  4. Adapterinstallation Fehlermeldungen aber Code 0
    6.5k
28 Beiträge 3 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • G guitardoc
    Bei mir läuft kein Docker, das System liegt auf einem Proxmox LXC und läuft auf einem headless Debian Trixie.
    @guitardoc sagte in Adapterinstallation Fehlermeldungen aber Code 0:
    Hier läuft auch kein Docker.
    • G Online
      G Online
      guitardoc
      Ahh, ich dachte, weil da oben was von Docker stand.
      Hmm, was kann ich denn nun machen?
      • G guitardoc
        @guitardoc
        Was spuckt denn
        iob upgrade admin@7.7.19 --host iobroker --debug
        nun aus?
        G 1 Antwort Letzte Antwort
          @guitardoc
          Was spuckt denn
          nun aus?
          G Online
          G Online
          guitardoc
          @Thomas-Braun
          Would you like to reinstall version 7.7.19 of admin now? [(y)es, (n)o]: y
          Update admin from @7.7.19 to @7.7.19
          Uninstall npm packet "iobroker.admin" for a clean re-installation
          removed 69 packages in 2s
          260 packages are looking for funding
            run `npm fund` for details
          host.iobroker Adapter "system.adapter.admin.0" is stopped.
          NPM version: 10.9.4
          Installing iobroker.admin@7.7.19... (System call)
          > cpu-features@0.0.10 install
          > node buildcheck.js > buildcheck.gypi && node-gyp rebuild
          gyp info it worked if it ends with ok
          gyp info using node-gyp@8.4.1
          gyp info using node@22.21.0 | linux | x64
          (node:7310) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
          (Use `node --trace-deprecation ...` to show where the warning was created)
          gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
          gyp info spawn /usr/bin/python3
          gyp info spawn args [
          gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
          gyp info spawn args   'binding.gyp',
          gyp info spawn args   '-f',
          gyp info spawn args   'make',
          gyp info spawn args   '-I',
          gyp info spawn args   '/opt/iobroker/node_modules/cpu-features/build/config.gypi',
          gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
          gyp info spawn args   '/home/iobroker/.cache/node-gyp/22.21.0/include/node/common.gypi',
          gyp info spawn args   '-Dlibrary=shared_library',
          gyp info spawn args   '-Dvisibility=default',
          gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.21.0',
          gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
          gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.21.0/<(target_arch)/node.lib',
          gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/cpu-features',
          gyp info spawn args   '-Dnode_engine=v8',
          gyp info spawn args   '--depth=.',
          gyp info spawn args   '--no-parallel',
          gyp info spawn args   '--generator-output',
          gyp info spawn args   'build',
          gyp info spawn args   '-Goutput_dir=.'
          gyp info spawn args ]
          Traceback (most recent call last):
            File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module>
              import gyp  # noqa: E402
            File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module>
              import gyp.input
            File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module>
              from distutils.version import StrictVersion
          ModuleNotFoundError: No module named 'distutils'
          gyp ERR! configure error
          gyp ERR! stack Error: `gyp` failed with exit code: 1
          gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)
          gyp ERR! stack     at ChildProcess.emit (node:events:519:28)
          gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:293:12)
          gyp ERR! System Linux 6.17.2-1-pve
          gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
          gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
          gyp ERR! node -v v22.21.0
          gyp ERR! node-gyp -v v8.4.1
          gyp ERR! not ok
          > ssh2@1.17.0 install
          > node install.js
          (node:7334) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
          gyp info spawn args   '/opt/iobroker/node_modules/ssh2/lib/protocol/crypto/build/config.gypi',
          gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/ssh2/lib/protocol/crypto',
              import gyp.input
          gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "--target=v22.21.0" "--real_openssl_major=3" "rebuild"
          gyp ERR! cwd /opt/iobroker/node_modules/ssh2/lib/protocol/crypto
          gyp ERR! not ok
          Failed to build optional crypto binding
          added 70 packages in 15s
          265 packages are looking for funding
          Updating objects from io-package.json for adapter "admin" with version "7.7.19"
          upload [172] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/README.md README.md text/markdown
          upload [150] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/Components-BGVs6Dmn.js custom/assets/Components-BGVs6Dmn.js application/javascript
          upload [100] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-B82Lauwj.js custom/assets/index-B82Lauwj.js application/javascript
          upload [90] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-C0FlO84Y.js custom/assets/index-C0FlO84Y.js application/javascript
          upload [80] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-CcDQHtwq.js custom/assets/index-CcDQHtwq.js application/javascript
          upload [70] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-DIVai5gZ.js custom/assets/index-DIVai5gZ.js application/javascript
          upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-G9F5mhbe.js custom/assets/index-G9F5mhbe.js application/javascript
          upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-eQxyhk2m.js custom/assets/index-eQxyhk2m.js application/javascript
          upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/jsx-runtime-DEOw6lrW.js custom/assets/jsx-runtime-DEOw6lrW.js application/javascript
          upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/virtualExposes-BufY-8i6.js custom/assets/virtualExposes-BufY-8i6.js application/javascript
          upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/es.json custom/i18n/es.json application/json
          upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
          upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
          upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json
          upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json
          upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
          upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
          upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
          upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
          upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de.json i18n/de.json application/json
          upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en.json i18n/en.json application/json
          upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es.json i18n/es.json application/json
          upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr.json i18n/fr.json application/json
          upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it.json i18n/it.json application/json
          upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl.json i18n/nl.json application/json
          upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl.json i18n/pl.json application/json
          upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt.json i18n/pt.json application/json
          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru.json i18n/ru.json application/json
          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk.json i18n/uk.json application/json
          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
          host.iobroker Adapter "system.adapter.admin.0" is started
          mn@iobroker:~$
          Hoffentlich hab ich alles beim Kopieren erwischt, hänge jetzt per iPhone über Tailscale an ssh. Das ist ne Fummelei…
          • G guitardoc
            @Thomas-Braun
            NPM version: 10.9.4
                import gyp.input
            gyp ERR! not ok
            > ssh2@1.17.0 install
            > node install.js
                import gyp.input
            gyp ERR! not ok
            mn@iobroker:~$
            @guitardoc
            Da klemmt irgendwas bei Python.
            apt policy python3-setuptools
            Und wenn das nicht installiert ist, nachinstallieren.
            • G Online
              G Online
              guitardoc
              mn@iobroker:~$ apt policy python3-setuptools
              python3-setuptools:
                Installed: (none)
                Candidate: 78.1.1-0.1
                Version table:
                   78.1.1-0.1 500
                      500 http://deb.debian.org/debian trixie/main >
              lines 1-6/6 (END)
              Scheint was zu fehlen. Wie müsste man das nachinstallieren?
              • G guitardoc
                python3-setuptools:
                  Installed: (none)
                  Version table:
                     78.1.1-0.1 500
                lines 1-6/6 (END)
                @guitardoc
                Wie alle anderen Pakete auch...
                sudo apt install python3-setuptools
                • G Online
                  G Online
                  guitardoc
                  Jetzt kommen bei Neuinstallation vom Admin erstmal keine Fehler. Adapter-Update teste ich nachher wenn ich wieder am richtigen Rechner bin. Vielen Dank erst mal bis hierher!
                  • G guitardoc
                    Das war das Ziel.
                    • G Online
                      G Online
                      guitardoc
                      Die Adapterinstallation funktioniert auch problemlos und ohne Fehler. Vielen Dank noch mal für die schnelle Hilfe!
