  4. Test Adapter Philips-TV v0.2.x
    6.8k
philipsphilips tv
550 Beiträge 84 Kommentatoren 185.8k Aufrufe 48 Beobachtet
  • AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    #101
    @integer63:
    Wow, ging sehr schnell auf grün: `
    Prima, das ist ein Haken mehr auf der Liste. Bitte mal beobachten ob das so bleibt.
      dali3
      #102
      http://192.168.0.87:1925/6/system
      Not Found
      The server has not found anything matching the request URI
      You can get technical details here.
      Please continue your visit at our home page.
      http://192.168.0.87:1925/system
      {"menulanguage":"German","name":"65PUS8700\/12","country":"Switzerland","serialnumber_encrypted":"cXxPJYO2Jd7cDIA2EVdcnlAJ7u3hHME1wGMcClXPKAw=\n","softwareversion_encrypted":"XYlnb20zZkKE3LL\/Vj3vwh+viBBi72vdK9ead64bFVE=\n","model_encrypted":"MaZqqUUf53LzdAflDuBMRtZDVgoCF0795oOzz3aR8EI=\n","deviceid_encrypted":"I1iDm1ydAOVzZ+Q8tqPbkZPy\/t9pDSwRgVKcKN2EHvk=\n","nettvversion":"5.2.0","epgsource":"ip","api_version":{"Major":5,"Minor":2,"Patch":0},"featuring":{"jsonfeatures":{"ambilight":["LoungeLight","Ambilight"],"textentry":["context_based","initial_string_available"],"inputkey":["key"],"applications":["TV_Apps","TV_Games","TV_Settings"],"pointer":["not_available"],"activities":["intent"]},"systemfeatures":{"tvtype":"consumer","content":["dmr","dms_tad"],"tvsearch":"intent","pairing_type":"digest_auth_pairing","secured_transport":"true"}}}
      http://192.168.0.87:1925/5/system
      {"menulanguage":"German","name":"65PUS8700\/12","country":"Switzerland","serialnumber_encrypted":"r6JNErTrk01mgMdYKDrcZhO2h8wxGWbU3\/oCU1YabU4=\n","softwareversion_encrypted":"64nDPvAaqHDiAVZbDPMDvBovcPmyT\/USuWhpBxNi1vE=\n","model_encrypted":"gHBfHO0\/ZcUFiP\/AhZXqohTJArRKu74yN9NoyUSqlEk=\n","deviceid_encrypted":"q6Tjl9HOpRMEqHn37o9fmjiqWOfzhcbVBqw6E4R8Bz0=\n","nettvversion":"5.2.0","epgsource":"ip","api_version":{"Major":5,"Minor":2,"Patch":0},"featuring":{"jsonfeatures":{"ambilight":["LoungeLight","Ambilight"],"textentry":["context_based","initial_string_available"],"inputkey":["key"],"applications":["TV_Apps","TV_Games","TV_Settings"],"pointer":["not_available"],"activities":["intent"]},"systemfeatures":{"tvtype":"consumer","content":["dmr","dms_tad"],"tvsearch":"intent","pairing_type":"digest_auth_pairing","secured_transport":"true"}}}
      http://192.168.0.87:1925/1/audio/volume
      http://192.168.0.87:1925/5/audio/volume
      https://192.168.0.87:1926/6/audio/volume
      Not Found
      Habe aktuell die alpha4? (https://github.com/AlCalzone/ioBroker.p … /api-v5+v6 ?)
      Systeminfo:
      Iobroker Pro, Surface 3 (Mobil), Acer T272 (Wand), Raspberry Pi 3, NUC, Synology DS212j (BackUp), Google Home, Xiaomi Aqara (Sensoren, Fühler, Kamera, LED), Revo Superconnect, Philips Hue, IKEA Tradfri...
      • N Offline
        N Offline
        NemoN
        #103
        philips-tv.0	2018-01-30 21:37:45.671	warn	The TV at 192.168.5.109 needs to be paired before you can use the adapter. Go to the adapter config to continue!
        philips-tv.0	2018-01-30 21:37:45.670	debug	TV has APIv6
        philips-tv.0	2018-01-30 21:37:45.493	debug	testing APIv6
        philips-tv.0	2018-01-30 21:37:45.392	debug	API test for v5 failed. Reason: [undefined] 404 - "\n\n \n\n\n
        philips-tv.0	2018-01-30 21:37:45.365	debug	testing APIv5
        philips-tv.0	2018-01-30 21:37:45.262	debug	API test for v1 failed. Reason: [undefined] 404 - "\n\n \n\n\n
        philips-tv.0	2018-01-30 21:37:45.245	debug	testing APIv1
        philips-tv.0	2018-01-30 21:37:45.245	debug	detecting API version
        philips-tv.0	2018-01-30 21:37:45.245	debug	connection is ALIVE
        philips-tv.0	2018-01-30 21:37:45.224	debug	checking if connection is alive
        philips-tv.0	2018-01-30 21:37:45.222	debug	initializing connection to 192.168.5.109
        er erkennt das noch nicht gepairt wurde. super :)
          AlCalzoneA Offline
          AlCalzone
          #104
          @dali3:
          Habe aktuell die alpha4? (https://github.com/AlCalzone/ioBroker.p … /api-v5+v6 ?) `
          Ja das passt, habe die Version bei den letzten Änderungen nicht mehr angepasst. Bist du etwa einer der Leute mit der 4. (anderen) API?
          Kommt da was?
          http://192.168.0.87:49154/nmrRenderingControl.xml
            dali3
            #105
            @AlCalzone:
            @dali3:
            Kommt da was?
            http://192.168.0.87:49154/nmrRenderingControl.xml `
            JA!
            This XML file does not appear to have any style information associated with it. The document tree is shown below.
            <scpd xmlns="urn:schemas-upnp-org:service-1-0"><specversion><major>1</major>
            <minor>0</minor></specversion>
            <servicestatetable><statevariable sendevents="no"><name>PresetNameList</name>
            <datatype>string</datatype></statevariable>
            <statevariable sendevents="yes"><name>LastChange</name>
            <statevariable sendevents="no"><name>A_ARG_TYPE_Channel</name>
            <allowedvaluelist><allowedvalue>Master</allowedvalue></allowedvaluelist></statevariable>
            <statevariable sendevents="no"><name>A_ARG_TYPE_InstanceID</name>
            <datatype>ui4</datatype></statevariable>
            <statevariable sendevents="no"><name>A_ARG_TYPE_PresetName</name>
            <allowedvaluelist><allowedvalue>FactoryDefaults</allowedvalue></allowedvaluelist></statevariable>
            <statevariable sendevents="no"><name>Volume</name>
            <datatype>ui2</datatype>
            <allowedvaluerange><minimum>0</minimum>
            <maximum>100</maximum>
            <step>1</step></allowedvaluerange></statevariable>
            <statevariable sendevents="no"><name>Mute</name>
            <datatype>boolean</datatype></statevariable></servicestatetable>
            <actionlist><action><name>ListPresets</name>
            <argumentlist><argument><name>InstanceID</name>
            <direction>in</direction>
            <relatedstatevariable>A_ARG_TYPE_InstanceID</relatedstatevariable></argument>
            <argument><name>CurrentPresetNameList</name>
            <direction>out</direction>
            <relatedstatevariable>PresetNameList</relatedstatevariable></argument></argumentlist></action>
            <action><name>SelectPreset</name>
            <argument><name>PresetName</name>
            <relatedstatevariable>A_ARG_TYPE_PresetName</relatedstatevariable></argument></argumentlist></action>
            <action><name>GetVolume</name>
            <argument><name>Channel</name>
            <relatedstatevariable>A_ARG_TYPE_Channel</relatedstatevariable></argument>
            <argument><name>CurrentVolume</name>
            <relatedstatevariable>Volume</relatedstatevariable></argument></argumentlist></action>
            <action><name>SetVolume</name>
            <argument><name>DesiredVolume</name>
            <action><name>SetMute</name>
            <argument><name>DesiredMute</name>
            <relatedstatevariable>Mute</relatedstatevariable></argument></argumentlist></action>
            <action><name>GetMute</name>
            <argument><name>CurrentMute</name>
            <relatedstatevariable>Mute</relatedstatevariable></argument></argumentlist></action></actionlist></scpd>
            Systeminfo:
              AlCalzoneA Offline
              AlCalzone
              #106
              @dali3:
              JA! `
              Hm das geht bei mir aber auch und ich hab API v1. Mich wundert, dass beim Rest nix kommt. Kannst ja nochmal ein paar der Links in diesem Thread probieren - wenn da außer /system nix geht, musst du dich wohl noch etwas gedulden.
              Aber jetzt ist erst mal Feierabend :)
                dali3
                #107
                @AlCalzone:
                @dali3:
                JA! `
                Aber jetzt ist erst mal Feierabend :) `
                AlCalzone, hatte gestern auch Feierabend :)
                Habe die Links jetzt zusammentragen und werde diese heute Abend zu Hause testen!
                Liste IP:
                • X= getestet
                X [https://IPvomTV:1926/6/audio/volume](https://IPvomTV:1926/6/audio/volume)
                X [http://IPvomTV:1925/5/audio/volume](http://IPvomTV:1925/5/audio/volume)
                X [http://IPvomTV:1925/1/audio/volume](http://IPvomTV:1925/1/audio/volume)
                X [http://IPvomTV:1925/system](http://IPvomTV:1925/system)
                X [http://IPvomTV:1925/5/system](http://IPvomTV:1925/5/system)
                X [http://IPvomTV:1925/6/system](http://IPvomTV:1925/6/system)
                X [http://IPvomTV:49154/nmrRenderingControl.xml](http://IPvomTV:49154/nmrRenderingControl.xml)
                [http://IPvomTV:49153/nmrRenderingControl.xml](http://IPvomTV:49153/nmrRenderingControl.xml)
                [https://IPvomTV:1926/input/Key](https://IPvomTV:1926/input/Key)
                [http://IPvomTV:49154/nmsDescription.xml](http://IPvomTV:49154/nmsDescription.xml)
                [http://IPvomTV:49154/nmrAVTransport.xml](http://IPvomTV:49154/nmrAVTransport.xml)
                [http://IPvomTV:49154/nmsContentDirectorySCPD.xml](http://IPvomTV:49154/nmsContentDirectorySCPD.xml)
                [http://IPvomTV:49154/nmrConnectionManager.xml](http://IPvomTV:49154/nmrConnectionManager.xml)
                Falls ich eine übersehen habe, bitte kurz mitteilen :)
                Danke für deinen Einsatz!!!
                Systeminfo:
                  dali3
                  #108
                  so wie versprochen noch die offenen Punkte:
                   <statevariable sendevents="no"><name>AllowedTransformSettings</name>
                   <statevariable sendevents="no"><name>TransformSettings</name>
                   <action><name>GetAllowedTransforms</name>
                   <argument><name>CurrentAllowedTransformSettings</name>
                  <relatedstatevariable>AllowedTransformSettings</relatedstatevariable></argument></argumentlist></action>
                   <action><name>GetTransforms</name>
                   <argument><name>CurrentTransformValues</name>
                  <relatedstatevariable>TransformSettings</relatedstatevariable></argument></argumentlist></action>
                   <action><name>SetTransforms</name>
                   <argument><name>DesiredTransformValues</name>
                   <action><name>GetAllAvailableTransforms</name>
                   <argumentlist><argument><name>AllAllowedTransformSettings</name>
                  <relatedstatevariable>AllowedTransformSettings</relatedstatevariable></argument></argumentlist></action></actionlist></scpd>
                  Not Found
                  >! The server has not found anything matching the request URI
                  >! You can get technical details here.
                   <root xmlns="urn:schemas-upnp-org:device-1-0"><specversion><major>1</major>
                   <device><devicetype>urn:schemas-upnp-org:device:MediaServer:3</devicetype>
                  <friendlyname>65PUS8700/12</friendlyname>
                  <manufacturer>Royal Philips Electronics</manufacturer>
                  <manufacturerurl>http://www.philips.com</manufacturerurl>
                  <modeldescription>Philips TV Server</modeldescription>
                  <modelname>Philips TV Server</modelname>
                  <modelnumber>2k15Marvel</modelnumber>
                  <modelurl>http://www.philips.com/</modelurl>
                  <serialnumber>123456789-serial</serialnumber>
                  <udn>uuid:5AFEF00D-BABE-DADA-FA5A-b886870336ed</udn>
                  <upc>123456789123</upc>
                   <iconlist><icon><mimetype>image/png</mimetype>
                  <height>48</height>
                  <width>48</width>
                  <depth>24</depth>
                  <url>CP_logo_0.png</url></icon>
                  <height>120</height>
                  <width>120</width>
                  <depth>24</depth>
                  <url>CP_logo_1.png</url></icon>
                   <icon><mimetype>image/jpeg</mimetype>
                  <height>48</height>
                  <width>48</width>
                  <depth>24</depth>
                  <url>CP_logo_2.jpg</url></icon>
                  <width>120</width>
                  <depth>24</depth>
                  <url>CP_logo_3.jpg</url></icon></iconlist>
                   <servicelist><service><servicetype>urn:schemas-upnp-org:service:ContentDirectory:3</servicetype>
                  <serviceid>urn:upnp-org:serviceId:ContentDirectory</serviceid>
                  <controlurl>upnp/control/ContentDirectoryNmsO</controlurl>
                  <eventsuburl>upnp/event/ContentDirectoryNmsO</eventsuburl>
                  <scpdurl>nmsContentDirectorySCPD.xml</scpdurl></service>
                   <service><servicetype>urn:schemas-upnp-org:service:ConnectionManager:2</servicetype>
                  <serviceid>urn:upnp-org:serviceId:ConnectionManager</serviceid>
                  <controlurl>upnp/control/ConnectionManagerNmsO</controlurl>
                  <eventsuburl>upnp/event/ConnectionManagerNmsO</eventsuburl>
                  <scpdurl>nmsConnectionManagerSCPD.xml</scpdurl></service></servicelist></device></root>
                   <actionlist><action><name>Play</name>
                   <argument><name>Speed</name>
                  <relatedstatevariable>TransportPlaySpeed</relatedstatevariable></argument></argumentlist></action>
                   <action><name>Stop</name>
                  <relatedstatevariable>A_ARG_TYPE_InstanceID</relatedstatevariable></argument></argumentlist></action>
                   <action><name>Next</name>
                   <action><name>Previous</name>
                   <action><name>GetMediaInfo</name>
                   <argument><name>NrTracks</name>
                  <relatedstatevariable>NumberOfTracks</relatedstatevariable></argument>
                   <argument><name>MediaDuration</name>
                  <relatedstatevariable>CurrentMediaDuration</relatedstatevariable></argument>
                   <argument><name>CurrentURI</name>
                  <relatedstatevariable>AVTransportURI</relatedstatevariable></argument>
                   <argument><name>CurrentURIMetaData</name>
                  <relatedstatevariable>AVTransportURIMetaData</relatedstatevariable></argument>
                   <argument><name>NextURI</name>
                  <relatedstatevariable>NextAVTransportURI</relatedstatevariable></argument>
                   <argument><name>NextURIMetaData</name>
                  <relatedstatevariable>NextAVTransportURIMetaData</relatedstatevariable></argument>
                   <argument><name>PlayMedium</name>
                  <relatedstatevariable>PlaybackStorageMedium</relatedstatevariable></argument>
                   <argument><name>RecordMedium</name>
                  <relatedstatevariable>RecordStorageMedium</relatedstatevariable></argument>
                   <argument><name>WriteStatus</name>
                  <relatedstatevariable>RecordMediumWriteStatus</relatedstatevariable></argument></argumentlist></action>
                   <action><name>GetDeviceCapabilities</name>
                   <argument><name>PlayMedia</name>
                  <relatedstatevariable>PossiblePlaybackStorageMedia</relatedstatevariable></argument>
                   <argument><name>RecMedia</name>
                  <relatedstatevariable>PossibleRecordStorageMedia</relatedstatevariable></argument>
                   <argument><name>RecQualityModes</name>
                  <relatedstatevariable>PossibleRecordQualityModes</relatedstatevariable></argument></argumentlist></action>
                   <action><name>SetAVTransportURI</name>
                  <relatedstatevariable>AVTransportURIMetaData</relatedstatevariable></argument></argumentlist></action>
                   <action><name>GetCurrentTransportActions</name>
                   <argument><name>Actions</name>
                  <relatedstatevariable>CurrentTransportActions</relatedstatevariable></argument></argumentlist></action>
                   <action><name>GetTransportSettings</name>
                   <argument><name>PlayMode</name>
                  <relatedstatevariable>CurrentPlayMode</relatedstatevariable></argument>
                   <argument><name>RecQualityMode</name>
                  <relatedstatevariable>CurrentRecordQualityMode</relatedstatevariable></argument></argumentlist></action>
                   <action><name>GetTransportInfo</name>
                   <argument><name>CurrentTransportState</name>
                  <relatedstatevariable>TransportState</relatedstatevariable></argument>
                   <argument><name>CurrentTransportStatus</name>
                  <relatedstatevariable>TransportStatus</relatedstatevariable></argument>
                   <argument><name>CurrentSpeed</name>
                   <action><name>Pause</name>
                   <action><name>Seek</name>
                   <argument><name>Unit</name>
                  <relatedstatevariable>A_ARG_TYPE_SeekMode</relatedstatevariable></argument>
                   <argument><name>Target</name>
                  <relatedstatevariable>A_ARG_TYPE_SeekTarget</relatedstatevariable></argument></argumentlist></action>
                   <action><name>GetPositionInfo</name>
                   <argument><name>Track</name>
                  <relatedstatevariable>CurrentTrack</relatedstatevariable></argument>
                   <argument><name>TrackDuration</name>
                  <relatedstatevariable>CurrentTrackDuration</relatedstatevariable></argument>
                   <argument><name>TrackMetaData</name>
                  <relatedstatevariable>CurrentTrackMetaData</relatedstatevariable></argument>
                   <argument><name>TrackURI</name>
                  <relatedstatevariable>CurrentTrackURI</relatedstatevariable></argument>
                   <argument><name>RelTime</name>
                  <relatedstatevariable>RelativeTimePosition</relatedstatevariable></argument>
                   <argument><name>AbsTime</name>
                  <relatedstatevariable>AbsoluteTimePosition</relatedstatevariable></argument>
                   <argument><name>RelCount</name>
                  <relatedstatevariable>RelativeCounterPosition</relatedstatevariable></argument>
                   <argument><name>AbsCount</name>
                  <relatedstatevariable>AbsoluteCounterPosition</relatedstatevariable></argument></argumentlist></action></actionlist>
                   <servicestatetable><statevariable sendevents="no"><name>CurrentPlayMode</name>
                  <defaultvalue>NORMAL</defaultvalue>
                   <allowedvaluelist><allowedvalue>NORMAL</allowedvalue></allowedvaluelist></statevariable>
                   <statevariable sendevents="no"><name>RecordStorageMedium</name>
                   <allowedvaluelist><allowedvalue>UNKNOWN</allowedvalue>
                  <allowedvalue>DV</allowedvalue>
                  <allowedvalue>MINI-DV</allowedvalue>
                  <allowedvalue>VHS</allowedvalue>
                  <allowedvalue>W-VHS</allowedvalue>
                  <allowedvalue>S-VHS</allowedvalue>
                  <allowedvalue>D-VHS</allowedvalue>
                  <allowedvalue>VHSC</allowedvalue>
                  <allowedvalue>VIDEO8</allowedvalue>
                  <allowedvalue>HI8</allowedvalue>
                  <allowedvalue>CD-ROM</allowedvalue>
                  <allowedvalue>CD-DA</allowedvalue>
                  <allowedvalue>CD-R</allowedvalue>
                  <allowedvalue>CD-RW</allowedvalue>
                  <allowedvalue>VIDEO-CD</allowedvalue>
                  <allowedvalue>SACD</allowedvalue>
                  <allowedvalue>MD-AUDIO</allowedvalue>
                  <allowedvalue>MD-PICTURE</allowedvalue>
                  <allowedvalue>DVD-ROM</allowedvalue>
                  <allowedvalue>DVD-VIDEO</allowedvalue>
                  <allowedvalue>DVD-R</allowedvalue>
                  <allowedvalue>DVD+RW</allowedvalue>
                  <allowedvalue>DVD-RW</allowedvalue>
                  <allowedvalue>DVD-RAM</allowedvalue>
                  <allowedvalue>DVD-AUDIO</allowedvalue>
                  <allowedvalue>DAT</allowedvalue>
                  <allowedvalue>LD</allowedvalue>
                  <allowedvalue>HDD</allowedvalue>
                  <allowedvalue>MICRO-MV</allowedvalue>
                  <allowedvalue>NETWORK</allowedvalue>
                  <allowedvalue>NONE</allowedvalue>
                  <allowedvalue>NOT_IMPLEMENTED</allowedvalue></allowedvaluelist></statevariable>
                   <statevariable sendevents="no"><name>RelativeTimePosition</name>
                   <statevariable sendevents="no"><name>CurrentTrackURI</name>
                   <statevariable sendevents="no"><name>CurrentTrackDuration</name>
                   <statevariable sendevents="no"><name>CurrentRecordQualityMode</name>
                   <allowedvaluelist><allowedvalue>0:EP</allowedvalue>
                  <allowedvalue>1:LP</allowedvalue>
                  <allowedvalue>2:SP</allowedvalue>
                  <allowedvalue>0:BASIC</allowedvalue>
                  <allowedvalue>1:MEDIUM</allowedvalue>
                  <allowedvalue>2:HIGH</allowedvalue>
                   <statevariable sendevents="no"><name>CurrentMediaDuration</name>
                   <statevariable sendevents="no"><name>AbsoluteCounterPosition</name>
                  <datatype>i4</datatype></statevariable>
                   <statevariable sendevents="no"><name>RelativeCounterPosition</name>
                   <statevariable sendevents="no"><name>AVTransportURI</name>
                   <statevariable sendevents="no"><name>TransportState</name>
                   <allowedvaluelist><allowedvalue>STOPPED</allowedvalue>
                  <allowedvalue>PAUSED_PLAYBACK</allowedvalue>
                  <allowedvalue>PAUSED_RECORDING</allowedvalue>
                  <allowedvalue>PLAYING</allowedvalue>
                  <allowedvalue>RECORDING</allowedvalue>
                  <allowedvalue>TRANSITIONING</allowedvalue>
                  <allowedvalue>NO_MEDIA_PRESENT</allowedvalue></allowedvaluelist></statevariable>
                   <statevariable sendevents="no"><name>CurrentTrackMetaData</name>
                   <statevariable sendevents="no"><name>NextAVTransportURI</name>
                   <statevariable sendevents="no"><name>PossibleRecordQualityModes</name>
                   <statevariable sendevents="no"><name>CurrentTrack</name>
                  <maximum>4294967295</maximum>
                   <statevariable sendevents="no"><name>AbsoluteTimePosition</name>
                   <statevariable sendevents="no"><name>NextAVTransportURIMetaData</name>
                   <statevariable sendevents="no"><name>PlaybackStorageMedium</name>
                   <statevariable sendevents="no"><name>RecordMediumWriteStatus</name>
                   <allowedvaluelist><allowedvalue>WRITABLE</allowedvalue>
                  <allowedvalue>PROTECTED</allowedvalue>
                  <allowedvalue>NOT_WRITABLE</allowedvalue>
                   <statevariable sendevents="no"><name>PossiblePlaybackStorageMedia</name>
                   <statevariable sendevents="no"><name>AVTransportURIMetaData</name>
                   <statevariable sendevents="no"><name>NumberOfTracks</name>
                  <maximum>4294967295</maximum></allowedvaluerange></statevariable>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_SeekMode</name>
                   <allowedvaluelist><allowedvalue>ABS_TIME</allowedvalue>
                  <allowedvalue>REL_TIME</allowedvalue>
                  <allowedvalue>TRACK_NR</allowedvalue></allowedvaluelist></statevariable>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_SeekTarget</name>
                   <statevariable sendevents="no"><name>PossibleRecordStorageMedia</name>
                   <statevariable sendevents="no"><name>TransportStatus</name>
                   <allowedvaluelist><allowedvalue>OK</allowedvalue>
                  <allowedvalue>ERROR_OCCURRED</allowedvalue>
                  <allowedvalue>UNKNOWN</allowedvalue></allowedvaluelist></statevariable>
                   <statevariable sendevents="no"><name>TransportPlaySpeed</name>
                   <allowedvaluelist><allowedvalue>1</allowedvalue></allowedvaluelist></statevariable>
                   <statevariable sendevents="no"><name>CurrentTransportActions</name>
                  <datatype>string</datatype></statevariable></servicestatetable></scpd>
                  http://IPvomTV:49154/nmsContentDirectorySCPD.…
                   <actionlist><action><name>GetSearchCapabilities</name>
                   <argumentlist><argument><name>SearchCaps</name>
                  <relatedstatevariable>SearchCapabilities</relatedstatevariable></argument></argumentlist></action>
                   <action><name>GetSortCapabilities</name>
                   <argumentlist><argument><name>SortCaps</name>
                  <relatedstatevariable>SortCapabilities</relatedstatevariable></argument></argumentlist></action>
                   <action><name>GetSystemUpdateID</name>
                   <argumentlist><argument><name>Id</name>
                  <relatedstatevariable>SystemUpdateID</relatedstatevariable></argument></argumentlist></action>
                   <action><name>GetServiceResetToken</name>
                   <argumentlist><argument><name>ResetToken</name>
                  <relatedstatevariable>ServiceResetToken</relatedstatevariable></argument></argumentlist></action>
                   <action><name>GetFeatureList</name>
                   <argumentlist><argument><name>FeatureList</name>
                  <relatedstatevariable>FeatureList</relatedstatevariable></argument></argumentlist></action>
                   <action><name>Browse</name>
                   <argumentlist><argument><name>ObjectID</name>
                  <relatedstatevariable>A_ARG_TYPE_ObjectID</relatedstatevariable></argument>
                   <argument><name>BrowseFlag</name>
                  <relatedstatevariable>A_ARG_TYPE_BrowseFlag</relatedstatevariable></argument>
                   <argument><name>Filter</name>
                  <relatedstatevariable>A_ARG_TYPE_Filter</relatedstatevariable></argument>
                   <argument><name>StartingIndex</name>
                  <relatedstatevariable>A_ARG_TYPE_Index</relatedstatevariable></argument>
                   <argument><name>RequestedCount</name>
                  <relatedstatevariable>A_ARG_TYPE_Count</relatedstatevariable></argument>
                   <argument><name>SortCriteria</name>
                  <relatedstatevariable>A_ARG_TYPE_SortCriteria</relatedstatevariable></argument>
                   <argument><name>Result</name>
                  <relatedstatevariable>A_ARG_TYPE_Result</relatedstatevariable></argument>
                   <argument><name>NumberReturned</name>
                   <argument><name>TotalMatches</name>
                   <argument><name>UpdateID</name>
                  <relatedstatevariable>A_ARG_TYPE_UpdateID</relatedstatevariable></argument></argumentlist></action>
                   <action><name>X_BrowseByLetter</name>
                   <argument><name>StartingLetter</name>
                  <relatedstatevariable>A_ARG_TYPE_BrowseLetter</relatedstatevariable></argument>
                  <relatedstatevariable>A_ARG_TYPE_Index</relatedstatevariable></argument></argumentlist></action>
                   <action><name>X_Philips_PauseStream</name>
                   <argumentlist><argument><name>Result</name>
                  <relatedstatevariable>X_Philips_A_ARG_TYPE_Result</relatedstatevariable></argument></argumentlist></action>
                   <action><name>X_Philips_ResumeStream</name>
                   <action><name>X_Philips_JumpToPosition</name>
                   <argumentlist><argument><name>PositionFlag</name>
                  <relatedstatevariable>X_Philips_A_ARG_TYPE_PositionFlag</relatedstatevariable></argument>
                   <argument><name>Position</name>
                  <relatedstatevariable>X_Philips_A_ARG_Position</relatedstatevariable></argument>
                   <action><name>X_Philips_GetPlaybackPosition</name>
                  <relatedstatevariable>X_Philips_A_ARG_Position</relatedstatevariable></argument></argumentlist></action>
                   <action><name>X_Philips_GetTimeShiftInfo</name>
                   <argumentlist><argument><name>BufferDuration</name>
                  <relatedstatevariable>X_Philips_A_ARG_TYPE_BufferedDuration</relatedstatevariable></argument>
                   <argument><name>CurrentPosition</name>
                   <argument><name>MaxDuration</name>
                  <relatedstatevariable>X_Philips_A_ARG_TYPE_MaxDuration</relatedstatevariable></argument>
                  <relatedstatevariable>X_Philips_A_ARG_TYPE_Result</relatedstatevariable></argument></argumentlist></action></actionlist>
                   <servicestatetable><statevariable sendevents="yes"><name>TransferIDs</name>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_ObjectID</name>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_Result</name>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_BrowseFlag</name>
                   <allowedvaluelist><allowedvalue>BrowseMetadata</allowedvalue>
                  <allowedvalue>BrowseDirectChildren</allowedvalue></allowedvaluelist></statevariable>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_BrowseLetter</name>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_Filter</name>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_SortCriteria</name>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_Index</name>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_Count</name>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_UpdateID</name>
                   <statevariable sendevents="no"><name>SearchCapabilities</name>
                   <statevariable sendevents="no"><name>SortCapabilities</name>
                   <statevariable sendevents="yes"><name>SystemUpdateID</name>
                   <statevariable sendevents="no"><name>ServiceResetToken</name>
                   <statevariable sendevents="yes"><name>ContainerUpdateIDs</name>
                   <statevariable sendevents="no"><name>FeatureList</name>
                   <statevariable sendevents="no"><name>X_Philips_A_ARG_TYPE_Result</name>
                   <statevariable sendevents="no"><name>X_Philips_A_ARG_TYPE_PositionFlag</name>
                   <statevariable sendevents="no"><name>X_Philips_A_ARG_Position</name>
                   <statevariable sendevents="no"><name>X_Philips_A_ARG_TYPE_BufferedDuration</name>
                   <statevariable sendevents="no"><name>X_Philips_A_ARG_TYPE_MaxDuration</name>
                   <actionlist><action><name>GetProtocolInfo</name>
                   <argumentlist><argument><name>Source</name>
                  <relatedstatevariable>SourceProtocolInfo</relatedstatevariable></argument>
                   <argument><name>Sink</name>
                  <relatedstatevariable>SinkProtocolInfo</relatedstatevariable></argument></argumentlist></action>
                   <action><name>GetCurrentConnectionIDs</name>
                   <argumentlist><argument><name>ConnectionIDs</name>
                  <relatedstatevariable>CurrentConnectionIDs</relatedstatevariable></argument></argumentlist></action>
                   <action><name>GetCurrentConnectionInfo</name>
                   <argumentlist><argument><name>ConnectionID</name>
                  <relatedstatevariable>A_ARG_TYPE_ConnectionID</relatedstatevariable></argument>
                   <argument><name>RcsID</name>
                  <relatedstatevariable>A_ARG_TYPE_RcsID</relatedstatevariable></argument>
                   <argument><name>AVTransportID</name>
                  <relatedstatevariable>A_ARG_TYPE_AVTransportID</relatedstatevariable></argument>
                   <argument><name>ProtocolInfo</name>
                  <relatedstatevariable>A_ARG_TYPE_ProtocolInfo</relatedstatevariable></argument>
                   <argument><name>PeerConnectionManager</name>
                  <relatedstatevariable>A_ARG_TYPE_ConnectionManager</relatedstatevariable></argument>
                   <argument><name>PeerConnectionID</name>
                   <argument><name>Direction</name>
                  <relatedstatevariable>A_ARG_TYPE_Direction</relatedstatevariable></argument>
                   <argument><name>Status</name>
                  <relatedstatevariable>A_ARG_TYPE_ConnectionStatus</relatedstatevariable></argument></argumentlist></action></actionlist>
                   <servicestatetable><statevariable sendevents="yes"><name>SourceProtocolInfo</name>
                   <statevariable sendevents="yes"><name>SinkProtocolInfo</name>
                   <statevariable sendevents="yes"><name>CurrentConnectionIDs</name>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_ConnectionStatus</name>
                  <allowedvalue>ContentFormatMismatch</allowedvalue>
                  <allowedvalue>InsufficientBandwidth</allowedvalue>
                  <allowedvalue>UnreliableChannel</allowedvalue>
                  <allowedvalue>Unknown</allowedvalue></allowedvaluelist></statevariable>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_ConnectionManager</name>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_Direction</name>
                   <allowedvaluelist><allowedvalue>Input</allowedvalue>
                  <allowedvalue>Output</allowedvalue></allowedvaluelist></statevariable>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_ProtocolInfo</name>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_ConnectionID</name>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_AVTransportID</name>
                   <statevariable sendevents="no"><name>A_ARG_TYPE_RcsID</name>
                  <datatype>i4</datatype></statevariable></servicestatetable></scpd>
                  Systeminfo:
                  • wendy2702W Online
                    wendy2702W Online
                    wendy2702
                    #109
                    @dali3:
                    http://IPvomTV:49153/nmrRenderingControl.xml `
                    Kannst du die vielleicht noch in "SPOILER" verpacken!?
                    Erleichtert das scrollen ;)
                      dali3
                      #110
                      @wendy2702:
                      @dali3:
                      Erleichtert das scrollen ;) `
                      So eingepackt, danke für den Input :)
                      Systeminfo:
                        AlCalzoneA Offline
                        AlCalzone
                        #111
                        Danke für die Logs, das scheint aktuell keine unterstützte API zu sein. Falls du Lust hast, kannst du dich mal in Google austoben. Für sachdienliche Hinweise zur Einbindung bin ich dankbar :D
                          dali3
                          #112
                          Ist diese Seite schob bekannt?
                          http://jointspace.sourceforge.net/proje … c/API.html
                          Bzw.
                          https://github.com/stevenle/googletv-anymote ?
                          Systeminfo:
                            AlCalzoneA Offline
                            AlCalzone
                            #113
                            @dali3:
                            Bzw.
                            https://github.com/stevenle/googletv-anymote ? `
                            1. ja, darauf bauen die aktuellen API-Implementationen
                            2. nein, funktiniert das mit deinem TV? Bzw kannst du herausfinden, ob der auf dieses "anymote" Protokoll setzt?
                              dali3
                              #114
                              @AlCalzone:
                              @dali3:
                              Bzw.
                              2. nein, funktiniert das mit deinem TV? Bzw kannst du herausfinden, ob der auf dieses "anymote" Protokoll setzt? `
                              Ich werde es dieses Weekend probieren, leider sind meine Programmierkenntnisse sehr begrenzt :)
                              Systeminfo:
                                Mater1984
                                #115
                                Ich habe ebenfalls einen TV mit API v6
                                Das Pairing manuell funktioniert. Dort habe ich jetzt Username und Passwort ausgelesen
                                Kann man das schon manuell in der Settings Datei eintragen?
                                Was muss denn noch am Admin Modul geändert werden?
                                Viele Grüße
                                  AlCalzoneA Offline
                                  AlCalzone
                                  #116
                                  @Mater1984:
                                  Viele Grüße `
                                  Ich kämpfe aktuell mit der Schnittstelle zum Admin v3, sonst wäre ich gestern schon fertig geworden. Bin mir nicht sicher ob ich das schon fertig implementiert hab, aber die neueste Version von github sollte mit username/Passwort funktionieren. Dazu das Objekt system.adapter.philips-tv.0 bearbeiten und bei username und password deine Daten eintragen.
                                  Gesendet von unterwegs
                                    Mater1984
                                    #117
                                    @AlCalzone:
                                    @Mater1984:
                                    Viele Grüße `
                                    Gesendet von unterwegs `
                                    Von wann ist die aktuelle Version?
                                    Hab es gestern Abend via git heruntergeladen.
                                    Schau es mit nachher mal an. Aber leider sind meine Programmierkenntnisse in dem Bereich nicht so Dolle. Eher dann in Cloudformation und Lambda ;-)
                                      Mater1984
                                      #118
                                      @AlCalzone:
                                      @Mater1984:
                                      Viele Grüße `
                                      Irgendwie finde ich das Bearbeiten nicht. Bin aber auch ganz neu bei iobroker.
                                        AlCalzoneA Offline
                                        AlCalzone
                                        #119
                                        Das ist auch nicht das richtige Objekt (system.adapter….) kann aber sein dass das nur per Skript zu bearbeiten geht.
                                        Edit: Probier mal das hier als Skript im Skripte-Adapter:
                                        const obj = getObject("system.adapter.philips-tv.0");
                                        obj.native.username = "dein username hier";
                                        obj.native.password = "dein passwort hier";
                                        setObject("system.adapter.philips-tv.0", obj);
                                        Danach wieder löschen oder deaktivieren.
                                        • sigi234S Online
                                          sigi234S Online
                                          sigi234
                                          #120
                                          @AlCalzone:
                                          @sigi234:
                                          bei mir bleibt die Instanz im Status "gelb". Du hast einen Fernseher mit Pairing (https und Benutzername/Passwort), richtig? Kannst du die Logstufe des Adapters mal auf debug stellen und nochmal nen Log posten? Ich hätte da etwas mehr Ausgaben erwartet.
                                          ich glaube ich habe keinen TV mit Pairing, da ich noch nie nach einen Benutzernamen oder Code gefragt wurde. Weder bei der Android App oder vom Programm tvremote ( Diese Programm verbindet sich automatisch mit dem TV und der Richtigen IP)!
                                          Immer Daten sichern!
