  4. iob fix und iob diag ohne Reaktion
    6.4k
94 Beiträge 8 Kommentatoren 12.8k Aufrufe 4 Beobachtet
  • G George_Best
    stimmt! Ich muss ja den User wieder in den Gruppen hinzufügen. Das ist jetzt erledigt.
    Aber das Verhalten (auch nach iob fix) ist immer noch gleich:
    iobroker läuft hoch - d.h. die instanzen starten, aber dann scheinen alle zu stoppen
    iob diag sagt atkuell:
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: ioBroker-V2
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-30-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.1-0-g3208b098f51a-prebuilt.qemu.org
    OS is similar to:
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     22:04:14 up 6 min,  2 users,  load average: 0.20, 0.28, 0.14
    CPU threads: 8
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2025-11-11 22:04:14 CET
               Universal time: Tue 2025-11-11 21:04:14 UTC
                     RTC time: Tue 2025-11-11 21:04:14
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    jonny
    HOME=/home/jonny
    GROUPS=jonny adm cdrom floppy sudo audio dip video plugdev systemd-journal netdev iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             12G        504M         10G        548K        1.6G         11G
    Swap:           4.3G          0B        4.3G
    Total:           16G        504M         14G
    Active iob-Instances:   1
            11644 M total memory
              481 M used memory
              587 M active memory
              720 M inactive memory
             9976 M free memory
              200 M buffer memory
             1299 M swap cache
             4093 M total swap
                0 M used swap
             4093 M free swap
    top - 22:04:14 up 6 min,  2 users,  load average: 0.20, 0.28, 0.14
    Tasks: 107 total,   1 running, 106 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  11644.7 total,   9973.5 free,    484.2 used,   1500.3 buff/cache
    MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.  11160.5 avail Mem
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  5.7G     0  5.7G   0% /dev
    tmpfs          tmpfs     1.2G  544K  1.2G   1% /run
    /dev/sda1      ext4       28G  9.2G   17G  36% /
    tmpfs          tmpfs     5.7G     0  5.7G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
    [Tue Nov 11 21:57:33 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Nov 11 21:57:34 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    1.6G    /var/
    798M    /var/log
    776M    /var/log/journal/123d1e3573ba4b7d9135f498a7b4789a
    600M    /var/cache
    Archived and active journals take up 775.9M in the file system.
    /opt/iobroker/backups:
    22M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    676M    /opt/iobroker/iobroker-data/
    450M    /opt/iobroker/iobroker-data/files
    166M    /opt/iobroker/iobroker-data/backup-objects
    81M     /opt/iobroker/iobroker-data/files/vis
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    26M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/objects.json.migrated
    12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    4.6M    /opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2195735-if00
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.2
    /usr/bin/node           v20.18.2
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.2-1nodesource1
      Candidate: 20.19.5-1nodesource1
      Version table:
         20.19.5-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.19.4-1nodesource1 1001
         20.19.3-1nodesource1 1001
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
     *** 20.18.2-1nodesource1 1001
            100 /var/lib/dpkg/status
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    The current Node.js version (v20.18.2) is vulnerable to the following CVEs:
    CVE-2025-23166(high):  The C++ method SignTraits::DeriveBits() may incorrectly call ThrowException() based on user-supplied inputs when executing in a background thread, crashing the Node.js process. Such cryptographic operations are commonly applied to untrusted inputs. Thus, this mechanism potentially allows an adversary to remotely crash a Node.js runtime.
    Patched versions: ^20.19.2 || ^22.15.1 || ^23.11.1 || ^24.0.2
    CVE-2025-23167(medium): A flaw in Node.js 20's HTTP parser allows improper termination of HTTP/1 headers using `\r\n\rX` instead of the required `\r\n\r\n`.
    This inconsistency enables request smuggling, allowing attackers to bypass proxy-based access controls and submit unauthorized requests.
    The issue was resolved by upgrading `llhttp` to version 9, which enforces correct header termination.
    Impact:
    * This vulnerability affects only Node.js 20.x users prior to the `llhttp` v9 upgrade.
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker-V2         ioBroker-V2 (version: 7.0.7, hostname: ioBroker-V2   , dead, uptime: 47)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     8.9.2
    nodejs modules from github:     2
    |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
    | +-- tplink-smarthome-api@5.0.0 invalid: "https://github.com/arteck/tplink-smarthome-api/tarball/08bcca9334c701b60d1eeb18b0ec72350aa3bf7a" from node_modules/iobroker.hs100
    Adapter State
      system.adapter.accuweather.0            : accuweather           : ioBroker-V2                              -  enabled
      system.adapter.admin.0                  : admin                 : ioBroker-V2                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.alias-manager.0          : alias-manager         : ioBroker-V2                              -  enabled
      system.adapter.amazon-dash.0            : amazon-dash           : ioBroker-V2                              - disabled
      system.adapter.chromecast.0             : chromecast            : ioBroker-V2                              -  enabled
      system.adapter.cloud.0                  : cloud                 : ioBroker-V2                              - disabled
      system.adapter.daswetter.0              : daswetter             : ioBroker-V2                              -  enabled
      system.adapter.deconz.0                 : deconz                : ioBroker-V2                              - disabled, port: 80
      system.adapter.devices.0                : devices               : ioBroker-V2                              -  enabled
      system.adapter.discovery.0              : discovery             : ioBroker-V2                              -  enabled
      system.adapter.email.0                  : email                 : ioBroker-V2                              -  enabled
      system.adapter.flot.0                   : flot                  : ioBroker-V2                              -  enabled
      system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker-V2                              -  enabled
      system.adapter.fronius.0                : fronius               : ioBroker-V2                              -  enabled
      system.adapter.frontier_silicon.0       : frontier_silicon      : ioBroker-V2                              -  enabled
      system.adapter.habpanel.0               : habpanel              : ioBroker-V2                              -  enabled
      system.adapter.history.0                : history               : ioBroker-V2                              -  enabled
      system.adapter.hm-rega.0                : hm-rega               : ioBroker-V2                              -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-V2                              -  enabled, port: 0
      system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-V2                              -  enabled, port: 0
      system.adapter.hs100.0                  : hs100                 : ioBroker-V2                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker-V2                              -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker-V2                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-V2                              -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-V2                              -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker-V2                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-V2                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-V2                              -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker-V2                              -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-V2                              -  enabled
      system.adapter.influxdb.0               : influxdb              : ioBroker-V2                              - disabled, port: 8086
      system.adapter.influxdb.1               : influxdb              : ioBroker-V2                              - disabled, port: 8086
      system.adapter.info.0                   : info                  : ioBroker-V2                              -  enabled
      system.adapter.iot.0                    : iot                   : ioBroker-V2                              -  enabled
      system.adapter.javascript.0             : javascript            : ioBroker-V2                              -  enabled
      system.adapter.javascript.1             : javascript            : ioBroker-V2                              -  enabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-V2                              - disabled, port: 54321
      system.adapter.mqtt.0                   : mqtt                  : ioBroker-V2                              -  enabled, port: 1883, bind: 192.168.178.121
      system.adapter.net-tools.0              : net-tools             : ioBroker-V2                              - disabled
      system.adapter.net-tools.1              : net-tools             : ioBroker-V2                              -  enabled
      system.adapter.octoprint.0              : octoprint             : ioBroker-V2                              -  enabled
      system.adapter.parser.0                 : parser                : ioBroker-V2                              -  enabled
      system.adapter.ping.0                   : ping                  : ioBroker-V2                              - disabled
      system.adapter.proxmox.0                : proxmox               : ioBroker-V2                              -  enabled, port: 8006
      system.adapter.radar.0                  : radar                 : ioBroker-V2                              - disabled
      system.adapter.radar2.0                 : radar2                : ioBroker-V2                              - disabled
      system.adapter.radar2.1                 : radar2                : ioBroker-V2                              -  enabled
      system.adapter.reolink.0                : reolink               : ioBroker-V2                              -  enabled
      system.adapter.reolink.1                : reolink               : ioBroker-V2                              -  enabled
      system.adapter.rickshaw.0               : rickshaw              : ioBroker-V2                              -  enabled
      system.adapter.s7.0                     : s7                    : ioBroker-V2                              -  enabled
      system.adapter.s7.1                     : s7                    : ioBroker-V2                              -  enabled
      system.adapter.s7.2                     : s7                    : ioBroker-V2                              -  enabled
      system.adapter.sayit.0                  : sayit                 : ioBroker-V2                              -  enabled
      system.adapter.sayit.1                  : sayit                 : ioBroker-V2                              -  enabled
      system.adapter.sayit.2                  : sayit                 : ioBroker-V2                              -  enabled
      system.adapter.simple-api.0             : simple-api            : ioBroker-V2                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.smartmeter.0             : smartmeter            : ioBroker-V2                              - disabled
      system.adapter.smartmeter.2             : smartmeter            : ioBroker-V2                              - disabled
      system.adapter.socketio.0               : socketio              : ioBroker-V2                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.sql.0                    : sql                   : ioBroker-V2                              -  enabled, port: 3306
      system.adapter.sql.1                    : sql                   : ioBroker-V2                              - disabled, port: 3306
      system.adapter.statistics.0             : statistics            : ioBroker-V2                              -  enabled
      system.adapter.systeminfo.0             : systeminfo            : ioBroker-V2                              - disabled
      system.adapter.telegram.0               : telegram              : ioBroker-V2                              -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.terminal.0               : terminal              : ioBroker-V2                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      system.adapter.tr-064.0                 : tr-064                : ioBroker-V2                              -  enabled
      system.adapter.unifi.0                  : unifi                 : ioBroker-V2                              -  enabled
      system.adapter.upnp.0                   : upnp                  : ioBroker-V2                              -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker-V2                              -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker-V2                              -  enabled
      system.adapter.vis-2.0                  : vis-2                 : ioBroker-V2                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : ioBroker-V2                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-V2                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-V2                              -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-V2                              -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker-V2                              -  enabled
      system.adapter.vis-history.0            : vis-history           : ioBroker-V2                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-V2                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-V2                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-V2                              -  enabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-V2                              -  enabled
      system.adapter.vis-lcars.0              : vis-lcars             : ioBroker-V2                              -  enabled
      system.adapter.vis-map.0                : vis-map               : ioBroker-V2                              -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker-V2                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : ioBroker-V2                              -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-V2                              -  enabled
      system.adapter.vis-weather.0            : vis-weather           : ioBroker-V2                              -  enabled
      system.adapter.vis.0                    : vis                   : ioBroker-V2                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker-V2                              -  enabled
      system.adapter.web.0                    : web                   : ioBroker-V2                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "accuweather"  : 2.1.1    , installed 2.1.1
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "deconz"       : 1.6.4    , installed 1.6.4
    Adapter    "devices"      : 1.2.8    , installed 1.2.8
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "fronius"      : 2.1.1    , installed 2.1.1
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
    Adapter    "frontier_silicon": 0.5.0 , installed 0.5.0
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "hs100"        : 3.0.5    , installed 3.0.5
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "iot"          : 5.0.7    , installed 5.0.7
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
    Adapter    "net-tools"    : 1.1.2    , installed 1.1.2
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "parser"       : 2.2.4    , installed 2.2.4
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "radar2"       : 2.4.0    , installed 2.4.0
    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "s7"           : 1.5.0    , installed 1.5.0
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Objects and States
    Objects:        24997
    States:         19923
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 153
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15854      497/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          16500      733/exim4
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15856      497/sshd: /usr/sbin
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          16501      733/exim4
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1979       334/dhclient
    udp        0      0 0.0.0.0:33468           0.0.0.0:*                           107        382        440/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        380        440/avahi-daemon: r
    udp6       0      0 :::34467                :::*                                107        383        440/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                107        381        440/avahi-daemon: r
    2025-11-11 22:01:40.743  - info: radar2.1 (3290) terminating with timeout
    2025-11-11 22:01:40.745  - info: fronius.0 (3375) terminating with timeout
    2025-11-11 22:01:41.081  - warn: sql.0 (2920) No Connection to database
    2025-11-11 22:01:41.082  - warn: sql.0 (2920) No Connection to database
    2025-11-11 22:01:41.083  - error: sql.0 (2920) No database connection
    2025-11-11 22:01:42.082  - warn: sql.0 (2920) No Connection to database
    2025-11-11 22:01:44.464  - error: fronius.0 (3375) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    2025-11-11 22:01:44.463  - error: hm-rega.0 (3190) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    2025-11-11 22:01:44.473  - error: radar2.1 (3290) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    2025-11-11 22:01:44.488  - error: javascript.1 (2970) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    2025-11-11 22:01:44.485  - warn: history.0 (3005) get state error: Connection is closed.
    2025-11-11 22:01:44.484  - error: telegram.0 (3020) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    2025-11-11 22:01:44.491  - error: sql.0 (2920) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    2025-11-11 22:01:44.492  - error: sql.0 (2920) States database error: connect ECONNREFUSED 0.0.0.0:9000
    2025-11-11 22:01:49.494  - error: sql.0 (2920) States database error: connect ECONNREFUSED 0.0.0.0:9000
    2025-11-11 22:01:49.495  - error: sql.0 (2920) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    2025-11-11 22:01:50.490  - info: sql.0 (2920) terminating with timeout
    2025-11-11 22:01:50.490  - info: sql.0 (2920) Terminated (NO_ERROR): Without reason
    2025-11-11 22:01:54.497  - error: sql.0 (2920) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    2025-11-11 22:01:54.498  - warn: sql.0 (2920) get state error: Connection is closed.
    2025-11-11 22:01:54.499  - warn: sql.0 (2920) get state error: DB closed
    2025-11-11 22:01:54.499  - info: sql.0 (2920) terminating
    2025-11-11 22:01:59.501  - error: sql.0 (2920) Cannot find view "system" for search "instance" : Connection is closed.
    ```![Screenshot 2025-11-11 220204.png](/assets/uploads/files/1762895295022-screenshot-2025-11-11-220204.png)
    #41
    @george_best
    Bring den ganzen Sums erstmal auf Stand...
    G 1 Antwort Letzte Antwort
      @george_best
      George_Best
      #42
      @thomas-braun sagte in iob fix und iob diag ohne Reaktion:
      @george_best
      Ok, aber wie geh ich da nun vor?
      Die Adapter sind geupdatet.
      • G George_Best
        @george_best
        #43
        @george_best
        Das Betriebssystem aber nicht.
          @george_best
          George_Best
          #44
          @george_best
          Ich befürchte ich habe das gleiche Problem wie hier: https://forum.iobroker.net/topic/81185/system-admin-upgrade-exited-with-code-25-start-schleife/60
          1. Betriebssystem habe ich nun geupdatet
          2. iob fix gemacht
          library: loaded
          Library version=2025-08-09
              Welcome to the ioBroker installation fixer!
              Script version: 2025-08-09
              You might need to enter your password a couple of times.
              Installing prerequisites (1/5)
          OK:1 http://deb.debian.org/debian bookworm InRelease
          OK:2 http://deb.debian.org/debian bookworm-updates InRelease
          OK:3 http://deb.debian.org/debian-security bookworm-security InRelease
          OK:4 https://deb.nodesource.com/node_22.x nodistro InRelease
              Checking ioBroker user and directory permissions (2/5)
          Created /etc/sudoers.d/iobroker
              Check and cleanup npm temporary directories (3/5)
          Done.
              Database maintenance (4/5)
          Checking for uncompressed JSONL databases... This might take a while!
          Compressing /opt/iobroker/iobroker-data/states.jsonl
          Compressing /opt/iobroker/iobroker-data/objects.jsonl
          Compressed 2 JSONL files. Done
              Checking autostart (5/5)
          ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
          Legitimierung ist zum Stoppen von »iobroker.service« notwendig.
          Authenticating as: jonny,,, (jonny)
          Password:
          ==== AUTHENTICATION COMPLETE ====
          Enabling autostart...
          Autostart enabled!
          1. iob diag sagt:
          ```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
            Virtualization: kvm
                    Kernel: Linux 6.1.0-41-amd64
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
           16:30:54 up 29 min,  2 users,  load average: 0.64, 0.37, 0.62
          CPU threads: 8
          Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                         Local time: Wed 2025-11-12 16:30:54 CET
                     Universal time: Wed 2025-11-12 15:30:54 UTC
                           RTC time: Wed 2025-11-12 15:30:54
                        NTP service: active
                    RTC in local TZ: no
          jonny
          HOME=/home/jonny
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Mem:             12G        1.9G        8.1G        561K        2.5G         10G
          Swap:           4.3G          0B        4.3G
          Total:           16G        1.9G         12G
          Active iob-Instances:   6
                   1812 M used memory
                   1465 M active memory
                   1926 M inactive memory
                   7764 M free memory
                    343 M buffer memory
                   2036 M swap cache
                   4093 M total swap
                      0 M used swap
                   4093 M free swap
          top - 16:30:55 up 29 min,  2 users,  load average: 0.64, 0.37, 0.62
          Tasks: 124 total,   1 running, 123 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  11644.7 total,   7765.0 free,   1812.8 used,   2380.2 buff/cache
          MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.   9831.8 avail Mem
          0 loaded units listed.
          *** FILESYSTEM ***
          tmpfs          tmpfs     1.2G  548K  1.2G   1% /run
          /dev/sda1      ext4       28G   11G   16G  40% /
          [Wed Nov 12 16:01:54 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
          [Wed Nov 12 16:01:54 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
          /var:
          1.9G    /var/
          889M    /var/cache
          870M    /var/cache/apt
          805M    /var/log
          793M    /var/cache/apt/archives
          Archived and active journals take up 782.1M in the file system.
          25M     /opt/iobroker/iobroker-data/objects.jsonl
          4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/nodejs         v22.21.0
          /usr/bin/node           v22.21.0
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          /usr/bin/corepack       0.34.0
          nodejs:
            Installed: 22.21.0-1nodesource1
            Candidate: 22.21.0-1nodesource1
            Version table:
           *** 22.21.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
               22.20.0-1nodesource1 1001
               22.19.0-1nodesource1 1001
               22.18.0-1nodesource1 1001
               22.17.1-1nodesource1 1001
               22.17.0-1nodesource1 1001
               22.16.0-1nodesource1 1001
               22.15.1-1nodesource1 1001
               22.15.0-1nodesource1 1001
               22.14.0-1nodesource1 1001
               22.13.1-1nodesource1 1001
               22.13.0-1nodesource1 1001
               22.12.0-1nodesource1 1001
               22.11.0-1nodesource1 1001
               22.10.0-1nodesource1 1001
               22.9.0-1nodesource1 1001
               22.8.0-1nodesource1 1001
               22.7.0-1nodesource1 1001
               22.6.0-1nodesource1 1001
               22.5.1-1nodesource1 1001
               22.5.0-1nodesource1 1001
               22.4.1-1nodesource1 1001
               22.4.0-1nodesource1 1001
               22.3.0-1nodesource1 1001
               22.2.0-1nodesource1 1001
               22.1.0-1nodesource1 1001
               22.0.0-1nodesource1 1001
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          ioBroker-V2         ioBroker-V2 (version: 7.0.7, hostname: ioBroker-V2   , alive, uptime: 32)
          admin:          7.7.19
          javascript:     8.9.2
          Adapter State
          + system.adapter.admin.0                  : admin                 : ioBroker-V2                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          + system.adapter.email.0                  : email                 : ioBroker-V2                              -  enabled
          + system.adapter.javascript.0             : javascript            : ioBroker-V2                              -  enabled
          + system.adapter.javascript.1             : javascript            : ioBroker-V2                              -  enabled
          + system.adapter.sql.0                    : sql                   : ioBroker-V2                              -  enabled, port: 3306
          + instance is alive
          Objects and States
          Objects:        24997
          States:         20033
          Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
          Pending Updates: 0
          tcp        0      0 192.168.178.121:2001    0.0.0.0:*               LISTEN      1001       66571      14348/io.hm-rpc.0
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17410      736/exim4
          tcp        0      0 192.168.178.121:1883    0.0.0.0:*               LISTEN      1001       61291      14044/io.mqtt.0
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       62504      12617/iobroker.js-c
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       59698      12617/iobroker.js-c
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15485      553/sshd: /usr/sbin
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       59780      12641/io.admin.0
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17411      736/exim4
          tcp6       0      0 :::22                   :::*                    LISTEN      0          15487      553/sshd: /usr/sbin
          udp        0      0 0.0.0.0:35015           0.0.0.0:*                           107        13947      440/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       65677      14275/io.chromecast
          udp        0      0 192.168.178.121:5353    0.0.0.0:*                           1001       64680      14141/io.tr-064.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        13945      440/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13849      376/dhclient
          udp6       0      0 :::36795                :::*                                107        13948      440/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                107        13946      440/avahi-daemon: r
          2025-11-12 16:31:21.431  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] connected with secret 1762961481430_2245
          2025-11-12 16:31:21.446  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] subscribes on "Wemos_DisplayV2_6/#" with regex /^Wemos_DisplayV2_6\..*/
          2025-11-12 16:31:21.447  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] subscribes on "Wemos_DisplayV2_6/#"  with regex /^mqtt\.0\.Wemos_DisplayV2_6\..*/
          2025-11-12 16:31:21.647  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] publishOnSubscribe send all known states
          2025-11-12 16:31:22.266  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 1(Jonny-Pixel3/3C:28:6D:E8:64:45) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
          2025-11-12 16:31:22.409  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 2(Jenny-Pixel3a/58:CB:52:8E:4E:68) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
          2025-11-12 16:31:22.548  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 3(Jonny-Arbeit-A40/F0:8A:76:20:A8:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
          2025-11-12 16:31:22.766  - info: chromecast.0 (14275) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.chromecast, node: v22.21.0, js-controller: 7.0.7
          2025-11-12 16:31:23.348  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 7(Pixel-3a/BA:DC:2D:6F:F1:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
          2025-11-12 16:31:23.407  - info: chromecast.0 (14275) Google_HomeKueche - Connected client
          2025-11-12 16:31:23.438  - info: chromecast.0 (14275) Küche - Connected client
          2025-11-12 16:31:23.905  - info: host.ioBroker-V2 instance system.adapter.hm-rpc.0 in version "2.0.2" started with pid 14348
          2025-11-12 16:31:26.245  - info: hm-rpc.0 (14348) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v22.21.0, js-controller: 7.0.7
          2025-11-12 16:31:26.463  - info: hm-rpc.0 (14348) xmlrpc server is trying to listen on 192.168.178.121:2001
          2025-11-12 16:31:26.464  - info: hm-rpc.0 (14348) xmlrpc client is trying to connect to 192.168.178.155:2001/ with ["http://192.168.178.121:2001","ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
          2025-11-12 16:31:26.492  - info: hm-rpc.0 (14348) xmlrpc <- system.listMethods ["ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
          2025-11-12 16:31:26.498  - info: hm-rpc.0 (14348) xmlrpc <- listDevices ["ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
          2025-11-12 16:31:26.528  - info: hm-rpc.0 (14348) xmlrpc -> 64 devices
          2025-11-12 16:31:26.547  - info: hm-rpc.0 (14348) Connected
          2025-11-12 16:31:27.831  - info: host.ioBroker-V2 instance system.adapter.hm-rega.0 in version "5.1.0" started with pid 14782
          2025-11-12 16:31:30.487  - info: hm-rega.0 (14782) starting. Version 5.1.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v22.21.0, js-controller: 7.0.7
          2025-11-12 16:31:30.694  - info: hm-rega.0 (14782) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
          2025-11-12 16:31:30.763  - info: hm-rega.0 (14782) ReGaHSS 192.168.178.155 up
          2025-11-12 16:31:30.869  - info: hm-rega.0 (14782) time difference local-ccu 1s
          2025-11-12 16:31:31.325  - info: hm-rega.0 (14782) request state values
          Ro75R 1 Antwort Letzte Antwort
          • G Offline
            George_Best
            #45
            1. npm ls:
            cd /opt/iobroker
            npm ls
            npm ls graceful-fs
            ── component-inherit@ extraneous
            ├── compress-commons@ extraneous
            ├── compressible@ extraneous
            ├── compression@ extraneous
            ├── concat-map@ extraneous
            ├── concat-stream@ extraneous
            ├── connect-flash@ extraneous
            ├── connect-history-api-fallback@ extraneous
            ├── connect@ extraneous
            ├── console-control-strings@ extraneous
            ├── content-disposition@ extraneous
            ├── content-type@ extraneous
            ├── cookie-parser@ extraneous
            ├── cookie-signature@ extraneous
            ├── cookie@ extraneous
            ├── core-util-is@ extraneous
            ├── cors@ extraneous
            ├── country-data@ extraneous
            ├── cpu-features@ extraneous
            ├── crc-32@ extraneous
            ├── crc32-stream@ extraneous
            ├── cron-parser@ extraneous
            ├── cron@ extraneous
            ├── cross-spawn@ extraneous
            ├── crypto-js@ extraneous
            ├── css-select@ extraneous
            ├── css-what@ extraneous
            ├── cssom@ extraneous
            ├── cssstyle@ extraneous
            ├── currency-symbol-map@ extraneous
            ├── cycle@ extraneous
            ├── dashdash@ extraneous
            ├── data-view-buffer@ extraneous
            ├── data-view-byte-length@ extraneous
            ├── data-view-byte-offset@ extraneous
            ├── dateformat@ extraneous
            ├── dbus-next@ extraneous
            ├── debug@ extraneous
            ├── decache@ extraneous
            ├── decamelize@ extraneous
            ├── decompress-response@ extraneous
            ├── deep-clone@ extraneous
            ├── deep-eql@ extraneous
            ├── deep-extend@0.6.0 extraneous
            ├── deep-is@ extraneous
            ├── define-data-property@ extraneous
            ├── define-lazy-prop@ extraneous
            ├── define-properties@ extraneous
            ├── delayed-stream@ extraneous
            ├── delegates@ extraneous
            ├── denque@ extraneous
            ├── depd@ extraneous
            ├── destroy@ extraneous
            ├── detect-libc@ extraneous
            ├── dev-ip@ extraneous
            ├── dev-null@ extraneous
            ├── dgram@ extraneous
            ├── diff@ extraneous
            ├── diskusage@ extraneous
            ├── dns-packet@ extraneous
            ├── docker-modem@ extraneous
            ├── dockerode@ extraneous
            ├── dom-compare-temp@ extraneous
            ├── dom-serializer@ extraneous
            ├── domelementtype@ extraneous
            ├── domhandler@ extraneous
            ├── domutils@ extraneous
            ├── dunder-proto@ extraneous
            ├── duplexer@ extraneous
            ├── duplexify@ extraneous
            ├── eastasianwidth@ extraneous
            ├── easy-extender@ extraneous
            ├── eazy-logger@ extraneous
            ├── ecc-jsbn@ extraneous
            ├── ecdsa-sig-formatter@ extraneous
            ├── ee-first@ extraneous
            ├── emoji-regex@ extraneous
            ├── enabled@ extraneous
            ├── encodeurl@ extraneous
            ├── encoding-sniffer@ extraneous
            ├── encoding@ extraneous
            ├── end-of-stream@ extraneous
            ├── engine.io-client@ extraneous
            ├── engine.io-parser@ extraneous
            ├── engine.io@ extraneous
            ├── enquirer@ extraneous
            ├── entities@ extraneous
            ├── env-paths@ extraneous
            ├── err-code@ extraneous
            ├── error-ex@ extraneous
            ├── es-abstract@ extraneous
            ├── es-aggregate-error@ extraneous
            ├── es-define-property@ extraneous
            ├── es-errors@ extraneous
            ├── es-object-atoms@ extraneous
            ├── es-set-tostringtag@ extraneous
            ├── es-shim-unscopables@ extraneous
            ├── es-to-primitive@ extraneous
            ├── es6-promise@ extraneous
            ├── esbuild@ extraneous
            ├── escalade@ extraneous
            ├── escape-html@ extraneous
            ├── escape-string-regexp@ extraneous
            ├── escodegen@ extraneous
            ├── esprima@ extraneous
            ├── estraverse@ extraneous
            ├── esutils@ extraneous
            ├── etag@ extraneous
            ├── event-stream@ extraneous
            ├── event-target-shim@ extraneous
            ├── eventemitter2@ extraneous
            ├── eventemitter3@ extraneous
            ├── events-universal@ extraneous
            ├── events@ extraneous
            ├── evilscan@ extraneous
            ├── execa@ extraneous
            ├── expand-template@ extraneous
            ├── exponential-backoff@ extraneous
            ├── express-fileupload@ extraneous
            ├── express-session@ extraneous
            ├── express@ extraneous
            ├── extend@3.0.2 extraneous
            ├── extsprintf@ extraneous
            ├── eyes@ extraneous
            ├── fast-deep-equal@ extraneous
            ├── fast-fifo@ extraneous
            ├── fast-glob@ extraneous
            ├── fast-json-stable-stringify@ extraneous
            ├── fast-levenshtein@ extraneous
            ├── fast-unique-numbers@ extraneous
            ├── fast-uri@ extraneous
            ├── fast-xml-parser@ extraneous
            ├── fastq@ extraneous
            ├── fecha@ extraneous
            ├── fetch-enhanced@ extraneous
            ├── file-stream-rotator@ extraneous
            ├── file-type@ extraneous
            ├── file-uri-to-path@ extraneous
            ├── fill-range@ extraneous
            ├── finalhandler@ extraneous
            ├── find-up@ extraneous
            ├── find-yarn-workspace-root@ extraneous
            ├── flat@ extraneous
            ├── fn.name@ extraneous
            ├── follow-redirects@ extraneous
            ├── for-each@ extraneous
            ├── foreground-child@ extraneous
            ├── forever-agent@ extraneous
            ├── form-data@ extraneous
            ├── forwarded@ extraneous
            ├── fresh@ extraneous
            ├── from@ extraneous
            ├── fs-constants@1.0.0 extraneous
            ├── fs-extra@7.0.1
            ├── fs-minipass@ extraneous
            ├── fs.realpath@ extraneous
            ├── fsevents@ extraneous
            ├── ftp-response-parser@ extraneous
            ├── function-bind@ extraneous
            ├── function.prototype.name@ extraneous
            ├── functions-have-names@ extraneous
            ├── gauge@ extraneous
            ├── gaxios@ extraneous
            ├── gcp-metadata@ extraneous
            ├── generate-function@ extraneous
            ├── generator-function@ extraneous
            ├── get-caller-file@1.0.3 extraneous
            ├── get-func-name@ extraneous
            ├── get-intrinsic@ extraneous
            ├── get-proto@ extraneous
            ├── get-stream@ extraneous
            ├── get-symbol-description@ extraneous
            ├── getpass@ extraneous
            ├── github-from-package@ extraneous
            ├── glob-parent@ extraneous
            ├── glob@ extraneous
            ├── globalthis@ extraneous
            ├── glossy@ extraneous
            ├── google-auth-library@ extraneous
            ├── google-logging-utils@ extraneous
            ├── google-tts-api@ extraneous
            ├── googleapis-common@ extraneous
            ├── googleapis@ extraneous
            ├── gopd@ extraneous
            ├── gtoken@ extraneous
            ├── har-schema@ extraneous
            ├── har-validator@ extraneous
            ├── has-bigints@ extraneous
            ├── has-binary@ extraneous
            ├── has-binary2@1.0.3 extraneous
            ├── has-cors@ extraneous
            ├── has-flag@ extraneous
            ├── has-property-descriptors@ extraneous
            ├── has-proto@ extraneous
            ├── has-symbols@ extraneous
            ├── has-tostringtag@ extraneous
            ├── has-unicode@ extraneous
            ├── hasown@ extraneous
            ├── he@ extraneous
            ├── help-me@ extraneous
            ├── hexy@ extraneous
            ├── homematic-xmlrpc@ extraneous
            ├── hosted-git-info@ extraneous
            ├── htmlparser2@ extraneous
            ├── http-cache-semantics@ extraneous
            ├── http-errors@ extraneous
            ├── http-proxy-agent@ extraneous
            ├── http-proxy-middleware@ extraneous
            ├── http-proxy@ extraneous
            ├── http-signature@ extraneous
            ├── https-proxy-agent@ extraneous
            ├── https@ extraneous
            ├── human-signals@ extraneous
            ├── humanize-ms@ extraneous
            ├── iconv-lite@ extraneous
            ├── icy@ extraneous
            ├── ieee754@ extraneous
            ├── ignore-by-default@ extraneous
            ├── immediate@ extraneous
            ├── immutable@ extraneous
            ├── imurmurhash@ extraneous
            ├── indent-string@ extraneous
            ├── indexof@ extraneous
            ├── infer-owner@ extraneous
            ├── inflight@ extraneous
            ├── influx@ extraneous
            ├── inherits@ extraneous
            ├── ini@ extraneous
            ├── int64-buffer@ extraneous
            ├── internal-slot@ extraneous
            ├── invert-kv@ extraneous
            ├── iobroker.accuweather@ invalid: "2.1.1" from the root project
            ├── iobroker.admin@ invalid: "7.7.19" from the root project
            ├── iobroker.alias-manager@ invalid: "2.0.0" from the root project
            ├── iobroker.amazon-dash@ invalid: "1.2.0" from the root project
            ├── iobroker.chromecast@ invalid: "4.0.0" from the root project
            ├── iobroker.cloud@ invalid: "5.0.1" from the root project
            ├── iobroker.daswetter@ invalid: "3.2.3" from the root project
            ├── iobroker.deconz@ invalid: "1.6.4" from the root project
            ├── iobroker.devices@ invalid: "1.2.8" from the root project
            ├── iobroker.discovery@ invalid: "5.0.0" from the root project
            ├── iobroker.email@ invalid: "2.0.4" from the root project
            ├── iobroker.flot@ invalid: "1.12.0" from the root project
            ├── iobroker.fronius-solarweb@ invalid: "0.0.3" from the root project
            ├── iobroker.fronius@ invalid: "2.1.1" from the root project
            ├── iobroker.frontier_silicon@ invalid: "0.5.0" from the root project
            ├── iobroker.habpanel@ invalid: "0.5.0" from the root project
            ├── iobroker.history@ invalid: "3.0.1" from the root project
            ├── iobroker.hm-rega@ invalid: "5.1.0" from the root project
            ├── iobroker.hm-rpc@ invalid: "2.0.2" from the root project
            ├── iobroker.hs100@ invalid: "3.0.5" from the root project
            ├── iobroker.icons-addictive-flavour-png@ invalid: "^0.1.0" from the root project
            ├── iobroker.icons-fatcow-hosting@ invalid: "^0.1.0" from the root project
            ├── iobroker.icons-icons8@ invalid: "0.0.1" from the root project
            ├── iobroker.icons-material-png@ invalid: "^0.1.0" from the root project
            ├── iobroker.icons-material-svg@ invalid: "^0.1.0" from the root project
            ├── iobroker.icons-mfd-png@ invalid: "1.2.1" from the root project
            ├── iobroker.icons-mfd-svg@ invalid: "1.2.0" from the root project
            ├── iobroker.icons-open-icon-library-png@ invalid: "0.1.2" from the root project
            ├── iobroker.icons-ultimate-png@ invalid: "^1.0.1" from the root project
            ├── iobroker.influxdb@ invalid: "4.0.2" from the root project
            ├── iobroker.info@ invalid: "2.0.0" from the root project
            ├── iobroker.iot@ invalid: "5.0.7" from the root project
            ├── iobroker.javascript@ invalid: "8.9.2" from the root project
            ├── iobroker.js-controller@ invalid: "^7.0.7" from the root project
            ├── iobroker.mihome-vacuum@ invalid: "5.2.0" from the root project
            ├── iobroker.mqtt@ invalid: "6.1.4" from the root project
            ├── iobroker.net-tools@ invalid: "1.1.2" from the root project
            ├── iobroker.octoprint@ invalid: "5.1.0" from the root project
            ├── iobroker.openweathermap@ invalid: "1.1.2" from the root project
            ├── iobroker.parser@ invalid: "2.2.4" from the root project
            ├── iobroker.ping@ invalid: "1.6.2" from the root project
            ├── iobroker.proxmox@ invalid: "2.4.0" from the root project
            ├── iobroker.radar@ invalid: "^1.2.1" from the root project
            ├── iobroker.radar2@ invalid: "^2.0.3" from the root project
            ├── iobroker.reolink@ invalid: "1.2.3" from the root project
            ├── iobroker.rickshaw@ invalid: "^1.0.0" from the root project
            ├── iobroker.s7@ invalid: "1.5.0" from the root project
            ├── iobroker.sayit@ invalid: "5.0.0" from the root project
            ├── iobroker.smartmeter@ invalid: "3.4.0" from the root project
            ├── iobroker.socketio@ invalid: "6.7.1" from the root project
            ├── iobroker.sql@ invalid: "3.0.1" from the root project
            ├── iobroker.statistics@ invalid: "2.4.0" from the root project
            ├── iobroker.systeminfo@ invalid: "1.3.0" from the root project
            ├── iobroker.telegram@ invalid: "4.1.0" from the root project
            ├── iobroker.terminal@ invalid: "1.0.0" from the root project
            ├── iobroker.tr-064@ invalid: "4.3.0" from the root project
            ├── iobroker.unifi@ invalid: "0.7.0" from the root project
            ├── iobroker.upnp@ invalid: "1.1.0" from the root project
            ├── iobroker.vis-2-widgets-inventwo@ invalid: "0.2.2" from the root project
            ├── iobroker.vis-2-widgets-material@ invalid: "1.4.10" from the root project
            ├── iobroker.vis-2@ invalid: "2.13.4" from the root project
            ├── iobroker.vis-bars@ invalid: "^0.1.4" from the root project
            ├── iobroker.vis-canvas-gauges@ invalid: "1.0.1" from the root project
            ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
            ├── iobroker.vis-fancyswitch@ invalid: "^1.1.0" from the root project
            ├── iobroker.vis-google-fonts@ invalid: "1.0.4" from the root project
            ├── iobroker.vis-history@ invalid: "^1.0.0" from the root project
            ├── iobroker.vis-hqwidgets@ invalid: "1.5.1" from the root project
            ├── iobroker.vis-jqui-mfd@ invalid: "^1.0.12" from the root project
            ├── iobroker.vis-justgage@ invalid: "2.1.7" from the root project
            ├── iobroker.vis-keyboard@ invalid: "0.0.2" from the root project
            ├── iobroker.vis-lcars@ invalid: "1.1.1" from the root project
            ├── iobroker.vis-map@ invalid: "1.1.2" from the root project
            ├── iobroker.vis-materialdesign@ invalid: "0.5.9" from the root project
            ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
            ├── iobroker.vis-rgraph@ invalid: "0.0.2" from the root project
            ├── iobroker.vis-weather@ invalid: "2.5.12" from the root project
            ├── iobroker.vis@ invalid: "1.5.6" from the root project
            ├── iobroker.weatherunderground@ invalid: "3.7.0" from the root project
            ├── iobroker.web@ invalid: "7.0.8" from the root project
            ├── iobroker.ws@ invalid: "2.6.2" from the root project
            ├── iobroker@ invalid: "^2.0.2" from the root project
            ├── ioredis@ extraneous
            ├── ip-address@ extraneous
            ├── ip@ extraneous
            ├── ipaddr.js@ extraneous
            ├── is-arguments@ extraneous
            ├── is-array-buffer@ extraneous
            ├── is-arrayish@ extraneous
            ├── is-async-function@ extraneous
            ├── is-bigint@ extraneous
            ├── is-binary-path@ extraneous
            ├── is-boolean-object@ extraneous
            ├── is-callable@ extraneous
            ├── is-core-module@ extraneous
            ├── is-data-view@ extraneous
            ├── is-date-object@ extraneous
            ├── is-docker@ extraneous
            ├── is-extglob@ extraneous
            ├── is-finalizationregistry@ extraneous
            ├── is-fullwidth-code-point@ extraneous
            ├── is-generator-function@ extraneous
            ├── is-generator@ extraneous
            ├── is-glob@ extraneous
            ├── is-lambda@ extraneous
            ├── is-map@ extraneous
            ├── is-negative-zero@ extraneous
            ├── is-number-like@ extraneous
            ├── is-number-object@ extraneous
            ├── is-number@ extraneous
            ├── is-path-inside@ extraneous
            ├── is-plain-obj@ extraneous
            ├── is-plain-object@ extraneous
            ├── is-promise@ extraneous
            ├── is-property@ extraneous
            ├── is-regex@ extraneous
            ├── is-set@ extraneous
            ├── is-shared-array-buffer@ extraneous
            ├── is-stream@ extraneous
            ├── is-string@ extraneous
            ├── is-symbol@ extraneous
            ├── is-typed-array@ extraneous
            ├── is-typedarray@ extraneous
            ├── is-unicode-supported@ extraneous
            ├── is-utf8@ extraneous
            ├── is-weakmap@ extraneous
            ├── is-weakref@ extraneous
            ├── is-weakset@ extraneous
            ├── is-wsl@ extraneous
            ├── is@ extraneous
            ├── isarray@ extraneous
            ├── isexe@ extraneous
            ├── isomorphic-ws@ extraneous
            ├── isstream@ extraneous
            ├── jackspeak@ extraneous
            ├── jose@ extraneous
            ├── js-md4@ extraneous
            ├── js-sdsl@ extraneous
            ├── js-yaml@ extraneous
            ├── jsbi@ extraneous
            ├── jsbn@ extraneous
            ├── jsdom@ extraneous
            ├── jsftp@ extraneous
            ├── jshashes@ extraneous
            ├── json-bigint@ extraneous
            ├── json-logic-js@ extraneous
            ├── json-schema-traverse@ extraneous
            ├── json-schema@ extraneous
            ├── json-stable-stringify@ extraneous
            ├── json-stringify-safe@ extraneous
            ├── json3@ extraneous
            ├── json5@ extraneous
            ├── jsonata@ extraneous
            ├── jsonc-parser@ extraneous
            ├── jsonify@ extraneous
            ├── jsonwebtoken@ extraneous
            ├── jsprim@ extraneous
            ├── jszip@ extraneous
            ├── jwa@ extraneous
            ├── jwks-rsa@ extraneous
            ├── jws@ extraneous
            ├── klaw-sync@ extraneous
            ├── kuler@ extraneous
            ├── lazystream@ extraneous
            ├── lcid@ extraneous
            ├── leven@ extraneous
            ├── levn@ extraneous
            ├── lie@ extraneous
            ├── limiter@ extraneous
            ├── load-json-file@ extraneous
            ├── loadavg-windows@ extraneous
            ├── localforage@ extraneous
            ├── locate-path@ extraneous
            ├── lodash.camelcase@ extraneous
            ├── lodash.castarray@ extraneous
            ├── lodash.clone@ extraneous
            ├── lodash.clonedeep@ extraneous
            ├── lodash.defaults@ extraneous
            ├── lodash.defaultto@ extraneous
            ├── lodash.flatten@ extraneous
            ├── lodash.get@ extraneous
            ├── lodash.groupby@ extraneous
            ├── lodash.includes@ extraneous
            ├── lodash.isarguments@ extraneous
            ├── lodash.isboolean@ extraneous
            ├── lodash.isequal@ extraneous
            ├── lodash.isfinite@ extraneous
            ├── lodash.isinteger@ extraneous
            ├── lodash.isnumber@ extraneous
            ├── lodash.isplainobject@ extraneous
            ├── lodash.isstring@ extraneous
            ├── lodash.once@ extraneous
            ├── lodash.truncate@ extraneous
            ├── lodash@ extraneous
            ├── log-symbols@ extraneous
            ├── logform@ extraneous
            ├── loglevel@ extraneous
            ├── long-timeout@ extraneous
            ├── long@ extraneous
            ├── loupe@ extraneous
            ├── lru-cache@ extraneous
            ├── lru-memoizer@ extraneous
            ├── lru.min@ extraneous
            ├── luxon@ extraneous
            ├── make-dir@ extraneous
            ├── make-fetch-happen@ extraneous
            ├── map-stream@ extraneous
            ├── math-intrinsics@ extraneous
            ├── mdns-discovery@ extraneous
            ├── mdns@ extraneous
            ├── media-typer@ extraneous
            ├── merge-descriptors@ extraneous
            ├── merge-stream@ extraneous
            ├── merge2@ extraneous
            ├── methods@ extraneous
            ├── micromatch@ extraneous
            ├── mime-db@ extraneous
            ├── mime-types@ extraneous
            ├── mime@ extraneous
            ├── mimic-fn@ extraneous
            ├── mimic-response@ extraneous
            ├── minimatch@ extraneous
            ├── minimist@ extraneous
            ├── minipass-collect@ extraneous
            ├── minipass-fetch@ extraneous
            ├── minipass-flush@ extraneous
            ├── minipass-pipeline@ extraneous
            ├── minipass-sized@ extraneous
            ├── minipass@ extraneous
            ├── minizlib@ extraneous
            ├── mitt@ extraneous
            ├── mkdirp-classic@ extraneous
            ├── mkdirp@ extraneous
            ├── mocha@ extraneous
            ├── moment@ extraneous
            ├── mp3-duration@ extraneous
            ├── mqtt-connection@ extraneous
            ├── mqtt-packet@ extraneous
            ├── mqtt@ extraneous
            ├── ms@ extraneous
            ├── mssql@ extraneous
            ├── multicast-dns@ extraneous
            ├── mute-stream@ extraneous
            ├── mysql2@ extraneous
            ├── named-placeholders@ extraneous
            ├── nan@ extraneous
            ├── napi-build-utils@ extraneous
            ├── napi-thread-safe-callback@ extraneous
            ├── native-duplexpair@ extraneous
            ├── needle@ extraneous
            ├── negotiator@ extraneous
            ├── net-ping@ extraneous
            ├── netmask@ extraneous
            ├── noble@ extraneous
            ├── node-abi@ extraneous
            ├── node-abort-controller@ extraneous
            ├── node-addon-api@ extraneous
            ├── node-arp@ extraneous
            ├── node-ble@ extraneous
            ├── node-fetch@ extraneous
            ├── node-forge@ extraneous
            ├── node-gyp-build@ extraneous
            ├── node-gyp@ extraneous
            ├── node-inspect@ extraneous
            ├── node-mndp@ extraneous
            ├── node-schedule@ extraneous
            ├── node-snap7@ extraneous
            ├── node-ssdp@ extraneous
            ├── node-telegram-bot-api@ extraneous
            ├── node-unifi@ extraneous
            ├── node.extend@ extraneous
            ├── nodemailer@ extraneous
            ├── nodemon@ extraneous
            ├── nopt@ extraneous
            ├── normalize-package-data@ extraneous
            ├── normalize-path@ extraneous
            ├── npm-run-path@ extraneous
            ├── npmlog@ extraneous
            ├── nth-check@ extraneous
            ├── number-allocator@ extraneous
            ├── number-is-nan@ extraneous
            ├── nwmatcher@ extraneous
            ├── oauth-sign@0.9.0 extraneous
            ├── oauth2-server@ extraneous
            ├── object-assign@ extraneous
            ├── object-component@ extraneous
            ├── object-hash@ extraneous
            ├── object-inspect@ extraneous
            ├── object-keys@ extraneous
            ├── object.assign@ extraneous
            ├── on-finished@ extraneous
            ├── on-headers@ extraneous
            ├── once@ extraneous
            ├── one-time@ extraneous
            ├── onetime@ extraneous
            ├── open-sml@ extraneous
            ├── open@ extraneous
            ├── opn@ extraneous
            ├── optionator@ extraneous
            ├── options@ extraneous
            ├── os-locale@ extraneous
            ├── osx-temperature-sensor@ extraneous
            ├── oui@ extraneous
            ├── own-keys@ extraneous
            ├── p-limit@ extraneous
            ├── p-locate@ extraneous
            ├── p-map@ extraneous
            ├── package-json-from-dist@ extraneous
            ├── pako@ extraneous
            ├── parse-json@ extraneous
            ├── parse-listing@ extraneous
            ├── parse5-htmlparser2-tree-adapter@ extraneous
            ├── parse5-parser-stream@ extraneous
            ├── parse5@ extraneous
            ├── parsejson@ extraneous
            ├── parseqs@ extraneous
            ├── parseuri@ extraneous
            ├── parseurl@ extraneous
            ├── parsexmlresponse@ extraneous
            ├── passport-local@ extraneous
            ├── passport-strategy@ extraneous
            ├── passport@ extraneous
            ├── patch-package@ extraneous
            ├── path-exists@ extraneous
            ├── path-is-absolute@ extraneous
            ├── path-key@ extraneous
            ├── path-parse@ extraneous
            ├── path-scurry@ extraneous
            ├── path-to-regexp@ extraneous
            ├── path-type@ extraneous
            ├── pathval@ extraneous
            ├── pause-stream@ extraneous
            ├── pause@ extraneous
            ├── pcap@ extraneous
            ├── performance-now@ extraneous
            ├── pg-cloudflare@ extraneous
            ├── pg-connection-string@ extraneous
            ├── pg-int8@ extraneous
            ├── pg-pool@ extraneous
            ├── pg-protocol@ extraneous
            ├── pg-types@ extraneous
            ├── pg@ extraneous
            ├── pgpass@ extraneous
            ├── picocolors@ extraneous
            ├── picomatch@ extraneous
            ├── pidtree@ extraneous
            ├── pidusage@ extraneous
            ├── pify@ extraneous
            ├── ping@ extraneous
            ├── pinkie-promise@ extraneous
            ├── pinkie@ extraneous
            ├── playlist-parser@ extraneous
            ├── portfinder@ extraneous
            ├── portscanner@ extraneous
            ├── possible-typed-array-names@ extraneous
            ├── postgres-array@ extraneous
            ├── postgres-bytea@ extraneous
            ├── postgres-date@ extraneous
            ├── postgres-interval@ extraneous
            ├── prebuild-install@ extraneous
            ├── prelude-ls@ extraneous
            ├── proc-log@ extraneous
            ├── process-nextick-args@ extraneous
            ├── process@ extraneous
            ├── promise-inflight@ extraneous
            ├── promise-queue@ extraneous
            ├── promise-retry@ extraneous
            ├── promisify-any@ extraneous
            ├── promisify-child-process@ extraneous
            ├── prompt@ extraneous
            ├── protobufjs@ extraneous
            ├── proxy-addr@ extraneous
            ├── proxy-from-env@ extraneous
            ├── ps-tree@ extraneous
            ├── psl@ extraneous
            ├── pstree.remy@ extraneous
            ├── pump@ extraneous
            ├── punycode@ extraneous
            ├── put@ extraneous
            ├── q@ extraneous
            ├── qjobs@ extraneous
            ├── qs@ extraneous
            ├── querystringify@ extraneous
            ├── queue-microtask@ extraneous
            ├── quick-lru@ extraneous
            ├── random-bytes@ extraneous
            ├── randombytes@ extraneous
            ├── range-parser@ extraneous
            ├── raw-body@ extraneous
            ├── raw-socket@ extraneous
            ├── rc@1.2.8 extraneous
            ├── read-pkg-up@ extraneous
            ├── read-pkg@ extraneous
            ├── read@ extraneous
            ├── readable-stream@ extraneous
            ├── readdir-glob@ extraneous
            ├── readdirp@ extraneous
            ├── readline-sync@ extraneous
            ├── readline@ extraneous
            ├── redis-errors@ extraneous
            ├── redis-parser@ extraneous
            ├── reflect.getprototypeof@ extraneous
            ├── regexp.prototype.flags@ extraneous
            ├── reinterval@ extraneous
            ├── request-promise-core@ extraneous
            ├── request@ extraneous
            ├── require-directory@ extraneous
            ├── require-from-string@ extraneous
            ├── require-main-filename@ extraneous
            ├── requires-port@ extraneous
            ├── resolve@ extraneous
            ├── resp-modifier@ extraneous
            ├── respjs@ extraneous
            ├── retry@ extraneous
            ├── reusify@ extraneous
            ├── revalidator@ extraneous
            ├── rfdc@ extraneous
            ├── rimraf@ extraneous
            ├── router@ extraneous
            ├── run-parallel@ extraneous
            ├── rx@ extraneous
            ├── safe-array-concat@ extraneous
            ├── safe-buffer@ extraneous
            ├── safe-push-apply@ extraneous
            ├── safe-regex-test@ extraneous
            ├── safe-stable-stringify@ extraneous
            ├── safer-buffer@2.1.2 extraneous
            ├── sax@ extraneous
            ├── semver@ invalid: "^5.6.0" from the root project
            ├── send@ extraneous
            ├── seq-logging@ extraneous
            ├── seq-queue@ extraneous
            ├── serialize-javascript@ extraneous
            ├── serialport@ extraneous
            ├── serve-index@ extraneous
            ├── serve-static@ extraneous
            ├── server-destroy@ extraneous
            ├── set-blocking@ extraneous
            ├── set-function-length@ extraneous
            ├── set-function-name@ extraneous
            ├── set-proto@ extraneous
            ├── setimmediate@ extraneous
            ├── setprototypeof@ extraneous
            ├── shebang-command@ extraneous
            ├── shebang-regex@ extraneous
            ├── side-channel-list@ extraneous
            ├── side-channel-map@ extraneous
            ├── side-channel-weakmap@ extraneous
            ├── side-channel@ extraneous
            ├── siginfo@ extraneous
            ├── signal-exit@ extraneous
            ├── simple-concat@ extraneous
            ├── simple-get@ extraneous
            ├── simple-update-notifier@ extraneous
            ├── sinon-chai@ extraneous
            ├── sinon@ extraneous
            ├── slash@ extraneous
            ├── slice-ansi@ extraneous
            ├── smart-buffer@ extraneous
            ├── smartmeter-obis@ extraneous
            ├── socket.io-adapter@ extraneous
            ├── socket.io-client@ extraneous
            ├── socket.io-parser@ extraneous
            ├── socket.io@ extraneous
            ├── socks-proxy-agent@ extraneous
            ├── socks@ extraneous
            ├── sorted-array-functions@ extraneous
            ├── source-map-support@ extraneous
            ├── source-map@ extraneous
            ├── spdx-correct@ extraneous
            ├── spdx-exceptions@ extraneous
            ├── spdx-expression-parse@ extraneous
            ├── spdx-license-ids@ extraneous
            ├── split-ca@ extraneous
            ├── split@ extraneous
            ├── split2@ extraneous
            ├── sprintf-js@ extraneous
            ├── sql-client@ extraneous
            ├── sqlite3@ extraneous
            ├── sqlstring@ extraneous
            ├── ssh2@ extraneous
            ├── sshpk@ extraneous
            ├── ssri@ extraneous
            ├── stack-trace@ extraneous
            ├── stackback@ extraneous
            ├── standard-as-callback@ extraneous
            ├── statuses@ extraneous
            ├── stealthy-require@ extraneous
            ├── stop-iteration-iterator@ extraneous
            ├── stoppable@ extraneous
            ├── stream-combiner@ extraneous
            ├── stream-parser@ extraneous
            ├── stream-shift@ extraneous
            ├── stream-throttle@ extraneous
            ├── streamsearch@ extraneous
            ├── streamx@ extraneous
            ├── string_decoder@ extraneous
            ├── string-width-cjs@ extraneous
            ├── string-width@ extraneous
            ├── string.prototype.trim@ extraneous
            ├── string.prototype.trimend@ extraneous
            ├── string.prototype.trimstart@ extraneous
            ├── strip-ansi-cjs@ extraneous
            ├── strip-ansi@ extraneous
            ├── strip-bom@ extraneous
            ├── strip-final-newline@ extraneous
            ├── strip-json-comments@ extraneous
            ├── strnum@ extraneous
            ├── suncalc2@ extraneous
            ├── supports-color@ extraneous
            ├── supports-preserve-symlinks-flag@ extraneous
            ├── symbol-tree@ extraneous
            ├── systeminformation@ extraneous
            ├── table@ extraneous
            ├── tar-fs@ extraneous
            ├── tar-stream@ extraneous
            ├── tar@ extraneous
            ├── tarn@ extraneous
            ├── tedious@ extraneous
            ├── text-decoder@ extraneous
            ├── text-hex@ extraneous
            ├── text-table@ extraneous
            ├── through@ extraneous
            ├── through2@ extraneous
            ├── thunky@ extraneous
            ├── tldts-core@ extraneous
            ├── tldts@ extraneous
            ├── tmp@ extraneous
            ├── to-array@ extraneous
            ├── to-regex-range@ extraneous
            ├── toidentifier@ extraneous
            ├── touch@ extraneous
            ├── tough-cookie@ extraneous
            ├── tplink-smarthome-api@ extraneous
            ├── tplink-smarthome-crypto@ extraneous
            ├── tr-O64@ extraneous
            ├── tr46@ extraneous
            ├── traverse@ extraneous
            ├── treemap-js@ extraneous
            ├── triple-beam@ extraneous
            ├── tslib@ extraneous
            ├── tunnel-agent@ extraneous
            ├── tweetnacl@ extraneous
            ├── type-check@ extraneous
            ├── type-detect@ extraneous
            ├── type-fest@ extraneous
            ├── type-is@ extraneous
            ├── typed-array-buffer@ extraneous
            ├── typed-array-byte-length@ extraneous
            ├── typed-array-byte-offset@ extraneous
            ├── typed-array-length@ extraneous
            ├── typedarray@ extraneous
            ├── typescript@ extraneous
            ├── ua-parser-js@ extraneous
            ├── uid-number@ extraneous
            ├── uid-safe@2.1.5 extraneous
            ├── ultron@ extraneous
            ├── unbox-primitive@ extraneous
            ├── undefsafe@ extraneous
            ├── underscore@ extraneous
            ├── undici-types@ extraneous
            ├── undici@ extraneous
            ├── unique-filename@ extraneous
            ├── unique-slug@ extraneous
            ├── unix-dgram@ extraneous
            ├── unorm@ extraneous
            ├── unpipe@ extraneous
            ├── uri-js@ extraneous
            ├── url-parse@ extraneous
            ├── url-template@ extraneous
            ├── url@ extraneous
            ├── usb@ extraneous
            ├── usocket@ extraneous
            ├── util-deprecate@ extraneous
            ├── util@ extraneous
            ├── utils-merge@ extraneous
            ├── uuid@ extraneous
            ├── validate-npm-package-license@3.0.4 extraneous
            ├── vary@ extraneous
            ├── verror@ extraneous
            ├── virtual-tsc@ extraneous
            ├── wake_on_lan@ extraneous
            ├── weak-daemon@ extraneous
            ├── webidl-conversions@ extraneous
            ├── websocket-stream@ extraneous
            ├── whatwg-encoding@ extraneous
            ├── whatwg-mimetype@ extraneous
            ├── whatwg-url-compat@ extraneous
            ├── whatwg-url@ extraneous
            ├── which-boxed-primitive@ extraneous
            ├── which-builtin-type@ extraneous
            ├── which-collection@ extraneous
            ├── which-module@ extraneous
            ├── which-typed-array@ extraneous
            ├── which@ extraneous
            ├── why-is-node-running@ extraneous
            ├── wide-align@ extraneous
            ├── widest-line@ extraneous
            ├── winston-daily-rotate-file@ extraneous
            ├── winston-seq-updated@ extraneous
            ├── winston-syslog@ extraneous
            ├── winston-transport@ extraneous
            ├── winston@ extraneous
            ├── wol@ extraneous
            ├── word-wrap@ extraneous
            ├── worker-factory@ extraneous
            ├── worker-timers-broker@ extraneous
            ├── worker-timers-worker@ extraneous
            ├── worker-timers@ extraneous
            ├── workerpool@ extraneous
            ├── wrap-ansi-cjs@ extraneous
            ├── wrap-ansi@ extraneous
            ├── wrappy@ extraneous
            ├── ws@ extraneous
            ├── wtf-8@ extraneous
            ├── xml-name-validator@ extraneous
            ├── xml2js@ extraneous
            ├── xml2json-light@ extraneous
            ├── xmlbuilder@ extraneous
            ├── xmldom@ extraneous
            ├── xmlhttprequest-ssl@ extraneous
            ├── xmlhttprequest@ extraneous
            ├── xpc-connection@ extraneous
            ├── xtend@ extraneous
            ├── y18n@ extraneous
            ├── yallist@ extraneous
            ├── yaml@ extraneous
            ├── yargs-parser@ extraneous
            ├── yargs-unparser@ extraneous
            ├── yargs@ invalid: "^7.0.2" from the root project
            ├── yeast@ extraneous
            ├── yocto-queue@ extraneous
            ├── youtube-remote@ extraneous
            └── zip-stream@ extraneous
            npm error code ELSPROBLEMS
            npm error extraneous: @abandonware/bluetooth-hci-socket@ /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
            npm error extraneous: @abandonware/noble@ /opt/iobroker/node_modules/@abandonware/noble
            npm error extraneous: @alcalzone/esbuild-register@ /opt/iobroker/node_modules/@alcalzone/esbuild-register
            npm error extraneous: @alcalzone/jsonl-db@ /opt/iobroker/node_modules/@alcalzone/jsonl-db
            npm error extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/@alcalzone/pak
            npm error extraneous: @alcalzone/proper-lockfile@ /opt/iobroker/node_modules/@alcalzone/proper-lockfile
            npm error extraneous: @all-smart/all-smart-tools@ /opt/iobroker/node_modules/@all-smart/all-smart-tools
            npm error extraneous: @aws-crypto/sha256-browser@ /opt/iobroker/node_modules/@aws-crypto/sha256-browser
            npm error extraneous: @aws-crypto/sha256-js@ /opt/iobroker/node_modules/@aws-crypto/sha256-js
            npm error extraneous: @aws-crypto/supports-web-crypto@ /opt/iobroker/node_modules/@aws-crypto/supports-web-crypto
            npm error extraneous: @aws-crypto/util@ /opt/iobroker/node_modules/@aws-crypto/util
            npm error extraneous: @aws-sdk/client-polly@ /opt/iobroker/node_modules/@aws-sdk/client-polly
            npm error extraneous: @aws-sdk/client-sso@ /opt/iobroker/node_modules/@aws-sdk/client-sso
            npm error extraneous: @aws-sdk/core@ /opt/iobroker/node_modules/@aws-sdk/core
            npm error extraneous: @aws-sdk/credential-provider-env@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-env
            npm error extraneous: @aws-sdk/credential-provider-http@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-http
            npm error extraneous: @aws-sdk/credential-provider-ini@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-ini
            npm error extraneous: @aws-sdk/credential-provider-node@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-node
            npm error extraneous: @aws-sdk/credential-provider-process@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-process
            npm error extraneous: @aws-sdk/credential-provider-sso@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-sso
            npm error extraneous: @aws-sdk/credential-provider-web-identity@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-web-identity
            npm error extraneous: @aws-sdk/middleware-host-header@ /opt/iobroker/node_modules/@aws-sdk/middleware-host-header
            npm error extraneous: @aws-sdk/middleware-logger@ /opt/iobroker/node_modules/@aws-sdk/middleware-logger
            npm error extraneous: @aws-sdk/middleware-recursion-detection@ /opt/iobroker/node_modules/@aws-sdk/middleware-recursion-detection
            npm error extraneous: @aws-sdk/middleware-user-agent@ /opt/iobroker/node_modules/@aws-sdk/middleware-user-agent
            npm error extraneous: @aws-sdk/nested-clients@ /opt/iobroker/node_modules/@aws-sdk/nested-clients
            npm error extraneous: @aws-sdk/region-config-resolver@ /opt/iobroker/node_modules/@aws-sdk/region-config-resolver
            npm error extraneous: @aws-sdk/token-providers@ /opt/iobroker/node_modules/@aws-sdk/token-providers
            npm error extraneous: @aws-sdk/types@ /opt/iobroker/node_modules/@aws-sdk/types
            npm error extraneous: @aws-sdk/util-endpoints@ /opt/iobroker/node_modules/@aws-sdk/util-endpoints
            npm error extraneous: @aws-sdk/util-locate-window@ /opt/iobroker/node_modules/@aws-sdk/util-locate-window
            npm error extraneous: @aws-sdk/util-user-agent-browser@ /opt/iobroker/node_modules/@aws-sdk/util-user-agent-browser
            npm error extraneous: @aws-sdk/util-user-agent-node@ /opt/iobroker/node_modules/@aws-sdk/util-user-agent-node
            npm error extraneous: @aws-sdk/xml-builder@ /opt/iobroker/node_modules/@aws-sdk/xml-builder
            npm error extraneous: @aws/lambda-invoke-store@ /opt/iobroker/node_modules/@aws/lambda-invoke-store
            npm error extraneous: @azure-rest/core-client@ /opt/iobroker/node_modules/@azure-rest/core-client
            npm error extraneous: @azure/abort-controller@ /opt/iobroker/node_modules/@azure/abort-controller
            npm error extraneous: @azure/core-auth@ /opt/iobroker/node_modules/@azure/core-auth
            npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
            npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
            npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
            npm error extraneous: @azure/core-paging@ /opt/iobroker/node_modules/@azure/core-paging
            npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
            npm error extraneous: @azure/core-tracing@ /opt/iobroker/node_modules/@azure/core-tracing
            npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
            npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
            npm error extraneous: @azure/keyvault-common@ /opt/iobroker/node_modules/@azure/keyvault-common
            npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
            npm error extraneous: @azure/logger@ /opt/iobroker/node_modules/@azure/logger
            npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
            npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
            npm error extraneous: @azure/msal-node@ /opt/iobroker/node_modules/@azure/msal-node
            npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
            npm error extraneous: @balena/dockerignore@ /opt/iobroker/node_modules/@balena/dockerignore
            npm error extraneous: @colors/colors@ /opt/iobroker/node_modules/@colors/colors
            npm error extraneous: @cypress/request-promise@ /opt/iobroker/node_modules/@cypress/request-promise
            npm error extraneous: @cypress/request@ /opt/iobroker/node_modules/@cypress/request
            npm error extraneous: @dabh/diagnostics@ /opt/iobroker/node_modules/@dabh/diagnostics
            npm error extraneous: @datalust/winston-seq@ /opt/iobroker/node_modules/@datalust/winston-seq
            npm error extraneous: @fastify/busboy@ /opt/iobroker/node_modules/@fastify/busboy
            npm error extraneous: @gar/promisify@ /opt/iobroker/node_modules/@gar/promisify
            npm error extraneous: @grpc/grpc-js@ /opt/iobroker/node_modules/@grpc/grpc-js
            npm error extraneous: @grpc/proto-loader@ /opt/iobroker/node_modules/@grpc/proto-loader
            npm error extraneous: @httptoolkit/websocket-stream@ /opt/iobroker/node_modules/@httptoolkit/websocket-stream
            npm error extraneous: @influxdata/influxdb-client-apis@ /opt/iobroker/node_modules/@influxdata/influxdb-client-apis
            npm error extraneous: @influxdata/influxdb-client@ /opt/iobroker/node_modules/@influxdata/influxdb-client
            npm error invalid: @iobroker-javascript.0/moment-parseformat@ /opt/iobroker/node_modules/@iobroker-javascript.0/moment-parseformat
            npm error invalid: @iobroker-javascript.0/moment@ /opt/iobroker/node_modules/@iobroker-javascript.0/moment
            npm error extraneous: @iobroker/adapter-core@ /opt/iobroker/node_modules/@iobroker/adapter-core
            npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
            npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
            npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
            npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
            npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
            npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
            npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
            npm error extraneous: @iobroker/dev-server@ /opt/iobroker/node_modules/@iobroker/dev-server
            npm error extraneous: @iobroker/dm-utils@ /opt/iobroker/node_modules/@iobroker/dm-utils
            npm error extraneous: @iobroker/i18n@ /opt/iobroker/node_modules/@iobroker/i18n
            npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
            npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
            npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
            npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
            npm error extraneous: @iobroker/plugin-base@ /opt/iobroker/node_modules/@iobroker/plugin-base
            npm error extraneous: @iobroker/plugin-docker@ /opt/iobroker/node_modules/@iobroker/plugin-docker
            npm error extraneous: @iobroker/plugin-sentry@ /opt/iobroker/node_modules/@iobroker/plugin-sentry
            npm error extraneous: @iobroker/socket-classes@ /opt/iobroker/node_modules/@iobroker/socket-classes
            npm error extraneous: @iobroker/testing@ /opt/iobroker/node_modules/@iobroker/testing
            npm error extraneous: @iobroker/type-detector@ /opt/iobroker/node_modules/@iobroker/type-detector
            npm error extraneous: @iobroker/types@ /opt/iobroker/node_modules/@iobroker/types
            npm error extraneous: @iobroker/webserver@ /opt/iobroker/node_modules/@iobroker/webserver
            npm error extraneous: @iobroker/ws-server@ /opt/iobroker/node_modules/@iobroker/ws-server
            npm error extraneous: @iobroker/ws@ /opt/iobroker/node_modules/@iobroker/ws
            npm error extraneous: @ioredis/commands@ /opt/iobroker/node_modules/@ioredis/commands
            npm error extraneous: @isaacs/balanced-match@ /opt/iobroker/node_modules/@isaacs/balanced-match
            npm error extraneous: @isaacs/brace-expansion@ /opt/iobroker/node_modules/@isaacs/brace-expansion
            npm error extraneous: @isaacs/cliui@ /opt/iobroker/node_modules/@isaacs/cliui
            npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
            npm error extraneous: @js-sdsl/ordered-map@ /opt/iobroker/node_modules/@js-sdsl/ordered-map
            npm error extraneous: @leichtgewicht/ip-codec@ /opt/iobroker/node_modules/@leichtgewicht/ip-codec
            npm error extraneous: @mapbox/node-pre-gyp@ /opt/iobroker/node_modules/@mapbox/node-pre-gyp
            npm error extraneous: @network-utils/arp-lookup@ /opt/iobroker/node_modules/@network-utils/arp-lookup
            npm error extraneous: @nodelib/fs.scandir@ /opt/iobroker/node_modules/@nodelib/fs.scandir
            npm error extraneous: @nodelib/fs.stat@ /opt/iobroker/node_modules/@nodelib/fs.stat
            npm error extraneous: @nodelib/fs.walk@ /opt/iobroker/node_modules/@nodelib/fs.walk
            npm error extraneous: @nornagon/put@ /opt/iobroker/node_modules/@nornagon/put
            npm error extraneous: @npmcli/agent@ /opt/iobroker/node_modules/@npmcli/agent
            npm error extraneous: @npmcli/fs@ /opt/iobroker/node_modules/@npmcli/fs
            npm error extraneous: @npmcli/move-file@ /opt/iobroker/node_modules/@npmcli/move-file
            npm error extraneous: @pkgjs/parseargs@ /opt/iobroker/node_modules/@pkgjs/parseargs
            npm error extraneous: @protobufjs/aspromise@ /opt/iobroker/node_modules/@protobufjs/aspromise
            npm error extraneous: @protobufjs/base64@ /opt/iobroker/node_modules/@protobufjs/base64
            npm error extraneous: @protobufjs/codegen@ /opt/iobroker/node_modules/@protobufjs/codegen
            npm error extraneous: @protobufjs/eventemitter@ /opt/iobroker/node_modules/@protobufjs/eventemitter
            npm error extraneous: @protobufjs/fetch@ /opt/iobroker/node_modules/@protobufjs/fetch
            npm error extraneous: @protobufjs/float@ /opt/iobroker/node_modules/@protobufjs/float
            npm error extraneous: @protobufjs/inquire@ /opt/iobroker/node_modules/@protobufjs/inquire
            npm error extraneous: @protobufjs/path@ /opt/iobroker/node_modules/@protobufjs/path
            npm error extraneous: @protobufjs/pool@ /opt/iobroker/node_modules/@protobufjs/pool
            npm error extraneous: @protobufjs/utf8@ /opt/iobroker/node_modules/@protobufjs/utf8
            npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
            npm error extraneous: @sentry/core@ /opt/iobroker/node_modules/@sentry/core
            npm error extraneous: @sentry/integrations@ /opt/iobroker/node_modules/@sentry/integrations
            npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
            npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
            npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
            npm error extraneous: @serialport/binding-mock@ /opt/iobroker/node_modules/@serialport/binding-mock
            npm error extraneous: @serialport/bindings-cpp@ /opt/iobroker/node_modules/@serialport/bindings-cpp
            npm error extraneous: @serialport/bindings-interface@ /opt/iobroker/node_modules/@serialport/bindings-interface
            npm error extraneous: @serialport/parser-byte-length@ /opt/iobroker/node_modules/@serialport/parser-byte-length
            npm error extraneous: @serialport/parser-cctalk@ /opt/iobroker/node_modules/@serialport/parser-cctalk
            npm error extraneous: @serialport/parser-delimiter@ /opt/iobroker/node_modules/@serialport/parser-delimiter
            npm error extraneous: @serialport/parser-inter-byte-timeout@ /opt/iobroker/node_modules/@serialport/parser-inter-byte-timeout
            npm error extraneous: @serialport/parser-packet-length@ /opt/iobroker/node_modules/@serialport/parser-packet-length
            npm error extraneous: @serialport/parser-readline@ /opt/iobroker/node_modules/@serialport/parser-readline
            npm error extraneous: @serialport/parser-ready@ /opt/iobroker/node_modules/@serialport/parser-ready
            npm error extraneous: @serialport/parser-regex@ /opt/iobroker/node_modules/@serialport/parser-regex
            npm error extraneous: @serialport/parser-slip-encoder@ /opt/iobroker/node_modules/@serialport/parser-slip-encoder
            npm error extraneous: @serialport/parser-spacepacket@ /opt/iobroker/node_modules/@serialport/parser-spacepacket
            npm error extraneous: @serialport/stream@ /opt/iobroker/node_modules/@serialport/stream
            npm error extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/@sinonjs/commons
            npm error extraneous: @sinonjs/fake-timers@ /opt/iobroker/node_modules/@sinonjs/fake-timers
            npm error extraneous: @sinonjs/samsam@ /opt/iobroker/node_modules/@sinonjs/samsam
            npm error extraneous: @smithy/abort-controller@ /opt/iobroker/node_modules/@smithy/abort-controller
            npm error extraneous: @smithy/config-resolver@ /opt/iobroker/node_modules/@smithy/config-resolver
            npm error extraneous: @smithy/core@ /opt/iobroker/node_modules/@smithy/core
            npm error extraneous: @smithy/credential-provider-imds@ /opt/iobroker/node_modules/@smithy/credential-provider-imds
            npm error extraneous: @smithy/fetch-http-handler@ /opt/iobroker/node_modules/@smithy/fetch-http-handler
            npm error extraneous: @smithy/hash-node@ /opt/iobroker/node_modules/@smithy/hash-node
            npm error extraneous: @smithy/invalid-dependency@ /opt/iobroker/node_modules/@smithy/invalid-dependency
            npm error extraneous: @smithy/is-array-buffer@ /opt/iobroker/node_modules/@smithy/is-array-buffer
            npm error extraneous: @smithy/middleware-content-length@ /opt/iobroker/node_modules/@smithy/middleware-content-length
            npm error extraneous: @smithy/middleware-endpoint@ /opt/iobroker/node_modules/@smithy/middleware-endpoint
            npm error extraneous: @smithy/middleware-retry@ /opt/iobroker/node_modules/@smithy/middleware-retry
            npm error extraneous: @smithy/middleware-serde@ /opt/iobroker/node_modules/@smithy/middleware-serde
            npm error extraneous: @smithy/middleware-stack@ /opt/iobroker/node_modules/@smithy/middleware-stack
            npm error extraneous: @smithy/node-config-provider@ /opt/iobroker/node_modules/@smithy/node-config-provider
            npm error extraneous: @smithy/node-http-handler@ /opt/iobroker/node_modules/@smithy/node-http-handler
            npm error extraneous: @smithy/property-provider@ /opt/iobroker/node_modules/@smithy/property-provider
            npm error extraneous: @smithy/protocol-http@ /opt/iobroker/node_modules/@smithy/protocol-http
            npm error extraneous: @smithy/querystring-builder@ /opt/iobroker/node_modules/@smithy/querystring-builder
            npm error extraneous: @smithy/querystring-parser@ /opt/iobroker/node_modules/@smithy/querystring-parser
            npm error extraneous: @smithy/service-error-classification@ /opt/iobroker/node_modules/@smithy/service-error-classification
            npm error extraneous: @smithy/shared-ini-file-loader@ /opt/iobroker/node_modules/@smithy/shared-ini-file-loader
            npm error extraneous: @smithy/signature-v4@ /opt/iobroker/node_modules/@smithy/signature-v4
            npm error extraneous: @smithy/smithy-client@ /opt/iobroker/node_modules/@smithy/smithy-client
            npm error extraneous: @smithy/types@ /opt/iobroker/node_modules/@smithy/types
            npm error extraneous: @smithy/url-parser@ /opt/iobroker/node_modules/@smithy/url-parser
            npm error extraneous: @smithy/util-base64@ /opt/iobroker/node_modules/@smithy/util-base64
            npm error extraneous: @smithy/util-body-length-browser@ /opt/iobroker/node_modules/@smithy/util-body-length-browser
            npm error extraneous: @smithy/util-body-length-node@ /opt/iobroker/node_modules/@smithy/util-body-length-node
            npm error extraneous: @smithy/util-buffer-from@ /opt/iobroker/node_modules/@smithy/util-buffer-from
            npm error extraneous: @smithy/util-config-provider@ /opt/iobroker/node_modules/@smithy/util-config-provider
            npm error extraneous: @smithy/util-defaults-mode-browser@ /opt/iobroker/node_modules/@smithy/util-defaults-mode-browser
            npm error extraneous: @smithy/util-defaults-mode-node@ /opt/iobroker/node_modules/@smithy/util-defaults-mode-node
            npm error extraneous: @smithy/util-endpoints@ /opt/iobroker/node_modules/@smithy/util-endpoints
            npm error extraneous: @smithy/util-hex-encoding@ /opt/iobroker/node_modules/@smithy/util-hex-encoding
            npm error extraneous: @smithy/util-middleware@ /opt/iobroker/node_modules/@smithy/util-middleware
            npm error extraneous: @smithy/util-retry@ /opt/iobroker/node_modules/@smithy/util-retry
            npm error extraneous: @smithy/util-stream@ /opt/iobroker/node_modules/@smithy/util-stream
            npm error extraneous: @smithy/util-uri-escape@ /opt/iobroker/node_modules/@smithy/util-uri-escape
            npm error extraneous: @smithy/util-utf8@ /opt/iobroker/node_modules/@smithy/util-utf8
            npm error extraneous: @smithy/uuid@ /opt/iobroker/node_modules/@smithy/uuid
            npm error extraneous: @so-ric/colorspace@ /opt/iobroker/node_modules/@so-ric/colorspace
            npm error extraneous: @socket.io/component-emitter@ /opt/iobroker/node_modules/@socket.io/component-emitter
            npm error extraneous: @stoprocent/bluetooth-hci-socket@ /opt/iobroker/node_modules/@stoprocent/bluetooth-hci-socket
            npm error extraneous: @stoprocent/noble@ /opt/iobroker/node_modules/@stoprocent/noble
            npm error extraneous: @tediousjs/connection-string@ /opt/iobroker/node_modules/@tediousjs/connection-string
            npm error extraneous: @tootallnate/once@ /opt/iobroker/node_modules/@tootallnate/once
            npm error extraneous: @types/body-parser@ /opt/iobroker/node_modules/@types/body-parser
            npm error extraneous: @types/caseless@ /opt/iobroker/node_modules/@types/caseless
            npm error extraneous: @types/chai-as-promised@ /opt/iobroker/node_modules/@types/chai-as-promised
            npm error extraneous: @types/chai@ /opt/iobroker/node_modules/@types/chai
            npm error extraneous: @types/connect@ /opt/iobroker/node_modules/@types/connect
            npm error extraneous: @types/cors@ /opt/iobroker/node_modules/@types/cors
            npm error extraneous: @types/express-serve-static-core@ /opt/iobroker/node_modules/@types/express-serve-static-core
            npm error extraneous: @types/express@ /opt/iobroker/node_modules/@types/express
            npm error extraneous: @types/http-errors@ /opt/iobroker/node_modules/@types/http-errors
            npm error extraneous: @types/http-proxy@ /opt/iobroker/node_modules/@types/http-proxy
            npm error extraneous: @types/jsonwebtoken@ /opt/iobroker/node_modules/@types/jsonwebtoken
            npm error extraneous: @types/long@ /opt/iobroker/node_modules/@types/long
            npm error extraneous: @types/luxon@ /opt/iobroker/node_modules/@types/luxon
            npm error extraneous: @types/mime@ /opt/iobroker/node_modules/@types/mime
            npm error extraneous: @types/mocha@ /opt/iobroker/node_modules/@types/mocha
            npm error extraneous: @types/ms@ /opt/iobroker/node_modules/@types/ms
            npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
            npm error extraneous: @types/qs@ /opt/iobroker/node_modules/@types/qs
            npm error extraneous: @types/range-parser@ /opt/iobroker/node_modules/@types/range-parser
            npm error extraneous: @types/readable-stream@ /opt/iobroker/node_modules/@types/readable-stream
            npm error extraneous: @types/request@ /opt/iobroker/node_modules/@types/request
            npm error extraneous: @types/send@ /opt/iobroker/node_modules/@types/send
            npm error extraneous: @types/serve-static@ /opt/iobroker/node_modules/@types/serve-static
            npm error extraneous: @types/sinon-chai@ /opt/iobroker/node_modules/@types/sinon-chai
            npm error extraneous: @types/sinon@ /opt/iobroker/node_modules/@types/sinon
            npm error extraneous: @types/sinonjs__fake-timers@ /opt/iobroker/node_modules/@types/sinonjs__fake-timers
            npm error extraneous: @types/tough-cookie@ /opt/iobroker/node_modules/@types/tough-cookie
            npm error extraneous: @types/triple-beam@ /opt/iobroker/node_modules/@types/triple-beam
            npm error extraneous: @types/w3c-web-usb@ /opt/iobroker/node_modules/@types/w3c-web-usb
            npm error extraneous: @types/ws@ /opt/iobroker/node_modules/@types/ws
            npm error extraneous: @typespec/ts-http-runtime@ /opt/iobroker/node_modules/@typespec/ts-http-runtime
            npm error extraneous: @yarnpkg/lockfile@ /opt/iobroker/node_modules/@yarnpkg/lockfile
            npm error extraneous: abbrev@ /opt/iobroker/node_modules/abbrev
            npm error extraneous: abort-controller@ /opt/iobroker/node_modules/abort-controller
            npm error extraneous: accepts@ /opt/iobroker/node_modules/accepts
            npm error extraneous: acorn-globals@ /opt/iobroker/node_modules/acorn-globals
            npm error extraneous: acorn@ /opt/iobroker/node_modules/acorn
            npm error extraneous: after@ /opt/iobroker/node_modules/after
            npm error extraneous: agent-base@ /opt/iobroker/node_modules/agent-base
            npm error extraneous: agentkeepalive@ /opt/iobroker/node_modules/agentkeepalive
            npm error extraneous: aggregate-error@ /opt/iobroker/node_modules/aggregate-error
            npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
            npm error extraneous: alcalzone-shared@ /opt/iobroker/node_modules/alcalzone-shared
            npm error extraneous: ansi-align@ /opt/iobroker/node_modules/ansi-align
            npm error extraneous: ansi-colors@ /opt/iobroker/node_modules/ansi-colors
            npm error extraneous: ansi-regex@ /opt/iobroker/node_modules/ansi-regex
            npm error extraneous: ansi-styles@ /opt/iobroker/node_modules/ansi-styles
            npm error extraneous: anymatch@ /opt/iobroker/node_modules/anymatch
            npm error extraneous: aproba@ /opt/iobroker/node_modules/aproba
            npm error extraneous: archiver-utils@ /opt/iobroker/node_modules/archiver-utils
            npm error extraneous: archiver@ /opt/iobroker/node_modules/archiver
            npm error extraneous: are-we-there-yet@ /opt/iobroker/node_modules/are-we-there-yet
            npm error extraneous: argf@ /opt/iobroker/node_modules/argf
            npm error extraneous: argparse@ /opt/iobroker/node_modules/argparse
            npm error extraneous: array-buffer-byte-length@ /opt/iobroker/node_modules/array-buffer-byte-length
            npm error extraneous: array-find@ /opt/iobroker/node_modules/array-find
            npm error extraneous: array-flatten@ /opt/iobroker/node_modules/array-flatten
            npm error extraneous: array.prototype.findindex@ /opt/iobroker/node_modules/array.prototype.findindex
            npm error extraneous: arraybuffer.prototype.slice@ /opt/iobroker/node_modules/arraybuffer.prototype.slice
            npm error extraneous: arraybuffer.slice@ /opt/iobroker/node_modules/arraybuffer.slice
            npm error extraneous: asn1@ /opt/iobroker/node_modules/asn1
            npm error extraneous: assert-plus@ /opt/iobroker/node_modules/assert-plus
            npm error extraneous: assertion-error@ /opt/iobroker/node_modules/assertion-error
            npm error extraneous: astral-regex@ /opt/iobroker/node_modules/astral-regex
            npm error extraneous: async-each-series@ /opt/iobroker/node_modules/async-each-series
            npm error extraneous: async-function@ /opt/iobroker/node_modules/async-function
            npm error extraneous: async-limiter@ /opt/iobroker/node_modules/async-limiter
            npm error extraneous: async@ /opt/iobroker/node_modules/async
            npm error extraneous: asynckit@ /opt/iobroker/node_modules/asynckit
            npm error extraneous: authenticate-pam@ /opt/iobroker/node_modules/authenticate-pam
            npm error extraneous: available-typed-arrays@ /opt/iobroker/node_modules/available-typed-arrays
            npm error extraneous: aws-iot-device-sdk@ /opt/iobroker/node_modules/aws-iot-device-sdk
            npm error extraneous: aws-sign2@ /opt/iobroker/node_modules/aws-sign2
            npm error extraneous: aws-ssl-profiles@ /opt/iobroker/node_modules/aws-ssl-profiles
            npm error extraneous: aws4@ /opt/iobroker/node_modules/aws4
            npm error extraneous: axios@ /opt/iobroker/node_modules/axios
            npm error extraneous: b4a@ /opt/iobroker/node_modules/b4a
            npm error extraneous: backo2@ /opt/iobroker/node_modules/backo2
            npm error extraneous: balanced-match@ /opt/iobroker/node_modules/balanced-match
            npm error extraneous: bare-events@ /opt/iobroker/node_modules/bare-events
            npm error extraneous: base-64@ /opt/iobroker/node_modules/base-64
            npm error extraneous: base64-arraybuffer@ /opt/iobroker/node_modules/base64-arraybuffer
            npm error extraneous: base64-js@ /opt/iobroker/node_modules/base64-js
            npm error extraneous: base64id@ /opt/iobroker/node_modules/base64id
            npm error extraneous: basic-auth@ /opt/iobroker/node_modules/basic-auth
            npm error extraneous: batch@ /opt/iobroker/node_modules/batch
            npm error extraneous: bcrypt-pbkdf@ /opt/iobroker/node_modules/bcrypt-pbkdf
            npm error extraneous: better-assert@ /opt/iobroker/node_modules/better-assert
            npm error extraneous: bignumber.js@ /opt/iobroker/node_modules/bignumber.js
            npm error extraneous: binary-extensions@ /opt/iobroker/node_modules/binary-extensions
            npm error extraneous: binary@ /opt/iobroker/node_modules/binary
            npm error extraneous: bindings@ /opt/iobroker/node_modules/bindings
            npm error extraneous: binrpc@ /opt/iobroker/node_modules/binrpc
            npm error extraneous: bl@ /opt/iobroker/node_modules/bl
            npm error extraneous: blob@ /opt/iobroker/node_modules/blob
            npm error extraneous: bluebird-co@ /opt/iobroker/node_modules/bluebird-co
            npm error extraneous: bluebird@ /opt/iobroker/node_modules/bluebird
            npm error extraneous: bluetooth-hci-socket@ /opt/iobroker/node_modules/bluetooth-hci-socket
            npm error extraneous: body-parser@ /opt/iobroker/node_modules/body-parser
            npm error extraneous: boolbase@ /opt/iobroker/node_modules/boolbase
            npm error extraneous: bower@ /opt/iobroker/node_modules/bower
            npm error extraneous: bowser@ /opt/iobroker/node_modules/bowser
            npm error extraneous: boxen@ /opt/iobroker/node_modules/boxen
            npm error extraneous: bplist-parser@ /opt/iobroker/node_modules/bplist-parser
            npm error extraneous: brace-expansion@ /opt/iobroker/node_modules/brace-expansion
            npm error extraneous: braces@ /opt/iobroker/node_modules/braces
            npm error extraneous: broker-factory@ /opt/iobroker/node_modules/broker-factory
            npm error extraneous: browser-request@ /opt/iobroker/node_modules/browser-request
            npm error extraneous: browser-stdout@ /opt/iobroker/node_modules/browser-stdout
            npm error extraneous: browser-sync-client@ /opt/iobroker/node_modules/browser-sync-client
            npm error extraneous: browser-sync-ui@ /opt/iobroker/node_modules/browser-sync-ui
            npm error extraneous: browser-sync@ /opt/iobroker/node_modules/browser-sync
            npm error extraneous: bs-html-injector@ /opt/iobroker/node_modules/bs-html-injector
            npm error extraneous: bs-recipes@ /opt/iobroker/node_modules/bs-recipes
            npm error extraneous: buffer-crc32@ /opt/iobroker/node_modules/buffer-crc32
            npm error extraneous: buffer-equal-constant-time@ /opt/iobroker/node_modules/buffer-equal-constant-time
            npm error extraneous: buffer-from@ /opt/iobroker/node_modules/buffer-from
            npm error extraneous: buffer@ /opt/iobroker/node_modules/buffer
            npm error extraneous: buffers@ /opt/iobroker/node_modules/buffers
            npm error extraneous: buildcheck@ /opt/iobroker/node_modules/buildcheck
            npm error extraneous: busboy@ /opt/iobroker/node_modules/busboy
            npm error extraneous: bytes@ /opt/iobroker/node_modules/bytes
            npm error extraneous: cacache@ /opt/iobroker/node_modules/cacache
            npm error extraneous: call-bind-apply-helpers@ /opt/iobroker/node_modules/call-bind-apply-helpers
            npm error extraneous: call-bind@ /opt/iobroker/node_modules/call-bind
            npm error extraneous: call-bound@ /opt/iobroker/node_modules/call-bound
            npm error extraneous: callsite@ /opt/iobroker/node_modules/callsite
            npm error extraneous: camelcase@ /opt/iobroker/node_modules/camelcase
            npm error extraneous: canvas@ /opt/iobroker/node_modules/canvas
            npm error extraneous: caseless@ /opt/iobroker/node_modules/caseless
            npm error extraneous: castv2-client@ /opt/iobroker/node_modules/castv2-client
            npm error extraneous: castv2-player@ /opt/iobroker/node_modules/castv2-player
            npm error extraneous: castv2@ /opt/iobroker/node_modules/castv2
            npm error extraneous: chai-as-promised@ /opt/iobroker/node_modules/chai-as-promised
            npm error extraneous: chai@ /opt/iobroker/node_modules/chai
            npm error extraneous: chainsaw@ /opt/iobroker/node_modules/chainsaw
            npm error extraneous: chalk@ /opt/iobroker/node_modules/chalk
            npm error extraneous: char-spinner@ /opt/iobroker/node_modules/char-spinner
            npm error extraneous: check-error@ /opt/iobroker/node_modules/check-error
            npm error extraneous: cheerio-select@ /opt/iobroker/node_modules/cheerio-select
            npm error extraneous: cheerio@ /opt/iobroker/node_modules/cheerio
            npm error extraneous: chokidar@ /opt/iobroker/node_modules/chokidar
            npm error extraneous: chownr@ /opt/iobroker/node_modules/chownr
            npm error extraneous: ci-info@ /opt/iobroker/node_modules/ci-info
            npm error extraneous: clean-stack@ /opt/iobroker/node_modules/clean-stack
            npm error extraneous: cli-boxes@ /opt/iobroker/node_modules/cli-boxes
            npm error extraneous: cliui@ /opt/iobroker/node_modules/cliui
            npm error extraneous: cluster-key-slot@ /opt/iobroker/node_modules/cluster-key-slot
            npm error extraneous: co-bluebird@ /opt/iobroker/node_modules/co-bluebird
            npm error extraneous: co-use@ /opt/iobroker/node_modules/co-use
            npm error extraneous: code-point-at@ /opt/iobroker/node_modules/code-point-at
            npm error extraneous: color-convert@ /opt/iobroker/node_modules/color-convert
            npm error extraneous: color-name@ /opt/iobroker/node_modules/color-name
            npm error extraneous: color-string@ /opt/iobroker/node_modules/color-string
            npm error extraneous: color-support@ /opt/iobroker/node_modules/color-support
            npm error extraneous: color@ /opt/iobroker/node_modules/color
            npm error invalid: colors@ /opt/iobroker/node_modules/colors
            npm error extraneous: combined-stream@ /opt/iobroker/node_modules/combined-stream
            npm error extraneous: commander@ /opt/iobroker/node_modules/commander
            npm error extraneous: commist@ /opt/iobroker/node_modules/commist
            npm error extraneous: component-bind@ /opt/iobroker/node_modules/component-bind
            npm error extraneous: component-emitter@ /opt/iobroker/node_modules/component-emitter
            npm error extraneous: component-inherit@ /opt/iobroker/node_modules/component-inherit
            npm error extraneous: compress-commons@ /opt/iobroker/node_modules/compress-commons
            npm error extraneous: compressible@ /opt/iobroker/node_modules/compressible
            npm error extraneous: compression@ /opt/iobroker/node_modules/compression
            npm error extraneous: concat-map@ /opt/iobroker/node_modules/concat-map
            npm error extraneous: concat-stream@ /opt/iobroker/node_modules/concat-stream
            npm error extraneous: connect-flash@ /opt/iobroker/node_modules/connect-flash
            npm error extraneous: connect-history-api-fallback@ /opt/iobroker/node_modules/connect-history-api-fallback
            npm error extraneous: connect@ /opt/iobroker/node_modules/connect
            npm error extraneous: console-control-strings@ /opt/iobroker/node_modules/console-control-strings
            npm error extraneous: content-disposition@ /opt/iobroker/node_modules/content-disposition
            npm error extraneous: content-type@ /opt/iobroker/node_modules/content-type
            npm error extraneous: cookie-parser@ /opt/iobroker/node_modules/cookie-parser
            npm error extraneous: cookie-signature@ /opt/iobroker/node_modules/cookie-signature
            npm error extraneous: cookie@ /opt/iobroker/node_modules/cookie
            npm error extraneous: core-util-is@ /opt/iobroker/node_modules/core-util-is
            npm error extraneous: cors@ /opt/iobroker/node_modules/cors
            npm error extraneous: country-data@ /opt/iobroker/node_modules/country-data
            npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
            npm error extraneous: crc-32@ /opt/iobroker/node_modules/crc-32
            npm error extraneous: crc32-stream@ /opt/iobroker/node_modules/crc32-stream
            npm error extraneous: cron-parser@ /opt/iobroker/node_modules/cron-parser
            npm error extraneous: cron@ /opt/iobroker/node_modules/cron
            npm error extraneous: cross-spawn@ /opt/iobroker/node_modules/cross-spawn
            npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
            npm error extraneous: css-select@ /opt/iobroker/node_modules/css-select
            npm error extraneous: css-what@ /opt/iobroker/node_modules/css-what
            npm error extraneous: cssom@ /opt/iobroker/node_modules/cssom
            npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
            npm error extraneous: currency-symbol-map@ /opt/iobroker/node_modules/currency-symbol-map
            npm error extraneous: cycle@ /opt/iobroker/node_modules/cycle
            npm error extraneous: dashdash@ /opt/iobroker/node_modules/dashdash
            npm error extraneous: data-view-buffer@ /opt/iobroker/node_modules/data-view-buffer
            npm error extraneous: data-view-byte-length@ /opt/iobroker/node_modules/data-view-byte-length
            npm error extraneous: data-view-byte-offset@ /opt/iobroker/node_modules/data-view-byte-offset
            npm error extraneous: dateformat@ /opt/iobroker/node_modules/dateformat
            npm error extraneous: dbus-next@ /opt/iobroker/node_modules/dbus-next
            npm error extraneous: debug@ /opt/iobroker/node_modules/debug
            npm error extraneous: decache@ /opt/iobroker/node_modules/decache
            npm error extraneous: decamelize@ /opt/iobroker/node_modules/decamelize
            npm error extraneous: decompress-response@ /opt/iobroker/node_modules/decompress-response
            npm error extraneous: deep-clone@ /opt/iobroker/node_modules/deep-clone
            npm error extraneous: deep-eql@ /opt/iobroker/node_modules/deep-eql
            npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
            npm error extraneous: deep-is@ /opt/iobroker/node_modules/deep-is
            npm error extraneous: define-data-property@ /opt/iobroker/node_modules/define-data-property
            npm error extraneous: define-lazy-prop@ /opt/iobroker/node_modules/define-lazy-prop
            npm error extraneous: define-properties@ /opt/iobroker/node_modules/define-properties
            npm error extraneous: delayed-stream@ /opt/iobroker/node_modules/delayed-stream
            npm error extraneous: delegates@ /opt/iobroker/node_modules/delegates
            npm error extraneous: denque@ /opt/iobroker/node_modules/denque
            npm error extraneous: depd@ /opt/iobroker/node_modules/depd
            npm error extraneous: destroy@ /opt/iobroker/node_modules/destroy
            npm error extraneous: detect-libc@ /opt/iobroker/node_modules/detect-libc
            npm error extraneous: dev-ip@ /opt/iobroker/node_modules/dev-ip
            npm error extraneous: dev-null@ /opt/iobroker/node_modules/dev-null
            npm error extraneous: dgram@ /opt/iobroker/node_modules/dgram
            npm error extraneous: diff@ /opt/iobroker/node_modules/diff
            npm error extraneous: diskusage@ /opt/iobroker/node_modules/diskusage
            npm error extraneous: dns-packet@ /opt/iobroker/node_modules/dns-packet
            npm error extraneous: docker-modem@ /opt/iobroker/node_modules/docker-modem
            npm error extraneous: dockerode@ /opt/iobroker/node_modules/dockerode
            npm error extraneous: dom-compare-temp@ /opt/iobroker/node_modules/dom-compare-temp
            npm error extraneous: dom-serializer@ /opt/iobroker/node_modules/dom-serializer
            npm error extraneous: domelementtype@ /opt/iobroker/node_modules/domelementtype
            npm error extraneous: domhandler@ /opt/iobroker/node_modules/domhandler
            npm error extraneous: domutils@ /opt/iobroker/node_modules/domutils
            npm error extraneous: dunder-proto@ /opt/iobroker/node_modules/dunder-proto
            npm error extraneous: duplexer@ /opt/iobroker/node_modules/duplexer
            npm error extraneous: duplexify@ /opt/iobroker/node_modules/duplexify
            npm error extraneous: eastasianwidth@ /opt/iobroker/node_modules/eastasianwidth
            npm error extraneous: easy-extender@ /opt/iobroker/node_modules/easy-extender
            npm error extraneous: eazy-logger@ /opt/iobroker/node_modules/eazy-logger
            npm error extraneous: ecc-jsbn@ /opt/iobroker/node_modules/ecc-jsbn
            npm error extraneous: ecdsa-sig-formatter@ /opt/iobroker/node_modules/ecdsa-sig-formatter
            npm error extraneous: ee-first@ /opt/iobroker/node_modules/ee-first
            npm error extraneous: emoji-regex@ /opt/iobroker/node_modules/emoji-regex
            npm error extraneous: enabled@ /opt/iobroker/node_modules/enabled
            npm error extraneous: encodeurl@ /opt/iobroker/node_modules/encodeurl
            npm error extraneous: encoding-sniffer@ /opt/iobroker/node_modules/encoding-sniffer
            npm error extraneous: encoding@ /opt/iobroker/node_modules/encoding
            npm error extraneous: end-of-stream@ /opt/iobroker/node_modules/end-of-stream
            npm error extraneous: engine.io-client@ /opt/iobroker/node_modules/engine.io-client
            npm error extraneous: engine.io-parser@ /opt/iobroker/node_modules/engine.io-parser
            npm error extraneous: engine.io@ /opt/iobroker/node_modules/engine.io
            npm error extraneous: enquirer@ /opt/iobroker/node_modules/enquirer
            npm error extraneous: entities@ /opt/iobroker/node_modules/entities
            npm error extraneous: env-paths@ /opt/iobroker/node_modules/env-paths
            npm error extraneous: err-code@ /opt/iobroker/node_modules/err-code
            npm error extraneous: error-ex@ /opt/iobroker/node_modules/error-ex
            npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
            npm error extraneous: es-aggregate-error@ /opt/iobroker/node_modules/es-aggregate-error
            npm error extraneous: es-define-property@ /opt/iobroker/node_modules/es-define-property
            npm error extraneous: es-errors@ /opt/iobroker/node_modules/es-errors
            • G George_Best
              1. npm ls:
              cd /opt/iobroker
              npm ls
              npm ls graceful-fs
              ── component-inherit@ extraneous
              ├── compress-commons@ extraneous
              ├── compressible@ extraneous
              ├── compression@ extraneous
              ├── concat-map@ extraneous
              ├── concat-stream@ extraneous
              ├── connect-flash@ extraneous
              ├── connect-history-api-fallback@ extraneous
              ├── connect@ extraneous
              ├── console-control-strings@ extraneous
              ├── content-disposition@ extraneous
              ├── content-type@ extraneous
              ├── cookie-parser@ extraneous
              ├── cookie-signature@ extraneous
              ├── cookie@ extraneous
              ├── core-util-is@ extraneous
              ├── cors@ extraneous
              ├── country-data@ extraneous
              ├── cpu-features@ extraneous
              ├── crc-32@ extraneous
              ├── crc32-stream@ extraneous
              ├── cron-parser@ extraneous
              ├── cron@ extraneous
              ├── cross-spawn@ extraneous
              ├── crypto-js@ extraneous
              ├── css-select@ extraneous
              ├── css-what@ extraneous
              ├── cssom@ extraneous
              ├── cssstyle@ extraneous
              ├── currency-symbol-map@ extraneous
              ├── cycle@ extraneous
              ├── dashdash@ extraneous
              ├── data-view-buffer@ extraneous
              ├── data-view-byte-length@ extraneous
              ├── data-view-byte-offset@ extraneous
              ├── dateformat@ extraneous
              ├── dbus-next@ extraneous
              ├── debug@ extraneous
              ├── decache@ extraneous
              ├── decamelize@ extraneous
              ├── decompress-response@ extraneous
              ├── deep-clone@ extraneous
              ├── deep-eql@ extraneous
              ├── deep-extend@0.6.0 extraneous
              ├── deep-is@ extraneous
              ├── define-data-property@ extraneous
              ├── define-lazy-prop@ extraneous
              ├── define-properties@ extraneous
              ├── delayed-stream@ extraneous
              ├── delegates@ extraneous
              ├── denque@ extraneous
              ├── depd@ extraneous
              ├── destroy@ extraneous
              ├── detect-libc@ extraneous
              ├── dev-ip@ extraneous
              ├── dev-null@ extraneous
              ├── dgram@ extraneous
              ├── diff@ extraneous
              ├── diskusage@ extraneous
              ├── dns-packet@ extraneous
              ├── docker-modem@ extraneous
              ├── dockerode@ extraneous
              ├── dom-compare-temp@ extraneous
              ├── dom-serializer@ extraneous
              ├── domelementtype@ extraneous
              ├── domhandler@ extraneous
              ├── domutils@ extraneous
              ├── dunder-proto@ extraneous
              ├── duplexer@ extraneous
              ├── duplexify@ extraneous
              ├── eastasianwidth@ extraneous
              ├── easy-extender@ extraneous
              ├── eazy-logger@ extraneous
              ├── ecc-jsbn@ extraneous
              ├── ecdsa-sig-formatter@ extraneous
              ├── ee-first@ extraneous
              ├── emoji-regex@ extraneous
              ├── enabled@ extraneous
              ├── encodeurl@ extraneous
              ├── encoding-sniffer@ extraneous
              ├── encoding@ extraneous
              ├── end-of-stream@ extraneous
              ├── engine.io-client@ extraneous
              ├── engine.io-parser@ extraneous
              ├── engine.io@ extraneous
              ├── enquirer@ extraneous
              ├── entities@ extraneous
              ├── env-paths@ extraneous
              ├── err-code@ extraneous
              ├── error-ex@ extraneous
              ├── es-abstract@ extraneous
              ├── es-aggregate-error@ extraneous
              ├── es-define-property@ extraneous
              ├── es-errors@ extraneous
              ├── es-object-atoms@ extraneous
              ├── es-set-tostringtag@ extraneous
              ├── es-shim-unscopables@ extraneous
              ├── es-to-primitive@ extraneous
              ├── es6-promise@ extraneous
              ├── esbuild@ extraneous
              ├── escalade@ extraneous
              ├── escape-html@ extraneous
              ├── escape-string-regexp@ extraneous
              ├── escodegen@ extraneous
              ├── esprima@ extraneous
              ├── estraverse@ extraneous
              ├── esutils@ extraneous
              ├── etag@ extraneous
              ├── event-stream@ extraneous
              ├── event-target-shim@ extraneous
              ├── eventemitter2@ extraneous
              ├── eventemitter3@ extraneous
              ├── events-universal@ extraneous
              ├── events@ extraneous
              ├── evilscan@ extraneous
              ├── execa@ extraneous
              ├── expand-template@ extraneous
              ├── exponential-backoff@ extraneous
              ├── express-fileupload@ extraneous
              ├── express-session@ extraneous
              ├── express@ extraneous
              ├── extend@3.0.2 extraneous
              ├── extsprintf@ extraneous
              ├── eyes@ extraneous
              ├── fast-deep-equal@ extraneous
              ├── fast-fifo@ extraneous
              ├── fast-glob@ extraneous
              ├── fast-json-stable-stringify@ extraneous
              ├── fast-levenshtein@ extraneous
              ├── fast-unique-numbers@ extraneous
              ├── fast-uri@ extraneous
              ├── fast-xml-parser@ extraneous
              ├── fastq@ extraneous
              ├── fecha@ extraneous
              ├── fetch-enhanced@ extraneous
              ├── file-stream-rotator@ extraneous
              ├── file-type@ extraneous
              ├── file-uri-to-path@ extraneous
              ├── fill-range@ extraneous
              ├── finalhandler@ extraneous
              ├── find-up@ extraneous
              ├── find-yarn-workspace-root@ extraneous
              ├── flat@ extraneous
              ├── fn.name@ extraneous
              ├── follow-redirects@ extraneous
              ├── for-each@ extraneous
              ├── foreground-child@ extraneous
              ├── forever-agent@ extraneous
              ├── form-data@ extraneous
              ├── forwarded@ extraneous
              ├── fresh@ extraneous
              ├── from@ extraneous
              ├── fs-constants@1.0.0 extraneous
              ├── fs-extra@7.0.1
              ├── fs-minipass@ extraneous
              ├── fs.realpath@ extraneous
              ├── fsevents@ extraneous
              ├── ftp-response-parser@ extraneous
              ├── function-bind@ extraneous
              ├── function.prototype.name@ extraneous
              ├── functions-have-names@ extraneous
              ├── gauge@ extraneous
              ├── gaxios@ extraneous
              ├── gcp-metadata@ extraneous
              ├── generate-function@ extraneous
              ├── generator-function@ extraneous
              ├── get-caller-file@1.0.3 extraneous
              ├── get-func-name@ extraneous
              ├── get-intrinsic@ extraneous
              ├── get-proto@ extraneous
              ├── get-stream@ extraneous
              ├── get-symbol-description@ extraneous
              ├── getpass@ extraneous
              ├── github-from-package@ extraneous
              ├── glob-parent@ extraneous
              ├── glob@ extraneous
              ├── globalthis@ extraneous
              ├── glossy@ extraneous
              ├── google-auth-library@ extraneous
              ├── google-logging-utils@ extraneous
              ├── google-tts-api@ extraneous
              ├── googleapis-common@ extraneous
              ├── googleapis@ extraneous
              ├── gopd@ extraneous
              ├── gtoken@ extraneous
              ├── har-schema@ extraneous
              ├── har-validator@ extraneous
              ├── has-bigints@ extraneous
              ├── has-binary@ extraneous
              ├── has-binary2@1.0.3 extraneous
              ├── has-cors@ extraneous
              ├── has-flag@ extraneous
              ├── has-property-descriptors@ extraneous
              ├── has-proto@ extraneous
              ├── has-symbols@ extraneous
              ├── has-tostringtag@ extraneous
              ├── has-unicode@ extraneous
              ├── hasown@ extraneous
              ├── he@ extraneous
              ├── help-me@ extraneous
              ├── hexy@ extraneous
              ├── homematic-xmlrpc@ extraneous
              ├── hosted-git-info@ extraneous
              ├── htmlparser2@ extraneous
              ├── http-cache-semantics@ extraneous
              ├── http-errors@ extraneous
              ├── http-proxy-agent@ extraneous
              ├── http-proxy-middleware@ extraneous
              ├── http-proxy@ extraneous
              ├── http-signature@ extraneous
              ├── https-proxy-agent@ extraneous
              ├── https@ extraneous
              ├── human-signals@ extraneous
              ├── humanize-ms@ extraneous
              ├── iconv-lite@ extraneous
              ├── icy@ extraneous
              ├── ieee754@ extraneous
              ├── ignore-by-default@ extraneous
              ├── immediate@ extraneous
              ├── immutable@ extraneous
              ├── imurmurhash@ extraneous
              ├── indent-string@ extraneous
              ├── indexof@ extraneous
              ├── infer-owner@ extraneous
              ├── inflight@ extraneous
              ├── influx@ extraneous
              ├── inherits@ extraneous
              ├── ini@ extraneous
              ├── int64-buffer@ extraneous
              ├── internal-slot@ extraneous
              ├── invert-kv@ extraneous
              ├── iobroker.accuweather@ invalid: "2.1.1" from the root project
              ├── iobroker.admin@ invalid: "7.7.19" from the root project
              ├── iobroker.alias-manager@ invalid: "2.0.0" from the root project
              ├── iobroker.amazon-dash@ invalid: "1.2.0" from the root project
              ├── iobroker.chromecast@ invalid: "4.0.0" from the root project
              ├── iobroker.cloud@ invalid: "5.0.1" from the root project
              ├── iobroker.daswetter@ invalid: "3.2.3" from the root project
              ├── iobroker.deconz@ invalid: "1.6.4" from the root project
              ├── iobroker.devices@ invalid: "1.2.8" from the root project
              ├── iobroker.discovery@ invalid: "5.0.0" from the root project
              ├── iobroker.email@ invalid: "2.0.4" from the root project
              ├── iobroker.flot@ invalid: "1.12.0" from the root project
              ├── iobroker.fronius-solarweb@ invalid: "0.0.3" from the root project
              ├── iobroker.fronius@ invalid: "2.1.1" from the root project
              ├── iobroker.frontier_silicon@ invalid: "0.5.0" from the root project
              ├── iobroker.habpanel@ invalid: "0.5.0" from the root project
              ├── iobroker.history@ invalid: "3.0.1" from the root project
              ├── iobroker.hm-rega@ invalid: "5.1.0" from the root project
              ├── iobroker.hm-rpc@ invalid: "2.0.2" from the root project
              ├── iobroker.hs100@ invalid: "3.0.5" from the root project
              ├── iobroker.icons-addictive-flavour-png@ invalid: "^0.1.0" from the root project
              ├── iobroker.icons-fatcow-hosting@ invalid: "^0.1.0" from the root project
              ├── iobroker.icons-icons8@ invalid: "0.0.1" from the root project
              ├── iobroker.icons-material-png@ invalid: "^0.1.0" from the root project
              ├── iobroker.icons-material-svg@ invalid: "^0.1.0" from the root project
              ├── iobroker.icons-mfd-png@ invalid: "1.2.1" from the root project
              ├── iobroker.icons-mfd-svg@ invalid: "1.2.0" from the root project
              ├── iobroker.icons-open-icon-library-png@ invalid: "0.1.2" from the root project
              ├── iobroker.icons-ultimate-png@ invalid: "^1.0.1" from the root project
              ├── iobroker.influxdb@ invalid: "4.0.2" from the root project
              ├── iobroker.info@ invalid: "2.0.0" from the root project
              ├── iobroker.iot@ invalid: "5.0.7" from the root project
              ├── iobroker.javascript@ invalid: "8.9.2" from the root project
              ├── iobroker.js-controller@ invalid: "^7.0.7" from the root project
              ├── iobroker.mihome-vacuum@ invalid: "5.2.0" from the root project
              ├── iobroker.mqtt@ invalid: "6.1.4" from the root project
              ├── iobroker.net-tools@ invalid: "1.1.2" from the root project
              ├── iobroker.octoprint@ invalid: "5.1.0" from the root project
              ├── iobroker.openweathermap@ invalid: "1.1.2" from the root project
              ├── iobroker.parser@ invalid: "2.2.4" from the root project
              ├── iobroker.ping@ invalid: "1.6.2" from the root project
              ├── iobroker.proxmox@ invalid: "2.4.0" from the root project
              ├── iobroker.radar@ invalid: "^1.2.1" from the root project
              ├── iobroker.radar2@ invalid: "^2.0.3" from the root project
              ├── iobroker.reolink@ invalid: "1.2.3" from the root project
              ├── iobroker.rickshaw@ invalid: "^1.0.0" from the root project
              ├── iobroker.s7@ invalid: "1.5.0" from the root project
              ├── iobroker.sayit@ invalid: "5.0.0" from the root project
              ├── iobroker.smartmeter@ invalid: "3.4.0" from the root project
              ├── iobroker.socketio@ invalid: "6.7.1" from the root project
              ├── iobroker.sql@ invalid: "3.0.1" from the root project
              ├── iobroker.statistics@ invalid: "2.4.0" from the root project
              ├── iobroker.systeminfo@ invalid: "1.3.0" from the root project
              ├── iobroker.telegram@ invalid: "4.1.0" from the root project
              ├── iobroker.terminal@ invalid: "1.0.0" from the root project
              ├── iobroker.tr-064@ invalid: "4.3.0" from the root project
              ├── iobroker.unifi@ invalid: "0.7.0" from the root project
              ├── iobroker.upnp@ invalid: "1.1.0" from the root project
              ├── iobroker.vis-2-widgets-inventwo@ invalid: "0.2.2" from the root project
              ├── iobroker.vis-2-widgets-material@ invalid: "1.4.10" from the root project
              ├── iobroker.vis-2@ invalid: "2.13.4" from the root project
              ├── iobroker.vis-bars@ invalid: "^0.1.4" from the root project
              ├── iobroker.vis-canvas-gauges@ invalid: "1.0.1" from the root project
              ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
              ├── iobroker.vis-fancyswitch@ invalid: "^1.1.0" from the root project
              ├── iobroker.vis-google-fonts@ invalid: "1.0.4" from the root project
              ├── iobroker.vis-history@ invalid: "^1.0.0" from the root project
              ├── iobroker.vis-hqwidgets@ invalid: "1.5.1" from the root project
              ├── iobroker.vis-jqui-mfd@ invalid: "^1.0.12" from the root project
              ├── iobroker.vis-justgage@ invalid: "2.1.7" from the root project
              ├── iobroker.vis-keyboard@ invalid: "0.0.2" from the root project
              ├── iobroker.vis-lcars@ invalid: "1.1.1" from the root project
              ├── iobroker.vis-map@ invalid: "1.1.2" from the root project
              ├── iobroker.vis-materialdesign@ invalid: "0.5.9" from the root project
              ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
              ├── iobroker.vis-rgraph@ invalid: "0.0.2" from the root project
              ├── iobroker.vis-weather@ invalid: "2.5.12" from the root project
              ├── iobroker.vis@ invalid: "1.5.6" from the root project
              ├── iobroker.weatherunderground@ invalid: "3.7.0" from the root project
              ├── iobroker.web@ invalid: "7.0.8" from the root project
              ├── iobroker.ws@ invalid: "2.6.2" from the root project
              ├── iobroker@ invalid: "^2.0.2" from the root project
              ├── ioredis@ extraneous
              ├── ip-address@ extraneous
              ├── ip@ extraneous
              ├── ipaddr.js@ extraneous
              ├── is-arguments@ extraneous
              ├── is-array-buffer@ extraneous
              ├── is-arrayish@ extraneous
              ├── is-async-function@ extraneous
              ├── is-bigint@ extraneous
              ├── is-binary-path@ extraneous
              ├── is-boolean-object@ extraneous
              ├── is-callable@ extraneous
              ├── is-core-module@ extraneous
              ├── is-data-view@ extraneous
              ├── is-date-object@ extraneous
              ├── is-docker@ extraneous
              ├── is-extglob@ extraneous
              ├── is-finalizationregistry@ extraneous
              ├── is-fullwidth-code-point@ extraneous
              ├── is-generator-function@ extraneous
              ├── is-generator@ extraneous
              ├── is-glob@ extraneous
              ├── is-lambda@ extraneous
              ├── is-map@ extraneous
              ├── is-negative-zero@ extraneous
              ├── is-number-like@ extraneous
              ├── is-number-object@ extraneous
              ├── is-number@ extraneous
              ├── is-path-inside@ extraneous
              ├── is-plain-obj@ extraneous
              ├── is-plain-object@ extraneous
              ├── is-promise@ extraneous
              ├── is-property@ extraneous
              ├── is-regex@ extraneous
              ├── is-set@ extraneous
              ├── is-shared-array-buffer@ extraneous
              ├── is-stream@ extraneous
              ├── is-string@ extraneous
              ├── is-symbol@ extraneous
              ├── is-typed-array@ extraneous
              ├── is-typedarray@ extraneous
              ├── is-unicode-supported@ extraneous
              ├── is-utf8@ extraneous
              ├── is-weakmap@ extraneous
              ├── is-weakref@ extraneous
              ├── is-weakset@ extraneous
              ├── is-wsl@ extraneous
              ├── is@ extraneous
              ├── isarray@ extraneous
              ├── isexe@ extraneous
              ├── isomorphic-ws@ extraneous
              ├── isstream@ extraneous
              ├── jackspeak@ extraneous
              ├── jose@ extraneous
              ├── js-md4@ extraneous
              ├── js-sdsl@ extraneous
              ├── js-yaml@ extraneous
              ├── jsbi@ extraneous
              ├── jsbn@ extraneous
              ├── jsdom@ extraneous
              ├── jsftp@ extraneous
              ├── jshashes@ extraneous
              ├── json-bigint@ extraneous
              ├── json-logic-js@ extraneous
              ├── json-schema-traverse@ extraneous
              ├── json-schema@ extraneous
              ├── json-stable-stringify@ extraneous
              ├── json-stringify-safe@ extraneous
              ├── json3@ extraneous
              ├── json5@ extraneous
              ├── jsonata@ extraneous
              ├── jsonc-parser@ extraneous
              ├── jsonify@ extraneous
              ├── jsonwebtoken@ extraneous
              ├── jsprim@ extraneous
              ├── jszip@ extraneous
              ├── jwa@ extraneous
              ├── jwks-rsa@ extraneous
              ├── jws@ extraneous
              ├── klaw-sync@ extraneous
              ├── kuler@ extraneous
              ├── lazystream@ extraneous
              ├── lcid@ extraneous
              ├── leven@ extraneous
              ├── levn@ extraneous
              ├── lie@ extraneous
              ├── limiter@ extraneous
              ├── load-json-file@ extraneous
              ├── loadavg-windows@ extraneous
              ├── localforage@ extraneous
              ├── locate-path@ extraneous
              ├── lodash.camelcase@ extraneous
              ├── lodash.castarray@ extraneous
              ├── lodash.clone@ extraneous
              ├── lodash.clonedeep@ extraneous
              ├── lodash.defaults@ extraneous
              ├── lodash.defaultto@ extraneous
              ├── lodash.flatten@ extraneous
              ├── lodash.get@ extraneous
              ├── lodash.groupby@ extraneous
              ├── lodash.includes@ extraneous
              ├── lodash.isarguments@ extraneous
              ├── lodash.isboolean@ extraneous
              ├── lodash.isequal@ extraneous
              ├── lodash.isfinite@ extraneous
              ├── lodash.isinteger@ extraneous
              ├── lodash.isnumber@ extraneous
              ├── lodash.isplainobject@ extraneous
              ├── lodash.isstring@ extraneous
              ├── lodash.once@ extraneous
              ├── lodash.truncate@ extraneous
              ├── lodash@ extraneous
              ├── log-symbols@ extraneous
              ├── logform@ extraneous
              ├── loglevel@ extraneous
              ├── long-timeout@ extraneous
              ├── long@ extraneous
              ├── loupe@ extraneous
              ├── lru-cache@ extraneous
              ├── lru-memoizer@ extraneous
              ├── lru.min@ extraneous
              ├── luxon@ extraneous
              ├── make-dir@ extraneous
              ├── make-fetch-happen@ extraneous
              ├── map-stream@ extraneous
              ├── math-intrinsics@ extraneous
              ├── mdns-discovery@ extraneous
              ├── mdns@ extraneous
              ├── media-typer@ extraneous
              ├── merge-descriptors@ extraneous
              ├── merge-stream@ extraneous
              ├── merge2@ extraneous
              ├── methods@ extraneous
              ├── micromatch@ extraneous
              ├── mime-db@ extraneous
              ├── mime-types@ extraneous
              ├── mime@ extraneous
              ├── mimic-fn@ extraneous
              ├── mimic-response@ extraneous
              ├── minimatch@ extraneous
              ├── minimist@ extraneous
              ├── minipass-collect@ extraneous
              ├── minipass-fetch@ extraneous
              ├── minipass-flush@ extraneous
              ├── minipass-pipeline@ extraneous
              ├── minipass-sized@ extraneous
              ├── minipass@ extraneous
              ├── minizlib@ extraneous
              ├── mitt@ extraneous
              ├── mkdirp-classic@ extraneous
              ├── mkdirp@ extraneous
              ├── mocha@ extraneous
              ├── moment@ extraneous
              ├── mp3-duration@ extraneous
              ├── mqtt-connection@ extraneous
              ├── mqtt-packet@ extraneous
              ├── mqtt@ extraneous
              ├── ms@ extraneous
              ├── mssql@ extraneous
              ├── multicast-dns@ extraneous
              ├── mute-stream@ extraneous
              ├── mysql2@ extraneous
              ├── named-placeholders@ extraneous
              ├── nan@ extraneous
              ├── napi-build-utils@ extraneous
              ├── napi-thread-safe-callback@ extraneous
              ├── native-duplexpair@ extraneous
              ├── needle@ extraneous
              ├── negotiator@ extraneous
              ├── net-ping@ extraneous
              ├── netmask@ extraneous
              ├── noble@ extraneous
              ├── node-abi@ extraneous
              ├── node-abort-controller@ extraneous
              ├── node-addon-api@ extraneous
              ├── node-arp@ extraneous
              ├── node-ble@ extraneous
              ├── node-fetch@ extraneous
              ├── node-forge@ extraneous
              ├── node-gyp-build@ extraneous
              ├── node-gyp@ extraneous
              ├── node-inspect@ extraneous
              ├── node-mndp@ extraneous
              ├── node-schedule@ extraneous
              ├── node-snap7@ extraneous
              ├── node-ssdp@ extraneous
              ├── node-telegram-bot-api@ extraneous
              ├── node-unifi@ extraneous
              ├── node.extend@ extraneous
              ├── nodemailer@ extraneous
              ├── nodemon@ extraneous
              ├── nopt@ extraneous
              ├── normalize-package-data@ extraneous
              ├── normalize-path@ extraneous
              ├── npm-run-path@ extraneous
              ├── npmlog@ extraneous
              ├── nth-check@ extraneous
              ├── number-allocator@ extraneous
              ├── number-is-nan@ extraneous
              ├── nwmatcher@ extraneous
              ├── oauth-sign@0.9.0 extraneous
              ├── oauth2-server@ extraneous
              ├── object-assign@ extraneous
              ├── object-component@ extraneous
              ├── object-hash@ extraneous
              ├── object-inspect@ extraneous
              ├── object-keys@ extraneous
              ├── object.assign@ extraneous
              ├── on-finished@ extraneous
              ├── on-headers@ extraneous
              ├── once@ extraneous
              ├── one-time@ extraneous
              ├── onetime@ extraneous
              ├── open-sml@ extraneous
              ├── open@ extraneous
              ├── opn@ extraneous
              ├── optionator@ extraneous
              ├── options@ extraneous
              ├── os-locale@ extraneous
              ├── osx-temperature-sensor@ extraneous
              ├── oui@ extraneous
              ├── own-keys@ extraneous
              ├── p-limit@ extraneous
              ├── p-locate@ extraneous
              ├── p-map@ extraneous
              ├── package-json-from-dist@ extraneous
              ├── pako@ extraneous
              ├── parse-json@ extraneous
              ├── parse-listing@ extraneous
              ├── parse5-htmlparser2-tree-adapter@ extraneous
              ├── parse5-parser-stream@ extraneous
              ├── parse5@ extraneous
              ├── parsejson@ extraneous
              ├── parseqs@ extraneous
              ├── parseuri@ extraneous
              ├── parseurl@ extraneous
              ├── parsexmlresponse@ extraneous
              ├── passport-local@ extraneous
              ├── passport-strategy@ extraneous
              ├── passport@ extraneous
              ├── patch-package@ extraneous
              ├── path-exists@ extraneous
              ├── path-is-absolute@ extraneous
              ├── path-key@ extraneous
              ├── path-parse@ extraneous
              ├── path-scurry@ extraneous
              ├── path-to-regexp@ extraneous
              ├── path-type@ extraneous
              ├── pathval@ extraneous
              ├── pause-stream@ extraneous
              ├── pause@ extraneous
              ├── pcap@ extraneous
              ├── performance-now@ extraneous
              ├── pg-cloudflare@ extraneous
              ├── pg-connection-string@ extraneous
              ├── pg-int8@ extraneous
              ├── pg-pool@ extraneous
              ├── pg-protocol@ extraneous
              ├── pg-types@ extraneous
              ├── pg@ extraneous
              ├── pgpass@ extraneous
              ├── picocolors@ extraneous
              ├── picomatch@ extraneous
              ├── pidtree@ extraneous
              ├── pidusage@ extraneous
              ├── pify@ extraneous
              ├── ping@ extraneous
              ├── pinkie-promise@ extraneous
              ├── pinkie@ extraneous
              ├── playlist-parser@ extraneous
              ├── portfinder@ extraneous
              ├── portscanner@ extraneous
              ├── possible-typed-array-names@ extraneous
              ├── postgres-array@ extraneous
              ├── postgres-bytea@ extraneous
              ├── postgres-date@ extraneous
              ├── postgres-interval@ extraneous
              ├── prebuild-install@ extraneous
              ├── prelude-ls@ extraneous
              ├── proc-log@ extraneous
              ├── process-nextick-args@ extraneous
              ├── process@ extraneous
              ├── promise-inflight@ extraneous
              ├── promise-queue@ extraneous
              ├── promise-retry@ extraneous
              ├── promisify-any@ extraneous
              ├── promisify-child-process@ extraneous
              ├── prompt@ extraneous
              ├── protobufjs@ extraneous
              ├── proxy-addr@ extraneous
              ├── proxy-from-env@ extraneous
              ├── ps-tree@ extraneous
              ├── psl@ extraneous
              ├── pstree.remy@ extraneous
              ├── pump@ extraneous
              ├── punycode@ extraneous
              ├── put@ extraneous
              ├── q@ extraneous
              ├── qjobs@ extraneous
              ├── qs@ extraneous
              ├── querystringify@ extraneous
              ├── queue-microtask@ extraneous
              ├── quick-lru@ extraneous
              ├── random-bytes@ extraneous
              ├── randombytes@ extraneous
              ├── range-parser@ extraneous
              ├── raw-body@ extraneous
              ├── raw-socket@ extraneous
              ├── rc@1.2.8 extraneous
              ├── read-pkg-up@ extraneous
              ├── read-pkg@ extraneous
              ├── read@ extraneous
              ├── readable-stream@ extraneous
              ├── readdir-glob@ extraneous
              ├── readdirp@ extraneous
              ├── readline-sync@ extraneous
              ├── readline@ extraneous
              ├── redis-errors@ extraneous
              ├── redis-parser@ extraneous
              ├── reflect.getprototypeof@ extraneous
              ├── regexp.prototype.flags@ extraneous
              ├── reinterval@ extraneous
              ├── request-promise-core@ extraneous
              ├── request@ extraneous
              ├── require-directory@ extraneous
              ├── require-from-string@ extraneous
              ├── require-main-filename@ extraneous
              ├── requires-port@ extraneous
              ├── resolve@ extraneous
              ├── resp-modifier@ extraneous
              ├── respjs@ extraneous
              ├── retry@ extraneous
              ├── reusify@ extraneous
              ├── revalidator@ extraneous
              ├── rfdc@ extraneous
              ├── rimraf@ extraneous
              ├── router@ extraneous
              ├── run-parallel@ extraneous
              ├── rx@ extraneous
              ├── safe-array-concat@ extraneous
              ├── safe-buffer@ extraneous
              ├── safe-push-apply@ extraneous
              ├── safe-regex-test@ extraneous
              ├── safe-stable-stringify@ extraneous
              ├── safer-buffer@2.1.2 extraneous
              ├── sax@ extraneous
              ├── semver@ invalid: "^5.6.0" from the root project
              ├── send@ extraneous
              ├── seq-logging@ extraneous
              ├── seq-queue@ extraneous
              ├── serialize-javascript@ extraneous
              ├── serialport@ extraneous
              ├── serve-index@ extraneous
              ├── serve-static@ extraneous
              ├── server-destroy@ extraneous
              ├── set-blocking@ extraneous
              ├── set-function-length@ extraneous
              ├── set-function-name@ extraneous
              ├── set-proto@ extraneous
              ├── setimmediate@ extraneous
              ├── setprototypeof@ extraneous
              ├── shebang-command@ extraneous
              ├── shebang-regex@ extraneous
              ├── side-channel-list@ extraneous
              ├── side-channel-map@ extraneous
              ├── side-channel-weakmap@ extraneous
              ├── side-channel@ extraneous
              ├── siginfo@ extraneous
              ├── signal-exit@ extraneous
              ├── simple-concat@ extraneous
              ├── simple-get@ extraneous
              ├── simple-update-notifier@ extraneous
              ├── sinon-chai@ extraneous
              ├── sinon@ extraneous
              ├── slash@ extraneous
              ├── slice-ansi@ extraneous
              ├── smart-buffer@ extraneous
              ├── smartmeter-obis@ extraneous
              ├── socket.io-adapter@ extraneous
              ├── socket.io-client@ extraneous
              ├── socket.io-parser@ extraneous
              ├── socket.io@ extraneous
              ├── socks-proxy-agent@ extraneous
              ├── socks@ extraneous
              ├── sorted-array-functions@ extraneous
              ├── source-map-support@ extraneous
              ├── source-map@ extraneous
              ├── spdx-correct@ extraneous
              ├── spdx-exceptions@ extraneous
              ├── spdx-expression-parse@ extraneous
              ├── spdx-license-ids@ extraneous
              ├── split-ca@ extraneous
              ├── split@ extraneous
              ├── split2@ extraneous
              ├── sprintf-js@ extraneous
              ├── sql-client@ extraneous
              ├── sqlite3@ extraneous
              ├── sqlstring@ extraneous
              ├── ssh2@ extraneous
              ├── sshpk@ extraneous
              ├── ssri@ extraneous
              ├── stack-trace@ extraneous
              ├── stackback@ extraneous
              ├── standard-as-callback@ extraneous
              ├── statuses@ extraneous
              ├── stealthy-require@ extraneous
              ├── stop-iteration-iterator@ extraneous
              ├── stoppable@ extraneous
              ├── stream-combiner@ extraneous
              ├── stream-parser@ extraneous
              ├── stream-shift@ extraneous
              ├── stream-throttle@ extraneous
              ├── streamsearch@ extraneous
              ├── streamx@ extraneous
              ├── string_decoder@ extraneous
              ├── string-width-cjs@ extraneous
              ├── string-width@ extraneous
              ├── string.prototype.trim@ extraneous
              ├── string.prototype.trimend@ extraneous
              ├── string.prototype.trimstart@ extraneous
              ├── strip-ansi-cjs@ extraneous
              ├── strip-ansi@ extraneous
              ├── strip-bom@ extraneous
              ├── strip-final-newline@ extraneous
              ├── strip-json-comments@ extraneous
              ├── strnum@ extraneous
              ├── suncalc2@ extraneous
              ├── supports-color@ extraneous
              ├── supports-preserve-symlinks-flag@ extraneous
              ├── symbol-tree@ extraneous
              ├── systeminformation@ extraneous
              ├── table@ extraneous
              ├── tar-fs@ extraneous
              ├── tar-stream@ extraneous
              ├── tar@ extraneous
              ├── tarn@ extraneous
              ├── tedious@ extraneous
              ├── text-decoder@ extraneous
              ├── text-hex@ extraneous
              ├── text-table@ extraneous
              ├── through@ extraneous
              ├── through2@ extraneous
              ├── thunky@ extraneous
              ├── tldts-core@ extraneous
              ├── tldts@ extraneous
              ├── tmp@ extraneous
              ├── to-array@ extraneous
              ├── to-regex-range@ extraneous
              ├── toidentifier@ extraneous
              ├── touch@ extraneous
              ├── tough-cookie@ extraneous
              ├── tplink-smarthome-api@ extraneous
              ├── tplink-smarthome-crypto@ extraneous
              ├── tr-O64@ extraneous
              ├── tr46@ extraneous
              ├── traverse@ extraneous
              ├── treemap-js@ extraneous
              ├── triple-beam@ extraneous
              ├── tslib@ extraneous
              ├── tunnel-agent@ extraneous
              ├── tweetnacl@ extraneous
              ├── type-check@ extraneous
              ├── type-detect@ extraneous
              ├── type-fest@ extraneous
              ├── type-is@ extraneous
              ├── typed-array-buffer@ extraneous
              ├── typed-array-byte-length@ extraneous
              ├── typed-array-byte-offset@ extraneous
              ├── typed-array-length@ extraneous
              ├── typedarray@ extraneous
              ├── typescript@ extraneous
              ├── ua-parser-js@ extraneous
              ├── uid-number@ extraneous
              ├── uid-safe@2.1.5 extraneous
              ├── ultron@ extraneous
              ├── unbox-primitive@ extraneous
              ├── undefsafe@ extraneous
              ├── underscore@ extraneous
              ├── undici-types@ extraneous
              ├── undici@ extraneous
              ├── unique-filename@ extraneous
              ├── unique-slug@ extraneous
              ├── unix-dgram@ extraneous
              ├── unorm@ extraneous
              ├── unpipe@ extraneous
              ├── uri-js@ extraneous
              ├── url-parse@ extraneous
              ├── url-template@ extraneous
              ├── url@ extraneous
              ├── usb@ extraneous
              ├── usocket@ extraneous
              ├── util-deprecate@ extraneous
              ├── util@ extraneous
              ├── utils-merge@ extraneous
              ├── uuid@ extraneous
              ├── validate-npm-package-license@3.0.4 extraneous
              ├── vary@ extraneous
              ├── verror@ extraneous
              ├── virtual-tsc@ extraneous
              ├── wake_on_lan@ extraneous
              ├── weak-daemon@ extraneous
              ├── webidl-conversions@ extraneous
              ├── websocket-stream@ extraneous
              ├── whatwg-encoding@ extraneous
              ├── whatwg-mimetype@ extraneous
              ├── whatwg-url-compat@ extraneous
              ├── whatwg-url@ extraneous
              ├── which-boxed-primitive@ extraneous
              ├── which-builtin-type@ extraneous
              ├── which-collection@ extraneous
              ├── which-module@ extraneous
              ├── which-typed-array@ extraneous
              ├── which@ extraneous
              ├── why-is-node-running@ extraneous
              ├── wide-align@ extraneous
              ├── widest-line@ extraneous
              ├── winston-daily-rotate-file@ extraneous
              ├── winston-seq-updated@ extraneous
              ├── winston-syslog@ extraneous
              ├── winston-transport@ extraneous
              ├── winston@ extraneous
              ├── wol@ extraneous
              ├── word-wrap@ extraneous
              ├── worker-factory@ extraneous
              ├── worker-timers-broker@ extraneous
              ├── worker-timers-worker@ extraneous
              ├── worker-timers@ extraneous
              ├── workerpool@ extraneous
              ├── wrap-ansi-cjs@ extraneous
              ├── wrap-ansi@ extraneous
              ├── wrappy@ extraneous
              ├── ws@ extraneous
              ├── wtf-8@ extraneous
              ├── xml-name-validator@ extraneous
              ├── xml2js@ extraneous
              ├── xml2json-light@ extraneous
              ├── xmlbuilder@ extraneous
              ├── xmldom@ extraneous
              ├── xmlhttprequest-ssl@ extraneous
              ├── xmlhttprequest@ extraneous
              ├── xpc-connection@ extraneous
              ├── xtend@ extraneous
              ├── y18n@ extraneous
              ├── yallist@ extraneous
              ├── yaml@ extraneous
              ├── yargs-parser@ extraneous
              ├── yargs-unparser@ extraneous
              ├── yargs@ invalid: "^7.0.2" from the root project
              ├── yeast@ extraneous
              ├── yocto-queue@ extraneous
              ├── youtube-remote@ extraneous
              └── zip-stream@ extraneous
              npm error code ELSPROBLEMS
              npm error extraneous: @abandonware/bluetooth-hci-socket@ /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
              npm error extraneous: @abandonware/noble@ /opt/iobroker/node_modules/@abandonware/noble
              npm error extraneous: @alcalzone/esbuild-register@ /opt/iobroker/node_modules/@alcalzone/esbuild-register
              npm error extraneous: @alcalzone/jsonl-db@ /opt/iobroker/node_modules/@alcalzone/jsonl-db
              npm error extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/@alcalzone/pak
              npm error extraneous: @alcalzone/proper-lockfile@ /opt/iobroker/node_modules/@alcalzone/proper-lockfile
              npm error extraneous: @all-smart/all-smart-tools@ /opt/iobroker/node_modules/@all-smart/all-smart-tools
              npm error extraneous: @aws-crypto/sha256-browser@ /opt/iobroker/node_modules/@aws-crypto/sha256-browser
              npm error extraneous: @aws-crypto/sha256-js@ /opt/iobroker/node_modules/@aws-crypto/sha256-js
              npm error extraneous: @aws-crypto/supports-web-crypto@ /opt/iobroker/node_modules/@aws-crypto/supports-web-crypto
              npm error extraneous: @aws-crypto/util@ /opt/iobroker/node_modules/@aws-crypto/util
              npm error extraneous: @aws-sdk/client-polly@ /opt/iobroker/node_modules/@aws-sdk/client-polly
              npm error extraneous: @aws-sdk/client-sso@ /opt/iobroker/node_modules/@aws-sdk/client-sso
              npm error extraneous: @aws-sdk/core@ /opt/iobroker/node_modules/@aws-sdk/core
              npm error extraneous: @aws-sdk/credential-provider-env@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-env
              npm error extraneous: @aws-sdk/credential-provider-http@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-http
              npm error extraneous: @aws-sdk/credential-provider-ini@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-ini
              npm error extraneous: @aws-sdk/credential-provider-node@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-node
              npm error extraneous: @aws-sdk/credential-provider-process@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-process
              npm error extraneous: @aws-sdk/credential-provider-sso@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-sso
              npm error extraneous: @aws-sdk/credential-provider-web-identity@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-web-identity
              npm error extraneous: @aws-sdk/middleware-host-header@ /opt/iobroker/node_modules/@aws-sdk/middleware-host-header
              npm error extraneous: @aws-sdk/middleware-logger@ /opt/iobroker/node_modules/@aws-sdk/middleware-logger
              npm error extraneous: @aws-sdk/middleware-recursion-detection@ /opt/iobroker/node_modules/@aws-sdk/middleware-recursion-detection
              npm error extraneous: @aws-sdk/middleware-user-agent@ /opt/iobroker/node_modules/@aws-sdk/middleware-user-agent
              npm error extraneous: @aws-sdk/nested-clients@ /opt/iobroker/node_modules/@aws-sdk/nested-clients
              npm error extraneous: @aws-sdk/region-config-resolver@ /opt/iobroker/node_modules/@aws-sdk/region-config-resolver
              npm error extraneous: @aws-sdk/token-providers@ /opt/iobroker/node_modules/@aws-sdk/token-providers
              npm error extraneous: @aws-sdk/types@ /opt/iobroker/node_modules/@aws-sdk/types
              npm error extraneous: @aws-sdk/util-endpoints@ /opt/iobroker/node_modules/@aws-sdk/util-endpoints
              npm error extraneous: @aws-sdk/util-locate-window@ /opt/iobroker/node_modules/@aws-sdk/util-locate-window
              npm error extraneous: @aws-sdk/util-user-agent-browser@ /opt/iobroker/node_modules/@aws-sdk/util-user-agent-browser
              npm error extraneous: @aws-sdk/util-user-agent-node@ /opt/iobroker/node_modules/@aws-sdk/util-user-agent-node
              npm error extraneous: @aws-sdk/xml-builder@ /opt/iobroker/node_modules/@aws-sdk/xml-builder
              npm error extraneous: @aws/lambda-invoke-store@ /opt/iobroker/node_modules/@aws/lambda-invoke-store
              npm error extraneous: @azure-rest/core-client@ /opt/iobroker/node_modules/@azure-rest/core-client
              npm error extraneous: @azure/abort-controller@ /opt/iobroker/node_modules/@azure/abort-controller
              npm error extraneous: @azure/core-auth@ /opt/iobroker/node_modules/@azure/core-auth
              npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
              npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
              npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
              npm error extraneous: @azure/core-paging@ /opt/iobroker/node_modules/@azure/core-paging
              npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
              npm error extraneous: @azure/core-tracing@ /opt/iobroker/node_modules/@azure/core-tracing
              npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
              npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
              npm error extraneous: @azure/keyvault-common@ /opt/iobroker/node_modules/@azure/keyvault-common
              npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
              npm error extraneous: @azure/logger@ /opt/iobroker/node_modules/@azure/logger
              npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
              npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
              npm error extraneous: @azure/msal-node@ /opt/iobroker/node_modules/@azure/msal-node
              npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
              npm error extraneous: @balena/dockerignore@ /opt/iobroker/node_modules/@balena/dockerignore
              npm error extraneous: @colors/colors@ /opt/iobroker/node_modules/@colors/colors
              npm error extraneous: @cypress/request-promise@ /opt/iobroker/node_modules/@cypress/request-promise
              npm error extraneous: @cypress/request@ /opt/iobroker/node_modules/@cypress/request
              npm error extraneous: @dabh/diagnostics@ /opt/iobroker/node_modules/@dabh/diagnostics
              npm error extraneous: @datalust/winston-seq@ /opt/iobroker/node_modules/@datalust/winston-seq
              npm error extraneous: @fastify/busboy@ /opt/iobroker/node_modules/@fastify/busboy
              npm error extraneous: @gar/promisify@ /opt/iobroker/node_modules/@gar/promisify
              npm error extraneous: @grpc/grpc-js@ /opt/iobroker/node_modules/@grpc/grpc-js
              npm error extraneous: @grpc/proto-loader@ /opt/iobroker/node_modules/@grpc/proto-loader
              npm error extraneous: @httptoolkit/websocket-stream@ /opt/iobroker/node_modules/@httptoolkit/websocket-stream
              npm error extraneous: @influxdata/influxdb-client-apis@ /opt/iobroker/node_modules/@influxdata/influxdb-client-apis
              npm error extraneous: @influxdata/influxdb-client@ /opt/iobroker/node_modules/@influxdata/influxdb-client
              npm error invalid: @iobroker-javascript.0/moment-parseformat@ /opt/iobroker/node_modules/@iobroker-javascript.0/moment-parseformat
              npm error invalid: @iobroker-javascript.0/moment@ /opt/iobroker/node_modules/@iobroker-javascript.0/moment
              npm error extraneous: @iobroker/adapter-core@ /opt/iobroker/node_modules/@iobroker/adapter-core
              npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
              npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
              npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
              npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
              npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
              npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
              npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
              npm error extraneous: @iobroker/dev-server@ /opt/iobroker/node_modules/@iobroker/dev-server
              npm error extraneous: @iobroker/dm-utils@ /opt/iobroker/node_modules/@iobroker/dm-utils
              npm error extraneous: @iobroker/i18n@ /opt/iobroker/node_modules/@iobroker/i18n
              npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
              npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
              npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
              npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
              npm error extraneous: @iobroker/plugin-base@ /opt/iobroker/node_modules/@iobroker/plugin-base
              npm error extraneous: @iobroker/plugin-docker@ /opt/iobroker/node_modules/@iobroker/plugin-docker
              npm error extraneous: @iobroker/plugin-sentry@ /opt/iobroker/node_modules/@iobroker/plugin-sentry
              npm error extraneous: @iobroker/socket-classes@ /opt/iobroker/node_modules/@iobroker/socket-classes
              npm error extraneous: @iobroker/testing@ /opt/iobroker/node_modules/@iobroker/testing
              npm error extraneous: @iobroker/type-detector@ /opt/iobroker/node_modules/@iobroker/type-detector
              npm error extraneous: @iobroker/types@ /opt/iobroker/node_modules/@iobroker/types
              npm error extraneous: @iobroker/webserver@ /opt/iobroker/node_modules/@iobroker/webserver
              npm error extraneous: @iobroker/ws-server@ /opt/iobroker/node_modules/@iobroker/ws-server
              npm error extraneous: @iobroker/ws@ /opt/iobroker/node_modules/@iobroker/ws
              npm error extraneous: @ioredis/commands@ /opt/iobroker/node_modules/@ioredis/commands
              npm error extraneous: @isaacs/balanced-match@ /opt/iobroker/node_modules/@isaacs/balanced-match
              npm error extraneous: @isaacs/brace-expansion@ /opt/iobroker/node_modules/@isaacs/brace-expansion
              npm error extraneous: @isaacs/cliui@ /opt/iobroker/node_modules/@isaacs/cliui
              npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
              npm error extraneous: @js-sdsl/ordered-map@ /opt/iobroker/node_modules/@js-sdsl/ordered-map
              npm error extraneous: @leichtgewicht/ip-codec@ /opt/iobroker/node_modules/@leichtgewicht/ip-codec
              npm error extraneous: @mapbox/node-pre-gyp@ /opt/iobroker/node_modules/@mapbox/node-pre-gyp
              npm error extraneous: @network-utils/arp-lookup@ /opt/iobroker/node_modules/@network-utils/arp-lookup
              npm error extraneous: @nodelib/fs.scandir@ /opt/iobroker/node_modules/@nodelib/fs.scandir
              npm error extraneous: @nodelib/fs.stat@ /opt/iobroker/node_modules/@nodelib/fs.stat
              npm error extraneous: @nodelib/fs.walk@ /opt/iobroker/node_modules/@nodelib/fs.walk
              npm error extraneous: @nornagon/put@ /opt/iobroker/node_modules/@nornagon/put
              npm error extraneous: @npmcli/agent@ /opt/iobroker/node_modules/@npmcli/agent
              npm error extraneous: @npmcli/fs@ /opt/iobroker/node_modules/@npmcli/fs
              npm error extraneous: @npmcli/move-file@ /opt/iobroker/node_modules/@npmcli/move-file
              npm error extraneous: @pkgjs/parseargs@ /opt/iobroker/node_modules/@pkgjs/parseargs
              npm error extraneous: @protobufjs/aspromise@ /opt/iobroker/node_modules/@protobufjs/aspromise
              npm error extraneous: @protobufjs/base64@ /opt/iobroker/node_modules/@protobufjs/base64
              npm error extraneous: @protobufjs/codegen@ /opt/iobroker/node_modules/@protobufjs/codegen
              npm error extraneous: @protobufjs/eventemitter@ /opt/iobroker/node_modules/@protobufjs/eventemitter
              npm error extraneous: @protobufjs/fetch@ /opt/iobroker/node_modules/@protobufjs/fetch
              npm error extraneous: @protobufjs/float@ /opt/iobroker/node_modules/@protobufjs/float
              npm error extraneous: @protobufjs/inquire@ /opt/iobroker/node_modules/@protobufjs/inquire
              npm error extraneous: @protobufjs/path@ /opt/iobroker/node_modules/@protobufjs/path
              npm error extraneous: @protobufjs/pool@ /opt/iobroker/node_modules/@protobufjs/pool
              npm error extraneous: @protobufjs/utf8@ /opt/iobroker/node_modules/@protobufjs/utf8
              npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
              npm error extraneous: @sentry/core@ /opt/iobroker/node_modules/@sentry/core
              npm error extraneous: @sentry/integrations@ /opt/iobroker/node_modules/@sentry/integrations
              npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
              npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
              npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
              npm error extraneous: @serialport/binding-mock@ /opt/iobroker/node_modules/@serialport/binding-mock
              npm error extraneous: @serialport/bindings-cpp@ /opt/iobroker/node_modules/@serialport/bindings-cpp
              npm error extraneous: @serialport/bindings-interface@ /opt/iobroker/node_modules/@serialport/bindings-interface
              npm error extraneous: @serialport/parser-byte-length@ /opt/iobroker/node_modules/@serialport/parser-byte-length
              npm error extraneous: @serialport/parser-cctalk@ /opt/iobroker/node_modules/@serialport/parser-cctalk
              npm error extraneous: @serialport/parser-delimiter@ /opt/iobroker/node_modules/@serialport/parser-delimiter
              npm error extraneous: @serialport/parser-inter-byte-timeout@ /opt/iobroker/node_modules/@serialport/parser-inter-byte-timeout
              npm error extraneous: @serialport/parser-packet-length@ /opt/iobroker/node_modules/@serialport/parser-packet-length
              npm error extraneous: @serialport/parser-readline@ /opt/iobroker/node_modules/@serialport/parser-readline
              npm error extraneous: @serialport/parser-ready@ /opt/iobroker/node_modules/@serialport/parser-ready
              npm error extraneous: @serialport/parser-regex@ /opt/iobroker/node_modules/@serialport/parser-regex
              npm error extraneous: @serialport/parser-slip-encoder@ /opt/iobroker/node_modules/@serialport/parser-slip-encoder
              npm error extraneous: @serialport/parser-spacepacket@ /opt/iobroker/node_modules/@serialport/parser-spacepacket
              npm error extraneous: @serialport/stream@ /opt/iobroker/node_modules/@serialport/stream
              npm error extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/@sinonjs/commons
              npm error extraneous: @sinonjs/fake-timers@ /opt/iobroker/node_modules/@sinonjs/fake-timers
              npm error extraneous: @sinonjs/samsam@ /opt/iobroker/node_modules/@sinonjs/samsam
              npm error extraneous: @smithy/abort-controller@ /opt/iobroker/node_modules/@smithy/abort-controller
              npm error extraneous: @smithy/config-resolver@ /opt/iobroker/node_modules/@smithy/config-resolver
              npm error extraneous: @smithy/core@ /opt/iobroker/node_modules/@smithy/core
              npm error extraneous: @smithy/credential-provider-imds@ /opt/iobroker/node_modules/@smithy/credential-provider-imds
              npm error extraneous: @smithy/fetch-http-handler@ /opt/iobroker/node_modules/@smithy/fetch-http-handler
              npm error extraneous: @smithy/hash-node@ /opt/iobroker/node_modules/@smithy/hash-node
              npm error extraneous: @smithy/invalid-dependency@ /opt/iobroker/node_modules/@smithy/invalid-dependency
              npm error extraneous: @smithy/is-array-buffer@ /opt/iobroker/node_modules/@smithy/is-array-buffer
              npm error extraneous: @smithy/middleware-content-length@ /opt/iobroker/node_modules/@smithy/middleware-content-length
              npm error extraneous: @smithy/middleware-endpoint@ /opt/iobroker/node_modules/@smithy/middleware-endpoint
              npm error extraneous: @smithy/middleware-retry@ /opt/iobroker/node_modules/@smithy/middleware-retry
              npm error extraneous: @smithy/middleware-serde@ /opt/iobroker/node_modules/@smithy/middleware-serde
              npm error extraneous: @smithy/middleware-stack@ /opt/iobroker/node_modules/@smithy/middleware-stack
              npm error extraneous: @smithy/node-config-provider@ /opt/iobroker/node_modules/@smithy/node-config-provider
              npm error extraneous: @smithy/node-http-handler@ /opt/iobroker/node_modules/@smithy/node-http-handler
              npm error extraneous: @smithy/property-provider@ /opt/iobroker/node_modules/@smithy/property-provider
              npm error extraneous: @smithy/protocol-http@ /opt/iobroker/node_modules/@smithy/protocol-http
              npm error extraneous: @smithy/querystring-builder@ /opt/iobroker/node_modules/@smithy/querystring-builder
              npm error extraneous: @smithy/querystring-parser@ /opt/iobroker/node_modules/@smithy/querystring-parser
              npm error extraneous: @smithy/service-error-classification@ /opt/iobroker/node_modules/@smithy/service-error-classification
              npm error extraneous: @smithy/shared-ini-file-loader@ /opt/iobroker/node_modules/@smithy/shared-ini-file-loader
              npm error extraneous: @smithy/signature-v4@ /opt/iobroker/node_modules/@smithy/signature-v4
              npm error extraneous: @smithy/smithy-client@ /opt/iobroker/node_modules/@smithy/smithy-client
              npm error extraneous: @smithy/types@ /opt/iobroker/node_modules/@smithy/types
              npm error extraneous: @smithy/url-parser@ /opt/iobroker/node_modules/@smithy/url-parser
              npm error extraneous: @smithy/util-base64@ /opt/iobroker/node_modules/@smithy/util-base64
              npm error extraneous: @smithy/util-body-length-browser@ /opt/iobroker/node_modules/@smithy/util-body-length-browser
              npm error extraneous: @smithy/util-body-length-node@ /opt/iobroker/node_modules/@smithy/util-body-length-node
              npm error extraneous: @smithy/util-buffer-from@ /opt/iobroker/node_modules/@smithy/util-buffer-from
              npm error extraneous: @smithy/util-config-provider@ /opt/iobroker/node_modules/@smithy/util-config-provider
              npm error extraneous: @smithy/util-defaults-mode-browser@ /opt/iobroker/node_modules/@smithy/util-defaults-mode-browser
              npm error extraneous: @smithy/util-defaults-mode-node@ /opt/iobroker/node_modules/@smithy/util-defaults-mode-node
              npm error extraneous: @smithy/util-endpoints@ /opt/iobroker/node_modules/@smithy/util-endpoints
              npm error extraneous: @smithy/util-hex-encoding@ /opt/iobroker/node_modules/@smithy/util-hex-encoding
              npm error extraneous: @smithy/util-middleware@ /opt/iobroker/node_modules/@smithy/util-middleware
              npm error extraneous: @smithy/util-retry@ /opt/iobroker/node_modules/@smithy/util-retry
              npm error extraneous: @smithy/util-stream@ /opt/iobroker/node_modules/@smithy/util-stream
              npm error extraneous: @smithy/util-uri-escape@ /opt/iobroker/node_modules/@smithy/util-uri-escape
              npm error extraneous: @smithy/util-utf8@ /opt/iobroker/node_modules/@smithy/util-utf8
              npm error extraneous: @smithy/uuid@ /opt/iobroker/node_modules/@smithy/uuid
              npm error extraneous: @so-ric/colorspace@ /opt/iobroker/node_modules/@so-ric/colorspace
              npm error extraneous: @socket.io/component-emitter@ /opt/iobroker/node_modules/@socket.io/component-emitter
              npm error extraneous: @stoprocent/bluetooth-hci-socket@ /opt/iobroker/node_modules/@stoprocent/bluetooth-hci-socket
              npm error extraneous: @stoprocent/noble@ /opt/iobroker/node_modules/@stoprocent/noble
              npm error extraneous: @tediousjs/connection-string@ /opt/iobroker/node_modules/@tediousjs/connection-string
              npm error extraneous: @tootallnate/once@ /opt/iobroker/node_modules/@tootallnate/once
              npm error extraneous: @types/body-parser@ /opt/iobroker/node_modules/@types/body-parser
              npm error extraneous: @types/caseless@ /opt/iobroker/node_modules/@types/caseless
              npm error extraneous: @types/chai-as-promised@ /opt/iobroker/node_modules/@types/chai-as-promised
              npm error extraneous: @types/chai@ /opt/iobroker/node_modules/@types/chai
              npm error extraneous: @types/connect@ /opt/iobroker/node_modules/@types/connect
              npm error extraneous: @types/cors@ /opt/iobroker/node_modules/@types/cors
              npm error extraneous: @types/express-serve-static-core@ /opt/iobroker/node_modules/@types/express-serve-static-core
              npm error extraneous: @types/express@ /opt/iobroker/node_modules/@types/express
              npm error extraneous: @types/http-errors@ /opt/iobroker/node_modules/@types/http-errors
              npm error extraneous: @types/http-proxy@ /opt/iobroker/node_modules/@types/http-proxy
              npm error extraneous: @types/jsonwebtoken@ /opt/iobroker/node_modules/@types/jsonwebtoken
              npm error extraneous: @types/long@ /opt/iobroker/node_modules/@types/long
              npm error extraneous: @types/luxon@ /opt/iobroker/node_modules/@types/luxon
              npm error extraneous: @types/mime@ /opt/iobroker/node_modules/@types/mime
              npm error extraneous: @types/mocha@ /opt/iobroker/node_modules/@types/mocha
              npm error extraneous: @types/ms@ /opt/iobroker/node_modules/@types/ms
              npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
              npm error extraneous: @types/qs@ /opt/iobroker/node_modules/@types/qs
              npm error extraneous: @types/range-parser@ /opt/iobroker/node_modules/@types/range-parser
              npm error extraneous: @types/readable-stream@ /opt/iobroker/node_modules/@types/readable-stream
              npm error extraneous: @types/request@ /opt/iobroker/node_modules/@types/request
              npm error extraneous: @types/send@ /opt/iobroker/node_modules/@types/send
              npm error extraneous: @types/serve-static@ /opt/iobroker/node_modules/@types/serve-static
              npm error extraneous: @types/sinon-chai@ /opt/iobroker/node_modules/@types/sinon-chai
              npm error extraneous: @types/sinon@ /opt/iobroker/node_modules/@types/sinon
              npm error extraneous: @types/sinonjs__fake-timers@ /opt/iobroker/node_modules/@types/sinonjs__fake-timers
              npm error extraneous: @types/tough-cookie@ /opt/iobroker/node_modules/@types/tough-cookie
              npm error extraneous: @types/triple-beam@ /opt/iobroker/node_modules/@types/triple-beam
              npm error extraneous: @types/w3c-web-usb@ /opt/iobroker/node_modules/@types/w3c-web-usb
              npm error extraneous: @types/ws@ /opt/iobroker/node_modules/@types/ws
              npm error extraneous: @typespec/ts-http-runtime@ /opt/iobroker/node_modules/@typespec/ts-http-runtime
              npm error extraneous: @yarnpkg/lockfile@ /opt/iobroker/node_modules/@yarnpkg/lockfile
              npm error extraneous: abbrev@ /opt/iobroker/node_modules/abbrev
              npm error extraneous: abort-controller@ /opt/iobroker/node_modules/abort-controller
              npm error extraneous: accepts@ /opt/iobroker/node_modules/accepts
              npm error extraneous: acorn-globals@ /opt/iobroker/node_modules/acorn-globals
              npm error extraneous: acorn@ /opt/iobroker/node_modules/acorn
              npm error extraneous: after@ /opt/iobroker/node_modules/after
              npm error extraneous: agent-base@ /opt/iobroker/node_modules/agent-base
              npm error extraneous: agentkeepalive@ /opt/iobroker/node_modules/agentkeepalive
              npm error extraneous: aggregate-error@ /opt/iobroker/node_modules/aggregate-error
              npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
              npm error extraneous: alcalzone-shared@ /opt/iobroker/node_modules/alcalzone-shared
              npm error extraneous: ansi-align@ /opt/iobroker/node_modules/ansi-align
              npm error extraneous: ansi-colors@ /opt/iobroker/node_modules/ansi-colors
              npm error extraneous: ansi-regex@ /opt/iobroker/node_modules/ansi-regex
              npm error extraneous: ansi-styles@ /opt/iobroker/node_modules/ansi-styles
              npm error extraneous: anymatch@ /opt/iobroker/node_modules/anymatch
              npm error extraneous: aproba@ /opt/iobroker/node_modules/aproba
              npm error extraneous: archiver-utils@ /opt/iobroker/node_modules/archiver-utils
              npm error extraneous: archiver@ /opt/iobroker/node_modules/archiver
              npm error extraneous: are-we-there-yet@ /opt/iobroker/node_modules/are-we-there-yet
              npm error extraneous: argf@ /opt/iobroker/node_modules/argf
              npm error extraneous: argparse@ /opt/iobroker/node_modules/argparse
              npm error extraneous: array-buffer-byte-length@ /opt/iobroker/node_modules/array-buffer-byte-length
              npm error extraneous: array-find@ /opt/iobroker/node_modules/array-find
              npm error extraneous: array-flatten@ /opt/iobroker/node_modules/array-flatten
              npm error extraneous: array.prototype.findindex@ /opt/iobroker/node_modules/array.prototype.findindex
              npm error extraneous: arraybuffer.prototype.slice@ /opt/iobroker/node_modules/arraybuffer.prototype.slice
              npm error extraneous: arraybuffer.slice@ /opt/iobroker/node_modules/arraybuffer.slice
              npm error extraneous: asn1@ /opt/iobroker/node_modules/asn1
              npm error extraneous: assert-plus@ /opt/iobroker/node_modules/assert-plus
              npm error extraneous: assertion-error@ /opt/iobroker/node_modules/assertion-error
              npm error extraneous: astral-regex@ /opt/iobroker/node_modules/astral-regex
              npm error extraneous: async-each-series@ /opt/iobroker/node_modules/async-each-series
              npm error extraneous: async-function@ /opt/iobroker/node_modules/async-function
              npm error extraneous: async-limiter@ /opt/iobroker/node_modules/async-limiter
              npm error extraneous: async@ /opt/iobroker/node_modules/async
              npm error extraneous: asynckit@ /opt/iobroker/node_modules/asynckit
              npm error extraneous: authenticate-pam@ /opt/iobroker/node_modules/authenticate-pam
              npm error extraneous: available-typed-arrays@ /opt/iobroker/node_modules/available-typed-arrays
              npm error extraneous: aws-iot-device-sdk@ /opt/iobroker/node_modules/aws-iot-device-sdk
              npm error extraneous: aws-sign2@ /opt/iobroker/node_modules/aws-sign2
              npm error extraneous: aws-ssl-profiles@ /opt/iobroker/node_modules/aws-ssl-profiles
              npm error extraneous: aws4@ /opt/iobroker/node_modules/aws4
              npm error extraneous: axios@ /opt/iobroker/node_modules/axios
              npm error extraneous: b4a@ /opt/iobroker/node_modules/b4a
              npm error extraneous: backo2@ /opt/iobroker/node_modules/backo2
              npm error extraneous: balanced-match@ /opt/iobroker/node_modules/balanced-match
              npm error extraneous: bare-events@ /opt/iobroker/node_modules/bare-events
              npm error extraneous: base-64@ /opt/iobroker/node_modules/base-64
              npm error extraneous: base64-arraybuffer@ /opt/iobroker/node_modules/base64-arraybuffer
              npm error extraneous: base64-js@ /opt/iobroker/node_modules/base64-js
              npm error extraneous: base64id@ /opt/iobroker/node_modules/base64id
              npm error extraneous: basic-auth@ /opt/iobroker/node_modules/basic-auth
              npm error extraneous: batch@ /opt/iobroker/node_modules/batch
              npm error extraneous: bcrypt-pbkdf@ /opt/iobroker/node_modules/bcrypt-pbkdf
              npm error extraneous: better-assert@ /opt/iobroker/node_modules/better-assert
              npm error extraneous: bignumber.js@ /opt/iobroker/node_modules/bignumber.js
              npm error extraneous: binary-extensions@ /opt/iobroker/node_modules/binary-extensions
              npm error extraneous: binary@ /opt/iobroker/node_modules/binary
              npm error extraneous: bindings@ /opt/iobroker/node_modules/bindings
              npm error extraneous: binrpc@ /opt/iobroker/node_modules/binrpc
              npm error extraneous: bl@ /opt/iobroker/node_modules/bl
              npm error extraneous: blob@ /opt/iobroker/node_modules/blob
              npm error extraneous: bluebird-co@ /opt/iobroker/node_modules/bluebird-co
              npm error extraneous: bluebird@ /opt/iobroker/node_modules/bluebird
              npm error extraneous: bluetooth-hci-socket@ /opt/iobroker/node_modules/bluetooth-hci-socket
              npm error extraneous: body-parser@ /opt/iobroker/node_modules/body-parser
              npm error extraneous: boolbase@ /opt/iobroker/node_modules/boolbase
              npm error extraneous: bower@ /opt/iobroker/node_modules/bower
              npm error extraneous: bowser@ /opt/iobroker/node_modules/bowser
              npm error extraneous: boxen@ /opt/iobroker/node_modules/boxen
              npm error extraneous: bplist-parser@ /opt/iobroker/node_modules/bplist-parser
              npm error extraneous: brace-expansion@ /opt/iobroker/node_modules/brace-expansion
              npm error extraneous: braces@ /opt/iobroker/node_modules/braces
              npm error extraneous: broker-factory@ /opt/iobroker/node_modules/broker-factory
              npm error extraneous: browser-request@ /opt/iobroker/node_modules/browser-request
              npm error extraneous: browser-stdout@ /opt/iobroker/node_modules/browser-stdout
              npm error extraneous: browser-sync-client@ /opt/iobroker/node_modules/browser-sync-client
              npm error extraneous: browser-sync-ui@ /opt/iobroker/node_modules/browser-sync-ui
              npm error extraneous: browser-sync@ /opt/iobroker/node_modules/browser-sync
              npm error extraneous: bs-html-injector@ /opt/iobroker/node_modules/bs-html-injector
              npm error extraneous: bs-recipes@ /opt/iobroker/node_modules/bs-recipes
              npm error extraneous: buffer-crc32@ /opt/iobroker/node_modules/buffer-crc32
              npm error extraneous: buffer-equal-constant-time@ /opt/iobroker/node_modules/buffer-equal-constant-time
              npm error extraneous: buffer-from@ /opt/iobroker/node_modules/buffer-from
              npm error extraneous: buffer@ /opt/iobroker/node_modules/buffer
              npm error extraneous: buffers@ /opt/iobroker/node_modules/buffers
              npm error extraneous: buildcheck@ /opt/iobroker/node_modules/buildcheck
              npm error extraneous: busboy@ /opt/iobroker/node_modules/busboy
              npm error extraneous: bytes@ /opt/iobroker/node_modules/bytes
              npm error extraneous: cacache@ /opt/iobroker/node_modules/cacache
              npm error extraneous: call-bind-apply-helpers@ /opt/iobroker/node_modules/call-bind-apply-helpers
              npm error extraneous: call-bind@ /opt/iobroker/node_modules/call-bind
              npm error extraneous: call-bound@ /opt/iobroker/node_modules/call-bound
              npm error extraneous: callsite@ /opt/iobroker/node_modules/callsite
              npm error extraneous: camelcase@ /opt/iobroker/node_modules/camelcase
              npm error extraneous: canvas@ /opt/iobroker/node_modules/canvas
              npm error extraneous: caseless@ /opt/iobroker/node_modules/caseless
              npm error extraneous: castv2-client@ /opt/iobroker/node_modules/castv2-client
              npm error extraneous: castv2-player@ /opt/iobroker/node_modules/castv2-player
              npm error extraneous: castv2@ /opt/iobroker/node_modules/castv2
              npm error extraneous: chai-as-promised@ /opt/iobroker/node_modules/chai-as-promised
              npm error extraneous: chai@ /opt/iobroker/node_modules/chai
              npm error extraneous: chainsaw@ /opt/iobroker/node_modules/chainsaw
              npm error extraneous: chalk@ /opt/iobroker/node_modules/chalk
              npm error extraneous: char-spinner@ /opt/iobroker/node_modules/char-spinner
              npm error extraneous: check-error@ /opt/iobroker/node_modules/check-error
              npm error extraneous: cheerio-select@ /opt/iobroker/node_modules/cheerio-select
              npm error extraneous: cheerio@ /opt/iobroker/node_modules/cheerio
              npm error extraneous: chokidar@ /opt/iobroker/node_modules/chokidar
              npm error extraneous: chownr@ /opt/iobroker/node_modules/chownr
              npm error extraneous: ci-info@ /opt/iobroker/node_modules/ci-info
              npm error extraneous: clean-stack@ /opt/iobroker/node_modules/clean-stack
              npm error extraneous: cli-boxes@ /opt/iobroker/node_modules/cli-boxes
              npm error extraneous: cliui@ /opt/iobroker/node_modules/cliui
              npm error extraneous: cluster-key-slot@ /opt/iobroker/node_modules/cluster-key-slot
              npm error extraneous: co-bluebird@ /opt/iobroker/node_modules/co-bluebird
              npm error extraneous: co-use@ /opt/iobroker/node_modules/co-use
              npm error extraneous: code-point-at@ /opt/iobroker/node_modules/code-point-at
              npm error extraneous: color-convert@ /opt/iobroker/node_modules/color-convert
              npm error extraneous: color-name@ /opt/iobroker/node_modules/color-name
              npm error extraneous: color-string@ /opt/iobroker/node_modules/color-string
              npm error extraneous: color-support@ /opt/iobroker/node_modules/color-support
              npm error extraneous: color@ /opt/iobroker/node_modules/color
              npm error invalid: colors@ /opt/iobroker/node_modules/colors
              npm error extraneous: combined-stream@ /opt/iobroker/node_modules/combined-stream
              npm error extraneous: commander@ /opt/iobroker/node_modules/commander
              npm error extraneous: commist@ /opt/iobroker/node_modules/commist
              npm error extraneous: component-bind@ /opt/iobroker/node_modules/component-bind
              npm error extraneous: component-emitter@ /opt/iobroker/node_modules/component-emitter
              npm error extraneous: component-inherit@ /opt/iobroker/node_modules/component-inherit
              npm error extraneous: compress-commons@ /opt/iobroker/node_modules/compress-commons
              npm error extraneous: compressible@ /opt/iobroker/node_modules/compressible
              npm error extraneous: compression@ /opt/iobroker/node_modules/compression
              npm error extraneous: concat-map@ /opt/iobroker/node_modules/concat-map
              npm error extraneous: concat-stream@ /opt/iobroker/node_modules/concat-stream
              npm error extraneous: connect-flash@ /opt/iobroker/node_modules/connect-flash
              npm error extraneous: connect-history-api-fallback@ /opt/iobroker/node_modules/connect-history-api-fallback
              npm error extraneous: connect@ /opt/iobroker/node_modules/connect
              npm error extraneous: console-control-strings@ /opt/iobroker/node_modules/console-control-strings
              npm error extraneous: content-disposition@ /opt/iobroker/node_modules/content-disposition
              npm error extraneous: content-type@ /opt/iobroker/node_modules/content-type
              npm error extraneous: cookie-parser@ /opt/iobroker/node_modules/cookie-parser
              npm error extraneous: cookie-signature@ /opt/iobroker/node_modules/cookie-signature
              npm error extraneous: cookie@ /opt/iobroker/node_modules/cookie
              npm error extraneous: core-util-is@ /opt/iobroker/node_modules/core-util-is
              npm error extraneous: cors@ /opt/iobroker/node_modules/cors
              npm error extraneous: country-data@ /opt/iobroker/node_modules/country-data
              npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
              npm error extraneous: crc-32@ /opt/iobroker/node_modules/crc-32
              npm error extraneous: crc32-stream@ /opt/iobroker/node_modules/crc32-stream
              npm error extraneous: cron-parser@ /opt/iobroker/node_modules/cron-parser
              npm error extraneous: cron@ /opt/iobroker/node_modules/cron
              npm error extraneous: cross-spawn@ /opt/iobroker/node_modules/cross-spawn
              npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
              npm error extraneous: css-select@ /opt/iobroker/node_modules/css-select
              npm error extraneous: css-what@ /opt/iobroker/node_modules/css-what
              npm error extraneous: cssom@ /opt/iobroker/node_modules/cssom
              npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
              npm error extraneous: currency-symbol-map@ /opt/iobroker/node_modules/currency-symbol-map
              npm error extraneous: cycle@ /opt/iobroker/node_modules/cycle
              npm error extraneous: dashdash@ /opt/iobroker/node_modules/dashdash
              npm error extraneous: data-view-buffer@ /opt/iobroker/node_modules/data-view-buffer
              npm error extraneous: data-view-byte-length@ /opt/iobroker/node_modules/data-view-byte-length
              npm error extraneous: data-view-byte-offset@ /opt/iobroker/node_modules/data-view-byte-offset
              npm error extraneous: dateformat@ /opt/iobroker/node_modules/dateformat
              npm error extraneous: dbus-next@ /opt/iobroker/node_modules/dbus-next
              npm error extraneous: debug@ /opt/iobroker/node_modules/debug
              npm error extraneous: decache@ /opt/iobroker/node_modules/decache
              npm error extraneous: decamelize@ /opt/iobroker/node_modules/decamelize
              npm error extraneous: decompress-response@ /opt/iobroker/node_modules/decompress-response
              npm error extraneous: deep-clone@ /opt/iobroker/node_modules/deep-clone
              npm error extraneous: deep-eql@ /opt/iobroker/node_modules/deep-eql
              npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
              npm error extraneous: deep-is@ /opt/iobroker/node_modules/deep-is
              npm error extraneous: define-data-property@ /opt/iobroker/node_modules/define-data-property
              npm error extraneous: define-lazy-prop@ /opt/iobroker/node_modules/define-lazy-prop
              npm error extraneous: define-properties@ /opt/iobroker/node_modules/define-properties
              npm error extraneous: delayed-stream@ /opt/iobroker/node_modules/delayed-stream
              npm error extraneous: delegates@ /opt/iobroker/node_modules/delegates
              npm error extraneous: denque@ /opt/iobroker/node_modules/denque
              npm error extraneous: depd@ /opt/iobroker/node_modules/depd
              npm error extraneous: destroy@ /opt/iobroker/node_modules/destroy
              npm error extraneous: detect-libc@ /opt/iobroker/node_modules/detect-libc
              npm error extraneous: dev-ip@ /opt/iobroker/node_modules/dev-ip
              npm error extraneous: dev-null@ /opt/iobroker/node_modules/dev-null
              npm error extraneous: dgram@ /opt/iobroker/node_modules/dgram
              npm error extraneous: diff@ /opt/iobroker/node_modules/diff
              npm error extraneous: diskusage@ /opt/iobroker/node_modules/diskusage
              npm error extraneous: dns-packet@ /opt/iobroker/node_modules/dns-packet
              npm error extraneous: docker-modem@ /opt/iobroker/node_modules/docker-modem
              npm error extraneous: dockerode@ /opt/iobroker/node_modules/dockerode
              npm error extraneous: dom-compare-temp@ /opt/iobroker/node_modules/dom-compare-temp
              npm error extraneous: dom-serializer@ /opt/iobroker/node_modules/dom-serializer
              npm error extraneous: domelementtype@ /opt/iobroker/node_modules/domelementtype
              npm error extraneous: domhandler@ /opt/iobroker/node_modules/domhandler
              npm error extraneous: domutils@ /opt/iobroker/node_modules/domutils
              npm error extraneous: dunder-proto@ /opt/iobroker/node_modules/dunder-proto
              npm error extraneous: duplexer@ /opt/iobroker/node_modules/duplexer
              npm error extraneous: duplexify@ /opt/iobroker/node_modules/duplexify
              npm error extraneous: eastasianwidth@ /opt/iobroker/node_modules/eastasianwidth
              npm error extraneous: easy-extender@ /opt/iobroker/node_modules/easy-extender
              npm error extraneous: eazy-logger@ /opt/iobroker/node_modules/eazy-logger
              npm error extraneous: ecc-jsbn@ /opt/iobroker/node_modules/ecc-jsbn
              npm error extraneous: ecdsa-sig-formatter@ /opt/iobroker/node_modules/ecdsa-sig-formatter
              npm error extraneous: ee-first@ /opt/iobroker/node_modules/ee-first
              npm error extraneous: emoji-regex@ /opt/iobroker/node_modules/emoji-regex
              npm error extraneous: enabled@ /opt/iobroker/node_modules/enabled
              npm error extraneous: encodeurl@ /opt/iobroker/node_modules/encodeurl
              npm error extraneous: encoding-sniffer@ /opt/iobroker/node_modules/encoding-sniffer
              npm error extraneous: encoding@ /opt/iobroker/node_modules/encoding
              npm error extraneous: end-of-stream@ /opt/iobroker/node_modules/end-of-stream
              npm error extraneous: engine.io-client@ /opt/iobroker/node_modules/engine.io-client
              npm error extraneous: engine.io-parser@ /opt/iobroker/node_modules/engine.io-parser
              npm error extraneous: engine.io@ /opt/iobroker/node_modules/engine.io
              npm error extraneous: enquirer@ /opt/iobroker/node_modules/enquirer
              npm error extraneous: entities@ /opt/iobroker/node_modules/entities
              npm error extraneous: env-paths@ /opt/iobroker/node_modules/env-paths
              npm error extraneous: err-code@ /opt/iobroker/node_modules/err-code
              npm error extraneous: error-ex@ /opt/iobroker/node_modules/error-ex
              npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
              npm error extraneous: es-aggregate-error@ /opt/iobroker/node_modules/es-aggregate-error
              npm error extraneous: es-define-property@ /opt/iobroker/node_modules/es-define-property
              npm error extraneous: es-errors@ /opt/iobroker/node_modules/es-errors
              #46
              @george_best
              Da gilt dann auch für dich:
              Die mit Invalid gekennzeichneten Adapter mal neuinstallieren, tote Adapter rauskicken.
              Sieht mir aber insgesamt SEHR strubbelig aus.
              G 1 Antwort Letzte Antwort
                @george_best
                George_Best
                #47
                ich musste nun auch den js-controller neu installieren:
                npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                npm warn deprecated uid-number@0.0.6: This package is no longer supported.
                npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                npm warn deprecated lodash.get@4.4.2: This package is deprecated. Use the optional chaining (?.) operator instead.
                npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                npm warn deprecated lodash.isequal@4.5.0: This package is deprecated. Use require('node:util').isDeepStrictEqual instead.
                npm warn deprecated lodash.clone@4.5.0: This package is deprecated. Use structuredClone instead.
                npm warn deprecated har-validator@5.1.5: this library is no longer supported
                npm warn deprecated npmlog@4.1.2: This package is no longer supported.
                npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
                npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                npm warn deprecated q@1.5.1: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                npm warn deprecated
                npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                npm warn deprecated gauge@3.0.2: This package is no longer supported.
                npm warn deprecated gauge@4.0.4: This package is no longer supported.
                npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                npm warn deprecated gauge@2.7.4: This package is no longer supported.
                npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                npm warn deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
                changed 1848 packages in 3m
                205 packages are looking for funding
                  run `npm fund` for details
                Aber:
                Ist das normal?
                • G George_Best
                  npm warn deprecated
                  Aber:
                  Ist das normal?
                  #48
                  @george_best sagte in iob fix und iob diag ohne Reaktion:
                  Ist das normal?
                  Bei dem strubbeligen npm-Tree kann das normal sein.
                    Ist das normal?
                    George_Best
                    #49
                    npm ls:
                    iobroker.inst@2.0.2 /opt/iobroker
                    ├── @iobroker-javascript.0/moment-parseformat@npm:moment-parseformat@4.0.0
                    ├── @iobroker-javascript.0/moment@npm:moment@2.30.1
                    ├── colors@1.4.0
                    ├── fs-extra@7.0.1
                    ├── iobroker.accuweather@2.1.1
                    ├── iobroker.admin@7.7.19
                    ├── iobroker.alias-manager@2.0.0
                    ├── iobroker.amazon-dash@1.2.0
                    ├── iobroker.chromecast@4.0.0
                    ├── iobroker.cloud@5.0.1
                    ├── iobroker.daswetter@3.2.3
                    ├── iobroker.deconz@1.6.4
                    ├── iobroker.devices@1.2.8
                    ├── iobroker.discovery@5.0.0
                    ├── iobroker.email@2.0.4
                    ├── iobroker.flot@1.12.0
                    ├── iobroker.fronius-solarweb@0.0.3
                    ├── iobroker.fronius@2.1.1
                    ├── iobroker.frontier_silicon@0.5.0
                    ├── iobroker.habpanel@0.5.0
                    ├── iobroker.history@3.0.1
                    ├── iobroker.hm-rega@5.1.0
                    ├── iobroker.hm-rpc@2.0.2
                    ├── iobroker.hs100@3.0.5
                    ├── iobroker.icons-addictive-flavour-png@0.1.0
                    ├── iobroker.icons-fatcow-hosting@0.1.0
                    ├── iobroker.icons-icons8@0.0.1
                    ├── iobroker.icons-material-png@0.1.0
                    ├── iobroker.icons-material-svg@0.1.0
                    ├── iobroker.icons-mfd-png@1.2.1
                    ├── iobroker.icons-mfd-svg@1.2.0
                    ├── iobroker.icons-open-icon-library-png@0.1.2
                    ├── iobroker.icons-ultimate-png@1.0.1
                    ├── iobroker.influxdb@4.0.2
                    ├── iobroker.info@2.0.0
                    ├── iobroker.iot@5.0.7
                    ├── iobroker.javascript@8.9.2
                    ├── iobroker.js-controller@7.0.7
                    ├── iobroker.mihome-vacuum@5.2.0
                    ├── iobroker.mqtt@6.1.4
                    ├── iobroker.net-tools@1.1.2
                    ├── iobroker.octoprint@5.1.0
                    ├── iobroker.openweathermap@1.1.2
                    ├── iobroker.parser@2.2.4
                    ├── iobroker.ping@1.6.2
                    ├── iobroker.proxmox@2.4.0
                    ├── iobroker.radar@1.2.1
                    ├── iobroker.radar2@2.4.0
                    ├── iobroker.reolink@1.2.3
                    ├── iobroker.rickshaw@1.0.0
                    ├── iobroker.s7@1.5.0
                    ├── iobroker.sayit@5.0.0
                    ├── iobroker.smartmeter@3.4.0
                    ├── iobroker.socketio@6.7.1
                    ├── iobroker.sql@3.0.1
                    ├── iobroker.statistics@2.4.0
                    ├── iobroker.systeminfo@1.3.0
                    ├── iobroker.telegram@4.1.0
                    ├── iobroker.terminal@1.0.0
                    ├── iobroker.tr-064@4.3.0
                    ├── iobroker.unifi@0.7.0
                    ├── iobroker.upnp@1.1.0
                    ├── iobroker.vis-2-widgets-inventwo@0.2.2
                    ├── iobroker.vis-2-widgets-material@1.4.10
                    ├── iobroker.vis-2@2.13.4
                    ├── iobroker.vis-bars@0.1.4
                    ├── iobroker.vis-canvas-gauges@1.0.1
                    ├── iobroker.vis-colorpicker@2.0.3
                    ├── iobroker.vis-fancyswitch@1.1.0
                    ├── iobroker.vis-google-fonts@1.0.4
                    ├── iobroker.vis-history@1.0.0
                    ├── iobroker.vis-hqwidgets@1.5.1
                    ├── iobroker.vis-jqui-mfd@1.1.1
                    ├── iobroker.vis-justgage@2.1.7
                    ├── iobroker.vis-keyboard@0.0.2
                    ├── iobroker.vis-lcars@1.1.1
                    ├── iobroker.vis-map@1.1.2
                    ├── iobroker.vis-materialdesign@0.5.9
                    ├── iobroker.vis-metro@1.2.0
                    ├── iobroker.vis-rgraph@0.0.2
                    ├── iobroker.vis-weather@2.5.12
                    ├── iobroker.vis@1.5.6
                    ├── iobroker.weatherunderground@3.7.0
                    ├── iobroker.web@7.0.8
                    ├── iobroker.ws@2.6.2
                    ├── iobroker@2.0.3
                    ├── semver@5.7.2
                    └── yargs@7.1.2
                    npm ls graceful-fs
                    ├── colors@1.4.0
                    ├── fs-extra@7.0.1
                    ├── iobroker@2.0.3
                    ├── semver@5.7.2
                    └── yargs@7.1.2
                    ├─┬ fs-extra@7.0.1
                    │ ├── graceful-fs@4.2.11
                    │ └─┬ jsonfile@4.0.0
                    │   └── graceful-fs@4.2.11 deduped
                    ├─┬ iobroker.admin@7.7.19
                    │ └─┬ archiver@7.0.1
                    │   └─┬ archiver-utils@5.0.2
                    ├─┬ iobroker.js-controller@7.0.7
                    │ ├─┬ @iobroker/db-objects-file@7.0.7
                    │ │ ├─┬ @iobroker/db-base@7.0.7
                    │ │ │ └─┬ fs-extra@11.3.2
                    │ │ │   ├── graceful-fs@4.2.11 deduped
                    │ │ │   └─┬ jsonfile@6.2.0
                    │ │ │     └── graceful-fs@4.2.11 deduped
                    │ ├─┬ @iobroker/db-objects-jsonl@7.0.7
                    │ │ ├─┬ @alcalzone/jsonl-db@3.1.1
                    │ │ │ ├─┬ @alcalzone/proper-lockfile@4.1.3-0
                    │ │ │ │ └── graceful-fs@4.2.11 deduped
                    │ │ │ └─┬ fs-extra@10.1.0
                    │ ├─┬ @iobroker/js-controller-adapter@7.0.7
                    │ │ ├─┬ @alcalzone/pak@0.8.1
                    │ ├─┬ @iobroker/js-controller-cli@7.0.7
                    │ ├─┬ @iobroker/js-controller-common-db@7.0.7
                    │ ├─┬ @iobroker/js-controller-common@7.0.7
                    ├─┬ iobroker.radar@1.2.1
                    │ └─┬ @abandonware/noble@1.9.2-26
                    │   └─┬ @abandonware/bluetooth-hci-socket@0.5.3-12
                    │     └─┬ node-gyp@10.3.1
                    ├─┬ iobroker.radar2@2.4.0
                    │ └─┬ @stoprocent/noble@1.19.1
                    │   └─┬ @stoprocent/bluetooth-hci-socket@1.5.2
                    │     └─┬ patch-package@8.0.1
                    │       ├─┬ fs-extra@10.1.0
                    │       └─┬ klaw-sync@6.0.0
                    ├─┬ iobroker.sql@3.0.1
                    │ └─┬ sqlite3@5.1.7
                    │   └─┬ node-gyp@8.4.1
                    ├─┬ iobroker.vis-map@1.1.2
                    │ └─┬ @iobroker/dev-server@0.7.8
                    │   ├─┬ @iobroker/testing@5.2.2
                    │   ├─┬ browser-sync@3.0.4
                    │   │ └─┬ fs-extra@3.0.1
                    │   │   └─┬ jsonfile@3.0.1
                    └─┬ yargs@7.1.2
                      └─┬ read-pkg-up@1.0.1
                        └─┬ read-pkg@1.1.0
                          ├─┬ load-json-file@1.1.0
                          └─┬ path-type@1.1.0
                    Jetzt sieht es auf einmal wieder gut aus, oder?
                    G Thomas BraunT 2 Antworten Letzte Antwort
                    • G George_Best
                      npm ls:
                      ├── colors@1.4.0
                      ├── fs-extra@7.0.1
                      ├── iobroker@2.0.3
                      ├── semver@5.7.2
                      └── yargs@7.1.2
                      npm ls graceful-fs
                      ├── colors@1.4.0
                      ├── fs-extra@7.0.1
                      ├── iobroker@2.0.3
                      ├── semver@5.7.2
                      └── yargs@7.1.2
                      ├─┬ fs-extra@7.0.1
                      │ └─┬ sqlite3@5.1.7
                      └─┬ yargs@7.1.2
                          └─┬ read-pkg@1.1.0
                            └─┬ path-type@1.1.0
                      George_Best
                      #50
                      und zack... iobroker ist wieder weg..
                      jonny@ioBroker-V2:/opt/iobroker$ iob status
                      node:internal/modules/cjs/loader:1386
                        throw err;
                      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                          at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                          at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                          at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                          at Function._load (node:internal/modules/cjs/loader:1192:37)
                          at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                          at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:171:5)
                          at node:internal/main/run_main_module:36:49 {
                        code: 'MODULE_NOT_FOUND',
                        requireStack: []
                      Node.js v22.21.0
                      • G Offline
                        George_Best
                        #51
                        Es scheint (lt. Logs) immer bei diesem Eintrag los zugehen:
                        2025-11-12 16:16:29.213  - error: host.ioBroker-V2 Error: Could not determine controller directory
                            at getControllerDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1833:11)
                            at Module.getPidsFileName (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:3368:22)
                            at Timeout._onTimeout (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:2871:91)
                            at listOnTimeout (node:internal/timers:581:17)
                            at processTimers (node:internal/timers:519:7)
                        Davor fangen scheinbar alle Adapter an neu starten - oder was auch immer...
                        z.B.
                        2025-11-12 16:16:24.689  - error: hm-rpc.0 (8741) hm-rpc.0 already running
                        2025-11-12 16:16:24.691  - warn: hm-rpc.0 (8741) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                        Ich bin leider völlig ratlos...
                        • G Offline
                          George_Best
                          #52
                          Das "Adapter Requested Termintation" ist doch seltsam:
                          2025-11-12 16:32:31.619  - info: discovery.0 (15882) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2025-11-12 16:32:31.616  - info: hm-rpc.1 (15825) xmlrpc -> 192.168.178.155:2010/ init ["http://192.168.178.121:2010",""]
                          2025-11-12 16:32:31.649  - info: hm-rpc.1 (15825) Disconnected
                          2025-11-12 16:32:31.649  - info: hm-rpc.1 (15825) terminating
                          2025-11-12 16:32:31.650  - info: hm-rpc.1 (15825) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2025-11-12 16:32:31.562  - info: hm-rpc.0 (14348) xmlrpc -> 192.168.178.155:2001/ init ["http://192.168.178.121:2001",""]
                          2025-11-12 16:32:31.571  - info: hm-rpc.0 (14348) Disconnected
                          2025-11-12 16:32:31.572  - info: hm-rpc.0 (14348) terminating
                          2025-11-12 16:32:31.572  - info: hm-rpc.0 (14348) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2025-11-12 16:32:31.685  - info: host.ioBroker-V2 stopInstance system.adapter.admin.0 send kill signal
                          2025-11-12 16:32:31.725  - info: host.ioBroker-V2 stopInstance system.adapter.javascript.0 send kill signal
                          2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.javascript.1 send kill signal
                          2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.email.0 send kill signal
                          2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.telegram.0 send kill signal
                          2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.s7.0 send kill signal
                          2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.s7.1 send kill signal
                          oder
                          2025-11-12 16:54:15.882  - info: admin.0 (20463) Got terminate signal TERMINATE_YOURSELF
                          2025-11-12 16:54:15.882  - info: javascript.0 (20529) Got terminate signal TERMINATE_YOURSELF
                          2025-11-12 16:54:15.883  - info: telegram.0 (20605) Got terminate signal TERMINATE_YOURSELF
                          2025-11-12 16:54:15.884  - info: javascript.0 (20529) terminating
                          2025-11-12 16:54:15.885  - info: javascript.0 (20529) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2025-11-12 16:54:15.884  - info: s7.1 (20635) Got terminate signal TERMINATE_YOURSELF
                          2025-11-12 16:54:15.885  - info: s7.0 (20620) Got terminate signal TERMINATE_YOURSELF
                          2025-11-12 16:54:15.883  - info: admin.0 (20463) terminating https server on port 8081
                          2025-11-12 16:54:15.884  - info: admin.0 (20463) terminating
                          2025-11-12 16:54:15.885  - info: admin.0 (20463) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          Das ist vermutlich der Grund für die Abstürze?
                          Anbei mal der komplette Log
                          iobroker.2025-11-12.log
                          • G Offline
                            George_Best
                            #53
                            Neuer Versuch - und wieder:
                            2025-11-12 17:36:08.400  - info: web.0 (28941) starting. Version 7.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v22.21.0, js-controller: 7.0.7
                            2025-11-12 17:36:08.571  - info: web.0 (28941) socket.io server listening on port 8082
                            2025-11-12 17:36:08.572  - info: web.0 (28941) Connecting extension "habpanel/lib/habpanelapi.js"
                            2025-11-12 17:36:08.572  - info: web.0 (28941) habpanel server listening on port 8082
                            2025-11-12 17:36:08.573  - info: web.0 (28941) habpanel web extension - Install extension on /rest/habpanel/
                            2025-11-12 17:36:08.575  - info: web.0 (28941) http server listening on port 8082
                            2025-11-12 17:36:10.873  - error: host.ioBroker-V2 uncaught exception: Could not determine controller directory
                            2025-11-12 17:36:10.873  - error: host.ioBroker-V2 Error: Could not determine controller directory
                                at Module.getAdapterDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1306:37)
                                at startInstance (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:3219:30)
                            Es scheint fast so, als wird immer der js-controller gekillt....
                            Hat jemand eine Idee wie ich das lösen kann?
                            • G George_Best
                              @thomas-braun sagte in iob fix und iob diag ohne Reaktion:
                              @george_best
                              Das Betriebssystem aber nicht.
                              Ich befürchte ich habe das gleiche Problem wie hier: https://forum.iobroker.net/topic/81185/system-admin-upgrade-exited-with-code-25-start-schleife/60
                              1. Betriebssystem habe ich nun geupdatet
                              2. iob fix gemacht
                              library: loaded
                              Library version=2025-08-09
                                  Welcome to the ioBroker installation fixer!
                                  Script version: 2025-08-09
                                  You might need to enter your password a couple of times.
                                  Installing prerequisites (1/5)
                              OK:1 http://deb.debian.org/debian bookworm InRelease
                              OK:2 http://deb.debian.org/debian bookworm-updates InRelease
                              OK:3 http://deb.debian.org/debian-security bookworm-security InRelease
                              OK:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                                  Checking ioBroker user and directory permissions (2/5)
                              Created /etc/sudoers.d/iobroker
                                  Check and cleanup npm temporary directories (3/5)
                              Done.
                                  Database maintenance (4/5)
                              Checking for uncompressed JSONL databases... This might take a while!
                              Compressing /opt/iobroker/iobroker-data/states.jsonl
                              Compressing /opt/iobroker/iobroker-data/objects.jsonl
                              Compressed 2 JSONL files. Done
                                  Checking autostart (5/5)
                              ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
                              Legitimierung ist zum Stoppen von »iobroker.service« notwendig.
                              Authenticating as: jonny,,, (jonny)
                              Password:
                              ==== AUTHENTICATION COMPLETE ====
                              Enabling autostart...
                              Autostart enabled!
                              1. iob diag sagt:
                              ```bash
                              Script v.2025-08-09
                              *** BASE SYSTEM ***
                               Static hostname: ioBroker-V2
                                     Icon name: computer-vm
                                       Chassis: vm 🖴
                                Virtualization: kvm
                                        Kernel: Linux 6.1.0-41-amd64
                                  Architecture: x86-64
                               Hardware Vendor: QEMU
                                Hardware Model: Standard PC _i440FX + PIIX, 1996_
                              Firmware Version: rel-1.16.1-0-g3208b098f51a-prebuilt.qemu.org
                              OS is similar to:
                              model name      : Common KVM processor
                              Docker          : false
                              Virtualization  : kvm
                              Kernel          : x86_64
                              Userland        : 64 bit
                              Systemuptime and Load:
                               16:30:54 up 29 min,  2 users,  load average: 0.64, 0.37, 0.62
                              CPU threads: 8
                              *** LIFE CYCLE STATUS ***
                              Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                              *** TIME AND TIMEZONES ***
                                             Local time: Wed 2025-11-12 16:30:54 CET
                                         Universal time: Wed 2025-11-12 15:30:54 UTC
                                               RTC time: Wed 2025-11-12 15:30:54
                                            NTP service: active
                                        RTC in local TZ: no
                              *** Users and Groups ***
                              User that called 'iob diag':
                              jonny
                              HOME=/home/jonny
                              GROUPS=jonny adm cdrom floppy sudo audio dip video plugdev systemd-journal netdev iobroker
                              iobroker
                              HOME=/home/iobroker
                              GROUPS=iobroker tty dialout audio video plugdev bluetooth
                              *** DISPLAY-SERVER SETUP ***
                              Display-Server:         false
                              Unit display-manager.service could not be found.
                              Display-Manager:
                              Desktop:
                              Session:                tty
                              *** MEMORY ***
                              Mem:             12G        1.9G        8.1G        561K        2.5G         10G
                              Swap:           4.3G          0B        4.3G
                              Total:           16G        1.9G         12G
                              Active iob-Instances:   6
                                      11644 M total memory
                                       1812 M used memory
                                       1465 M active memory
                                       1926 M inactive memory
                                       7764 M free memory
                                        343 M buffer memory
                                       2036 M swap cache
                                       4093 M total swap
                                          0 M used swap
                                       4093 M free swap
                              top - 16:30:55 up 29 min,  2 users,  load average: 0.64, 0.37, 0.62
                              Tasks: 124 total,   1 running, 123 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :  11644.7 total,   7765.0 free,   1812.8 used,   2380.2 buff/cache
                              MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.   9831.8 avail Mem
                              *** FAILED SERVICES ***
                              0 loaded units listed.
                              *** DMESG CRITICAL ERRORS ***
                              No critical errors detected
                              *** FILESYSTEM ***
                              udev           devtmpfs  5.7G     0  5.7G   0% /dev
                              tmpfs          tmpfs     1.2G  548K  1.2G   1% /run
                              /dev/sda1      ext4       28G   11G   16G  40% /
                              tmpfs          tmpfs     5.7G     0  5.7G   0% /dev/shm
                              tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                              tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
                              [Wed Nov 12 16:01:54 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                              [Wed Nov 12 16:01:54 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
                              Show mounted filesystems:
                              TARGET SOURCE    FSTYPE OPTIONS
                              /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                              /var:
                              1.9G    /var/
                              889M    /var/cache
                              870M    /var/cache/apt
                              805M    /var/log
                              793M    /var/cache/apt/archives
                              Archived and active journals take up 782.1M in the file system.
                              /opt/iobroker/backups:
                              22M     /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              676M    /opt/iobroker/iobroker-data/
                              450M    /opt/iobroker/iobroker-data/files
                              166M    /opt/iobroker/iobroker-data/backup-objects
                              81M     /opt/iobroker/iobroker-data/files/vis
                              78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                              25M     /opt/iobroker/iobroker-data/objects.jsonl
                              12M     /opt/iobroker/iobroker-data/objects.json.migrated
                              12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                              9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
                              4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                              USB-Devices by-id:
                              /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2195735-if00
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v22.21.0
                              /usr/bin/node           v22.21.0
                              /usr/bin/npm            10.9.4
                              /usr/bin/npx            10.9.4
                              /usr/bin/corepack       0.34.0
                              nodejs:
                                Installed: 22.21.0-1nodesource1
                                Candidate: 22.21.0-1nodesource1
                                Version table:
                               *** 22.21.0-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                                      100 /var/lib/dpkg/status
                                   22.20.0-1nodesource1 1001
                                   22.19.0-1nodesource1 1001
                                   22.18.0-1nodesource1 1001
                                   22.17.1-1nodesource1 1001
                                   22.17.0-1nodesource1 1001
                                   22.16.0-1nodesource1 1001
                                   22.15.1-1nodesource1 1001
                                   22.15.0-1nodesource1 1001
                                   22.14.0-1nodesource1 1001
                                   22.13.1-1nodesource1 1001
                                   22.13.0-1nodesource1 1001
                                   22.12.0-1nodesource1 1001
                                   22.11.0-1nodesource1 1001
                                   22.10.0-1nodesource1 1001
                                   22.9.0-1nodesource1 1001
                                   22.8.0-1nodesource1 1001
                                   22.7.0-1nodesource1 1001
                                   22.6.0-1nodesource1 1001
                                   22.5.1-1nodesource1 1001
                                   22.5.0-1nodesource1 1001
                                   22.4.1-1nodesource1 1001
                                   22.4.0-1nodesource1 1001
                                   22.3.0-1nodesource1 1001
                                   22.2.0-1nodesource1 1001
                                   22.1.0-1nodesource1 1001
                                   22.0.0-1nodesource1 1001
                                   18.20.4+dfsg-1~deb12u1 500
                                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                      500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                              No problems detected
                              Errors in npm tree: 0
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              ioBroker-V2         ioBroker-V2 (version: 7.0.7, hostname: ioBroker-V2   , alive, uptime: 32)
                              Core adapters versions
                              admin:          7.7.19
                              javascript:     8.9.2
                              nodejs modules from github:     2
                              |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
                              | +-- tplink-smarthome-api@5.0.0 invalid: "https://github.com/arteck/tplink-smarthome-api/tarball/08bcca9334c701b60d1eeb18b0ec72350aa3bf7a" from node_modules/iobroker.hs100
                              Adapter State
                                system.adapter.accuweather.0            : accuweather           : ioBroker-V2                              -  enabled
                              + system.adapter.admin.0                  : admin                 : ioBroker-V2                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                system.adapter.alias-manager.0          : alias-manager         : ioBroker-V2                              -  enabled
                                system.adapter.amazon-dash.0            : amazon-dash           : ioBroker-V2                              - disabled
                                system.adapter.chromecast.0             : chromecast            : ioBroker-V2                              -  enabled
                                system.adapter.cloud.0                  : cloud                 : ioBroker-V2                              - disabled
                                system.adapter.daswetter.0              : daswetter             : ioBroker-V2                              -  enabled
                                system.adapter.deconz.0                 : deconz                : ioBroker-V2                              - disabled, port: 80
                                system.adapter.devices.0                : devices               : ioBroker-V2                              -  enabled
                                system.adapter.discovery.0              : discovery             : ioBroker-V2                              -  enabled
                              + system.adapter.email.0                  : email                 : ioBroker-V2                              -  enabled
                                system.adapter.flot.0                   : flot                  : ioBroker-V2                              -  enabled
                                system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker-V2                              -  enabled
                                system.adapter.fronius.0                : fronius               : ioBroker-V2                              -  enabled
                                system.adapter.frontier_silicon.0       : frontier_silicon      : ioBroker-V2                              -  enabled
                                system.adapter.habpanel.0               : habpanel              : ioBroker-V2                              -  enabled
                                system.adapter.history.0                : history               : ioBroker-V2                              -  enabled
                                system.adapter.hm-rega.0                : hm-rega               : ioBroker-V2                              -  enabled
                                system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-V2                              -  enabled, port: 0
                                system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-V2                              -  enabled, port: 0
                                system.adapter.hs100.0                  : hs100                 : ioBroker-V2                              -  enabled
                                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker-V2                              -  enabled
                                system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker-V2                              -  enabled
                                system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-V2                              -  enabled
                                system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-V2                              -  enabled
                                system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker-V2                              -  enabled
                                system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-V2                              -  enabled
                                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-V2                              -  enabled
                                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker-V2                              -  enabled
                                system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-V2                              -  enabled
                                system.adapter.influxdb.0               : influxdb              : ioBroker-V2                              - disabled, port: 8086
                                system.adapter.influxdb.1               : influxdb              : ioBroker-V2                              - disabled, port: 8086
                                system.adapter.info.0                   : info                  : ioBroker-V2                              -  enabled
                                system.adapter.iot.0                    : iot                   : ioBroker-V2                              -  enabled
                              + system.adapter.javascript.0             : javascript            : ioBroker-V2                              -  enabled
                              + system.adapter.javascript.1             : javascript            : ioBroker-V2                              -  enabled
                                system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-V2                              - disabled, port: 54321
                                system.adapter.mqtt.0                   : mqtt                  : ioBroker-V2                              -  enabled, port: 1883, bind: 192.168.178.121
                                system.adapter.net-tools.0              : net-tools             : ioBroker-V2                              - disabled
                                system.adapter.net-tools.1              : net-tools             : ioBroker-V2                              -  enabled
                                system.adapter.octoprint.0              : octoprint             : ioBroker-V2                              -  enabled
                                system.adapter.parser.0                 : parser                : ioBroker-V2                              -  enabled
                                system.adapter.ping.0                   : ping                  : ioBroker-V2                              - disabled
                                system.adapter.proxmox.0                : proxmox               : ioBroker-V2                              -  enabled, port: 8006
                                system.adapter.radar.0                  : radar                 : ioBroker-V2                              - disabled
                                system.adapter.radar2.0                 : radar2                : ioBroker-V2                              - disabled
                                system.adapter.radar2.1                 : radar2                : ioBroker-V2                              -  enabled
                                system.adapter.reolink.0                : reolink               : ioBroker-V2                              -  enabled
                                system.adapter.reolink.1                : reolink               : ioBroker-V2                              -  enabled
                                system.adapter.rickshaw.0               : rickshaw              : ioBroker-V2                              -  enabled
                                system.adapter.s7.0                     : s7                    : ioBroker-V2                              -  enabled
                                system.adapter.s7.1                     : s7                    : ioBroker-V2                              -  enabled
                                system.adapter.s7.2                     : s7                    : ioBroker-V2                              -  enabled
                                system.adapter.sayit.0                  : sayit                 : ioBroker-V2                              -  enabled
                                system.adapter.sayit.1                  : sayit                 : ioBroker-V2                              -  enabled
                                system.adapter.sayit.2                  : sayit                 : ioBroker-V2                              -  enabled
                                system.adapter.simple-api.0             : simple-api            : ioBroker-V2                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                system.adapter.smartmeter.0             : smartmeter            : ioBroker-V2                              - disabled
                                system.adapter.smartmeter.2             : smartmeter            : ioBroker-V2                              - disabled
                                system.adapter.socketio.0               : socketio              : ioBroker-V2                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                              + system.adapter.sql.0                    : sql                   : ioBroker-V2                              -  enabled, port: 3306
                                system.adapter.sql.1                    : sql                   : ioBroker-V2                              - disabled, port: 3306
                                system.adapter.statistics.0             : statistics            : ioBroker-V2                              -  enabled
                                system.adapter.systeminfo.0             : systeminfo            : ioBroker-V2                              - disabled
                                system.adapter.telegram.0               : telegram              : ioBroker-V2                              -  enabled, port: 8443, bind: 0.0.0.0
                                system.adapter.terminal.0               : terminal              : ioBroker-V2                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                system.adapter.tr-064.0                 : tr-064                : ioBroker-V2                              -  enabled
                                system.adapter.unifi.0                  : unifi                 : ioBroker-V2                              -  enabled
                                system.adapter.upnp.0                   : upnp                  : ioBroker-V2                              -  enabled
                                system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker-V2                              -  enabled
                                system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker-V2                              -  enabled
                                system.adapter.vis-2.0                  : vis-2                 : ioBroker-V2                              -  enabled
                                system.adapter.vis-bars.0               : vis-bars              : ioBroker-V2                              -  enabled
                                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-V2                              -  enabled
                                system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-V2                              -  enabled
                                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-V2                              -  enabled
                                system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker-V2                              -  enabled
                                system.adapter.vis-history.0            : vis-history           : ioBroker-V2                              -  enabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-V2                              -  enabled
                                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-V2                              -  enabled
                                system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-V2                              -  enabled
                                system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-V2                              -  enabled
                                system.adapter.vis-lcars.0              : vis-lcars             : ioBroker-V2                              -  enabled
                                system.adapter.vis-map.0                : vis-map               : ioBroker-V2                              -  enabled
                                system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker-V2                              -  enabled
                                system.adapter.vis-metro.0              : vis-metro             : ioBroker-V2                              -  enabled
                                system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-V2                              -  enabled
                                system.adapter.vis-weather.0            : vis-weather           : ioBroker-V2                              -  enabled
                                system.adapter.vis.0                    : vis                   : ioBroker-V2                              -  enabled
                                system.adapter.weatherunderground.0     : weatherunderground    : ioBroker-V2                              -  enabled
                                system.adapter.web.0                    : web                   : ioBroker-V2                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + instance is alive
                              ioBroker-Repositories
                              Active repo(s): stable
                              Upgrade policy: none
                              Installed ioBroker-Adapters
                              Used repository: stable
                              Adapter    "accuweather"  : 2.1.1    , installed 2.1.1
                              Adapter    "admin"        : 7.7.19   , installed 7.7.19
                              Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                              Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
                              Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
                              Adapter    "cloud"        : 5.0.1    , installed 5.0.1
                              Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                              Adapter    "deconz"       : 1.6.4    , installed 1.6.4
                              Adapter    "devices"      : 1.2.8    , installed 1.2.8
                              Adapter    "email"        : 2.0.4    , installed 2.0.4
                              Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                              Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                              Adapter    "frontier_silicon": 0.5.0 , installed 0.5.0
                              Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                              Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                              Adapter    "hs100"        : 3.0.5    , installed 3.0.5
                              Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
                              Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                              Adapter    "icons-material-png": 0.1.0, installed 0.1.0
                              Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                              Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                              Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                              Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
                              Adapter    "iot"          : 5.0.7    , installed 5.0.7
                              Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                              Controller "js-controller": 7.0.7    , installed 7.0.7
                              Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
                              Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
                              Adapter    "net-tools"    : 1.1.2    , installed 1.1.2
                              Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                              Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                              Adapter    "parser"       : 2.2.4    , installed 2.2.4
                              Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                              Adapter    "radar2"       : 2.4.0    , installed 2.4.0
                              Adapter    "reolink"      : 1.2.3    , installed 1.2.3
                              Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
                              Adapter    "s7"           : 1.5.0    , installed 1.5.0
                              Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                              Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                              Adapter    "sql"          : 3.0.1    , installed 3.0.1
                              Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                              Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
                              Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                              Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                              Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                              Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
                              Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
                              Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                              Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
                              Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
                              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                              Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                              Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                              Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                              Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
                              Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
                              Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                              Adapter    "web"          : 7.0.8    , installed 7.0.8
                              Adapter    "ws"           : 2.6.2    , installed 2.6.2
                              Objects and States
                              Objects:        24997
                              States:         20033
                              Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                              Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                              Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                              Reading package lists...
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 192.168.178.121:2001    0.0.0.0:*               LISTEN      1001       66571      14348/io.hm-rpc.0
                              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17410      736/exim4
                              tcp        0      0 192.168.178.121:1883    0.0.0.0:*               LISTEN      1001       61291      14044/io.mqtt.0
                              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       62504      12617/iobroker.js-c
                              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       59698      12617/iobroker.js-c
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15485      553/sshd: /usr/sbin
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       59780      12641/io.admin.0
                              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17411      736/exim4
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          15487      553/sshd: /usr/sbin
                              udp        0      0 0.0.0.0:35015           0.0.0.0:*                           107        13947      440/avahi-daemon: r
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       65677      14275/io.chromecast
                              udp        0      0 192.168.178.121:5353    0.0.0.0:*                           1001       64680      14141/io.tr-064.0
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        13945      440/avahi-daemon: r
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13849      376/dhclient
                              udp6       0      0 :::36795                :::*                                107        13948      440/avahi-daemon: r
                              udp6       0      0 :::5353                 :::*                                107        13946      440/avahi-daemon: r
                              2025-11-12 16:31:21.431  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] connected with secret 1762961481430_2245
                              2025-11-12 16:31:21.446  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] subscribes on "Wemos_DisplayV2_6/#" with regex /^Wemos_DisplayV2_6\..*/
                              2025-11-12 16:31:21.447  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] subscribes on "Wemos_DisplayV2_6/#"  with regex /^mqtt\.0\.Wemos_DisplayV2_6\..*/
                              2025-11-12 16:31:21.647  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] publishOnSubscribe send all known states
                              2025-11-12 16:31:22.266  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 1(Jonny-Pixel3/3C:28:6D:E8:64:45) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                              2025-11-12 16:31:22.409  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 2(Jenny-Pixel3a/58:CB:52:8E:4E:68) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                              2025-11-12 16:31:22.548  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 3(Jonny-Arbeit-A40/F0:8A:76:20:A8:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                              2025-11-12 16:31:22.766  - info: chromecast.0 (14275) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.chromecast, node: v22.21.0, js-controller: 7.0.7
                              2025-11-12 16:31:23.348  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 7(Pixel-3a/BA:DC:2D:6F:F1:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                              2025-11-12 16:31:23.407  - info: chromecast.0 (14275) Google_HomeKueche - Connected client
                              2025-11-12 16:31:23.438  - info: chromecast.0 (14275) Küche - Connected client
                              2025-11-12 16:31:23.905  - info: host.ioBroker-V2 instance system.adapter.hm-rpc.0 in version "2.0.2" started with pid 14348
                              2025-11-12 16:31:26.245  - info: hm-rpc.0 (14348) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v22.21.0, js-controller: 7.0.7
                              2025-11-12 16:31:26.463  - info: hm-rpc.0 (14348) xmlrpc server is trying to listen on 192.168.178.121:2001
                              2025-11-12 16:31:26.464  - info: hm-rpc.0 (14348) xmlrpc client is trying to connect to 192.168.178.155:2001/ with ["http://192.168.178.121:2001","ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
                              2025-11-12 16:31:26.492  - info: hm-rpc.0 (14348) xmlrpc <- system.listMethods ["ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
                              2025-11-12 16:31:26.498  - info: hm-rpc.0 (14348) xmlrpc <- listDevices ["ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
                              2025-11-12 16:31:26.528  - info: hm-rpc.0 (14348) xmlrpc -> 64 devices
                              2025-11-12 16:31:26.547  - info: hm-rpc.0 (14348) Connected
                              2025-11-12 16:31:27.831  - info: host.ioBroker-V2 instance system.adapter.hm-rega.0 in version "5.1.0" started with pid 14782
                              2025-11-12 16:31:30.487  - info: hm-rega.0 (14782) starting. Version 5.1.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v22.21.0, js-controller: 7.0.7
                              2025-11-12 16:31:30.694  - info: hm-rega.0 (14782) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                              2025-11-12 16:31:30.763  - info: hm-rega.0 (14782) ReGaHSS 192.168.178.155 up
                              2025-11-12 16:31:30.869  - info: hm-rega.0 (14782) time difference local-ccu 1s
                              2025-11-12 16:31:31.325  - info: hm-rega.0 (14782) request state values
                              Ro75R Offline
                              Ro75R Offline
                              Ro75
                              #54
                              @george_best
                              Was ist das? Woher kommt das?
                              Ro75.
                              • Ro75R Ro75
                                @george_best
                                Ro75.
                                George_Best
                                #55
                                @ro75
                                ersteres ist wohl vom hometmatic adapter
                                letzeres ist ein Adapter von TP-Link für smarte Steckdosen
                                Ro75R 1 Antwort Letzte Antwort
                                • G George_Best
                                  @ro75
                                  Ro75R Offline
                                  Ro75R Offline
                                  Ro75
                                  #56
                                  @george_best mir geht es mehr um das "invalid"
                                  Ro75.
                                  • Ro75R Ro75
                                    Ro75.
                                    George_Best
                                    #57
                                    @ro75
                                    woher hast du die Zeilen genau?
                                    Weil der npm-tree am Anfang war als der js-controller nicht mehr da war. Da war/ist so ziemlich alles auf "invalid"
                                    • G George_Best
                                      @ro75
                                      Ro75R Offline
                                      Ro75R Offline
                                      Ro75
                                      #58
                                      aus deinem iob diag log
                                      Ro75.
                                      • Ro75R Ro75
                                        Ro75.
                                        George_Best
                                        #59
                                        @ro75
                                        ok.
                                        Adapter mal löschen? Neu installieren?
                                        • G George_Best
                                          @ro75
                                          ok.
                                          Ro75R Offline
                                          Ro75R Offline
                                          Ro75
                                          #60
                                          @george_best keine Ahnung. Auf alle Fälle, die, die man nicht (mehr) braucht können auch weg. Weniger Last, weniger Probleme.
                                          Ro75.
