  4. Wechselnde USB-Stick mounts nach Neustart
    5.3k
31 Beiträge 3 Kommentatoren 3.5k Aufrufe 3 Beobachtet
  • M MP_Trixi
    ok, habe das File wieder gelöscht:
    pi@smarthome:/etc/apt/sources.list.d $ sudo rm bullseye-proposed-updates.list
    pi@smarthome:/etc/apt/sources.list.d $ ls
    grafana.list  influxdata.list  nodesource.list  raspi.list
    NodeJS hab ich gemäß Anleitung auf Stand gebracht:
    pi@smarthome:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
    pi@smarthome:~ $ type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    /usr/bin/npx
    v18.16.1
    v18.16.1
    9.5.1
    9.5.1
    dann iob fix und iob start
    beim Start hatte ich dann aber einige Fehler im log, z.B.:
    2023-06-30 12:28:13.976 - error: javascript.0 (11426) npm
    2023-06-30 12:28:13.978 - error: javascript.0 (11426) WARN deprecated har-validator@5.1.5: this library is no longer supported
    2023-06-30 12:28:14.471 - error: javascript.0 (11426) npm
    2023-06-30 12:28:14.473 - error: javascript.0 (11426) WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    2023-06-30 12:28:14.825 - error: javascript.0 (11426) npm
    2023-06-30 12:28:14.827 - error: javascript.0 (11426) WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    2023-06-30 12:28:15.223 - error: javascript.0 (11426) npm
    2023-06-30 12:28:15.225 - error: javascript.0 (11426) WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    2023-06-30 12:29:01.635 - error: host.smarthome Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
    2023-06-30 12:29:01.637 - error: host.smarthome Caught by controller[0]: throw e;
    2023-06-30 12:29:01.637 - error: host.smarthome Caught by controller[0]: ^
    2023-06-30 12:29:01.638 - error: host.smarthome Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
    2023-06-30 12:29:01.638 - error: host.smarthome Caught by controller[0]: was compiled against a different Node.js version using
    2023-06-30 12:29:01.639 - error: host.smarthome Caught by controller[0]: NODE_MODULE_VERSION 93. This version of Node.js requires
    2023-06-30 12:29:01.639 - error: host.smarthome Caught by controller[0]: NODE_MODULE_VERSION 108. Please try re-compiling or re-installing
    2023-06-30 12:29:01.640 - error: host.smarthome Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2023-06-30 12:29:01.641 - error: host.smarthome Caught by controller[0]: at Module._extensions..node (node:internal/modules/cjs/loader:1340:18)
    2023-06-30 12:29:01.641 - error: host.smarthome Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
    2023-06-30 12:29:01.642 - error: host.smarthome Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
    2023-06-30 12:29:01.642 - error: host.smarthome Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-06-30 12:29:01.642 - error: host.smarthome Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
    2023-06-30 12:29:01.643 - error: host.smarthome Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
    2023-06-30 12:29:01.643 - error: host.smarthome Caught by controller[0]: at Object. (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
    2023-06-30 12:29:01.643 - error: host.smarthome Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-06-30 12:29:01.644 - error: host.smarthome Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2023-06-30 12:29:01.644 - error: host.smarthome Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32) {
    2023-06-30 12:29:01.645 - error: host.smarthome Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    2023-06-30 12:29:01.645 - error: host.smarthome Caught by controller[0]: }
    2023-06-30 12:29:01.645 - error: host.smarthome Caught by controller[0]: Node.js v18.16.1
    2023-06-30 12:29:01.646 - error: host.smarthome instance system.adapter.selverf.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-06-30 12:30:29.497 - error: host.smarthome iobroker npm-rebuild: Rebuilding native modules failed
    @mp_trixi sagte in Wechselnde USB-Stick mounts nach Neustart:
    Das Verzeichnis gibt es auf meinem System gar nicht.
    Keine Ahnung was das da bei dir ist.
    Ist aber was für einen eigenen Thread.
      MP_Trixi
      ok - keine Ahnung wo ich das her habe. In dem Verzeichnis ist eine README.md
        GNU nano 5.4        README.md
      # @serialport/Bindings
      The `Binding` is how Node-SerialPort talks to the underlying system. By default, we auto detect Windows, Linux and OS X, and load the appropriate module for your system. You can assign `SerialPort.Binding` to any binding you like. Find more by searchin>
      Learn more at our [bindings documentation](https://serialport.io/docs/api-bindings) page.
      # Android users
      When using termux there is a way to compile serialport to be used under Android
      ```sh
      CFLAGS=-fPIC CXXFLAGS=-fPIC yarn rebuild
      Habe nochmals iob stop und iob start gemacht. Jetzt sind alle Fehler weg (vlt. hat das "rebuilding native modules" doch funktioniert. So passt es erstmal für mich. Falls das wieder auftaucht mache ich einen neues Thema auf. Danke Dir nochmals.
      • M MP_Trixi
        # Android users
        ```sh
        @mp_trixi
        iob diag
        sagt dazu?
          @mp_trixi
          iob diag
          sagt dazu?
          MP_Trixi
          glaub da hab ich (auch) noch einen Hund drin:
          Used repository: stable
          Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
          Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
          die gesamte Ausgabe:
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Architecture    : aarch64
          Docker          : false
          Virtualization  : none
          Distributor ID: Debian
          Description:    Debian GNU/Linux 11 (bullseye)
          Release:        11
          Codename:       bullseye
          PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
          NAME="Debian GNU/Linux"
          VERSION_ID="11"
          VERSION="11 (bullseye)"
          VERSION_CODENAME=bullseye
          ID=debian
          HOME_URL="https://www.debian.org/"
          SUPPORT_URL="https://www.debian.org/support"
          BUG_REPORT_URL="https://bugs.debian.org/"
          Systemuptime and Load:
           13:39:13 up  2:06,  2 users,  load average: 0.85, 1.14, 1.15
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          Other values than 0x0 hint to temperature/voltage problems
          temp=52.1'C
          volt=0.9160V
          *** Time and Time Zones ***
                         Local time: Fri 2023-06-30 13:39:13 CEST
                     Universal time: Fri 2023-06-30 11:39:13 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            3.8G        2.4G        537M        0.0K        904M        1.4G
          Swap:            99M          0B         99M
          Total:          3.9G        2.4G        637M
                   3794 M total memory
                   2352 M used memory
                   2485 M active memory
                    424 M inactive memory
                    537 M free memory
                     49 M buffer memory
                    854 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /dev/root      ext4       28G   12G   15G  45% /
          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
          tmpfs          tmpfs     759M  844K  759M   1% /run
          /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
          [Fri Jun 30 11:32:49 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:62:A2:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=cf73e54d-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Fri Jun 30 11:32:50 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Fri Jun 30 11:32:50 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Fri Jun 30 11:32:52 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
          /var:
          4.0G    /var/
          3.2G    /var/log
          2.8G    /var/log/journal/6c5b87a59f584c03b6491451f2e5b6da
          479M    /var/lib
          Archived and active journals take up 2.7G in the file system.
          /opt/iobroker/backups:
          4.0K    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          3.6G    /opt/iobroker/iobroker-data/
          3.0G    /opt/iobroker/iobroker-data/history
          458M    /opt/iobroker/iobroker-data/files
          95M     /opt/iobroker/iobroker-data/backup-objects
          78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
          51M     /opt/iobroker/iobroker-data/states.jsonl
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          29M     /opt/iobroker/iobroker-data/objects.jsonl
          15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
          8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.16.1
          /usr/bin/node           v18.16.1
          /usr/bin/npm            9.5.1
          /usr/bin/npx            9.5.1
          nodejs:
            Installed: 18.16.1-deb-1nodesource1
            Candidate: 18.16.1-deb-1nodesource1
            Version table:
           *** 18.16.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
               12.22.12~dfsg-1~deb11u4 500
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
               12.22.12~dfsg-1~deb11u3 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
          No problems detected
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  4.0.24
          admin:          6.3.5
          javascript:     7.0.3
          Adapters from github:   1
          Adapter State
          + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          + system.adapter.alexa2.0                 : alexa2                : smarthome                                -  enabled
          + system.adapter.backitup.0               : backitup              : smarthome                                -  enabled
            system.adapter.bmw.0                    : bmw                   : smarthome                                - disabled
            system.adapter.devices.0                : devices               : smarthome                                -  enabled
            system.adapter.discovery.0              : discovery             : smarthome                                - disabled
          + system.adapter.energiefluss.0           : energiefluss          : smarthome                                -  enabled
            system.adapter.feiertage.0              : feiertage             : smarthome                                -  enabled
            system.adapter.habpanel.0               : habpanel              : smarthome                                - disabled
          + system.adapter.harmony.0                : harmony               : smarthome                                -  enabled
            system.adapter.heatingcontrol.0         : heatingcontrol        : smarthome                                - disabled
          + system.adapter.history.0                : history               : smarthome                                -  enabled
            system.adapter.homeconnect.0            : homeconnect           : smarthome                                - disabled
          + system.adapter.hue-extended.0           : hue-extended          : smarthome                                -  enabled
            system.adapter.ical.0                   : ical                  : smarthome                                -  enabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: smarthome                                - disabled
            system.adapter.icons-icons8.0           : icons-icons8          : smarthome                                -  enabled
            system.adapter.icons-material-png.0     : icons-material-png    : smarthome                                - disabled
            system.adapter.icons-material-svg.0     : icons-material-svg    : smarthome                                -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : smarthome                                - disabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: smarthome                                -  enabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : smarthome                                - disabled
          + system.adapter.influxdb.0               : influxdb              : smarthome                                -  enabled, port: 8086
          + system.adapter.javascript.0             : javascript            : smarthome                                -  enabled
            system.adapter.javascript.1             : javascript            : smarthome                                - disabled
          + system.adapter.logparser.0              : logparser             : smarthome                                -  enabled
          + system.adapter.meross.0                 : meross                : smarthome                                -  enabled
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : smarthome                                -  enabled, port: 54321
          + system.adapter.modbus.0                 : modbus                : smarthome                                -  enabled
          + system.adapter.myenergi.0               : myenergi              : smarthome                                -  enabled
          + system.adapter.net-tools.0              : net-tools             : smarthome                                -  enabled
            system.adapter.openweathermap.0         : openweathermap        : smarthome                                -  enabled
            system.adapter.powerfox2.0              : powerfox2             : smarthome                                -  enabled
          + system.adapter.pvforecast.0             : pvforecast            : smarthome                                -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : smarthome                                -  enabled
            system.adapter.schoolfree.0             : schoolfree            : smarthome                                -  enabled
          + system.adapter.selverf.0                : selverf               : smarthome                                -  enabled
          + system.adapter.shelly.0                 : shelly                : smarthome                                -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : smarthome                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.sourceanalytix.0         : sourceanalytix        : smarthome                                -  enabled
          + system.adapter.synology.0               : synology              : smarthome                                -  enabled, port: 5501
          + system.adapter.telegram.0               : telegram              : smarthome                                -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.trashschedule.0          : trashschedule         : smarthome                                -  enabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : smarthome                                -  enabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : smarthome                                -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : smarthome                                -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : smarthome                                -  enabled
            system.adapter.vis-inventwo.0           : vis-inventwo          : smarthome                                - disabled
            system.adapter.vis-map.0                : vis-map               : smarthome                                -  enabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : smarthome                                -  enabled
            system.adapter.vis-material-webfont.0   : vis-material-webfont  : smarthome                                -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : smarthome                                -  enabled
            system.adapter.vis-metro.0              : vis-metro             : smarthome                                -  enabled
            system.adapter.vis-plumb.0              : vis-plumb             : smarthome                                -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : smarthome                                -  enabled
            system.adapter.vis-weather.0            : vis-weather           : smarthome                                -  enabled
            system.adapter.vis.0                    : vis                   : smarthome                                -  enabled
          + system.adapter.vw-connect.0             : vw-connect            : smarthome                                -  enabled
          + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.ws.0                     : ws                    : smarthome                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.yahka.0                  : yahka                 : smarthome                                -  enabled
          + system.adapter.zigbee.0                 : zigbee                : smarthome                                -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_626a1ae89b93eb11ac711b4f3d98b6d1-if00-port0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
          Adapter    "backitup"     : 2.6.23   , installed 2.6.23
          Adapter    "bmw"          : 2.5.7    , installed 2.5.7
          Adapter    "devices"      : 1.1.5    , installed 1.1.5
          Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
          Adapter    "harmony"      : 1.2.2    , installed 1.2.2
          Adapter    "heatingcontrol": 2.10.6  , installed 2.10.6
          Adapter    "history"      : 2.2.4    , installed 2.2.4
          Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
          Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
          Adapter    "ical"         : 1.13.3   , installed 1.13.3
          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
          Adapter    "javascript"   : 7.0.3    , installed 7.0.3
          Adapter    "logparser"    : 2.2.0    , installed 2.2.0
          Adapter    "meross"       : 1.15.1   , installed 1.15.1
          Adapter    "mihome-vacuum": 3.11.0   , installed 3.8.8  [Updatable]
          Adapter    "modbus"       : 5.0.11   , installed 5.0.5  [Updatable]
          Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
          Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
          Adapter    "openweathermap": 0.3.9   , installed 0.3.9
          Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
          Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
          Adapter    "schoolfree"   : 1.1.1    , installed 1.1.1
          Adapter    "selverf"      : 0.6.2    , installed 0.6.2
          Adapter    "shelly"       : 6.4.1    , installed 6.4.1
          Adapter    "synology"     : 2.1.13   , installed 2.1.13
          Adapter    "telegram"     : 1.15.6   , installed 1.15.6
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "vis-icontwo"  : 0.94.0   , installed 0.94.0
          Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
          Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
          Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
          Adapter    "yahka"        : 0.17.0   , installed 0.17.0
          Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
          Objects and States
          Objects:        22939
          States:         20151
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://repos.influxdata.com/debian stable InRelease
          Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
          Hit:7 https://apt.grafana.com stable InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1599       567/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:43849         0.0.0.0:*               LISTEN      1001       203072     20754/io.yahka.0
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       195347     20296/iobroker.js-c
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       196046     20296/iobroker.js-c
          tcp        0      0 0.0.0.0:44833           0.0.0.0:*               LISTEN      1001       197534     20754/io.yahka.0
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        13821      685/influxd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          1601       567/sshd: /usr/sbin
          tcp6       0      0 :::3000                 :::*                    LISTEN      109        14815      781/grafana
          tcp6       0      0 :::61991                :::*                    LISTEN      1001       198206     20809/io.harmony.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       197442     20686/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       193454     20314/io.admin.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       197458     20702/io.simple-api
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        15464      685/influxd
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       198412     20957/io.ws.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13668      450/avahi-daemon: r
          udp        0      0 0.0.0.0:50618           0.0.0.0:*                           108        13670      450/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       196946     20466/io.shelly.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13754      681/dhcpcd
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       196391     20526/io.mihome-vac
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       198207     20809/io.harmony.0
          udp6       0      0 :::5353                 :::*                                108        13669      450/avahi-daemon: r
          udp6       0      0 :::52628                :::*                                108        13671      450/avahi-daemon: r
          2023-06-30 13:36:55.841  - info: meross.0 (20394) Can not get Data for Device 2204268862707951070248e1e9904eb1: Error: Device has no data connection available
          2023-06-30 13:36:55.842  - warn: meross.0 (20394) Can not get Data for Device 2204268862707951070248e1e9904eb1: undefined
          2023-06-30 13:37:00.087  - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 21840
          2023-06-30 13:37:02.788  - info: powerfox2.0 (21840) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.16.1, js-controller: 4.0.24
          2023-06-30 13:37:06.051  - info: powerfox2.0 (21840) Terminated (NO_ERROR): Without reason
          2023-06-30 13:37:06.590  - info: host.smarthome instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
          2023-06-30 13:38:00.147  - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 21964
          2023-06-30 13:38:01.985  - info: meross.0 (20394) Can not get Data for Device 2204268862707951070248e1e9904eb1: Error: Device has no data connection available
          2023-06-30 13:38:01.986  - warn: meross.0 (20394) Can not get Data for Device 2204268862707951070248e1e9904eb1: undefined
          2023-06-30 13:38:03.224  - info: powerfox2.0 (21964) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.16.1, js-controller: 4.0.24
          2023-06-30 13:38:08.782  - info: powerfox2.0 (21964) Terminated (NO_ERROR): Without reason
          2023-06-30 13:38:09.342  - info: host.smarthome instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
          2023-06-30 13:39:00.416  - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 22100
          2023-06-30 13:39:03.039  - info: powerfox2.0 (22100) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.16.1, js-controller: 4.0.24
          2023-06-30 13:39:06.781  - info: powerfox2.0 (22100) Terminated (NO_ERROR): Without reason
          2023-06-30 13:39:07.324  - info: host.smarthome instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
          2023-06-30 13:39:08.129  - info: meross.0 (20394) Can not get Data for Device 2204268862707951070248e1e9904eb1: Error: Device has no data connection available
          2023-06-30 13:39:08.130  - warn: meross.0 (20394) Can not get Data for Device 2204268862707951070248e1e9904eb1: undefined
          2023-06-30 13:40:00.066  - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 22476
          2023-06-30 13:40:04.557  - info: powerfox2.0 (22476) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.16.1, js-controller: 4.0.24
          2023-06-30 13:40:08.816  - info: powerfox2.0 (22476) Terminated (NO_ERROR): Without reason
          2023-06-30 13:40:09.357  - info: host.smarthome instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
          2023-06-30 13:40:14.433  - info: meross.0 (20394) Can not get Data for Device 2204268862707951070248e1e9904eb1: Error: Device has no data connection available
          2023-06-30 13:40:14.434  - warn: meross.0 (20394) Can not get Data for Device 2204268862707951070248e1e9904eb1: undefined
          2023-06-30 13:41:00.122  - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 23598
          DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
          • M MP_Trixi
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Docker          : false
            Release:        11
            Codename:       bullseye
            VERSION_ID="11"
            ID=debian
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            temp=52.1'C
            volt=0.9160V
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     3794 M total memory
                     2352 M used memory
                      537 M free memory
                       49 M buffer memory
                      854 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            4.0G    /var/
            3.2G    /var/log
            479M    /var/lib
            /usr/bin/npm            9.5.1
            /usr/bin/npx            9.5.1
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            javascript:     7.0.3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        22939
            States:         20151
            Pending Updates: 0
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @mp_trixi bei einem 4GB System über 50 Adapter ist nicht grad "gesund" ;)
            Lehrling seit 1975 !!!
            • M MP_Trixi
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Docker          : false
              Release:        11
              Codename:       bullseye
              VERSION_ID="11"
              ID=debian
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              temp=52.1'C
              volt=0.9160V
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M          0B         99M
                       3794 M total memory
                       2352 M used memory
                        537 M free memory
                         49 M buffer memory
                        854 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              4.0G    /var/
              3.2G    /var/log
              479M    /var/lib
              /usr/bin/npm            9.5.1
              /usr/bin/npx            9.5.1
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.3.5
              javascript:     7.0.3
              Adapter State
              + instance is alive
              Objects and States
              Objects:        22939
              States:         20151
              Pending Updates: 0
              @mp_trixi
              Schaut okay aus.
              Zu dem Repo: Versuch mal die sog. 'live'-Quelle einzubinden.
              Hab da aber gerade die Befehle dazu nicht zur Hand.
              • DJMarc75D DJMarc75
                MP_Trixi
                @djmarc75
                hab nicht alles am Laufen, die Auslastung scheint mir noch ok zu sein:
                @Thomas-Braun
                ok, ich versuche mal dazu was zu finden
                • M MP_Trixi
                  @djmarc75
                  @Thomas-Braun
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  da bitte nicht schauen, sondern in der Konsole :)
                  Thomas BraunT M 2 Antworten Letzte Antwort
                    @djmarc75 sagte in Wechselnde USB-Stick mounts nach Neustart:
                    free
                    in iob diag
                    schaut doch gut aus.
                      MP_Trixi
                      @djmarc75
                      so?
                      pi@smarthome:/opt/iobroker/node_modules/@serialport/bindings $ free
                      Mem:         3885396     2438848      501240         844      945308     1467740
                      Swap:         102396           0      102396
                      • M MP_Trixi
                        @djmarc75
                        so?
                        @mp_trixi
                        free -mt --mega
                        Die Ausgabe ist aber wie gesagt auch im Output von iob diag schon drin.
                          @mp_trixi
                          free -mt --mega
                          MP_Trixi
                          @thomas-braun sagte in Wechselnde USB-Stick mounts nach Neustart:
                          free -mt --mega
                          den mag mein System nicht:
                          pi@smarthome:/opt/iobroker/node_modules/@serialport/bindings $ free -mt --mega
                          free: Multiple unit options doesn't make sense.
                          aber wenn es im diag drin ist und passt bin ich ja beruhigt.
                            @mp_trixi
                            Schaut okay aus.
                            MP_Trixi
                            schrieb am zuletzt editiert von MP_Trixi
                            dazu habe ich leider nichts gefunden. In der GUI sieht es so aus:
                            ist es das?
                            https://iobroker.readthedocs.io/de/latest/ecosystem/domains.html#iobroker-live
                              @mp_trixi
                              free -mt --mega
                              MP_Trixi
                              hab was gefunden:
                              https://forum.iobroker.net/topic/57541/gelöst-nach-installation-weden-keine-adapter-angezeigt/11
                              und so gemacht. Wenn ich damit dann einen iob diag mache, hängt sich der iobroker an der Stelle auf:
                              Skript v.2023-04-16
                              *** BASE SYSTEM ***
                              Docker          : false
                              Release:        11
                              Codename:       bullseye
                              VERSION_ID="11"
                              ID=debian
                               14:24:59 up  2:52,  2 users,  load average: 1.02, 0.98, 0.88
                              CPU threads: 4
                              Raspberry only:
                              throttled=0x0
                              temp=54.5'C
                              volt=0.9160V
                                             Local time: Fri 2023-06-30 14:24:59 CEST
                                         Universal time: Fri 2023-06-30 12:24:59 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            3.8G        2.5G        954M        0.0K        325M        1.2G
                              Swap:            99M         89M         10M
                              Total:          3.9G        2.6G        964M
                                       3794 M total memory
                                       2514 M used memory
                                       1545 M active memory
                                        984 M inactive memory
                                        954 M free memory
                                          2 M buffer memory
                                        322 M swap cache
                                         99 M total swap
                                         89 M used swap
                                         10 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              4.0G    /var/
                              3.2G    /var/log
                              464M    /var/lib
                              42M     /opt/iobroker/iobroker-data/objects.jsonl
                              13M     /opt/iobroker/iobroker-data/states.jsonl
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.3.5
                              javascript:     7.0.3
                              Adapter State
                              + instance is alive
                              live-stable   : http://iobroker.live/repo/sources-dist.json
                              Active repo(s): live-stable
                              Used repository: live-stable
                              • M MP_Trixi
                                hab was gefunden:
                                Skript v.2023-04-16
                                *** BASE SYSTEM ***
                                Docker          : false
                                Release:        11
                                Codename:       bullseye
                                VERSION_ID="11"
                                ID=debian
                                CPU threads: 4
                                Raspberry only:
                                throttled=0x0
                                temp=54.5'C
                                volt=0.9160V
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                /home/pi
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:            99M         89M         10M
                                         3794 M total memory
                                         2514 M used memory
                                          954 M free memory
                                            2 M buffer memory
                                          322 M swap cache
                                           99 M total swap
                                           89 M used swap
                                           10 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /var:
                                4.0G    /var/
                                3.2G    /var/log
                                464M    /var/lib
                                /usr/bin/npm            9.5.1
                                /usr/bin/npx            9.5.1
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.3.5
                                javascript:     7.0.3
                                Adapter State
                                + instance is alive
                                MP_Trixi
                                @Thomas-Braun
                                musste dem Raspi den Stecker ziehn (pingbar war er noch, aber auf die Konsole kam ich nicht mehr). Nach dem Neustart scheint es ok zu sein:
                                Skript v.2023-04-16
                                *** BASE SYSTEM ***
                                Docker          : false
                                Release:        11
                                Codename:       bullseye
                                VERSION_ID="11"
                                ID=debian
                                 14:39:10 up 5 min,  2 users,  load average: 2.96, 2.38, 1.09
                                CPU threads: 4
                                Raspberry only:
                                throttled=0x0
                                temp=59.4'C
                                volt=0.9160V
                                               Local time: Fri 2023-06-30 14:39:11 CEST
                                           Universal time: Fri 2023-06-30 12:39:11 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                /home/pi
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            3.8G        2.5G        1.1G        0.0K        265M        1.3G
                                Swap:            99M        2.0M         97M
                                Total:          3.9G        2.5G        1.2G
                                         3794 M total memory
                                         2458 M used memory
                                          617 M active memory
                                         1974 M inactive memory
                                         1069 M free memory
                                           10 M buffer memory
                                          255 M swap cache
                                           99 M total swap
                                            2 M used swap
                                           97 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                [Fri Jun 30 14:33:37 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:62:A2:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=cf73e54d-02 rootfstype=ext4 fsck.repair=yes rootwait
                                [Fri Jun 30 14:33:38 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                                [Fri Jun 30 14:33:38 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                                [Fri Jun 30 14:33:39 2023] EXT4-fs (mmcblk0p2): recovery complete
                                [Fri Jun 30 14:33:39 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Fri Jun 30 14:33:39 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Fri Jun 30 14:33:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                /var:
                                3.9G    /var/
                                3.1G    /var/log
                                2.7G    /var/log/journal/6c5b87a59f584c03b6491451f2e5b6da
                                468M    /var/lib
                                Archived and active journals take up 2.6G in the file system.
                                55M     /opt/iobroker/iobroker-data/objects.jsonl
                                16M     /opt/iobroker/iobroker-data/states.jsonl
                                /usr/bin/npm            9.5.1
                                /usr/bin/npx            9.5.1
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.3.5
                                javascript:     7.0.3
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        22941
                                States:         20154
                                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                Hit:2 http://deb.debian.org/debian bullseye InRelease
                                Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                Pending Updates: 0
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13248      740/iobroker.js-con
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13255      740/iobroker.js-con
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11262      565/sshd: /usr/sbin
                                tcp        0      0 127.0.0.1:41421         0.0.0.0:*               LISTEN      1001       21828      1642/io.yahka.0
                                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        14024      684/influxd
                                tcp        0      0 0.0.0.0:35981           0.0.0.0:*               LISTEN      1001       18744      1642/io.yahka.0
                                tcp6       0      0 :::61991                :::*                    LISTEN      1001       16222      1679/io.harmony.0
                                tcp6       0      0 :::3000                 :::*                    LISTEN      109        15373      735/grafana
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          11264      565/sshd: /usr/sbin
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19951      1482/io.web.0
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14638      935/io.admin.0
                                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       19916      1493/io.simple-api.
                                tcp6       0      0 :::8086                 :::*                    LISTEN      999        12230      684/influxd
                                tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21568      1771/io.ws.0
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11223      449/avahi-daemon: r
                                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15918      1215/io.shelly.0
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12140      680/dhcpcd
                                udp        0      0 0.0.0.0:57516           0.0.0.0:*                           108        11225      449/avahi-daemon: r
                                udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       16850      1238/io.mihome-vacu
                                udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       16223      1679/io.harmony.0
                                udp6       0      0 :::5353                 :::*                                108        11224      449/avahi-daemon: r
                                udp6       0      0 :::58916                :::*                                108        11226      449/avahi-daemon: r
                                2023-06-30 14:38:56.492  - info: sourceanalytix.0 (1723) Initialization of 0_userdata.0.Strom.WallboxGaN_Vortagesverbrauch_Gesamt successfully
                                2023-06-30 14:38:56.515  - info: sourceanalytix.0 (1723) Successfully activated SourceAnalytix for 8 of 8 states, will do my Job until you stop me!
                                2023-06-30 14:38:57.184  - info: meross.0 (1063) Can not get Data for Device 2204268862707951070248e1e9904eb1: Error: Device has no data connection available
                                2023-06-30 14:38:57.185  - warn: meross.0 (1063) Can not get Data for Device 2204268862707951070248e1e9904eb1: undefined
                                2023-06-30 14:39:00.105  - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 2062
                                2023-06-30 14:39:03.697  - info: powerfox2.0 (2062) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.16.1, js-controller: 4.0.24
                                2023-06-30 14:39:05.531  - info: alexa2.0 (1245) Unknown Device, but enabling commands, Try it and report back if commands work.
                                2023-06-30 14:39:05.533  - info: alexa2.0 (1245) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                                2023-06-30 14:39:05.533  - info: alexa2.0 (1245)     Device-type:A93SQJNJQLDSS - TV Schlafzimmer (CHANGE_NAME,SHARKNADO,MULTI_WAKEWORDS_SUPPORTED,SUPPORTS_LOCALE_SWITCH,SUPPORTS_LOCALE,ACTIVE_AFTER_FRO,SPEECH_RECOGNIZER_USS,VOLUME_SETTING,TIMERS_AND_ALARMS,PERSISTENT_CONNECTION,ARTHUR_TARGET,EQUALIZER_CONTROLLER_MIDRANGE,DIALOG_INTERFACE_VERSION,SOUND_SETTINGS,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,MICROPHONE,ADAPTIVE_LISTENING,SUPPORTS_SOFTWARE_VERSION,CUSTOM_ALARM_TONE,EARCONS,REMINDERS,FLASH_BRIEFING,AUDIO_CONTROLS)
                                2023-06-30 14:39:08.790  - info: powerfox2.0 (2062) Terminated (NO_ERROR): Without reason
                                2023-06-30 14:39:09.497  - info: host.smarthome instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                                2023-06-30 14:39:17.583  - info: alexa2.0 (1245) Unknown Device, but enabling commands, Try it and report back if commands work.
                                2023-06-30 14:39:17.584  - info: alexa2.0 (1245) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                                2023-06-30 14:39:17.585  - info: alexa2.0 (1245)     Device-type:A2N49KXGVA18AR - Philipps Fire (NO_TIME_ZONE_SETTING,ASX_TIME_ZONE,MICROPHONE,VOLUME_SETTING,ADAPTIVE_LISTENING,SUPPORTS_SOFTWARE_VERSION,TIMERS_AND_ALARMS,PERSISTENT_CONNECTION,REMINDERS)
                                2023-06-30 14:39:47.062  - info: alexa2.0 (1245) No smart home devices to query
                                2023-06-30 14:39:48.509  - info: alexa2.0 (1245) Subscribing to states...
                                2023-06-30 14:39:48.516  - info: alexa2.0 (1245) Deleting the following states: ["Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.#enabled","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.#delete","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.powerState","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.connectivity","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.connectivity-reason","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.#query","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.#enabled","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.#delete","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.powerState","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.connectivity","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.connectivity-reason","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.#query","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.#enabled","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.#delete","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.powerState","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.connectivity","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.connectivity-reason","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.#query","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.#enabled","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.#delete","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.powerState","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.connectivity","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.connectivity-reason","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.#query","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.#enabled","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.#delete","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.powerState","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.connectivity","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.connectivity-reason","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.#query","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.#delete","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.powerState","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.brightness","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.colorName","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.color-hue","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.color-saturation","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.color-brightness","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.colorRgb","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.colorTemperatureName","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.colorTemperatureInKelvin","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.connectivity","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.connectivity-reason","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.#enabled","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.#delete","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.powerState","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.connectivity","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.connectivity-reason","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.#query","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.#includeInAllQuery","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.#includeInAllQuery","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.#includeInAllQuery","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.#includeInAllQuery"]
                                2023-06-30 14:39:50.615  - info: alexa2.0 (1245) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                2023-06-30 14:40:00.573  - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 2419
                                2023-06-30 14:40:03.328  - info: meross.0 (1063) Can not get Data for Device 2204268862707951070248e1e9904eb1: Error: Device has no data connection available
                                2023-06-30 14:40:03.329  - warn: meross.0 (1063) Can not get Data for Device 2204268862707951070248e1e9904eb1: undefined
                                2023-06-30 14:40:04.250  - info: powerfox2.0 (2419) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.16.1, js-controller: 4.0.24
                                2023-06-30 14:40:06.674  - info: powerfox2.0 (2419) Terminated (NO_ERROR): Without reason
                                2023-06-30 14:40:07.276  - info: host.smarthome instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                                2023-06-30 14:40:08.594  - info: alexa2.0 (1245) Initialization Done ...
                                • M MP_Trixi
                                  @Thomas-Braun
                                  Skript v.2023-04-16
                                  *** BASE SYSTEM ***
                                  Docker          : false
                                  Release:        11
                                  Codename:       bullseye
                                  VERSION_ID="11"
                                  ID=debian
                                  CPU threads: 4
                                  Raspberry only:
                                  throttled=0x0
                                  temp=59.4'C
                                  volt=0.9160V
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:            99M        2.0M         97M
                                           3794 M total memory
                                           2458 M used memory
                                            617 M active memory
                                           1069 M free memory
                                             10 M buffer memory
                                            255 M swap cache
                                             99 M total swap
                                              2 M used swap
                                             97 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /var:
                                  3.9G    /var/
                                  3.1G    /var/log
                                  468M    /var/lib
                                  /usr/bin/npm            9.5.1
                                  /usr/bin/npx            9.5.1
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.3.5
                                  javascript:     7.0.3
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        22941
                                  States:         20154
                                  Pending Updates: 0
                                  @mp_trixi
                                  Dann kannste ja jetzt die beiden Adapter noch hochziehen.
                                    @mp_trixi
                                    MP_Trixi
                                    das hätte ich vorher schon gekonnt - das hat komischerweise mit der alten repo Einstellung auch funktioniert. Die anderen Updates bis auf die zwei hatte ich ja noch vor dem live dingens gemacht. Die zwei waren mit verschiedenen Adapter Versionen ein schönes gefrickel bis sie liefen. Deswegen traute ich mit da noch nicht ran. Ich zieh mir jetzt nochmal ein image und wage es dann.
