  4. JavaScript
  5. Raspi GPIO wird gesetzt, wie Ursache herausfinden?
65 Beiträge 4 Kommentatoren 8.2k Aufrufe 3 Beobachtet
  • L Laser
    @homoran hier mal ein Auszug:
    2023-07-23 05:22:04.164  - warn: javascript.0 (945) State "javascript.0.variables.DP-kW-Hoy" not found
    2023-07-23 05:22:04.167  - warn: javascript.0 (945)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    2023-07-23 05:22:04.167  - warn: javascript.0 (945)     at Object.Solar (script.js.Solar.Ges-kW-Solarertrag:19:1)
    2023-07-23 05:22:04.168  - warn: javascript.0 (945)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2723:34)
    2023-07-23 05:22:04.168  - warn: javascript.0 (945)     at listOnTimeout (node:internal/timers:569:17)
    2023-07-23 05:22:04.168  - warn: javascript.0 (945)     at processTimers (node:internal/timers:512:7)
    2023-07-23 05:22:04.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Hoyges: 509
    2023-07-23 05:22:04.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Laden: 133
    2023-07-23 05:22:04.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: GesSolar: 642
    2023-07-23 05:22:04.226  - info: javascript.0 (945) script.js.HausSchalter.Anpassung_Messwerte: Tempo: 21.8
    2023-07-23 05:22:09.164  - warn: javascript.0 (945) State "javascript.0.variables.DP-kW-Hoy" not found
    2023-07-23 05:22:09.165  - warn: javascript.0 (945)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    2023-07-23 05:22:09.165  - warn: javascript.0 (945)     at Object.Solar (script.js.Solar.Ges-kW-Solarertrag:19:1)
    2023-07-23 05:22:09.165  - warn: javascript.0 (945)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2723:34)
    2023-07-23 05:22:09.165  - warn: javascript.0 (945)     at listOnTimeout (node:internal/timers:569:17)
    2023-07-23 05:22:09.166  - warn: javascript.0 (945)     at processTimers (node:internal/timers:512:7)
    2023-07-23 05:22:09.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Hoyges: 509
    2023-07-23 05:22:09.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Laden: 133
    2023-07-23 05:22:09.197  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: GesSolar: 642
    2023-07-23 05:22:09.226  - info: javascript.0 (945) script.js.HausSchalter.Anpassung_Messwerte: Tempo: 21.8
    2023-07-23 05:22:12.779  - warn: mqtt.0 (144534) Client [shellyem3-485519D7986A] has invalid password(otto) or username(otto)
    2023-07-23 05:22:13.975  - warn: javascript.0 (945) You are assigning a number to the state "rpi2.0.gpio.22.state" which expects a boolean. Please fix your code to use a boolean or change the state type to number. This warning might become an error in future versions.
    2023-07-23 05:22:13.977  - warn: javascript.0 (945)     at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    2023-07-23 05:22:13.977  - warn: javascript.0 (945)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1788:29)
    2023-07-23 05:22:13.977  - warn: javascript.0 (945)     at listOnTimeout (node:internal/timers:571:11)
    2023-07-23 05:22:13.977  - warn: javascript.0 (945)     at processTimers (node:internal/timers:512:7)
    2023-07-23 05:22:13.989  - info: javascript.0 (945) State value to set for "rpi2.0.gpio.22.state" has to be type "boolean" but received type "number"
    2023-07-23 05:22:14.164  - warn: javascript.0 (945) State "javascript.0.variables.DP-kW-Hoy" not found
    2023-07-23 05:22:14.165  - warn: javascript.0 (945)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    2023-07-23 05:22:14.166  - warn: javascript.0 (945)     at Object.Solar (script.js.Solar.Ges-kW-Solarertrag:19:1)
    2023-07-23 05:22:14.166  - warn: javascript.0 (945)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2723:34)
    2023-07-23 05:22:14.166  - warn: javascript.0 (945)     at listOnTimeout (node:internal/timers:569:17)
    2023-07-23 05:22:14.166  - warn: javascript.0 (945)     at processTimers (node:internal/timers:512:7)
    2023-07-23 05:22:14.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Hoyges: 509
    2023-07-23 05:22:14.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Laden: 133
    2023-07-23 05:22:14.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: GesSolar: 642
    2023-07-23 05:22:14.226  - info: javascript.0 (945) script.js.HausSchalter.Anpassung_Messwerte: Tempo: 21.8
    2023-07-23 05:22:15.241  - warn: mqtt.0 (144534) Client [ESP_Easy_0] has invalid password(otto) or username(otto)
    2023-07-23 05:22:19.164  - warn: javascript.0 (945) State "javascript.0.variables.DP-kW-Hoy" not found
    2023-07-23 05:22:19.166  - warn: javascript.0 (945)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    2023-07-23 05:22:19.166  - warn: javascript.0 (945)     at Object.Solar (script.js.Solar.Ges-kW-Solarertrag:19:1)
    2023-07-23 05:22:19.166  - warn: javascript.0 (945)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2723:34)
    2023-07-23 05:22:19.166  - warn: javascript.0 (945)     at listOnTimeout (node:internal/timers:569:17)
    2023-07-23 05:22:19.168  - warn: javascript.0 (945)     at processTimers (node:internal/timers:512:7)
    2023-07-23 05:22:19.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Hoyges: 509
    2023-07-23 05:22:19.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Laden: 133
    2023-07-23 05:22:19.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: GesSolar: 642
    2023-07-23 05:22:19.226  - info: javascript.0 (945) script.js.HausSchalter.Anpassung_Messwerte: Tempo: 21.8
    2023-07-23 05:22:21.512  - warn: modbus.0 (260793) Error: undefined
    2023-07-23 05:22:21.513  - error: modbus.0 (260793) Request timed out.
    2023-07-23 05:22:21.514  - warn: modbus.0 (260793) Poll error count: 3 code: {"err":"timeout","timeout":5000}
    2023-07-23 05:22:21.520  - info: javascript.0 (945) script.js.Logik.SSH-Exec: VE Err: 1
    2023-07-23 05:22:24.164  - warn: javascript.0 (945) State "javascript.0.variables.DP-kW-Hoy" not found
    2023-07-23 05:22:24.167  - warn: javascript.0 (945)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    2023-07-23 05:22:24.167  - warn: javascript.0 (945)     at Object.Solar (script.js.Solar.Ges-kW-Solarertrag:19:1)
    2023-07-23 05:22:24.167  - warn: javascript.0 (945)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2723:34)
    2023-07-23 05:22:24.167  - warn: javascript.0 (945)     at listOnTimeout (node:internal/timers:569:17)
    2023-07-23 05:22:24.167  - warn: javascript.0 (945)     at processTimers (node:internal/timers:512:7)
    2023-07-23 05:22:24.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Hoyges: 509
    2023-07-23 05:22:24.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Laden: 133
    2023-07-23 05:22:24.197  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: GesSolar: 642
    2023-07-23 05:22:24.206  - info: host.raspberrypi stopInstance system.adapter.vedirect.0 (force=false, process=true)
    2023-07-23 05:22:24.220  - error: vedirect.0 (260989) Sentry disabled, error catched : [onUnload] TypeError: SerialPort.close is not a function
    2023-07-23 05:22:24.226  - info: javascript.0 (945) script.js.HausSchalter.Anpassung_Messwerte: Tempo: 21.8
    2023-07-23 05:22:24.228  - info: javascript.0 (945) script.js.Logik.SSH-Exec: VE Err: 1
    2023-07-23 05:22:24.258  - info: host.raspberrypi stopInstance system.adapter.vedirect.0 send kill signal
    2023-07-23 05:22:24.809  - info: host.raspberrypi instance system.adapter.vedirect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-23 05:22:26.533  - info: host.raspberrypi instance system.adapter.vedirect.0 started with pid 261103
    2023-07-23 05:22:29.164  - warn: javascript.0 (945) State "javascript.0.variables.DP-kW-Hoy" not found
    2023-07-23 05:22:29.165  - warn: javascript.0 (945)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    2023-07-23 05:22:29.165  - warn: javascript.0 (945)     at Object.Solar (script.js.Solar.Ges-kW-Solarertrag:19:1)
    2023-07-23 05:22:29.166  - warn: javascript.0 (945)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2723:34)
    2023-07-23 05:22:29.166  - warn: javascript.0 (945)     at listOnTimeout (node:internal/timers:569:17)
    2023-07-23 05:22:29.166  - warn: javascript.0 (945)     at processTimers (node:internal/timers:512:7)
    2023-07-23 05:22:29.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Hoyges: 509
    2023-07-23 05:22:29.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Laden: 133
    2023-07-23 05:22:29.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: GesSolar: 642
    2023-07-23 05:22:29.226  - info: javascript.0 (945) script.js.HausSchalter.Anpassung_Messwerte: Tempo: 21.8
    2023-07-23 05:22:30.251  - warn: mqtt.0 (144534) Object of state "mqtt.0.shellies.shellyswitch25-3C6105E3A7AF.roller.0" is missing the required property "common.type"
    2023-07-23 05:22:30.597  - warn: mqtt.0 (144534) Client [ESP_Easy_0] has invalid password(otto) or username(otto)
    2023-07-23 05:22:34.164  - warn: javascript.0 (945) State "javascript.0.variables.DP-kW-Hoy" not found
    2023-07-23 05:22:34.165  - warn: javascript.0 (945)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    2023-07-23 05:22:34.166  - warn: javascript.0 (945)     at Object.Solar (script.js.Solar.Ges-kW-Solarertrag:19:1)
    2023-07-23 05:22:34.166  - warn: javascript.0 (945)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2723:34)
    2023-07-23 05:22:34.166  - warn: javascript.0 (945)     at listOnTimeout (node:internal/timers:569:17)
    2023-07-23 05:22:34.166  - warn: javascript.0 (945)     at processTimers (node:internal/timers:512:7)
    2023-07-23 05:22:34.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Hoyges: 509
    2023-07-23 05:22:34.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Laden: 133
    2023-07-23 05:22:34.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: GesSolar: 642
    2023-07-23 05:22:34.226  - info: javascript.0 (945) script.js.HausSchalter.Anpassung_Messwerte: Tempo: 21.8
    2023-07-23 05:22:39.164  - warn: javascript.0 (945) State "javascript.0.variables.DP-kW-Hoy" not found
    2023-07-23 05:22:39.166  - warn: javascript.0 (945)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    2023-07-23 05:22:39.166  - warn: javascript.0 (945)     at Object.Solar (script.js.Solar.Ges-kW-Solarertrag:19:1)
    2023-07-23 05:22:39.166  - warn: javascript.0 (945)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2723:34)
    2023-07-23 05:22:39.167  - warn: javascript.0 (945)     at listOnTimeout (node:internal/timers:569:17)
    2023-07-23 05:22:39.167  - warn: javascript.0 (945)     at processTimers (node:internal/timers:512:7)
    2023-07-23 05:22:39.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Hoyges: 509
    2023-07-23 05:22:39.197  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Laden: 133
    2023-07-23 05:22:39.197  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: GesSolar: 642
    2023-07-23 05:22:39.228  - info: javascript.0 (945) script.js.HausSchalter.Anpassung_Messwerte: Tempo: 21.8
    2023-07-23 05:22:44.164  - warn: javascript.0 (945) State "javascript.0.variables.DP-kW-Hoy" not found
    2023-07-23 05:22:44.165  - warn: javascript.0 (945)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    2023-07-23 05:22:44.165  - warn: javascript.0 (945)     at Object.Solar (script.js.Solar.Ges-kW-Solarertrag:19:1)
    2023-07-23 05:22:44.165  - warn: javascript.0 (945)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2723:34)
    2023-07-23 05:22:44.165  - warn: javascript.0 (945)     at listOnTimeout (node:internal/timers:569:17)
    2023-07-23 05:22:44.165  - warn: javascript.0 (945)     at processTimers (node:internal/timers:512:7)
    2023-07-23 05:22:44.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Hoyges: 509
    2023-07-23 05:22:44.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Laden: 133
    2023-07-23 05:22:44.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: GesSolar: 642
    2023-07-23 05:22:44.228  - info: javascript.0 (945) script.js.HausSchalter.Anpassung_Messwerte: Tempo: 21.8
    2023-07-23 05:22:45.918  - warn: mqtt.0 (144534) Client [ESP_Easy_0] has invalid password(otto) or username(otto)
    2023-07-23 05:22:49.164  - warn: javascript.0 (945) State "javascript.0.variables.DP-kW-Hoy" not found
    2023-07-23 05:22:49.165  - warn: javascript.0 (945)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    2023-07-23 05:22:49.165  - warn: javascript.0 (945)     at Object.Solar (script.js.Solar.Ges-kW-Solarertrag:19:1)
    2023-07-23 05:22:49.165  - warn: javascript.0 (945)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2723:34)
    2023-07-23 05:22:49.165  - warn: javascript.0 (945)     at listOnTimeout (node:internal/timers:569:17)
    2023-07-23 05:22:49.165  - warn: javascript.0 (945)     at processTimers (node:internal/timers:512:7)
    2023-07-23 05:22:49.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Hoyges: 509
    2023-07-23 05:22:49.196  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: Laden: 133
    2023-07-23 05:22:49.197  - info: javascript.0 (945) script.js.Solar.Ges-kWh-Solarertrag: GesSolar: 642
    2023-07-23 05:22:49.228  - info: javascript.0 (945) script.js.HausSchalter.Anpassung_Messwerte: Tempo: 21.8
    2023-07-23 05:22:54.094  - warn: mqtt.0 (144534) Client [shellyswitch25-3C6105E462D5] has invalid password(otti1212) or username(Otto)
    2023-07-23 05:22:54.164  - warn: javascript.0 (945) State "javascript.0.variables.DP-kW-Hoy" not found
    2023-07-23 05:22:54.165  - warn: javascript.0 (945)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    2023-07-23 05:22:54.165  - warn: javascript.0 (945)     at Object.Solar (script.js.Solar.Ges-kW-Solarertrag:19:1)
    so sieht das Log den ganzen Tag über aus.
    ticaki
    @laser
    1. das Password ist jetzt verbrannt mußt du ändern
    2. das heißt das sich der shellyswitch25 versucht anzumelden aber es nicht hinbekommt. Wenn du den shelly adapter installiert hast, stimmt der Port im shelly nicht.
    3. mit ESP kenne ich mich nicht aus, aber da das pw ist falsch oder der user
    Em kontrolliere das mal alles, bringt ja nix geräte zu haben wenn die Daten nicht ankommen
    erstelle diesen State genau an dieser Stelle als Zahl. Must du wahrscheinlich Expert anschalten, schalte das aber sobald der State erstellt ist wieder aus.
    und hier haben wir den Kern des Problems:
    Der Adapter wird um 5:22 neugestartet
    und
    da gibts noch eine Stelle in deinen Skripten die diesen State beschreibt
    Ehrlich ich würde Austicken wenn mein Log so aussieht 😁
    Spenden
    L 1 Antwort Letzte Antwort
    • T ticaki
      @laser
      und
      Laser
      @ticaki In meinem Projekt geht es in der Tat noch etwas chaotisch zu. So habe ich Shellys rausgeworfen und durch HM- Schalter ersetzt. Da kursieren noch Shelly- Leichen. Die müssen raus.
      Der VE Adapter überwacht die Akku Spannung. Da könnte das Problem liegen. Warum (bzw. wo) das Datenformat nicht passen soll, habe ich noch nicht herausgefunden.
      • L Laser
        Die Anzahl meiner Scripte ist überschaubar. Wieso finde ich mit der Suchfunktion nichts? Kann es sein, daß der GPIO22 gar nicht durch ein Script gesetzt wird, sondern durch einen anderen Dreck- Effekt gesetzt wird? Warum gerade um 5:20 Uhr?
        @laser sagte: Kann es sein, daß der GPIO22 gar nicht durch ein Script gesetzt wird
        Laut erstem Beitrag durch ein Skript.
        2023-07-24 05:21:52.759  - warn: javascript.0 (3320) You are assigning a number to the state "rpi2.0.gpio.22.state" which expects a boolean. Please fix your code to
        Sind Skripte unter der Gruppe "global" aktiv (Expertenmodus)?
        • L Laser
          ticaki
          @laser
          obestes Skript auf machen, rein klicken das der Cursor drin ist, strg - f drücken - gpio.22 reinschreiben auf die Treffer schauen, dann nächsten Skipt anklicken wenn 0 nächsten anklicken und so weiter
          Spenden
          HomoranH L 2 Antworten Letzte Antwort
          • T ticaki
            @laser
            @ticaki dafür gibt es die Suchfunktion im Skripteditor
            Lupe über dem Skriptenexplorer
            • T ticaki
              @laser
              Laser
              schrieb am zuletzt editiert von Laser
              @ticaki Der GPIO wird natürlich von einem Script gesetzt. Das war jetzt blöd ausgedrückt! Ich meinte, das fehlerhafte Setzen.
              Mit der Lupe arbeite ich und finde nur die gewollten Stellen.
              T paul53P 2 Antworten Letzte Antwort
                ticaki
                Ihr habt Geheimnisse vor mir... hätte ich nicht gedacht, was verbergt ihr noch?
                Spenden
                • L Laser
                  ticaki
                  @laser sagte in Raspi GPIO wird gesetzt, wie Ursache herausfinden?:
                  dann zeigen
                  Spenden
                  • T ticaki
                    dann zeigen
                    Laser
                    @ticaki
                    // Akkuspannung überwachen mit Vergleichswert bei Änderung führe aus:
                    // State value to set for "javascript.0.Logik.AkkuMin" has to be type "string" but received type "number" ?
                    // "state" hieß früher "new state"
                    on({id: (['vedirect.0.V'/*Main or channel 1 (battery) voltage*/]), change: "lt"},async function (obj) {
                    //on({id: (['vedirect.0.V'/*Main or channel 1 (battery) voltage*/]), valLt: "24.8"},async function (obj) {
                      var value = obj.state.val;
                      // console.log("val: " +value);
                      // console.log("old: " +oldValue);
                     if (getState("vedirect.0.V").val < getState('javascript.0.variables.DP_SpannungMIN'/**/).val) {
                      // console.log("MIN erreicht");
                       setStateDelayed("rpi2.0.gpio.22.state"/*GPIO 22*/,false,5000);
                       setStateDelayed('javascript.0.Logik.AkkuMin'/*AkkuMin*/,true,5000);
                       setStateDelayed('javascript.0.Logik.AkkuMerker'/*AkkuMerker*/,true,5000);
                     };  // Ende if
                    if (getState("vedirect.0.V").val > getState("javascript.0.variables.DP_SpannungMIN").val) {
                      setStateDelayed('javascript.0.Logik.AkkuMin'/*AkkuMin*/,false,1000) ;
                      };  // Ende if
                    });   // Ende on
                    /*  change:
                    Wert	Erklärung
                    eq	Der neue Wert muss gleich dem alten sein
                    ne	Der neue Wert muss nicht gleich dem alten sein (Standard)
                    gt	Neuer Wert muss größer als der alte Wert sein
                    ge	Neuer Wert muss größer oder gleich groß sein
                    lt	Neuer Wert muss kleiner als der alte sein
                    le	Neuer Wert muss kleiner oder gleich groß sein
                    any	Trigger wird immer ausgeführt
                    oder:
                    valLt	mixed	New value must be smaller than given one
                    HomoranH T 2 Antworten Letzte Antwort
                    • L Laser
                      @ticaki
                       };  // Ende if
                        };  // Ende if
                      });   // Ende on
                      /*  change:
                      Wert	Erklärung
                      oder:
                      was kommt da zurück wenn der Adapter gerade neu startet?
                      • L Laser
                        @ticaki
                         };  // Ende if
                          };  // Ende if
                        });   // Ende on
                        /*  change:
                        Wert	Erklärung
                        oder:
                        ticaki
                        @laser
                        aha :)
                        on({id: "vedirect.0.V"/*Main or channel 1 (battery) voltage*/, change: "lt"},function (obj) {
                         if (value < getState('javascript.0.variables.DP_SpannungMIN'/**/).val) {
                         };  // Ende if
                          };  // Ende if
                        das async ist nicht nötig, erhöht nur den "was hab ich nicht bedacht faktor) und man benutzt in on() immer .state.val in deinem Fall obj.state.val. Das Array in id ist auch nicht nötig und was die umschliessenden Klammern machen... kein Plan also weg.
                        noch mehr EDIT: und wenn wir schon dabei sind, man benutzt in JSON {} nur eine Sorte Gänsefüsschen und da wird " bevorzugt (oder ist sogar ne vorschrift ka) alle benutzen ""
                        Spenden
                        paul53P L 2 Antworten Letzte Antwort
                        • T ticaki
                          @laser
                          aha :)
                           };  // Ende if
                            };  // Ende if
                          @ticaki sagte: das async ist nicht nötig
                          @Laser hatte das Skript offenbar mit Blockly begonnen.
                          • T ticaki
                            @laser
                            aha :)
                             };  // Ende if
                              };  // Ende if
                            Laser
                            @Homoran habe die Objekte auf einem Tablet dargestellt und am PC den Adapter neu gestartet. Der Wert steht. Falls man das überhaupt so kontrollieren kann.
                            L T 2 Antworten Letzte Antwort
                            • L Laser
                              Laser
                              @ticaki Blockly mag ich nicht. Mit dem Assync hatte ich mal gelesen, daß man das besser verwenden soll.
                              • L Laser
                                ticaki
                                du siehst das nicht, das must du ins log schreiben lassen.
                                async lässt das nur asychron laufen... im Grund wenn wir folgende auszuführende Funktionen in deinem Skript hast
                                a
                                b async
                                c
                                d
                                wird das sehr warscheinlich so ausgeführt
                                a
                                c
                                d
                                b
                                Also nicht nutzen wenn nicht erforderlich. Da du nicht weißt wann es ausgeführt wird, nur dass es ausgeführt wird.
                                btw. meckert der Javascript editor bestimmt über die fehlende return Promise() :) die er dann auch Promt rot markiert, weil er sie zwar haben will, aber nicht kennt 😁
                                Spenden
                                • T ticaki
                                  a
                                  b async
                                  c
                                  d
                                  a
                                  c
                                  d
                                  b
                                  Laser
                                  @Homoran
                                  Der Wert des VE Adapters bricht nicht ein oder etwas Anderes, wenn der Adapter neu gestartet wird.
                                  Den Adapter starte ich neu, wenn er gestört ist (Überwachung im Log). Soll das immer genau 5:20 Uhr sein?
                                  • L Laser
                                    @Homoran
                                    ticaki
                                    @laser
                                    Wieso schreibst du 5:20 zeigst aber das log von 5:22?
                                    Spenden
                                    • L Laser
                                      @laser sagte: Mit der Lupe arbeite ich und finde nur die gewollten Stellen.
                                      Suchbegriffe werden unter der Gruppe "global" nur im Expertenmodus gefunden.
                                      • T ticaki
                                        @laser
                                        Laser
                                        @ticaki 5:22 habe ich durch Suchen nach gpio.22 gefunden. Die Zeit 5:20 habe ich (ungenau) aus dem E-Chart ermittelt. Die Zeit, zu der ungewollt eingeschaltet wurde.
                                        • L Laser
                                          @laser dann sieh erst einmal zu, dass sämtliche Leichen verschwinden und das log nicht zugemüllt wird.
                                          Vorher ergibt es keinen Sinn nach etwas zu suchen, von dem es dann heisst: gibt es nicht mehr!
