  4. Adapterinstallation Fehlermeldungen aber Code 0
    6.5k
28 Beiträge 3 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • G guitardoc
    mn@iobroker:~$ cd /opt/iobroker
    mn@iobroker:/opt/iobroker$ npm ls
    iobroker.inst@3.0.0 /opt/iobroker
    +-- iobroker.admin@7.7.19
    +-- iobroker.alias-manager@2.0.0
    +-- iobroker.backitup@3.3.10
    +-- iobroker.cloud@5.0.1
    +-- iobroker.discovery@5.0.0
    +-- iobroker.echarts@1.9.2
    +-- iobroker.eusec@2.0.3
    +-- iobroker.feiertage@1.2.1
    +-- iobroker.followthesun@0.5.2
    +-- iobroker.homeconnect@1.4.3
    +-- iobroker.hydrawise@1.0.2
    +-- iobroker.javascript@9.0.11
    +-- iobroker.js-controller@7.0.7
    +-- iobroker.logparser@2.4.0
    +-- iobroker.modbus@6.3.2
    +-- iobroker.mqtt@6.1.4
    +-- iobroker.nanoleaf-lightpanels@1.4.0
    +-- iobroker.notification-manager@1.3.0
    +-- iobroker.pvforecast@5.0.0
    +-- iobroker.shelly@10.4.2-alpha.2
    +-- iobroker.shuttercontrol@2.0.7
    +-- iobroker.simple-api@2.8.0
    +-- iobroker.socketio@6.7.1
    +-- iobroker.solaredge@1.4.1
    +-- iobroker.sonoff@3.2.1
    +-- iobroker.sql@3.0.1
    +-- iobroker.telegram@4.1.0
    +-- iobroker.tuya@3.16.0
    +-- iobroker.uv-protect@0.6.9
    +-- iobroker.viessmannapi@2.4.3
    +-- iobroker.vis-2-widgets-material@1.4.10
    +-- iobroker.vis-2@2.13.4
    +-- iobroker.vis-map@1.1.2
    +-- iobroker.vis-materialdesign@0.5.9
    +-- iobroker.vis@1.5.6
    +-- iobroker.vw-connect@0.7.13
    +-- iobroker.weatherunderground@3.7.0
    +-- iobroker.web@7.0.8
    +-- iobroker.ws@2.6.2
    +-- iobroker.yahka@1.1.5
    `-- iobroker.zigbee@3.1.5
    mn@iobroker:/opt/iobroker$ npm ls cpu-features
    `-- (empty)
    @guitardoc
    Bei mir liegt das unterhalb vom admin@7.7.20:
    echad@chet:/opt/iobroker $ npm ls cpu-features
    └─┬ iobroker.admin@7.7.20
      └─┬ @iobroker/plugin-docker@0.1.6
        └─┬ dockerode@4.0.9
          └─┬ docker-modem@5.0.6
            └─┬ ssh2@1.17.0
              └── cpu-features@0.0.10
    • G Offline
      guitardoc
      Hmm, das ist wohl irgendwann was schief gelaufen. Ich bin auf Trixie, liegt es daran?
      Ansonsten - wie kann ich das beheben?
      • G guitardoc
        @guitardoc sagte in Adapterinstallation Fehlermeldungen aber Code 0:
        Nein.
        iob upgrade admin@7.7.19 --host iobroker --debug
        • Thomas BraunT Online
          Gerade nochmal auf meinem Test-System geschaut:
          [thomas@daleth iobroker]$ npm ls cpu-features
          └─┬ iobroker.admin@7.7.19
              └─┬ dockerode@4.0.9
                  └─┬ ssh2@1.17.0
          Auch bei admin@7.7.19 war das schon eine Abhängigkeit vom plugin-docker
          • G Offline
            guitardoc
            Bei mir läuft kein Docker, das System liegt auf einem Proxmox LXC und läuft auf einem headless Debian Trixie.
            • G guitardoc
              Hier läuft auch kein Docker.
              • G Offline
                guitardoc
                Ahh, ich dachte, weil da oben was von Docker stand.
                Hmm, was kann ich denn nun machen?
                • G guitardoc
                  @guitardoc
                  Was spuckt denn
                  nun aus?
                  G 1 Antwort Letzte Antwort
                    @guitardoc
                    Was spuckt denn
                    nun aus?
                    guitardoc
                    @Thomas-Braun
                    Would you like to reinstall version 7.7.19 of admin now? [(y)es, (n)o]: y
                    Update admin from @7.7.19 to @7.7.19
                    Uninstall npm packet "iobroker.admin" for a clean re-installation
                    removed 69 packages in 2s
                    260 packages are looking for funding
                      run `npm fund` for details
                    host.iobroker Adapter "system.adapter.admin.0" is stopped.
                    NPM version: 10.9.4
                    Installing iobroker.admin@7.7.19... (System call)
                    > cpu-features@0.0.10 install
                    > node buildcheck.js > buildcheck.gypi && node-gyp rebuild
                    gyp info it worked if it ends with ok
                    gyp info using node-gyp@8.4.1
                    gyp info using node@22.21.0 | linux | x64
                    (node:7310) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                    (Use `node --trace-deprecation ...` to show where the warning was created)
                    gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
                    gyp info spawn /usr/bin/python3
                    gyp info spawn args [
                    gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                    gyp info spawn args   'binding.gyp',
                    gyp info spawn args   '-f',
                    gyp info spawn args   'make',
                    gyp info spawn args   '-I',
                    gyp info spawn args   '/opt/iobroker/node_modules/cpu-features/build/config.gypi',
                    gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                    gyp info spawn args   '/home/iobroker/.cache/node-gyp/22.21.0/include/node/common.gypi',
                    gyp info spawn args   '-Dlibrary=shared_library',
                    gyp info spawn args   '-Dvisibility=default',
                    gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.21.0',
                    gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                    gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.21.0/<(target_arch)/node.lib',
                    gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/cpu-features',
                    gyp info spawn args   '-Dnode_engine=v8',
                    gyp info spawn args   '--depth=.',
                    gyp info spawn args   '--no-parallel',
                    gyp info spawn args   '--generator-output',
                    gyp info spawn args   'build',
                    gyp info spawn args   '-Goutput_dir=.'
                    gyp info spawn args ]
                    Traceback (most recent call last):
                      File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module>
                        import gyp  # noqa: E402
                      File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module>
                        import gyp.input
                      File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module>
                        from distutils.version import StrictVersion
                    ModuleNotFoundError: No module named 'distutils'
                    gyp ERR! configure error
                    gyp ERR! stack Error: `gyp` failed with exit code: 1
                    gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)
                    gyp ERR! stack     at ChildProcess.emit (node:events:519:28)
                    gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:293:12)
                    gyp ERR! System Linux 6.17.2-1-pve
                    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                    gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
                    gyp ERR! node -v v22.21.0
                    gyp ERR! node-gyp -v v8.4.1
                    gyp ERR! not ok
                    > ssh2@1.17.0 install
                    > node install.js
                    (node:7334) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                    gyp info spawn args   '/opt/iobroker/node_modules/ssh2/lib/protocol/crypto/build/config.gypi',
                    gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/ssh2/lib/protocol/crypto',
                        import gyp.input
                    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "--target=v22.21.0" "--real_openssl_major=3" "rebuild"
                    gyp ERR! cwd /opt/iobroker/node_modules/ssh2/lib/protocol/crypto
                    gyp ERR! not ok
                    Failed to build optional crypto binding
                    added 70 packages in 15s
                    265 packages are looking for funding
                    Updating objects from io-package.json for adapter "admin" with version "7.7.19"
                    upload [172] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/README.md README.md text/markdown
                    upload [150] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/Components-BGVs6Dmn.js custom/assets/Components-BGVs6Dmn.js application/javascript
                    upload [100] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-B82Lauwj.js custom/assets/index-B82Lauwj.js application/javascript
                    upload [90] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-C0FlO84Y.js custom/assets/index-C0FlO84Y.js application/javascript
                    upload [80] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-CcDQHtwq.js custom/assets/index-CcDQHtwq.js application/javascript
                    upload [70] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-DIVai5gZ.js custom/assets/index-DIVai5gZ.js application/javascript
                    upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-G9F5mhbe.js custom/assets/index-G9F5mhbe.js application/javascript
                    upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-eQxyhk2m.js custom/assets/index-eQxyhk2m.js application/javascript
                    upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/jsx-runtime-DEOw6lrW.js custom/assets/jsx-runtime-DEOw6lrW.js application/javascript
                    upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/virtualExposes-BufY-8i6.js custom/assets/virtualExposes-BufY-8i6.js application/javascript
                    upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/es.json custom/i18n/es.json application/json
                    upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/fr.json custom/i18n/fr.json application/json
                    upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
                    upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/nl.json custom/i18n/nl.json application/json
                    upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json custom/i18n/pl.json application/json
                    upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
                    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
                    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de.json i18n/de.json application/json
                    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en.json i18n/en.json application/json
                    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es.json i18n/es.json application/json
                    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr.json i18n/fr.json application/json
                    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it.json i18n/it.json application/json
                    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl.json i18n/nl.json application/json
                    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl.json i18n/pl.json application/json
                    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt.json i18n/pt.json application/json
                    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru.json i18n/ru.json application/json
                    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk.json i18n/uk.json application/json
                    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
                    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                    host.iobroker Adapter "system.adapter.admin.0" is started
                    mn@iobroker:~$
                    Hoffentlich hab ich alles beim Kopieren erwischt, hänge jetzt per iPhone über Tailscale an ssh. Das ist ne Fummelei…
                    • G guitardoc
                      @Thomas-Braun
                      NPM version: 10.9.4
                          import gyp.input
                      gyp ERR! not ok
                      > ssh2@1.17.0 install
                      > node install.js
                          import gyp.input
                      gyp ERR! not ok
                      mn@iobroker:~$
                      @guitardoc
                      Da klemmt irgendwas bei Python.
                      apt policy python3-setuptools
                      Und wenn das nicht installiert ist, nachinstallieren.
                      • G Offline
                        guitardoc
                        mn@iobroker:~$ apt policy python3-setuptools
                        python3-setuptools:
                          Installed: (none)
                          Candidate: 78.1.1-0.1
                          Version table:
                             78.1.1-0.1 500
                                500 http://deb.debian.org/debian trixie/main >
                        lines 1-6/6 (END)
                        Scheint was zu fehlen. Wie müsste man das nachinstallieren?
                        • G guitardoc
                          python3-setuptools:
                            Installed: (none)
                            Version table:
                               78.1.1-0.1 500
                          lines 1-6/6 (END)
                          @guitardoc
                          Wie alle anderen Pakete auch...
                          sudo apt install python3-setuptools
                          • G Offline
                            guitardoc
                            Jetzt kommen bei Neuinstallation vom Admin erstmal keine Fehler. Adapter-Update teste ich nachher wenn ich wieder am richtigen Rechner bin. Vielen Dank erst mal bis hierher!
                            • G guitardoc
                              Das war das Ziel.
                              • G Offline
                                guitardoc
                                Die Adapterinstallation funktioniert auch problemlos und ohne Fehler. Vielen Dank noch mal für die schnelle Hilfe!
