  4. Wechselnde USB-Stick mounts nach Neustart
    5.4k
31 Beiträge 3 Kommentatoren 3.5k Aufrufe 3 Beobachtet
  • M MP_Trixi
    glaub da hab ich (auch) noch einen Hund drin:
    Used repository: stable
    Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
    Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
    die gesamte Ausgabe:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     13:39:13 up  2:06,  2 users,  load average: 0.85, 1.14, 1.15
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=52.1'C
    volt=0.9160V
    *** Time and Time Zones ***
                   Local time: Fri 2023-06-30 13:39:13 CEST
               Universal time: Fri 2023-06-30 11:39:13 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        2.4G        537M        0.0K        904M        1.4G
    Swap:            99M          0B         99M
    Total:          3.9G        2.4G        637M
             3794 M total memory
             2352 M used memory
             2485 M active memory
              424 M inactive memory
              537 M free memory
               49 M buffer memory
              854 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       28G   12G   15G  45% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  844K  759M   1% /run
    /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Fri Jun 30 11:32:49 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:62:A2:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=cf73e54d-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Fri Jun 30 11:32:50 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Jun 30 11:32:50 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Fri Jun 30 11:32:52 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    4.0G    /var/
    3.2G    /var/log
    2.8G    /var/log/journal/6c5b87a59f584c03b6491451f2e5b6da
    479M    /var/lib
    Archived and active journals take up 2.7G in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    3.6G    /opt/iobroker/iobroker-data/
    3.0G    /opt/iobroker/iobroker-data/history
    458M    /opt/iobroker/iobroker-data/files
    95M     /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    51M     /opt/iobroker/iobroker-data/states.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    29M     /opt/iobroker/iobroker-data/objects.jsonl
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.1
    /usr/bin/node           v18.16.1
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.1-deb-1nodesource1
      Candidate: 18.16.1-deb-1nodesource1
      Version table:
     *** 18.16.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : smarthome                                -  enabled
    + system.adapter.backitup.0               : backitup              : smarthome                                -  enabled
      system.adapter.bmw.0                    : bmw                   : smarthome                                - disabled
      system.adapter.devices.0                : devices               : smarthome                                -  enabled
      system.adapter.discovery.0              : discovery             : smarthome                                - disabled
    + system.adapter.energiefluss.0           : energiefluss          : smarthome                                -  enabled
      system.adapter.feiertage.0              : feiertage             : smarthome                                -  enabled
      system.adapter.habpanel.0               : habpanel              : smarthome                                - disabled
    + system.adapter.harmony.0                : harmony               : smarthome                                -  enabled
      system.adapter.heatingcontrol.0         : heatingcontrol        : smarthome                                - disabled
    + system.adapter.history.0                : history               : smarthome                                -  enabled
      system.adapter.homeconnect.0            : homeconnect           : smarthome                                - disabled
    + system.adapter.hue-extended.0           : hue-extended          : smarthome                                -  enabled
      system.adapter.ical.0                   : ical                  : smarthome                                -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: smarthome                                - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : smarthome                                -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : smarthome                                - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : smarthome                                -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : smarthome                                - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: smarthome                                -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : smarthome                                - disabled
    + system.adapter.influxdb.0               : influxdb              : smarthome                                -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : smarthome                                -  enabled
      system.adapter.javascript.1             : javascript            : smarthome                                - disabled
    + system.adapter.logparser.0              : logparser             : smarthome                                -  enabled
    + system.adapter.meross.0                 : meross                : smarthome                                -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : smarthome                                -  enabled, port: 54321
    + system.adapter.modbus.0                 : modbus                : smarthome                                -  enabled
    + system.adapter.myenergi.0               : myenergi              : smarthome                                -  enabled
    + system.adapter.net-tools.0              : net-tools             : smarthome                                -  enabled
      system.adapter.openweathermap.0         : openweathermap        : smarthome                                -  enabled
      system.adapter.powerfox2.0              : powerfox2             : smarthome                                -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : smarthome                                -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : smarthome                                -  enabled
      system.adapter.schoolfree.0             : schoolfree            : smarthome                                -  enabled
    + system.adapter.selverf.0                : selverf               : smarthome                                -  enabled
    + system.adapter.shelly.0                 : shelly                : smarthome                                -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : smarthome                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sourceanalytix.0         : sourceanalytix        : smarthome                                -  enabled
    + system.adapter.synology.0               : synology              : smarthome                                -  enabled, port: 5501
    + system.adapter.telegram.0               : telegram              : smarthome                                -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.trashschedule.0          : trashschedule         : smarthome                                -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : smarthome                                -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : smarthome                                -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : smarthome                                -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : smarthome                                -  enabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : smarthome                                - disabled
      system.adapter.vis-map.0                : vis-map               : smarthome                                -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : smarthome                                -  enabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : smarthome                                -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : smarthome                                -  enabled
      system.adapter.vis-metro.0              : vis-metro             : smarthome                                -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : smarthome                                -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : smarthome                                -  enabled
      system.adapter.vis-weather.0            : vis-weather           : smarthome                                -  enabled
      system.adapter.vis.0                    : vis                   : smarthome                                -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : smarthome                                -  enabled
    + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.ws.0                     : ws                    : smarthome                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : smarthome                                -  enabled
    + system.adapter.zigbee.0                 : zigbee                : smarthome                                -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_626a1ae89b93eb11ac711b4f3d98b6d1-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "bmw"          : 2.5.7    , installed 2.5.7
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "heatingcontrol": 2.10.6  , installed 2.10.6
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
    Adapter    "meross"       : 1.15.1   , installed 1.15.1
    Adapter    "mihome-vacuum": 3.11.0   , installed 3.8.8  [Updatable]
    Adapter    "modbus"       : 5.0.11   , installed 5.0.5  [Updatable]
    Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
    Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
    Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
    Adapter    "schoolfree"   : 1.1.1    , installed 1.1.1
    Adapter    "selverf"      : 0.6.2    , installed 0.6.2
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "telegram"     : 1.15.6   , installed 1.15.6
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vis-icontwo"  : 0.94.0   , installed 0.94.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
    Adapter    "yahka"        : 0.17.0   , installed 0.17.0
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        22939
    States:         20151
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:7 https://apt.grafana.com stable InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1599       567/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:43849         0.0.0.0:*               LISTEN      1001       203072     20754/io.yahka.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       195347     20296/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       196046     20296/iobroker.js-c
    tcp        0      0 0.0.0.0:44833           0.0.0.0:*               LISTEN      1001       197534     20754/io.yahka.0
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        13821      685/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1601       567/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      109        14815      781/grafana
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       198206     20809/io.harmony.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       197442     20686/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       193454     20314/io.admin.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       197458     20702/io.simple-api
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        15464      685/influxd
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       198412     20957/io.ws.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13668      450/avahi-daemon: r
    udp        0      0 0.0.0.0:50618           0.0.0.0:*                           108        13670      450/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       196946     20466/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13754      681/dhcpcd
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       196391     20526/io.mihome-vac
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       198207     20809/io.harmony.0
    udp6       0      0 :::5353                 :::*                                108        13669      450/avahi-daemon: r
    udp6       0      0 :::52628                :::*                                108        13671      450/avahi-daemon: r
    2023-06-30 13:36:55.841  - info: meross.0 (20394) Can not get Data for Device 2204268862707951070248e1e9904eb1: Error: Device has no data connection available
    2023-06-30 13:36:55.842  - warn: meross.0 (20394) Can not get Data for Device 2204268862707951070248e1e9904eb1: undefined
    2023-06-30 13:37:00.087  - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 21840
    2023-06-30 13:37:02.788  - info: powerfox2.0 (21840) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.16.1, js-controller: 4.0.24
    2023-06-30 13:37:06.051  - info: powerfox2.0 (21840) Terminated (NO_ERROR): Without reason
    2023-06-30 13:37:06.590  - info: host.smarthome instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
    2023-06-30 13:38:00.147  - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 21964
    2023-06-30 13:38:01.985  - info: meross.0 (20394) Can not get Data for Device 2204268862707951070248e1e9904eb1: Error: Device has no data connection available
    2023-06-30 13:38:01.986  - warn: meross.0 (20394) Can not get Data for Device 2204268862707951070248e1e9904eb1: undefined
    2023-06-30 13:38:03.224  - info: powerfox2.0 (21964) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.16.1, js-controller: 4.0.24
    2023-06-30 13:38:08.782  - info: powerfox2.0 (21964) Terminated (NO_ERROR): Without reason
    2023-06-30 13:38:09.342  - info: host.smarthome instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
    2023-06-30 13:39:00.416  - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 22100
    2023-06-30 13:39:03.039  - info: powerfox2.0 (22100) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.16.1, js-controller: 4.0.24
    2023-06-30 13:39:06.781  - info: powerfox2.0 (22100) Terminated (NO_ERROR): Without reason
    2023-06-30 13:39:07.324  - info: host.smarthome instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
    2023-06-30 13:39:08.129  - info: meross.0 (20394) Can not get Data for Device 2204268862707951070248e1e9904eb1: Error: Device has no data connection available
    2023-06-30 13:39:08.130  - warn: meross.0 (20394) Can not get Data for Device 2204268862707951070248e1e9904eb1: undefined
    2023-06-30 13:40:00.066  - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 22476
    2023-06-30 13:40:04.557  - info: powerfox2.0 (22476) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.16.1, js-controller: 4.0.24
    2023-06-30 13:40:08.816  - info: powerfox2.0 (22476) Terminated (NO_ERROR): Without reason
    2023-06-30 13:40:09.357  - info: host.smarthome instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
    2023-06-30 13:40:14.433  - info: meross.0 (20394) Can not get Data for Device 2204268862707951070248e1e9904eb1: Error: Device has no data connection available
    2023-06-30 13:40:14.434  - warn: meross.0 (20394) Can not get Data for Device 2204268862707951070248e1e9904eb1: undefined
    2023-06-30 13:41:00.122  - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 23598
    @mp_trixi
    Schaut okay aus.
    Zu dem Repo: Versuch mal die sog. 'live'-Quelle einzubinden.
    Hab da aber gerade die Befehle dazu nicht zur Hand.
    • DJMarc75D DJMarc75
      @mp_trixi bei einem 4GB System über 50 Adapter ist nicht grad "gesund" ;)
      MP_Trixi
      @djmarc75
      hab nicht alles am Laufen, die Auslastung scheint mir noch ok zu sein:
      @Thomas-Braun
      ok, ich versuche mal dazu was zu finden
      • M MP_Trixi
        @djmarc75
        @Thomas-Braun
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @mp_trixi sagte in Wechselnde USB-Stick mounts nach Neustart:
        da bitte nicht schauen, sondern in der Konsole :)
        Lehrling seit 1975 !!!
        Thomas BraunT M 2 Antworten Letzte Antwort
          @djmarc75 sagte in Wechselnde USB-Stick mounts nach Neustart:
          free
          in iob diag
          schaut doch gut aus.
            MP_Trixi
            @djmarc75
            so?
            pi@smarthome:/opt/iobroker/node_modules/@serialport/bindings $ free
            Mem:         3885396     2438848      501240         844      945308     1467740
            Swap:         102396           0      102396
            • M MP_Trixi
              @djmarc75
              so?
              @mp_trixi
              free -mt --mega
              Die Ausgabe ist aber wie gesagt auch im Output von iob diag schon drin.
                @mp_trixi
                free -mt --mega
                MP_Trixi
                @thomas-braun sagte in Wechselnde USB-Stick mounts nach Neustart:
                free -mt --mega
                den mag mein System nicht:
                pi@smarthome:/opt/iobroker/node_modules/@serialport/bindings $ free -mt --mega
                free: Multiple unit options doesn't make sense.
                aber wenn es im diag drin ist und passt bin ich ja beruhigt.
                  @mp_trixi
                  Schaut okay aus.
                  MP_Trixi
                  schrieb am zuletzt editiert von MP_Trixi
                  dazu habe ich leider nichts gefunden. In der GUI sieht es so aus:
                  ist es das?
                  https://iobroker.readthedocs.io/de/latest/ecosystem/domains.html#iobroker-live
                    @mp_trixi
                    free -mt --mega
                    MP_Trixi
                    hab was gefunden:
                    https://forum.iobroker.net/topic/57541/gelöst-nach-installation-weden-keine-adapter-angezeigt/11
                    und so gemacht. Wenn ich damit dann einen iob diag mache, hängt sich der iobroker an der Stelle auf:
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:        11
                    Codename:       bullseye
                    VERSION_ID="11"
                    ID=debian
                     14:24:59 up  2:52,  2 users,  load average: 1.02, 0.98, 0.88
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x0
                    temp=54.5'C
                    volt=0.9160V
                                   Local time: Fri 2023-06-30 14:24:59 CEST
                               Universal time: Fri 2023-06-30 12:24:59 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            3.8G        2.5G        954M        0.0K        325M        1.2G
                    Swap:            99M         89M         10M
                    Total:          3.9G        2.6G        964M
                             3794 M total memory
                             2514 M used memory
                             1545 M active memory
                              984 M inactive memory
                              954 M free memory
                                2 M buffer memory
                              322 M swap cache
                               99 M total swap
                               89 M used swap
                               10 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    4.0G    /var/
                    3.2G    /var/log
                    464M    /var/lib
                    42M     /opt/iobroker/iobroker-data/objects.jsonl
                    13M     /opt/iobroker/iobroker-data/states.jsonl
                    /usr/bin/npm            9.5.1
                    /usr/bin/npx            9.5.1
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.3.5
                    javascript:     7.0.3
                    Adapter State
                    + instance is alive
                    live-stable   : http://iobroker.live/repo/sources-dist.json
                    Active repo(s): live-stable
                    Used repository: live-stable
                    • M MP_Trixi
                      hab was gefunden:
                      Skript v.2023-04-16
                      *** BASE SYSTEM ***
                      Docker          : false
                      Release:        11
                      Codename:       bullseye
                      VERSION_ID="11"
                      ID=debian
                      CPU threads: 4
                      Raspberry only:
                      throttled=0x0
                      temp=54.5'C
                      volt=0.9160V
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:            99M         89M         10M
                               3794 M total memory
                               2514 M used memory
                                954 M free memory
                                  2 M buffer memory
                                322 M swap cache
                                 99 M total swap
                                 89 M used swap
                                 10 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      4.0G    /var/
                      3.2G    /var/log
                      464M    /var/lib
                      /usr/bin/npm            9.5.1
                      /usr/bin/npx            9.5.1
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.3.5
                      javascript:     7.0.3
                      Adapter State
                      + instance is alive
                      MP_Trixi
                      @Thomas-Braun
                      musste dem Raspi den Stecker ziehn (pingbar war er noch, aber auf die Konsole kam ich nicht mehr). Nach dem Neustart scheint es ok zu sein:
                      Skript v.2023-04-16
                      *** BASE SYSTEM ***
                      Docker          : false
                      Release:        11
                      Codename:       bullseye
                      VERSION_ID="11"
                      ID=debian
                       14:39:10 up 5 min,  2 users,  load average: 2.96, 2.38, 1.09
                      CPU threads: 4
                      Raspberry only:
                      throttled=0x0
                      temp=59.4'C
                      volt=0.9160V
                                     Local time: Fri 2023-06-30 14:39:11 CEST
                                 Universal time: Fri 2023-06-30 12:39:11 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            3.8G        2.5G        1.1G        0.0K        265M        1.3G
                      Swap:            99M        2.0M         97M
                      Total:          3.9G        2.5G        1.2G
                               3794 M total memory
                               2458 M used memory
                                617 M active memory
                               1974 M inactive memory
                               1069 M free memory
                                 10 M buffer memory
                                255 M swap cache
                                 99 M total swap
                                  2 M used swap
                                 97 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      [Fri Jun 30 14:33:37 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:62:A2:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=cf73e54d-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Fri Jun 30 14:33:38 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                      [Fri Jun 30 14:33:38 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                      [Fri Jun 30 14:33:39 2023] EXT4-fs (mmcblk0p2): recovery complete
                      [Fri Jun 30 14:33:39 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Fri Jun 30 14:33:39 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                      [Fri Jun 30 14:33:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                      /var:
                      3.9G    /var/
                      3.1G    /var/log
                      2.7G    /var/log/journal/6c5b87a59f584c03b6491451f2e5b6da
                      468M    /var/lib
                      Archived and active journals take up 2.6G in the file system.
                      55M     /opt/iobroker/iobroker-data/objects.jsonl
                      16M     /opt/iobroker/iobroker-data/states.jsonl
                      /usr/bin/npm            9.5.1
                      /usr/bin/npx            9.5.1
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.3.5
                      javascript:     7.0.3
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        22941
                      States:         20154
                      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                      Hit:2 http://deb.debian.org/debian bullseye InRelease
                      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                      Pending Updates: 0
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13248      740/iobroker.js-con
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13255      740/iobroker.js-con
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11262      565/sshd: /usr/sbin
                      tcp        0      0 127.0.0.1:41421         0.0.0.0:*               LISTEN      1001       21828      1642/io.yahka.0
                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        14024      684/influxd
                      tcp        0      0 0.0.0.0:35981           0.0.0.0:*               LISTEN      1001       18744      1642/io.yahka.0
                      tcp6       0      0 :::61991                :::*                    LISTEN      1001       16222      1679/io.harmony.0
                      tcp6       0      0 :::3000                 :::*                    LISTEN      109        15373      735/grafana
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          11264      565/sshd: /usr/sbin
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19951      1482/io.web.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14638      935/io.admin.0
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       19916      1493/io.simple-api.
                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        12230      684/influxd
                      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21568      1771/io.ws.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11223      449/avahi-daemon: r
                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15918      1215/io.shelly.0
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12140      680/dhcpcd
                      udp        0      0 0.0.0.0:57516           0.0.0.0:*                           108        11225      449/avahi-daemon: r
                      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       16850      1238/io.mihome-vacu
                      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       16223      1679/io.harmony.0
                      udp6       0      0 :::5353                 :::*                                108        11224      449/avahi-daemon: r
                      udp6       0      0 :::58916                :::*                                108        11226      449/avahi-daemon: r
                      2023-06-30 14:38:56.492  - info: sourceanalytix.0 (1723) Initialization of 0_userdata.0.Strom.WallboxGaN_Vortagesverbrauch_Gesamt successfully
                      2023-06-30 14:38:56.515  - info: sourceanalytix.0 (1723) Successfully activated SourceAnalytix for 8 of 8 states, will do my Job until you stop me!
                      2023-06-30 14:38:57.184  - info: meross.0 (1063) Can not get Data for Device 2204268862707951070248e1e9904eb1: Error: Device has no data connection available
                      2023-06-30 14:38:57.185  - warn: meross.0 (1063) Can not get Data for Device 2204268862707951070248e1e9904eb1: undefined
                      2023-06-30 14:39:00.105  - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 2062
                      2023-06-30 14:39:03.697  - info: powerfox2.0 (2062) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.16.1, js-controller: 4.0.24
                      2023-06-30 14:39:05.531  - info: alexa2.0 (1245) Unknown Device, but enabling commands, Try it and report back if commands work.
                      2023-06-30 14:39:05.533  - info: alexa2.0 (1245) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                      2023-06-30 14:39:05.533  - info: alexa2.0 (1245)     Device-type:A93SQJNJQLDSS - TV Schlafzimmer (CHANGE_NAME,SHARKNADO,MULTI_WAKEWORDS_SUPPORTED,SUPPORTS_LOCALE_SWITCH,SUPPORTS_LOCALE,ACTIVE_AFTER_FRO,SPEECH_RECOGNIZER_USS,VOLUME_SETTING,TIMERS_AND_ALARMS,PERSISTENT_CONNECTION,ARTHUR_TARGET,EQUALIZER_CONTROLLER_MIDRANGE,DIALOG_INTERFACE_VERSION,SOUND_SETTINGS,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,MICROPHONE,ADAPTIVE_LISTENING,SUPPORTS_SOFTWARE_VERSION,CUSTOM_ALARM_TONE,EARCONS,REMINDERS,FLASH_BRIEFING,AUDIO_CONTROLS)
                      2023-06-30 14:39:08.790  - info: powerfox2.0 (2062) Terminated (NO_ERROR): Without reason
                      2023-06-30 14:39:09.497  - info: host.smarthome instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                      2023-06-30 14:39:17.583  - info: alexa2.0 (1245) Unknown Device, but enabling commands, Try it and report back if commands work.
                      2023-06-30 14:39:17.584  - info: alexa2.0 (1245) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                      2023-06-30 14:39:17.585  - info: alexa2.0 (1245)     Device-type:A2N49KXGVA18AR - Philipps Fire (NO_TIME_ZONE_SETTING,ASX_TIME_ZONE,MICROPHONE,VOLUME_SETTING,ADAPTIVE_LISTENING,SUPPORTS_SOFTWARE_VERSION,TIMERS_AND_ALARMS,PERSISTENT_CONNECTION,REMINDERS)
                      2023-06-30 14:39:47.062  - info: alexa2.0 (1245) No smart home devices to query
                      2023-06-30 14:39:48.509  - info: alexa2.0 (1245) Subscribing to states...
                      2023-06-30 14:39:48.516  - info: alexa2.0 (1245) Deleting the following states: ["Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.#enabled","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.#delete","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.powerState","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.connectivity","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.connectivity-reason","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.#query","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.#enabled","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.#delete","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.powerState","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.connectivity","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.connectivity-reason","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.#query","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.#enabled","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.#delete","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.powerState","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.connectivity","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.connectivity-reason","Smart-Home-Devices.3e38aed4-a9fb-4880-9d19-79fd38b767c5.#query","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.#enabled","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.#delete","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.powerState","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.connectivity","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.connectivity-reason","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.#query","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.#enabled","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.#delete","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.powerState","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.connectivity","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.connectivity-reason","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.#query","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.#delete","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.powerState","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.brightness","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.colorName","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.color-hue","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.color-saturation","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.color-brightness","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.colorRgb","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.colorTemperatureName","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.colorTemperatureInKelvin","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.connectivity","Smart-Home-Devices.1e4da5c0-6a72-4da4-a3b4-31b2701acbf7.connectivity-reason","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.#enabled","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.#delete","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.powerState","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.connectivity","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.connectivity-reason","Smart-Home-Devices.37655abf-083c-4fd1-8e96-703a962c1a4c.#query","Smart-Home-Devices.674b986c-8600-46d2-b55a-79256dd7b23a.#includeInAllQuery","Smart-Home-Devices.76e08de5-544c-461e-b3b1-38206f1e9adb.#includeInAllQuery","Smart-Home-Devices.d09edd9e-20d7-4035-bffa-11105126fcd0.#includeInAllQuery","Smart-Home-Devices.ed7448e1-96f9-4f3b-837e-f9e7f37fccb1.#includeInAllQuery"]
                      2023-06-30 14:39:50.615  - info: alexa2.0 (1245) Alexa-Push-Connection (macDms = true) established. Disable Polling
                      2023-06-30 14:40:00.573  - info: host.smarthome instance system.adapter.powerfox2.0 started with pid 2419
                      2023-06-30 14:40:03.328  - info: meross.0 (1063) Can not get Data for Device 2204268862707951070248e1e9904eb1: Error: Device has no data connection available
                      2023-06-30 14:40:03.329  - warn: meross.0 (1063) Can not get Data for Device 2204268862707951070248e1e9904eb1: undefined
                      2023-06-30 14:40:04.250  - info: powerfox2.0 (2419) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.16.1, js-controller: 4.0.24
                      2023-06-30 14:40:06.674  - info: powerfox2.0 (2419) Terminated (NO_ERROR): Without reason
                      2023-06-30 14:40:07.276  - info: host.smarthome instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                      2023-06-30 14:40:08.594  - info: alexa2.0 (1245) Initialization Done ...
                      • M MP_Trixi
                        @Thomas-Braun
                        Skript v.2023-04-16
                        *** BASE SYSTEM ***
                        Docker          : false
                        Release:        11
                        Codename:       bullseye
                        VERSION_ID="11"
                        ID=debian
                        CPU threads: 4
                        Raspberry only:
                        throttled=0x0
                        temp=59.4'C
                        volt=0.9160V
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            99M        2.0M         97M
                                 3794 M total memory
                                 2458 M used memory
                                  617 M active memory
                                 1069 M free memory
                                   10 M buffer memory
                                  255 M swap cache
                                   99 M total swap
                                    2 M used swap
                                   97 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        3.9G    /var/
                        3.1G    /var/log
                        468M    /var/lib
                        /usr/bin/npm            9.5.1
                        /usr/bin/npx            9.5.1
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.3.5
                        javascript:     7.0.3
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        22941
                        States:         20154
                        Pending Updates: 0
                        @mp_trixi
                        Dann kannste ja jetzt die beiden Adapter noch hochziehen.
                          @mp_trixi
                          MP_Trixi
                          das hätte ich vorher schon gekonnt - das hat komischerweise mit der alten repo Einstellung auch funktioniert. Die anderen Updates bis auf die zwei hatte ich ja noch vor dem live dingens gemacht. Die zwei waren mit verschiedenen Adapter Versionen ein schönes gefrickel bis sie liefen. Deswegen traute ich mit da noch nicht ran. Ich zieh mir jetzt nochmal ein image und wage es dann.
