  4. nach Admin-Adapter-Update iobroker nicht über Web erreichbar
    5.2k
65 Beiträge 8 Kommentatoren 8.6k Aufrufe 6 Beobachtet
  • R rennigel
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     14:20:55 up 48 min,  3 users,  load average: 0.55, 0.37, 0.38
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=45.2'C
    volt=0.8750V
    *** Time and Time Zones ***
                   Local time: Thu 2023-08-03 14:20:56 CEST
               Universal time: Thu 2023-08-03 12:20:56 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           1.9G        1.2G        271M         20M        423M        587M
    Swap:           99M        9.0M         90M
    Total:         2.0G        1.2G        362M
             1872 M total memory
             1176 M used memory
              246 M active memory
             1233 M inactive memory
              271 M free memory
               86 M buffer memory
              337 M swap cache
               99 M total swap
                9 M used swap
               90 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       29G   11G   17G  40% /
    devtmpfs       devtmpfs  776M     0  776M   0% /dev
    tmpfs          tmpfs     937M     0  937M   0% /dev/shm
    tmpfs          tmpfs     937M  8.6M  928M   1% /run
    tmpfs          tmpfs     937M     0  937M   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
    tmpfs          tmpfs     188M  4.0K  188M   1% /run/user/1000
    [Thu Aug  3 13:32:11 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1280x1024M@60D smsc95xx.macaddr=DC:A6:32:28:44:BD vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ea7d04d6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Thu Aug  3 13:32:12 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Aug  3 13:32:12 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Aug  3 13:32:14 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET                SOURCE         FSTYPE          OPTIONS
    /                     /dev/mmcblk0p2 ext4            rw,noatime
    |-/sys/fs/bpf         none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
    |-/run/user/1000/gvfs gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.7G    /var/
    1.5G    /var/cache
    1.4G    /var/cache/apt/archives
    1.4G    /var/cache/apt
    125M    /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    21M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    397M    /opt/iobroker/iobroker-data/
    224M    /opt/iobroker/iobroker-data/files
    91M     /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
    15M     /opt/iobroker/iobroker-data/objects.jsonl
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    9.7M    /opt/iobroker/iobroker-data/states.jsonl
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.0
    /usr/bin/node           v18.17.0
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.0-deb-1nodesource1
      Candidate: 18.17.0-deb-1nodesource1
      Version table:
     *** 18.17.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.7.0
    javascript:     7.1.1
    Adapters from github:   0
    Adapter State
      system.adapter.admin.0                  : admin                 : RPi4                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : RPi4                                     -  enabled
    + system.adapter.backitup.0               : backitup              : RPi4                                     -  enabled
    + system.adapter.botvac.0                 : botvac                : RPi4                                     -  enabled
    + system.adapter.discovery.0              : discovery             : RPi4                                     -  enabled
    + system.adapter.history.0                : history               : RPi4                                     -  enabled
    + system.adapter.hue-extended.0           : hue-extended          : RPi4                                     -  enabled
    + system.adapter.hue.0                    : hue                   : RPi4                                     -  enabled, port: 80
    + system.adapter.influxdb.0               : influxdb              : RPi4                                     -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : RPi4                                     -  enabled
    + system.adapter.jarvis.0                 : jarvis                : RPi4                                     -  enabled
    + system.adapter.javascript.0             : javascript            : RPi4                                     -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : RPi4                                     -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.netatmo.0                : netatmo               : RPi4                                     -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : RPi4                                     -  enabled
    + system.adapter.ping.0                   : ping                  : RPi4                                     -  enabled
      system.adapter.rickshaw.0               : rickshaw              : RPi4                                     -  enabled
    + system.adapter.shelly.0                 : shelly                : RPi4                                     -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : RPi4                                     -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sourceanalytix.0         : sourceanalytix        : RPi4                                     -  enabled
      system.adapter.sprinklecontrol.0        : sprinklecontrol       : RPi4                                     - disabled
    + system.adapter.telegram.0               : telegram              : RPi4                                     -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : RPi4                                     -  enabled
    + system.adapter.tr-064.1                 : tr-064                : RPi4                                     -  enabled
    + system.adapter.tr-064.2                 : tr-064                : RPi4                                     -  enabled
      system.adapter.vis.0                    : vis                   : RPi4                                     -  enabled
      system.adapter.web.0                    : web                   : RPi4                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.worx.0                   : worx                  : RPi4                                     -  enabled
    + system.adapter.yahka.0                  : yahka                 : RPi4                                     -  enabled
    + system.adapter.zigbee.0                 : zigbee                : RPi4                                     -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Active repo(s): Beta (latest)
    Installed ioBroker-Instances
    Used repository: Beta (latest)
    Adapter    "admin"        : 6.7.0    , installed 6.7.0
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "botvac"       : 1.0.0    , installed 1.0.0
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "discovery"    : 3.2.0    , installed 3.2.0
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hue"          : 3.9.5    , installed 3.9.5
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.2  [Updatable]
    Adapter    "javascript"   : 7.1.1    , installed 7.1.1
    Controller "js-controller": 5.0.11   , installed 4.0.24 [Updatable]
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "plex"         : 0.9.1    , installed 0.9.1
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "socketio"     : 6.5.2    , installed 6.5.2
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "web"          : 6.1.0    , installed 6.1.0
    Adapter    "worx"         : 2.3.2    , installed 2.3.2
    Adapter    "ws"           : 2.5.3    , installed 2.5.3
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.8.21   , installed 1.8.21
    Objects and States
    Objects:        8313
    States:         6814
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x buster InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       25495      2327/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17317      507/sshd
    tcp        0      0 127.0.0.1:46455         0.0.0.0:*               LISTEN      1001       28607      2498/io.yahka.0
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15212      352/cupsd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       22092      1626/io.mqtt.0
    tcp        0      0 0.0.0.0:34951           0.0.0.0:*               LISTEN      1001       28700      2498/io.yahka.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19403      478/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19396      478/iobroker.js-con
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          18447      497/vncserver-x11-c
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       23989      1684/io.nuki-extend
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17319      507/sshd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       28729      2539/io.simple-api.
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15211      352/cupsd
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          18446      497/vncserver-x11-c
    udp        0      0 0.0.0.0:47119           0.0.0.0:*                           108        16783      372/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21381      1443/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19913      442/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16228      469/cups-browsed
    udp        0      0 192.168.178.69:5353     0.0.0.0:*                           1001       24582      1587/io.tr-064.2
    udp        0      0 192.168.178.21:5353     0.0.0.0:*                           1001       24581      1587/io.tr-064.2
    udp        0      0 192.168.178.69:5353     0.0.0.0:*                           1001       22009      1504/io.tr-064.1
    udp        0      0 192.168.178.21:5353     0.0.0.0:*                           1001       22008      1504/io.tr-064.1
    udp        0      0 192.168.178.69:5353     0.0.0.0:*                           1001       22006      1424/io.tr-064.0
    udp        0      0 192.168.178.21:5353     0.0.0.0:*                           1001       22005      1424/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16781      372/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          19234      442/dhcpcd
    udp6       0      0 :::50829                :::*                                108        16784      372/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        16782      372/avahi-daemon: r
    2023-08-03 14:22:16.307  - warn: shelly.0 (1443) [authEnabled] 192.168.178.155 (shelly1 / shelly1-C4FC6C / SHSW-1#C4FC6C#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:19.329  - warn: shelly.0 (1443) [authEnabled] 192.168.178.160 (shellydimmer2 / shellydimmer2-40F52000E62F / SHDM-2#40F52000E62F#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:19.563  - warn: shelly.0 (1443) [authEnabled] 192.168.178.159 (shellydimmer2 / shellydimmer2-40F520015676 / SHDM-2#40F520015676#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:19.665  - warn: shelly.0 (1443) [authEnabled] 192.168.178.153 (shellydimmer / shellydimmer-CC50E3F35994 / SHDM-1#CC50E3F35994#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:21.380  - info: influxdb.0 (1203) Connecting http://192.168.178.40:8086/ ...
    2023-08-03 14:22:21.380  - info: influxdb.0 (1203) Influx DB Version used: 1.x
    2023-08-03 14:22:21.384  - error: influxdb.0 (1203) Error: connect ECONNREFUSED 192.168.178.40:8086
    2023-08-03 14:22:20.092  - warn: shelly.0 (1443) [authEnabled] 192.168.178.154 (shelly1 / shelly1-C4870D / SHSW-1#C4870D#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:20.289  - warn: shelly.0 (1443) [authEnabled] 192.168.178.156 (shelly1 / shelly1-C4F5D9 / SHSW-1#C4F5D9#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:20.339  - warn: shelly.0 (1443) [authEnabled] 192.168.178.157 (shelly1 / shelly1-C42940 / SHSW-1#C42940#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:20.447  - warn: shelly.0 (1443) [authEnabled] 192.168.178.152 (shellydimmer2 / shellydimmer2-48551900BDA6 / SHDM-2#48551900BDA6#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:20.992  - warn: shelly.0 (1443) [authEnabled] 192.168.178.151 (shelly1 / shelly1-C4834E / SHSW-1#C4834E#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:26.636  - warn: shelly.0 (1443) [authEnabled] 192.168.178.155 (shelly1 / shelly1-C4FC6C / SHSW-1#C4FC6C#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:29.555  - warn: shelly.0 (1443) [authEnabled] 192.168.178.160 (shellydimmer2 / shellydimmer2-40F52000E62F / SHDM-2#40F52000E62F#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:29.674  - warn: shelly.0 (1443) [authEnabled] 192.168.178.159 (shellydimmer2 / shellydimmer2-40F520015676 / SHDM-2#40F520015676#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:29.909  - warn: shelly.0 (1443) [authEnabled] 192.168.178.153 (shellydimmer / shellydimmer-CC50E3F35994 / SHDM-1#CC50E3F35994#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:30.395  - warn: shelly.0 (1443) [authEnabled] 192.168.178.154 (shelly1 / shelly1-C4870D / SHSW-1#C4870D#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:31.384  - info: influxdb.0 (1203) Connecting http://192.168.178.40:8086/ ...
    2023-08-03 14:22:30.549  - warn: shelly.0 (1443) [authEnabled] 192.168.178.152 (shellydimmer2 / shellydimmer2-48551900BDA6 / SHDM-2#48551900BDA6#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:30.615  - warn: shelly.0 (1443) [authEnabled] 192.168.178.156 (shelly1 / shelly1-C4F5D9 / SHSW-1#C4F5D9#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:30.721  - warn: shelly.0 (1443) [authEnabled] 192.168.178.157 (shelly1 / shelly1-C42940 / SHSW-1#C42940#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:31.336  - warn: shelly.0 (1443) [authEnabled] 192.168.178.151 (shelly1 / shelly1-C4834E / SHSW-1#C4834E#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-08-03 14:22:31.385  - info: influxdb.0 (1203) Influx DB Version used: 1.x
    2023-08-03 14:22:31.390  - error: influxdb.0 (1203) Error: connect ECONNREFUSED 192.168.178.40:8086
    2023-08-03 14:22:37.000  - warn: shelly.0 (1443) [authEnabled] 192.168.178.155 (shelly1 / shelly1-C4FC6C / SHSW-1#C4FC6C#1): This device is not protected via restricted login (see adapter documentation for details)
    iob diag has finished.
    Hab mit grep mal im logfile gesucht (trotz DAU).
    Ergebnis:
    2023-08-03 13:31:35.341  - info: host.RPi4 stopInstance system.adapter.admin.0 (force=false, process=false)
    2023-08-03 13:32:22.776  - info: host.RPi4 instance system.adapter.admin.0 started with pid 1054
    2023-08-03 13:32:24.519  - error: host.RPi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js
    2023-08-03 13:32:24.520  - error: host.RPi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
    2023-08-03 13:32:24.523  - error: host.RPi4 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js:21:1)
    2023-08-03 13:32:24.526  - error: host.RPi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js',
    2023-08-03 13:32:24.526  - error: host.RPi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/main.js'
    2023-08-03 13:32:24.528  - error: host.RPi4 instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-08-03 13:32:24.528  - info: host.RPi4 Adapter system.adapter.admin.0 needs rebuild and will be restarted afterwards.
    2023-08-03 13:32:24.533  - info: host.RPi4 system.adapter.admin.0 will be rebuilt
    2023-08-03 13:32:24.534  - warn: host.RPi4 adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
    2023-08-03 13:34:08.451  - info: host.RPi4 instance system.adapter.admin.0 started with pid 2045
    2023-08-03 13:34:12.074  - error: host.RPi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js
    2023-08-03 13:34:12.074  - error: host.RPi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
    2023-08-03 13:34:12.076  - error: host.RPi4 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js:21:1)
    2023-08-03 13:34:12.080  - error: host.RPi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js',
    2023-08-03 13:34:12.080  - error: host.RPi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/main.js'
    2023-08-03 13:34:12.081  - error: host.RPi4 instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-08-03 13:34:12.082  - info: host.RPi4 Adapter system.adapter.admin.0 needs rebuild and will be restarted afterwards.
    2023-08-03 13:34:12.082  - info: host.RPi4 system.adapter.admin.0 will be rebuilt
    2023-08-03 13:35:03.984  - info: host.RPi4 instance system.adapter.admin.0 started with pid 2934
    2023-08-03 13:35:06.855  - error: host.RPi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js
    2023-08-03 13:35:06.855  - error: host.RPi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
    2023-08-03 13:35:06.856  - error: host.RPi4 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js:21:1)
    2023-08-03 13:35:06.857  - error: host.RPi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js',
    2023-08-03 13:35:06.857  - error: host.RPi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/main.js'
    2023-08-03 13:35:06.858  - error: host.RPi4 instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-08-03 13:35:06.859  - info: host.RPi4 Adapter system.adapter.admin.0 needs rebuild and will be restarted afterwards.
    2023-08-03 13:35:06.859  - info: host.RPi4 system.adapter.admin.0 will be rebuilt
    2023-08-03 13:35:06.860  - warn: host.RPi4 adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
    2023-08-03 13:35:48.385  - info: host.RPi4 instance system.adapter.admin.0 started with pid 3332
    2023-08-03 13:35:50.394  - error: host.RPi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js
    2023-08-03 13:35:50.394  - error: host.RPi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
    2023-08-03 13:35:50.395  - error: host.RPi4 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js:21:1)
    2023-08-03 13:35:50.396  - error: host.RPi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core/build/index.js',
    2023-08-03 13:35:50.396  - error: host.RPi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.admin/main.js'
    2023-08-03 13:35:50.396  - error: host.RPi4 instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-08-03 13:35:50.396  - info: host.RPi4 Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    Da gibt es den Hinweis auf
    "Please execute "npm install --production""
    (Habe ich aber noch nicht gemacht.)
    crunchipC Offline
    crunchipC Offline
    @rennigel buster ende Gelände
    Warum tummelt man sich im beta Zweig, schafft es aber nicht sein OS auf stand zu halten?
    R 1 Antwort Letzte Antwort
    • R rennigel
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        10
      Codename:       buster
      VERSION_ID="10"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=45.2'C
      volt=0.8750V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           99M        9.0M         90M
               1872 M total memory
               1176 M used memory
                246 M active memory
                271 M free memory
                 86 M buffer memory
                337 M swap cache
                 99 M total swap
                  9 M used swap
                 90 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1.7G    /var/
      1.5G    /var/cache
      1.4G    /var/cache/apt
      125M    /var/lib
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.7.0
      javascript:     7.1.1
      Adapter State
      + instance is alive
      Objects and States
      Objects:        8313
      States:         6814
      Pending Updates: 0
      Ergebnis:
      @rennigel sagte in nach Admin-Adapter-Update iobroker nicht über Web erreichbar:
      buster
      Tot, Nachfolger installieren. Bevorzugt die 64bit-Version.
      Dann gleich OHNE Desktop.
      Updates der Adapter einspielen.
      Zum Problem:
      iob rebuild admin
      sagt?
      ist veraltet, versuch zunächst ein rebuild.
        rennigel
        @crunchip said in nach Admin-Adapter-Update iobroker nicht über Web erreichbar:
        Auf beta hatte ich mal umgestellt, um irgendwelche Fixes für einen Adapter zu bekommen.
        Dann aber nie zurückgestellt ... ja, vielleicht nicht so pfiffig ...
        Und beim OS habe ich eher die Denke "Never touch a running system". Irgendwann auch nicht pffifig ...
        • R rennigel
          Jedenfalls nicht wenn das 'nevergetatschte System' mittlerweile seit einem Jahr das End Of Life errreicht hat.
            buster
            Zum Problem:
            iob rebuild admin
            sagt?
            rennigel
            schrieb am zuletzt editiert von rennigel
            @thomas-braun said in nach Admin-Adapter-Update iobroker nicht über Web erreichbar:
            Zum Problem:
            iob rebuild admin
            sagt?
            pi@RPi4:/opt/iobroker/log $ iob rebuild admin
            Rebuilding native module "admin" ...
            rebuilt dependencies successfully
            Rebuilding native modules done
            Leider ist die Web-Oderfläche immernoch nicht erreichbar.
            Kann ich beim Hochziehen auf Bullseye Bookworm beeinflussen, ob ich 64 bit und ohne Desktop haben möchte?
            Neue Installationen auf anderen RPi mache ich auch ohne Desktop, in der Anfangszeit des Raspberrys war mir ein Desktop "sicherer" - aber ich nutze ihn eh nie.
            Thomas BraunT HomoranH 3 Antworten Letzte Antwort
            • R rennigel
              Zum Problem:
              iob rebuild admin
              sagt?
              Du kannst nicht von 32 auf 64 'hochziehen'. Muss komplett neuinstalliert werden. Und du kannst auch nicht (ohne zusätzliche Klimmzüge) von Buster auf Bookworm (was es vom Raspberry OS eh noch nicht gibt).
              Also Bullseye 64bit Lite neuinstallieren.
              • R rennigel
                Zum Problem:
                iob rebuild admin
                sagt?
                @rennigel
                iob start admin
                sagt?
                • R Offline
                  rennigel
                  iob start admin
                  sagt?
                  Nichts (es folgt nur das System-Prompt).
                  Weboberfläche immer noch nicht erreichbar.
                  • R rennigel
                    Zum Problem:
                    iob rebuild admin
                    sagt?
                    @rennigel wieso stehst du in .../log?
                      rennigel
                      @homoran said in nach Admin-Adapter-Update iobroker nicht über Web erreichbar:
                      Das kam noch vom suchen im Log.
                      Ich war unaufmerksam ...
                      Habe das Rebuild wiederholt aus dem root-Verzeichnis, Adapter gestartet.
                      Keine Änderung.
                      • R rennigel
                        Keine Änderung.
                        wieso root?
                        /opt/iobroker war schon richtig (oder besser /opt/iobroker/npm-modules/)
                          wieso root?
                          rennigel
                          pi@RPi4:/opt/iobroker $ iob rebuild admin
                          pi@RPi4:/opt/iobroker $ iob start admin
                          Jetzt sollte es passen ...
                          Leider
                          Vielleicht eine blöde Frage, aber könnte das Problem auch am Web-Server liegen und nicht am Adapter?
                          In der Instanz-Übersicht sind ja noch ein paar mehr Port-Angaben (z.B. für infux-DB). Egal welchen Port ich nehme, immer das gleiche Ergebnis wie auf 8081.
                          • R rennigel
                            Leider
                            nein
                            der läuft aber auch nicht
                            wie sieht denn dein URL vollständig aus?
                            • R rennigel
                              Leider
                              iob start web
                              iob start admin
                                nein
                                rennigel
                                192.168.178.69:8081/
                                  iob start web
                                  iob start admin
                                  rennigel
                                  iob start web
                                  iob start admin
                                  Durchgeführt,
                                  pi@RPi4:/opt/iobroker $ iob start web
                                  keine Änderung
                                  • R rennigel
                                    kein http:// oder gar https://
                                      rennigel
                                      Genau, ich gebe es ohne ein.
                                      Habe aber auch mit http:// probiert, kein Unterschied.
                                      (https dürfte wohl sowieso nicht funktionieren ...!?)
                                      • R rennigel
                                        iob start web
                                        iob start admin
                                        Durchgeführt,
                                        keine Änderung
                                        crunchipC Offline
                                        crunchipC Offline
                                        keine Änderung
                                        läuft die Instanz denn?
                                        • R rennigel
                                          das glaube ich dir!
                                          Browser haben aber einen eigenen Willen und ändern das gerne
                                          deswegen ja
