  4. Adapterinstallation Fehlermeldungen aber Code 0
    6.5k
28 Beiträge 3 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • G guitardoc
    Ahh, ich dachte, weil da oben was von Docker stand.
    Hmm, was kann ich denn nun machen?
    @guitardoc
    Was spuckt denn
    iob upgrade admin@7.7.19 --host iobroker --debug
    nun aus?
    G 1 Antwort Letzte Antwort
      @guitardoc
      Was spuckt denn
      nun aus?
      G Online
      G Online
      guitardoc
      @Thomas-Braun
      Would you like to reinstall version 7.7.19 of admin now? [(y)es, (n)o]: y
      Update admin from @7.7.19 to @7.7.19
      Uninstall npm packet "iobroker.admin" for a clean re-installation
      removed 69 packages in 2s
      260 packages are looking for funding
        run `npm fund` for details
      host.iobroker Adapter "system.adapter.admin.0" is stopped.
      NPM version: 10.9.4
      Installing iobroker.admin@7.7.19... (System call)
      > cpu-features@0.0.10 install
      > node buildcheck.js > buildcheck.gypi && node-gyp rebuild
      gyp info it worked if it ends with ok
      gyp info using node-gyp@8.4.1
      gyp info using node@22.21.0 | linux | x64
      (node:7310) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      (Use `node --trace-deprecation ...` to show where the warning was created)
      gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
      gyp info spawn /usr/bin/python3
      gyp info spawn args [
      gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
      gyp info spawn args   'binding.gyp',
      gyp info spawn args   '-f',
      gyp info spawn args   'make',
      gyp info spawn args   '-I',
      gyp info spawn args   '/opt/iobroker/node_modules/cpu-features/build/config.gypi',
      gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
      gyp info spawn args   '/home/iobroker/.cache/node-gyp/22.21.0/include/node/common.gypi',
      gyp info spawn args   '-Dlibrary=shared_library',
      gyp info spawn args   '-Dvisibility=default',
      gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.21.0',
      gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
      gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.21.0/<(target_arch)/node.lib',
      gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/cpu-features',
      gyp info spawn args   '-Dnode_engine=v8',
      gyp info spawn args   '--depth=.',
      gyp info spawn args   '--no-parallel',
      gyp info spawn args   '--generator-output',
      gyp info spawn args   'build',
      gyp info spawn args   '-Goutput_dir=.'
      gyp info spawn args ]
      Traceback (most recent call last):
        File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module>
          import gyp  # noqa: E402
        File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module>
          import gyp.input
        File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module>
          from distutils.version import StrictVersion
      ModuleNotFoundError: No module named 'distutils'
      gyp ERR! configure error
      gyp ERR! stack Error: `gyp` failed with exit code: 1
      gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)
      gyp ERR! stack     at ChildProcess.emit (node:events:519:28)
      gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:293:12)
      gyp ERR! System Linux 6.17.2-1-pve
      gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
      gyp ERR! node -v v22.21.0
      gyp ERR! node-gyp -v v8.4.1
      gyp ERR! not ok
      > ssh2@1.17.0 install
      > node install.js
      (node:7334) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
      gyp info spawn args   '/opt/iobroker/node_modules/ssh2/lib/protocol/crypto/build/config.gypi',
      gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/ssh2/lib/protocol/crypto',
          import gyp.input
      gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "--target=v22.21.0" "--real_openssl_major=3" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/ssh2/lib/protocol/crypto
      gyp ERR! not ok
      Failed to build optional crypto binding
      added 70 packages in 15s
      265 packages are looking for funding
      Updating objects from io-package.json for adapter "admin" with version "7.7.19"
      upload [172] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/README.md README.md text/markdown
      upload [150] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/Components-BGVs6Dmn.js custom/assets/Components-BGVs6Dmn.js application/javascript
      upload [100] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-B82Lauwj.js custom/assets/index-B82Lauwj.js application/javascript
      upload [90] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-C0FlO84Y.js custom/assets/index-C0FlO84Y.js application/javascript
      upload [80] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-CcDQHtwq.js custom/assets/index-CcDQHtwq.js application/javascript
      upload [70] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-DIVai5gZ.js custom/assets/index-DIVai5gZ.js application/javascript
      upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-G9F5mhbe.js custom/assets/index-G9F5mhbe.js application/javascript
      upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-eQxyhk2m.js custom/assets/index-eQxyhk2m.js application/javascript
      upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/jsx-runtime-DEOw6lrW.js custom/assets/jsx-runtime-DEOw6lrW.js application/javascript
      upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/virtualExposes-BufY-8i6.js custom/assets/virtualExposes-BufY-8i6.js application/javascript
      upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/es.json custom/i18n/es.json application/json
      upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
      upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
      upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json
      upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json
      upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de.json i18n/de.json application/json
      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en.json i18n/en.json application/json
      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es.json i18n/es.json application/json
      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr.json i18n/fr.json application/json
      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it.json i18n/it.json application/json
      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl.json i18n/nl.json application/json
      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl.json i18n/pl.json application/json
      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt.json i18n/pt.json application/json
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru.json i18n/ru.json application/json
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk.json i18n/uk.json application/json
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
      host.iobroker Adapter "system.adapter.admin.0" is started
      mn@iobroker:~$
      Hoffentlich hab ich alles beim Kopieren erwischt, hänge jetzt per iPhone über Tailscale an ssh. Das ist ne Fummelei…
      • G guitardoc
        @Thomas-Braun
        NPM version: 10.9.4
            import gyp.input
        gyp ERR! not ok
        > ssh2@1.17.0 install
        > node install.js
            import gyp.input
        gyp ERR! not ok
        mn@iobroker:~$
        @guitardoc
        Da klemmt irgendwas bei Python.
        apt policy python3-setuptools
        Und wenn das nicht installiert ist, nachinstallieren.
        • G Online
          G Online
          guitardoc
          mn@iobroker:~$ apt policy python3-setuptools
          python3-setuptools:
            Installed: (none)
            Candidate: 78.1.1-0.1
            Version table:
               78.1.1-0.1 500
                  500 http://deb.debian.org/debian trixie/main >
          lines 1-6/6 (END)
          Scheint was zu fehlen. Wie müsste man das nachinstallieren?
          • G guitardoc
            python3-setuptools:
              Installed: (none)
              Version table:
                 78.1.1-0.1 500
            lines 1-6/6 (END)
            @guitardoc
            Wie alle anderen Pakete auch...
            sudo apt install python3-setuptools
            • G Online
              G Online
              guitardoc
              Jetzt kommen bei Neuinstallation vom Admin erstmal keine Fehler. Adapter-Update teste ich nachher wenn ich wieder am richtigen Rechner bin. Vielen Dank erst mal bis hierher!
              • G guitardoc
                @guitardoc sagte in Adapterinstallation Fehlermeldungen aber Code 0:
                Das war das Ziel.
                • G Online
                  G Online
                  guitardoc
                  Die Adapterinstallation funktioniert auch problemlos und ohne Fehler. Vielen Dank noch mal für die schnelle Hilfe!
