  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Sayit-Adapter seit gestern stumm
sayit problem ausgabetext to speech
48 Beiträge 6 Kommentatoren 6.7k Aufrufe 5 Beobachtet
    @crunchip
    Jetzt wird es spooky, habe mal ein Backup vom 30.07.2023 gestartet. Es läuft gar kein text to speak mehr.
    Irgendwie können die devices gar nicht mehr angesprochen werden.
    sayit.4	2023-08-13 19:20:51.011	error	Error while checking if chromecast.0.d4f54704fa54.player.announcement finished playing announcement: {"url":"http://192.168.178.10:8082/sayit.4/tts.mp3?ts=1691947240501","volume":40}: TIMEOUT
    sayit.4	2023-08-13 19:20:51.013	error	Cannot play file: Timeout by checking of announcement finished playing
    sayit.4	2023-08-13 19:21:02.974	error	Error: The module '/opt/iobroker/node_modules/mdns/build/Release/dns_sd_bindings.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 83. This version of Node.js requiresNODE_MODULE_VERSION 108. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
    sayit.4	2023-08-13 19:21:19.396	error	Error while checking if chromecast.0.d4f54704fa54.player.announcement finished playing announcement: {"url":"http://192.168.178.10:8082/sayit.4/tts.mp3?ts=1691947268882","volume":40}: TIMEOUT
    sayit.4	2023-08-13 19:21:19.397	error	Cannot play file: Timeout by checking of announcement finished playing
    sayit.4	2023-08-13 19:22:14.061	error	Error while checking if chromecast.0.d4f54704fa54.player.announcement finished playing announcement: {"url":"http://192.168.178.10:8082/sayit.4/tts.mp3?ts=1691947323551","volume":40}: TIMEOUT
    sayit.4	2023-08-13 19:22:14.061	error	Cannot play file: Timeout by checking of announcement finished playing
    crunchipC Offline
    crunchipC Offline
    @meister-mopper sagte in Sayit-Adapter seit gestern stumm:
    bei mir is der cache aus und der test Button funktioniert auch, sprachausgabe erfolgt
    edit aber wenn ich den test button in der instanz betätige erschein im log
    sayit.0
    2023-08-13 19:33:23.210	error	Error on MDNS discovery: Error: getaddrinfo -3008
      sayit.0
      Meister MopperM Offline
      Meister Mopper
      @crunchip
      So, bin jetzt wieder zurück auf dem aktuellen ioBroker und es funktionieren keine Sprachnachrichten.
      Stoppe ich den chromecast.0, lösche alle chromecast Objekte und starte den Adapter neu, labert meine Tante, aber nicht mit Skript.
      Es ist zum Haareraufen.
      Proxmox und HA ...
        @crunchip
        crunchipC Offline
        crunchipC Offline
        @meister-mopper irgendwas am Netztwerk geändert? Probleme mit unifi?
        Meister MopperM 2 Antworten Letzte Antwort
          Meister Mopper
          schrieb am zuletzt editiert von Meister Mopper
          @crunchip
          Nö, wurde auch schon wegen der dns-Meldung aufmerksam, hier wird aber fleißig richtig aufgelöst (zudem 2xpihole und unbound).
          Proxmox und HA ...
            @crunchip
            ticaki
            @meister-mopper
            Verstehe ich das richtig. Wenn du den Datenpunkt per Hand beschreibst geht es, aber per Blockly nicht?
            Spenden
            • T ticaki
              @meister-mopper
              Meister Mopper
              @ticaki sagte in Sayit-Adapter seit gestern stumm:
              Genau so!
              Proxmox und HA ...
                Genau so!
                ticaki
                @meister-mopper
                Zeig mir mal den Javascript code vom Blockly
                Spenden
                • T ticaki
                  @meister-mopper
                  Meister Mopper
                  @ticaki
                  sendTo("sayit.4", "say", { text: 'Testdurchsage' });
                  console.warn("Executed sayit.4: : " + 'Testdurchsage');
                  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
                  Proxmox und HA ...
                  T 2 Antworten Letzte Antwort
                    @ticaki
                    ticaki
                    @meister-mopper
                    Da drauf klicken und den Text in codetags posten
                    https://github.com/ioBroker/ioBroker.sayit/issues/269
                    Spenden
                      @ticaki
                      ticaki
                      @meister-mopper
                      Dann würde ich dir empfehlen bis es wieder geht den Datenpunkt per "steuere Objekt" zu beschreiben.
                      Spenden
                      • T ticaki
                        @meister-mopper
                        Meister Mopper
                        @ticaki
                        Ich Danke dir,
                        das ist eine Lösung, aber auch zeitaufwändig.
                        Proxmox und HA ...
                          Meister Mopper
                          @crunchip
                          So, wissen wir jetzt bescheid.
                          Danke @ticaki
                          Proxmox und HA ...
                          FragMikeF 1 Antwort Letzte Antwort
                            @crunchip
                            Danke @ticaki
                            FragMikeF Offline
                            FragMikeF Offline
                            FragMike
                            ich habe das beschriebene Problem seit dem 7.12.23
                            Löschen von Datenpunkten hilft aber bei mir nicht.
                            • FragMikeF FragMike
                              Meister Mopper
                              @fragmike sagte in Sayit-Adapter seit gestern stumm:
                              7.12.23
                              Hä? Was meinst du?
                              Und was soll dies bedeuten?
                              Proxmox und HA ...
                                7.12.23
                                Hä? Was meinst du?
                                FragMikeF Offline
                                FragMikeF Offline
                                FragMike
                                @meister-mopper
                                das Problem ist bei mir seit dem 23.12.23 vorhanden, dass mein Google mini stumm bleibt und dass das löschen von Datenpunkten / Objekten im Chromecast Verzeichnisse auch keine Besserung herbeiführt.
                                Sprachausgabe funktioniert übrigens immer noch nicht :-(
                                crunchipC mcm1957M 2 Antworten Letzte Antwort
                                  @meister-mopper
                                  crunchipC Offline
                                  crunchipC Offline
                                  @fragmike hattest ein update gemacht auf die v3.x?
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    @FragMike
                                    Gerade auf die 3.0.5 upgedatet.
                                    Googlemini funktioniert wie vorher.
                                    Scheint was bei dir zu klemmen im Ganzen.
                                    @crunchip
                                    Im Changelog ist glaube ich seit 10/23 die Version 4 .
                                    Warum ist die nicht im Stable? 🤔
                                    • haselchenH haselchen
                                      @FragMike
                                      @crunchip
                                      crunchipC Offline
                                      crunchipC Offline
                                      @haselchen sagte in Sayit-Adapter seit gestern stumm:
                                      halt noch nicht bereit/fertig, wenn dann vllt erstmal latest bevor irgendwann stable
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        @crunchip
                                        Seit 4 Monaten?
                                        Naja, naja...
                                          @crunchip
                                          Seit 4 Monaten?
                                          Naja, naja...
                                          ticaki
                                          @haselchen
                                          ist nicht durch die tests gegangen weil nodejs 14 im js-controller 5 gekillt wurde und keiner hats gemerkt. Ist jetzt in arbeit.
                                          EDIT: Falls ihr woanders seht das ein Release erstellt werden sollte vor längerem und das ein rotes Kreuz hat mich gerne mit @ticaki oder mit
                                          @Developer
                                          anpingen. Hoffe jetzt nicht das jeder in der Gruppe nen Ping bekommt :D
                                          Spenden
