  4. Adapterinstallation Fehlermeldungen aber Code 0
    6.5k
28 Beiträge 3 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • G Online
    G Online
    guitardoc
    Sieht eigentlich ganz OK aus. Die Fehlermeldungen im Log kommen vom Modus-Adapter und VW-Adapter (beide Fehler sind bekannt).
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.17.2-1-pve
        Architecture: x86-64
    OS is similar to:
    model name	: Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     18:52:23 up  4:21,  1 user,  load average: 0.93, 0.83, 0.79
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-11-26 18:52:23 CET
               Universal time: Wed 2025-11-26 17:52:23 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    mn
    HOME=/home/mn
    GROUPS=mn adm dialout sudo users iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/mn
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: 	false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session: 		tty
    *** MEMORY ***
    Mem:             12G        4.0G        7.7G        3.1M        1.3G        8.9G
    Swap:           536M          0B        536M
    Total:           13G        4.0G        8.2G
    Active iob-Instances: 	33
            12288 M total memory
             3768 M used memory
             3883 M active memory
              899 M inactive memory
             7309 M free memory
                0 M buffer memory
             1212 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    top - 18:52:23 up  4:21,  1 user,  load average: 0.93, 0.83, 0.79
    Tasks:  65 total,   1 running,  64 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  9.5 us,  4.8 sy,  0.0 ni, 85.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  12288.0 total,   7308.6 free,   3769.4 used,   1212.8 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   8518.6 avail Mem
    *** FAILED SERVICES ***
      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    2 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       63G   26G   35G  43% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    /dev/mapper/pve-root             ext4       94G   12G   78G  14% /dev/ttyACM0
    udev                             devtmpfs   32G     0   32G   0% /dev/tty
    tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
    tmpfs                            tmpfs      13G  132K   13G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs      32G  2.9M   32G   1% /tmp
    tmpfs                            tmpfs     6.3G  8.0K  6.3G   1% /run/user/1001
    Show mounted filesystems:
    TARGET         SOURCE                                                 FSTYPE OPTIONS
    /              /dev/mapper/pve-vm--100--disk--0                       ext4   rw,relatime,stripe=16
    `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/101/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
    /var:
    8.5G	/var/
    7.4G	/var/lib
    7.3G	/var/lib/mysql
    7.1G	/var/lib/mysql/DBioBroker
    990M	/var/log
    Archived and active journals take up 988M in the file system.
    /opt/iobroker/backups:
    9.0G	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    843M	/opt/iobroker/iobroker-data/
    497M	/opt/iobroker/iobroker-data/files
    162M	/opt/iobroker/iobroker-data/backup-objects
    92M	/opt/iobroker/iobroker-data/files/vis-2
    67M	/opt/iobroker/iobroker-data/files/echarts.admin
    150M	/opt/iobroker/iobroker-data/objects.jsonl
    34M	/opt/iobroker/iobroker-data/states.jsonl
    30M	/opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
    26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v22.21.0
    /usr/bin/node 		v22.21.0
    /usr/bin/npm 		10.9.4
    /usr/bin/npx 		10.9.4
    /usr/bin/corepack 	0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 15690)
    Core adapters versions
    js-controller: 	7.0.7
    admin: 		7.7.19
    javascript: 	9.0.11
    nodejs modules from github: 	0
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.eusec.0                  : eusec                 : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
    + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
    + system.adapter.hydrawise.0              : hydrawise             : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : iobroker                                 -  enabled, port: 16021
    + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.shuttercontrol.1         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.shuttercontrol.2         : shuttercontrol        : iobroker                                 -  enabled
      system.adapter.solaredge.0              : solaredge             : iobroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1888, bind: 0.0.0.0
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      system.adapter.uv-protect.0             : uv-protect            : iobroker                                 -  enabled
    + system.adapter.viessmannapi.0           : viessmannapi          : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name          │ url                                                      │ auto upgrade │
    │ 0       │ 'stable'      │ 'https://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'beta'        │ 'https://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json'            │ false        │
    │ 3       │ 'live-beta'   │ 'http://iobroker.live/repo/sources-dist-latest.json'     │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "eusec"        : 2.0.3    , installed 2.0.3
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "followthesun" : 0.5.2    , installed 0.5.2
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "hydrawise"    : 1.0.2    , installed 1.0.2
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "nanoleaf-lightpanels": 1.4.0, installed 1.4.0
    Adapter    "notification-manager": 1.3.0, installed 1.3.0
    Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
    Adapter    "shelly"       : 10.4.0   , installed 10.4.2-alpha.2
    Adapter    "shuttercontrol": 2.0.7   , installed 2.0.7
    Adapter    "solaredge"    : 1.4.1    , installed 1.4.1
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "uv-protect"   : 0.6.9    , installed 0.6.9
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "yahka"        : 1.1.5    , installed 1.1.5
    Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
    Objects and States
    Objects: 	96170
    States: 	79976
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://security.debian.org trixie-security InRelease
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:44381         0.0.0.0:*               LISTEN      1000       72879191   1036/io.yahka.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          72861883   1/init
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1000       72870727   783/io.mqtt.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       72870726   783/io.mqtt.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       72879779   861/io.shelly.1
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       72864848   140/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       72863795   140/iobroker.js-con
    tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1000       72873925   1125/io.sonoff.0
    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      105        72863732   232/mariadbd
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          72863527   348/master
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          72863528   348/master
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       72879343   1173/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       72864231   521/io.admin.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          72861885   1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          72863180   1/init
    tcp6       0      0 :::1984                 :::*                    LISTEN      1000       72879639   1289/go2rtc
    tcp6       0      0 :::45397                :::*                    LISTEN      1000       72873856   1036/io.yahka.0
    tcp6       0      0 :::8555                 :::*                    LISTEN      1000       72880288   1289/go2rtc
    tcp6       0      0 :::8554                 :::*                    LISTEN      1000       72880286   1289/go2rtc
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       72880018   817/io.shelly.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       72879468   1029/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       72879469   1029/io.tuya.0
    udp        0      0 0.0.0.0:59799           0.0.0.0:*                           1000       72880277   1140/io.eusec.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          72861884   1/init
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       72880476   1337/io.nanoleaf-li
    udp        0      0 0.0.0.0:36770           0.0.0.0:*                           1000       72880272   1140/io.eusec.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       72879182   1036/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       72879181   1036/io.yahka.0
    udp6       0      0 :::8555                 :::*                                1000       72880289   1289/go2rtc
    udp6       0      0 :::111                  :::*                                0          72861886   1/init
    2025-11-26 17:57:40.228  - warn: modbus.0 (766) On error: {"errno":-104,"code":"ECONNRESET","syscall":"read"}
    2025-11-26 17:57:41.229  - info: modbus.0 (766) Disconnected from slave 192.168.188.90
    2025-11-26 17:58:41.237  - error: modbus.0 (766) Socket Error
    2025-11-26 17:58:41.237  - error: modbus.0 (766) Client in error state.
    2025-11-26 17:58:41.237  - warn: modbus.0 (766) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.188.90","port":1502}
    2025-11-26 17:59:42.241  - info: modbus.0 (766) Connected to slave 192.168.188.90
    2025-11-26 18:00:50.670  - error: vw-connect.0 (4648) Restart adapter
    2025-11-26 18:01:24.464  - error: vw-connect.0 (5191) Login Failed
    2025-11-26 18:01:24.464  - error: vw-connect.0 (5191) Restart Adapter in 30min
    2025-11-26 18:15:38.682  - info: javascript.0 (3276) script.js.common.Beleuchtung.Schalte_Licht_Terrasse_infolge_Insektenschutztür: Terrassenbeleuchtung wird infolge Insektenschutztür eingeschaltet.
    2025-11-26 18:15:38.684  - info: javascript.0 (3276) script.js.common.Fenster.Kombinationen_der_Kontaktsensoren: Kombination der Kontaktsensoren Wohnzimmer Tür zur Terrasse: true, Auslöser: offen geschlossen/angekippt
    2025-11-26 18:15:49.577  - info: javascript.0 (3276) script.js.common.Fenster.Kombinationen_der_Kontaktsensoren: Kombination der Kontaktsensoren Wohnzimmer Tür zur Terrasse: false, Auslöser: offen geschlossen/angekippt
    2025-11-26 18:16:38.682  - info: javascript.0 (3276) script.js.common.Beleuchtung.Schalte_Licht_Terrasse_infolge_Insektenschutztür: Terrassenbeleuchtung infolge Insektenschutztür wird ausgeschaltet.
    2025-11-26 18:31:24.464  - error: vw-connect.0 (5191) Restart adapter
    2025-11-26 18:32:04.356  - error: vw-connect.0 (5541) Login Failed
    2025-11-26 18:32:04.357  - error: vw-connect.0 (5541) Restart Adapter in 30min
    2025-11-26 18:36:02.406  - error: vw-connect.0 (5658) No Login Form found for type: Id
    2025-11-26 18:36:02.407  - error: vw-connect.0 (5658) Login Failed
    2025-11-26 18:36:02.407  - error: vw-connect.0 (5658) Restart Adapter in 30min
    2025-11-26 18:38:08.210  - info: homeconnect.0 (1114) DISCONNECTED: 011070386308002348
    2025-11-26 18:38:09.632  - info: homeconnect.0 (1114) 011070386308002348/programs/active/options: HomeAppliance is offline.
    2025-11-26 18:38:24.450  - info: uv-protect.0 (5808) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v22.21.0, js-controller: 7.0.7
    2025-11-26 18:38:31.197  - info: uv-protect.0 (5808) Terminated (NO_ERROR): Without reason
    2025-11-26 18:39:47.205  - info: homeconnect.0 (1114) CONNECTED: 011070386308002348
    2025-11-26 18:39:48.114  - info: homeconnect.0 (1114) 011070386308002348/programs/active: There is no program active.
    • G guitardoc
      Script v.2025-08-09
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 2
                       RTC time: n/a
                RTC in local TZ: no
      mn
      HOME=/home/mn
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/mn
      Display-Manager:
      Desktop:
      Session: 		tty
      *** MEMORY ***
      Swap:           536M          0B        536M
               3768 M used memory
               7309 M free memory
                  0 M buffer memory
               1212 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      *** FILESYSTEM ***
      /var:
      8.5G	/var/
      7.4G	/var/lib
      7.3G	/var/lib/mysql
      990M	/var/log
      USB-Devices by-id:
      HINT:
      /dev/ttyACM0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm 		10.9.4
      /usr/bin/npx 		10.9.4
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin: 		7.7.19
      javascript: 	9.0.11
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	96170
      States: 	79976
      Pending Updates: 0
      @guitardoc
      Okay, schau dir den tree an.
      cd /opt/iobroker
      npm ls
      npm ls cpu-features
      • G Online
        G Online
        guitardoc
        mn@iobroker:~$ cd /opt/iobroker
        mn@iobroker:/opt/iobroker$ npm ls
        iobroker.inst@3.0.0 /opt/iobroker
        +-- iobroker.admin@7.7.19
        +-- iobroker.alias-manager@2.0.0
        +-- iobroker.backitup@3.3.10
        +-- iobroker.cloud@5.0.1
        +-- iobroker.discovery@5.0.0
        +-- iobroker.echarts@1.9.2
        +-- iobroker.eusec@2.0.3
        +-- iobroker.feiertage@1.2.1
        +-- iobroker.followthesun@0.5.2
        +-- iobroker.homeconnect@1.4.3
        +-- iobroker.hydrawise@1.0.2
        +-- iobroker.javascript@9.0.11
        +-- iobroker.js-controller@7.0.7
        +-- iobroker.logparser@2.4.0
        +-- iobroker.modbus@6.3.2
        +-- iobroker.mqtt@6.1.4
        +-- iobroker.nanoleaf-lightpanels@1.4.0
        +-- iobroker.notification-manager@1.3.0
        +-- iobroker.pvforecast@5.0.0
        +-- iobroker.shelly@10.4.2-alpha.2
        +-- iobroker.shuttercontrol@2.0.7
        +-- iobroker.simple-api@2.8.0
        +-- iobroker.socketio@6.7.1
        +-- iobroker.solaredge@1.4.1
        +-- iobroker.sonoff@3.2.1
        +-- iobroker.sql@3.0.1
        +-- iobroker.telegram@4.1.0
        +-- iobroker.tuya@3.16.0
        +-- iobroker.uv-protect@0.6.9
        +-- iobroker.viessmannapi@2.4.3
        +-- iobroker.vis-2-widgets-material@1.4.10
        +-- iobroker.vis-2@2.13.4
        +-- iobroker.vis-map@1.1.2
        +-- iobroker.vis-materialdesign@0.5.9
        +-- iobroker.vis@1.5.6
        +-- iobroker.vw-connect@0.7.13
        +-- iobroker.weatherunderground@3.7.0
        +-- iobroker.web@7.0.8
        +-- iobroker.ws@2.6.2
        +-- iobroker.yahka@1.1.5
        `-- iobroker.zigbee@3.1.5
        mn@iobroker:/opt/iobroker$ npm ls cpu-features
        `-- (empty)
        • G guitardoc
          `-- (empty)
          @guitardoc
          Bei mir liegt das unterhalb vom admin@7.7.20:
          echad@chet:/opt/iobroker $ npm ls cpu-features
          └─┬ iobroker.admin@7.7.20
            └─┬ @iobroker/plugin-docker@0.1.6
              └─┬ dockerode@4.0.9
                └─┬ docker-modem@5.0.6
                  └─┬ ssh2@1.17.0
                    └── cpu-features@0.0.10
          • G Online
            G Online
            guitardoc
            Hmm, das ist wohl irgendwann was schief gelaufen. Ich bin auf Trixie, liegt es daran?
            Ansonsten - wie kann ich das beheben?
            • G guitardoc
              @guitardoc sagte in Adapterinstallation Fehlermeldungen aber Code 0:
              Nein.
              iob upgrade admin@7.7.19 --host iobroker --debug
              • Thomas BraunT Online
                Gerade nochmal auf meinem Test-System geschaut:
                [thomas@daleth iobroker]$ npm ls cpu-features
                └─┬ iobroker.admin@7.7.19
                    └─┬ dockerode@4.0.9
                        └─┬ ssh2@1.17.0
                Auch bei admin@7.7.19 war das schon eine Abhängigkeit vom plugin-docker
                • G Online
                  G Online
                  guitardoc
                  Bei mir läuft kein Docker, das System liegt auf einem Proxmox LXC und läuft auf einem headless Debian Trixie.
                  • G guitardoc
                    Hier läuft auch kein Docker.
                    • G Online
                      G Online
                      guitardoc
                      Ahh, ich dachte, weil da oben was von Docker stand.
                      Hmm, was kann ich denn nun machen?
                      • G guitardoc
                        @guitardoc
                        Was spuckt denn
                        nun aus?
                        G 1 Antwort Letzte Antwort
                          @guitardoc
                          Was spuckt denn
                          nun aus?
                          G Online
                          G Online
                          guitardoc
                          @Thomas-Braun
                          Would you like to reinstall version 7.7.19 of admin now? [(y)es, (n)o]: y
                          Update admin from @7.7.19 to @7.7.19
                          Uninstall npm packet "iobroker.admin" for a clean re-installation
                          removed 69 packages in 2s
                          260 packages are looking for funding
                            run `npm fund` for details
                          host.iobroker Adapter "system.adapter.admin.0" is stopped.
                          NPM version: 10.9.4
                          Installing iobroker.admin@7.7.19... (System call)
                          > cpu-features@0.0.10 install
                          > node buildcheck.js > buildcheck.gypi && node-gyp rebuild
                          gyp info it worked if it ends with ok
                          gyp info using node-gyp@8.4.1
                          gyp info using node@22.21.0 | linux | x64
                          (node:7310) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                          (Use `node --trace-deprecation ...` to show where the warning was created)
                          gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
                          gyp info spawn /usr/bin/python3
                          gyp info spawn args [
                          gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                          gyp info spawn args   'binding.gyp',
                          gyp info spawn args   '-f',
                          gyp info spawn args   'make',
                          gyp info spawn args   '-I',
                          gyp info spawn args   '/opt/iobroker/node_modules/cpu-features/build/config.gypi',
                          gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                          gyp info spawn args   '/home/iobroker/.cache/node-gyp/22.21.0/include/node/common.gypi',
                          gyp info spawn args   '-Dlibrary=shared_library',
                          gyp info spawn args   '-Dvisibility=default',
                          gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.21.0',
                          gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                          gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.21.0/<(target_arch)/node.lib',
                          gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/cpu-features',
                          gyp info spawn args   '-Dnode_engine=v8',
                          gyp info spawn args   '--depth=.',
                          gyp info spawn args   '--no-parallel',
                          gyp info spawn args   '--generator-output',
                          gyp info spawn args   'build',
                          gyp info spawn args   '-Goutput_dir=.'
                          gyp info spawn args ]
                          Traceback (most recent call last):
                            File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module>
                              import gyp  # noqa: E402
                            File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module>
                              import gyp.input
                            File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module>
                              from distutils.version import StrictVersion
                          ModuleNotFoundError: No module named 'distutils'
                          gyp ERR! configure error
                          gyp ERR! stack Error: `gyp` failed with exit code: 1
                          gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)
                          gyp ERR! stack     at ChildProcess.emit (node:events:519:28)
                          gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:293:12)
                          gyp ERR! System Linux 6.17.2-1-pve
                          gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                          gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
                          gyp ERR! node -v v22.21.0
                          gyp ERR! node-gyp -v v8.4.1
                          gyp ERR! not ok
                          > ssh2@1.17.0 install
                          > node install.js
                          (node:7334) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                          gyp info spawn args   '/opt/iobroker/node_modules/ssh2/lib/protocol/crypto/build/config.gypi',
                          gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/ssh2/lib/protocol/crypto',
                              import gyp.input
                          gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "--target=v22.21.0" "--real_openssl_major=3" "rebuild"
                          gyp ERR! cwd /opt/iobroker/node_modules/ssh2/lib/protocol/crypto
                          gyp ERR! not ok
                          Failed to build optional crypto binding
                          added 70 packages in 15s
                          265 packages are looking for funding
                          Updating objects from io-package.json for adapter "admin" with version "7.7.19"
                          upload [172] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/README.md README.md text/markdown
                          upload [150] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/Components-BGVs6Dmn.js custom/assets/Components-BGVs6Dmn.js application/javascript
                          upload [100] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-B82Lauwj.js custom/assets/index-B82Lauwj.js application/javascript
                          upload [90] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-C0FlO84Y.js custom/assets/index-C0FlO84Y.js application/javascript
                          upload [80] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-CcDQHtwq.js custom/assets/index-CcDQHtwq.js application/javascript
                          upload [70] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-DIVai5gZ.js custom/assets/index-DIVai5gZ.js application/javascript
                          upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-G9F5mhbe.js custom/assets/index-G9F5mhbe.js application/javascript
                          upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-eQxyhk2m.js custom/assets/index-eQxyhk2m.js application/javascript
                          upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/jsx-runtime-DEOw6lrW.js custom/assets/jsx-runtime-DEOw6lrW.js application/javascript
                          upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/virtualExposes-BufY-8i6.js custom/assets/virtualExposes-BufY-8i6.js application/javascript
                          upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/es.json custom/i18n/es.json application/json
                          upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
                          upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
                          upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json
                          upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json
                          upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
                          upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
                          upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                          upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                          upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de.json i18n/de.json application/json
                          upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en.json i18n/en.json application/json
                          upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es.json i18n/es.json application/json
                          upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr.json i18n/fr.json application/json
                          upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it.json i18n/it.json application/json
                          upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl.json i18n/nl.json application/json
                          upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl.json i18n/pl.json application/json
                          upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt.json i18n/pt.json application/json
                          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru.json i18n/ru.json application/json
                          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk.json i18n/uk.json application/json
                          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
                          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                          host.iobroker Adapter "system.adapter.admin.0" is started
                          mn@iobroker:~$
                          Hoffentlich hab ich alles beim Kopieren erwischt, hänge jetzt per iPhone über Tailscale an ssh. Das ist ne Fummelei…
                          • G guitardoc
                            @Thomas-Braun
                            NPM version: 10.9.4
                                import gyp.input
                            gyp ERR! not ok
                            > ssh2@1.17.0 install
                            > node install.js
                                import gyp.input
                            gyp ERR! not ok
                            mn@iobroker:~$
                            @guitardoc
                            Da klemmt irgendwas bei Python.
                            apt policy python3-setuptools
                            Und wenn das nicht installiert ist, nachinstallieren.
                            • G Online
                              G Online
                              guitardoc
                              mn@iobroker:~$ apt policy python3-setuptools
                              python3-setuptools:
                                Installed: (none)
                                Candidate: 78.1.1-0.1
                                Version table:
                                   78.1.1-0.1 500
                                      500 http://deb.debian.org/debian trixie/main >
                              lines 1-6/6 (END)
                              Scheint was zu fehlen. Wie müsste man das nachinstallieren?
                              • G guitardoc
                                python3-setuptools:
                                  Installed: (none)
                                  Version table:
                                     78.1.1-0.1 500
                                lines 1-6/6 (END)
                                @guitardoc
                                Wie alle anderen Pakete auch...
                                sudo apt install python3-setuptools
                                • G Online
                                  G Online
                                  guitardoc
                                  Jetzt kommen bei Neuinstallation vom Admin erstmal keine Fehler. Adapter-Update teste ich nachher wenn ich wieder am richtigen Rechner bin. Vielen Dank erst mal bis hierher!
                                  • G guitardoc
                                    Das war das Ziel.
                                    • G Online
                                      G Online
                                      guitardoc
                                      Die Adapterinstallation funktioniert auch problemlos und ohne Fehler. Vielen Dank noch mal für die schnelle Hilfe!
