  4. iob fix und iob diag ohne Reaktion
    6.4k
94 Beiträge 8 Kommentatoren 12.8k Aufrufe 4 Beobachtet
  • G George_Best
    1. npm ls:
    cd /opt/iobroker
    npm ls
    npm ls graceful-fs
    ── component-inherit@ extraneous
    ├── compress-commons@ extraneous
    ├── compressible@ extraneous
    ├── compression@ extraneous
    ├── concat-map@ extraneous
    ├── concat-stream@ extraneous
    ├── connect-flash@ extraneous
    ├── connect-history-api-fallback@ extraneous
    ├── connect@ extraneous
    ├── console-control-strings@ extraneous
    ├── content-disposition@ extraneous
    ├── content-type@ extraneous
    ├── cookie-parser@ extraneous
    ├── cookie-signature@ extraneous
    ├── cookie@ extraneous
    ├── core-util-is@ extraneous
    ├── cors@ extraneous
    ├── country-data@ extraneous
    ├── cpu-features@ extraneous
    ├── crc-32@ extraneous
    ├── crc32-stream@ extraneous
    ├── cron-parser@ extraneous
    ├── cron@ extraneous
    ├── cross-spawn@ extraneous
    ├── crypto-js@ extraneous
    ├── css-select@ extraneous
    ├── css-what@ extraneous
    ├── cssom@ extraneous
    ├── cssstyle@ extraneous
    ├── currency-symbol-map@ extraneous
    ├── cycle@ extraneous
    ├── dashdash@ extraneous
    ├── data-view-buffer@ extraneous
    ├── data-view-byte-length@ extraneous
    ├── data-view-byte-offset@ extraneous
    ├── dateformat@ extraneous
    ├── dbus-next@ extraneous
    ├── debug@ extraneous
    ├── decache@ extraneous
    ├── decamelize@ extraneous
    ├── decompress-response@ extraneous
    ├── deep-clone@ extraneous
    ├── deep-eql@ extraneous
    ├── deep-extend@0.6.0 extraneous
    ├── deep-is@ extraneous
    ├── define-data-property@ extraneous
    ├── define-lazy-prop@ extraneous
    ├── define-properties@ extraneous
    ├── delayed-stream@ extraneous
    ├── delegates@ extraneous
    ├── denque@ extraneous
    ├── depd@ extraneous
    ├── destroy@ extraneous
    ├── detect-libc@ extraneous
    ├── dev-ip@ extraneous
    ├── dev-null@ extraneous
    ├── dgram@ extraneous
    ├── diff@ extraneous
    ├── diskusage@ extraneous
    ├── dns-packet@ extraneous
    ├── docker-modem@ extraneous
    ├── dockerode@ extraneous
    ├── dom-compare-temp@ extraneous
    ├── dom-serializer@ extraneous
    ├── domelementtype@ extraneous
    ├── domhandler@ extraneous
    ├── domutils@ extraneous
    ├── dunder-proto@ extraneous
    ├── duplexer@ extraneous
    ├── duplexify@ extraneous
    ├── eastasianwidth@ extraneous
    ├── easy-extender@ extraneous
    ├── eazy-logger@ extraneous
    ├── ecc-jsbn@ extraneous
    ├── ecdsa-sig-formatter@ extraneous
    ├── ee-first@ extraneous
    ├── emoji-regex@ extraneous
    ├── enabled@ extraneous
    ├── encodeurl@ extraneous
    ├── encoding-sniffer@ extraneous
    ├── encoding@ extraneous
    ├── end-of-stream@ extraneous
    ├── engine.io-client@ extraneous
    ├── engine.io-parser@ extraneous
    ├── engine.io@ extraneous
    ├── enquirer@ extraneous
    ├── entities@ extraneous
    ├── env-paths@ extraneous
    ├── err-code@ extraneous
    ├── error-ex@ extraneous
    ├── es-abstract@ extraneous
    ├── es-aggregate-error@ extraneous
    ├── es-define-property@ extraneous
    ├── es-errors@ extraneous
    ├── es-object-atoms@ extraneous
    ├── es-set-tostringtag@ extraneous
    ├── es-shim-unscopables@ extraneous
    ├── es-to-primitive@ extraneous
    ├── es6-promise@ extraneous
    ├── esbuild@ extraneous
    ├── escalade@ extraneous
    ├── escape-html@ extraneous
    ├── escape-string-regexp@ extraneous
    ├── escodegen@ extraneous
    ├── esprima@ extraneous
    ├── estraverse@ extraneous
    ├── esutils@ extraneous
    ├── etag@ extraneous
    ├── event-stream@ extraneous
    ├── event-target-shim@ extraneous
    ├── eventemitter2@ extraneous
    ├── eventemitter3@ extraneous
    ├── events-universal@ extraneous
    ├── events@ extraneous
    ├── evilscan@ extraneous
    ├── execa@ extraneous
    ├── expand-template@ extraneous
    ├── exponential-backoff@ extraneous
    ├── express-fileupload@ extraneous
    ├── express-session@ extraneous
    ├── express@ extraneous
    ├── extend@3.0.2 extraneous
    ├── extsprintf@ extraneous
    ├── eyes@ extraneous
    ├── fast-deep-equal@ extraneous
    ├── fast-fifo@ extraneous
    ├── fast-glob@ extraneous
    ├── fast-json-stable-stringify@ extraneous
    ├── fast-levenshtein@ extraneous
    ├── fast-unique-numbers@ extraneous
    ├── fast-uri@ extraneous
    ├── fast-xml-parser@ extraneous
    ├── fastq@ extraneous
    ├── fecha@ extraneous
    ├── fetch-enhanced@ extraneous
    ├── file-stream-rotator@ extraneous
    ├── file-type@ extraneous
    ├── file-uri-to-path@ extraneous
    ├── fill-range@ extraneous
    ├── finalhandler@ extraneous
    ├── find-up@ extraneous
    ├── find-yarn-workspace-root@ extraneous
    ├── flat@ extraneous
    ├── fn.name@ extraneous
    ├── follow-redirects@ extraneous
    ├── for-each@ extraneous
    ├── foreground-child@ extraneous
    ├── forever-agent@ extraneous
    ├── form-data@ extraneous
    ├── forwarded@ extraneous
    ├── fresh@ extraneous
    ├── from@ extraneous
    ├── fs-constants@1.0.0 extraneous
    ├── fs-extra@7.0.1
    ├── fs-minipass@ extraneous
    ├── fs.realpath@ extraneous
    ├── fsevents@ extraneous
    ├── ftp-response-parser@ extraneous
    ├── function-bind@ extraneous
    ├── function.prototype.name@ extraneous
    ├── functions-have-names@ extraneous
    ├── gauge@ extraneous
    ├── gaxios@ extraneous
    ├── gcp-metadata@ extraneous
    ├── generate-function@ extraneous
    ├── generator-function@ extraneous
    ├── get-caller-file@1.0.3 extraneous
    ├── get-func-name@ extraneous
    ├── get-intrinsic@ extraneous
    ├── get-proto@ extraneous
    ├── get-stream@ extraneous
    ├── get-symbol-description@ extraneous
    ├── getpass@ extraneous
    ├── github-from-package@ extraneous
    ├── glob-parent@ extraneous
    ├── glob@ extraneous
    ├── globalthis@ extraneous
    ├── glossy@ extraneous
    ├── google-auth-library@ extraneous
    ├── google-logging-utils@ extraneous
    ├── google-tts-api@ extraneous
    ├── googleapis-common@ extraneous
    ├── googleapis@ extraneous
    ├── gopd@ extraneous
    ├── gtoken@ extraneous
    ├── har-schema@ extraneous
    ├── har-validator@ extraneous
    ├── has-bigints@ extraneous
    ├── has-binary@ extraneous
    ├── has-binary2@1.0.3 extraneous
    ├── has-cors@ extraneous
    ├── has-flag@ extraneous
    ├── has-property-descriptors@ extraneous
    ├── has-proto@ extraneous
    ├── has-symbols@ extraneous
    ├── has-tostringtag@ extraneous
    ├── has-unicode@ extraneous
    ├── hasown@ extraneous
    ├── he@ extraneous
    ├── help-me@ extraneous
    ├── hexy@ extraneous
    ├── homematic-xmlrpc@ extraneous
    ├── hosted-git-info@ extraneous
    ├── htmlparser2@ extraneous
    ├── http-cache-semantics@ extraneous
    ├── http-errors@ extraneous
    ├── http-proxy-agent@ extraneous
    ├── http-proxy-middleware@ extraneous
    ├── http-proxy@ extraneous
    ├── http-signature@ extraneous
    ├── https-proxy-agent@ extraneous
    ├── https@ extraneous
    ├── human-signals@ extraneous
    ├── humanize-ms@ extraneous
    ├── iconv-lite@ extraneous
    ├── icy@ extraneous
    ├── ieee754@ extraneous
    ├── ignore-by-default@ extraneous
    ├── immediate@ extraneous
    ├── immutable@ extraneous
    ├── imurmurhash@ extraneous
    ├── indent-string@ extraneous
    ├── indexof@ extraneous
    ├── infer-owner@ extraneous
    ├── inflight@ extraneous
    ├── influx@ extraneous
    ├── inherits@ extraneous
    ├── ini@ extraneous
    ├── int64-buffer@ extraneous
    ├── internal-slot@ extraneous
    ├── invert-kv@ extraneous
    ├── iobroker.accuweather@ invalid: "2.1.1" from the root project
    ├── iobroker.admin@ invalid: "7.7.19" from the root project
    ├── iobroker.alias-manager@ invalid: "2.0.0" from the root project
    ├── iobroker.amazon-dash@ invalid: "1.2.0" from the root project
    ├── iobroker.chromecast@ invalid: "4.0.0" from the root project
    ├── iobroker.cloud@ invalid: "5.0.1" from the root project
    ├── iobroker.daswetter@ invalid: "3.2.3" from the root project
    ├── iobroker.deconz@ invalid: "1.6.4" from the root project
    ├── iobroker.devices@ invalid: "1.2.8" from the root project
    ├── iobroker.discovery@ invalid: "5.0.0" from the root project
    ├── iobroker.email@ invalid: "2.0.4" from the root project
    ├── iobroker.flot@ invalid: "1.12.0" from the root project
    ├── iobroker.fronius-solarweb@ invalid: "0.0.3" from the root project
    ├── iobroker.fronius@ invalid: "2.1.1" from the root project
    ├── iobroker.frontier_silicon@ invalid: "0.5.0" from the root project
    ├── iobroker.habpanel@ invalid: "0.5.0" from the root project
    ├── iobroker.history@ invalid: "3.0.1" from the root project
    ├── iobroker.hm-rega@ invalid: "5.1.0" from the root project
    ├── iobroker.hm-rpc@ invalid: "2.0.2" from the root project
    ├── iobroker.hs100@ invalid: "3.0.5" from the root project
    ├── iobroker.icons-addictive-flavour-png@ invalid: "^0.1.0" from the root project
    ├── iobroker.icons-fatcow-hosting@ invalid: "^0.1.0" from the root project
    ├── iobroker.icons-icons8@ invalid: "0.0.1" from the root project
    ├── iobroker.icons-material-png@ invalid: "^0.1.0" from the root project
    ├── iobroker.icons-material-svg@ invalid: "^0.1.0" from the root project
    ├── iobroker.icons-mfd-png@ invalid: "1.2.1" from the root project
    ├── iobroker.icons-mfd-svg@ invalid: "1.2.0" from the root project
    ├── iobroker.icons-open-icon-library-png@ invalid: "0.1.2" from the root project
    ├── iobroker.icons-ultimate-png@ invalid: "^1.0.1" from the root project
    ├── iobroker.influxdb@ invalid: "4.0.2" from the root project
    ├── iobroker.info@ invalid: "2.0.0" from the root project
    ├── iobroker.iot@ invalid: "5.0.7" from the root project
    ├── iobroker.javascript@ invalid: "8.9.2" from the root project
    ├── iobroker.js-controller@ invalid: "^7.0.7" from the root project
    ├── iobroker.mihome-vacuum@ invalid: "5.2.0" from the root project
    ├── iobroker.mqtt@ invalid: "6.1.4" from the root project
    ├── iobroker.net-tools@ invalid: "1.1.2" from the root project
    ├── iobroker.octoprint@ invalid: "5.1.0" from the root project
    ├── iobroker.openweathermap@ invalid: "1.1.2" from the root project
    ├── iobroker.parser@ invalid: "2.2.4" from the root project
    ├── iobroker.ping@ invalid: "1.6.2" from the root project
    ├── iobroker.proxmox@ invalid: "2.4.0" from the root project
    ├── iobroker.radar@ invalid: "^1.2.1" from the root project
    ├── iobroker.radar2@ invalid: "^2.0.3" from the root project
    ├── iobroker.reolink@ invalid: "1.2.3" from the root project
    ├── iobroker.rickshaw@ invalid: "^1.0.0" from the root project
    ├── iobroker.s7@ invalid: "1.5.0" from the root project
    ├── iobroker.sayit@ invalid: "5.0.0" from the root project
    ├── iobroker.smartmeter@ invalid: "3.4.0" from the root project
    ├── iobroker.socketio@ invalid: "6.7.1" from the root project
    ├── iobroker.sql@ invalid: "3.0.1" from the root project
    ├── iobroker.statistics@ invalid: "2.4.0" from the root project
    ├── iobroker.systeminfo@ invalid: "1.3.0" from the root project
    ├── iobroker.telegram@ invalid: "4.1.0" from the root project
    ├── iobroker.terminal@ invalid: "1.0.0" from the root project
    ├── iobroker.tr-064@ invalid: "4.3.0" from the root project
    ├── iobroker.unifi@ invalid: "0.7.0" from the root project
    ├── iobroker.upnp@ invalid: "1.1.0" from the root project
    ├── iobroker.vis-2-widgets-inventwo@ invalid: "0.2.2" from the root project
    ├── iobroker.vis-2-widgets-material@ invalid: "1.4.10" from the root project
    ├── iobroker.vis-2@ invalid: "2.13.4" from the root project
    ├── iobroker.vis-bars@ invalid: "^0.1.4" from the root project
    ├── iobroker.vis-canvas-gauges@ invalid: "1.0.1" from the root project
    ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
    ├── iobroker.vis-fancyswitch@ invalid: "^1.1.0" from the root project
    ├── iobroker.vis-google-fonts@ invalid: "1.0.4" from the root project
    ├── iobroker.vis-history@ invalid: "^1.0.0" from the root project
    ├── iobroker.vis-hqwidgets@ invalid: "1.5.1" from the root project
    ├── iobroker.vis-jqui-mfd@ invalid: "^1.0.12" from the root project
    ├── iobroker.vis-justgage@ invalid: "2.1.7" from the root project
    ├── iobroker.vis-keyboard@ invalid: "0.0.2" from the root project
    ├── iobroker.vis-lcars@ invalid: "1.1.1" from the root project
    ├── iobroker.vis-map@ invalid: "1.1.2" from the root project
    ├── iobroker.vis-materialdesign@ invalid: "0.5.9" from the root project
    ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
    ├── iobroker.vis-rgraph@ invalid: "0.0.2" from the root project
    ├── iobroker.vis-weather@ invalid: "2.5.12" from the root project
    ├── iobroker.vis@ invalid: "1.5.6" from the root project
    ├── iobroker.weatherunderground@ invalid: "3.7.0" from the root project
    ├── iobroker.web@ invalid: "7.0.8" from the root project
    ├── iobroker.ws@ invalid: "2.6.2" from the root project
    ├── iobroker@ invalid: "^2.0.2" from the root project
    ├── ioredis@ extraneous
    ├── ip-address@ extraneous
    ├── ip@ extraneous
    ├── ipaddr.js@ extraneous
    ├── is-arguments@ extraneous
    ├── is-array-buffer@ extraneous
    ├── is-arrayish@ extraneous
    ├── is-async-function@ extraneous
    ├── is-bigint@ extraneous
    ├── is-binary-path@ extraneous
    ├── is-boolean-object@ extraneous
    ├── is-callable@ extraneous
    ├── is-core-module@ extraneous
    ├── is-data-view@ extraneous
    ├── is-date-object@ extraneous
    ├── is-docker@ extraneous
    ├── is-extglob@ extraneous
    ├── is-finalizationregistry@ extraneous
    ├── is-fullwidth-code-point@ extraneous
    ├── is-generator-function@ extraneous
    ├── is-generator@ extraneous
    ├── is-glob@ extraneous
    ├── is-lambda@ extraneous
    ├── is-map@ extraneous
    ├── is-negative-zero@ extraneous
    ├── is-number-like@ extraneous
    ├── is-number-object@ extraneous
    ├── is-number@ extraneous
    ├── is-path-inside@ extraneous
    ├── is-plain-obj@ extraneous
    ├── is-plain-object@ extraneous
    ├── is-promise@ extraneous
    ├── is-property@ extraneous
    ├── is-regex@ extraneous
    ├── is-set@ extraneous
    ├── is-shared-array-buffer@ extraneous
    ├── is-stream@ extraneous
    ├── is-string@ extraneous
    ├── is-symbol@ extraneous
    ├── is-typed-array@ extraneous
    ├── is-typedarray@ extraneous
    ├── is-unicode-supported@ extraneous
    ├── is-utf8@ extraneous
    ├── is-weakmap@ extraneous
    ├── is-weakref@ extraneous
    ├── is-weakset@ extraneous
    ├── is-wsl@ extraneous
    ├── is@ extraneous
    ├── isarray@ extraneous
    ├── isexe@ extraneous
    ├── isomorphic-ws@ extraneous
    ├── isstream@ extraneous
    ├── jackspeak@ extraneous
    ├── jose@ extraneous
    ├── js-md4@ extraneous
    ├── js-sdsl@ extraneous
    ├── js-yaml@ extraneous
    ├── jsbi@ extraneous
    ├── jsbn@ extraneous
    ├── jsdom@ extraneous
    ├── jsftp@ extraneous
    ├── jshashes@ extraneous
    ├── json-bigint@ extraneous
    ├── json-logic-js@ extraneous
    ├── json-schema-traverse@ extraneous
    ├── json-schema@ extraneous
    ├── json-stable-stringify@ extraneous
    ├── json-stringify-safe@ extraneous
    ├── json3@ extraneous
    ├── json5@ extraneous
    ├── jsonata@ extraneous
    ├── jsonc-parser@ extraneous
    ├── jsonify@ extraneous
    ├── jsonwebtoken@ extraneous
    ├── jsprim@ extraneous
    ├── jszip@ extraneous
    ├── jwa@ extraneous
    ├── jwks-rsa@ extraneous
    ├── jws@ extraneous
    ├── klaw-sync@ extraneous
    ├── kuler@ extraneous
    ├── lazystream@ extraneous
    ├── lcid@ extraneous
    ├── leven@ extraneous
    ├── levn@ extraneous
    ├── lie@ extraneous
    ├── limiter@ extraneous
    ├── load-json-file@ extraneous
    ├── loadavg-windows@ extraneous
    ├── localforage@ extraneous
    ├── locate-path@ extraneous
    ├── lodash.camelcase@ extraneous
    ├── lodash.castarray@ extraneous
    ├── lodash.clone@ extraneous
    ├── lodash.clonedeep@ extraneous
    ├── lodash.defaults@ extraneous
    ├── lodash.defaultto@ extraneous
    ├── lodash.flatten@ extraneous
    ├── lodash.get@ extraneous
    ├── lodash.groupby@ extraneous
    ├── lodash.includes@ extraneous
    ├── lodash.isarguments@ extraneous
    ├── lodash.isboolean@ extraneous
    ├── lodash.isequal@ extraneous
    ├── lodash.isfinite@ extraneous
    ├── lodash.isinteger@ extraneous
    ├── lodash.isnumber@ extraneous
    ├── lodash.isplainobject@ extraneous
    ├── lodash.isstring@ extraneous
    ├── lodash.once@ extraneous
    ├── lodash.truncate@ extraneous
    ├── lodash@ extraneous
    ├── log-symbols@ extraneous
    ├── logform@ extraneous
    ├── loglevel@ extraneous
    ├── long-timeout@ extraneous
    ├── long@ extraneous
    ├── loupe@ extraneous
    ├── lru-cache@ extraneous
    ├── lru-memoizer@ extraneous
    ├── lru.min@ extraneous
    ├── luxon@ extraneous
    ├── make-dir@ extraneous
    ├── make-fetch-happen@ extraneous
    ├── map-stream@ extraneous
    ├── math-intrinsics@ extraneous
    ├── mdns-discovery@ extraneous
    ├── mdns@ extraneous
    ├── media-typer@ extraneous
    ├── merge-descriptors@ extraneous
    ├── merge-stream@ extraneous
    ├── merge2@ extraneous
    ├── methods@ extraneous
    ├── micromatch@ extraneous
    ├── mime-db@ extraneous
    ├── mime-types@ extraneous
    ├── mime@ extraneous
    ├── mimic-fn@ extraneous
    ├── mimic-response@ extraneous
    ├── minimatch@ extraneous
    ├── minimist@ extraneous
    ├── minipass-collect@ extraneous
    ├── minipass-fetch@ extraneous
    ├── minipass-flush@ extraneous
    ├── minipass-pipeline@ extraneous
    ├── minipass-sized@ extraneous
    ├── minipass@ extraneous
    ├── minizlib@ extraneous
    ├── mitt@ extraneous
    ├── mkdirp-classic@ extraneous
    ├── mkdirp@ extraneous
    ├── mocha@ extraneous
    ├── moment@ extraneous
    ├── mp3-duration@ extraneous
    ├── mqtt-connection@ extraneous
    ├── mqtt-packet@ extraneous
    ├── mqtt@ extraneous
    ├── ms@ extraneous
    ├── mssql@ extraneous
    ├── multicast-dns@ extraneous
    ├── mute-stream@ extraneous
    ├── mysql2@ extraneous
    ├── named-placeholders@ extraneous
    ├── nan@ extraneous
    ├── napi-build-utils@ extraneous
    ├── napi-thread-safe-callback@ extraneous
    ├── native-duplexpair@ extraneous
    ├── needle@ extraneous
    ├── negotiator@ extraneous
    ├── net-ping@ extraneous
    ├── netmask@ extraneous
    ├── noble@ extraneous
    ├── node-abi@ extraneous
    ├── node-abort-controller@ extraneous
    ├── node-addon-api@ extraneous
    ├── node-arp@ extraneous
    ├── node-ble@ extraneous
    ├── node-fetch@ extraneous
    ├── node-forge@ extraneous
    ├── node-gyp-build@ extraneous
    ├── node-gyp@ extraneous
    ├── node-inspect@ extraneous
    ├── node-mndp@ extraneous
    ├── node-schedule@ extraneous
    ├── node-snap7@ extraneous
    ├── node-ssdp@ extraneous
    ├── node-telegram-bot-api@ extraneous
    ├── node-unifi@ extraneous
    ├── node.extend@ extraneous
    ├── nodemailer@ extraneous
    ├── nodemon@ extraneous
    ├── nopt@ extraneous
    ├── normalize-package-data@ extraneous
    ├── normalize-path@ extraneous
    ├── npm-run-path@ extraneous
    ├── npmlog@ extraneous
    ├── nth-check@ extraneous
    ├── number-allocator@ extraneous
    ├── number-is-nan@ extraneous
    ├── nwmatcher@ extraneous
    ├── oauth-sign@0.9.0 extraneous
    ├── oauth2-server@ extraneous
    ├── object-assign@ extraneous
    ├── object-component@ extraneous
    ├── object-hash@ extraneous
    ├── object-inspect@ extraneous
    ├── object-keys@ extraneous
    ├── object.assign@ extraneous
    ├── on-finished@ extraneous
    ├── on-headers@ extraneous
    ├── once@ extraneous
    ├── one-time@ extraneous
    ├── onetime@ extraneous
    ├── open-sml@ extraneous
    ├── open@ extraneous
    ├── opn@ extraneous
    ├── optionator@ extraneous
    ├── options@ extraneous
    ├── os-locale@ extraneous
    ├── osx-temperature-sensor@ extraneous
    ├── oui@ extraneous
    ├── own-keys@ extraneous
    ├── p-limit@ extraneous
    ├── p-locate@ extraneous
    ├── p-map@ extraneous
    ├── package-json-from-dist@ extraneous
    ├── pako@ extraneous
    ├── parse-json@ extraneous
    ├── parse-listing@ extraneous
    ├── parse5-htmlparser2-tree-adapter@ extraneous
    ├── parse5-parser-stream@ extraneous
    ├── parse5@ extraneous
    ├── parsejson@ extraneous
    ├── parseqs@ extraneous
    ├── parseuri@ extraneous
    ├── parseurl@ extraneous
    ├── parsexmlresponse@ extraneous
    ├── passport-local@ extraneous
    ├── passport-strategy@ extraneous
    ├── passport@ extraneous
    ├── patch-package@ extraneous
    ├── path-exists@ extraneous
    ├── path-is-absolute@ extraneous
    ├── path-key@ extraneous
    ├── path-parse@ extraneous
    ├── path-scurry@ extraneous
    ├── path-to-regexp@ extraneous
    ├── path-type@ extraneous
    ├── pathval@ extraneous
    ├── pause-stream@ extraneous
    ├── pause@ extraneous
    ├── pcap@ extraneous
    ├── performance-now@ extraneous
    ├── pg-cloudflare@ extraneous
    ├── pg-connection-string@ extraneous
    ├── pg-int8@ extraneous
    ├── pg-pool@ extraneous
    ├── pg-protocol@ extraneous
    ├── pg-types@ extraneous
    ├── pg@ extraneous
    ├── pgpass@ extraneous
    ├── picocolors@ extraneous
    ├── picomatch@ extraneous
    ├── pidtree@ extraneous
    ├── pidusage@ extraneous
    ├── pify@ extraneous
    ├── ping@ extraneous
    ├── pinkie-promise@ extraneous
    ├── pinkie@ extraneous
    ├── playlist-parser@ extraneous
    ├── portfinder@ extraneous
    ├── portscanner@ extraneous
    ├── possible-typed-array-names@ extraneous
    ├── postgres-array@ extraneous
    ├── postgres-bytea@ extraneous
    ├── postgres-date@ extraneous
    ├── postgres-interval@ extraneous
    ├── prebuild-install@ extraneous
    ├── prelude-ls@ extraneous
    ├── proc-log@ extraneous
    ├── process-nextick-args@ extraneous
    ├── process@ extraneous
    ├── promise-inflight@ extraneous
    ├── promise-queue@ extraneous
    ├── promise-retry@ extraneous
    ├── promisify-any@ extraneous
    ├── promisify-child-process@ extraneous
    ├── prompt@ extraneous
    ├── protobufjs@ extraneous
    ├── proxy-addr@ extraneous
    ├── proxy-from-env@ extraneous
    ├── ps-tree@ extraneous
    ├── psl@ extraneous
    ├── pstree.remy@ extraneous
    ├── pump@ extraneous
    ├── punycode@ extraneous
    ├── put@ extraneous
    ├── q@ extraneous
    ├── qjobs@ extraneous
    ├── qs@ extraneous
    ├── querystringify@ extraneous
    ├── queue-microtask@ extraneous
    ├── quick-lru@ extraneous
    ├── random-bytes@ extraneous
    ├── randombytes@ extraneous
    ├── range-parser@ extraneous
    ├── raw-body@ extraneous
    ├── raw-socket@ extraneous
    ├── rc@1.2.8 extraneous
    ├── read-pkg-up@ extraneous
    ├── read-pkg@ extraneous
    ├── read@ extraneous
    ├── readable-stream@ extraneous
    ├── readdir-glob@ extraneous
    ├── readdirp@ extraneous
    ├── readline-sync@ extraneous
    ├── readline@ extraneous
    ├── redis-errors@ extraneous
    ├── redis-parser@ extraneous
    ├── reflect.getprototypeof@ extraneous
    ├── regexp.prototype.flags@ extraneous
    ├── reinterval@ extraneous
    ├── request-promise-core@ extraneous
    ├── request@ extraneous
    ├── require-directory@ extraneous
    ├── require-from-string@ extraneous
    ├── require-main-filename@ extraneous
    ├── requires-port@ extraneous
    ├── resolve@ extraneous
    ├── resp-modifier@ extraneous
    ├── respjs@ extraneous
    ├── retry@ extraneous
    ├── reusify@ extraneous
    ├── revalidator@ extraneous
    ├── rfdc@ extraneous
    ├── rimraf@ extraneous
    ├── router@ extraneous
    ├── run-parallel@ extraneous
    ├── rx@ extraneous
    ├── safe-array-concat@ extraneous
    ├── safe-buffer@ extraneous
    ├── safe-push-apply@ extraneous
    ├── safe-regex-test@ extraneous
    ├── safe-stable-stringify@ extraneous
    ├── safer-buffer@2.1.2 extraneous
    ├── sax@ extraneous
    ├── semver@ invalid: "^5.6.0" from the root project
    ├── send@ extraneous
    ├── seq-logging@ extraneous
    ├── seq-queue@ extraneous
    ├── serialize-javascript@ extraneous
    ├── serialport@ extraneous
    ├── serve-index@ extraneous
    ├── serve-static@ extraneous
    ├── server-destroy@ extraneous
    ├── set-blocking@ extraneous
    ├── set-function-length@ extraneous
    ├── set-function-name@ extraneous
    ├── set-proto@ extraneous
    ├── setimmediate@ extraneous
    ├── setprototypeof@ extraneous
    ├── shebang-command@ extraneous
    ├── shebang-regex@ extraneous
    ├── side-channel-list@ extraneous
    ├── side-channel-map@ extraneous
    ├── side-channel-weakmap@ extraneous
    ├── side-channel@ extraneous
    ├── siginfo@ extraneous
    ├── signal-exit@ extraneous
    ├── simple-concat@ extraneous
    ├── simple-get@ extraneous
    ├── simple-update-notifier@ extraneous
    ├── sinon-chai@ extraneous
    ├── sinon@ extraneous
    ├── slash@ extraneous
    ├── slice-ansi@ extraneous
    ├── smart-buffer@ extraneous
    ├── smartmeter-obis@ extraneous
    ├── socket.io-adapter@ extraneous
    ├── socket.io-client@ extraneous
    ├── socket.io-parser@ extraneous
    ├── socket.io@ extraneous
    ├── socks-proxy-agent@ extraneous
    ├── socks@ extraneous
    ├── sorted-array-functions@ extraneous
    ├── source-map-support@ extraneous
    ├── source-map@ extraneous
    ├── spdx-correct@ extraneous
    ├── spdx-exceptions@ extraneous
    ├── spdx-expression-parse@ extraneous
    ├── spdx-license-ids@ extraneous
    ├── split-ca@ extraneous
    ├── split@ extraneous
    ├── split2@ extraneous
    ├── sprintf-js@ extraneous
    ├── sql-client@ extraneous
    ├── sqlite3@ extraneous
    ├── sqlstring@ extraneous
    ├── ssh2@ extraneous
    ├── sshpk@ extraneous
    ├── ssri@ extraneous
    ├── stack-trace@ extraneous
    ├── stackback@ extraneous
    ├── standard-as-callback@ extraneous
    ├── statuses@ extraneous
    ├── stealthy-require@ extraneous
    ├── stop-iteration-iterator@ extraneous
    ├── stoppable@ extraneous
    ├── stream-combiner@ extraneous
    ├── stream-parser@ extraneous
    ├── stream-shift@ extraneous
    ├── stream-throttle@ extraneous
    ├── streamsearch@ extraneous
    ├── streamx@ extraneous
    ├── string_decoder@ extraneous
    ├── string-width-cjs@ extraneous
    ├── string-width@ extraneous
    ├── string.prototype.trim@ extraneous
    ├── string.prototype.trimend@ extraneous
    ├── string.prototype.trimstart@ extraneous
    ├── strip-ansi-cjs@ extraneous
    ├── strip-ansi@ extraneous
    ├── strip-bom@ extraneous
    ├── strip-final-newline@ extraneous
    ├── strip-json-comments@ extraneous
    ├── strnum@ extraneous
    ├── suncalc2@ extraneous
    ├── supports-color@ extraneous
    ├── supports-preserve-symlinks-flag@ extraneous
    ├── symbol-tree@ extraneous
    ├── systeminformation@ extraneous
    ├── table@ extraneous
    ├── tar-fs@ extraneous
    ├── tar-stream@ extraneous
    ├── tar@ extraneous
    ├── tarn@ extraneous
    ├── tedious@ extraneous
    ├── text-decoder@ extraneous
    ├── text-hex@ extraneous
    ├── text-table@ extraneous
    ├── through@ extraneous
    ├── through2@ extraneous
    ├── thunky@ extraneous
    ├── tldts-core@ extraneous
    ├── tldts@ extraneous
    ├── tmp@ extraneous
    ├── to-array@ extraneous
    ├── to-regex-range@ extraneous
    ├── toidentifier@ extraneous
    ├── touch@ extraneous
    ├── tough-cookie@ extraneous
    ├── tplink-smarthome-api@ extraneous
    ├── tplink-smarthome-crypto@ extraneous
    ├── tr-O64@ extraneous
    ├── tr46@ extraneous
    ├── traverse@ extraneous
    ├── treemap-js@ extraneous
    ├── triple-beam@ extraneous
    ├── tslib@ extraneous
    ├── tunnel-agent@ extraneous
    ├── tweetnacl@ extraneous
    ├── type-check@ extraneous
    ├── type-detect@ extraneous
    ├── type-fest@ extraneous
    ├── type-is@ extraneous
    ├── typed-array-buffer@ extraneous
    ├── typed-array-byte-length@ extraneous
    ├── typed-array-byte-offset@ extraneous
    ├── typed-array-length@ extraneous
    ├── typedarray@ extraneous
    ├── typescript@ extraneous
    ├── ua-parser-js@ extraneous
    ├── uid-number@ extraneous
    ├── uid-safe@2.1.5 extraneous
    ├── ultron@ extraneous
    ├── unbox-primitive@ extraneous
    ├── undefsafe@ extraneous
    ├── underscore@ extraneous
    ├── undici-types@ extraneous
    ├── undici@ extraneous
    ├── unique-filename@ extraneous
    ├── unique-slug@ extraneous
    ├── unix-dgram@ extraneous
    ├── unorm@ extraneous
    ├── unpipe@ extraneous
    ├── uri-js@ extraneous
    ├── url-parse@ extraneous
    ├── url-template@ extraneous
    ├── url@ extraneous
    ├── usb@ extraneous
    ├── usocket@ extraneous
    ├── util-deprecate@ extraneous
    ├── util@ extraneous
    ├── utils-merge@ extraneous
    ├── uuid@ extraneous
    ├── validate-npm-package-license@3.0.4 extraneous
    ├── vary@ extraneous
    ├── verror@ extraneous
    ├── virtual-tsc@ extraneous
    ├── wake_on_lan@ extraneous
    ├── weak-daemon@ extraneous
    ├── webidl-conversions@ extraneous
    ├── websocket-stream@ extraneous
    ├── whatwg-encoding@ extraneous
    ├── whatwg-mimetype@ extraneous
    ├── whatwg-url-compat@ extraneous
    ├── whatwg-url@ extraneous
    ├── which-boxed-primitive@ extraneous
    ├── which-builtin-type@ extraneous
    ├── which-collection@ extraneous
    ├── which-module@ extraneous
    ├── which-typed-array@ extraneous
    ├── which@ extraneous
    ├── why-is-node-running@ extraneous
    ├── wide-align@ extraneous
    ├── widest-line@ extraneous
    ├── winston-daily-rotate-file@ extraneous
    ├── winston-seq-updated@ extraneous
    ├── winston-syslog@ extraneous
    ├── winston-transport@ extraneous
    ├── winston@ extraneous
    ├── wol@ extraneous
    ├── word-wrap@ extraneous
    ├── worker-factory@ extraneous
    ├── worker-timers-broker@ extraneous
    ├── worker-timers-worker@ extraneous
    ├── worker-timers@ extraneous
    ├── workerpool@ extraneous
    ├── wrap-ansi-cjs@ extraneous
    ├── wrap-ansi@ extraneous
    ├── wrappy@ extraneous
    ├── ws@ extraneous
    ├── wtf-8@ extraneous
    ├── xml-name-validator@ extraneous
    ├── xml2js@ extraneous
    ├── xml2json-light@ extraneous
    ├── xmlbuilder@ extraneous
    ├── xmldom@ extraneous
    ├── xmlhttprequest-ssl@ extraneous
    ├── xmlhttprequest@ extraneous
    ├── xpc-connection@ extraneous
    ├── xtend@ extraneous
    ├── y18n@ extraneous
    ├── yallist@ extraneous
    ├── yaml@ extraneous
    ├── yargs-parser@ extraneous
    ├── yargs-unparser@ extraneous
    ├── yargs@ invalid: "^7.0.2" from the root project
    ├── yeast@ extraneous
    ├── yocto-queue@ extraneous
    ├── youtube-remote@ extraneous
    └── zip-stream@ extraneous
    npm error code ELSPROBLEMS
    npm error extraneous: @abandonware/bluetooth-hci-socket@ /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
    npm error extraneous: @abandonware/noble@ /opt/iobroker/node_modules/@abandonware/noble
    npm error extraneous: @alcalzone/esbuild-register@ /opt/iobroker/node_modules/@alcalzone/esbuild-register
    npm error extraneous: @alcalzone/jsonl-db@ /opt/iobroker/node_modules/@alcalzone/jsonl-db
    npm error extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/@alcalzone/pak
    npm error extraneous: @alcalzone/proper-lockfile@ /opt/iobroker/node_modules/@alcalzone/proper-lockfile
    npm error extraneous: @all-smart/all-smart-tools@ /opt/iobroker/node_modules/@all-smart/all-smart-tools
    npm error extraneous: @aws-crypto/sha256-browser@ /opt/iobroker/node_modules/@aws-crypto/sha256-browser
    npm error extraneous: @aws-crypto/sha256-js@ /opt/iobroker/node_modules/@aws-crypto/sha256-js
    npm error extraneous: @aws-crypto/supports-web-crypto@ /opt/iobroker/node_modules/@aws-crypto/supports-web-crypto
    npm error extraneous: @aws-crypto/util@ /opt/iobroker/node_modules/@aws-crypto/util
    npm error extraneous: @aws-sdk/client-polly@ /opt/iobroker/node_modules/@aws-sdk/client-polly
    npm error extraneous: @aws-sdk/client-sso@ /opt/iobroker/node_modules/@aws-sdk/client-sso
    npm error extraneous: @aws-sdk/core@ /opt/iobroker/node_modules/@aws-sdk/core
    npm error extraneous: @aws-sdk/credential-provider-env@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-env
    npm error extraneous: @aws-sdk/credential-provider-http@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-http
    npm error extraneous: @aws-sdk/credential-provider-ini@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-ini
    npm error extraneous: @aws-sdk/credential-provider-node@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-node
    npm error extraneous: @aws-sdk/credential-provider-process@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-process
    npm error extraneous: @aws-sdk/credential-provider-sso@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-sso
    npm error extraneous: @aws-sdk/credential-provider-web-identity@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-web-identity
    npm error extraneous: @aws-sdk/middleware-host-header@ /opt/iobroker/node_modules/@aws-sdk/middleware-host-header
    npm error extraneous: @aws-sdk/middleware-logger@ /opt/iobroker/node_modules/@aws-sdk/middleware-logger
    npm error extraneous: @aws-sdk/middleware-recursion-detection@ /opt/iobroker/node_modules/@aws-sdk/middleware-recursion-detection
    npm error extraneous: @aws-sdk/middleware-user-agent@ /opt/iobroker/node_modules/@aws-sdk/middleware-user-agent
    npm error extraneous: @aws-sdk/nested-clients@ /opt/iobroker/node_modules/@aws-sdk/nested-clients
    npm error extraneous: @aws-sdk/region-config-resolver@ /opt/iobroker/node_modules/@aws-sdk/region-config-resolver
    npm error extraneous: @aws-sdk/token-providers@ /opt/iobroker/node_modules/@aws-sdk/token-providers
    npm error extraneous: @aws-sdk/types@ /opt/iobroker/node_modules/@aws-sdk/types
    npm error extraneous: @aws-sdk/util-endpoints@ /opt/iobroker/node_modules/@aws-sdk/util-endpoints
    npm error extraneous: @aws-sdk/util-locate-window@ /opt/iobroker/node_modules/@aws-sdk/util-locate-window
    npm error extraneous: @aws-sdk/util-user-agent-browser@ /opt/iobroker/node_modules/@aws-sdk/util-user-agent-browser
    npm error extraneous: @aws-sdk/util-user-agent-node@ /opt/iobroker/node_modules/@aws-sdk/util-user-agent-node
    npm error extraneous: @aws-sdk/xml-builder@ /opt/iobroker/node_modules/@aws-sdk/xml-builder
    npm error extraneous: @aws/lambda-invoke-store@ /opt/iobroker/node_modules/@aws/lambda-invoke-store
    npm error extraneous: @azure-rest/core-client@ /opt/iobroker/node_modules/@azure-rest/core-client
    npm error extraneous: @azure/abort-controller@ /opt/iobroker/node_modules/@azure/abort-controller
    npm error extraneous: @azure/core-auth@ /opt/iobroker/node_modules/@azure/core-auth
    npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
    npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
    npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
    npm error extraneous: @azure/core-paging@ /opt/iobroker/node_modules/@azure/core-paging
    npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
    npm error extraneous: @azure/core-tracing@ /opt/iobroker/node_modules/@azure/core-tracing
    npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
    npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
    npm error extraneous: @azure/keyvault-common@ /opt/iobroker/node_modules/@azure/keyvault-common
    npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
    npm error extraneous: @azure/logger@ /opt/iobroker/node_modules/@azure/logger
    npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
    npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
    npm error extraneous: @azure/msal-node@ /opt/iobroker/node_modules/@azure/msal-node
    npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
    npm error extraneous: @balena/dockerignore@ /opt/iobroker/node_modules/@balena/dockerignore
    npm error extraneous: @colors/colors@ /opt/iobroker/node_modules/@colors/colors
    npm error extraneous: @cypress/request-promise@ /opt/iobroker/node_modules/@cypress/request-promise
    npm error extraneous: @cypress/request@ /opt/iobroker/node_modules/@cypress/request
    npm error extraneous: @dabh/diagnostics@ /opt/iobroker/node_modules/@dabh/diagnostics
    npm error extraneous: @datalust/winston-seq@ /opt/iobroker/node_modules/@datalust/winston-seq
    npm error extraneous: @fastify/busboy@ /opt/iobroker/node_modules/@fastify/busboy
    npm error extraneous: @gar/promisify@ /opt/iobroker/node_modules/@gar/promisify
    npm error extraneous: @grpc/grpc-js@ /opt/iobroker/node_modules/@grpc/grpc-js
    npm error extraneous: @grpc/proto-loader@ /opt/iobroker/node_modules/@grpc/proto-loader
    npm error extraneous: @httptoolkit/websocket-stream@ /opt/iobroker/node_modules/@httptoolkit/websocket-stream
    npm error extraneous: @influxdata/influxdb-client-apis@ /opt/iobroker/node_modules/@influxdata/influxdb-client-apis
    npm error extraneous: @influxdata/influxdb-client@ /opt/iobroker/node_modules/@influxdata/influxdb-client
    npm error invalid: @iobroker-javascript.0/moment-parseformat@ /opt/iobroker/node_modules/@iobroker-javascript.0/moment-parseformat
    npm error invalid: @iobroker-javascript.0/moment@ /opt/iobroker/node_modules/@iobroker-javascript.0/moment
    npm error extraneous: @iobroker/adapter-core@ /opt/iobroker/node_modules/@iobroker/adapter-core
    npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
    npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
    npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
    npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
    npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
    npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
    npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
    npm error extraneous: @iobroker/dev-server@ /opt/iobroker/node_modules/@iobroker/dev-server
    npm error extraneous: @iobroker/dm-utils@ /opt/iobroker/node_modules/@iobroker/dm-utils
    npm error extraneous: @iobroker/i18n@ /opt/iobroker/node_modules/@iobroker/i18n
    npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
    npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
    npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
    npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
    npm error extraneous: @iobroker/plugin-base@ /opt/iobroker/node_modules/@iobroker/plugin-base
    npm error extraneous: @iobroker/plugin-docker@ /opt/iobroker/node_modules/@iobroker/plugin-docker
    npm error extraneous: @iobroker/plugin-sentry@ /opt/iobroker/node_modules/@iobroker/plugin-sentry
    npm error extraneous: @iobroker/socket-classes@ /opt/iobroker/node_modules/@iobroker/socket-classes
    npm error extraneous: @iobroker/testing@ /opt/iobroker/node_modules/@iobroker/testing
    npm error extraneous: @iobroker/type-detector@ /opt/iobroker/node_modules/@iobroker/type-detector
    npm error extraneous: @iobroker/types@ /opt/iobroker/node_modules/@iobroker/types
    npm error extraneous: @iobroker/webserver@ /opt/iobroker/node_modules/@iobroker/webserver
    npm error extraneous: @iobroker/ws-server@ /opt/iobroker/node_modules/@iobroker/ws-server
    npm error extraneous: @iobroker/ws@ /opt/iobroker/node_modules/@iobroker/ws
    npm error extraneous: @ioredis/commands@ /opt/iobroker/node_modules/@ioredis/commands
    npm error extraneous: @isaacs/balanced-match@ /opt/iobroker/node_modules/@isaacs/balanced-match
    npm error extraneous: @isaacs/brace-expansion@ /opt/iobroker/node_modules/@isaacs/brace-expansion
    npm error extraneous: @isaacs/cliui@ /opt/iobroker/node_modules/@isaacs/cliui
    npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
    npm error extraneous: @js-sdsl/ordered-map@ /opt/iobroker/node_modules/@js-sdsl/ordered-map
    npm error extraneous: @leichtgewicht/ip-codec@ /opt/iobroker/node_modules/@leichtgewicht/ip-codec
    npm error extraneous: @mapbox/node-pre-gyp@ /opt/iobroker/node_modules/@mapbox/node-pre-gyp
    npm error extraneous: @network-utils/arp-lookup@ /opt/iobroker/node_modules/@network-utils/arp-lookup
    npm error extraneous: @nodelib/fs.scandir@ /opt/iobroker/node_modules/@nodelib/fs.scandir
    npm error extraneous: @nodelib/fs.stat@ /opt/iobroker/node_modules/@nodelib/fs.stat
    npm error extraneous: @nodelib/fs.walk@ /opt/iobroker/node_modules/@nodelib/fs.walk
    npm error extraneous: @nornagon/put@ /opt/iobroker/node_modules/@nornagon/put
    npm error extraneous: @npmcli/agent@ /opt/iobroker/node_modules/@npmcli/agent
    npm error extraneous: @npmcli/fs@ /opt/iobroker/node_modules/@npmcli/fs
    npm error extraneous: @npmcli/move-file@ /opt/iobroker/node_modules/@npmcli/move-file
    npm error extraneous: @pkgjs/parseargs@ /opt/iobroker/node_modules/@pkgjs/parseargs
    npm error extraneous: @protobufjs/aspromise@ /opt/iobroker/node_modules/@protobufjs/aspromise
    npm error extraneous: @protobufjs/base64@ /opt/iobroker/node_modules/@protobufjs/base64
    npm error extraneous: @protobufjs/codegen@ /opt/iobroker/node_modules/@protobufjs/codegen
    npm error extraneous: @protobufjs/eventemitter@ /opt/iobroker/node_modules/@protobufjs/eventemitter
    npm error extraneous: @protobufjs/fetch@ /opt/iobroker/node_modules/@protobufjs/fetch
    npm error extraneous: @protobufjs/float@ /opt/iobroker/node_modules/@protobufjs/float
    npm error extraneous: @protobufjs/inquire@ /opt/iobroker/node_modules/@protobufjs/inquire
    npm error extraneous: @protobufjs/path@ /opt/iobroker/node_modules/@protobufjs/path
    npm error extraneous: @protobufjs/pool@ /opt/iobroker/node_modules/@protobufjs/pool
    npm error extraneous: @protobufjs/utf8@ /opt/iobroker/node_modules/@protobufjs/utf8
    npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
    npm error extraneous: @sentry/core@ /opt/iobroker/node_modules/@sentry/core
    npm error extraneous: @sentry/integrations@ /opt/iobroker/node_modules/@sentry/integrations
    npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
    npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
    npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
    npm error extraneous: @serialport/binding-mock@ /opt/iobroker/node_modules/@serialport/binding-mock
    npm error extraneous: @serialport/bindings-cpp@ /opt/iobroker/node_modules/@serialport/bindings-cpp
    npm error extraneous: @serialport/bindings-interface@ /opt/iobroker/node_modules/@serialport/bindings-interface
    npm error extraneous: @serialport/parser-byte-length@ /opt/iobroker/node_modules/@serialport/parser-byte-length
    npm error extraneous: @serialport/parser-cctalk@ /opt/iobroker/node_modules/@serialport/parser-cctalk
    npm error extraneous: @serialport/parser-delimiter@ /opt/iobroker/node_modules/@serialport/parser-delimiter
    npm error extraneous: @serialport/parser-inter-byte-timeout@ /opt/iobroker/node_modules/@serialport/parser-inter-byte-timeout
    npm error extraneous: @serialport/parser-packet-length@ /opt/iobroker/node_modules/@serialport/parser-packet-length
    npm error extraneous: @serialport/parser-readline@ /opt/iobroker/node_modules/@serialport/parser-readline
    npm error extraneous: @serialport/parser-ready@ /opt/iobroker/node_modules/@serialport/parser-ready
    npm error extraneous: @serialport/parser-regex@ /opt/iobroker/node_modules/@serialport/parser-regex
    npm error extraneous: @serialport/parser-slip-encoder@ /opt/iobroker/node_modules/@serialport/parser-slip-encoder
    npm error extraneous: @serialport/parser-spacepacket@ /opt/iobroker/node_modules/@serialport/parser-spacepacket
    npm error extraneous: @serialport/stream@ /opt/iobroker/node_modules/@serialport/stream
    npm error extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/@sinonjs/commons
    npm error extraneous: @sinonjs/fake-timers@ /opt/iobroker/node_modules/@sinonjs/fake-timers
    npm error extraneous: @sinonjs/samsam@ /opt/iobroker/node_modules/@sinonjs/samsam
    npm error extraneous: @smithy/abort-controller@ /opt/iobroker/node_modules/@smithy/abort-controller
    npm error extraneous: @smithy/config-resolver@ /opt/iobroker/node_modules/@smithy/config-resolver
    npm error extraneous: @smithy/core@ /opt/iobroker/node_modules/@smithy/core
    npm error extraneous: @smithy/credential-provider-imds@ /opt/iobroker/node_modules/@smithy/credential-provider-imds
    npm error extraneous: @smithy/fetch-http-handler@ /opt/iobroker/node_modules/@smithy/fetch-http-handler
    npm error extraneous: @smithy/hash-node@ /opt/iobroker/node_modules/@smithy/hash-node
    npm error extraneous: @smithy/invalid-dependency@ /opt/iobroker/node_modules/@smithy/invalid-dependency
    npm error extraneous: @smithy/is-array-buffer@ /opt/iobroker/node_modules/@smithy/is-array-buffer
    npm error extraneous: @smithy/middleware-content-length@ /opt/iobroker/node_modules/@smithy/middleware-content-length
    npm error extraneous: @smithy/middleware-endpoint@ /opt/iobroker/node_modules/@smithy/middleware-endpoint
    npm error extraneous: @smithy/middleware-retry@ /opt/iobroker/node_modules/@smithy/middleware-retry
    npm error extraneous: @smithy/middleware-serde@ /opt/iobroker/node_modules/@smithy/middleware-serde
    npm error extraneous: @smithy/middleware-stack@ /opt/iobroker/node_modules/@smithy/middleware-stack
    npm error extraneous: @smithy/node-config-provider@ /opt/iobroker/node_modules/@smithy/node-config-provider
    npm error extraneous: @smithy/node-http-handler@ /opt/iobroker/node_modules/@smithy/node-http-handler
    npm error extraneous: @smithy/property-provider@ /opt/iobroker/node_modules/@smithy/property-provider
    npm error extraneous: @smithy/protocol-http@ /opt/iobroker/node_modules/@smithy/protocol-http
    npm error extraneous: @smithy/querystring-builder@ /opt/iobroker/node_modules/@smithy/querystring-builder
    npm error extraneous: @smithy/querystring-parser@ /opt/iobroker/node_modules/@smithy/querystring-parser
    npm error extraneous: @smithy/service-error-classification@ /opt/iobroker/node_modules/@smithy/service-error-classification
    npm error extraneous: @smithy/shared-ini-file-loader@ /opt/iobroker/node_modules/@smithy/shared-ini-file-loader
    npm error extraneous: @smithy/signature-v4@ /opt/iobroker/node_modules/@smithy/signature-v4
    npm error extraneous: @smithy/smithy-client@ /opt/iobroker/node_modules/@smithy/smithy-client
    npm error extraneous: @smithy/types@ /opt/iobroker/node_modules/@smithy/types
    npm error extraneous: @smithy/url-parser@ /opt/iobroker/node_modules/@smithy/url-parser
    npm error extraneous: @smithy/util-base64@ /opt/iobroker/node_modules/@smithy/util-base64
    npm error extraneous: @smithy/util-body-length-browser@ /opt/iobroker/node_modules/@smithy/util-body-length-browser
    npm error extraneous: @smithy/util-body-length-node@ /opt/iobroker/node_modules/@smithy/util-body-length-node
    npm error extraneous: @smithy/util-buffer-from@ /opt/iobroker/node_modules/@smithy/util-buffer-from
    npm error extraneous: @smithy/util-config-provider@ /opt/iobroker/node_modules/@smithy/util-config-provider
    npm error extraneous: @smithy/util-defaults-mode-browser@ /opt/iobroker/node_modules/@smithy/util-defaults-mode-browser
    npm error extraneous: @smithy/util-defaults-mode-node@ /opt/iobroker/node_modules/@smithy/util-defaults-mode-node
    npm error extraneous: @smithy/util-endpoints@ /opt/iobroker/node_modules/@smithy/util-endpoints
    npm error extraneous: @smithy/util-hex-encoding@ /opt/iobroker/node_modules/@smithy/util-hex-encoding
    npm error extraneous: @smithy/util-middleware@ /opt/iobroker/node_modules/@smithy/util-middleware
    npm error extraneous: @smithy/util-retry@ /opt/iobroker/node_modules/@smithy/util-retry
    npm error extraneous: @smithy/util-stream@ /opt/iobroker/node_modules/@smithy/util-stream
    npm error extraneous: @smithy/util-uri-escape@ /opt/iobroker/node_modules/@smithy/util-uri-escape
    npm error extraneous: @smithy/util-utf8@ /opt/iobroker/node_modules/@smithy/util-utf8
    npm error extraneous: @smithy/uuid@ /opt/iobroker/node_modules/@smithy/uuid
    npm error extraneous: @so-ric/colorspace@ /opt/iobroker/node_modules/@so-ric/colorspace
    npm error extraneous: @socket.io/component-emitter@ /opt/iobroker/node_modules/@socket.io/component-emitter
    npm error extraneous: @stoprocent/bluetooth-hci-socket@ /opt/iobroker/node_modules/@stoprocent/bluetooth-hci-socket
    npm error extraneous: @stoprocent/noble@ /opt/iobroker/node_modules/@stoprocent/noble
    npm error extraneous: @tediousjs/connection-string@ /opt/iobroker/node_modules/@tediousjs/connection-string
    npm error extraneous: @tootallnate/once@ /opt/iobroker/node_modules/@tootallnate/once
    npm error extraneous: @types/body-parser@ /opt/iobroker/node_modules/@types/body-parser
    npm error extraneous: @types/caseless@ /opt/iobroker/node_modules/@types/caseless
    npm error extraneous: @types/chai-as-promised@ /opt/iobroker/node_modules/@types/chai-as-promised
    npm error extraneous: @types/chai@ /opt/iobroker/node_modules/@types/chai
    npm error extraneous: @types/connect@ /opt/iobroker/node_modules/@types/connect
    npm error extraneous: @types/cors@ /opt/iobroker/node_modules/@types/cors
    npm error extraneous: @types/express-serve-static-core@ /opt/iobroker/node_modules/@types/express-serve-static-core
    npm error extraneous: @types/express@ /opt/iobroker/node_modules/@types/express
    npm error extraneous: @types/http-errors@ /opt/iobroker/node_modules/@types/http-errors
    npm error extraneous: @types/http-proxy@ /opt/iobroker/node_modules/@types/http-proxy
    npm error extraneous: @types/jsonwebtoken@ /opt/iobroker/node_modules/@types/jsonwebtoken
    npm error extraneous: @types/long@ /opt/iobroker/node_modules/@types/long
    npm error extraneous: @types/luxon@ /opt/iobroker/node_modules/@types/luxon
    npm error extraneous: @types/mime@ /opt/iobroker/node_modules/@types/mime
    npm error extraneous: @types/mocha@ /opt/iobroker/node_modules/@types/mocha
    npm error extraneous: @types/ms@ /opt/iobroker/node_modules/@types/ms
    npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
    npm error extraneous: @types/qs@ /opt/iobroker/node_modules/@types/qs
    npm error extraneous: @types/range-parser@ /opt/iobroker/node_modules/@types/range-parser
    npm error extraneous: @types/readable-stream@ /opt/iobroker/node_modules/@types/readable-stream
    npm error extraneous: @types/request@ /opt/iobroker/node_modules/@types/request
    npm error extraneous: @types/send@ /opt/iobroker/node_modules/@types/send
    npm error extraneous: @types/serve-static@ /opt/iobroker/node_modules/@types/serve-static
    npm error extraneous: @types/sinon-chai@ /opt/iobroker/node_modules/@types/sinon-chai
    npm error extraneous: @types/sinon@ /opt/iobroker/node_modules/@types/sinon
    npm error extraneous: @types/sinonjs__fake-timers@ /opt/iobroker/node_modules/@types/sinonjs__fake-timers
    npm error extraneous: @types/tough-cookie@ /opt/iobroker/node_modules/@types/tough-cookie
    npm error extraneous: @types/triple-beam@ /opt/iobroker/node_modules/@types/triple-beam
    npm error extraneous: @types/w3c-web-usb@ /opt/iobroker/node_modules/@types/w3c-web-usb
    npm error extraneous: @types/ws@ /opt/iobroker/node_modules/@types/ws
    npm error extraneous: @typespec/ts-http-runtime@ /opt/iobroker/node_modules/@typespec/ts-http-runtime
    npm error extraneous: @yarnpkg/lockfile@ /opt/iobroker/node_modules/@yarnpkg/lockfile
    npm error extraneous: abbrev@ /opt/iobroker/node_modules/abbrev
    npm error extraneous: abort-controller@ /opt/iobroker/node_modules/abort-controller
    npm error extraneous: accepts@ /opt/iobroker/node_modules/accepts
    npm error extraneous: acorn-globals@ /opt/iobroker/node_modules/acorn-globals
    npm error extraneous: acorn@ /opt/iobroker/node_modules/acorn
    npm error extraneous: after@ /opt/iobroker/node_modules/after
    npm error extraneous: agent-base@ /opt/iobroker/node_modules/agent-base
    npm error extraneous: agentkeepalive@ /opt/iobroker/node_modules/agentkeepalive
    npm error extraneous: aggregate-error@ /opt/iobroker/node_modules/aggregate-error
    npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
    npm error extraneous: alcalzone-shared@ /opt/iobroker/node_modules/alcalzone-shared
    npm error extraneous: ansi-align@ /opt/iobroker/node_modules/ansi-align
    npm error extraneous: ansi-colors@ /opt/iobroker/node_modules/ansi-colors
    npm error extraneous: ansi-regex@ /opt/iobroker/node_modules/ansi-regex
    npm error extraneous: ansi-styles@ /opt/iobroker/node_modules/ansi-styles
    npm error extraneous: anymatch@ /opt/iobroker/node_modules/anymatch
    npm error extraneous: aproba@ /opt/iobroker/node_modules/aproba
    npm error extraneous: archiver-utils@ /opt/iobroker/node_modules/archiver-utils
    npm error extraneous: archiver@ /opt/iobroker/node_modules/archiver
    npm error extraneous: are-we-there-yet@ /opt/iobroker/node_modules/are-we-there-yet
    npm error extraneous: argf@ /opt/iobroker/node_modules/argf
    npm error extraneous: argparse@ /opt/iobroker/node_modules/argparse
    npm error extraneous: array-buffer-byte-length@ /opt/iobroker/node_modules/array-buffer-byte-length
    npm error extraneous: array-find@ /opt/iobroker/node_modules/array-find
    npm error extraneous: array-flatten@ /opt/iobroker/node_modules/array-flatten
    npm error extraneous: array.prototype.findindex@ /opt/iobroker/node_modules/array.prototype.findindex
    npm error extraneous: arraybuffer.prototype.slice@ /opt/iobroker/node_modules/arraybuffer.prototype.slice
    npm error extraneous: arraybuffer.slice@ /opt/iobroker/node_modules/arraybuffer.slice
    npm error extraneous: asn1@ /opt/iobroker/node_modules/asn1
    npm error extraneous: assert-plus@ /opt/iobroker/node_modules/assert-plus
    npm error extraneous: assertion-error@ /opt/iobroker/node_modules/assertion-error
    npm error extraneous: astral-regex@ /opt/iobroker/node_modules/astral-regex
    npm error extraneous: async-each-series@ /opt/iobroker/node_modules/async-each-series
    npm error extraneous: async-function@ /opt/iobroker/node_modules/async-function
    npm error extraneous: async-limiter@ /opt/iobroker/node_modules/async-limiter
    npm error extraneous: async@ /opt/iobroker/node_modules/async
    npm error extraneous: asynckit@ /opt/iobroker/node_modules/asynckit
    npm error extraneous: authenticate-pam@ /opt/iobroker/node_modules/authenticate-pam
    npm error extraneous: available-typed-arrays@ /opt/iobroker/node_modules/available-typed-arrays
    npm error extraneous: aws-iot-device-sdk@ /opt/iobroker/node_modules/aws-iot-device-sdk
    npm error extraneous: aws-sign2@ /opt/iobroker/node_modules/aws-sign2
    npm error extraneous: aws-ssl-profiles@ /opt/iobroker/node_modules/aws-ssl-profiles
    npm error extraneous: aws4@ /opt/iobroker/node_modules/aws4
    npm error extraneous: axios@ /opt/iobroker/node_modules/axios
    npm error extraneous: b4a@ /opt/iobroker/node_modules/b4a
    npm error extraneous: backo2@ /opt/iobroker/node_modules/backo2
    npm error extraneous: balanced-match@ /opt/iobroker/node_modules/balanced-match
    npm error extraneous: bare-events@ /opt/iobroker/node_modules/bare-events
    npm error extraneous: base-64@ /opt/iobroker/node_modules/base-64
    npm error extraneous: base64-arraybuffer@ /opt/iobroker/node_modules/base64-arraybuffer
    npm error extraneous: base64-js@ /opt/iobroker/node_modules/base64-js
    npm error extraneous: base64id@ /opt/iobroker/node_modules/base64id
    npm error extraneous: basic-auth@ /opt/iobroker/node_modules/basic-auth
    npm error extraneous: batch@ /opt/iobroker/node_modules/batch
    npm error extraneous: bcrypt-pbkdf@ /opt/iobroker/node_modules/bcrypt-pbkdf
    npm error extraneous: better-assert@ /opt/iobroker/node_modules/better-assert
    npm error extraneous: bignumber.js@ /opt/iobroker/node_modules/bignumber.js
    npm error extraneous: binary-extensions@ /opt/iobroker/node_modules/binary-extensions
    npm error extraneous: binary@ /opt/iobroker/node_modules/binary
    npm error extraneous: bindings@ /opt/iobroker/node_modules/bindings
    npm error extraneous: binrpc@ /opt/iobroker/node_modules/binrpc
    npm error extraneous: bl@ /opt/iobroker/node_modules/bl
    npm error extraneous: blob@ /opt/iobroker/node_modules/blob
    npm error extraneous: bluebird-co@ /opt/iobroker/node_modules/bluebird-co
    npm error extraneous: bluebird@ /opt/iobroker/node_modules/bluebird
    npm error extraneous: bluetooth-hci-socket@ /opt/iobroker/node_modules/bluetooth-hci-socket
    npm error extraneous: body-parser@ /opt/iobroker/node_modules/body-parser
    npm error extraneous: boolbase@ /opt/iobroker/node_modules/boolbase
    npm error extraneous: bower@ /opt/iobroker/node_modules/bower
    npm error extraneous: bowser@ /opt/iobroker/node_modules/bowser
    npm error extraneous: boxen@ /opt/iobroker/node_modules/boxen
    npm error extraneous: bplist-parser@ /opt/iobroker/node_modules/bplist-parser
    npm error extraneous: brace-expansion@ /opt/iobroker/node_modules/brace-expansion
    npm error extraneous: braces@ /opt/iobroker/node_modules/braces
    npm error extraneous: broker-factory@ /opt/iobroker/node_modules/broker-factory
    npm error extraneous: browser-request@ /opt/iobroker/node_modules/browser-request
    npm error extraneous: browser-stdout@ /opt/iobroker/node_modules/browser-stdout
    npm error extraneous: browser-sync-client@ /opt/iobroker/node_modules/browser-sync-client
    npm error extraneous: browser-sync-ui@ /opt/iobroker/node_modules/browser-sync-ui
    npm error extraneous: browser-sync@ /opt/iobroker/node_modules/browser-sync
    npm error extraneous: bs-html-injector@ /opt/iobroker/node_modules/bs-html-injector
    npm error extraneous: bs-recipes@ /opt/iobroker/node_modules/bs-recipes
    npm error extraneous: buffer-crc32@ /opt/iobroker/node_modules/buffer-crc32
    npm error extraneous: buffer-equal-constant-time@ /opt/iobroker/node_modules/buffer-equal-constant-time
    npm error extraneous: buffer-from@ /opt/iobroker/node_modules/buffer-from
    npm error extraneous: buffer@ /opt/iobroker/node_modules/buffer
    npm error extraneous: buffers@ /opt/iobroker/node_modules/buffers
    npm error extraneous: buildcheck@ /opt/iobroker/node_modules/buildcheck
    npm error extraneous: busboy@ /opt/iobroker/node_modules/busboy
    npm error extraneous: bytes@ /opt/iobroker/node_modules/bytes
    npm error extraneous: cacache@ /opt/iobroker/node_modules/cacache
    npm error extraneous: call-bind-apply-helpers@ /opt/iobroker/node_modules/call-bind-apply-helpers
    npm error extraneous: call-bind@ /opt/iobroker/node_modules/call-bind
    npm error extraneous: call-bound@ /opt/iobroker/node_modules/call-bound
    npm error extraneous: callsite@ /opt/iobroker/node_modules/callsite
    npm error extraneous: camelcase@ /opt/iobroker/node_modules/camelcase
    npm error extraneous: canvas@ /opt/iobroker/node_modules/canvas
    npm error extraneous: caseless@ /opt/iobroker/node_modules/caseless
    npm error extraneous: castv2-client@ /opt/iobroker/node_modules/castv2-client
    npm error extraneous: castv2-player@ /opt/iobroker/node_modules/castv2-player
    npm error extraneous: castv2@ /opt/iobroker/node_modules/castv2
    npm error extraneous: chai-as-promised@ /opt/iobroker/node_modules/chai-as-promised
    npm error extraneous: chai@ /opt/iobroker/node_modules/chai
    npm error extraneous: chainsaw@ /opt/iobroker/node_modules/chainsaw
    npm error extraneous: chalk@ /opt/iobroker/node_modules/chalk
    npm error extraneous: char-spinner@ /opt/iobroker/node_modules/char-spinner
    npm error extraneous: check-error@ /opt/iobroker/node_modules/check-error
    npm error extraneous: cheerio-select@ /opt/iobroker/node_modules/cheerio-select
    npm error extraneous: cheerio@ /opt/iobroker/node_modules/cheerio
    npm error extraneous: chokidar@ /opt/iobroker/node_modules/chokidar
    npm error extraneous: chownr@ /opt/iobroker/node_modules/chownr
    npm error extraneous: ci-info@ /opt/iobroker/node_modules/ci-info
    npm error extraneous: clean-stack@ /opt/iobroker/node_modules/clean-stack
    npm error extraneous: cli-boxes@ /opt/iobroker/node_modules/cli-boxes
    npm error extraneous: cliui@ /opt/iobroker/node_modules/cliui
    npm error extraneous: cluster-key-slot@ /opt/iobroker/node_modules/cluster-key-slot
    npm error extraneous: co-bluebird@ /opt/iobroker/node_modules/co-bluebird
    npm error extraneous: co-use@ /opt/iobroker/node_modules/co-use
    npm error extraneous: code-point-at@ /opt/iobroker/node_modules/code-point-at
    npm error extraneous: color-convert@ /opt/iobroker/node_modules/color-convert
    npm error extraneous: color-name@ /opt/iobroker/node_modules/color-name
    npm error extraneous: color-string@ /opt/iobroker/node_modules/color-string
    npm error extraneous: color-support@ /opt/iobroker/node_modules/color-support
    npm error extraneous: color@ /opt/iobroker/node_modules/color
    npm error invalid: colors@ /opt/iobroker/node_modules/colors
    npm error extraneous: combined-stream@ /opt/iobroker/node_modules/combined-stream
    npm error extraneous: commander@ /opt/iobroker/node_modules/commander
    npm error extraneous: commist@ /opt/iobroker/node_modules/commist
    npm error extraneous: component-bind@ /opt/iobroker/node_modules/component-bind
    npm error extraneous: component-emitter@ /opt/iobroker/node_modules/component-emitter
    npm error extraneous: component-inherit@ /opt/iobroker/node_modules/component-inherit
    npm error extraneous: compress-commons@ /opt/iobroker/node_modules/compress-commons
    npm error extraneous: compressible@ /opt/iobroker/node_modules/compressible
    npm error extraneous: compression@ /opt/iobroker/node_modules/compression
    npm error extraneous: concat-map@ /opt/iobroker/node_modules/concat-map
    npm error extraneous: concat-stream@ /opt/iobroker/node_modules/concat-stream
    npm error extraneous: connect-flash@ /opt/iobroker/node_modules/connect-flash
    npm error extraneous: connect-history-api-fallback@ /opt/iobroker/node_modules/connect-history-api-fallback
    npm error extraneous: connect@ /opt/iobroker/node_modules/connect
    npm error extraneous: console-control-strings@ /opt/iobroker/node_modules/console-control-strings
    npm error extraneous: content-disposition@ /opt/iobroker/node_modules/content-disposition
    npm error extraneous: content-type@ /opt/iobroker/node_modules/content-type
    npm error extraneous: cookie-parser@ /opt/iobroker/node_modules/cookie-parser
    npm error extraneous: cookie-signature@ /opt/iobroker/node_modules/cookie-signature
    npm error extraneous: cookie@ /opt/iobroker/node_modules/cookie
    npm error extraneous: core-util-is@ /opt/iobroker/node_modules/core-util-is
    npm error extraneous: cors@ /opt/iobroker/node_modules/cors
    npm error extraneous: country-data@ /opt/iobroker/node_modules/country-data
    npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
    npm error extraneous: crc-32@ /opt/iobroker/node_modules/crc-32
    npm error extraneous: crc32-stream@ /opt/iobroker/node_modules/crc32-stream
    npm error extraneous: cron-parser@ /opt/iobroker/node_modules/cron-parser
    npm error extraneous: cron@ /opt/iobroker/node_modules/cron
    npm error extraneous: cross-spawn@ /opt/iobroker/node_modules/cross-spawn
    npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
    npm error extraneous: css-select@ /opt/iobroker/node_modules/css-select
    npm error extraneous: css-what@ /opt/iobroker/node_modules/css-what
    npm error extraneous: cssom@ /opt/iobroker/node_modules/cssom
    npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
    npm error extraneous: currency-symbol-map@ /opt/iobroker/node_modules/currency-symbol-map
    npm error extraneous: cycle@ /opt/iobroker/node_modules/cycle
    npm error extraneous: dashdash@ /opt/iobroker/node_modules/dashdash
    npm error extraneous: data-view-buffer@ /opt/iobroker/node_modules/data-view-buffer
    npm error extraneous: data-view-byte-length@ /opt/iobroker/node_modules/data-view-byte-length
    npm error extraneous: data-view-byte-offset@ /opt/iobroker/node_modules/data-view-byte-offset
    npm error extraneous: dateformat@ /opt/iobroker/node_modules/dateformat
    npm error extraneous: dbus-next@ /opt/iobroker/node_modules/dbus-next
    npm error extraneous: debug@ /opt/iobroker/node_modules/debug
    npm error extraneous: decache@ /opt/iobroker/node_modules/decache
    npm error extraneous: decamelize@ /opt/iobroker/node_modules/decamelize
    npm error extraneous: decompress-response@ /opt/iobroker/node_modules/decompress-response
    npm error extraneous: deep-clone@ /opt/iobroker/node_modules/deep-clone
    npm error extraneous: deep-eql@ /opt/iobroker/node_modules/deep-eql
    npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
    npm error extraneous: deep-is@ /opt/iobroker/node_modules/deep-is
    npm error extraneous: define-data-property@ /opt/iobroker/node_modules/define-data-property
    npm error extraneous: define-lazy-prop@ /opt/iobroker/node_modules/define-lazy-prop
    npm error extraneous: define-properties@ /opt/iobroker/node_modules/define-properties
    npm error extraneous: delayed-stream@ /opt/iobroker/node_modules/delayed-stream
    npm error extraneous: delegates@ /opt/iobroker/node_modules/delegates
    npm error extraneous: denque@ /opt/iobroker/node_modules/denque
    npm error extraneous: depd@ /opt/iobroker/node_modules/depd
    npm error extraneous: destroy@ /opt/iobroker/node_modules/destroy
    npm error extraneous: detect-libc@ /opt/iobroker/node_modules/detect-libc
    npm error extraneous: dev-ip@ /opt/iobroker/node_modules/dev-ip
    npm error extraneous: dev-null@ /opt/iobroker/node_modules/dev-null
    npm error extraneous: dgram@ /opt/iobroker/node_modules/dgram
    npm error extraneous: diff@ /opt/iobroker/node_modules/diff
    npm error extraneous: diskusage@ /opt/iobroker/node_modules/diskusage
    npm error extraneous: dns-packet@ /opt/iobroker/node_modules/dns-packet
    npm error extraneous: docker-modem@ /opt/iobroker/node_modules/docker-modem
    npm error extraneous: dockerode@ /opt/iobroker/node_modules/dockerode
    npm error extraneous: dom-compare-temp@ /opt/iobroker/node_modules/dom-compare-temp
    npm error extraneous: dom-serializer@ /opt/iobroker/node_modules/dom-serializer
    npm error extraneous: domelementtype@ /opt/iobroker/node_modules/domelementtype
    npm error extraneous: domhandler@ /opt/iobroker/node_modules/domhandler
    npm error extraneous: domutils@ /opt/iobroker/node_modules/domutils
    npm error extraneous: dunder-proto@ /opt/iobroker/node_modules/dunder-proto
    npm error extraneous: duplexer@ /opt/iobroker/node_modules/duplexer
    npm error extraneous: duplexify@ /opt/iobroker/node_modules/duplexify
    npm error extraneous: eastasianwidth@ /opt/iobroker/node_modules/eastasianwidth
    npm error extraneous: easy-extender@ /opt/iobroker/node_modules/easy-extender
    npm error extraneous: eazy-logger@ /opt/iobroker/node_modules/eazy-logger
    npm error extraneous: ecc-jsbn@ /opt/iobroker/node_modules/ecc-jsbn
    npm error extraneous: ecdsa-sig-formatter@ /opt/iobroker/node_modules/ecdsa-sig-formatter
    npm error extraneous: ee-first@ /opt/iobroker/node_modules/ee-first
    npm error extraneous: emoji-regex@ /opt/iobroker/node_modules/emoji-regex
    npm error extraneous: enabled@ /opt/iobroker/node_modules/enabled
    npm error extraneous: encodeurl@ /opt/iobroker/node_modules/encodeurl
    npm error extraneous: encoding-sniffer@ /opt/iobroker/node_modules/encoding-sniffer
    npm error extraneous: encoding@ /opt/iobroker/node_modules/encoding
    npm error extraneous: end-of-stream@ /opt/iobroker/node_modules/end-of-stream
    npm error extraneous: engine.io-client@ /opt/iobroker/node_modules/engine.io-client
    npm error extraneous: engine.io-parser@ /opt/iobroker/node_modules/engine.io-parser
    npm error extraneous: engine.io@ /opt/iobroker/node_modules/engine.io
    npm error extraneous: enquirer@ /opt/iobroker/node_modules/enquirer
    npm error extraneous: entities@ /opt/iobroker/node_modules/entities
    npm error extraneous: env-paths@ /opt/iobroker/node_modules/env-paths
    npm error extraneous: err-code@ /opt/iobroker/node_modules/err-code
    npm error extraneous: error-ex@ /opt/iobroker/node_modules/error-ex
    npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
    npm error extraneous: es-aggregate-error@ /opt/iobroker/node_modules/es-aggregate-error
    npm error extraneous: es-define-property@ /opt/iobroker/node_modules/es-define-property
    npm error extraneous: es-errors@ /opt/iobroker/node_modules/es-errors
    @george_best
    Da gilt dann auch für dich:
    Die mit Invalid gekennzeichneten Adapter mal neuinstallieren, tote Adapter rauskicken.
    Sieht mir aber insgesamt SEHR strubbelig aus.
    G 1 Antwort Letzte Antwort
      @george_best
      George_Best
      ich musste nun auch den js-controller neu installieren:
      npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
      npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
      npm warn deprecated uid-number@0.0.6: This package is no longer supported.
      npm warn deprecated npmlog@5.0.1: This package is no longer supported.
      npm warn deprecated lodash.get@4.4.2: This package is deprecated. Use the optional chaining (?.) operator instead.
      npm warn deprecated npmlog@6.0.2: This package is no longer supported.
      npm warn deprecated lodash.isequal@4.5.0: This package is deprecated. Use require('node:util').isDeepStrictEqual instead.
      npm warn deprecated lodash.clone@4.5.0: This package is deprecated. Use structuredClone instead.
      npm warn deprecated har-validator@5.1.5: this library is no longer supported
      npm warn deprecated npmlog@4.1.2: This package is no longer supported.
      npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
      npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
      npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
      npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
      npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
      npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
      npm warn deprecated q@1.5.1: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
      npm warn deprecated
      npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
      npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
      npm warn deprecated gauge@3.0.2: This package is no longer supported.
      npm warn deprecated gauge@4.0.4: This package is no longer supported.
      npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm warn deprecated gauge@2.7.4: This package is no longer supported.
      npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm warn deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
      changed 1848 packages in 3m
      205 packages are looking for funding
        run `npm fund` for details
      Aber:
      Ist das normal?
      • G George_Best
        npm warn deprecated
        Aber:
        Ist das normal?
        @george_best sagte in iob fix und iob diag ohne Reaktion:
        Ist das normal?
        Bei dem strubbeligen npm-Tree kann das normal sein.
          Ist das normal?
          George_Best
          npm ls:
          iobroker.inst@2.0.2 /opt/iobroker
          ├── @iobroker-javascript.0/moment-parseformat@npm:moment-parseformat@4.0.0
          ├── @iobroker-javascript.0/moment@npm:moment@2.30.1
          ├── colors@1.4.0
          ├── fs-extra@7.0.1
          ├── iobroker.accuweather@2.1.1
          ├── iobroker.admin@7.7.19
          ├── iobroker.alias-manager@2.0.0
          ├── iobroker.amazon-dash@1.2.0
          ├── iobroker.chromecast@4.0.0
          ├── iobroker.cloud@5.0.1
          ├── iobroker.daswetter@3.2.3
          ├── iobroker.deconz@1.6.4
          ├── iobroker.devices@1.2.8
          ├── iobroker.discovery@5.0.0
          ├── iobroker.email@2.0.4
          ├── iobroker.flot@1.12.0
          ├── iobroker.fronius-solarweb@0.0.3
          ├── iobroker.fronius@2.1.1
          ├── iobroker.frontier_silicon@0.5.0
          ├── iobroker.habpanel@0.5.0
          ├── iobroker.history@3.0.1
          ├── iobroker.hm-rega@5.1.0
          ├── iobroker.hm-rpc@2.0.2
          ├── iobroker.hs100@3.0.5
          ├── iobroker.icons-addictive-flavour-png@0.1.0
          ├── iobroker.icons-fatcow-hosting@0.1.0
          ├── iobroker.icons-icons8@0.0.1
          ├── iobroker.icons-material-png@0.1.0
          ├── iobroker.icons-material-svg@0.1.0
          ├── iobroker.icons-mfd-png@1.2.1
          ├── iobroker.icons-mfd-svg@1.2.0
          ├── iobroker.icons-open-icon-library-png@0.1.2
          ├── iobroker.icons-ultimate-png@1.0.1
          ├── iobroker.influxdb@4.0.2
          ├── iobroker.info@2.0.0
          ├── iobroker.iot@5.0.7
          ├── iobroker.javascript@8.9.2
          ├── iobroker.js-controller@7.0.7
          ├── iobroker.mihome-vacuum@5.2.0
          ├── iobroker.mqtt@6.1.4
          ├── iobroker.net-tools@1.1.2
          ├── iobroker.octoprint@5.1.0
          ├── iobroker.openweathermap@1.1.2
          ├── iobroker.parser@2.2.4
          ├── iobroker.ping@1.6.2
          ├── iobroker.proxmox@2.4.0
          ├── iobroker.radar@1.2.1
          ├── iobroker.radar2@2.4.0
          ├── iobroker.reolink@1.2.3
          ├── iobroker.rickshaw@1.0.0
          ├── iobroker.s7@1.5.0
          ├── iobroker.sayit@5.0.0
          ├── iobroker.smartmeter@3.4.0
          ├── iobroker.socketio@6.7.1
          ├── iobroker.sql@3.0.1
          ├── iobroker.statistics@2.4.0
          ├── iobroker.systeminfo@1.3.0
          ├── iobroker.telegram@4.1.0
          ├── iobroker.terminal@1.0.0
          ├── iobroker.tr-064@4.3.0
          ├── iobroker.unifi@0.7.0
          ├── iobroker.upnp@1.1.0
          ├── iobroker.vis-2-widgets-inventwo@0.2.2
          ├── iobroker.vis-2-widgets-material@1.4.10
          ├── iobroker.vis-2@2.13.4
          ├── iobroker.vis-bars@0.1.4
          ├── iobroker.vis-canvas-gauges@1.0.1
          ├── iobroker.vis-colorpicker@2.0.3
          ├── iobroker.vis-fancyswitch@1.1.0
          ├── iobroker.vis-google-fonts@1.0.4
          ├── iobroker.vis-history@1.0.0
          ├── iobroker.vis-hqwidgets@1.5.1
          ├── iobroker.vis-jqui-mfd@1.1.1
          ├── iobroker.vis-justgage@2.1.7
          ├── iobroker.vis-keyboard@0.0.2
          ├── iobroker.vis-lcars@1.1.1
          ├── iobroker.vis-map@1.1.2
          ├── iobroker.vis-materialdesign@0.5.9
          ├── iobroker.vis-metro@1.2.0
          ├── iobroker.vis-rgraph@0.0.2
          ├── iobroker.vis-weather@2.5.12
          ├── iobroker.vis@1.5.6
          ├── iobroker.weatherunderground@3.7.0
          ├── iobroker.web@7.0.8
          ├── iobroker.ws@2.6.2
          ├── iobroker@2.0.3
          ├── semver@5.7.2
          └── yargs@7.1.2
          npm ls graceful-fs
          ├── colors@1.4.0
          ├── fs-extra@7.0.1
          ├── iobroker@2.0.3
          ├── semver@5.7.2
          └── yargs@7.1.2
          ├─┬ fs-extra@7.0.1
          │ ├── graceful-fs@4.2.11
          │ └─┬ jsonfile@4.0.0
          │   └── graceful-fs@4.2.11 deduped
          ├─┬ iobroker.admin@7.7.19
          │ └─┬ archiver@7.0.1
          │   └─┬ archiver-utils@5.0.2
          ├─┬ iobroker.js-controller@7.0.7
          │ ├─┬ @iobroker/db-objects-file@7.0.7
          │ │ ├─┬ @iobroker/db-base@7.0.7
          │ │ │ └─┬ fs-extra@11.3.2
          │ │ │   ├── graceful-fs@4.2.11 deduped
          │ │ │   └─┬ jsonfile@6.2.0
          │ │ │     └── graceful-fs@4.2.11 deduped
          │ ├─┬ @iobroker/db-objects-jsonl@7.0.7
          │ │ ├─┬ @alcalzone/jsonl-db@3.1.1
          │ │ │ ├─┬ @alcalzone/proper-lockfile@4.1.3-0
          │ │ │ │ └── graceful-fs@4.2.11 deduped
          │ │ │ └─┬ fs-extra@10.1.0
          │ ├─┬ @iobroker/js-controller-adapter@7.0.7
          │ │ ├─┬ @alcalzone/pak@0.8.1
          │ ├─┬ @iobroker/js-controller-cli@7.0.7
          │ ├─┬ @iobroker/js-controller-common-db@7.0.7
          │ ├─┬ @iobroker/js-controller-common@7.0.7
          ├─┬ iobroker.radar@1.2.1
          │ └─┬ @abandonware/noble@1.9.2-26
          │   └─┬ @abandonware/bluetooth-hci-socket@0.5.3-12
          │     └─┬ node-gyp@10.3.1
          ├─┬ iobroker.radar2@2.4.0
          │ └─┬ @stoprocent/noble@1.19.1
          │   └─┬ @stoprocent/bluetooth-hci-socket@1.5.2
          │     └─┬ patch-package@8.0.1
          │       ├─┬ fs-extra@10.1.0
          │       └─┬ klaw-sync@6.0.0
          ├─┬ iobroker.sql@3.0.1
          │ └─┬ sqlite3@5.1.7
          │   └─┬ node-gyp@8.4.1
          ├─┬ iobroker.vis-map@1.1.2
          │ └─┬ @iobroker/dev-server@0.7.8
          │   ├─┬ @iobroker/testing@5.2.2
          │   ├─┬ browser-sync@3.0.4
          │   │ └─┬ fs-extra@3.0.1
          │   │   └─┬ jsonfile@3.0.1
          └─┬ yargs@7.1.2
            └─┬ read-pkg-up@1.0.1
              └─┬ read-pkg@1.1.0
                ├─┬ load-json-file@1.1.0
                └─┬ path-type@1.1.0
          Jetzt sieht es auf einmal wieder gut aus, oder?
          G Thomas BraunT 2 Antworten Letzte Antwort
          • G George_Best
            npm ls:
            ├── colors@1.4.0
            ├── fs-extra@7.0.1
            ├── iobroker@2.0.3
            ├── semver@5.7.2
            └── yargs@7.1.2
            npm ls graceful-fs
            ├── colors@1.4.0
            ├── fs-extra@7.0.1
            ├── iobroker@2.0.3
            ├── semver@5.7.2
            └── yargs@7.1.2
            ├─┬ fs-extra@7.0.1
            │ └─┬ sqlite3@5.1.7
            └─┬ yargs@7.1.2
                └─┬ read-pkg@1.1.0
                  └─┬ path-type@1.1.0
            George_Best
            und zack... iobroker ist wieder weg..
            jonny@ioBroker-V2:/opt/iobroker$ iob status
            node:internal/modules/cjs/loader:1386
              throw err;
            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                at Function._load (node:internal/modules/cjs/loader:1192:37)
                at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:171:5)
                at node:internal/main/run_main_module:36:49 {
              code: 'MODULE_NOT_FOUND',
              requireStack: []
            Node.js v22.21.0
            • G Offline
              George_Best
              Es scheint (lt. Logs) immer bei diesem Eintrag los zugehen:
              2025-11-12 16:16:29.213  - error: host.ioBroker-V2 Error: Could not determine controller directory
                  at getControllerDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1833:11)
                  at Module.getPidsFileName (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:3368:22)
                  at Timeout._onTimeout (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:2871:91)
                  at listOnTimeout (node:internal/timers:581:17)
                  at processTimers (node:internal/timers:519:7)
              Davor fangen scheinbar alle Adapter an neu starten - oder was auch immer...
              z.B.
              2025-11-12 16:16:24.689  - error: hm-rpc.0 (8741) hm-rpc.0 already running
              2025-11-12 16:16:24.691  - warn: hm-rpc.0 (8741) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
              Ich bin leider völlig ratlos...
              • G Offline
                George_Best
                Das "Adapter Requested Termintation" ist doch seltsam:
                2025-11-12 16:32:31.619  - info: discovery.0 (15882) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2025-11-12 16:32:31.616  - info: hm-rpc.1 (15825) xmlrpc -> 192.168.178.155:2010/ init ["http://192.168.178.121:2010",""]
                2025-11-12 16:32:31.649  - info: hm-rpc.1 (15825) Disconnected
                2025-11-12 16:32:31.649  - info: hm-rpc.1 (15825) terminating
                2025-11-12 16:32:31.650  - info: hm-rpc.1 (15825) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2025-11-12 16:32:31.562  - info: hm-rpc.0 (14348) xmlrpc -> 192.168.178.155:2001/ init ["http://192.168.178.121:2001",""]
                2025-11-12 16:32:31.571  - info: hm-rpc.0 (14348) Disconnected
                2025-11-12 16:32:31.572  - info: hm-rpc.0 (14348) terminating
                2025-11-12 16:32:31.572  - info: hm-rpc.0 (14348) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2025-11-12 16:32:31.685  - info: host.ioBroker-V2 stopInstance system.adapter.admin.0 send kill signal
                2025-11-12 16:32:31.725  - info: host.ioBroker-V2 stopInstance system.adapter.javascript.0 send kill signal
                2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.javascript.1 send kill signal
                2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.email.0 send kill signal
                2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.telegram.0 send kill signal
                2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.s7.0 send kill signal
                2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.s7.1 send kill signal
                oder
                2025-11-12 16:54:15.882  - info: admin.0 (20463) Got terminate signal TERMINATE_YOURSELF
                2025-11-12 16:54:15.882  - info: javascript.0 (20529) Got terminate signal TERMINATE_YOURSELF
                2025-11-12 16:54:15.883  - info: telegram.0 (20605) Got terminate signal TERMINATE_YOURSELF
                2025-11-12 16:54:15.884  - info: javascript.0 (20529) terminating
                2025-11-12 16:54:15.885  - info: javascript.0 (20529) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2025-11-12 16:54:15.884  - info: s7.1 (20635) Got terminate signal TERMINATE_YOURSELF
                2025-11-12 16:54:15.885  - info: s7.0 (20620) Got terminate signal TERMINATE_YOURSELF
                2025-11-12 16:54:15.883  - info: admin.0 (20463) terminating https server on port 8081
                2025-11-12 16:54:15.884  - info: admin.0 (20463) terminating
                2025-11-12 16:54:15.885  - info: admin.0 (20463) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                Das ist vermutlich der Grund für die Abstürze?
                Anbei mal der komplette Log
                iobroker.2025-11-12.log
                • G Offline
                  George_Best
                  Neuer Versuch - und wieder:
                  2025-11-12 17:36:08.400  - info: web.0 (28941) starting. Version 7.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v22.21.0, js-controller: 7.0.7
                  2025-11-12 17:36:08.571  - info: web.0 (28941) socket.io server listening on port 8082
                  2025-11-12 17:36:08.572  - info: web.0 (28941) Connecting extension "habpanel/lib/habpanelapi.js"
                  2025-11-12 17:36:08.572  - info: web.0 (28941) habpanel server listening on port 8082
                  2025-11-12 17:36:08.573  - info: web.0 (28941) habpanel web extension - Install extension on /rest/habpanel/
                  2025-11-12 17:36:08.575  - info: web.0 (28941) http server listening on port 8082
                  2025-11-12 17:36:10.873  - error: host.ioBroker-V2 uncaught exception: Could not determine controller directory
                  2025-11-12 17:36:10.873  - error: host.ioBroker-V2 Error: Could not determine controller directory
                      at Module.getAdapterDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1306:37)
                      at startInstance (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:3219:30)
                  Es scheint fast so, als wird immer der js-controller gekillt....
                  Hat jemand eine Idee wie ich das lösen kann?
                  • G George_Best
                    @thomas-braun sagte in iob fix und iob diag ohne Reaktion:
                    @george_best
                    Das Betriebssystem aber nicht.
                    Ich befürchte ich habe das gleiche Problem wie hier: https://forum.iobroker.net/topic/81185/system-admin-upgrade-exited-with-code-25-start-schleife/60
                    1. Betriebssystem habe ich nun geupdatet
                    2. iob fix gemacht
                    library: loaded
                    Library version=2025-08-09
                        Welcome to the ioBroker installation fixer!
                        Script version: 2025-08-09
                        You might need to enter your password a couple of times.
                        Installing prerequisites (1/5)
                    OK:1 http://deb.debian.org/debian bookworm InRelease
                    OK:2 http://deb.debian.org/debian bookworm-updates InRelease
                    OK:3 http://deb.debian.org/debian-security bookworm-security InRelease
                    OK:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                        Checking ioBroker user and directory permissions (2/5)
                        Check and cleanup npm temporary directories (3/5)
                    Done.
                        Database maintenance (4/5)
                    Checking for uncompressed JSONL databases... This might take a while!
                    Compressing /opt/iobroker/iobroker-data/states.jsonl
                    Compressing /opt/iobroker/iobroker-data/objects.jsonl
                    Compressed 2 JSONL files. Done
                        Checking autostart (5/5)
                    ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
                    Legitimierung ist zum Stoppen von »iobroker.service« notwendig.
                    Authenticating as: jonny,,, (jonny)
                    Password:
                    ==== AUTHENTICATION COMPLETE ====
                    Enabling autostart...
                    Autostart enabled!
                        Your installation was fixed successfully
                        Run iobroker start to start ioBroker again!
                    1. iob diag sagt:
                    ```bash
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                     Static hostname: ioBroker-V2
                           Icon name: computer-vm
                             Chassis: vm 🖴
                      Virtualization: kvm
                              Kernel: Linux 6.1.0-41-amd64
                        Architecture: x86-64
                     Hardware Vendor: QEMU
                      Hardware Model: Standard PC _i440FX + PIIX, 1996_
                    Firmware Version: rel-1.16.1-0-g3208b098f51a-prebuilt.qemu.org
                    OS is similar to:
                    model name      : Common KVM processor
                    Docker          : false
                    Virtualization  : kvm
                    Kernel          : x86_64
                    Userland        : 64 bit
                    Systemuptime and Load:
                     16:30:54 up 29 min,  2 users,  load average: 0.64, 0.37, 0.62
                    CPU threads: 8
                    *** LIFE CYCLE STATUS ***
                    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                    *** TIME AND TIMEZONES ***
                                   Local time: Wed 2025-11-12 16:30:54 CET
                               Universal time: Wed 2025-11-12 15:30:54 UTC
                                     RTC time: Wed 2025-11-12 15:30:54
                                  NTP service: active
                              RTC in local TZ: no
                    *** Users and Groups ***
                    User that called 'iob diag':
                    jonny
                    HOME=/home/jonny
                    GROUPS=jonny adm cdrom floppy sudo audio dip video plugdev systemd-journal netdev iobroker
                    iobroker
                    HOME=/home/iobroker
                    GROUPS=iobroker tty dialout audio video plugdev bluetooth
                    *** DISPLAY-SERVER SETUP ***
                    Display-Server:         false
                    Unit display-manager.service could not be found.
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Mem:             12G        1.9G        8.1G        561K        2.5G         10G
                    Swap:           4.3G          0B        4.3G
                    Total:           16G        1.9G         12G
                    Active iob-Instances:   6
                            11644 M total memory
                             1812 M used memory
                             1465 M active memory
                             1926 M inactive memory
                             7764 M free memory
                              343 M buffer memory
                             2036 M swap cache
                             4093 M total swap
                                0 M used swap
                             4093 M free swap
                    top - 16:30:55 up 29 min,  2 users,  load average: 0.64, 0.37, 0.62
                    Tasks: 124 total,   1 running, 123 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :  11644.7 total,   7765.0 free,   1812.8 used,   2380.2 buff/cache
                    MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.   9831.8 avail Mem
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** DMESG CRITICAL ERRORS ***
                    No critical errors detected
                    *** FILESYSTEM ***
                    udev           devtmpfs  5.7G     0  5.7G   0% /dev
                    tmpfs          tmpfs     1.2G  548K  1.2G   1% /run
                    /dev/sda1      ext4       28G   11G   16G  40% /
                    tmpfs          tmpfs     5.7G     0  5.7G   0% /dev/shm
                    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                    tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
                    [Wed Nov 12 16:01:54 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                    [Wed Nov 12 16:01:54 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
                    Show mounted filesystems:
                    TARGET SOURCE    FSTYPE OPTIONS
                    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                    /var:
                    1.9G    /var/
                    889M    /var/cache
                    870M    /var/cache/apt
                    805M    /var/log
                    793M    /var/cache/apt/archives
                    Archived and active journals take up 782.1M in the file system.
                    /opt/iobroker/backups:
                    22M     /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    676M    /opt/iobroker/iobroker-data/
                    450M    /opt/iobroker/iobroker-data/files
                    166M    /opt/iobroker/iobroker-data/backup-objects
                    81M     /opt/iobroker/iobroker-data/files/vis
                    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                    25M     /opt/iobroker/iobroker-data/objects.jsonl
                    12M     /opt/iobroker/iobroker-data/objects.json.migrated
                    12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
                    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                    USB-Devices by-id:
                    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2195735-if00
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v22.21.0
                    /usr/bin/node           v22.21.0
                    /usr/bin/npm            10.9.4
                    /usr/bin/npx            10.9.4
                    /usr/bin/corepack       0.34.0
                    nodejs:
                      Installed: 22.21.0-1nodesource1
                      Candidate: 22.21.0-1nodesource1
                      Version table:
                     *** 22.21.0-1nodesource1 1001
                         22.20.0-1nodesource1 1001
                         22.19.0-1nodesource1 1001
                         22.18.0-1nodesource1 1001
                         22.17.1-1nodesource1 1001
                         22.17.0-1nodesource1 1001
                         22.16.0-1nodesource1 1001
                         22.15.1-1nodesource1 1001
                         22.15.0-1nodesource1 1001
                         22.14.0-1nodesource1 1001
                         22.13.1-1nodesource1 1001
                         22.13.0-1nodesource1 1001
                         22.12.0-1nodesource1 1001
                         22.11.0-1nodesource1 1001
                         22.10.0-1nodesource1 1001
                         22.9.0-1nodesource1 1001
                         22.8.0-1nodesource1 1001
                         22.7.0-1nodesource1 1001
                         22.6.0-1nodesource1 1001
                         22.5.1-1nodesource1 1001
                         22.5.0-1nodesource1 1001
                         22.4.1-1nodesource1 1001
                         22.4.0-1nodesource1 1001
                         22.3.0-1nodesource1 1001
                         22.2.0-1nodesource1 1001
                         22.1.0-1nodesource1 1001
                         22.0.0-1nodesource1 1001
                         18.20.4+dfsg-1~deb12u1 500
                            500 http://deb.debian.org/debian bookworm/main amd64 Packages
                            500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                    No problems detected
                    Errors in npm tree: 0
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    ioBroker-V2         ioBroker-V2 (version: 7.0.7, hostname: ioBroker-V2   , alive, uptime: 32)
                    Core adapters versions
                    admin:          7.7.19
                    javascript:     8.9.2
                    nodejs modules from github:     2
                    |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
                    | +-- tplink-smarthome-api@5.0.0 invalid: "https://github.com/arteck/tplink-smarthome-api/tarball/08bcca9334c701b60d1eeb18b0ec72350aa3bf7a" from node_modules/iobroker.hs100
                    Adapter State
                      system.adapter.accuweather.0            : accuweather           : ioBroker-V2                              -  enabled
                    + system.adapter.admin.0                  : admin                 : ioBroker-V2                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                      system.adapter.alias-manager.0          : alias-manager         : ioBroker-V2                              -  enabled
                      system.adapter.amazon-dash.0            : amazon-dash           : ioBroker-V2                              - disabled
                      system.adapter.chromecast.0             : chromecast            : ioBroker-V2                              -  enabled
                      system.adapter.cloud.0                  : cloud                 : ioBroker-V2                              - disabled
                      system.adapter.daswetter.0              : daswetter             : ioBroker-V2                              -  enabled
                      system.adapter.deconz.0                 : deconz                : ioBroker-V2                              - disabled, port: 80
                      system.adapter.devices.0                : devices               : ioBroker-V2                              -  enabled
                      system.adapter.discovery.0              : discovery             : ioBroker-V2                              -  enabled
                    + system.adapter.email.0                  : email                 : ioBroker-V2                              -  enabled
                      system.adapter.flot.0                   : flot                  : ioBroker-V2                              -  enabled
                      system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker-V2                              -  enabled
                      system.adapter.fronius.0                : fronius               : ioBroker-V2                              -  enabled
                      system.adapter.frontier_silicon.0       : frontier_silicon      : ioBroker-V2                              -  enabled
                      system.adapter.habpanel.0               : habpanel              : ioBroker-V2                              -  enabled
                      system.adapter.history.0                : history               : ioBroker-V2                              -  enabled
                      system.adapter.hm-rega.0                : hm-rega               : ioBroker-V2                              -  enabled
                      system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-V2                              -  enabled, port: 0
                      system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-V2                              -  enabled, port: 0
                      system.adapter.hs100.0                  : hs100                 : ioBroker-V2                              -  enabled
                      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker-V2                              -  enabled
                      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker-V2                              -  enabled
                      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-V2                              -  enabled
                      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-V2                              -  enabled
                      system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker-V2                              -  enabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-V2                              -  enabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-V2                              -  enabled
                      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker-V2                              -  enabled
                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-V2                              -  enabled
                      system.adapter.influxdb.0               : influxdb              : ioBroker-V2                              - disabled, port: 8086
                      system.adapter.influxdb.1               : influxdb              : ioBroker-V2                              - disabled, port: 8086
                      system.adapter.info.0                   : info                  : ioBroker-V2                              -  enabled
                      system.adapter.iot.0                    : iot                   : ioBroker-V2                              -  enabled
                    + system.adapter.javascript.0             : javascript            : ioBroker-V2                              -  enabled
                    + system.adapter.javascript.1             : javascript            : ioBroker-V2                              -  enabled
                      system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-V2                              - disabled, port: 54321
                      system.adapter.mqtt.0                   : mqtt                  : ioBroker-V2                              -  enabled, port: 1883, bind: 192.168.178.121
                      system.adapter.net-tools.0              : net-tools             : ioBroker-V2                              - disabled
                      system.adapter.net-tools.1              : net-tools             : ioBroker-V2                              -  enabled
                      system.adapter.octoprint.0              : octoprint             : ioBroker-V2                              -  enabled
                      system.adapter.parser.0                 : parser                : ioBroker-V2                              -  enabled
                      system.adapter.ping.0                   : ping                  : ioBroker-V2                              - disabled
                      system.adapter.proxmox.0                : proxmox               : ioBroker-V2                              -  enabled, port: 8006
                      system.adapter.radar.0                  : radar                 : ioBroker-V2                              - disabled
                      system.adapter.radar2.0                 : radar2                : ioBroker-V2                              - disabled
                      system.adapter.radar2.1                 : radar2                : ioBroker-V2                              -  enabled
                      system.adapter.reolink.0                : reolink               : ioBroker-V2                              -  enabled
                      system.adapter.reolink.1                : reolink               : ioBroker-V2                              -  enabled
                      system.adapter.rickshaw.0               : rickshaw              : ioBroker-V2                              -  enabled
                      system.adapter.s7.0                     : s7                    : ioBroker-V2                              -  enabled
                      system.adapter.s7.1                     : s7                    : ioBroker-V2                              -  enabled
                      system.adapter.s7.2                     : s7                    : ioBroker-V2                              -  enabled
                      system.adapter.sayit.0                  : sayit                 : ioBroker-V2                              -  enabled
                      system.adapter.sayit.1                  : sayit                 : ioBroker-V2                              -  enabled
                      system.adapter.sayit.2                  : sayit                 : ioBroker-V2                              -  enabled
                      system.adapter.simple-api.0             : simple-api            : ioBroker-V2                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      system.adapter.smartmeter.0             : smartmeter            : ioBroker-V2                              - disabled
                      system.adapter.smartmeter.2             : smartmeter            : ioBroker-V2                              - disabled
                      system.adapter.socketio.0               : socketio              : ioBroker-V2                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    + system.adapter.sql.0                    : sql                   : ioBroker-V2                              -  enabled, port: 3306
                      system.adapter.sql.1                    : sql                   : ioBroker-V2                              - disabled, port: 3306
                      system.adapter.statistics.0             : statistics            : ioBroker-V2                              -  enabled
                      system.adapter.systeminfo.0             : systeminfo            : ioBroker-V2                              - disabled
                      system.adapter.telegram.0               : telegram              : ioBroker-V2                              -  enabled, port: 8443, bind: 0.0.0.0
                      system.adapter.terminal.0               : terminal              : ioBroker-V2                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                      system.adapter.tr-064.0                 : tr-064                : ioBroker-V2                              -  enabled
                      system.adapter.unifi.0                  : unifi                 : ioBroker-V2                              -  enabled
                      system.adapter.upnp.0                   : upnp                  : ioBroker-V2                              -  enabled
                      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker-V2                              -  enabled
                      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker-V2                              -  enabled
                      system.adapter.vis-2.0                  : vis-2                 : ioBroker-V2                              -  enabled
                      system.adapter.vis-bars.0               : vis-bars              : ioBroker-V2                              -  enabled
                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-V2                              -  enabled
                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-V2                              -  enabled
                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-V2                              -  enabled
                      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker-V2                              -  enabled
                      system.adapter.vis-history.0            : vis-history           : ioBroker-V2                              -  enabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-V2                              -  enabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-V2                              -  enabled
                      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-V2                              -  enabled
                      system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-V2                              -  enabled
                      system.adapter.vis-lcars.0              : vis-lcars             : ioBroker-V2                              -  enabled
                      system.adapter.vis-map.0                : vis-map               : ioBroker-V2                              -  enabled
                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker-V2                              -  enabled
                      system.adapter.vis-metro.0              : vis-metro             : ioBroker-V2                              -  enabled
                      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-V2                              -  enabled
                      system.adapter.vis-weather.0            : vis-weather           : ioBroker-V2                              -  enabled
                      system.adapter.vis.0                    : vis                   : ioBroker-V2                              -  enabled
                      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker-V2                              -  enabled
                      system.adapter.web.0                    : web                   : ioBroker-V2                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Upgrade policy: none
                    Installed ioBroker-Adapters
                    Used repository: stable
                    Adapter    "accuweather"  : 2.1.1    , installed 2.1.1
                    Adapter    "admin"        : 7.7.19   , installed 7.7.19
                    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                    Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
                    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
                    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                    Adapter    "deconz"       : 1.6.4    , installed 1.6.4
                    Adapter    "devices"      : 1.2.8    , installed 1.2.8
                    Adapter    "email"        : 2.0.4    , installed 2.0.4
                    Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                    Adapter    "frontier_silicon": 0.5.0 , installed 0.5.0
                    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                    Adapter    "hs100"        : 3.0.5    , installed 3.0.5
                    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                    Adapter    "iot"          : 5.0.7    , installed 5.0.7
                    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                    Controller "js-controller": 7.0.7    , installed 7.0.7
                    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
                    Adapter    "net-tools"    : 1.1.2    , installed 1.1.2
                    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                    Adapter    "parser"       : 2.2.4    , installed 2.2.4
                    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                    Adapter    "radar2"       : 2.4.0    , installed 2.4.0
                    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
                    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
                    Adapter    "s7"           : 1.5.0    , installed 1.5.0
                    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                    Adapter    "sql"          : 3.0.1    , installed 3.0.1
                    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                    Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
                    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
                    Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
                    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                    Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
                    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                    Adapter    "web"          : 7.0.8    , installed 7.0.8
                    Objects and States
                    Objects:        24997
                    States:         20033
                    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                    Reading package lists...
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 192.168.178.121:2001    0.0.0.0:*               LISTEN      1001       66571      14348/io.hm-rpc.0
                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17410      736/exim4
                    tcp        0      0 192.168.178.121:1883    0.0.0.0:*               LISTEN      1001       61291      14044/io.mqtt.0
                    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       62504      12617/iobroker.js-c
                    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       59698      12617/iobroker.js-c
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15485      553/sshd: /usr/sbin
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       59780      12641/io.admin.0
                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17411      736/exim4
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          15487      553/sshd: /usr/sbin
                    udp        0      0 0.0.0.0:35015           0.0.0.0:*                           107        13947      440/avahi-daemon: r
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       65677      14275/io.chromecast
                    udp        0      0 192.168.178.121:5353    0.0.0.0:*                           1001       64680      14141/io.tr-064.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        13945      440/avahi-daemon: r
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13849      376/dhclient
                    udp6       0      0 :::36795                :::*                                107        13948      440/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                107        13946      440/avahi-daemon: r
                    2025-11-12 16:31:21.431  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] connected with secret 1762961481430_2245
                    2025-11-12 16:31:21.446  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] subscribes on "Wemos_DisplayV2_6/#" with regex /^Wemos_DisplayV2_6\..*/
                    2025-11-12 16:31:21.447  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] subscribes on "Wemos_DisplayV2_6/#"  with regex /^mqtt\.0\.Wemos_DisplayV2_6\..*/
                    2025-11-12 16:31:21.647  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] publishOnSubscribe send all known states
                    2025-11-12 16:31:22.266  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 1(Jonny-Pixel3/3C:28:6D:E8:64:45) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                    2025-11-12 16:31:22.409  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 2(Jenny-Pixel3a/58:CB:52:8E:4E:68) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                    2025-11-12 16:31:22.548  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 3(Jonny-Arbeit-A40/F0:8A:76:20:A8:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                    2025-11-12 16:31:22.766  - info: chromecast.0 (14275) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.chromecast, node: v22.21.0, js-controller: 7.0.7
                    2025-11-12 16:31:23.348  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 7(Pixel-3a/BA:DC:2D:6F:F1:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                    2025-11-12 16:31:23.407  - info: chromecast.0 (14275) Google_HomeKueche - Connected client
                    2025-11-12 16:31:23.438  - info: chromecast.0 (14275) Küche - Connected client
                    2025-11-12 16:31:23.905  - info: host.ioBroker-V2 instance system.adapter.hm-rpc.0 in version "2.0.2" started with pid 14348
                    2025-11-12 16:31:26.245  - info: hm-rpc.0 (14348) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v22.21.0, js-controller: 7.0.7
                    2025-11-12 16:31:26.463  - info: hm-rpc.0 (14348) xmlrpc server is trying to listen on 192.168.178.121:2001
                    2025-11-12 16:31:26.464  - info: hm-rpc.0 (14348) xmlrpc client is trying to connect to 192.168.178.155:2001/ with ["http://192.168.178.121:2001","ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
                    2025-11-12 16:31:26.492  - info: hm-rpc.0 (14348) xmlrpc <- system.listMethods ["ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
                    2025-11-12 16:31:26.498  - info: hm-rpc.0 (14348) xmlrpc <- listDevices ["ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
                    2025-11-12 16:31:26.528  - info: hm-rpc.0 (14348) xmlrpc -> 64 devices
                    2025-11-12 16:31:26.547  - info: hm-rpc.0 (14348) Connected
                    2025-11-12 16:31:27.831  - info: host.ioBroker-V2 instance system.adapter.hm-rega.0 in version "5.1.0" started with pid 14782
                    2025-11-12 16:31:30.487  - info: hm-rega.0 (14782) starting. Version 5.1.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v22.21.0, js-controller: 7.0.7
                    2025-11-12 16:31:30.694  - info: hm-rega.0 (14782) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                    2025-11-12 16:31:30.763  - info: hm-rega.0 (14782) ReGaHSS 192.168.178.155 up
                    2025-11-12 16:31:30.869  - info: hm-rega.0 (14782) time difference local-ccu 1s
                    2025-11-12 16:31:31.325  - info: hm-rega.0 (14782) request state values
                    Ro75R Offline
                    Ro75R Offline
                    Ro75
                    @george_best
                    Was ist das? Woher kommt das?
                    Ro75.
                    • Ro75R Ro75
                      @george_best
                      Ro75.
                      George_Best
                      @ro75
                      ersteres ist wohl vom hometmatic adapter
                      letzeres ist ein Adapter von TP-Link für smarte Steckdosen
                      Ro75R 1 Antwort Letzte Antwort
                      • G George_Best
                        @ro75
                        Ro75R Offline
                        Ro75R Offline
                        Ro75
                        @george_best mir geht es mehr um das "invalid"
                        Ro75.
                        • Ro75R Ro75
                          Ro75.
                          George_Best
                          @ro75
                          woher hast du die Zeilen genau?
                          Weil der npm-tree am Anfang war als der js-controller nicht mehr da war. Da war/ist so ziemlich alles auf "invalid"
                          • G George_Best
                            @ro75
                            Ro75R Offline
                            Ro75R Offline
                            Ro75
                            aus deinem iob diag log
                            Ro75.
                            • Ro75R Ro75
                              Ro75.
                              George_Best
                              @ro75
                              ok.
                              Adapter mal löschen? Neu installieren?
                              • G George_Best
                                @ro75
                                ok.
                                Ro75R Offline
                                Ro75R Offline
                                Ro75
                                @george_best keine Ahnung. Auf alle Fälle, die, die man nicht (mehr) braucht können auch weg. Weniger Last, weniger Probleme.
                                Ro75.
                                • G George_Best
                                  npm ls:
                                  ├── colors@1.4.0
                                  ├── fs-extra@7.0.1
                                  ├── iobroker@2.0.3
                                  ├── semver@5.7.2
                                  └── yargs@7.1.2
                                  npm ls graceful-fs
                                  ├── colors@1.4.0
                                  ├── fs-extra@7.0.1
                                  ├── iobroker@2.0.3
                                  ├── semver@5.7.2
                                  └── yargs@7.1.2
                                  ├─┬ fs-extra@7.0.1
                                  │ └─┬ sqlite3@5.1.7
                                  └─┬ yargs@7.1.2
                                      └─┬ read-pkg@1.1.0
                                        └─┬ path-type@1.1.0
                                  ├── semver@5.7.2
                                  ├── semver@5.7.2
                                  └── yargs@7.1.2
                                  ├─┬ fs-extra@7.0.1
                                  Die Stelle schau auch komisch aus...
                                  Bitte NICHT die LogInPrompts löschen und IMMER die vollständigen Ein- und Ausgaben posten. Man kann sich ohne die Dinger als Helfer nur schlecht durch die zusammenkopierten Ausgaben hangeln.
                                  • G Offline
                                    George_Best
                                    hm... es läuft nun schon einige Minuten stabil...
                                    Möglicherweise war es der HS100 Adapter
                                    Ro75R Thomas BraunT 2 Antworten Letzte Antwort
                                    • G George_Best
                                      Ro75R Offline
                                      Ro75R Offline
                                      Ro75
                                      @george_best der HS100 läuft bei mir. Installiere den, falls du den brauchst, einfach mal neu.
                                      Ro75.
                                      • G George_Best
                                        @george_best
                                        Du kannst auch mal schauen, was da passiert:
                                        cd /opt/iobroker && npm ci
                                        Wird was länger laufen, vermutlich.
                                          @george_best
                                          George_Best
                                          Ich glaube das sieht nicht gut aus:
                                          jonny@ioBroker-V2:/opt/iobroker$ cd /opt/iobroker && npm ci
                                          [sudo] Passwort für jonny:
                                          npm warn old lockfile
                                          npm warn old lockfile The package-lock.json file was created with an old version of npm,
                                          npm warn old lockfile so supplemental metadata must be fetched from the registry.
                                          npm warn old lockfile This is a one-time fix-up, please be patient...
                                          npm error code EUSAGE
                                          npm error
                                          npm error `npm ci` can only install packages when your package.json and package-lock.json or npm-shrinkwrap.json are in sync. Please update your lock file with `npm install` before continuing.
                                          npm error
                                          npm error Missing: @iobroker-javascript.0/moment@2.30.1 from lock file
                                          npm error Missing: @iobroker-javascript.0/moment-parseformat@4.0.0 from lock file
                                          npm error Missing: iobroker.accuweather@2.1.1 from lock file
                                          npm error Invalid: lock file's iobroker.admin@3.5.10 does not satisfy iobroker.admin@7.7.19
                                          npm error Missing: iobroker.alias-manager@2.0.0 from lock file
                                          npm error Missing: iobroker.amazon-dash@1.2.0 from lock file
                                          npm error Missing: iobroker.chromecast@4.0.0 from lock file
                                          npm error Missing: iobroker.cloud@5.0.1 from lock file
                                          npm error Missing: iobroker.daswetter@3.2.3 from lock file
                                          npm error Missing: iobroker.deconz@1.6.4 from lock file
                                          npm error Missing: iobroker.devices@1.2.8 from lock file
                                          npm error Invalid: lock file's iobroker.discovery@1.2.4 does not satisfy iobroker.discovery@5.0.0
                                          npm error Missing: iobroker.email@2.0.4 from lock file
                                          npm error Missing: iobroker.flot@1.12.0 from lock file
                                          npm error Missing: iobroker.fronius@2.1.1 from lock file
                                          npm error Missing: iobroker.fronius-solarweb@0.0.3 from lock file
                                          npm error Missing: iobroker.frontier_silicon@0.5.0 from lock file
                                          npm error Missing: iobroker.habpanel@0.5.0 from lock file
                                          npm error Missing: iobroker.history@3.0.1 from lock file
                                          npm error Missing: iobroker.hm-rega@5.1.0 from lock file
                                          npm error Missing: iobroker.hm-rpc@2.0.2 from lock file
                                          npm error Missing: iobroker.hs100@3.0.5 from lock file
                                          npm error Missing: iobroker.icons-addictive-flavour-png@0.1.0 from lock file
                                          npm error Missing: iobroker.icons-fatcow-hosting@0.1.0 from lock file
                                          npm error Missing: iobroker.icons-icons8@0.0.1 from lock file
                                          npm error Missing: iobroker.icons-material-png@0.1.0 from lock file
                                          npm error Missing: iobroker.icons-material-svg@0.1.0 from lock file
                                          npm error Missing: iobroker.icons-mfd-png@1.2.1 from lock file
                                          npm error Missing: iobroker.icons-mfd-svg@1.2.0 from lock file
                                          npm error Missing: iobroker.icons-open-icon-library-png@0.1.2 from lock file
                                          npm error Missing: iobroker.icons-ultimate-png@1.0.1 from lock file
                                          npm error Missing: iobroker.influxdb@4.0.2 from lock file
                                          npm error Missing: iobroker.info@2.0.0 from lock file
                                          npm error Missing: iobroker.iot@5.0.7 from lock file
                                          npm error Missing: iobroker.javascript@8.9.2 from lock file
                                          npm error Invalid: lock file's iobroker.js-controller@1.4.2 does not satisfy iobroker.js-controller@7.0.7
                                          npm error Missing: iobroker.mihome-vacuum@5.2.0 from lock file
                                          ==> weitere ist im file.2025-11-12T17_36_48_294Z-debug-0.log
                                          Oder hätte ich iobroker vorher stoppen sollen?
