  4. (Erledigt) upnp nicht kompatibel mit aktuellem admin ?
    6.4k
29 Beiträge 4 Kommentatoren 1.1k Aufrufe 4 Beobachtet
  • amg_666A Offline
    amg_666A Offline
    amg_666
    Update von Debian auf Trixie muss ich noch in Ruhe machen, ich war 4 Monate im Ausland und komme erst jetzt dazu, hier wieder alles auf Vordermann zu bringen...
    Mir läuft jetzt aber leider das Log voll mit Fehlermeldungen vom Plenticore Adapter. Kann das an der neuen node-js liegen?
    host.iobroker
    	2026-04-02 20:34:17.919	error	Caught by controller[0]: (Use `node --trace-deprecation ...` to show where the warning was created)
    host.iobroker
    	2026-04-02 20:34:17.918	error	Caught by controller[0]: (node:793117) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
    plenticore.0
    	2026-04-02 20:34:17.503	error	Cannot read properties of undefined (reading 'sky')
    plenticore.0
    	2026-04-02 20:34:17.502	error	TypeError: Cannot read properties of undefined (reading 'sky') at checkStoreSunPanelSkyData (/opt/iobroker/node_modules/iobroker.plenticore/lib/plenticore.js:1068:48) at Object.storeSunPanelData (/opt/iobroker/node_modules/iobroker.plenticore/lib/plenticore.js:1526:2) at /opt/iobroker/node_modules/iobroker.plenticore/main.js:221:15 at loginSuccess (/opt/iobroker/node_modules/iobroker.plenticore/lib/plenticore.js:2718:14) at /opt/iobroker/node_modules/iobroker.plenticore/lib/plenticore.js:2677:5 at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/iobroker.plenticore/lib/plenticore.js:1585:16) at IncomingMessage.emit (node:events:531:35) at endReadableNT (node:internal/streams/readable:1698:12) at process.processTicksAndRejections (node:internal/process/task_queues:89:21)
    plenticore.0
    	2026-04-02 20:34:17.500	error	uncaught exception: Cannot read properties of undefined (reading 'sky')
    vw-connect.0
    	2026-04-02 20:34:12.829	error	MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
    host.iobroker
    	2026-04-02 20:33:43.029	error	Caught by controller[0]: (Use `node --trace-deprecation ...` to show where the warning was created)
    host.iobroker
    	2026-04-02 20:33:43.029	error	Caught by controller[0]: (node:793085) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
    plenticore.0
    	2026-04-02 20:33:42.500	error	Cannot read properties of undefined (reading 'sky')
    • amg_666A amg_666
      host.iobroker
      host.iobroker
      plenticore.0
      plenticore.0
      plenticore.0
      vw-connect.0
      host.iobroker
      host.iobroker
      plenticore.0
      @amg_666
      So alt wie das Ding ist:
      Ja.
      plenticore
      latest:	2.3.1 for 30 months
      stable:	2.2.0 for 58 months
        @amg_666 sagte:
        iobroker is not running on this host.
        amg_666A Offline
        amg_666A Offline
        amg_666
        @Thomas-Braun sagte:
        ich hatte den iob diag direkt nach dem Update laufen lassen, da war iob noch nicht wieder gestartet.
        So siehts jetzt im laufenden System aus
        ```bash
        Script v.2026-01-31
        *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-container
                 Chassis: container ☐
          Virtualization: lxc
                  Kernel: Linux 6.17.13-2-pve
            Architecture: x86-64
        OS is similar to:
        model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         20:37:53 up 19 days,  2:28,  2 users,  load average: 1.07, 1.37, 1.47
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
        *** TIME AND TIMEZONES ***
                       Local time: Thu 2026-04-02 20:37:54 CEST
                   Universal time: Thu 2026-04-02 18:37:54 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        Andreas
        HOME=/home/Andreas
        GROUPS=Andreas sudo iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev redis
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         false
        Unit display-manager.service could not be found.
        Display-Manager:
        Desktop:
        Session:
        *** MEMORY ***
        Mem:             12G        4.3G        8.3G         98K        248M        8.5G
        Swap:           4.3G         20K        4.3G
        Total:           17G        4.3G         12G
        Active iob-Instances:   47
                12288 M total memory
                 4145 M used memory
                 4133 M active memory
                   26 M inactive memory
                 7905 M free memory
                    0 M buffer memory
                  237 M swap cache
                 4096 M total swap
                    0 M used swap
                 4095 M free swap
        top - 20:37:54 up 19 days,  2:28,  2 users,  load average: 1.07, 1.37, 1.47
        Tasks:  72 total,   1 running,  71 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  12288.0 total,   7903.8 free,   4146.8 used,    237.4 buff/cache
        MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   8141.2 avail Mem
        *** FAILED SERVICES ***
          UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
        2 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        dmesg: read kernel buffer failed: Operation not permitted
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem                  Type      Size  Used Avail Use% Mounted on
        HA-Volume/subvol-100-disk-0 zfs       150G   17G  134G  11% /
        none                        tmpfs     492K  4.0K  488K   1% /dev
        udev                        devtmpfs  7.7G     0  7.7G   0% /dev/tty
        tmpfs                       tmpfs     7.8G     0  7.8G   0% /dev/shm
        tmpfs                       tmpfs     3.1G  112K  3.1G   1% /run
        tmpfs                       tmpfs     5.0M     0  5.0M   0% /run/lock
        Show mounted filesystems:
        TARGET SOURCE                      FSTYPE OPTIONS
        /      HA-Volume/subvol-100-disk-0 zfs    rw,relatime,xattr,posixacl,casesensitive
        /var:
        445M    /var/
        316M    /var/cache
        314M    /var/cache/apt
        267M    /var/cache/apt/archives
        69M     /var/lib
        Archived and active journals take up 3.8M in the file system.
        /opt/iobroker/backups:
        3.1G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        2.1G    /opt/iobroker/iobroker-data/
        1.6G    /opt/iobroker/iobroker-data/history
        319M    /opt/iobroker/iobroker-data/files
        179M    /opt/iobroker/iobroker-data/backup-objects
        78M     /opt/iobroker/iobroker-data/files/vis
        18M     /opt/iobroker/iobroker-data/objects.jsonl
        16M     /opt/iobroker/iobroker-data/files/vis-2/assets/index-DqJdyjgH.js.map
        16M     /opt/iobroker/iobroker-data/files/vis-2/assets/index-CrLrNq4s.js.map
        7.5M    /opt/iobroker/iobroker-data/objects.json.migrated
        7.5M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
        USB-Devices by-id:
        USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
        please always prefer the links 'by-id':
        No Devices found 'by-id'
        *** ZigBee Settings ***
        ⚠ HINT:
        Your zigbee.2 COM-Port is NOT matching 'by-id'.
        Please check your setting:
        tcp
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v22.22.2
        /usr/bin/node           v22.22.2
        /usr/bin/npm            10.9.7
        /usr/bin/npx            10.9.7
        ✓ Node.js installation is correct
        nodejs:
          Installed: 22.22.2-1nodesource1
          Candidate: 22.22.2-1nodesource1
          Version table:
         *** 22.22.2-1nodesource1 1001
                500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             22.22.1-1nodesource1 1001
             22.22.0-1nodesource1 1001
             22.21.0-1nodesource1 1001
             22.20.0-1nodesource1 1001
             22.19.0-1nodesource1 1001
             22.18.0-1nodesource1 1001
             22.17.1-1nodesource1 1001
             22.17.0-1nodesource1 1001
             22.16.0-1nodesource1 1001
             22.15.1-1nodesource1 1001
             22.15.0-1nodesource1 1001
             22.14.0-1nodesource1 1001
             22.13.1-1nodesource1 1001
             22.13.0-1nodesource1 1001
             22.12.0-1nodesource1 1001
             22.11.0-1nodesource1 1001
             22.10.0-1nodesource1 1001
             22.9.0-1nodesource1 1001
             22.8.0-1nodesource1 1001
             22.7.0-1nodesource1 1001
             22.6.0-1nodesource1 1001
             22.5.1-1nodesource1 1001
             22.5.0-1nodesource1 1001
             22.4.1-1nodesource1 1001
             22.4.0-1nodesource1 1001
             22.3.0-1nodesource1 1001
             22.2.0-1nodesource1 1001
             22.1.0-1nodesource1 1001
             22.0.0-1nodesource1 1001
             18.20.4+dfsg-1~deb12u1 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
                500 http://security.debian.org bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        iobroker            iobroker (version: 7.1.0, hostname: iobroker      , alive, uptime: 817)
        Core adapters versions
        js-controller:  7.1.0
        admin:          7.8.20
        javascript:     9.1.1
        nodejs modules from github:     1
        | +-- node-milight-promise@0.3.2 (git+ssh://git@github.com/Steiger04/node-milight-promise.git#f1089feac9b7990727adf2016891029436729d33)
        Adapter State
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
        + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
        + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.bydbatt.0                : bydbatt               : iobroker                                 -  enabled
          system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 - disabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
          system.adapter.device-watcher.0         : device-watcher        : iobroker                                 - disabled
          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
        + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
        + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
          system.adapter.energiefluss.0           : energiefluss          : iobroker                                 - disabled
          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
        + system.adapter.history.0                : history               : iobroker                                 -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.6                   : ical                  : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.klf200.0                 : klf200                : iobroker                                 -  enabled
        + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
        + system.adapter.lgtv.1                   : lgtv                  : iobroker                                 -  enabled
        + system.adapter.milight-smart-light.0    : milight-smart-light   : iobroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
        + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
          system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
          system.adapter.phantomjs.0              : phantomjs             : iobroker                                 - disabled
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          system.adapter.plenticore.0             : plenticore            : iobroker                                 -  enabled, port: 80
        + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
        + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
          system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
        + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
        + system.adapter.snmp.0                   : snmp                  : iobroker                                 -  enabled
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        + system.adapter.tr-064.2                 : tr-064                : iobroker                                 -  enabled
        + system.adapter.tr-064.3                 : tr-064                : iobroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
        + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
        + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
          system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 - disabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
          system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
          system.adapter.vis-jsontemplate.0       : vis-jsontemplate      : iobroker                                 -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
          system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
          system.adapter.webcal.0                 : webcal                : iobroker                                 - disabled
          system.adapter.wifilight.0              : wifilight             : iobroker                                 - disabled
        + system.adapter.wolf.0                   : wolf                  : iobroker                                 -  enabled, port: 12004, bind: 0.0.0.0
        + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.1.224:1053
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: beta
        Adapter    "admin"        : 7.8.20   , installed 7.8.20
        Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
        Adapter    "alias-manager": 2.1.0    , installed 2.1.0
        Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
        Adapter    "backitup"     : 3.3.14   , installed 3.3.14
        Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
        Adapter    "bydhvs"       : 1.5.4    , installed 1.5.4
        Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
        Adapter    "device-watcher": 2.15.5  , installed 2.15.5
        Adapter    "echarts"      : 3.1.0    , installed 3.1.0
        Adapter    "email"        : 2.0.4    , installed 2.0.4
        Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
        Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
        Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
        Adapter    "history"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
        Adapter    "ical"         : 1.19.7   , installed 1.19.7
        Adapter    "iot"          : 5.0.13   , installed 5.0.13
        Adapter    "javascript"   : 9.1.1    , installed 9.1.1
        Controller "js-controller": 7.1.0    , installed 7.1.0
        Adapter    "klf200"       : 1.3.5    , installed 1.3.5
        Adapter    "lgtv"         : 2.5.0    , installed 2.5.0
        Adapter    "milight-smart-light": 1.2.2, installed 1.2.1 [Updatable]
        Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
        Adapter    "nina"         : 0.0.26   , installed 0.0.26
        Adapter    "openweathermap": 1.4.0   , installed 1.4.0
        Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
        Adapter    "ping"         : 2.1.0    , installed 2.1.0
        Adapter    "plenticore"   : 2.3.1    , installed 2.3.1
        Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
        Adapter    "rssfeed"      : 4.0.3    , installed 4.0.3
        Adapter    "schoolfree"   : 1.1.14   , installed 1.1.14
        Adapter    "shelly"       : 10.6.1   , installed 10.6.1
        Adapter    "shuttercontrol": 2.0.12  , installed 2.0.12
        Adapter    "snmp"         : 3.4.0    , installed 3.4.0
        Adapter    "socketio"     : 7.0.8    , installed 7.0.8
        Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "trashschedule": 5.2.1    , installed 5.2.1
        Adapter    "tuya"         : 3.17.0   , installed 3.17.0
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "upnp"         : 1.1.5    , installed 1.1.5
        Adapter    "vis-2"        : 2.13.17  , installed 2.13.17
        Adapter    "vis-2-widgets-gauges": 2.0.2, installed 2.0.2
        Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
        Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.0
        Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
        Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
        Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
        Adapter    "vis-jsontemplate": 4.4.0 , installed 4.4.0
        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
        Adapter    "vw-connect"   : 0.7.16   , installed 0.7.16
        Adapter    "web"          : 8.0.0    , installed 8.0.0
        Adapter    "webcal"       : 1.4.0    , installed 1.4.0
        Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
        Adapter    "wolf"         : 1.7.0    , installed 1.7.0
        Adapter    "ws"           : 4.0.0    , installed 4.0.0
        Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
        Objects and States
        Objects:        24397
        States:         19450
        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:3 http://security.debian.org bookworm-security InRelease
        Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
        Reading package lists...
        Pending systemupdates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.1.23:2001       0.0.0.0:*               LISTEN      1001       80060195   791892/io.hm-rpc.0
        tcp        0      0 192.168.1.23:2010       0.0.0.0:*               LISTEN      1001       80058319   791926/io.hm-rpc.2
        tcp        0      0 192.168.1.23:9292       0.0.0.0:*               LISTEN      1001       80060828   791943/io.hm-rpc.3
        tcp        0      0 192.168.1.23:8701       0.0.0.0:*               LISTEN      1001       80058296   791909/io.hm-rpc.1
        tcp        0      0 0.0.0.0:12004           0.0.0.0:*               LISTEN      1001       80065627   792286/io.wolf.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       80058506   791678/iobroker.js-
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       80056860   791678/iobroker.js-
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       80063121   792207/io.sonoff.0
        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       80064517   792140/io.shelly.0
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       80065435   792319/io.mqtt.0
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       80066451   792337/io.shelly.1
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17677      357/master
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12055      1/init
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       80059725   791709/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       80072024   792656/io.web.0
        tcp6       0      0 :::4400                 :::*                    LISTEN      1001       80068155   792468/io.milight-s
        tcp6       0      0 :::20002                :::*                    LISTEN      1001       80071005   792683/io.web.1
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17678      357/master
        tcp6       0      0 :::111                  :::*                    LISTEN      0          12057      1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          17415      1/init
        udp        0      0 192.168.1.23:5353       0.0.0.0:*                           1001       80065601   792243/io.tr-064.2
        udp        0      0 192.168.1.23:5353       0.0.0.0:*                           1001       80064153   792222/io.tr-064.0
        udp        0      0 0.0.0.0:54833           0.0.0.0:*                           1001       80063962   792187/io.snmp.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12056      1/init
        udp        0      0 0.0.0.0:33427           0.0.0.0:*                           1001       80069640   792468/io.milight-s
        udp        0      0 0.0.0.0:50301           0.0.0.0:*                           1001       80063960   792187/io.snmp.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       80072321   792719/io.upnp.0
        udp        0      0 0.0.0.0:43038           0.0.0.0:*                           1001       80070984   792719/io.upnp.0
        udp6       0      0 :::111                  :::*                                0          12058      1/init
        2026-04-02 20:38:23.658  - error: plenticore.0 (793739) Cannot read properties of undefined (reading 'sky')
        2026-04-02 20:38:24.039  - error: host.iobroker Caught by controller[0]: (node:793739) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
        2026-04-02 20:38:24.039  - error: host.iobroker Caught by controller[0]: (Use `node --trace-deprecation ...` to show where the warning was created)
        2026-04-02 20:38:24.039  - info: host.iobroker instance system.adapter.plenticore.0 terminated with code 0 (NO_ERROR)
        2026-04-02 20:38:24.039  - info: host.iobroker Restart adapter system.adapter.plenticore.0 because enabled
        2026-04-02 20:38:54.742  - info: host.iobroker instance system.adapter.plenticore.0 in version "2.3.1" started with pid 794201
        2026-04-02 20:38:58.654  - error: plenticore.0 (794201) uncaught exception: Cannot read properties of undefined (reading 'sky')
        2026-04-02 20:38:58.656  - error: plenticore.0 (794201) TypeError: Cannot read properties of undefined (reading 'sky')
        2026-04-02 20:38:58.657  - error: plenticore.0 (794201) Cannot read properties of undefined (reading 'sky')
        2026-04-02 20:38:59.044  - error: host.iobroker Caught by controller[0]: (node:794201) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
        2026-04-02 20:38:59.044  - error: host.iobroker Caught by controller[0]: (Use `node --trace-deprecation ...` to show where the warning was created)
        2026-04-02 20:38:59.044  - info: host.iobroker instance system.adapter.plenticore.0 terminated with code 0 (NO_ERROR)
        2026-04-02 20:38:59.045  - info: host.iobroker Restart adapter system.adapter.plenticore.0 because enabled
        • amg_666A amg_666
          ```bash
          Script v.2026-01-31
          *** BASE SYSTEM ***
            Virtualization: lxc
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
                           RTC time: n/a
                    RTC in local TZ: no
          Andreas
          HOME=/home/Andreas
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:
          *** MEMORY ***
          Swap:           4.3G         20K        4.3G
          Total:           17G        4.3G         12G
                   4145 M used memory
                   7905 M free memory
                      0 M buffer memory
                    237 M swap cache
                   4096 M total swap
                      0 M used swap
                   4095 M free swap
          *** FILESYSTEM ***
          /var:
          445M    /var/
          316M    /var/cache
          314M    /var/cache/apt
          69M     /var/lib
          USB-Devices by-id:
          ⚠ HINT:
          tcp
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.7
          /usr/bin/npx            10.9.7
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.8.20
          javascript:     9.1.1
          Adapter State
          + instance is alive
          Objects and States
          Objects:        24397
          States:         19450
          @amg_666
          Stell das mal auf plenticore-g3 um. Der ist wohl aktueller.
            @amg_666
            amg_666A Offline
            amg_666A Offline
            amg_666
            Danke für den Hinweis, wusste nicht dass es da einen anderen/aktuelleren Adapter gibt. Werde ich mal testen.
            • amg_666A amg_666
              @mcm1957
              Schau doch mal, ob der https://github.com/pixcept/ioBroker.plenticore dann nicht aus dem Verkehr gezogen werden muss.
              Edit: Du bist ja schon dran, hab ich erst gerade gesehen:
              https://github.com/pixcept/ioBroker.plenticore/issues/145
              Du redest aber wohl mit der Wand...
              https://github.com/pixcept/ioBroker.plenticore/issues/118
              • amg_666A Offline
                amg_666A Offline
                amg_666
                Der neue Adapter plenticore-g3 läuft gut, hab den alten jetzt deaktiviert
                • amg_666A amg_666
                  @amg_666
                  Ich würde den komplett rauswerfen. Irgendwann wird der dir sonst die Dependencies durcheinander würfeln.
                    @mcm1957
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    @mcm1957
                    Ist nicht ganz so einfach. Offenbar wird der alte plenticore für alte system noch gebraucht und funktioniert dort auch:
                    https://forum.iobroker.net/post/1332363
                    Muss schaun was da am wenigsten für User belastend ist.
                    Support Repositoryverwaltung.
                    LESEN - gute Forenbeitrage
