  4. [gelöst] sayit - mp3 erzeugen geht nicht mehr
errorsyntaxerror unexpectedsayit
78 Beiträge 6 Kommentatoren 8.2k Aufrufe 6 Beobachtet
    @bahnuhr
    Bitte PuTTY breiter schieben oder gleich ein besseres Terminal verwenden. Das Ding zerhackt die Ausgaben.
    bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    so besser ?
    dieter@iobroker:~$ mount | sort
    //192.168.243.100/1_Sound on /mnt type cifs (rw,relatime,vers=3.1.1,cache=strict,username=dieter,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.243.100,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1,user=dieter)
    cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
    configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
    debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
    devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
    /dev/sda1 on / type ext4 (rw,relatime,errors=remount-ro)
    /etc/auto.nfs on /home/nfs type autofs (rw,relatime,fd=6,pgrp=465,timeout=300,minproto=5,maxproto=5,indirect,pipe_ino=12034)
    fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
    hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
    mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
    none on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
    proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
    pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
    securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
    sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
    sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
    systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=13369)
    tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
    tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
    tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=607128k,mode=755)
    tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=607124k,nr_inodes=151781,mode=700,uid=1000,gid=1000)
    tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
    udev on /dev type devtmpfs (rw,nosuid,relatime,size=3017776k,nr_inodes=754444,mode=755)
    dieter@iobroker:~$
    Danke.
    • DJMarc75D DJMarc75
      @bahnuhr sagte in sayit - mp3 erzeugen geht nicht mehr:
      wo genau ?
      /opt/iobroker/mp3
      bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      @djmarc75 sagte in sayit - mp3 erzeugen geht nicht mehr:
      wo genau ?
      /opt/iobroker/mp3
      ne, den Ordner hab ich nicht !
      Danke.
      • bahnuhrB bahnuhr
        wo genau ?
        /opt/iobroker/mp3
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        na klar haste den nicht.... musst anlegen ;)
        Lehrling seit 1975 !!!
          wo genau ?
          /opt/iobroker/mp3
          bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          @djmarc75
          Na und was soll das dann ?
          Und wie kommt die mp3, wenn mit
          setState('sayit.2.tts.text', "1 2 3 4");
          erzeugt dann in dieses Verzeichnis.
          Ich versteh jetzt deine Logik nicht so ganz.
          Danke.
          • bahnuhrB bahnuhr
            so besser ?
            dieter@iobroker:~$
            @bahnuhr
            Man mounted nicht direkt auf /mnt sondern legt sich dort entsprechend mountpunkte an.
            Dann würde ich da auch nicht mit uid=0 /gid=0 mounten, das ist nämlich der root und den verwenden wir nicht, der soll ja auch keine Sounds hören sondern sich schön im Hintergrund halten.
              @bahnuhr
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              @thomas-braun sagte in sayit - mp3 erzeugen geht nicht mehr:
              @bahnuhr
              Ok, dann hab ich da was falsch gemacht.
              Aber, es hat jetzt jahreslang funktioniert.
              Und seit update auf V3 von sayit halt nicht mehr.
              Bin jetzt wieder zurück auf V1.13. und da klappt es wieder.
              Das Problem dürfte doch dann nicht an dem /mnt liegen, oder ?
              Danke.
              • bahnuhrB bahnuhr
                @bahnuhr
                Falsche Vorgehen funktionieren solange, bis es irgendwem auffällt, das User es falsch machen und den 'illegalen Weg' zumauern.
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  Danke für die Antwort, das hab ich jetzt gebraucht.
                  Hilfreich war dies jetzt nicht.
                  Gut, ich hab alles falsch gemacht.
                  Und es liegt auf keinen Fall am Adapter.
                  Fazit:
                  Illegaler Weg ist gestoppt.
                  Frust.
                  Schönen Sonntag noch.
                  Danke.
                  • bahnuhrB bahnuhr
                    Fazit:
                    Frust.
                    @bahnuhr
                    Ich hab dir doch oben was zu den mount Optionen gesagt. Umsetzen musst du das in deinem System schon selber.
                    Wobei es nicht (nur) daran liegt, aber ggfs halt auch.
                    • bahnuhrB bahnuhr
                      Fazit:
                      Frust.
                      @bahnuhr
                      Wir schaut es denn aus, wenn die ganze CIFS/SMB-Geschichte erstmal außen vor ist und du schaust was mit einer rein lokal angelegten Datei passiert?
                        @bahnuhr
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        wo gespeichert ?
                        Danke.
                        • bahnuhrB bahnuhr
                          wo gespeichert ?
                          @bahnuhr
                          Irgendwo wo es bestimmt keine Probleme gebe sollte.
                          /home/iobroker z.B.
                            @bahnuhr
                            /home/iobroker z.B.
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            Ich glaube du verstehsst mich nicht.
                            Oder umgedreht.
                            Die Datei wird mit V1.13 korrekt gespeichert, wenn:
                            setTimeout(function(){ request('http://192.168.243.15:8082/state/sayit.2.tts.mp3', {encoding:'binary'}, function(error, response, body) {
                                fs.writeFile("/mnt/2_sayit.mp3", body, 'binary', function (err) { if(err) log('Fehler!'); }); });
                            }, 2000);
                            Ich kann da gerne auch ein anderes Verzeichnis probieren.
                            Nur dies klappt halt mit V 3.0.5 nicht mehr.
                            Danke.
                            • bahnuhrB bahnuhr
                              Oder umgedreht.
                              }, 2000);
                              @bahnuhr
                              Doch, ich verstehe das schon.
                              • bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                So, ganz neu.
                                sayit, Adapter gelöscht.
                                und neu installiert, jetzt 3.0.5
                                Beim erstellen einer Instanz.2 kommt folgende log Meldungen (schon da stimmt was nicht)
                                sayit.2
                                2023-06-25 13:39:21.943	error	amixer is not available, so you may hear no audio. Install manually!
                                sayit.2
                                2023-06-25 13:39:21.936	error	sayIt.play: there was an error while playing the file: Error: spawn amixer ENOENT
                                sayit.2
                                2023-06-25 13:39:21.497	info	Upload announce mp3 files
                                sayit.2
                                2023-06-25 13:39:21.440	info	starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.sayit, node: v18.16.1, js-controller: 4.0.24
                                Und später kommt noch sowas:
                                sayit.2
                                2023-06-25 13:40:30.978	error	Error: dns service error: unknown
                                Instanz.2 mit folgenden Einstellungen:
                                und
                                Instanz wird dann grün.
                                Script laufen gelassen:
                                var request = require('request'),   fs = require('fs');
                                setState('sayit.2.tts.text', "alles 1 2");
                                    fs.writeFile("/home/iobroker/2_sayit.mp3", body, 'binary', function (err) { if(err) log('Fehler!'); }); });
                                }, 2000);
                                (auf Verz. /home/iobroker/...
                                Datei wird erzeugt, aber nur 1 kb
                                Und wenn ich diese dann per wscp kopieren auf win Rechner dann kommt im wmp
                                Danke.
                                • bahnuhrB bahnuhr
                                  So, ganz neu.
                                  sayit.2
                                  sayit.2
                                  sayit.2
                                  sayit.2
                                  sayit.2
                                  und
                                  }, 2000);
                                  @bahnuhr
                                  Da scheint schonmal der amixer zu fehlen.
                                  alsa-utils sind auf dem System vorhanden?
                                  • bahnuhrB bahnuhr
                                    So, ganz neu.
                                    sayit.2
                                    sayit.2
                                    sayit.2
                                    sayit.2
                                    sayit.2
                                    und
                                    }, 2000);
                                    @bahnuhr das angegeben Format kann IMHO bei 1kB auch nicht drin sein
                                    bahnuhrB Jey CeeJ 2 Antworten Letzte Antwort
                                      @bahnuhr
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      alsa-utils
                                      Ich vermute nicht.
                                      Stand bisher nirgends das man das braucht.
                                      Vielleicht sollte man dem Entwickler von sayit sagen, dass das mit installiert werden sollte.
                                      (oder ich bin der Einzige bei dem dies fehlt!)
                                      wenn notwendig, wie installieren:
                                      npm install alsa-utils
                                      richtig ?
                                      Danke.
                                        bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        @homoran sagte in sayit - mp3 erzeugen geht nicht mehr:
                                        Vorher ging es aber.
                                        welche Version hast du?
                                        Klappt es bei dir ?
                                        Danke.
                                          Jey CeeJ Online
                                          Jey CeeJ Online
                                          Jey Cee
                                          Japp und genau das die mp3 nicht funktioniert hat er schon am Anfang gesagt. Jetzt hat er nur nochmal den beweis angetreten das es an der Datei liegt umd nicht wie er an die Datei kommt.
                                          Ich hab jetzt kein Debug log gesehen. Daraus könnte man vielleicht mehr informationen ziehen.
                                          Persönlicher Support
                                          Spenden -> paypal.me/J3YC33
