  4. Adapter: SMA SEMP
Adapter: SMA SEMP
264 Beiträge 30 Kommentatoren 98.8k Aufrufe 28 Beobachtet
  • arteckA arteck
    @rene_hm
    nene
    master semp.0: exception in WriteCSVLog [Error: ENOENT: no such file or directory, open '']
    04 Jun 2023 20:20:35.164
     master semp.0: exception in CreateFilename [Error: ENOENT: no such file or directory, stat '/home/iobroker/semp.csv']
    und mit dem . oder ohne.. auch nicht
    <?xml version="1.0" encoding="utf-8"?> <Device2EM xmlns="http://www.sma.de/communication/schema/SEMP/v1"> <DeviceInfo> <Identification> <DeviceId>F-7442202-000000000001-00</DeviceId> <DeviceName>Waschmaschiene</DeviceName> <DeviceType>WashingMachine</DeviceType> <DeviceSerial>111111111111</DeviceSerial> <DeviceVendor>Siemens</DeviceVendor> </Identification> <Characteristics> <MaxPowerConsumption>3500</MaxPowerConsumption> </Characteristics> <Capabilities> <CurrentPower> <Method>Measurement</Method> </CurrentPower> <Timestamps> <AbsoluteTimestamps>false</AbsoluteTimestamps> </Timestamps> <Interruptions> <InterruptionsAllowed>false</InterruptionsAllowed> </Interruptions> <Requests> <OptionalEnergy>false</OptionalEnergy> </Requests> </Capabilities> </DeviceInfo> <DeviceInfo> <Identification> <DeviceId>F-7442202-000000000002-00</DeviceId> <DeviceName>Hundi_Waschmaschiene</DeviceName> <DeviceType>WashingMachine</DeviceType> <DeviceSerial>2222222222</DeviceSerial> <DeviceVendor>Samsung</DeviceVendor> </Identification> <Characteristics> <MaxPowerConsumption>3500</MaxPowerConsumption> </Characteristics> <Capabilities> <CurrentPower> <Method>Measurement</Method> </CurrentPower> <Timestamps> <AbsoluteTimestamps>false</AbsoluteTimestamps> </Timestamps> <Interruptions> <InterruptionsAllowed>false</InterruptionsAllowed> </Interruptions> <Requests> <OptionalEnergy>false</OptionalEnergy> </Requests> </Capabilities> </DeviceInfo> <DeviceStatus> <DeviceId>F-7442202-000000000001-00</DeviceId> <EMSignalsAccepted>true</EMSignalsAccepted> <Status>On</Status> <PowerConsumption> <PowerInfo> <AveragePower>0</AveragePower> <Timestamp>0</Timestamp> <AveragingInterval>60</AveragingInterval> </PowerInfo> </PowerConsumption> </DeviceStatus> <DeviceStatus> <DeviceId>F-7442202-000000000002-00</DeviceId> <EMSignalsAccepted>true</EMSignalsAccepted> <Status>On</Status> <PowerConsumption> <PowerInfo> <AveragePower>0</AveragePower> <Timestamp>0</Timestamp> <AveragingInterval>60</AveragingInterval> </PowerInfo> </PowerConsumption> </DeviceStatus> </Device2EM>
    Rene_HMR
    Rene_HMR
    Rene_HM
    #173
    @arteck versuche es mal ohne Angaber der csv-Datei, einfach nur /home/iobroker. Die csv legt der Adapter selbst an.
    und bzgl. Device-ID: wenn du den Punkt weglässt, musst du noch ein Zeichen hinzufügen. Dieser Teil der DeviceID muss 8 Zeichen lang sein.
    Hat der Adapter die BaseID mit dem Punkt selbst generiert? Wenn ja, muss ich das noch beheben...
    • Rene_HMR Rene_HM
      arteckA
      arteckA
      arteck
      #174
      @rene_hm sagte in Adapter: SMA SEMP:
      jo hat der
      ahhh ok dann schau ich mal...
      mist hast recht ..muss ich schauen .. ich habs nur gelöscht
      mit der Datei check ich auch.. das hab ich nicht gemacht..
      NAchtrag : jo gehts.. mit ohne angabe der csv also nur mit /home/iobroker gehts..
      und mit den 8 Stelligen kennung ..hab ich die Geräte jetzt auch im sunny Portal
      • Stefan GönczyS
        Stefan GönczyS
        Stefan Gönczy
        #175
        Moin,
        ich habe mal eine Frage : Ich versuche seit einer Woche einen Verbraucher als KANN Verbraucher einzurichten .
        Ich möchte eine Pumpe bei Solar-Überschuss vom Home Manager einschalten lassen und wieder aus ...
        Ich habe jetzt das Gerät so Konfiguriert :
        Min-Leistung : 100 W Max : 5000 W
        Energieanfragen : Timer aktiv - Täglich 08:00 - 20:00 - Min-Lauf 00:05 Max-Lauf 02:00
        trotz dem schaltet der HomeManager das Gerät dauerhaft von 8-20 Uhr an ( egal ob überschuss oder nicht ) ...
        Was habe ich falsch gemacht ?
        Gruß Stefan
        Rene_HMR 1 Antwort Letzte Antwort
        • Stefan GönczyS Stefan Gönczy
          Moin,
          Gruß Stefan
          Rene_HMR
          Rene_HMR
          Rene_HM
          #176
          @stefan-gönczy Im SunnyPortal wird die "verbrauchte" Energie auch angezeigt?
          wie hier für den Kühlschrank?
          Stefan GönczyS 1 Antwort Letzte Antwort
          • Rene_HMR Rene_HM
            Stefan GönczyS
            Stefan GönczyS
            Stefan Gönczy
            #177
            @rene_hm nein - da wird nichts angezeigt ...
              Rene_HMR
              Rene_HMR
              Rene_HM
              #178
              @stefan-gönczy Wie hast du die "Messung" konfiguriert?
              • Rene_HMR Rene_HM
                Stefan GönczyS
                Stefan GönczyS
                Stefan Gönczy
                #179
                @rene_hm Einschätzung - bei der Steckdose gibt es keine Messung ...
                  Rene_HMR
                  Rene_HMR
                  Rene_HM
                  #180
                  @stefan-gönczy und wie ist der nächste tab konfiguriert?
                  • Rene_HMR Rene_HM
                    Stefan GönczyS
                    Stefan GönczyS
                    Stefan Gönczy
                    #181
                    @rene_hm Entschuldigung - war die letzten Tag im Ausland ...
                    Der Reiter ist mit den Steckdosen - Schaltpnkten ( beide aud den "switch" von der Steckdose ( Manuell schalten über iobroker funktioniert ) ...
                    Gruß Stefan
                      Gruß Stefan
                      Stefan GönczyS
                      Stefan GönczyS
                      Stefan Gönczy
                      #182
                      @stefan-gönczy Jetzt scheint die eine Steckdose zu funktionieren ...
                      ABER : Ich kann keine weiteren Geräte installieren - das Sunny-Portal findet keine neuen Geräte ...
                        Rene_HMR
                        Rene_HMR
                        Rene_HM
                        #183
                        @stefan-gönczy schick mir bitte mal ein debug log... per email oder im github...
                        • Rene_HMR Rene_HM
                          Stefan GönczyS
                          Stefan GönczyS
                          Stefan Gönczy
                          schrieb am zuletzt editiert von Stefan Gönczy
                          #184
                          @rene_hm doofe Frage : wo finde ich den?
                            Rene_HMR
                            Rene_HMR
                            Rene_HM
                            #185
                            @stefan-gönczy schau hier docu
                            • Rene_HMR Rene_HM
                              Stefan GönczyS
                              Stefan GönczyS
                              Stefan Gönczy
                              #186
                              @rene_hm iobroker.2023-08-24.log.gz
                                Stefan GönczyS
                                Stefan GönczyS
                                Stefan Gönczy
                                #187
                                @stefan-gönczy das Sunny-Portal erkennt gar keine Geräte mehr - ich habe schon versucht den Adapter neu zu installieren - ohne Erfolg…
                                  Rene_HMR
                                  Rene_HMR
                                  Rene_HM
                                  #188
                                  @stefan-gönczy habe ein paar Fragen zum log:
                                  • das log ist vom 24.08.2023, nicht von heute?
                                  • bis 10:05 Uhr scheint alles in Ordnung zu sein, es werden regelmässig Daten von "Teichpumpe-Garten" an den SHM gesendet.
                                  • weisst du noch, was du dann gemacht hast?
                                  Für mich scheint es, als wäre zu diesem Zeitpunkt eine neu Instanz vom semp installiert worden. (semp.1). Die Instanz steht aber wohl nicht auf debug, und loggt somit auch nichts...
                                  Stefan GönczyS 2 Antworten Letzte Antwort
                                  • Rene_HMR Rene_HM
                                    Stefan GönczyS
                                    Stefan GönczyS
                                    Stefan Gönczy
                                    #189
                                    @rene_hm Moin, ich kann die Datei nicht senden da sie zu gross ist …
                                    • Rene_HMR Rene_HM
                                      Stefan GönczyS
                                      Stefan GönczyS
                                      Stefan Gönczy
                                      #190
                                      @rene_hm ja, da habe ich versucht einen neuen Adapter zu installieren…
                                      Die Pumpe wurde nicht vom Home-Hanager erkannt - auch keine anderen ( neu angelegten Geräte) … Die Log´s werdene geschrieben ( semp.1 ) leider ist der log zu groß um ihn hier senden zu können …
                                        Rene_HMR
                                        Rene_HMR
                                        Rene_HM
                                        #191
                                        @stefan-gönczy laufen beide Instanzen? Ich würde die semp.1 löschen und nur semp.0 verwenden.
                                        Das log kannst du mir auch per email an info@rg-engineering.eu senden
                                        • Rene_HMR Rene_HM
                                          Stefan GönczyS
                                          Stefan GönczyS
                                          Stefan Gönczy
                                          #192
                                          @rene_hm Moin, habe Dir die Logs gesendet - von meiner Firmen-Mail ( stefan@heino-heizung.de ) …
                                          Egal welch Instanz läuft - es werden keine Geräte gefunden …
                                          33.2k
                                          84.3k
