  4. Test Adapter powerfox v0.0.2-x
powerfoxenergy meterenergy monitorenergy
147 Beiträge 28 Kommentatoren 30.5k Aufrufe 23 Beobachtet
  • B Blotto112
    host.raspberrypi
    2023-01-09 17:37:54.001 warn instance system.adapter.powerfox2.0 already running with pid 284100
    host.raspberrypi
    2023-01-09 17:37:45.001 warn instance system.adapter.powerfox2.0 already running with pid 284100
    host.raspberrypi
    2023-01-09 17:37:36.002 warn instance system.adapter.powerfox2.0 already running with pid 284100
    host.raspberrypi
    2023-01-09 17:37:27.002 warn instance system.adapter.powerfox2.0 already running with pid 284100
    host.raspberrypi
    2023-01-09 17:37:18.003 warn instance system.adapter.powerfox2.0 already running with pid 284100
    host.raspberrypi
    2023-01-09 17:37:09.002 warn instance system.adapter.powerfox2.0 already running with pid 284100
    host.raspberrypi
    2023-01-09 17:37:00.002 warn instance system.adapter.powerfox2.0 already running with pid 284100
    host.raspberrypi
    2023-01-09 17:36:54.001 warn instance system.adapter.powerfox2.0 already running with pid 284100
    host.raspberrypi
    2023-01-09 17:36:45.001 warn instance system.adapter.powerfox2.0 already running with pid 284100
    host.raspberrypi
    2023-01-09 17:36:36.002 warn instance system.adapter.powerfox2.0 already running with pid 284100
    host.raspberrypi
    2023-01-09 17:36:27.001 warn instance system.adapter.powerfox2.0 already running with pid 284100
    host.raspberrypi
    2023-01-09 17:36:18.003 warn instance system.adapter.powerfox2.0 already running with pid 284100
    host.raspberrypi
    2023-01-09 17:36:09.002 warn instance system.adapter.powerfox2.0 already running with pid 284100
    host.raspberrypi
    2023-01-09 17:36:00.003 warn instance system.adapter.powerfox2.0 already running with pid 284100
    host.raspberrypi
    2023-01-09 17:35:54.002 warn instance system.adapter.powerfox2.0 already running with pid 284100
    host.raspberrypi
    2023-01-09 17:35:45.002 warn instance system.adapter.powerfox2.0 already running with pid 284100
    host.raspberrypi
    2023-01-09 17:35:36.001 warn instance system.adapter.powerfox2.0 already running with pid 284100
    Habe nichts verändert
    #108
    @blotto112
    Bitte Text immer in CodeTags eingebettet posten. Danke.
      @blotto112
      Blotto112
      #109
      Habe es alles gelöscht.
      Neu Installiert.
      Nun gehts wieder
      N 1 Antwort Letzte Antwort
      • B Blotto112
        Neu Installiert.
        Nun gehts wieder
        N Offline
        N Offline
        nobbiman
        #110
        @blotto112
        Ich habe auch immer wieder das Problem, dass die Daten im ioBroker nicht aktualisiert werden - in der powerfox-App sind sie zu sehen. Heute habe ich wieder mal auf "timestamp" im Device geschaut und gesehen, dass die letzte Aktualisierung vom 16.7. war, das sind jetzt 5 Tage her. Im Log ist kein Fehler zu sehen!
        Deinstalliere ich den Adapter und installiere ihn neu, geht es wieder ein paar Tage - gefühlt 1x je Woche muss ich de- und neuinstallieren; ein Dauerzustand sieht anders aus!
        Hat jemand eine Idee, woran das liegt, bzw. was ich unternehmen könnte, um das Problem zu beseitigen?
        Meine Adapterversion ist die 0.0.12 und ich weiß schon, dass ich hier im Thread v0.0.2-x bin, der wird mir aber im ioBroker nicht angeboten, aber wo bekomme ich den denn her?
        • N nobbiman
          @blotto112
          JoergH
          #111
          @nobbiman
          Du musst oben auf den Kopf klicken, dann über die Katze von GitHub installieren, dann kriegst Du auch die neuste Version.
          • J JoergH
            @nobbiman
            N Offline
            N Offline
            nobbiman
            #112
            @joergh Oh, noch nie gemacht, wieder etwas gelernt! Ist die Debug-Ausgabe zu installieren?
            • N nobbiman
              JoergH
              #113
              @nobbiman sagte in Test Adapter powerfox v0.0.2-x:
              Was meinst Du damit? Die Debug Ausgabe kann man aktivieren in den Einstellungen der Instanz, wenn man den Expertenmodus auswählt.
              • J JoergH
                N Offline
                N Offline
                nobbiman
                schrieb am zuletzt editiert von nobbiman
                #114
                @joergh bei der Installation über die Katze erscheint die Checkbox "Debug-Ausgaben"
                • N nobbiman
                  JoergH
                  #115
                  @nobbiman Achso. Da wird nichts installiert, sondern er zeigt Dir eine Debug Ausgabe während der Installation an.
                  • J JoergH
                    N Offline
                    N Offline
                    nobbiman
                    #116
                    @joergh OK und Danke
                    • bazidibavariaB bazidibavaria
                      ich habe einen Adapter erstellt um die powerfox-Api zu verarbeiten.
                      Zurzeit werden nur die aktuellen Daten minütlich abgeholt (kann aber über den schedule-tab in der Instanz geändert werden).
                      Hier der Link zum Github-Projekt:
                      https://github.com/bazidibavaria/ioBroker.powerfox.git
                      ioBroker.powerfox
                      Changelog
                      0.0.2-4 (2020-09-07)
                      (bazidibavaria) split current power into power consumption and feed in
                      0.0.2-3 (2020-09-07)
                      (bazidibavaria) added support for HEAT/WATER Devices
                      (bazidibavaria) update npm packages
                      0.0.2-2 (2020-08-27)
                      (bazidibavaria) changed log from error to info
                      0.0.2-1 (2020-08-27)
                      (bazidibavaria) added travis-ci
                      0.0.2-0 (2020-08-27)
                      (bazidibavaria) prerelease
                      0.0.1 (2020-08-25)
                      (bazidibavaria) initial commit
                      Ich freue mich auf euer Feedback.
                      LG bazidibavaria
                      TurboSasch
                      #117
                      ich habe heute auch den PowerFox Adapter installiert und bekomme im Log immer das angezeigt:
                      powerfox2.0
                      2023-08-14 19:12:01.904 info Terminated (NO_ERROR): Without reason
                      powerfox2.0
                      2023-08-14 19:12:00.901 info starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v16.20.1, js-controller: 4.0.24
                      Was heißt das und was müsste gegebenfalls geändert werden?
                      • T TurboSasch
                        powerfox2.0
                        powerfox2.0
                        N Offline
                        N Offline
                        nobbiman
                        #118
                        @turbosasch Ist wie die Fehlermeldung schon sagt, "NO ERROR", also kein Fehler! Der Adapter startet halt für jede Abfrage neu und endet (terminated) danach mit dieser Meldung!
                        • A AxLED
                          @hydraold
                          habe mich mal an der Überarbeitung des Adapters versucht: Adapter powerfox2
                          AxLED
                          ATARI
                          #119
                          @axled Danke das Du den Adapter weiter pflegst.
                          Hallo zusammen.
                          Bei mir lief die akt. Version 0.0.12 auf einem TinkerBoard S und auf einer Synology DS im Docker ohne Probleme.
                          Nach dem Totalausfall vom TinkerBoard habe ich mir einen Raspberry Pi 4 zugelegt.
                          Auch hier lief der powerfox2 ohne Probleme.
                          Vor ein paar Tagen habe ich den ioBroker auf dem Raspberry Pi und im Docker auf den akt. Stand gebracht. (Admin, node.js, npm, js-controller…)
                          Nach dem Update des js-controller von v4.x auf v5.x läuft powerfox2 nicht mehr
                          auf dem Raspberry Pi, auf Synology im Docker aber weiterhin ohne Probleme.
                          Als Fehler erhalte ich:
                          instance system.adapter.powerfox2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          Löschen, neuinstallieren, reboot, iobroker update && upgrade… blieb auf dem Pi erfolglos.
                          Hat jemand eine Idee?
                          ATARI
                          ATARI
                          Raspberry Pi 5B (ioB via pi OS_lite(64bit) | Synology NAS (ioB via Docker)
                          Fibaro Home Center 2 & Home Center 3 | Homematic IP | EMS-ESP32 Gateway
                          Aeotec Z-Wave | Tuya 4 in 1 Gateway | Zigbee & BLE Gateway
                          • A ATARI
                            Hallo zusammen.
                            ATARI
                            #120
                            @atari sagte in Test Adapter powerfox v0.0.2-x:
                            Zeig mal die Langfassung von
                            iob diag
                              iob diag
                              ATARI
                              #121
                              mit Langfassung meinst Du die "Summary"?
                              ATARI
                                ATARI
                                #122
                                                     v.2023-06-20
                                   Static hostname: pi
                                         Icon name: computer
                                        Machine ID: xxxxxxxxxxxxxxxxxxxx
                                           Boot ID: xxxxxxxxxxxxxxxxxxxx
                                  Operating System: Debian GNU/Linux 11 (bullseye)
                                            Kernel: Linux 6.1.21-v8+
                                      Architecture: arm64
                                Kernel:                 aarch64
                                Userland:               arm64
                                User-ID:                1000
                                X-Server:               false
                                Boot Target:            multi-user.target
                                Pending OS-Updates:     0
                                Pending iob updates:    0
                                Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                                        /usr/bin/node           v18.17.1
                                                        /usr/bin/npm            9.6.7
                                                        /usr/bin/npx            9.6.7
                                Recommended versions are nodejs 18.x.y and npm 9.x.y
                                MEMORY:
                                Mem:            7.8G        1.4G        5.7G        1.0M        640M        6.2G
                                Swap:            99M          0B         99M
                                Total:          7.9G        1.4G        5.8G
                                Active iob-Instances:   18
                                Active repo(s): stable
                                ioBroker Core:          js-controller           5.0.12
                                                        admin                   6.10.1
                                Objects type: jsonl
                                States  type: jsonl
                                + system.adapter.admin.0                  : admin                 : pi                                       -  enabled, port: 8081, bind: 0.0.0
                                + system.adapter.web.0                    : web                   : pi                                       -  enabled, port: 8082, bind: 0.0.0
                                Objects:                6327
                                States:                 4833
                                Size of iob-Database:
                                22M     /opt/iobroker/iobroker-data/objects.jsonl
                                3.0M    /opt/iobroker/iobroker-data/states.jsonl
                                ATARI
                                • A ATARI
                                  #123
                                  Nein, die Langfassung ist die Langfassung, 'Summary' ist die Zusammenfassung.
                                    ATARI
                                    #124
                                    Skript v.2023-06-20
                                    *** BASE SYSTEM ***
                                       Static hostname: pi
                                             Icon name: computer
                                            Machine ID: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                               Boot ID: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                          Architecture: arm64
                                    Model           : Raspberry Pi 4 Model B Rev 1.5
                                    Docker          : false
                                    Virtualization  : none
                                    Kernel          : aarch64
                                    Userland        : arm64
                                    Systemuptime and Load:
                                     16:10:12 up  5:12,  1 user,  load average: 0.44, 0.82, 1.35
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x0
                                    Other values than 0x0 hint to temperature/voltage problems
                                    temp=40.9'C
                                    volt=0.9360V
                                    *** Time and Time Zones ***
                                                   Local time: Mon 2023-09-25 16:10:12 CEST
                                               Universal time: Mon 2023-09-25 14:10:12 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    *** User and Groups ***
                                    admin
                                    /home/admin
                                    admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                    *** X-Server-Setup ***
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            7.8G        1.4G        5.7G        1.0M        717M        6.3G
                                    Swap:            99M          0B         99M
                                             7812 M total memory
                                             1394 M used memory
                                             1476 M active memory
                                              479 M inactive memory
                                             5700 M free memory
                                               76 M buffer memory
                                              641 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       59G  3.2G   53G   6% /
                                    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                                    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                    tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
                                    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                    tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                                    [Mon Sep 25 10:58:06 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:66:1B:1C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b80df8ab-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Mon Sep 25 10:58:07 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Mon Sep 25 10:58:07 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                    [Mon Sep 25 10:58:09 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                    TARGET  SOURCE         FSTYPE OPTIONS
                                    /       /dev/mmcblk0p2 ext4   rw,noatime
                                    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    /var:
                                    634M    /var/
                                    207M    /var/log
                                    193M    /var/log/journal/a8c446969d5b4d38975daa054bdd92b5
                                    180M    /var/cache
                                    Archived and active journals take up 192.0M in the file system.
                                    /opt/iobroker/backups:
                                    38M     /opt/iobroker/backups/
                                    /opt/iobroker/iobroker-data:
                                    242M    /opt/iobroker/iobroker-data/
                                    113M    /opt/iobroker/iobroker-data/files
                                    88M     /opt/iobroker/iobroker-data/backup-objects
                                    52M     /opt/iobroker/iobroker-data/files/javascript.admin
                                    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                                    27M     /opt/iobroker/iobroker-data/objects.jsonl
                                    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                                    16M     /opt/iobroker/iobroker-data/states.jsonl
                                    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
                                    7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
                                    *** NodeJS-Installation ***
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
                                    nodejs:
                                      Installed: 18.17.1-deb-1nodesource1
                                      Candidate: 18.17.1-deb-1nodesource1
                                      Version table:
                                     *** 18.17.1-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                         12.22.12~dfsg-1~deb11u4 500
                                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                         12.22.12~dfsg-1~deb11u3 500
                                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                    No problems detected
                                    npm ERR! code ELSPROBLEMS
                                    npm ERR! missing: http@^0.0.1-security, required by iobroker.javascript@7.1.4
                                    npm ERR! missing: modbus-serial@^8.0.13, required by iobroker.javascript@7.1.4
                                    npm ERR! missing: serial@^0.0.9, required by iobroker.javascript@7.1.4
                                    npm ERR! missing: usb@^2.10.0, required by iobroker.javascript@7.1.4
                                    npm ERR! A complete log of this run can be found in: /home/admin/.npm/_logs/2023-09-25T14_10_18_185Z-debug-0.log
                                    Errors in npm tree: 0
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    No configuration change needed.
                                    Multihost discovery server: disabled
                                    Discovery authentication:   enabled
                                    Persistent activation:      disabled
                                    Objects:                    jsonl on 127.0.0.1
                                    States:                     jsonl on 127.0.0.1
                                    Core adapters versions
                                    js-controller:  5.0.12
                                    admin:          6.10.1
                                    javascript:     7.1.4
                                    Adapters from github:   1
                                    Adapter State
                                    + system.adapter.admin.0                  : admin                 : pi                                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.alexa2.0                 : alexa2                : pi                                       -  enabled
                                    + system.adapter.backitup.0               : backitup              : pi                                       -  enabled
                                    + system.adapter.discovery.0              : discovery             : pi                                       -  enabled
                                    + system.adapter.email.0                  : email                 : pi                                       -  enabled
                                    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : pi                                       -  enabled
                                      system.adapter.feiertage.0              : feiertage             : pi                                       -  enabled
                                    + system.adapter.followthesun.0           : followthesun          : pi                                       -  enabled
                                      system.adapter.homepilot.0              : homepilot             : pi                                       - disabled
                                    + system.adapter.info.0                   : info                  : pi                                       -  enabled
                                    + system.adapter.javascript.0             : javascript            : pi                                       -  enabled
                                      system.adapter.netatmo-crawler.0        : netatmo-crawler       : pi                                       -  enabled
                                    + system.adapter.netatmo.0                : netatmo               : pi                                       -  enabled
                                      system.adapter.powerfox2.0              : powerfox2             : pi                                       -  enabled
                                      system.adapter.schoolfree.0             : schoolfree            : pi                                       -  enabled
                                    + system.adapter.shelly.0                 : shelly                : pi                                       -  enabled, port: 1882, bind: 0.0.0.0
                                    + system.adapter.simple-api.0             : simple-api            : pi                                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                    + system.adapter.smartgarden.0            : smartgarden           : pi                                       -  enabled
                                    + system.adapter.sonos.0                  : sonos                 : pi                                       -  enabled
                                    + system.adapter.sony-bravia.0            : sony-bravia           : pi                                       -  enabled
                                    + system.adapter.sony-bravia.1            : sony-bravia           : pi                                       -  enabled
                                    + system.adapter.tr-064.0                 : tr-064                : pi                                       -  enabled
                                    + system.adapter.web.0                    : web                   : pi                                       -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    + instance is alive
                                    ioBroker-Repositories
                                    Installed ioBroker-Instances
                                    Used repository: stable
                                    Adapter    "admin"        : 6.10.1   , installed 6.10.1
                                    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                                    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                                    Adapter    "email"        : 1.2.0    , installed 1.2.0
                                    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                                    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                                    Adapter    "followthesun" : 0.4.2    , installed 0.4.2
                                    Adapter    "homepilot"    : 1.1.6    , installed 1.1.6
                                    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                    Controller "js-controller": 5.0.12   , installed 5.0.12
                                    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                                    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                    Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
                                    Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
                                    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                                    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
                                    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                                    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
                                    Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
                                    Adapter    "web"          : 6.1.2    , installed 6.1.2
                                    Adapter    "ws"           : 2.5.5    , installed 2.5.5
                                    Objects and States
                                    Objects:        6757
                                    States:         5200
                                    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:2 http://deb.debian.org/debian bullseye InRelease
                                    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                                    Reading package lists...
                                    Pending Updates: 0
                                    *** Listening Ports ***
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       143047     20981/iobroker.js-c
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       143040     20981/iobroker.js-c
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13563      544/sshd: /usr/sbin
                                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       145602     21318/io.simple-api
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       147174     21470/io.web.0
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       143101     21000/io.admin.0
                                    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       143148     21084/io.sonos.0
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          13565      544/sshd: /usr/sbin
                                    udp        0      0 192.168.0.101:5353      0.0.0.0:*                           1001       145461     21169/io.tr-064.0
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15368      394/avahi-daemon: r
                                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       144211     21065/io.shelly.0
                                    udp        0      0 0.0.0.0:51391           0.0.0.0:*                           1001       155154     21065/io.shelly.0
                                    udp        0      0 0.0.0.0:60589           0.0.0.0:*                           108        15370      394/avahi-daemon: r
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11804      737/dhcpcd
                                    udp6       0      0 :::546                  :::*                                0          12706      737/dhcpcd
                                    udp6       0      0 :::5353                 :::*                                108        15369      394/avahi-daemon: r
                                    udp6       0      0 :::51198                :::*                                108        15371      394/avahi-daemon: r
                                    2023-09-25 16:10:34.690  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37100 with length 114
                                    2023-09-25 16:10:37.690  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 32000 with length 116
                                    2023-09-25 16:10:40.040  - info: host.pi instance system.adapter.powerfox2.0 started with pid 23068
                                    2023-09-25 16:10:40.700  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37000 with length 68
                                    2023-09-25 16:10:41.836  - error: host.pi instance system.adapter.powerfox2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2023-09-25 16:10:43.701  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37700 with length 100
                                    2023-09-25 16:10:46.701  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37800 with length 100
                                    2023-09-25 16:10:49.701  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 38200 with length 100
                                    2023-09-25 16:10:50.043  - info: host.pi instance system.adapter.powerfox2.0 started with pid 23102
                                    2023-09-25 16:10:51.201  - error: host.pi instance system.adapter.powerfox2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2023-09-25 16:10:52.701  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 38300 with length 100
                                    2023-09-25 16:10:55.701  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 38400 with length 100
                                    2023-09-25 16:10:56.976  - info: javascript.0 (21042) script.js.common.Huawei.Sonnen_Azimuth: -131.5
                                    2023-09-25 16:10:58.702  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 35300 with length 40
                                    2023-09-25 16:11:00.066  - info: host.pi instance system.adapter.powerfox2.0 started with pid 23135
                                    2023-09-25 16:11:01.134  - error: host.pi instance system.adapter.powerfox2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2023-09-25 16:11:01.702  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Processing new data...
                                    2023-09-25 16:11:01.710  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Processing done!
                                    2023-09-25 16:11:01.711  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 30000 with length 81
                                    2023-09-25 16:11:04.703  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37100 with length 114
                                    2023-09-25 16:11:07.704  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 32000 with length 116
                                    2023-09-25 16:11:10.048  - info: host.pi instance system.adapter.powerfox2.0 started with pid 23556
                                    2023-09-25 16:11:10.705  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37000 with length 68
                                    2023-09-25 16:11:11.332  - error: host.pi instance system.adapter.powerfox2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2023-09-25 16:11:13.705  - info: javascript.0 (21042) script.js.common.Huawei.get_data: Triggering read of inverter 1 at address 37700 with length 100
                                    ATARI
                                    • A ATARI
                                      Skript v.2023-06-20
                                      *** BASE SYSTEM ***
                                         Static hostname: pi
                                               Icon name: computer
                                            Architecture: arm64
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : arm64
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x0
                                      temp=40.9'C
                                      volt=0.9360V
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      admin
                                      /home/admin
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:            99M          0B         99M
                                               7812 M total memory
                                               1394 M used memory
                                               5700 M free memory
                                                 76 M buffer memory
                                                641 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      634M    /var/
                                      207M    /var/log
                                      180M    /var/cache
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.10.1
                                      javascript:     7.1.4
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        6757
                                      States:         5200
                                      Pending Updates: 0
                                      #125
                                      Installier den nochmal:
                                      iobroker upgrade iobroker.javascript@7.1.4
                                        ATARI
                                        schrieb am zuletzt editiert von ATARI
                                        #126
                                        JS Upgrade ändert nix.
                                        Der Adapter erkennt zwar meinen PowerFox als Gerät
                                        (somit ist die Anmeldung korrekt) aber es werden unter
                                        "/Objekte/powerfox2/0/devices" keine weiteren Datenpunkte
                                        angelegt.
                                        ATARI
                                        • A ATARI
                                          angelegt.
                                          #127
                                          @atari
                                          Sind die Fehlermeldungen nun weg?
                                          Hast du den
                                          iob fix
                                          mal ausgeführt?
                                          Du könntest auch den 'node fix' aus meiner Signatur ausführen, dann wärst du auch an der Stelle auf dem aktuellen Stand.
                                          A 3 Antworten Letzte Antwort
