (mmcblk0p2): 4 orphan inodes deleted
    [Sat Aug 26 12:49:37 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Sat Aug 26 12:49:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Aug 26 12:49:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sat Aug 26 12:49:40 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    725M    /var/
    354M    /var/cache
    342M    /var/cache/apt
    278M    /var/cache/apt/archives
    148M    /var/log
    Archived and active journals take up 144.0M in the file system.
    /opt/iobroker/backups:
    9.9M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    101M    /opt/iobroker/iobroker-data/
    85M     /opt/iobroker/iobroker-data/files
    45M     /opt/iobroker/iobroker-data/files/devices.admin/static
    44M     /opt/iobroker/iobroker-data/files/devices.admin/static/js
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    9.1M    /opt/iobroker/iobroker-data/objects.jsonl
    8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
    6.8M    /opt/iobroker/iobroker-data/states.jsonl
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.8.0
    javascript:     "javascript" not found
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker1                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.admin.1                  : admin                 : ioBroker2                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker2                                -  enabled
      system.adapter.backitup.0               : backitup              : ioBroker1                                -  enabled
    + system.adapter.ble.0                    : ble                   : ioBroker1                                -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : ioBroker2                                -  enabled
    + system.adapter.deconz.0                 : deconz                : ioBroker1                                -  enabled, port: 80
      system.adapter.devices.0                : devices               : ioBroker1                                - disabled
    + system.adapter.discovery.0              : discovery             : ioBroker2                                -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : ioBroker1                                - disabled
      system.adapter.history.0                : history               : ioBroker1                                - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker2                                - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker2                                - disabled
    + system.adapter.info.0                   : info                  : ioBroker1                                -  enabled
      system.adapter.mqtt.0                   : mqtt                  : ioBroker1                                -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.node-red.0               : node-red              : ioBroker1                                -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : ioBroker1                                -  enabled, port: 1884, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : ioBroker1                                - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker1                                - disabled
      system.adapter.vis.0                    : vis                   : ioBroker1                                - disabled
      system.adapter.web.0                    : web                   : ioBroker1                                - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.8.0    , installed 6.8.0
    Adapter    "backitup"     : 2.6.23   , installed 2.4.6  [Updatable]
    Adapter    "ble"          : 0.13.4   , installed 0.11.0 [Updatable]
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "devices"      : 1.1.5    , installed 1.0.10 [Updatable]
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "history"      : 2.2.4    , installed 1.11.1 [Updatable]
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.1  [Updatable]
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.16 [Updatable]
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.2.0  [Updatable]
    Objects and States
    Objects:        6085
    States:         32162
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       39948      7343/io.sonoff.0
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       38016      6860/iobroker.js-co
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       34810      6860/iobroker.js-co
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14404      567/cupsd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          24808      3426/sshd: /usr/sbi
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       38080      6888/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          24810      3426/sshd: /usr/sbi
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14403      567/cupsd
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12261      514/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15416      734/cups-browsed
    udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       19064      1829/chromium-brows
    udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       19062      1829/chromium-brows
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11159      423/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       41140      8067/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       41137      8067/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       41133      8067/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       41130      8067/io.deconz.0
    udp        0      0 0.0.0.0:53152           0.0.0.0:*                           108        11161      423/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          739        514/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        11160      423/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       41142      8067/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       41141      8067/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       41139      8067/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       41138      8067/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       41135      8067/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       41134      8067/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       41132      8067/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       41131      8067/io.deconz.0
    udp6       0      0 :::46502                :::*                                108        11162      423/avahi-daemon: r
    2023-08-26 13:58:18.048  - info: host.ioBroker1 iobroker upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/forum.js lib/js/forum.js application/javascript
    2023-08-26 13:58:18.067  - info: host.ioBroker1 iobroker upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/githubData.js lib/js/githubData.js application/javascript
    2023-08-26 13:58:18.088  - info: host.ioBroker1 iobroker upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/helper.js lib/js/helper.js application/javascript
    2023-08-26 13:58:18.107  - info: host.ioBroker1 iobroker upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
    2023-08-26 13:58:18.130  - info: host.ioBroker1 iobroker upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/info.js lib/js/info.js application/javascript
    2023-08-26 13:58:18.148  - info: host.ioBroker1 iobroker upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/news.js lib/js/news.js application/javascript
    2023-08-26 13:58:18.168  - info: host.ioBroker1 iobroker upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/popupnews.js lib/js/popupnews.js application/javascript
    2023-08-26 13:58:18.218  - info: host.ioBroker1 iobroker upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/searchGithub.js lib/js/searchGithub.js application/javascript
    2023-08-26 13:58:18.240  - info: host.ioBroker1 iobroker upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
    2023-08-26 13:58:18.260  - info: host.ioBroker1 iobroker upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/simplemde.min.js lib/js/simplemde.min.js application/javascript
    2023-08-26 13:58:18.288  - info: host.ioBroker1 iobroker upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/systemInformation.js lib/js/systemInformation.js application/javascript
    2023-08-26 13:58:18.306  - info: host.ioBroker1 iobroker upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/updateAdapter.js lib/js/updateAdapter.js application/javascript
    2023-08-26 13:58:18.326  - info: host.ioBroker1 iobroker upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
    2023-08-26 13:58:18.376  - info: host.ioBroker1 iobroker upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
    2023-08-26 13:58:19.519  - info: host.ioBroker1 iobroker exit 0
    2023-08-26 13:58:26.111  - info: info.0 (8942) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2023-08-26 13:58:27.220  - info: info.0 (8942) starting. Version 1.9.26 in /opt/iobroker/node_modules/iobroker.info, node: v18.17.1, js-controller: 4.0.24
    2023-08-26 13:58:27.626  - info: info.0 (8942) Reading/updating systemdata.
    2023-08-26 13:58:28.822  - info: info.0 (8942) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
    2023-08-26 13:58:28.970  - info: info.0 (8942) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
    2023-08-26 13:58:29.030  - info: info.0 (8942) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
    2023-08-26 13:58:29.095  - info: info.0 (8942) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
    2023-08-26 13:58:29.155  - info: info.0 (8942) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
    2023-08-26 13:58:29.492  - info: info.0 (8942) cpu Temp res = {"main":66.604,"cores":[],"max":66.604,"socket":[],"chipset":null}
    2023-08-26 13:58:44.477  - info: info.0 (8942) State value to set for "info.0.sysinfo.disks.diskLayout.dev0.size" has to be type "string" but received type "number"
    iob diag has finished.
    Press any key for a summary
    DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
    • A Arnulf
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x70000
      temp=64.5'C
      volt=1.3000V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M         99M        0.0K
                921 M total memory
                617 M used memory
                198 M active memory
                 59 M free memory
                 18 M buffer memory
                226 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      725M    /var/
      354M    /var/cache
      342M    /var/cache/apt
      148M    /var/log
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        6085
      States:         32162
      Pending Updates: 0
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @arnulf bitte in Codetags packen
      Lehrling seit 1975 !!!
      • A Arnulf
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=raspbian
        ID_LIKE=debian
        CPU threads: 4
        Raspberry only:
        throttled=0x70000
        temp=64.5'C
        volt=1.3000V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M         99M        0.0K
                  921 M total memory
                  617 M used memory
                  198 M active memory
                   59 M free memory
                   18 M buffer memory
                  226 M swap cache
                   99 M total swap
                   99 M used swap
                    0 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        725M    /var/
        354M    /var/cache
        342M    /var/cache/apt
        148M    /var/log
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.8.0
        Adapter State
        + instance is alive
        Objects and States
        Objects:        6085
        States:         32162
        Pending Updates: 0
        @arnulf
        Warum kein 32bit?
        Warum keinen individuellen User?
        Warum bremst die Kiste?
        Warum ist das Dateisystem schon Reparatur bedürftig?
        Warum mit Desktop?
        Weiter les ich das jetzt nicht mehr.
        Mach eine 64bit-Installation wie vorgesehen:
        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
          @arnulf
          Warum kein 32bit?
          Warum mit Desktop?
          Arnulf
          weil 32 Bit bei der Installation vorgegeben war.
          Auch der Desktop (habe ihn bereits deaktiviert
          Keine Ahnung, warum Filesystem schon wieder kaputt
          Wenn du mir nur einen Namen des OS nennst, nehme ich den für die Suchmaschine und suche mir ein Image.
          Ich bin da hin gegangen:
          https://www.raspberrypi.com/software/
          Habe den Installer installiert und da gab es nicht wirklich viel Auswahlmöglichkeiten
          Und von Bullseye eben nur die 32Bit-Version
          Wenn du mehr weißt, dann solltest du es dazu schreiben
          Und den ioBroker habe ich per curl-Kommandozeile laut der ioBroker-Homepage installiert
          curl -sLf https://iobroker.net/install.sh | bash -
          Mehr weiß ich nicht
          DJMarc75D Thomas BraunT W 3 Antworten Letzte Antwort
          • A Arnulf
            Mehr weiß ich nicht
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @arnulf sagte in Update des admin Moduls auf 6.8.0 schlug fehl.:
            Warum nicht mal selber Initiative ergreifen ?
            • A Arnulf
              Mehr weiß ich nicht
              Ich hab zu den Thema schon so viel geschrieben, das wiederhole ich nicht ständig.
              • A Arnulf
                Mehr weiß ich nicht
                W Online
                W Online
                Wildbill
                schrieb am zuletzt editiert von Wildbill
                Hast Du vielleicht voller Ungeduld weil es nicht ging oder etwas hing den Neustart beschleunigt und einfach den Strom abgezogen anstatt sauber neu zu starten? Beim Raspi versemmelt man sich so sehr schnell das Dateisystem und unter Umständen auch gleich die SD-Karte, so dass nicht nur eine Neuinstallation Sinn macht, sondern gleich eine neue SD-Karte nötig ist.
                Gruss, Jürgen
                  Arnulf
                  Nach vielen Versuchen musste ich dann doch einen etwas anderen Weg gehen:
                  Die Installation von Bullseye ging zwar, aber es lies sich leider das RaspBEE-Modul ums Verrecken nicht ansprechen.
                  Nachdem ich dann das SD-Image von der Deconz-Seite verwendet habe, läuft Deconz wieder.
                  Allerdings ist es noch das Buster-Image.
                  Bei meinem ioBroker läuft jetzt wieder eine ganze Menge.
                  Allerdings bekomme ich, beim Versuch bestimmte Adapter zu konfigurieren, einen Fehler angezeigt:
                  File index_m.html not found
                  (also die Seite, die aufgehen sollte, wenn man in der Instanzenliste auf den Schraubenschlüssel klickt)
                  Leider findet man unter dem Suchstring "File index_m.html not found" im Forum nicht wirklich was.
                  Der Adapter erscheint in der Instantzenliste als grün. Aber trotzdem scheint er nicht zu funktionieren.
                  Zumindest bei meinen Tests.
                  Ich wollte bei der Konfiguration nachschauen und bekomme eine nicht gefundene Webseite als Ergebnis.
                  Problem bei:
                  alexa2
                  broadlink
                  vis
                  Andere Adapter, wie zum Beispiel sonoff, scheinen beim Restore korrekt wiederhergestellt worden zu sein.
                  Hat jemand eine Idee, wo ich nachschauen könnte?
                  Ein Versuch, die gleiche Version noch einmal drüber zu installieren, hat nichts gebracht. Da bekomme ich den Error 25
                  4954 timing reify:rollback:retireShallow Completed in 586ms
                  4955 timing command:install Completed in 86679ms
                  4956 verbose stack Error: ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/accepts' -> '/opt/iobroker/node_modules/.accepts-rBwU1CL
                  7'
                  4957 verbose cwd /opt/iobroker
                  4958 verbose Linux 4.14.79-v7+
                  4959 verbose node v16.20.2
                  4960 verbose npm  v8.19.4
                  4961 error code ENOTEMPTY
                  4962 error syscall rename
                  4963 error path /opt/iobroker/node_modules/accepts
                  4964 error dest /opt/iobroker/node_modules/.accepts-rBwU1CL7
                  4965 error errno -39
                  4966 error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/accepts' -> '/opt/iobroker/node_modules/.accepts-rBwU1CL7'
                  4967 verbose exit -39
                  4968 timing npm Completed in 87514ms
                  4969 verbose unfinished npm timer reify 1693299670065
                  4970 verbose unfinished npm timer reify:retireShallow 1693299754820
                  4971 verbose code -39
                  4972 error A complete log of this run can be found in:
                  4972 error     /home/iobroker/.npm/_logs/2023-08-29T09_01_09_229Z-debug-0.log
                  Ja, ich hatte er Restore gemacht.
                  Und ja, ich habe lange gewartet, bis ich nachgeschaut habe (bestimmt 2-3 Stunden)
                  Zu sagen ist, dass Alexa2 auf dem Slave installiert ist/war.
                  Der Restore lief auf dem Master
                  Ein iob fix habe ich versucht.
                  Dieser läuft beim Master auch komplett durch.
                  Beim Slave kommt nach dem Command "iob fix" sofort wieder der prompt
                  pi@ioBroker2:/home/iobroker/.npm/_logs $ iob fix
                  • A Arnulf
                    Problem bei:
                    alexa2
                    broadlink
                    vis
                    7'
                    bist du mobil unterwegs?
                    lass mal das _m weg dann findest du gefühlt 1000 Threads
                    • W Wildbill
                      Gruss, Jürgen
                      Arnulf
                      @wildbill mittlerweile habe ich bestimmt 2x eine neue SD-Karte neu geschrieben.
                      Davor war ich wohl 1x zu schnell. ich wusste nicht, dass nach dem Restore noch eine Menge im Hintergrund läuft.
                      (Wäre gut, wenn der Restore dazu eine Info heraus geben würde)
                      Danach noch einmal.
                      Jetzt nach 2 weiteren Versuchen (und dem Buster-Image) geht schon etwas mehr. Aber noch nicht alles
                        Arnulf
                        öh. Ne. Ich rufe das vom PC aus auf.
                        • A Arnulf
                          Problem bei:
                          alexa2
                          broadlink
                          vis
                          7'
                          und du hast jetzt
                          was ist denn jetzt deine vollständige Basis?
                          welche?
                          • A Arnulf
                            Danach noch einmal.
                            was bei einem Raspi schon mal 1h dauern kann.
                            der Restore ist ja fertig.
                            Anschließend baut der js-controller alles neu. Sieht man auch im log
                              und du hast jetzt
                              welche?
                              Arnulf
                              @homoran sagte in Update des admin Moduls auf 6.8.0 schlug fehl.:
                              und du hast jetzt
                              welche?
                              Ja, Das offizielle Image von der Deconz-.Seite verwendet. Ohne grafischem Frontend.
                              Das ist (laut deren Seite) noch Buster
                              Darauf habe ich dann iobroker installiert miz
                              Dann ein Restore gestartet (auf dem Master)
                              Danach Master und Slave wieder zusammen gebracht.
                              Allerdings nach der ersten Methode von dieser Seite
                              https://www.iobroker.net/docu/index-24.htm?page_id=3068&lang=de
                              Denn die verkürzte Version klappte nicht, weil die Datenbank nicht rkannt wurde
                              Lief soweit ohne erkennbare Fehler durch
                              Die Fehlermeldung bei der Neuinstallation der neusten Alexa2-Version ist:
                              $ iobroker upgrade alexa2@3.24.1 --debug
                              Update alexa2 from @3.24.1 to @3.24.1
                              Installing iobroker.alexa2@3.24.1... (System call)
                              npm ERR! code ENOTEMPTY
                              npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-08-29T09_25_58_379Z-debug-0.log
                              host.ioBroker2 Cannot install iobroker.alexa2@3.24.1: 217
                              ERROR: Process exited with code 25
                                Arnulf
                                wie vorhin geschrieben, habe ich diesmal sicher 2-3 Stunden gewartet
                                • A Arnulf
                                  und du hast jetzt
                                  welche?
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  noch Buster
                                  warum installiert man sowas?
                                  daher wohl auch
                                  installier ein aktuelles OS und danach dein deConz manuell
                                  A 2 Antworten Letzte Antwort
                                    noch Buster
                                    daher wohl auch
                                    Arnulf
                                    @crunchip sagte in Update des admin Moduls auf 6.8.0 schlug fehl.:
                                    noch Buster
                                    daher wohl auch
                                    auch das hatte ich scvhon geschrieben
                                    Buster, weil sonst der RaspBEE nicht ansprechbar war. Und das Deconz-Image gibt es nur als Buster-Image
                                      noch Buster
                                      daher wohl auch
                                      Arnulf
                                      noch Buster
                                      daher wohl auch
                                      Das manuelle Installieren habe ich ja auch schon gemacht.
                                      Ergebnis: Dekonz lief nicht
                                      • A Arnulf
                                        noch Buster
                                        daher wohl auch
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        Dekonz lief nicht
                                        warum nicht?
                                          Dekonz lief nicht
                                          warum nicht?
                                          Arnulf
                                          Dekonz lief nicht
                                          warum nicht?
                                          wenn ich das mal wüsste.
                                          Meine Anfrage hat noch niemand beantwortet
                                          https://forum.iobroker.net/topic/67869/raspbee-die-1-version-und-bullseye-wollen-nicht?_=1693297933216
                                          Zumindest konnte ich die Phoscon-Oberfläche nicht aufrufen auf dem Raspi.
                                          Wenn ich das mit dem kaputten image gemacht habe, lief zumindest die Phoscon-Oberfläche.
                                          Und auch mit dem Deconz-Image (unter Buster) bringt mir die Phoscon-Oberfläche:
                                          Das Einzige ist: Mit dem Firefox scheint die Oberfläche ein Problem zu haben.
                                          Mit Edge geht es aber
