  4. [Adapter] cloudfreie Auslesung von Deye-Invertern
1.2k Beiträge 114 Kommentatoren 516.0k Aufrufe 93 Beobachtet
  • Rene55R Rene55
    @vgoe Sehr schön, Danke. 🤗 Versprich dir nicht zuviel davon.
    Eduard77E Online
    Eduard77E Online
    Eduard77
    schrieb am zuletzt editiert von Eduard77
    #376
    @rene55
    guten Abend. Ich habe gestern Adapter installiert und mit meiner Deye angebunden.
    Es läuft so weit und es werden die Werte übertragen.
    Allerdings habe ich im Log Warnungen.
    2023-07-11 19:14:35.776 - warn: deyeidc.0 (579) ControlCode faulty!: Data may be corrupt, therefore discarded
    2023-07-11 19:15:57.216 - info: admin.0 (301) ==> Connected system.user.admin from ::ffff:192.168.178.31
    2023-07-11 19:16:35.826 - warn: deyeidc.0 (579) ControlCode faulty!: Data may be corrupt, therefore discarded
    2023-07-11 19:22:41.922 - warn: deyeidc.0 (579) ControlCode faulty!: Data may be corrupt, therefore discarded
    2023-07-11 19:25:54.214 - info: web.0 (433) ==> Connected system.user.admin from ::ffff:192.168.178.31
    2023-07-11 19:25:57.671 - info: admin.0 (301) <== Disconnect system.user.admin from ::ffff:192.168.178.31 admin
    2023-07-11 19:26:03.737 - info: web.0 (433) <== Disconnect system.user.admin from ::ffff:192.168.178.31 vis.0
    2023-07-11 19:26:04.013 - info: web.0 (433) ==> Connected system.user.admin from ::ffff:192.168.178.31
    2023-07-11 19:32:31.814 - info: web.0 (433) ==> Connected system.user.admin from ::ffff:192.168.178.31
    2023-07-11 19:32:36.894 - info: web.0 (433) <== Disconnect system.user.admin from ::ffff:192.168.178.31 vis.0
    2023-07-11 19:33:44.953 - info: web.0 (433) ==> Connected system.user.admin from ::ffff:192.168.178.31
    2023-07-11 19:33:48.695 - warn: web.0 (433) Read-only state "deyeidc.0.3942394996.Apo_t1" has been written without ack-flag with value "0"
    2023-07-11 19:33:58.649 - warn: web.0 (433) Read-only state "deyeidc.0.3942394996.Etdy_ge0" has been written without ack-flag with value "0"
    2023-07-11 19:34:05.304 - info: web.0 (433) <== Disconnect system.user.admin from ::ffff:192.168.178.31 vis.0
    2023-07-11 19:34:05.990 - info: web.0 (433) ==> Connected system.user.admin from ::ffff:192.168.178.31
    2023-07-11 19:34:17.289 - info: web.0 (433) <== Disconnect system.user.admin from ::ffff:192.168.178.31 vis.0
    2023-07-11 19:34:17.958 - info: web.0 (433) ==> Connected system.user.admin from ::ffff:192.168.178.31
    2023-07-11 19:36:23.481 - warn: web.0 (433) Read-only state "deyeidc.0.3942394996.Apo_t1" has been written without ack-flag with value "90"
    Was kann ich dagegen machen?
    • Rene55R Offline
      Rene55R Offline
      Rene55
      #377
      @edis77 Von diesen Warnungen hatte ich heute -im gegensatz zu anderen Tagen - sehr viele. Dieser Controllcode wird im WR berechnet und hängt von ... keine Ahnung was ab. Erst mal ignorieren und morgen noch mal schauen. Ändern kann man daran nichts.
      Eduard77E 1 Antwort Letzte Antwort
      • Rene55R Rene55
        Eduard77E Online
        Eduard77E Online
        Eduard77
        #378
        @rene55 Alles klar.
        habe gerade auch noch meldung von Web.0
        web.0  2023-07-11 19:36:23.481	warn	Read-only state "deyeidc.0.3942394996.Apo_t1" has been written without ack-flag with value "90"
        • Eduard77E Eduard77
          @rene55 Alles klar.
          Rene55R Offline
          Rene55R Offline
          Rene55
          #379
          @edis77 Bei mir im Log sehe ich vom web.0 überhaupt nichts. (Ich weiß gar nicht, wofür ich web überhaupt brauchen könnte). Machst du sonst noch was mit den Daten vom deyeidc? Visualisierung?
          • Rene55R Rene55
            Eduard77E Online
            Eduard77E Online
            Eduard77
            #380
            @rene55
            Ich habe in VIS eine kleine Grafik
              @rene55
              Rene55R Offline
              Rene55R Offline
              Rene55
              #381
              @edis77 Ob die web-Warnungen daher kommen kann ich nicht sagen. Ich bin mir nur sicher, dass ich die States 'has been written without ack-flag' mit ack-Flag schreibe.
              Kannst du die Vis (oder den Teil davon) morgen mal abschalten und berichten?
              • P Offline
                Pino72
                #382
                hatte bisher Version 0.0.7 wunderbar am LAufen, habe eben über den Link
                https://github.com/raschy/ioBroker.deyeidc
                die 0.0.9 drüberinstalliert, sieht man auch im IOBroker dass er sie installiert hat leider geht der Adapter nicht mehr an, immer wenn ich auf Starten drücke macht er für 1 Sekunde was und stoppt dann wieder??
                Woran könnte das liegen und wie könnte ich auf 0.0.7 zurück gehen? Im Log sehe ich keine Fehler beim versuchten starten??
                Plattform
                Windows
                Betriebssystem
                win32
                Architektur
                x64
                CPUs
                Geschwindigkeit
                1498 MHz
                Modell
                Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
                RAM
                7.85 GB
                System-Betriebszeit
                00:00:09
                Node.js
                v14.18.0 (Es gibt eine neuere Version: v14.21.3 - Empfohlene Version v18.17.0)
                • P Pino72
                  Plattform
                  Windows
                  Betriebssystem
                  win32
                  Architektur
                  x64
                  CPUs
                  Geschwindigkeit
                  1498 MHz
                  Modell
                  RAM
                  7.85 GB
                  System-Betriebszeit
                  00:00:09
                  Node.js
                  #383
                  @pino72 sagte in [neuer Adapter] cloudfreie Auslesung von Deye-Invertern:
                  Node.js
                  P 1 Antwort Letzte Antwort
                    Node.js
                    Pino72
                    #384
                    Jo das wars :-)
                    Thomas BraunT Rene55R 2 Antworten Letzte Antwort
                    • P Pino72
                      Jo das wars :-)
                      #385
                      @pino72
                      Das ist es furchtbar oft. Insbesondere, wenn die fragliche Version auch bereits abgekündigt wurde. Die Hinweise auf Updates stehen nicht zur Zierde da.
                      • P Pino72
                        Jo das wars :-)
                        Rene55R Offline
                        Rene55R Offline
                        Rene55
                        #386
                        @pino72 Da der Adapter in kürze ins Repository aufgenommen werden soll, musste ich leider node 14.x kicken. So ist halt der Fortschritt.
                        • Rene55R Rene55
                          Pino72
                          #387
                          @rene55
                          Alles gut, leider ist IOBroker noch sehr weit weg von einem "Wartungsfreien" System....der Aufwand bei updates gerade auch bei Windows ist schon immer recht groß. SChade, dass das nicht innerhalb der WebUI gemacht werden kann auf Knopfdruck.
                          Der neue Windows Installer könnte da etwas Abhilfe schaffen , leider ist mein System noch mit dem alten aufgesetzt und das passt nicht zusammen.
                          • P Pino72
                            @rene55
                            #388
                            Kann es auch nicht werden, dafür spielen da viel zu viele Komponenten rein.
                              Rico Sander
                              #389
                              @thomas-braun sagte in [neuer Adapter] cloudfreie Auslesung von Deye-Invertern:
                              Richtig. Und dann ist ja auch noch die Frage, was man unter "wartungsfrei" versteht.
                              Selbst mein Auto braucht ab und zu eine Wartung :-)
                              Updates sind doch normal. Und "sehr weit weg" - naja, das ist wohl eine individuelle Betrachtung
                              Selbst in Windoof gibt es Updates und dass die dann im Hintergrund laufen, ist nicht immer von Vorteil.
                              Genau wie @rene55 schrieb: "So ist halt der Fortschritt."
                              Das Einzige, was man sich zur Not wünschen könnte, dass man vlt. per Mail über vorhandene Updates informiert wird.
                              (Oder gibt es das etwa schon und ich weiß das nicht?)
                              Nicht Jeder wird wie ich die Zeit haben, täglich ioBroker zu kontrollieren/überwachen.
                              Wenns nicht geht, wie man will
                              - muss mans tun, wie man kann.
                              • R Rico Sander
                                Rene55R Offline
                                Rene55R Offline
                                Rene55
                                #390
                                @pi-ter Wenn der Adapter im Repository ist (latest oder stable) gibt ja der ioBroker selbst die Hinweise auf Updates installierter Adapter. Dann wird das alles besser zu handeln sein. Mailkontakt zu den Usern (außer zu dir) habe ich ja nicht und wäre auch etwas aufwändig.
                                • Rene55R Rene55
                                  Rico Sander
                                  #391
                                  @rene55 sagte in [neuer Adapter] cloudfreie Auslesung von Deye-Invertern:
                                  Grüß Dich @rene55 :-)
                                  Ja, das ist natürlich richtig. Im Kontext der Aussage "wartungsfreies System" bezog ich mich auch nicht ausschließlich auf Deinen oder einen Adapter, sondern auf ioBroker gesamt.
                                  Ich selbst habe ein ziemlich eingefahrenes Ritual für den frühen Vormittag:
                                  • Mail checken
                                  • Statistik pflegen (diverse Zählerstände)
                                  • Website pflegen
                                  • ioBroker checken
                                  • Kontrolle Lovelace und jarvis
                                  • und etwa im 2- bis 3-Wochentakt via ssh auf OS-Updates checken
                                  Nicht Jeder hat diese zeitliche Freiheit. Für diese Nutzer wäre eine Benachrichtigung aus ioBroker heraus möglicherweise hilfreich.
                                  Was die Adapter angeht: ja. Ich warte auch immer auf stable. :-)
                                  Klar, das wäre auch schon wieder ein Fall für den deutschen Datenschutz, hihi...
                                  • R Rico Sander
                                    • Mail checken
                                    • Website pflegen
                                    • ioBroker checken
                                    Rene55R Offline
                                    Rene55R Offline
                                    Rene55
                                    #392
                                    @pi-ter So ein Smart-Home-System wird niemals wartungsfrei sein. Selbst wenn die Software ohne weiteres läuft, fällt mal irgendwo ein Sensor aus oder die Batterie ist leer.
                                    Schön, wenn man so ein morgendliches Ritual hat - und sich auch noch daran hält.
                                    • Rene55R Rene55
                                      Rico Sander
                                      #393
                                      Naja, vorbeugen ist besser, als nach hinten fallen ... oder so. Das ist wie mit der Datensicherung - wo auch immer.
                                      Aus Fehlern darf man ja lernen. :man-shrugging:
                                      • R Rico Sander
                                        Pino72
                                        schrieb am zuletzt editiert von Pino72
                                        #394
                                        Hab das heute mal in den Logs gefunden? Der Adapter wurde auch immer wieder mal als nicht verbunden angezeigt...hat das mit dem schlechten Wetter zu tun wo er wenn zu wenig Sonne scheint die Verbindung verliert?
                                        deyeidc.0
                                        	2023-07-24 14:10:09.092	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                        deyeidc.0
                                        	2023-07-24 14:08:09.330	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                        deyeidc.0
                                        	2023-07-24 14:06:08.989	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                        deyeidc.0
                                        	2023-07-24 14:04:09.274	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                        deyeidc.0
                                        	2023-07-24 14:02:07.934	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                        deyeidc.0
                                        	2023-07-24 14:00:07.874	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                        deyeidc.0
                                        	2023-07-24 13:58:08.175	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                        deyeidc.0
                                        	2023-07-24 13:05:18.972	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                        deyeidc.0
                                        	2023-07-24 13:03:18.933	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                        deyeidc.0
                                        	2023-07-24 13:01:19.223	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                        deyeidc.0
                                        	2023-07-24 12:59:10.177	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                        deyeidc.0
                                        	2023-07-24 12:57:09.847	warn	ControlCode faulty!: Data may be corrupt, therefore discarded
                                        Rene55R F 2 Antworten Letzte Antwort
                                        • P Pino72
                                          deyeidc.0
                                          deyeidc.0
                                          deyeidc.0
                                          deyeidc.0
                                          deyeidc.0
                                          deyeidc.0
                                          deyeidc.0
                                          deyeidc.0
                                          deyeidc.0
                                          deyeidc.0
                                          deyeidc.0
                                          deyeidc.0
                                          Rene55R Offline
                                          Rene55R Offline
                                          Rene55
                                          #395
                                          @pino72 Auch da sage ich mal: ja. Da hat der Inverter wohl Mühe, aus den Tiefen seiner selbst alle Daten zusammenzubringen. Dann stimmt der Controllcode nicht und die Antwort wird verworfen, bevor im ioBroker Mist angezeigt wird.
