  3. Entwicklung
  4. Adapter: Worx Landroid v2.x.x
1.2k Beiträge 121 Kommentatoren 733.5k Aufrufe 64 Beobachtet
  • O optus28
    @lucky_esa Habe alles gemacht. von Worx war nichts mehr zu finden.
    Immerhin wurde die Fehlermeldung deutlich kürzer.
    $ iobroker add worx auto --host klaus-PC(SmartHomeKlaus230620) --debug
    Installing iobroker.worx@2.3.2... (System call)
    npm ERR! code 1
    npm ERR! path F:\ioBroker2020\SmartHomeKlaus230620\node_modules\aws-crt npm ERR! command failed npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node ./scripts/install.js npm ERR! ERR! OMG CMake is not installed. Install CMake. npm ERR! ERR! OMG CMake is not installed. Install CMake. npm ERR! F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\cMake.js:106 npm ERR! throw new Error("CMake is not installed. Install CMake."); npm ERR! ^ npm ERR! npm ERR! Error: CMake is not installed. Install CMake. npm ERR! at CMake.getGenerators (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\cMake.js:106:15) npm ERR! at Toolset._getTopSupportedVisualStudioGenerator (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\toolset.js:217:28) npm ERR! at async Toolset.initializeWin (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\toolset.js:159:17) npm ERR! at async Toolset.initialize (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\toolset.js:32:13) npm ERR! at async BuildSystem._ensureInstalled (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\buildSystem.js:40:9) npm ERR! at async BuildSystem._invokeCMake (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\cmake-js\lib\buildSystem.js:69:9) npm ERR! at async buildLocally (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\aws-crt\scripts\build.js:154:5) npm ERR! at async buildFromRemoteSource (F:\ioBroker2020\SmartHomeKlaus230620\node_modules\aws-crt\scripts\build.js:176:5) npm ERR! npm ERR! Node.js v18.16.0 npm ERR! A complete log of this run can be found in: npm ERR! C:\WINDOWS\ServiceProfiles\iobroker(SmartHomeKlaus230620)\AppData\Local\npm-cache_logs\2023-07-31T21_43_20_887Z-debug-0.log
    host.klaus-PC(SmartHomeKlaus230620) Cannot install iobroker.worx@2.3.2: 1
    ERROR: Process exited with code 25
    Schade, dass ich es nicht hinbekomme. Nutze seit den ersten Worx Adaptern in 2017 , 2018 bis zur letzten Version vor 2.3.xx den Adapter und hatte bisher keine Probleme.
    Viele Grüße
    Klaus
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    #1047
    @optus28
    Installier das nach. Wenn es cmake für Windows gibt.
    O 1 Antwort Letzte Antwort
      @optus28
      O
      O
      optus28
      schrieb am zuletzt editiert von optus28
      #1048
      @thomas-braun Nach Installation von CMAKE im System Path.
      Wieder ein Stück kürzer aber leider noch nicht erfolgreich.
      npm ERR! info RUN '--no-warn-unused-cli', npm ERR! info RUN '-G',
      npm ERR! A complete log of this run can be found in: npm ERR! C:\WINDOWS\ServiceProfiles\iobroker(SmartHomeKlaus230620)\AppData\Local\npm-cache_logs\2023-07-31T23_14_49_746Z-debug-0.log
      Wüsste gerne ob es jemand geschafft hat Worx 2.3.xx unter Win zum Laufen gebracht zu haben.
      Vielen Dank für die bisherige Geduld und Unterstützung.
      O L 2 Antworten Letzte Antwort
      • O optus28
        O
        O
        optus28
        #1049
        @optus28 Ich bekomme es nicht hin und gebe auf. Dann eben iobroker ohne worx.
        Vielleicht könnte sich der Entwickler / Programmiere ja mal anschauen was er programmiert hat.
        Vielen Dank für die Hilfen.
        • O optus28
          Thomas BraunT
          Thomas BraunT
          #1050
          @optus28 sagte in Adapter: Worx Landroid v2.x.x:
          Das passt ja. Dein Betrübssystem spielt da nicht mit. Musst du richtig konfigurieren.
            O
            O
            optus28
            #1051
            @thomas-braun Hallo Thomas, das mag ja sein. Aber es gibt halt iobroker unter windows. Und ich wiederhole mich, bisher gab es auch zumindest mit worx keine Probleme. Ich würde ja gerne auf die vor 2.3.xx zurückgehen, weiss aber nicht wie.
            Klaus
            • O optus28
              Klaus
              Thomas BraunT
              Thomas BraunT
              #1052
              Mit marginalem Anteil.
                O
                O
                optus28
                #1053
                @thomas-braun Welches Linux empfiehlst Du denn? Da gibt es ja auch jede Menge Varianten.
                Würde mir halt dann einen älteren PC mit Linux einrichten.
                L Thomas BraunT Merlin123M 3 Antworten Letzte Antwort
                • O optus28
                  L
                  L
                  Lucky_ESA
                  #1054
                  Oben in deiner Fehlermeldung steht doch das Problem! Wie @Thomas-Braun beschrieben hat muss cmake installiert werden was du ja auch gemacht hast. Weiter unten steht noch das visual modul geladen werden. Das Modul aws-crt ist eine Anhänigkeit vom Modul sdk was ich benötige.
                  Prereqs:
                  Node 10.16+
                  npm
                  CMake 3.1+
                  Linux: gcc 5+ or clang 3.6+
                  If your compiler can compile node, it can compile this library
                  Windows: Visual Studio 2015+
                  OSX: XCode or brew-installed llvm
                  Kann hier nicht nachschauen daher mal kurz google anschmeißen :-)
                  Gruß//Lucky
                  RoboCopR 1 Antwort Letzte Antwort
                  • O optus28
                    Thomas BraunT
                    Thomas BraunT
                    #1055
                    @optus28
                    Ich würde für Server immer ein Debian (mindestens aber etwas was darauf basiert) empfehlen.
                    Darauf setzen auch die ganzen Anleitungen hier im Forum drauf auf.
                    • O optus28
                      Merlin123M
                      Merlin123M
                      Merlin123
                      #1056
                      @optus28 Debian ist wirklich das sinnvollste. Eigentlich gehen alle davon aus, dass iobroker unter Debian läuft (oder einem anderen Linux). Damit hat man einfach am wenigsten Stress
                      Beta-Tester
                      O 2 Antworten Letzte Antwort
                      • Merlin123M Merlin123
                        O
                        O
                        optus28
                        #1057
                        @merlin123 Danke, wie sieht es mit Ubuntu aus?
                          O
                          O
                          optus28
                          #1058
                          @merlin123 Habe es aufgegeben unter windows. Schade, dass man den Adapter nicht so hinbekommt, dass er auch unter Windows läuft.
                          nik82N 1 Antwort Letzte Antwort
                          • O optus28
                            Thomas BraunT
                            Thomas BraunT
                            #1059
                            Nimm ein Debian. Ubuntu ist eh nur eine Abwandlung davon. Ich würde das 'Original' nehmen. Gerade auf einem Server.
                              O
                              O
                              optus28
                              #1060
                              @thomas-braun Alles klar, werde es morgen versuchen. Wir haben eh gerade keinen Sommer im Südwesten.
                              Viele Grüße
                              Merlin123M 1 Antwort Letzte Antwort
                              • O optus28
                                nik82N
                                nik82N
                                nik82
                                #1061
                                @optus28
                                Ich habe jetzt nicht alles von euch genau gelesen, nur kurz überflogen, aber der Adapter läuft bei mir einwandfrei unter Windows.
                                Ich habe allerdings noch die Version 2.0.3 laufen.
                                Installiere die doch mal.
                                • L Lucky_ESA
                                  Prereqs:
                                  Node 10.16+
                                  npm
                                  CMake 3.1+
                                  Gruß//Lucky
                                  RoboCopR
                                  RoboCopR
                                  RoboCop
                                  #1062
                                  @lucky_esa Moin moin, ich habe bei meinem Worx WR141E in der APP den Regensensor deaktiviert, da diese in einer Behausung steht und den Regen daher nicht mitbekommt.
                                  Das "Wetter berücksichtigen" ist aktiviert und die voraussichtliche Regenmenge aus "DasWetter.com" wird mit 0.4mm angegeben und trotzdem fängt er an zu mähen.
                                  Welche oder wo muss ich welche Einstellungen im Script anpassen?
                                  Aktuell habe ich glaube ich Blockly 2.0 und Worx Installierte Version: 2.3.2 installiert.
                                  Für Hilfe wäre ich dankbar.
                                  Grüße Robbie
                                  • O optus28
                                    Viele Grüße
                                    Merlin123M
                                    Merlin123M
                                    Merlin123
                                    #1063
                                    @optus28 Viel Erfolg! Mit Debian ist es echt am einfachsten, da das von den meisten genutzt wird.
                                    Beta-Tester
                                    • nik82N nik82
                                      @optus28
                                      O
                                      O
                                      optus28
                                      #1064
                                      @nik82 Die vor 2.3.xx Version lief auch bei mir. Habe aber zwischendurch alles von worx gelöscht und weiss leider nicht wo ich die Vorgängerversion finden kann. Hast Du einen Rat.
                                      • O optus28
                                        nik82N
                                        nik82N
                                        nik82
                                        #1065
                                        @optus28
                                        Einfach unter Adapter.
                                        Dann Expertenmodus ein:
                                        Dann bei dem Worx Adapter auf die drei Punkte:
                                        Dann auf bestimmte Version installieren:
                                        • nik82N nik82
                                          @optus28
                                          O
                                          O
                                          optus28
                                          #1066
                                          @nik82 durch das komplette löschen anscheinend, sieht es bei mir so aus.
                                          Keine Chance eine andere Version auszuwählen.
                                          84.2k
