  4. Vis keine Verbindung - GELÖST
    3.1k
vis
36 Beiträge 5 Kommentatoren 3.1k Aufrufe 5 Beobachtet
  • wendy2702W wendy2702
    @nwh Ausgabe von
    iob diag
    Vollständig posten
    NWHN Offline
    NWHN Offline
    NWH
    schrieb am zuletzt editiert von NWH
    @wendy2702
    Besser bekomme ich die Daten nicht aus dem Terminal des dockers 🙄
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : v8.0.1
    Virtualization  : Unknown (buanet/Synology?)
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     12:59:58 up 44 min,  0 users,  load average: 0.37, 0.44, 0.49
    CPU threads: 4
    *** Time and Time Zones ***
    Tue Jun  6 10:59:58 UTC 2023
    Tue Jun  6 12:59:58 CEST 2023
    CEST +0200
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             19G        2.9G         13G        117M        3.7G         16G
    Swap:            14G          0B         14G
    Total:           34G        2.9G         27G
            19974 M total memory
             2920 M used memory
             3600 M active memory
             2024 M inactive memory
            13307 M free memory
               40 M buffer memory
             3706 M swap cache
            14035 M total swap
                0 M used swap
            14035 M free swap
    *** FILESYSTEM ***
    Filesystem             Type   Size  Used Avail Use% Mounted on
    /dev/mapper/cachedev_1 btrfs  855G   28G  827G   4% /
    tmpfs                  tmpfs   64M     0   64M   0% /dev
    tmpfs                  tmpfs  9.8G     0  9.8G   0% /sys/fs/cgroup
    shm                    tmpfs   64M     0   64M   0% /dev/shm
    /dev/mapper/cachedev_1 btrfs  855G   28G  827G   4% /opt/iobroker
    /dev/mapper/cachedev_1 btrfs  855G   28G  827G   4% /etc/hosts
    tmpfs                  tmpfs  9.8G     0  9.8G   0% /proc/acpi
    tmpfs                  tmpfs  9.8G     0  9.8G   0% /proc/scsi
    tmpfs                  tmpfs  9.8G     0  9.8G   0% /sys/firmware
    sudo: unable to resolve host iobroker: Name or service not known
    [Tue Jun  6 12:15:51 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
    [Tue Jun  6 12:15:51 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Tue Jun  6 12:15:53 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
    [Tue Jun  6 12:15:53 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Tue Jun  6 12:15:58 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
    [Tue Jun  6 12:15:58 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Tue Jun  6 12:15:58 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
    [Tue Jun  6 12:16:21 2023] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
    TARGET             SOURCE
    PE OPTIONS
    /                  /dev/mapper/cachedev_1[/@syno/@docker/btrfs/subvolumes/37a9e20c38e52b7dd312ff3a9a1a7f3159097adee27dfbe331f67c8eb3bd365a]
    s  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=1015,subvol=/@syno/@docker/btrfs/sub
    |-/opt/iobroker    /dev/mapper/cachedev_1[/@syno/docker/Iobtoker2/iobroker_data]
    s  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=263,subvol=/@syno/docker/Iobtoker2/i
    er_data
    |-/etc/resolv.conf /dev/mapper/cachedev_1[/@syno/@docker/containers/8a1df9a145f9137c72ddb4cf55be6ef3f17f301831be92c12724da12e3e00bcb/resolv.conf]
    s  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers
    |-/etc/hostname    /dev/mapper/cachedev_1[/@syno/@docker/containers/8a1df9a145f9137c72ddb4cf55be6ef3f17f301831be92c12724da12e3e00bcb/hostname]
    `-/etc/hosts       /dev/mapper/cachedev_1[/@syno/@docker/containers/8a1df9a145f9137c72ddb4cf55be6ef3f17f301831be92c12724da12e3e00bcb/hosts]
    /var:
    33M     /var/
    30M     /var/lib
    18M     /var/lib/apt/lists
    18M     /var/lib/apt
    13M     /var/lib/dpkg
    /opt/iobroker/backups:
    159M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    944M    /opt/iobroker/iobroker-data/
    429M    /opt/iobroker/iobroker-data/history
    296M    /opt/iobroker/iobroker-data/files
    155M    /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    26M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    15M     /opt/iobroker/iobroker-data/objects.json.migrated
    15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   7
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.
    n as: admin
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bluesound.0              : bluesound             : iobroker                                 -  enabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 - disabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
      system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : iobroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
    + system.adapter.heos.0                   : heos                  : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 42010
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
    + system.adapter.hoover.0                 : hoover                : iobroker                                 -  enabled
    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      system.adapter.iot.0                    : iot                   : iobroker                                 - disabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.
      system.adapter.mqtt.2                   : mqtt                  : iobroker                                 - disabled, port: 1885, bind: 0.0.0.
      system.adapter.node-red.0               : node-red              : iobroker                                 - disabled, port: 1880, bind: 192.16
    .100
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    admin:          6.3.5
    javascript:     6.1.4
    Adapter State
    n as: admin
    .100
      system.adapter.rtspStream.0             : rtspStream            : iobroker                                 - disabled, port: 8084
      system.adapter.seko.0                   : seko                  : iobroker                                 - disabled
      system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.16
    .100, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.
      system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
      system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.
    n as: admin
      system.adapter.web.1                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.
    n as: admin
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    n as: admin
    n as: admin
    .100, run as: admin
    n as: admin
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "denon"        : 1.15.0   , installed 1.15.0
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fuelpricemonitor": 0.3.4 , installed 0.3.4
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "heos"         : 1.10.0   , installed 1.12.1
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "hoover"       : 0.0.7    , installed 0.0.7
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "node-red"     : 4.0.0    , installed 4.0.0
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "pvforecast"   : 2.7.1    , installed 2.3.0  [Updatable]
    Adapter    "seko"         : 0.0.1    , installed 0.0.1
    Adapter    "shelly"       : 6.3.1    , installed 6.4.1
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "tuya"         : 3.13.1   , installed 3.13.1
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        18684
    States:         16517
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          173358     -
    tcp        0      0 127.0.0.1:2380          0.0.0.0:*               LISTEN      0          100164     -
    tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          170604     -
    tcp        0      0 0.0.0.0:4045            0.0.0.0:*               LISTEN      0          53381      -
    tcp        0      0 0.0.0.0:662             0.0.0.0:*               LISTEN      0          38450      -
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          34495      -
    tcp        0      0 192.168.100.100:8087    0.0.0.0:*               LISTEN      1000       197708     1090/io.simple-api.
    tcp        0      0 0.0.0.0:7000            0.0.0.0:*               LISTEN      0          93311      -
    tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      55         74019      -
    tcp        0      0 0.0.0.0:42010           0.0.0.0:*               LISTEN      1000       176849     313/io.hm-rpc.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       187409     444/io.mqtt.1
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          48983      -
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       188561     486/io.sonoff.0
    tcp        0      0 127.0.0.1:30300         0.0.0.0:*               LISTEN      0          130064     -
    tcp        0      0 192.168.100.100:3260    0.0.0.0:*               LISTEN      0          58383      -
    tcp        0      0 127.0.0.1:4700          0.0.0.0:*               LISTEN      0          51010      -
    tcp        0      0 0.0.0.0:892             0.0.0.0:*               LISTEN      0          39430      -
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          173357     -
    tcp        0      0 127.0.0.1:16509         0.0.0.0:*               LISTEN      0          120621     -
    tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN      0          109073     -
    tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          53358      -
    tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN      0          47473      -
    tcp        0      0 0.0.0.0:6690            0.0.0.0:*               LISTEN      0          139749     -
    tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN      0          37663      -
    tcp        0      0 0.0.0.0:8999            0.0.0.0:*               LISTEN      0          74685      -
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       173563     150/iobroker.js-con
    tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          48977      -
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       170639     150/iobroker.js
    udp        0      0 127.0.0.1:1-con
    tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          48979      -
    tcp        0      0 192.168.100.100:12010   0.0.0.0:*               LISTEN      1000       181431     328/io.hm-rpc.1
    tcp6       0      0 :::139                  :::*                    LISTEN      0          173356     -
    tcp6       0      0 :::5357                 :::*                    LISTEN      0          170605     -
    tcp6       0      0 :::4045                 :::*                    LISTEN      0          53383      -
    tcp6       0      0 :::111                  :::*                    LISTEN      0          23278      -
    tcp6       0      0 :::80                   :::*                    LISTEN      0          48982      -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       174990     191/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       561182     3103/io.web.0
    tcp6       0      0 :::662                  :::*                    LISTEN      0          38454      -
    tcp6       0      0 :::22                   :::*                    LISTEN      0          34499      -
    tcp6       0      0 :::3000                 :::*                    LISTEN      472        114997     -
    tcp6       0      0 :::7000                 :::*                    LISTEN      0          93312      -
    tcp6       0      0 :::443                  :::*                    LISTEN      0          48984      -
    tcp6       0      0 fe80::21b:21ff:fec:3260 :::*                    LISTEN      0          58384      -
    tcp6       0      0 :::892                  :::*                    LISTEN      0          39434      -
    tcp6       0      0 :::445                  :::*                    LISTEN      0          173355     -
    tcp6       0      0 :::3261                 :::*                    LISTEN      0          57539      -
    tcp6       0      0 :::5566                 :::*                    LISTEN      0          77053      -
    tcp6       0      0 :::3263                 :::*                    LISTEN      0          57538      -
    tcp6       0      0 :::3264                 :::*                    LISTEN      0          57540      -
    tcp6       0      0 :::3265                 :::*                    LISTEN      0          59606      -
    tcp6       0      0 :::2049                 :::*                    LISTEN      0          53369      -
    tcp6       0      0 :::6690                 :::*                    LISTEN      0          139750     -
    tcp6       0      0 :::548                  :::*                    LISTEN      0          52468      -
    tcp6       0      0 :::5000                 :::*                    LISTEN      0          48978      -
    tcp6       0      0 :::5001                 :::*                    LISTEN      0          48980      -
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          35228      -
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          33953      -
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          31483      -
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          23272      -
    udp        0      0 172.17.0.1:123          0.0.0.0:*                           87         124178     -
    udp        0      0 192.168.100.100:123     0.0.0.0:*                           0          34324      -                  23           0.0.0.0:*
                        0          34322      -
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          34318      -
    udp        0      0 192.168.100.255:137     0.0.0.0:*                           0          171403     -
    udp        0      0 192.168.100.100:137     0.0.0.0:*                           0          171402     -
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          171349     -
    udp        0      0 192.168.100.255:138     0.0.0.0:*                           0          171405     -
    udp        0      0 192.168.100.100:138     0.0.0.0:*                           0          171404     -
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          171350     -
    udp        0      0 127.0.0.1:161           0.0.0.0:*                           0          47472      -
    udp        0      0 0.0.0.0:514             0.0.0.0:*                           0          95302      -
    udp        0      0 0.0.0.0:662             0.0.0.0:*                           0          38448      -
    udp        0      0 127.0.0.1:815           0.0.0.0:*                           0          38444      -
    udp        0      0 0.0.0.0:892             0.0.0.0:*                           0          39425      -
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          139678     -
    udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          53368      -
    udp        0      0 0.0.0.0:3702            0.0.0.0:*                           99         170497     -
    udp        0      0 0.0.0.0:4045            0.0.0.0:*                           0          53380      -
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       183594     370/io.mihome-vacuu
    udp        0      0 0.0.0.0:54145           0.0.0.0:*                           0          23274      -
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          124960     -
    udp        0      0 0.0.0.0:39761           0.0.0.0:*                           1000       193922     590/io.heos.0
    udp        0      0 0.0.0.0:40699           0.0.0.0:*                           1000       193921     590/io.heos.0
    udp        0      0 0.0.0.0:42402           0.0.0.0:*                           0          124962     -
    udp        0      0 0.0.0.0:9997            0.0.0.0:*                           0          35539      -
    udp        0      0 0.0.0.0:9998            0.0.0.0:*                           0          35538      -
    udp        0      0 0.0.0.0:9999            0.0.0.0:*                           0          35537      -
    udp        0      0 0.0.0.0:44403           0.0.0.0:*                           0          175316     -
    udp6       0      0 :::47569                :::*                                0          124963     -
    udp6       0      0 :::65461                :::*                                0          23277      -
    udp6       0      0 :::111                  :::*                                0          23276      -
    udp6       0      0 fe80::400c:46ff:fe1:123 :::*                                87         124184     -
    udp6       0      0 fe80::42:caff:fe04::123 :::*                                87         124182     -
    udp6       0      0 fe80::21b:21ff:fec1:123 :::*                                87         41561      -
    udp6       0      0 ::1:123                 :::*                                0          34326      -
    udp6       0      0 :::123                  :::*                                0          34315      -
    udp6       0      0 :::662                  :::*                                0          38452      -
    udp6       0      0 :::892                  :::*                                0          39432      -
    udp6       0      0 :::2049                 :::*                                0          53370      -
    udp6       0      0 :::3702                 :::*                                99         170499     -
    udp6       0      0 :::4045                 :::*                                0          53382      -
    udp6       0      0 :::5353                 :::*                                0          124961     -
    4mdebug: mihome-vac2023-06-06 13:00:43.335  - info: bluesound.0 (1272) state bluesound.0.info.image changed:  (ack = true)
    Copy text starting here:
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Kernel:                 4.4.180+
    Installation:           Docker
    Timezone:               Etc/UTC
    User-ID:                0
    X-Server:               false
    Pending OS-Updates:     3
    Pending iob updates:    1
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:             19G        2.9G         13G        117M        3.9G         16G
    Swap:            14G          0B         14G
    Total:           34G        2.9G         27G
    Active iob-Instances:   31
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                18684
    States:                 16517
    Size of iob-Database:
    18M     /opt/iobroker/iobroker-data/objects.jsonl
    4.9M    /opt/iobroker/iobroker-data/states.jsonl
    2.7M    /opt/iobroker/iobroker-data/states.json.migrated
    2.7M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    root@iobroker:/opt/iobroker#
    • NWHN NWH
      @wendy2702
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : v8.0.1
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      CEST +0200
      Etc/UTC
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:            14G          0B         14G
      Total:           34G        2.9G         27G
               2920 M used memory
              13307 M free memory
                 40 M buffer memory
               3706 M swap cache
              14035 M total swap
                  0 M used swap
              14035 M free swap
      *** FILESYSTEM ***
      TARGET             SOURCE
      PE OPTIONS
      er_data
      /var:
      33M     /var/
      30M     /var/lib
      18M     /var/lib/apt
      13M     /var/lib/dpkg
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      n as: admin
      .100
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      n as: admin
      .100
      .100, run as: admin
      n as: admin
      n as: admin
      + instance is alive
      n as: admin
      n as: admin
      .100, run as: admin
      n as: admin
      Objects and States
      Objects:        18684
      States:         16517
      Pending Updates: 3
                          0          34322      -
                           v.2023-04-16
      Kernel:                 4.4.180+
      Timezone:               Etc/UTC
      User-ID:                0
      X-Server:               false
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
      MEMORY:
      Swap:            14G          0B         14G
      Total:           34G        2.9G         27G
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                18684
      States:                 16517
      GlasfaserG Offline
      GlasfaserG Offline
      @nwh sagte in Vis keine Verbindung:
      Sollte funktionieren .
      Mal mit einem anderen Browser versucht .. ( noch nie mit ioBroker genutzt )
      Eventuell mal den Browser im Inkognito öffnen .
      Was steht in der ioBroker Logausgabe , wenn die versuchst Vis - Runtime/Editor zu öffnen .
      EDIT:
      Bis vor einer halben Stunde funktionierte alles normal.
      Bridge oder Host ... kann ich leider nicht erkenne ,
      / im Bridge die Ports weitergeleitet !?
      NWHN 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        EDIT:
        NWHN Offline
        NWHN Offline
        NWH
        @glasfaser
        Also in einem anderen Browser habe ich es versucht, das gleiche Problem.
        Es steht " Connecting to Server" Loading Value und der Balken bleibt bei den ersten 15% stecken.
        Ja warum ich keinen Host sehe weiß ich selber nicht.
        Kann man das ändern?
        Bridge verwende ich nicht, Netzwerk der "gleiche Host"
        Debug vom Vis Adapter
        vis.0
        2023-06-06 14:31:58.320	info	Terminated (NO_ERROR): Without reason
        vis.0
        2023-06-06 14:31:57.460	info	vis license is OK.
        vis.0
        2023-06-06 14:31:57.089	info	starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.16.0, js-controller: 4.0.24
        sigi234S GlasfaserG 2 Antworten Letzte Antwort
        • NWHN NWH
          @glasfaser
          vis.0
          vis.0
          vis.0
          sigi234S Online
          sigi234S Online
          @nwh
          Was sagt F12?
          • sigi234S sigi234
            @nwh
            Was sagt F12?
            NWHN Offline
            NWHN Offline
            NWH
            @sigi234
            Da sehe ich ganz unten als Fehler, wenn du das meinst.
            widgets.min.js:1 vis-materialdesign: click audio file '/vis.0/materialdesign-widgets-click-sound.mp3' not exists!
            (anonymous) @ widgets.min.js:1
            visUtils.js:455 Uncaught TypeError: Cannot read properties of undefined (reading 'data')
               at getUsedObjectIDs (visUtils.js:455:97)
               at Object.getUsedObjectIDs (vis.js:519:22)
               at vis.js:2055:34
               at conn.js:585:25
            DevTools failed to load source map: Could not load content for chrome-extension://dafgdjggglmmknipkhngniifhplpcldb/browser-polyfill.min.js.map: System error: net::ERR_BLOCKED_BY_CLIENT
            widgets.min.js:1 [waitForWidgets] stop waiting for vis widgets after 500 retries
            • NWHN NWH
              @glasfaser
              vis.0
              vis.0
              vis.0
              GlasfaserG Offline
              GlasfaserG Offline
              das .... ist schonmal was anders als deine Info am Anfang
              Problem ist, dass plötzlich keine Verbindung zum Server aufgebaut werden kann.
              hast du hier den Haken gesetzt !?
                NWHN Offline
                NWHN Offline
                NWH
                @glasfaser
                ich interpretiere das so als er keine Verbindung zum Server aufbauen kann. Dann war das falsch.
                Haken, ja habe ich. Sieht alles gleich aus wie bei dir.
                • NWHN NWH
                  @glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @nwh
                  Ist die Meldung :
                  bei Runtime und bei Editor !?
                    @nwh
                    Ist die Meldung :
                    NWHN Offline
                    NWHN Offline
                    NWH
                    @glasfaser
                    Bei Runtime steht nur der Balken unten nicht, sonst ganz gleich wir bei Edit!
                    • NWHN NWH
                      @wendy2702
                      Skript v.2023-04-16
                      *** BASE SYSTEM ***
                      Docker          : v8.0.1
                      Release:        11
                      Codename:       bullseye
                      VERSION_ID="11"
                      ID=debian
                      CPU threads: 4
                      CEST +0200
                      Etc/UTC
                      root
                      /root
                      root
                      X-Server:       false
                      Desktop:
                      Terminal:
                      *** MEMORY ***
                      Swap:            14G          0B         14G
                      Total:           34G        2.9G         27G
                               2920 M used memory
                              13307 M free memory
                                 40 M buffer memory
                               3706 M swap cache
                              14035 M total swap
                                  0 M used swap
                              14035 M free swap
                      *** FILESYSTEM ***
                      TARGET             SOURCE
                      PE OPTIONS
                      er_data
                      /var:
                      33M     /var/
                      30M     /var/lib
                      18M     /var/lib/apt
                      13M     /var/lib/dpkg
                      /usr/bin/npm            9.5.1
                      /usr/bin/npx            9.5.1
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.3.5
                      javascript:     6.1.4
                      Adapter State
                      n as: admin
                      .100
                      admin:          6.3.5
                      javascript:     6.1.4
                      Adapter State
                      n as: admin
                      .100
                      .100, run as: admin
                      n as: admin
                      n as: admin
                      + instance is alive
                      n as: admin
                      n as: admin
                      .100, run as: admin
                      n as: admin
                      Objects and States
                      Objects:        18684
                      States:         16517
                      Pending Updates: 3
                                          0          34322      -
                                           v.2023-04-16
                      Kernel:                 4.4.180+
                      Timezone:               Etc/UTC
                      User-ID:                0
                      X-Server:               false
                                              /usr/bin/npm            9.5.1
                                              /usr/bin/npx            9.5.1
                                              /usr/bin/npm            9.5.1
                                              /usr/bin/npx            9.5.1
                      MEMORY:
                      Swap:            14G          0B         14G
                      Total:           34G        2.9G         27G
                                              admin                   6.3.5
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                18684
                      States:                 16517
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Installiere mal bitte diesen Adapter ... Instanz
                        NWHN Offline
                        NWHN Offline
                        NWH
                        @glasfaser
                        Erledigt.
                        und jetzt?
                        bei ip:8084 kommt "Not Implemented"
                        • NWHN NWH
                          @glasfaser
                          Erledigt.
                          und jetzt?
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @nwh
                          Vis und Web Adapter neu starten .
                          Hast du nur ein Projekt Main oder wie öffnest du den Runtime / Editor
                          NWHN GlasfaserG 2 Antworten Letzte Antwort
                            @nwh
                            NWHN Offline
                            NWHN Offline
                            NWH
                            @glasfaser sagte in Vis keine Verbindung:
                            erledigt.
                            Ich starte mit ....index.html
                            geht aber leider noch nicht.
                            • NWHN NWH
                              erledigt.
                              GlasfaserG Offline
                              GlasfaserG Offline
                              bitte das ganze davon was im Browser steht , bei Editor / Runtime
                                NWHN Offline
                                NWHN Offline
                                NWH
                                @glasfaser
                                edit: http://192.168.100.100:8082/vis/edit.html
                                Runtime: http://192.168.100.100:8082/vis/index.html
                                  @nwh
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @NWH
                                  Was war hiermit .. noch ein Projekt vorhanden !?
                                    @NWH
                                    NWHN Offline
                                    NWHN Offline
                                    NWH
                                    @glasfaser
                                    die punkte meinten die ip das davor.
                                    • NWHN NWH
                                      @glasfaser
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @nwh
                                      ich meine nicht die Punkte
                                      @NWH
                                      Ob du noch ein weiteres Projekt angelegt hast, außer das Main Projekt , das war die Frage .
                                        @nwh
                                        @NWH
                                        NWHN Offline
                                        NWHN Offline
                                        NWH
                                        @glasfaser
                                        Nein.
                                        und Main heißt es auch nicht.
                                        • NWHN NWH
                                          @glasfaser
                                          Nein.
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          main ist ein Standardprojekt und kann nicht nicht existieren :)
                                          Lehrling seit 1975 !!!
