    2. FuLLHDvs480p
    F
    • Posts 13
    FuLLHDvs480p
    @FuLLHDvs480p
    Location Saarland Age 31
    FuLLHDvs480p Follow
    Best posts made by FuLLHDvs480p
    • RE: "Adapter verfügbar" wird nicht mehr angezeigt
      habe derzeit genau das gleiche Problem. Kann die Adapterliste nicht aktualisieren und im Log steht folgendes:
      host.iobroker	2020-07-13 16:33:42.507	warn	warning: empty repo received!
      host.iobroker	2020-07-13 16:33:42.507	warn	warning: Cannot read "http://download.iobroker.net/sources-dist.json"
      Habe dann noch diese getestet:
      http://repo.iobroker.live/sources-dist.json
      leider das selbe Problem:
      host.iobroker	2020-07-13 16:46:25.949	warn	warning: empty repo received!
      host.iobroker	2020-07-13 16:46:25.948	warn	warning: Cannot read "http://repo.iobroker.live/sources-dist.json"
      host.iobroker	2020-07-13 16:46:15.380	info	Update repository "default" under "http://repo.iobroker.live/sources-dist.json"
      Mein Iobroker ist frisch installiert und läuft unter proxmox auf debain.
      Per SSH verbunden sind beide URLs erreichbar:
      timo@iobroker:~$ ping download.iobroker.net
      PING download.iobroker.net (79.143.182.215) 56(84) bytes of data.
      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=1 ttl=54 time=25.9 ms
      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=2 ttl=54 time=19.4 ms
      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=3 ttl=54 time=17.8 ms
      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=4 ttl=54 time=17.5 ms
      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=5 ttl=54 time=17.2 ms
      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=6 ttl=54 time=18.2 ms
      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=7 ttl=54 time=16.4 ms
      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=8 ttl=54 time=17.4 ms
      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=9 ttl=54 time=17.3 ms
      ^C
      --- download.iobroker.net ping statistics ---
      9 packets transmitted, 9 received, 0% packet loss, time 20ms
      rtt min/avg/max/mdev = 16.370/18.576/25.917/2.712 ms
      timo@iobroker:~$ ping repo.iobroker.live
      PING repo.iobroker.live.cdn.cloudflare.net (172.67.180.22) 56(84) bytes of data.
      64 bytes from 172.67.180.22 (172.67.180.22): icmp_seq=1 ttl=56 time=22.4 ms
      64 bytes from 172.67.180.22 (172.67.180.22): icmp_seq=2 ttl=56 time=23.6 ms
      64 bytes from 172.67.180.22 (172.67.180.22): icmp_seq=3 ttl=56 time=23.8 ms
      64 bytes from 172.67.180.22 (172.67.180.22): icmp_seq=4 ttl=56 time=21.9 ms
      64 bytes from 172.67.180.22 (172.67.180.22): icmp_seq=5 ttl=56 time=20.6 ms
      64 bytes from 172.67.180.22 (172.67.180.22): icmp_seq=6 ttl=56 time=22.6 ms
      64 bytes from 172.67.180.22 (172.67.180.22): icmp_seq=7 ttl=56 time=22.5 ms
      64 bytes from 172.67.180.22 (172.67.180.22): icmp_seq=8 ttl=56 time=20.8 ms
      64 bytes from 172.67.180.22 (172.67.180.22): icmp_seq=9 ttl=56 time=21.8 ms
      ^C
      --- repo.iobroker.live.cdn.cloudflare.net ping statistics ---
      9 packets transmitted, 9 received, 0% packet loss, time 22ms
      rtt min/avg/max/mdev = 20.639/22.225/23.844/1.053 ms
      timo@iobroker:~$
      JS-Controller: 3.1.6
      Admin: 4.0.10
      Node.js: v12.18.2
      NPM: 6.14.6
      Pi-Hole habe ich schon komplett deaktiviert und die DNS Weiterleitung aus der FritzBox rausgenommen.
      F
      FuLLHDvs480p
    Latest posts made by FuLLHDvs480p
      @crunchip sagte in "Adapter verfügbar" wird nicht mehr angezeigt:
      @Againstyou
      die ersten beiden sind ja die Standart die schon drin sind, einmal default (stable) und einmal latest. Bei denen kam es immer zum Fehler, siehe oben.
      Die letzte live hat bei mir funktioniert, ist jedoch auch latest.
      F
      FuLLHDvs480p
      ^C
      ^C
      timo@iobroker:~$
      Admin: 4.0.10
      Node.js: v12.18.2
      NPM: 6.14.6
      F
      FuLLHDvs480p
    • RE: [Adapter] Neuer radar2-Adapter
      habe folgendes Problem:
      Bei der Ausführung von
      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
      und
       sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp`)
      bekomme ich die Fehlermeldung:
      readlink: fehlender Operand
      „readlink --help“ liefert weitere Informationen.
      usage: setcap [-q] [-v] (-r|-|<caps>) <filename> [ ... (-r|-|<capsN>) <filenameN> ]
       Note <filename> must be a regular (non-symlink) file.
      Mein System ist frisch aufgesetzt und läuft in einer VM auf Proxmox.
      radar2 version: 1.0.3
      Hier die zusammenhängende Installation
      timo@ioBrokerEG:/opt/iobroker$ node -v
      v10.16.2
      timo@ioBrokerEG:/opt/iobroker$ nodejs -v
      v10.16.2
      timo@ioBrokerEG:/opt/iobroker$ npm -v
      6.10.3
      timo@ioBrokerEG:/opt/iobroker$ sudo apt-get install libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev net-tools
      arp-scan ist schon die neueste Version (1.9.5-1).
      bluetooth ist schon die neueste Version (5.50-1).
      bluez ist schon die neueste Version (5.50-1).
      libbluetooth-dev ist schon die neueste Version (5.50-1).
      libcap2-bin ist schon die neueste Version (1:2.25-2).
      net-tools ist schon die neueste Version (1.60+git20180626.aebd88e-1).
      libudev-dev ist schon die neueste Version (241-5).
      0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
      timo@ioBrokerEG:/opt/iobroker$ sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
      timo@ioBrokerEG:/opt/iobroker$ sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which node`)
      timo@ioBrokerEG:/opt/iobroker$ sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp`)
      timo@ioBrokerEG:/opt/iobroker$ sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hcitool`)
      timo@ioBrokerEG:/opt/iobroker$ sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hciconfig`)
      timo@ioBrokerEG:/opt/iobroker$ sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which l2ping`)
      posted in Entwicklung
      F
      FuLLHDvs480p
    • RE: [How-to] Node.js für ioBroker richtig updaten
      @Stabilostick
      cd /opt/iobroker
      iobroker stop
      sudo rm -r /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
      npm install @abandonware/bluetooth-hci-socket --force
      ergab folgendes:
      rock64@rock64:~$ cd /opt/iobroker
      rock64@rock64:/opt/iobroker$ iobroker stop
      rock64@rock64:/opt/iobroker$ sudo rm -r /opt/iobroker/node_modules/@abandonware/        bluetooth-hci-socket
      [sudo] password for rock64:
      rock64@rock64:/opt/iobroker$ npm install @abandonware/bluetooth-hci-socket --force
      npm WARN using --force I sure hope you know what you are doing.
      > @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall /opt/iobroker/node_modules/@abandonware/bluetoot        h-hci-socket
      > npm install node-pre-gyp
      npm notice created a lockfile as package-lock.json. You should commit this file.
      + node-pre-gyp@0.12.0
      added 63 packages from 24 contributors, updated 1 package and audited 97 packages in 12.486s
      found 0 vulnerabilities
      > bluetooth-hci-socket@0.5.1 install /opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_        modules/bluetooth-hci-socket
      > node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/blu        etooth-hci-socket/build'
        CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
      ../src/BluetoothHciSocket.cpp: In member function 'void BluetoothHciSocket::poll()':
      ../src/BluetoothHciSocket.cpp:251:95: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Ob        ject>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
           Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
      In file included from ../src/BluetoothHciSocket.cpp:8:0:
      ../../../../nan/nan.h:980:46: note: declared here
         NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
      ../src/BluetoothHciSocket.cpp: In member function 'void BluetoothHciSocket::emitErrnoError()':
      ../src/BluetoothHciSocket.cpp:275:72: error: no matching function for call to 'v8::Function::NewInstanc        e(int, v8::Local<v8::Value> [1])'
         Local<Value> error = errorConstructor->NewInstance(1, constructorArgs);
      In file included from /home/rock64/.node-gyp/10.16.0/include/node/node.h:63:0,
                       from /home/rock64/.node-gyp/10.16.0/include/node/node_buffer.h:25,
                       from ../src/BluetoothHciSocket.cpp:7:
      /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3993:44: note: candidate: v8::MaybeLocal<v8::Object> v        8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const
         V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
      /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3993:44: note:   candidate expects 3 arguments, 2 prov        ided
      /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3996:44: note: candidate: v8::MaybeLocal<v8::Object> v        8::Function::NewInstance(v8::Local<v8::Context>) const
      /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3996:44: note:   candidate expects 1 argument, 2 provi        ded
      ../src/BluetoothHciSocket.cpp:282:93: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Ob        ject>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
      ../src/BluetoothHciSocket.cpp: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BluetoothH        ciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)':
      ../src/BluetoothHciSocket.cpp:395:34: warning: 'int64_t v8::Value::IntegerValue() const' is deprecated:        Use maybe version [-Wdeprecated-declarations]
             devId = arg0->IntegerValue();
      In file included from /home/rock64/.node-gyp/10.16.0/include/node/v8.h:26:0,
                       from /home/rock64/.node-gyp/10.16.0/include/node/node.h:63,
      /home/rock64/.node-gyp/10.16.0/include/node/v8.h:2476:46: note: declared here
         V8_DEPRECATED("Use maybe version", int64_t IntegerValue() const);
      /home/rock64/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro 'V8_DEPRECAT        ED'
         declarator __attribute__((deprecated(message)))
      ../src/BluetoothHciSocket.cpp: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BluetoothH        ciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)':
      ../src/BluetoothHciSocket.cpp:417:34: warning: 'int64_t v8::Value::IntegerValue() const' is deprecated:        Use maybe version [-Wdeprecated-declarations]
      binding.target.mk:99: recipe for target 'Release/obj.target/binding/src/BluetoothHciSocket.o' failed
      make: *** [Release/obj.target/binding/src/BluetoothHciSocket.o] Error 1
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/blue        tooth-hci-socket/build'
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/bu        ild.js:262:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.4.132-1075-rockchip-ayufan-ga83beded8524
      gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js        " "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-so        cket
      gyp ERR! node -v v10.16.0
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      > osx-temperature-sensor@1.0.3 install /opt/iobroker/node_modules/osx-temperature-sensor
      > node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/osx-temperature-sensor/build'
        SOLINK_MODULE(target) Release/obj.target/none.node
        COPY Release/none.node
      make: Leaving directory '/opt/iobroker/node_modules/osx-temperature-sensor/build'
      > xpc-connection@0.1.4 install /opt/iobroker/node_modules/xpc-connection
      > node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/xpc-connection/build'
        SOLINK_MODULE(target) Release/obj.target/binding.node
        COPY Release/binding.node
      make: Leaving directory '/opt/iobroker/node_modules/xpc-connection/build'
      > @abandonware/bluetooth-hci-socket@0.5.3-1 install /opt/iobroker/node_modules/@abandonware/bluetooth-h        ci-socket
      > node-pre-gyp install --fallback-to-build
      node-pre-gyp WARN Using request for node-pre-gyp https download
      node-pre-gyp WARN Tried to download(404): https://github.com/sandeepmistry/node-bluetooth-hci-socket/re        leases/download/0.5.3-1/binding-0.5.3-1-node-v64-linux-arm64.tar.gz
      node-pre-gyp WARN Pre-built binaries not found for @abandonware/bluetooth-hci-socket@0.5.3-1 and node@1        0.16.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
      make: Entering directory '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build'
      ../src/BluetoothHciSocket.cpp:252:95: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Ob        ject>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
      ../../../nan/nan.h:1045:46: note: declared here
      ../src/BluetoothHciSocket.cpp:283:93: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Ob        ject>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
      ../src/BluetoothHciSocket.cpp:396:34: warning: 'int64_t v8::Value::IntegerValue() const' is deprecated:        Use maybe version [-Wdeprecated-declarations]
      ../src/BluetoothHciSocket.cpp:418:34: warning: 'int64_t v8::Value::IntegerValue() const' is deprecated:        Use maybe version [-Wdeprecated-declarations]
        COPY /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node
        TOUCH Release/obj.target/action_after_build.stamp
      make: Leaving directory '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build'
      npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/bluetooth-hci-soc        ket'
      npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-det        ector'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.radar/node        _modules/bluetooth-hci-socket/package.json'
      + @abandonware/bluetooth-hci-socket@0.5.3-1
      added 8 packages from 7 contributors and audited 19313 packages in 210.767s
      found 99 vulnerabilities (54 low, 5 moderate, 40 high)
        run `npm audit fix` to fix them, or `npm audit` for details
      darauf das npm rebuild ergab:
      rock64@rock64:/opt/iobroker$ ^C
      rock64@rock64:/opt/iobroker$ clear
      rock64@rock64:/opt/iobroker$ npm rebuild
      > @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
      updated 1 package and audited 97 packages in 8.593s
      > @abandonware/bluetooth-hci-socket@0.5.3-1 install /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
      [@abandonware/bluetooth-hci-socket] Success: "/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node" already installed
      Pass --update-binary to reinstall or --build-from-source to recompile
      > usb@1.6.0 install /opt/iobroker/node_modules/iobroker.ble/node_modules/usb
      > prebuild-install --verbose || node-gyp rebuild
      prebuild-install info begin Prebuild-install version 5.3.0
      prebuild-install info looking for cached prebuild @ /home/rock64/.npm/_prebuilds/c716aa-usb-v1.6.0-node-v64-linux-arm64.tar.gz
      prebuild-install http request GET https://github.com/tessel/node-usb/releases/download/v1.6.0/usb-v1.6.0-node-v64-linux-arm64.tar.gz
      prebuild-install http 404 https://github.com/tessel/node-usb/releases/download/v1.6.0/usb-v1.6.0-node-v64-linux-arm64.tar.gz
      prebuild-install WARN install No prebuilt binaries found (target=10.16.0 runtime=node arch=arm64 libc= platform=linux)
      make: Entering directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/usb/build'
        CC(target) Release/obj.target/libusb/libusb/libusb/core.o
        CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
        CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
        CC(target) Release/obj.target/libusb/libusb/libusb/io.o
        CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
        CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
        CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
        CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
        CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
        CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
        AR(target) Release/obj.target/usb.a
        COPY Release/usb.a
        CXX(target) Release/obj.target/usb_bindings/src/node_usb.o
      ../src/node_usb.cc: In function 'void handleHotplug(std::pair<libusb_device*, libusb_hotplug_event>)':
      ../src/node_usb.cc:151:58: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
        Nan::MakeCallback(Nan::New(hotplugThis), "emit", 2, argv);
      In file included from ../src/helpers.h:3:0,
                       from ../src/node_usb.h:21,
                       from ../src/node_usb.cc:1:
      ../node_modules/nan/nan.h:1001:46: note: declared here
        CXX(target) Release/obj.target/usb_bindings/src/device.o
      ../src/device.cc: In static member function 'static void Req::default_after(uv_work_t*)':
      ../src/device.cc:237:64: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declaratio                                                ns]
          Nan::MakeCallback(device, Nan::New(baton->callback), 1, argv);
                       from ../src/device.cc:1:
      ../node_modules/nan/nan.h:959:46: note: declared here
        CXX(target) Release/obj.target/usb_bindings/src/transfer.o
      ../src/transfer.cc: In function 'void handleCompletion(Transfer*)':
      ../src/transfer.cc:126:72: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarat                                                ions]
         Nan::MakeCallback(self->handle(), Nan::New(self->v8callback), 3, argv);
                       from ../src/transfer.cc:1:
        SOLINK_MODULE(target) Release/obj.target/usb_bindings.node
        COPY Release/usb_bindings.node
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/usb/build'
      > @abandonware/noble@1.9.2-2 install /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
      > node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build'
        SOLINK_MODULE(target) Release/obj.target/noble.node
        COPY Release/noble.node
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build'
        COPY Release/usb.a
      > @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket
      updated 1 package and audited 95 packages in 8.66s
      > @abandonware/bluetooth-hci-socket@0.5.3-1 install /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket
      [@abandonware/bluetooth-hci-socket] Success: "/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node" already installed
      > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings
      > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/build'
        CXX(target) Release/obj.target/bindings/src/serialport.o
        CXX(target) Release/obj.target/bindings/src/serialport_unix.o
        CXX(target) Release/obj.target/bindings/src/poller.o
        CXX(target) Release/obj.target/bindings/src/serialport_linux.o
        SOLINK_MODULE(target) Release/obj.target/bindings.node
        COPY Release/bindings.node
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/build'
      > grpc@1.20.3 install /opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc
      > node-pre-gyp install --fallback-to-build --library=static_library
      [grpc] Success: "/opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/node/extension_binary/node-v64-linux-arm64-glibc/grpc_node.node" already installed
      > protobufjs@6.8.8 postinstall /opt/iobroker/node_modules/iobroker.iogo/node_modules/@grpc/proto-loader/node_modules/protobufjs
      > node scripts/postinstall
      (node:19565) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 SIGINT listeners added. Use emitter.setMaxListeners() to increase limit
      > iobroker.javascript@4.1.14 postinstall /opt/iobroker/node_modules/iobroker.javascript
      > node ./install/installTypings.js
      Installing NodeJS typings...
      latest @types: 12, installed node: 10
      > iobroker.js-controller@1.5.14 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.4.1
      npm version >= 5: disabling package-lock
      > iobroker.js-controller@1.5.14 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      > unix-dgram@2.0.3 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/unix-dgram
      > node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/unix-dgram/build'
        CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
        SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
        COPY Release/unix_dgram.node
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/unix-dgram/build'
      > websocket@1.0.28 install /opt/iobroker/node_modules/iobroker.lgtv/node_modules/websocket
      > (node-gyp rebuild 2> builderror.log) || (exit 0)
      make: Entering directory '/opt/iobroker/node_modules/iobroker.lgtv/node_modules/websocket/build'
        CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
        SOLINK_MODULE(target) Release/obj.target/bufferutil.node
        COPY Release/bufferutil.node
        CXX(target) Release/obj.target/validation/src/validation.o
        SOLINK_MODULE(target) Release/obj.target/validation.node
        COPY Release/validation.node
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.lgtv/node_modules/websocket/build'
      > ws@0.7.0 install /opt/iobroker/node_modules/iobroker.owntracks/node_modules/ws
      make: Entering directory '/opt/iobroker/node_modules/iobroker.owntracks/node_modules/ws/build'
      bufferutil.target.mk:101: recipe for target 'Release/obj.target/bufferutil/src/bufferutil.o' failed
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.owntracks/node_modules/ws/build'
      > ws@0.6.5 install /opt/iobroker/node_modules/iobroker.owntracks/node_modules/websocket-stream/node_modules/ws
      make: Entering directory '/opt/iobroker/node_modules/iobroker.owntracks/node_modules/websocket-stream/node_modules/ws/build'
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.owntracks/node_modules/websocket-stream/node_modules/ws/build'
      > usb@1.5.0 install /opt/iobroker/node_modules/iobroker.radar/node_modules/usb
      [usb] Success: "/opt/iobroker/node_modules/iobroker.radar/node_modules/usb/src/binding/usb_bindings.node" already installed
      > bluetooth-hci-socket@0.5.1 install /opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket
      > node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket/build'
      ../src/BluetoothHciSocket.cpp:251:95: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated                                                -declarations]
      ../src/BluetoothHciSocket.cpp:275:72: error: no matching function for call to 'v8::Function::NewInstance(int, v8::Local<v8::Value> [1])'
      /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3993:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const
      /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3993:44: note:   candidate expects 3 arguments, 2 provided
      /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3996:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const
      /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3996:44: note:   candidate expects 1 argument, 2 provided
      ../src/BluetoothHciSocket.cpp:282:93: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated                                                -declarations]
      ../src/BluetoothHciSocket.cpp: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)':
      /home/rock64/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro 'V8_DEPRECATED'
      ../src/BluetoothHciSocket.cpp: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)':
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket/build'
      gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket
      gyp ERR! not ok
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! bluetooth-hci-socket@0.5.1 install: `node-gyp rebuild`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the bluetooth-hci-socket@0.5.1 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/rock64/.npm/_logs/2019-07-27T16_07_21_234Z-debug.log
      Hab gerade Versucht ble auf die neue Version zu bringen, bekomme dann die Fehler:
      $ ./iobroker upgrade ble
      Update ble from @0.7.4 to @0.8.1
      NPM version: 6.4.1
      npm install iobroker.ble@0.8.1 --production --save --prefix "/opt/iobroker" (System call)
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gypnpm
      WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware
      npm
       WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/bluetooth-hci-socket'npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.radar/node_modules/bluetooth-hci-socket/package.json'
      npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gypnpm ERR! code EACCES
      npm ERR! errno -13
      npm ERR! syscall access
      npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp'npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp']
      npm ERR!
         stack:npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp\'',
      npm
       ERR!   errno: -13,npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!   path:
      npm
      ERR!    '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp' }npm ERR!
      npm ERR!
       The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm
       ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator (though this is not recommended).
      npm ERR!     /home/iobroker/.npm/_logs/2019-07-27T17_03_18_601Z-debug.log
      ERROR: host.rock64 Cannot install iobroker.ble@0.8.1: 243
      ERROR: process exited with code 25
      F
      FuLLHDvs480p
      @AlCalzone Okay.
      Der npm rebuild läuft trotzdem nicht durch:
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp
      npm ERR! path /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp'
      npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp']
      npm ERR!   stack:
      npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp\'',
      npm ERR!   errno: -13,
      npm ERR!   path:
      npm ERR!    '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp' }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR!     /home/rock64/.npm/_logs/2019-07-26T14_46_23_187Z-debug.log
      npm ERR! errno 243
      npm ERR! @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall: `npm install node-pre-gyp`
      npm ERR! Exit status 243
      npm ERR!
      npm ERR! Failed at the @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall script.
      npm ERR!     /home/rock64/.npm/_logs/2019-07-26T14_46_23_397Z-debug.log
      Kann ich hingehen und den ganzen Ordner von dem bluetooth-hci-socket löschen?
      F
      FuLLHDvs480p
      @AlCalzone Wenn ich mich über Putty als iobroker anmelde schließt sich das Fenster direkt wieder.
      Wenn ich mich als root anmelde und danach auf den Benutzer iobroker wechseln will kommt:
      root@rock64:~# su iobroker
      This account is currently not available.
      Hab die Installation mal als rock64 laufen lassen und bekomme diese Fehler:
      rock64@rock64:~$ cd /opt/iobroker/
      rock64@rock64:/opt/iobroker$ sudo -H -u iobroker npm install @abandonware/bluetooth-hci-socket
      added 63 packages from 24 contributors, updated 1 package and audited 97 packages in 13.598s
      node-pre-gyp WARN Tried to download(404): https://github.com/sandeepmistry/node-bluetooth-hci-socket/releases/download/0.5.3-1/binding-0.5.3-1-node-v64-linux-arm64.tar.gz
      node-pre-gyp WARN Pre-built binaries not found for @abandonware/bluetooth-hci-socket@0.5.3-1 and node@10.16.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
      ../src/BluetoothHciSocket.cpp:252:95: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
      ../src/BluetoothHciSocket.cpp:283:93: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
      In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                       from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                       from /home/iobroker/.node-gyp/10.16.0/include/node/node_buffer.h:25,
      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2476:46: note: declared here
      /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro 'V8_DEPRECATED'
      > node-gyp rebuild
      ../src/BluetoothHciSocket.cpp:251:95: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
      In file included from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63:0,
      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3993:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const
      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3993:44: note:   candidate expects 3 arguments, 2 provided
      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3996:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const
      /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3996:44: note:   candidate expects 1 argument, 2 provided
      ../src/BluetoothHciSocket.cpp:282:93: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
      gyp ERR! not ok
      npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/bluetooth-hci-socket'
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 (node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 install: `node-gyp rebuild`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      removed 63 packages, updated 1 package and audited 19313 packages in 242.798s
      F
      FuLLHDvs480p
      rock64@rock64:/opt/iobroker$ curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
      ## Installing the NodeSource Node.js 10.x repo...
      ## Populating apt-get cache...
      + apt-get update
      Hit:1 http://security.debian.org stretch/updates InRelease
      Hit:2 http://ppa.launchpad.net/ayufan/rock64-ppa/ubuntu xenial InRelease
      Get:3 http://deb.ayufan.eu/orgs/ayufan-rock64/releases  InRelease [1339 B]
      Ign:4 http://cdn-fastly.deb.debian.org/debian stretch InRelease
      Get:5 http://cdn-fastly.deb.debian.org/debian stretch-updates InRelease [91.0 kB]
      Hit:6 https://deb.nodesource.com/node_10.x stretch InRelease
      Hit:7 http://cdn-fastly.deb.debian.org/debian stretch Release
      Fetched 92.4 kB in 2s (39.7 kB/s)
      Reading package lists... Done
      ## Confirming "stretch" is supported...
      + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_10.x/dists/stretch/Release'
      ## Adding the NodeSource signing key to your keyring...
      + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
      OK
      ## Creating apt sources list file for the NodeSource Node.js 10.x repo...
      + echo 'deb https://deb.nodesource.com/node_10.x stretch main' > /etc/apt/sources.list.d/nodesource.list
      + echo 'deb-src https://deb.nodesource.com/node_10.x stretch main' >> /etc/apt/sources.list.d/nodesource.list
      ## Running `apt-get update` for you...
      + apt-get update
      Ign:3 http://cdn-fastly.deb.debian.org/debian stretch InRelease
      Hit:4 http://cdn-fastly.deb.debian.org/debian stretch-updates InRelease
      Get:5 http://deb.ayufan.eu/orgs/ayufan-rock64/releases  InRelease [1339 B]
      Hit:6 http://cdn-fastly.deb.debian.org/debian stretch Release
      Hit:7 https://deb.nodesource.com/node_10.x stretch InRelease
      Fetched 1339 B in 2s (583 B/s)
      ## Run `sudo apt-get install -y nodejs` to install Node.js 10.x and npm
      ## You may also need development tools to build native addons:
           sudo apt-get install gcc g++ make
      ## To install the Yarn package manager, run:
           curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
           echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
           sudo apt-get update && sudo apt-get install yarn
      rock64@rock64:/opt/iobroker$ sudo apt-get install -y nodejs
      Building dependency tree
      nodejs is already the newest version (10.16.0-1nodesource1).
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      rock64@rock64:/opt/iobroker$ node -v
      v10.16.0
      rock64@rock64:/opt/iobroker$ curl -sL https://iobroker.net/fix.sh | bash -
          Welcome to the ioBroker installation fixer!
          Script version: 2019-07-21
          Installing prerequisites (1/3)
          Checking ioBroker user and directory permissions (2/3)
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      npm ERR! errno -13
      npm ERR!   stack:
      npm ERR!   path:
      npm ERR!
      npm ERR!
      npm ERR!     /home/rock64/.npm/_logs/2019-07-26T09_47_03_405Z-debug.log
      npm ERR! errno 243
      npm ERR!
      npm ERR!     /home/rock64/.npm/_logs/2019-07-26T09_47_03_647Z-debug.log
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/abbrev
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ansi-regex
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/aproba
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/balanced-match
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/chownr
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/code-point-at
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/concat-map
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/brace-expansion
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/console-control-strings
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/core-util-is
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/deep-extend
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/delegates
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/detect-libc
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/fs.realpath
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/has-unicode
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/inherits
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ini
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/isarray
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/minimatch
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ignore-walk
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/minimist
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/mkdirp
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/needle/node_modules/debug
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/npm-bundled
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/npm-packlist
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/number-is-nan
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/is-fullwidth-code-point
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/object-assign
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/os-homedir
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/os-tmpdir
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/osenv
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/nopt
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/path-is-absolute
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/process-nextick-args
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/rc/node_modules/minimist
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/safe-buffer
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/safer-buffer
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/iconv-lite
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/sax
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/set-blocking
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/signal-exit
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/string_decoder
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/strip-ansi
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/string-width
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/strip-json-comments
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/util-deprecate
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/readable-stream
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/are-we-there-yet
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/wide-align
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/gauge
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/npmlog
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/wrappy
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/once
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/inflight
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/glob
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/rimraf
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/yallist
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/minipass
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/fs-minipass
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/minizlib
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/tar
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket'
      npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket']
      npm ERR!   stack:
      npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket\'',
      npm ERR!   path:
      npm ERR!    '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket' }
      npm ERR!
      npm ERR!
      npm ERR!     /home/rock64/.npm/_logs/2019-07-26T09_58_41_378Z-debug.log
      Fixer Script habe ich laufen lassen,
      Radar2 und Ble vorher komplett gelöscht.
      Auch die Neuinstallation von bluetooth-hci-socket schlägt fehl.
      js-controller: 1.5.14
      Jemand eine Idee?
      F
      FuLLHDvs480p
    • RE: LOGO!8 Steuerungsproblem
      stehe gerade vor dem selben Problem.
      Verbindung zwischen Iobroker und Logo habe ich bereits.
      Nun habe ich in der Logo Netzwerkausgänge programmiert die ich gerne in Iobroker hätte um diese dort weiter zuarbeiten.
      Leider sind diese in iobroker immer auf false obwohl sie in der Logo auf true gesetzt sind.
      Hier mal ein paar Bilder meiner Konfiguration:
      Durch die ganze Testerei hab ich in Iobroker die Netzwerk ausgänge mal sowohl als Eingang und Ausgang reingenommen.
      Ausgang 0.5 müsste auf true sein, da er auf der Logo gesetzt wird.
      Hier am Beispiel Netzwerk Ausgang 0.5, der gerade auf true war.
      Gruß Timo
      F
      FuLLHDvs480p
    • RE: Adpater für USV ?
      @smarti2015 Achso Okay 😅
      F
      FuLLHDvs480p
      @smarti2015 Hast du mittlerweile eine Lösung? Würde gern meine APC Back UPS PRO - BR550GI - USV 550VA in iobroker einbinden
      Gruß Timo
      F
      FuLLHDvs480p
