  4. IOB im Docker Startet nicht mehr!!!
    6.4k
85 Beiträge 9 Kommentatoren 4.5k Aufrufe 6 Beobachtet
  • H Happyuser20
    Iob Diag vom Master
    ```bash
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Hardware Vendor : Synology
    Kernel          : x86_64
    Userland        : 64 bit
    Docker          : v11.1.0
    Virtualization  : docker
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     06:20:57 up 1 day, 13:20,  0 user,  load average: 3.64, 2.94, 2.43
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** TIME AND TIMEZONES ***
    Thu Mar 26 05:20:57 UTC 2026
    Thu Mar 26 06:20:57 CET 2026
    CET +0100
    Etc/UTC
    *** Users and Groups ***
    User that called 'iob diag':
    root
    HOME=/root
    GROUPS=root
    iobroker
    HOME=/opt/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    System has not been booted with systemd as init system (PID 1). Can't operate.
    Failed to connect to bus: Host is down
    Display-Manager:
    Desktop:
    Session:
    *** MEMORY ***
    Mem:             16G        5.1G        388M        179M         11G         11G
    Swap:           2.1G          0B        2.1G
    Total:           18G        5.1G        2.5G
    Active iob-Instances:   35
            15854 M total memory
             4842 M used memory
             7501 M active memory
             6739 M inactive memory
              370 M free memory
              863 M buffer memory
            10276 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    top - 06:20:57 up 1 day, 13:20,  0 user,  load average: 3.75, 2.97, 2.44
    Tasks:  42 total,   3 running,  39 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 50.0 us, 50.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  15854.1 total,    368.3 free,   4844.0 used,  11140.3 buff/cache
    MiB Swap:   2047.9 total,   2047.9 free,      0.0 used.  11010.1 avail Mem
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem     Type   Size  Used Avail Use% Mounted on
    none           aufs   3.6T  2.9T  734G  80% /
    tmpfs          tmpfs   64M     0   64M   0% /dev
    tmpfs          tmpfs  7.8G     0  7.8G   0% /sys/fs/cgroup
    shm            tmpfs   64M     0   64M   0% /dev/shm
    /dev/md2       ext4   3.6T  2.9T  734G  80% /opt/iobroker
    tmpfs          tmpfs  7.8G     0  7.8G   0% /proc/acpi
    tmpfs          tmpfs  7.8G     0  7.8G   0% /proc/scsi
    tmpfs          tmpfs  7.8G     0  7.8G   0% /sys/firmware
    [Tue Mar 24 17:01:21 2026] EXT4-fs (md0): mounting ext3 file system using the ext4 subsystem
    [Tue Mar 24 17:01:21 2026] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Tue Mar 24 17:01:21 2026] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
    [Tue Mar 24 17:01:28 2026] EXT4-fs (md0): mounting ext3 file system using the ext4 subsystem
    [Tue Mar 24 17:01:28 2026] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Tue Mar 24 17:01:29 2026] EXT4-fs (md0): mounting ext3 file system using the ext4 subsystem
    [Tue Mar 24 17:01:29 2026] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
    [Tue Mar 24 17:03:17 2026] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
    [Tue Mar 24 17:03:17 2026] EXT4-fs (md2): barriers disabled
    [Tue Mar 24 17:03:17 2026] EXT4-fs (md2): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl
    Show mounted filesystems:
    TARGET                                       SOURCE        FSTYPE OPTIONS
    /                                            none        aufs   rw,relatime,si=6168b05b7ad59782,dio,dirperm1
    |-/opt/iobroker                              /dev/md2[/@docker/volumes/f05afd1c2039f3f2420d44f864ea945a0032f09b91fd90766c6545cad187ae09/_data]          ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    |-/etc/resolv.conf                           /dev/md2[/@docker/containers/66b2fc691407fa63e000f8a76629f87539d2b564d91a2f746448b266709f57cf/resolv.conf] ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    |-/etc/hostname                              /dev/md2[/@docker/containers/66b2fc691407fa63e000f8a76629f87539d2b564d91a2f746448b266709f57cf/hostname]    ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    |-/etc/hosts                                 /dev/md2[/@docker/containers/66b2fc691407fa63e000f8a76629f87539d2b564d91a2f746448b266709f57cf/hosts]       ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    `-/volume1/docker/iobroker-data/opt/iobroker /dev/md2[/@docker/volumes/a065460fbdc6ce960ee3964c7901ac7fd163df98ea13d22185e2facd74a473aa/_data]          ext4   rw,nodev,relatime,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    /var:
    16M     /var/
    14M     /var/lib/dpkg
    14M     /var/lib
    13M     /var/lib/dpkg/info
    1.9M    /var/cache
    /opt/iobroker/backups:
    99M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    606M    /opt/iobroker/iobroker-data/
    499M    /opt/iobroker/iobroker-data/files
    71M     /opt/iobroker/iobroker-data/files/vis
    67M     /opt/iobroker/iobroker-data/files/echarts.admin
    63M     /opt/iobroker/iobroker-data/files/vis/widgets
    38M     /opt/iobroker/iobroker-data/objects.jsonl
    29M     /opt/iobroker/iobroker-data/states.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.1
    /usr/bin/node           v22.22.1
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.1-1nodesource1
      Candidate: 22.22.1-1nodesource1
      Version table:
     *** 22.22.1-1nodesource1 100
            100 /var/lib/dpkg/status
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    OldNo7NAS           OldNo7NAS (version: 7.0.7, hostname: OldNo7NAS     , alive, uptime: 51683)
    SlaveIOBroker       SlaveIOBroker (version: 7.0.7, hostname: SlaveIOBroker , alive, uptime: 35409)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     8
    +-- iobroker.bambulab@0.3.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#fd28f98d7ec46f36f4a2dae2d9ac740966453704)
    +-- iobroker.esphome@0.5.0-beta.10 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#8ca51cd0460c21c1a817acc18c774da1fcf4f5ff)
    +-- iobroker.fronius-solarweb@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.fronius-solarweb.git#ca2f1a4972992cbd0d14bb25f5f7546219dd5b9e)
    +-- iobroker.linkeddevices@1.5.5 (git+ssh://git@github.com/Scrounger/ioBroker.linkeddevices.git#b70f9d21eff8412656b053f93ddab42211900fdb)
    +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19)
    +-- iobroker.spritmonitor@0.0.2-beta.10 (git+ssh://git@github.com/ice987987/ioBroker.spritmonitor.git#4059f9e2e3019b0a025fd7af850c259a84a797de)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
    Adapter State
    + system.adapter.admin.0                  : admin                 : OldNo7NAS                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : OldNo7NAS                                -  enabled
    + system.adapter.backitup.0               : backitup              : OldNo7NAS                                -  enabled
      system.adapter.bambulab.0               : bambulab              : OldNo7NAS                                - disabled, port: 8883
      system.adapter.birthdays.0              : birthdays             : OldNo7NAS                                - disabled
    + system.adapter.device-reminder.0        : device-reminder       : OldNo7NAS                                -  enabled
      system.adapter.devices.0                : devices               : OldNo7NAS                                - disabled
    + system.adapter.discovery.0              : discovery             : OldNo7NAS                                -  enabled
    + system.adapter.ds18b20.0                : ds18b20               : SlaveIOBroker                            -  enabled
      system.adapter.dwd.0                    : dwd                   : OldNo7NAS                                -  enabled
      system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: OldNo7NAS                                - disabled
    + system.adapter.energiefluss.0           : energiefluss          : OldNo7NAS                                -  enabled
      system.adapter.esphome.0                : esphome               : OldNo7NAS                                - disabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : OldNo7NAS                                -  enabled
    + system.adapter.fronius-solarweb.0       : fronius-solarweb      : OldNo7NAS                                -  enabled
    + system.adapter.fronius.0                : fronius               : OldNo7NAS                                -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : OldNo7NAS                                -  enabled
    + system.adapter.hass.0                   : hass                  : OldNo7NAS                                -  enabled, port: 8123
      system.adapter.heizoel.0                : heizoel               : OldNo7NAS                                - disabled
    + system.adapter.history.0                : history               : OldNo7NAS                                -  enabled
    + system.adapter.hmip.0                   : hmip                  : OldNo7NAS                                -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : OldNo7NAS                                -  enabled
      system.adapter.ical.0                   : ical                  : OldNo7NAS                                -  enabled
      system.adapter.ical.1                   : ical                  : OldNo7NAS                                - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : OldNo7NAS                                - disabled
      system.adapter.influxdb.0               : influxdb              : OldNo7NAS                                - disabled, port: 8086
    + system.adapter.iot.0                    : iot                   : OldNo7NAS                                -  enabled
    + system.adapter.javascript.0             : javascript            : OldNo7NAS                                -  enabled
    + system.adapter.linkeddevices.0          : linkeddevices         : OldNo7NAS                                -  enabled
      system.adapter.modbus.0                 : modbus                : OldNo7NAS                                - disabled
    + system.adapter.mqtt.0                   : mqtt                  : OldNo7NAS                                -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.pvforecast.0             : pvforecast            : OldNo7NAS                                -  enabled
      system.adapter.reolink.0                : reolink               : OldNo7NAS                                - disabled
      system.adapter.sayit.0                  : sayit                 : OldNo7NAS                                - disabled
    + system.adapter.shelly.0                 : shelly                : OldNo7NAS                                -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : OldNo7NAS                                -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : OldNo7NAS                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartgarden.0            : smartgarden           : OldNo7NAS                                -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : OldNo7NAS                                -  enabled
    + system.adapter.snmp.0                   : snmp                  : OldNo7NAS                                -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : OldNo7NAS                                -  enabled
      system.adapter.spritmonitor.0           : spritmonitor          : OldNo7NAS                                - disabled
    + system.adapter.synology.0               : synology              : OldNo7NAS                                -  enabled, port: 5000
      system.adapter.tankerkoenig.0           : tankerkoenig          : OldNo7NAS                                - disabled
      system.adapter.text2command.0           : text2command          : OldNo7NAS                                - disabled
    + system.adapter.tr-064.0                 : tr-064                : OldNo7NAS                                -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : OldNo7NAS                                -  enabled
      system.adapter.trashschedule.1          : trashschedule         : OldNo7NAS                                - disabled
      system.adapter.tuya.0                   : tuya                  : OldNo7NAS                                - disabled
    + system.adapter.upnp.0                   : upnp                  : OldNo7NAS                                -  enabled
      system.adapter.viessmann.0              : viessmann             : SlaveIOBroker                            - disabled, port: 3002
      system.adapter.vis-2.0                  : vis-2                 : OldNo7NAS                                - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : OldNo7NAS                                - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : OldNo7NAS                                - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : OldNo7NAS                                -  enabled
      system.adapter.vis-history.0            : vis-history           : OldNo7NAS                                - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : OldNo7NAS                                - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : OldNo7NAS                                - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : OldNo7NAS                                -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : OldNo7NAS                                - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : OldNo7NAS                                - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : OldNo7NAS                                - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : OldNo7NAS                                - disabled
      system.adapter.vis-metro.0              : vis-metro             : OldNo7NAS                                - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : OldNo7NAS                                - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : OldNo7NAS                                - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : OldNo7NAS                                - disabled
      system.adapter.vis.0                    : vis                   : OldNo7NAS                                -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : OldNo7NAS                                -  enabled
    + system.adapter.web.0                    : web                   : OldNo7NAS                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : OldNo7NAS                                - disabled
    + system.adapter.wled.0                   : wled                  : OldNo7NAS                                -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ ''                 │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    Upgrade policy: none
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "birthdays"    : 5.0.0    , installed 5.0.0
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
    Adapter    "fronius"      : 2.1.1    , installed 2.1.1
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "homeconnect"  : 1.5.2    , installed 1.5.2
    Adapter    "ical"         : 1.19.7   , installed 1.19.7
    Adapter    "iot"          : 5.0.7    , installed 5.0.7
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "modbus"       : 7.0.6    , installed 7.0.6
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
    Adapter    "pvforecast"   : 5.1.0    , installed 5.1.0
    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "shelly"       : 10.5.2   , installed 10.5.2
    Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "snmp"         : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "text2command" : 4.0.0    , installed 4.0.0
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter    "vis-icontwo"  : 2.11.1   , installed 2.11.1
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wled"         : 0.7.3    , installed 0.7.3
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Objects and States
    Objects:        29048
    States:         25926
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 1
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      0          47739      -
    tcp        0      0 0.0.0.0:662             0.0.0.0:*               LISTEN      0          26284      -
    tcp        0      0 0.0.0.0:7000            0.0.0.0:*               LISTEN      0          97364      -
    tcp        0      0 0.0.0.0:7000            0.0.0.0:*               LISTEN      0          97362      -
    tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      55         67950      -
    tcp        0      0 127.0.0.1:33304         0.0.0.0:*               LISTEN      0          32433      -
    tcp        0      0 0.0.0.0:88              0.0.0.0:*               LISTEN      0          26824      -
    tcp        0      0 0.0.0.0:8889            0.0.0.0:*               LISTEN      0          108212     -
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       7080753    -
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       7088043    -
    tcp        0      0 0.0.0.0:8123            0.0.0.0:*               LISTEN      0          109355     -
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          39082      -
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          39074      -
    tcp        0      0 0.0.0.0:892             0.0.0.0:*               LISTEN      0          25522      -
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          49096      -
    tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN      0          117657     -
    tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          48553      -
    tcp        0      0 0.0.0.0:161             0.0.0.0:*               LISTEN      0          38143      -
    tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN      0          189966     -
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       7075212    -
    tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          39076      -
    tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          39068      -
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       7075879    -
    tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          39078      -
    tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          39070      -
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          49097      -
    tcp        0      0 0.0.0.0:4045            0.0.0.0:*               LISTEN      0          48574      -
    tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          40681      -
    tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          40679      -
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          25035      -
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          39080      -
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          39072      -
    tcp        0      0 192.168.1.111:50001     0.0.0.0:*               LISTEN      0          84183      -
    tcp        0      0 192.168.1.111:50002     0.0.0.0:*               LISTEN      0          84869      -
    tcp6       0      0 :::21                   :::*                    LISTEN      0          47740      -
    tcp6       0      0 :::8086                 :::*                    LISTEN      1000       128083     -
    tcp6       0      0 :::662                  :::*                    LISTEN      0          26288      -
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       7090869    -
    tcp6       0      0 :::7000                 :::*                    LISTEN      0          97365      -
    tcp6       0      0 :::7000                 :::*                    LISTEN      0          97363      -
    tcp6       0      0 :::88                   :::*                    LISTEN      0          26826      -
    tcp6       0      0 :::8889                 :::*                    LISTEN      0          108217     -
    tcp6       0      0 :::8123                 :::*                    LISTEN      0          108186     -
    tcp6       0      0 :::443                  :::*                    LISTEN      0          39083      -
    tcp6       0      0 :::443                  :::*                    LISTEN      0          39075      -
    tcp6       0      0 :::892                  :::*                    LISTEN      0          25528      -
    tcp6       0      0 :::445                  :::*                    LISTEN      0          49094      -
    tcp6       0      0 :::3261                 :::*                    LISTEN      0          44566      -
    tcp6       0      0 :::5566                 :::*                    LISTEN      0          73053      -
    tcp6       0      0 :::3263                 :::*                    LISTEN      0          43877      -
    tcp6       0      0 :::3264                 :::*                    LISTEN      0          44568      -
    tcp6       0      0 127.0.0.1:9665          :::*                    LISTEN      195763     91735      -
    tcp6       0      0 :::2049                 :::*                    LISTEN      0          48564      -
    tcp6       0      0 :::3265                 :::*                    LISTEN      0          46101      -
    tcp6       0      0 :::161                  :::*                    LISTEN      0          38144      -
    tcp6       0      0 ::1:9666                :::*                    LISTEN      195763     118858     -
    tcp6       0      0 127.0.0.1:9666          :::*                    LISTEN      195763     118857     -
    tcp6       0      0 :::5000                 :::*                    LISTEN      0          39077      -
    tcp6       0      0 :::5000                 :::*                    LISTEN      0          39069      -
    tcp6       0      0 :::5001                 :::*                    LISTEN      0          39079      -
    tcp6       0      0 :::5001                 :::*                    LISTEN      0          39071      -
    tcp6       0      0 :::139                  :::*                    LISTEN      0          49095      -
    tcp6       0      0 :::53325                :::*                    LISTEN      195763     117237     -
    tcp6       0      0 :::4045                 :::*                    LISTEN      0          48576      -
    tcp6       0      0 :::5357                 :::*                    LISTEN      0          40682      -
    tcp6       0      0 :::5357                 :::*                    LISTEN      0          40680      -
    tcp6       0      0 :::111                  :::*                    LISTEN      0          25038      -
    tcp6       0      0 :::80                   :::*                    LISTEN      0          39081      -
    tcp6       0      0 :::80                   :::*                    LISTEN      0          39073      -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       7076481    -
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       7096300    -
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          24092      -
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          26012      -
    udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          14733345   -
    udp        0      0 192.168.1.111:137       0.0.0.0:*                           0          14733344   -
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          14732280   -
    udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          14733347   -
    udp        0      0 192.168.1.111:138       0.0.0.0:*                           0          14733346   -
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          14732281   -
    udp        0      0 0.0.0.0:161             0.0.0.0:*                           0          38141      -
    udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          26010      -
    udp        0      0 127.0.0.1:601           0.0.0.0:*                           0          26278      -
    udp        0      0 0.0.0.0:662             0.0.0.0:*                           0          26282      -
    udp        0      0 0.0.0.0:892             0.0.0.0:*                           0          25519      -
    udp        0      0 0.0.0.0:58638           0.0.0.0:*                           1000       7086796    -
    udp        0      0 0.0.0.0:58733           0.0.0.0:*                           0          14732463   -
    udp        0      0 0.0.0.0:9997            0.0.0.0:*                           0          24125      -
    udp        0      0 0.0.0.0:9998            0.0.0.0:*                           0          24124      -
    udp        0      0 0.0.0.0:9999            0.0.0.0:*                           0          24123      -
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       7096189    -
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       7096188    -
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          84186      -
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          39477      -
    udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          48563      -
    udp        0      0 127.0.0.1:60916         0.0.0.0:*                           0          84184      -
    udp        0      0 0.0.0.0:3702            0.0.0.0:*                           99         27789      -
    udp        0      0 0.0.0.0:4045            0.0.0.0:*                           0          48573      -
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       7093271    -
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          46415      -
    udp        0      0 0.0.0.0:46641           0.0.0.0:*                           0          46417      -
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       7087882    -
    udp        0      0 0.0.0.0:63295           0.0.0.0:*                           0          25034      -
    udp        0      0 192.168.1.111:55900     0.0.0.0:*                           0          84185      -
    udp6       0      0 :::111                  :::*                                0          25036      -
    udp6       0      0 :::123                  :::*                                0          26013      -
    udp6       0      0 :::161                  :::*                                0          38142      -
    udp6       0      0 ::1:323                 :::*                                0          26011      -
    udp6       0      0 :::662                  :::*                                0          26286      -
    udp6       0      0 :::892                  :::*                                0          25525      -
    udp6       0      0 :::2049                 :::*                                0          48565      -
    udp6       0      0 :::3702                 :::*                                99         27791      -
    udp6       0      0 :::61372                :::*                                0          25037      -
    udp6       0      0 :::4045                 :::*                                0          48575      -
    udp6       0      0 :::45044                :::*                                0          46418      -
    udp6       0      0 :::5353                 :::*                                0          46416      -
    2026-03-26 06:21:58.542  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.info.label:{"val":"Bewegungsmelder - Wohnzimmer","ack":true,"ts":1774502518352,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580899778}
    2026-03-26 06:21:58.544  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.info.firmwareVersion:{"val":"3.2.48","ack":true,"ts":1774502518352,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675692922298}
    2026-03-26 06:21:58.544  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.info.updateState:{"val":"UP_TO_DATE","ack":true,"ts":1774502518353,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675692922298}
    2026-03-26 06:21:58.547  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.functionalChannelType:{"val":"DEVICE_SABOTAGE","ack":true,"ts":1774502518353,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580865126}
    2026-03-26 06:21:58.547  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.configPending:{"val":false,"ack":true,"ts":1774502518353,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1677685762380}
    2026-03-26 06:21:58.565  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.dutyCycle:{"val":false,"ack":true,"ts":1774502518353,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1774332279481}
    2026-03-26 06:21:58.573  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.lowBat:{"val":false,"ack":true,"ts":1774502518365,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1774332279481}
    2026-03-26 06:21:58.581  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.routerModuleEnabled:{"val":false,"ack":true,"ts":1774502518365,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580865126}
    2026-03-26 06:21:58.581  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.routerModuleSupported:{"val":false,"ack":true,"ts":1774502518365,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580865126}
    2026-03-26 06:21:58.581  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.rssiDeviceValue:{"val":-66,"ack":true,"ts":1774502518365,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1774502340738}
    2026-03-26 06:21:58.581  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.rssiPeerValue:{"val":null,"ack":true,"ts":1774502518365,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580865129}
    2026-03-26 06:21:58.581  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.unreach:{"val":false,"ack":true,"ts":1774502518366,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1774332279482}
    2026-03-26 06:21:58.581  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.0.sabotage:{"val":false,"ack":true,"ts":1774502518366,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1774332389693}
    2026-03-26 06:21:58.588  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.1.functionalChannelType:{"val":"MOTION_DETECTION_CHANNEL","ack":true,"ts":1774502518366,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580865129}
    2026-03-26 06:21:58.595  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.1.motionDetected:{"val":true,"ack":true,"ts":1774502518366,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1774502487756}
    2026-03-26 06:21:58.595  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.1.illumination:{"val":0.97,"ack":true,"ts":1774502518366,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1774502146009}
    2026-03-26 06:21:58.595  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.1.currentIllumination:{"val":null,"ack":true,"ts":1774502518366,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580865129}
    2026-03-26 06:21:58.603  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.1.motionDetectionSendInterval:{"val":"SECONDS_30","ack":true,"ts":1774502518366,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1676438900733}
    2026-03-26 06:21:58.603  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.1.motionBufferActive:{"val":false,"ack":true,"ts":1774502518367,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1677685760800}
    2026-03-26 06:21:58.611  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A000091D89A25024.channels.1.numberOfBrightnessMeasurements:{"val":1,"ack":true,"ts":1774502518367,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675600928761}
    2026-03-26 06:21:58.612  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.groups.fe32a10b-4c65-47a4-819a-fc6ca7d5350b.info.type:{"val":"SWITCHING","ack":true,"ts":1774502518367,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580927555}
    2026-03-26 06:21:58.612  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.groups.fe32a10b-4c65-47a4-819a-fc6ca7d5350b.info.label:{"val":"Bewegungsmelder Wohnzimmer","ack":true,"ts":1774502518367,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580927556}
    2026-03-26 06:21:58.612  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.groups.fe32a10b-4c65-47a4-819a-fc6ca7d5350b.on:{"val":null,"ack":true,"ts":1774502518369,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580927556}
    2026-03-26 06:21:58.618  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.groups.303a65f8-dedc-40ef-83a0-9ab477437fd5.info.type:{"val":"META","ack":true,"ts":1774502518370,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580902315}
    2026-03-26 06:21:58.620  - silly: hmip.0 (445) States user redis pmessage hmip.0.*/hmip.0.groups.303a65f8-dedc-40ef-83a0-9ab477437fd5.info.label:{"val":"Bewegungsmelder Wohnzimmer","ack":true,"ts":1774502518371,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1675580902315}
    iob diag has finished.
    Beim Slave
    pi@SlaveIOBroker:~ $ iob diag
    /usr/bin/iob: line 21: /home/iobroker/iob_diag.log: Permission denied
    Da passt wohl was nicht den Rechten!?!
    #81
    @Happyuser20
    Führ den
    iob fix
    aus.
    Und stell das logging auf was gescheites ein, silly ist halt 'silly'.
    H 1 Antwort Letzte Antwort
      @Happyuser20
      Führ den
      iob fix
      aus.
      Happyuser20
      schrieb am zuletzt editiert von Happyuser20
      #82
      @Thomas-Braun sagte in IOB im Docker Startet nicht mehr!!!:
      @Happyuser20
      Führ den
      iob fix
      aus.
      Auf dem Master oder Slave?
      • H Happyuser20
        @Happyuser20
        Führ den
        iob fix
        aus.
        #83
        @Happyuser20
        Den
        iob fix
        auf dem Pi, da fehlen dir ja die Rechte.
        Soweit ich weiß sagt dir aber auch der ioBroker-Installer am Ende, das nach einem Neustart des Rechners zum Abschluss der Installation ein 'iob fix' gemacht werden soll. Aus genau diesem Grund mit den noch nicht richtig gesetzten Rechten.
        Das Loglevel ist (mindestens) bei hmip.0 auf silly.
        • H Offline
          Happyuser20
          #84
          iob diag am Master Container
          ```bash
          Script v.2026-01-31
          *** BASE SYSTEM ***
          Kernel          : x86_64
          Userland        : 64 bit
          Docker          : v11.1.0
          Kernel          : x86_64
          Userland        : 64 bit
           12:49:01 up 1 day, 19:48,  0 user,  load average: 4.25, 2.94, 2.08
          CPU threads: 2
          Thu Mar 26 11:49:01 UTC 2026
          Thu Mar 26 12:49:01 CET 2026
          CET +0100
          Etc/UTC
          root
          HOME=/root
          GROUPS=root
          iobroker
          HOME=/opt/iobroker
          Display-Manager:
          Desktop:
          Session:
          *** MEMORY ***
          Mem:             16G        5.0G        1.0G        178M         11G         11G
          Swap:           2.1G         16K        2.1G
          Total:           18G        5.0G        3.2G
          Active iob-Instances:   36
                   4765 M used memory
                   7270 M active memory
                   6337 M inactive memory
                    996 M free memory
                    866 M buffer memory
                   9724 M swap cache
                   2047 M total swap
                      0 M used swap
                   2047 M free swap
          top - 12:49:02 up 1 day, 19:48,  0 user,  load average: 4.25, 2.94, 2.08
          Tasks:  47 total,   2 running,  45 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  15854.1 total,    994.9 free,   4767.1 used,  10590.6 buff/cache
          MiB Swap:   2047.9 total,   2047.9 free,      0.0 used.  11087.0 avail Mem
          *** FILESYSTEM ***
          /                                            none        aufs   rw,relatime,si=6168b05d95d12782,dio,dirperm1
          /var:
          35M     /var/
          33M     /var/lib
          19M     /var/lib/apt/lists
          19M     /var/lib/apt
          14M     /var/lib/dpkg
          605M    /opt/iobroker/iobroker-data/
          40M     /opt/iobroker/iobroker-data/objects.jsonl
          24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
          USB-Devices by-id:
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          nodejs:
            Candidate: 22.22.2-1nodesource1
            Version table:
               22.22.2-1nodesource1 1001
                  500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
           *** 22.22.1-1nodesource1 1001
               22.22.0-1nodesource1 1001
               22.21.0-1nodesource1 1001
               22.20.0-1nodesource1 1001
               22.19.0-1nodesource1 1001
               22.18.0-1nodesource1 1001
               22.17.1-1nodesource1 1001
               22.17.0-1nodesource1 1001
               22.16.0-1nodesource1 1001
               22.15.1-1nodesource1 1001
               22.15.0-1nodesource1 1001
               22.14.0-1nodesource1 1001
               22.13.1-1nodesource1 1001
               22.13.0-1nodesource1 1001
               22.12.0-1nodesource1 1001
               22.11.0-1nodesource1 1001
               22.10.0-1nodesource1 1001
               22.9.0-1nodesource1 1001
               22.8.0-1nodesource1 1001
               22.7.0-1nodesource1 1001
               22.6.0-1nodesource1 1001
               22.5.1-1nodesource1 1001
               22.5.0-1nodesource1 1001
               22.4.1-1nodesource1 1001
               22.4.0-1nodesource1 1001
               22.3.0-1nodesource1 1001
               22.2.0-1nodesource1 1001
               22.1.0-1nodesource1 1001
               22.0.0-1nodesource1 1001
               18.20.4+dfsg-1~deb12u1 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
                  500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          OldNo7NAS           OldNo7NAS (version: 7.0.7, hostname: OldNo7NAS     , alive, uptime: 14117)
          SlaveIOBroker       SlaveIOBroker (version: 7.0.7, hostname: SlaveIOBroker , alive, uptime: 3334)
          admin:          7.7.22
          javascript:     9.0.18
          Adapter State
            system.adapter.ds18b20.0                : ds18b20               : SlaveIOBroker                            - disabled
          + system.adapter.heizoel.0                : heizoel               : OldNo7NAS                                -  enabled
          + system.adapter.modbus.0                 : modbus                : OldNo7NAS                                -  enabled
          + instance is alive
          Objects and States
          Objects:        29035
          States:         25923
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       20831573   -
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       20831999   -
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       18733144   -
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       18733086   -
          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       20832542   -
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       20816965   -
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       20831995   -
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       20831916   -
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       20831915   -
          udp        0      0 0.0.0.0:53102           0.0.0.0:*                           1000       20833611   -
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       20831240   -
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       20831894   -
          2026-03-26 12:44:38.449  - info: homeconnect.0 (13632) Found 1 devices
          2026-03-26 12:44:42.189  - info: homeconnect.0 (13632) 014080394092003265/programs/active: There is no program active.
          2026-03-26 12:44:42.204  - info: homeconnect.0 (13632) No array: active
          2026-03-26 12:44:42.827  - info: homeconnect.0 (13632) 014080394092003265/programs/active/options: There is no program active.
          2026-03-26 12:44:47.872  - info: homeconnect.0 (13632) No array: selected
          2026-03-26 12:44:51.351  - warn: modbus.0 (11342) On error: {}
          2026-03-26 12:44:52.352  - warn: modbus.0 (11342) On error: {}
          2026-03-26 12:45:48.120  - info: host.OldNo7NAS instance system.adapter.dwd.0 in version "2.8.5" started with pid 13737
          2026-03-26 12:45:52.353  - warn: modbus.0 (11342) On error: {}
          2026-03-26 12:45:53.307  - info: dwd.0 (13737) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.1, js-controller: 7.0.7
          2026-03-26 12:45:53.355  - warn: modbus.0 (11342) On error: {}
          2026-03-26 12:45:53.914  - info: dwd.0 (13737) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2026-03-26 12:45:54.531  - info: host.OldNo7NAS instance system.adapter.dwd.0 having pid 13737 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2026-03-26 12:46:53.358  - warn: modbus.0 (11342) On error: {}
          2026-03-26 12:46:54.359  - warn: modbus.0 (11342) On error: {}
          2026-03-26 12:47:54.360  - warn: modbus.0 (11342) On error: {}
          2026-03-26 12:47:55.362  - warn: modbus.0 (11342) On error: {}
          2026-03-26 12:48:51.969  - info: web.0 (11195) <== Disconnect system.user.admin from ::ffff:192.168.1.66 energiefluss.0
          2026-03-26 12:48:51.984  - info: web.0 (11195) <== Disconnect system.user.admin from ::ffff:192.168.1.66 vis.0
          2026-03-26 12:48:55.363  - warn: modbus.0 (11342) On error: {}
          2026-03-26 12:48:56.364  - warn: modbus.0 (11342) On error: {}
          2026-03-26 12:49:00.616  - info: web.0 (11195) ==> Connected system.user.admin from ::ffff:192.168.1.66
          2026-03-26 12:49:03.650  - info: web.0 (11195) ==> Connected system.user.admin from ::ffff:192.168.1.66
          2026-03-26 12:49:56.368  - warn: modbus.0 (11342) On error: {}
          2026-03-26 12:49:57.369  - warn: modbus.0 (11342) On error: {}
          • H Offline
            Happyuser20
            #85
            iob diag am Slave Pi
            bash
            Script v.2026-01-31
            *** BASE SYSTEM ***
            Operating System: Debian GNU/Linux 13 (trixie)
             Static hostname: SlaveIOBroker
                   Icon name: computer
                      Kernel: Linux 6.12.75+rpt-rpi-v8
                Architecture: arm64
            OS is similar to:
            Model           : Raspberry Pi 3 Model B Plus Rev 1.3
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 64 bit
             12:49:23 up 16:18,  1 user,  load average: 0.34, 0.15, 0.05
            CPU threads: 4
            Operating System is the current Debian stable version codenamed 'trixie'!
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
                           Local time: Thu 2026-03-26 12:49:23 CET
                       Universal time: Thu 2026-03-26 11:49:23 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
            iobroker
            HOME=/home/iobroker
            SUDO_HOME=/home/pi
            Unit display-manager.service could not be found.
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Mem:            949M        263M        157M        7.2M        603M        686M
            Swap:           948M          0B        948M
            Total:          1.9G        263M        1.1G
                      905 M total memory
                      251 M used memory
                      295 M active memory
                      325 M inactive memory
                      149 M free memory
                       32 M buffer memory
                      543 M swap cache
                      904 M total swap
                        0 M used swap
                      904 M free swap
            top - 12:49:24 up 16:18,  1 user,  load average: 0.48, 0.18, 0.06
            Tasks: 155 total,   1 running, 154 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  1.9 us,  0.0 sy,  0.0 ni, 98.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :    906.0 total,    148.5 free,    252.5 used,    576.0 buff/cache
            MiB Swap:    905.0 total,    905.0 free,      0.0 used.    653.5 avail Mem
            *** FAILED SERVICES ***
              UNIT             LOAD   ACTIVE SUB    DESCRIPTION
            * vcontrol.service loaded failed failed Viessmann heating systems interface
            Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                    ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                    SUB    -> The low-level unit activation state, values depend on unit type.
            1 loaded units listed.
            *** FILESYSTEM ***
            udev           devtmpfs  319M     0  319M   0% /dev
            tmpfs          tmpfs     182M  4.1M  178M   3% /run
            /dev/mmcblk0p2 ext4       15G  4.5G  9.1G  33% /
            tmpfs          tmpfs     453M     0  453M   0% /dev/shm
            tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
            tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
            tmpfs          tmpfs     453M  2.8M  451M   1% /tmp
            /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
            tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
            tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
            tmpfs          tmpfs      91M  8.0K   91M   1% /run/user/1000
            [Wed Mar 25 20:30:41 2026] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
            [Wed Mar 25 20:30:41 2026] EXT4-fs (mmcblk0p2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mo        de: none.
            [Wed Mar 25 20:30:46 2026] EXT4-fs (mmcblk0p2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
            /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
            `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            1.3G    /var/
            234M    /var/cache
            229M    /var/cache/apt
            182M    /var/lib
            146M    /var/lib/apt
            Archived and active journals take up 2.9M in the file system.
            4.0K    /opt/iobroker/backups/
            111M    /opt/iobroker/iobroker-data/
            64M     /opt/iobroker/iobroker-data/files
            47M     /opt/iobroker/iobroker-data/files/admin.admin
            46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
            17M     /opt/iobroker/iobroker-data/objects.jsonl
            8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
            5.1M    /opt/iobroker/iobroker-data/states.jsonl
            3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-NCiLc44Q.js
            3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
            USB-Devices by-id:
            /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0
            /usr/bin/npm            10.9.4
            /usr/bin/npx            10.9.4
            nodejs:
              Version table:
                    500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                 20.19.2+dfsg-1+deb13u1 500
                    500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
                 20.19.2+dfsg-1 500
                    500 http://deb.debian.org/debian trixie/main arm64 Packages
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            OldNo7NAS           OldNo7NAS (version: 7.0.7, hostname: OldNo7NAS     , alive, uptime: 14147)
            SlaveIOBroker       SlaveIOBroker (version: 7.0.7, hostname: SlaveIOBroker , alive, uptime: 3349)
            admin:          7.7.22
            javascript:     "javascript" not found
            nodejs modules from github:     0
            Adapter State
            + instance is alive
            Adapter    "ds18b20"      : 3.1.1    , installed 3.1.1
            Adapter    "viessmann"    : 1.7.3    , installed 1.7.3
            Objects and States
            Objects:        29035
            States:         25923
            Hit:1 http://deb.debian.org/debian trixie InRelease
            Hit:2 http://deb.debian.org/debian trixie-updates InRelease
            Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
            Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
            Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8348       1055/sshd: /usr/sbi
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4404       1/init
            tcp6       0      0 :::22                   :::*                    LISTEN      0          8350       1055/sshd: /usr/sbi
            tcp6       0      0 :::111                  :::*                    LISTEN      0          180        1/init
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2464       1/init
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        5939       579/avahi-daemon: r
            udp        0      0 0.0.0.0:53519           0.0.0.0:*                           101        5941       579/avahi-daemon: r
            udp6       0      0 :::50076                :::*                                101        5942       579/avahi-daemon: r
            udp6       0      0 fe80::ba27:ebff:fea:546 :::*                                0          7350       613/NetworkManager
            udp6       0      0 :::111                  :::*                                0          4405       1/init
            udp6       0      0 :::5353                 :::*                                101        5940       579/avahi-daemon: r
            2026-03-26 11:52:34.346  - info: ds18b20.0 (2600) terminating
            2026-03-26 11:52:34.350  - info: ds18b20.0 (2600) Terminated (NO_ERROR): Without reason
            2026-03-26 11:52:34.701  - info: ds18b20.0 (2600) terminating
            2026-03-26 11:52:35.231  - info: host.SlaveIOBroker instance system.adapter.ds18b20.0 terminated with code 0 (NO_ERROR)
            2026-03-26 11:52:35.232  - info: host.SlaveIOBroker All instances are stopped.
            2026-03-26 11:52:35.444  - info: host.SlaveIOBroker terminated
            2026-03-26 11:53:47.750  - info: host.SlaveIOBroker iobroker.js-controller version 7.0.7 js-controller starting
            2026-03-26 11:53:47.761  - info: host.SlaveIOBroker Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
            2026-03-26 11:53:47.764  - info: host.SlaveIOBroker hostname: SlaveIOBroker, node: v22.22.1
            2026-03-26 11:53:47.766  - info: host.SlaveIOBroker ip addresses: 192.168.1.22 fd98:18cd:baca:0:ba27:ebff:feaf:cbe4 2003:db:6f07:b000:ba27:        ebff:feaf:cbe4 fe80::ba27:ebff:feaf:cbe4
            2026-03-26 11:53:48.774  - info: host.SlaveIOBroker connected to Objects and States
            2026-03-26 11:53:48.828  - info: host.SlaveIOBroker added notifications configuration of host
            2026-03-26 11:53:50.313  - info: host.SlaveIOBroker 72 instances found
            2026-03-26 11:53:50.369  - info: host.SlaveIOBroker starting 1 instance
            2026-03-26 11:53:53.488  - info: host.SlaveIOBroker instance system.adapter.ds18b20.0 in version "3.1.1" started with pid 3856
            2026-03-26 11:53:59.207  - info: ds18b20.0 (3856) starting. Version 3.1.1 in /opt/iobroker/node_modules/iobroker.ds18b20, node: v22.22.1, j        s-controller: 7.0.7
            2026-03-26 11:53:59.435  - warn: ds18b20.0 (3856) No sensors configured or enabled!
            2026-03-26 11:56:11.029  - info: host.SlaveIOBroker "system.adapter.ds18b20.0" disabled
            2026-03-26 11:56:11.034  - info: host.SlaveIOBroker stopInstance system.adapter.ds18b20.0 (force=false, process=true)
            2026-03-26 11:56:11.189  - info: ds18b20.0 (3856) Got terminate signal TERMINATE_YOURSELF
            2026-03-26 11:56:11.218  - info: host.SlaveIOBroker stopInstance system.adapter.ds18b20.0 send kill signal
            2026-03-26 11:56:11.289  - info: ds18b20.0 (3856) terminating
            2026-03-26 11:56:11.292  - info: ds18b20.0 (3856) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2026-03-26 11:56:11.693  - info: ds18b20.0 (3856) terminating
            2026-03-26 11:56:12.378  - info: host.SlaveIOBroker instance system.adapter.ds18b20.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATIO        N)
            pi@SlaveIOBroker:~ $ ========== Start marking the full check here ===========
            bash
            Script v.2026-01-31
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            SUDO_HOME=/home/pi
            Display-Manager:
            Desktop:
            Session:                tty
