  4. M-TEC Energy Butler
M-TEC Energy Butler
201 Beiträge 21 Kommentatoren 69.6k Aufrufe 18 Beobachtet
  • metaxaM Offline
    metaxaM Offline
    metaxa
    schrieb am zuletzt editiert von metaxa
    #86
    @gagafreeman Ich habe die IP dort unverändert stehen lassen und ES FUNKTIONIERT! Danke für Dein Posten der Einstellungen! Jedoch hagelt es mir LOG mit folgender Fehlermeldung voll:
    modbus.0
    2023-07-06 14:54:51.873	warn	Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    Ausfühliches LOG:
    2023-07-06 15:01:12.285 - debug: modbus.0 (1808930) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2023-07-06 15:01:12.616 - debug: modbus.0 (1808930) Objects client ready ... initialize now
    2023-07-06 15:01:12.699 - debug: modbus.0 (1808930) Objects create System PubSub Client
    2023-07-06 15:01:12.715 - debug: modbus.0 (1808930) Objects create User PubSub Client
    2023-07-06 15:01:13.495 - debug: modbus.0 (1808930) Objects client initialize lua scripts
    2023-07-06 15:01:13.601 - debug: modbus.0 (1808930) Objects connected to redis: 0.0.0.0:9001
    2023-07-06 15:01:13.846 - debug: modbus.0 (1808930) Redis States: Use Redis connection: 0.0.0.0:9000
    2023-07-06 15:01:14.241 - debug: modbus.0 (1808930) States create System PubSub Client
    2023-07-06 15:01:14.243 - debug: modbus.0 (1808930) States create User PubSub Client
    2023-07-06 15:01:15.433 - debug: modbus.0 (1808930) States connected to redis: 0.0.0.0:9000
    2023-07-06 15:01:17.006 - debug: modbus.0 (1808930) Plugin sentry Initialize Plugin (enabled=true)
    2023-07-06 15:01:19.674 - info: modbus.0 (1808930) starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.1, js-controller: 4.0.24
    2023-07-06 15:01:20.724 - debug: modbus.0 (1808930) Initialize Objects for disInputs: []
    2023-07-06 15:01:20.727 - debug: modbus.0 (1808930) Initialize Objects for coils: []
    2023-07-06 15:01:20.729 - debug: modbus.0 (1808930) Initialize Objects for inputRegs: []
    2023-07-06 15:01:20.730 - debug: modbus.0 (1808930) Initialize Objects for holdingRegs: [{"_address":"33000","name":"State of Charge (SOC)","description":"Ladezustand der Batterie","unit":"%","type":"uint16be","len":1,"factor":0.01,"offset":4,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":33000,"deviceId":247,"id":"holdingRegisters.33000_State_of_Charge_(SOC)"}]
    2023-07-06 15:01:20.731 - debug: modbus.0 (1808930) Add holdingRegisters.33000_State_of_Charge_(SOC): {"_id":"holdingRegisters.33000_State_of_Charge_(SOC)","type":"state","common":{"name":"Ladezustand der Batterie","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":33000,"deviceId":247,"type":"uint16be","len":1,"offset":4,"factor":0.01,"poll":true}}
    2023-07-06 15:01:21.969 - info: modbus.0 (1808930) Connected to slave 192.168.0.216
    2023-07-06 15:01:21.972 - debug: modbus.0 (1808930) [DevID_247] Poll start ---------------------
    2023-07-06 15:01:21.974 - debug: modbus.0 (1808930) Initialization of scale factors done!
    2023-07-06 15:01:21.976 - debug: modbus.0 (1808930) [DevID_247/holdingRegs] Poll address 33000 - 1 registers
    2023-07-06 15:01:22.177 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:22.234 - debug: modbus.0 (1808930) [DevID_247/holdingRegs] Poll address 33000 DONE
    2023-07-06 15:01:22.283 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:24.380 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:24.472 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:24.583 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:24.778 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:24.981 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:25.342 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:25.453 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:27.548 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:27.646 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:27.750 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:27.948 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:28.148 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:28.261 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:30.279 - info: host.iOProduktiv "system.adapter.modbus.0" disabled
    2023-07-06 15:01:30.281 - info: host.iOProduktiv stopInstance system.adapter.modbus.0 (force=false, process=true)
    2023-07-06 15:01:30.350 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:30.455 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:30.565 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:30.763 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:30.979 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:31.040 - info: modbus.0 (1808930) Got terminate signal TERMINATE_YOURSELF
    2023-07-06 15:01:31.077 - debug: modbus.0 (1808930) Closing client on purpose.
    2023-07-06 15:01:31.079 - info: modbus.0 (1808930) terminating
    2023-07-06 15:01:31.101 - debug: modbus.0 (1808930) Plugin sentry destroyed
    2023-07-06 15:01:31.102 - info: modbus.0 (1808930) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-06 15:01:31.104 - warn: modbus.0 (1808930) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    2023-07-06 15:01:31.130 - debug: modbus.0 (1808930) Socket closed with error
    2023-07-06 15:01:31.131 - debug: modbus.0 (1808930) Clearing timeout of the current request.
    2023-07-06 15:01:31.136 - debug: modbus.0 (1808930) Cleaning up request fifo.
    2023-07-06 15:01:31.284 - info: host.iOProduktiv stopInstance system.adapter.modbus.0 send kill signal
    2023-07-06 15:01:32.401 - info: host.iOProduktiv instance system.adapter.modbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    @Homoran & @wendy2702 könnt ihr mir bitte eventuell noch bei den Registereinträgen helfen?
    Die 30000er sind holdingRegister
    Laut dieser Erklärung handelt es sich bei den 11xxxx um discrete Input Contacts, gebe ich im passenden Reiter z.B. 11028 ein, kann ich aber nicht UINIT32 und die Länge 2 einstellen.
    20221125_MTEC-EnergyButler_Modbus_RTU_Protkoll.pdf
    Danke im Voraus
    HomoranH wendy2702W 2 Antworten Letzte Antwort
    • metaxaM metaxa
      modbus.0
      Ausfühliches LOG:
      Danke im Voraus
      #87
      @metaxa sagte in M-TEC Energy Butler:
      eigentlich nicht!
      Holdingregister sind 40000er.
      30000er sind Inputregister.
      wären das weder noch, sondern diskrete Eingänge.
      metaxaM 1 Antwort Letzte Antwort
      • metaxaM metaxa
        modbus.0
        Ausfühliches LOG:
        Danke im Voraus
        wendy2702W Online
        wendy2702W Online
        #88
        @metaxa im Spoiler ist ein Bild und kein Log.
        Wie sehen die Register einstellungen aktuell aus mit denen der Offset Fehler kommt ?
        • wendy2702W wendy2702
          metaxaM Offline
          metaxaM Offline
          metaxa
          #89
          @wendy2702 sagte in M-TEC Energy Butler:
          Entschldigung! Copy/Paste und nicht kontrolliert. schon ausgebessert in meinem Beitrag.
          Wobei egal ist, ob ich bei Offset 0, 1, 2, oder 4 eintrage.
            eigentlich nicht!
            metaxaM Offline
            metaxaM Offline
            metaxa
            #90
            @homoran sagte in M-TEC Energy Butler:
            Super, poste selbst einen Link und lese ihn falsch oder scheinbar gar nicht :-(
            Jetzt habe ich die 33000 Adresse unter InputRegister eingetragen, leider bekomme ich keine Daten, nur eine andere Fehlermeldung.
            modbus.0
            2023-07-06 18:45:08.983	debug	Closing client on purpose.
            modbus.0
            2023-07-06 18:45:07.981	debug	Cleaning up request fifo.
            modbus.0
            2023-07-06 18:45:07.980	debug	Clearing timeout of the current request.
            modbus.0
            2023-07-06 18:45:07.979	debug	Socket closed with error
            modbus.0
            2023-07-06 18:45:07.977	info	Disconnected from slave 192.168.0.216
            modbus.0
            2023-07-06 18:45:07.976	debug	Closing client on purpose.
            modbus.0
            2023-07-06 18:45:07.925	warn	Poll error count: 7 code: "ReadInputRegisters: Invalid FC 3"
            Die 33000 eingetragen unter Holding brachte zwar Daten aber auch die Fehlermeldug wie schon oben beschrieben.
            • metaxaM metaxa
              #91
              ich habe noch nie etwas bei Offset aktiv eingetragen 🤔
              FC3 muss etwas mit der internen Kommunikation zu tun haben.
              Bin da noch nicht fit drin.
              laut guhgell soll das read holding registers heißen.
              hab in der Doku zu deinem Butler nicht gefunden, ob die Adressen nur um 10000 verschoben sind (v2<->v3) und beide male Holdingregister sind, oder tatsächlich einmal holding und beim anderen input.
              • metaxaM Offline
                metaxaM Offline
                metaxa
                #92
                @homoran ich hab die 33000 jetzt wieder unter holding eingegeben und bekomme zumindest daten und gratis die Fehlermeldung, dass mit dem OFFSET etwas nicht stimmt.
                e84fccb7-c7b9-435b-8397-def6e971ef8b-image.png !
                Mannn .... ist das ein spanisches Dorf für mich, vielleicht hat @wendy2702 noch eine Idee.
                • metaxaM metaxa
                  wendy2702W Online
                  wendy2702W Online
                  #93
                  @metaxa bitte das log und die Register Einstellung dazu posten.
                  Ich habe das Doc noch nicht gelesen danach aktuell nur am Handy bin aber hast du bei Faktor in irgendeinem Register denn was eingetragen?
                    metaxaM Offline
                    metaxaM Offline
                    metaxa
                    #94
                    LOG
                    2023-07-06 19:18:44.919 - info: host.iOProduktiv instance system.adapter.modbus.0 started with pid 2394949
                    2023-07-06 19:18:47.720 - debug: modbus.0 (2394949) Redis Objects: Use Redis connection: 0.0.0.0:9001
                    2023-07-06 19:18:48.051 - debug: modbus.0 (2394949) Objects client ready ... initialize now
                    2023-07-06 19:18:48.137 - debug: modbus.0 (2394949) Objects create System PubSub Client
                    2023-07-06 19:18:48.139 - debug: modbus.0 (2394949) Objects create User PubSub Client
                    2023-07-06 19:18:48.789 - debug: modbus.0 (2394949) Objects client initialize lua scripts
                    2023-07-06 19:18:48.828 - debug: modbus.0 (2394949) Objects connected to redis: 0.0.0.0:9001
                    2023-07-06 19:18:49.033 - debug: modbus.0 (2394949) Redis States: Use Redis connection: 0.0.0.0:9000
                    2023-07-06 19:18:49.485 - debug: modbus.0 (2394949) States create System PubSub Client
                    2023-07-06 19:18:49.491 - debug: modbus.0 (2394949) States create User PubSub Client
                    2023-07-06 19:18:49.979 - debug: modbus.0 (2394949) States connected to redis: 0.0.0.0:9000
                    2023-07-06 19:18:51.698 - debug: modbus.0 (2394949) Plugin sentry Initialize Plugin (enabled=true)
                    2023-07-06 19:18:55.672 - info: modbus.0 (2394949) starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.1, js-controller: 4.0.24
                    2023-07-06 19:18:56.967 - debug: modbus.0 (2394949) Initialize Objects for disInputs: []
                    2023-07-06 19:18:56.970 - debug: modbus.0 (2394949) Initialize Objects for coils: []
                    2023-07-06 19:18:56.971 - debug: modbus.0 (2394949) Initialize Objects for inputRegs: []
                    2023-07-06 19:18:56.975 - debug: modbus.0 (2394949) Initialize Objects for holdingRegs: [{"_address":"33000","name":"State of Charge (SOC)","description":"Ladezustand der Batterie","unit":"%","type":"uint16be","len":1,"factor":0.01,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":33000,"deviceId":247,"id":"holdingRegisters.33000_State_of_Charge_(SOC)"}]
                    2023-07-06 19:18:56.979 - debug: modbus.0 (2394949) Add holdingRegisters.33000_State_of_Charge_(SOC): {"_id":"holdingRegisters.33000_State_of_Charge_(SOC)","type":"state","common":{"name":"Ladezustand der Batterie","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"%"},"native":{"regType":"holdingRegs","address":33000,"deviceId":247,"type":"uint16be","len":1,"offset":0,"factor":0.01,"poll":true}}
                    2023-07-06 19:18:59.712 - info: modbus.0 (2394949) Connected to slave 192.168.0.216
                    2023-07-06 19:18:59.714 - debug: modbus.0 (2394949) [DevID_247] Poll start ---------------------
                    2023-07-06 19:18:59.733 - debug: modbus.0 (2394949) Initialization of scale factors done!
                    2023-07-06 19:18:59.734 - debug: modbus.0 (2394949) [DevID_247/holdingRegs] Poll address 33000 - 1 registers
                    2023-07-06 19:18:59.799 - debug: modbus.0 (2394949) [DevID_247/holdingRegs] Poll address 33000 DONE
                    2023-07-06 19:19:00.629 - warn: modbus.0 (2394949) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
                    2023-07-06 19:19:00.716 - warn: modbus.0 (2394949) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
                    2023-07-06 19:19:00.809 - warn: modbus.0 (2394949) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
                    2023-07-06 19:19:01.006 - warn: modbus.0 (2394949) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
                    2023-07-06 19:19:01.203 - warn: modbus.0 (2394949) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
                    2023-07-06 19:19:01.328 - warn: modbus.0 (2394949) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
                    2023-07-06 19:19:03.417 - warn: modbus.0 (2394949) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
                    2023-07-06 19:19:03.513 - warn: modbus.0 (2394949) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
                    2023-07-06 19:19:03.621 - warn: modbus.0 (2394949) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
                    2023-07-06 19:19:03.821 - warn: modbus.0 (2394949) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
                    2023-07-06 19:19:04.017 - warn: modbus.0 (2394949) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
                    2023-07-06 19:19:04.128 - warn: modbus.0 (2394949) Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
                    Es ist egal, was ich bei Offseteintrage oder ihn leer lasse.
                    • metaxaM metaxa
                      LOG
                      #95
                      @wendy2702 fragte
                      das hast du. und wenn ich das richtig sehe sogar mit Komma statt Punkt.
                      nimm es mal vorsichtshalber gsnz raus, nimm 1 als Faktor
                      Edit:
                      bei mir
                      Dezimalpunkt und kein Offset.
                        @wendy2702 fragte
                        Edit:
                        bei mir
                        metaxaM Offline
                        metaxaM Offline
                        metaxa
                        #96
                        Damit bekomme ich den Prozentwert x100 und die gleiche Fehlermeldung wg. OFFSET
                        Damit bekomme ich auch den richtigen Prozentwert (Komma oder Punkt) und die gleiche Fehlermeldungen wg. OFFSET
                        • metaxaM metaxa
                          #97
                          die gleiche Fehlermeldung wg. Faktor
                          war doch bisher wegen Offset!?
                          wenn nicht, denke/hoffe ich dass @wendy2702 auf der richtigen Fährte ist.
                          Möglicherweise keinen Faktor, sondern offset 2 (falls mit drm Offset in diesem Falle die Kommaverschiebung gemeint ist)
                            metaxaM Offline
                            metaxaM Offline
                            metaxa
                            #98
                            @homoran Mahh, ich bin schon ganz gaga, sorry. Es wird immer nur OFFSET angemeckert. Ich editiere meinen Eintrag oben, danke @Homoran .
                            • metaxaM metaxa
                              #99
                              @metaxa Das wird schon!
                              ich versuche mich hier auf deine Kosten weiterzubilden.
                                metaxaM Offline
                                metaxaM Offline
                                metaxa
                                #100
                                @homoran ich gebe sogar gratis ein Bierchen dazu :-) wenn du mal wien besuchst, das Angbeot bekamst du schon mal und hast es bis jetzt nicht eingelöst :-)
                                • wendy2702W Online
                                  wendy2702W Online
                                  #101
                                  Arbeitest du mit Aliases verwenden in den Grundeinstellungen?
                                  Sorry falls schon irgendwo gepostet. Bin halt nur am Handy
                                    metaxaM Offline
                                    metaxaM Offline
                                    metaxa
                                    #102
                                    @wendy2702
                                    Nein
                                    Ich bin dir dankbar für jede Hilfestellung!
                                    • wendy2702W Online
                                      wendy2702W Online
                                      #103
                                      Hm,
                                      das mit dem Offset habe ich so noch nicht gesehen.
                                      Scheint ja so als wenn das entweder von dem Butler oder dem Konverter kommt und der Adapter damit nichts anfangen kann.
                                      Glaube ich würde mal ein Issue beim Adapter öffnen oder mit einem anderen Tool testen.
                                      • G gagafreeman
                                        Servus zusammen,
                                        bin auch ein Besitzer von Energy Butler 10kW-3P-3G25 und habe das ganze mal verfolgt.
                                        Mit erfolg habe ich die Kommnikation zwischen dem Wechselrichter und Iobrocker hinbekommen,
                                        habe den 2a88550a-a69b-42e3-b0cc-f3d645dc6344-grafik.png stecker nur A und B bei 13 und 14 angeschlossen die Abschlusswiderstände habe ich nicht deaktivert,
                                        mein Converter ist der "Waveshare RS485 to RJ45 Ethernet Converter Module, Industrial Rail-Mount RS485 Serial Server,TCP/IP to Serial Module,300~115200 BPS Baudrate,10 / 100M Auto-Negotiation RJ45 Connector" nach lagen versuchen muss habe ich geschaft 😀 .
                                        Folgen einstellung habe ich im IoBrocker 93dca4c6-1f5a-4cca-9679-45de64fffe8c-grafik.png und dan in die Holding Register
                                        und so siehts mal aus oben die erweiter ansicht aktiviren damit du den factor ein tragen kannst sonst sind es die Rohrwerte.
                                        Das ergebins in den Objekten 74ab5dc7-4dc5-4e36-a1c0-66d01c36547b-grafik.png.
                                        Als kleine hilfe habe ich diese Software benutz um die Komminaktion zu prüfen https://sourceforge.net/projects/qmodmaster/ unterstütz serial und auch TCP Verbindungen, ohne eine Installtion ein ausfürungs exe.
                                        Die einstellungen im Waveshare fa9f2559-6d4f-4ef2-a99c-6b5eed75976f-grafik.png
                                        hoffe du kannst es auch zum laufen kriegen.
                                        sir.wastl
                                        #104
                                        Hi @gagafreeman hab das Problem den waveshare zum laufen zu bekommen. Könntest Du mal ein Foto von der Anschluss an den BUS-Stecker im Energybutler posten, das wäre super.
                                        Rainer Maier 0R 1 Antwort Letzte Antwort
                                        • S sir.wastl
                                          Rainer Maier 0R Offline
                                          Rainer Maier 0
                                          #105
                                          Ich habe auch seit 3 Wochen einen Energy Butler am Laufen - ich lese derzeit die Daten aus der API des Webportals aus mittels einer Erweiterung von diesem Projekt (https://github.com/croedel/M-TEC-API/blob/main/MTECapi.py). Ich habe es dahingehend erweitert, dass ich die Daten zum MQTT-Broker sende und von dort auslese.
                                          Das Problem dabei ist, dass die Daten nur alle 60s aktualisiert werden. Ich wuerde jedoch eine höhere Auflösung benötigen, damit ich dann in Zukunft die Ladeleistung der Wallbox entsprechend der PV-Produktion und des Verbrauchs justieren kann.
                                          Ich wollte mich deshalb auch auf den Modbus draufhängen - allerdings bekomme ich überhaupt keine Daten vom Energy Butler. Ich habe ein CAT7-Kabel genommen, welches ich mit Orange auf dem Stecker auf den Pin 14 und Orange/Weiß habe ich auf den PIN 13 verbunden.
                                          Der Abschlusswiederstand auf dem Stecker am Wechselrichter ist auf Position 1.
                                          EB_abschluss.jpg Am anderen Ende habe ich einen Waveshare Converter: Orange ist mit TA und Orange/Weiß ist mit TB verbunden.
                                          Im IO-Broker habe ich soweit alles konfiguriert, wie in diesem Forum beschrieben - ich bekommen jedoch nur folgende Fehlermeldungen:
                                          modbus.0 2023-07-31 17:22:11.566 info Connected to slave 192.168.0.10
                                          modbus.0 2023-07-31 17:22:16.570 warn Error: undefined
                                          modbus.0 2023-07-31 17:22:16.571 error Request timed out.
                                          modbus.0 2023-07-31 17:22:16.572 error Client in error state.
                                          modbus.0 2023-07-31 17:22:16.574 warn Poll error count: 3 code: {"err":"timeout","timeout":5000}
                                          modbus.0 2023-07-31 17:22:17.572 info Disconnected from slave 192.168.0.10
                                          Ich habe die Verbindung auch schon abseits von iobroker direkt von einem rasperry mittels rs485-usb-adapter und diverser modbus-clients getestet. Wenn ich einen ESP32 dranhaenge, der Modbus-Server spielt, funktioniert es, aber vom Energy-Butler bekomme ich keinerlei Rueckmeldung.
                                          Es gibt ja schon Leute, die das zum Laufen gebracht haben - Hat jemand eine Idee wo der Fehler liegen koennte?
                                          M S metaxaM A 4 Antworten Letzte Antwort
