  4. iob fix und iob diag ohne Reaktion
    6.4k
94 Beiträge 8 Kommentatoren 12.8k Aufrufe 4 Beobachtet
  • G Offline
    George_Best
    Das "Adapter Requested Termintation" ist doch seltsam:
    2025-11-12 16:32:31.619  - info: discovery.0 (15882) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-11-12 16:32:31.616  - info: hm-rpc.1 (15825) xmlrpc -> 192.168.178.155:2010/ init ["http://192.168.178.121:2010",""]
    2025-11-12 16:32:31.649  - info: hm-rpc.1 (15825) Disconnected
    2025-11-12 16:32:31.649  - info: hm-rpc.1 (15825) terminating
    2025-11-12 16:32:31.650  - info: hm-rpc.1 (15825) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-11-12 16:32:31.562  - info: hm-rpc.0 (14348) xmlrpc -> 192.168.178.155:2001/ init ["http://192.168.178.121:2001",""]
    2025-11-12 16:32:31.571  - info: hm-rpc.0 (14348) Disconnected
    2025-11-12 16:32:31.572  - info: hm-rpc.0 (14348) terminating
    2025-11-12 16:32:31.572  - info: hm-rpc.0 (14348) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-11-12 16:32:31.685  - info: host.ioBroker-V2 stopInstance system.adapter.admin.0 send kill signal
    2025-11-12 16:32:31.725  - info: host.ioBroker-V2 stopInstance system.adapter.javascript.0 send kill signal
    2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.javascript.1 send kill signal
    2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.email.0 send kill signal
    2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.telegram.0 send kill signal
    2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.s7.0 send kill signal
    2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.s7.1 send kill signal
    oder
    2025-11-12 16:54:15.882  - info: admin.0 (20463) Got terminate signal TERMINATE_YOURSELF
    2025-11-12 16:54:15.882  - info: javascript.0 (20529) Got terminate signal TERMINATE_YOURSELF
    2025-11-12 16:54:15.883  - info: telegram.0 (20605) Got terminate signal TERMINATE_YOURSELF
    2025-11-12 16:54:15.884  - info: javascript.0 (20529) terminating
    2025-11-12 16:54:15.885  - info: javascript.0 (20529) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-11-12 16:54:15.884  - info: s7.1 (20635) Got terminate signal TERMINATE_YOURSELF
    2025-11-12 16:54:15.885  - info: s7.0 (20620) Got terminate signal TERMINATE_YOURSELF
    2025-11-12 16:54:15.883  - info: admin.0 (20463) terminating https server on port 8081
    2025-11-12 16:54:15.884  - info: admin.0 (20463) terminating
    2025-11-12 16:54:15.885  - info: admin.0 (20463) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    Das ist vermutlich der Grund für die Abstürze?
    Anbei mal der komplette Log
    iobroker.2025-11-12.log
    • G Offline
      George_Best
      Neuer Versuch - und wieder:
      2025-11-12 17:36:08.400  - info: web.0 (28941) starting. Version 7.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v22.21.0, js-controller: 7.0.7
      2025-11-12 17:36:08.571  - info: web.0 (28941) socket.io server listening on port 8082
      2025-11-12 17:36:08.572  - info: web.0 (28941) Connecting extension "habpanel/lib/habpanelapi.js"
      2025-11-12 17:36:08.572  - info: web.0 (28941) habpanel server listening on port 8082
      2025-11-12 17:36:08.573  - info: web.0 (28941) habpanel web extension - Install extension on /rest/habpanel/
      2025-11-12 17:36:08.575  - info: web.0 (28941) http server listening on port 8082
      2025-11-12 17:36:10.873  - error: host.ioBroker-V2 uncaught exception: Could not determine controller directory
      2025-11-12 17:36:10.873  - error: host.ioBroker-V2 Error: Could not determine controller directory
          at getControllerDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1833:11)
          at Module.getAdapterDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1306:37)
          at startInstance (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:3219:30)
      Es scheint fast so, als wird immer der js-controller gekillt....
      Hat jemand eine Idee wie ich das lösen kann?
      • G George_Best
        @thomas-braun sagte in iob fix und iob diag ohne Reaktion:
        @george_best
        Das Betriebssystem aber nicht.
        Ich befürchte ich habe das gleiche Problem wie hier: https://forum.iobroker.net/topic/81185/system-admin-upgrade-exited-with-code-25-start-schleife/60
        1. Betriebssystem habe ich nun geupdatet
        2. iob fix gemacht
        library: loaded
        Library version=2025-08-09
            Welcome to the ioBroker installation fixer!
            Script version: 2025-08-09
            You might need to enter your password a couple of times.
            Installing prerequisites (1/5)
        OK:1 http://deb.debian.org/debian bookworm InRelease
        OK:2 http://deb.debian.org/debian bookworm-updates InRelease
        OK:3 http://deb.debian.org/debian-security bookworm-security InRelease
        OK:4 https://deb.nodesource.com/node_22.x nodistro InRelease
            Checking ioBroker user and directory permissions (2/5)
            Check and cleanup npm temporary directories (3/5)
        Done.
            Database maintenance (4/5)
        Checking for uncompressed JSONL databases... This might take a while!
        Compressing /opt/iobroker/iobroker-data/states.jsonl
        Compressing /opt/iobroker/iobroker-data/objects.jsonl
        Compressed 2 JSONL files. Done
            Checking autostart (5/5)
        ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
        Legitimierung ist zum Stoppen von »iobroker.service« notwendig.
        Authenticating as: jonny,,, (jonny)
        Password:
        ==== AUTHENTICATION COMPLETE ====
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        1. iob diag sagt:
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
         Static hostname: ioBroker-V2
               Icon name: computer-vm
                 Chassis: vm 🖴
          Virtualization: kvm
                  Kernel: Linux 6.1.0-41-amd64
            Architecture: x86-64
         Hardware Vendor: QEMU
          Hardware Model: Standard PC _i440FX + PIIX, 1996_
        Firmware Version: rel-1.16.1-0-g3208b098f51a-prebuilt.qemu.org
        OS is similar to:
        model name      : Common KVM processor
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         16:30:54 up 29 min,  2 users,  load average: 0.64, 0.37, 0.62
        CPU threads: 8
        *** LIFE CYCLE STATUS ***
        Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
        *** TIME AND TIMEZONES ***
                       Local time: Wed 2025-11-12 16:30:54 CET
                   Universal time: Wed 2025-11-12 15:30:54 UTC
                         RTC time: Wed 2025-11-12 15:30:54
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        jonny
        HOME=/home/jonny
        GROUPS=jonny adm cdrom floppy sudo audio dip video plugdev systemd-journal netdev iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         false
        Unit display-manager.service could not be found.
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Mem:             12G        1.9G        8.1G        561K        2.5G         10G
        Swap:           4.3G          0B        4.3G
        Total:           16G        1.9G         12G
        Active iob-Instances:   6
                11644 M total memory
                 1812 M used memory
                 1465 M active memory
                 1926 M inactive memory
                 7764 M free memory
                  343 M buffer memory
                 2036 M swap cache
                 4093 M total swap
                    0 M used swap
                 4093 M free swap
        top - 16:30:55 up 29 min,  2 users,  load average: 0.64, 0.37, 0.62
        Tasks: 124 total,   1 running, 123 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  11644.7 total,   7765.0 free,   1812.8 used,   2380.2 buff/cache
        MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.   9831.8 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  5.7G     0  5.7G   0% /dev
        tmpfs          tmpfs     1.2G  548K  1.2G   1% /run
        /dev/sda1      ext4       28G   11G   16G  40% /
        tmpfs          tmpfs     5.7G     0  5.7G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
        [Wed Nov 12 16:01:54 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
        [Wed Nov 12 16:01:54 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        1.9G    /var/
        889M    /var/cache
        870M    /var/cache/apt
        805M    /var/log
        793M    /var/cache/apt/archives
        Archived and active journals take up 782.1M in the file system.
        /opt/iobroker/backups:
        22M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        676M    /opt/iobroker/iobroker-data/
        450M    /opt/iobroker/iobroker-data/files
        166M    /opt/iobroker/iobroker-data/backup-objects
        81M     /opt/iobroker/iobroker-data/files/vis
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        25M     /opt/iobroker/iobroker-data/objects.jsonl
        12M     /opt/iobroker/iobroker-data/objects.json.migrated
        12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
        4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2195735-if00
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v22.21.0
        /usr/bin/node           v22.21.0
        /usr/bin/npm            10.9.4
        /usr/bin/npx            10.9.4
        /usr/bin/corepack       0.34.0
        nodejs:
          Installed: 22.21.0-1nodesource1
          Candidate: 22.21.0-1nodesource1
          Version table:
         *** 22.21.0-1nodesource1 1001
             22.20.0-1nodesource1 1001
             22.19.0-1nodesource1 1001
             22.18.0-1nodesource1 1001
             22.17.1-1nodesource1 1001
             22.17.0-1nodesource1 1001
             22.16.0-1nodesource1 1001
             22.15.1-1nodesource1 1001
             22.15.0-1nodesource1 1001
             22.14.0-1nodesource1 1001
             22.13.1-1nodesource1 1001
             22.13.0-1nodesource1 1001
             22.12.0-1nodesource1 1001
             22.11.0-1nodesource1 1001
             22.10.0-1nodesource1 1001
             22.9.0-1nodesource1 1001
             22.8.0-1nodesource1 1001
             22.7.0-1nodesource1 1001
             22.6.0-1nodesource1 1001
             22.5.1-1nodesource1 1001
             22.5.0-1nodesource1 1001
             22.4.1-1nodesource1 1001
             22.4.0-1nodesource1 1001
             22.3.0-1nodesource1 1001
             22.2.0-1nodesource1 1001
             22.1.0-1nodesource1 1001
             22.0.0-1nodesource1 1001
             18.20.4+dfsg-1~deb12u1 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
                500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        ioBroker-V2         ioBroker-V2 (version: 7.0.7, hostname: ioBroker-V2   , alive, uptime: 32)
        Core adapters versions
        admin:          7.7.19
        javascript:     8.9.2
        nodejs modules from github:     2
        |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
        | +-- tplink-smarthome-api@5.0.0 invalid: "https://github.com/arteck/tplink-smarthome-api/tarball/08bcca9334c701b60d1eeb18b0ec72350aa3bf7a" from node_modules/iobroker.hs100
        Adapter State
          system.adapter.accuweather.0            : accuweather           : ioBroker-V2                              -  enabled
        + system.adapter.admin.0                  : admin                 : ioBroker-V2                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          system.adapter.alias-manager.0          : alias-manager         : ioBroker-V2                              -  enabled
          system.adapter.amazon-dash.0            : amazon-dash           : ioBroker-V2                              - disabled
          system.adapter.chromecast.0             : chromecast            : ioBroker-V2                              -  enabled
          system.adapter.cloud.0                  : cloud                 : ioBroker-V2                              - disabled
          system.adapter.daswetter.0              : daswetter             : ioBroker-V2                              -  enabled
          system.adapter.deconz.0                 : deconz                : ioBroker-V2                              - disabled, port: 80
          system.adapter.devices.0                : devices               : ioBroker-V2                              -  enabled
          system.adapter.discovery.0              : discovery             : ioBroker-V2                              -  enabled
        + system.adapter.email.0                  : email                 : ioBroker-V2                              -  enabled
          system.adapter.flot.0                   : flot                  : ioBroker-V2                              -  enabled
          system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker-V2                              -  enabled
          system.adapter.fronius.0                : fronius               : ioBroker-V2                              -  enabled
          system.adapter.frontier_silicon.0       : frontier_silicon      : ioBroker-V2                              -  enabled
          system.adapter.habpanel.0               : habpanel              : ioBroker-V2                              -  enabled
          system.adapter.history.0                : history               : ioBroker-V2                              -  enabled
          system.adapter.hm-rega.0                : hm-rega               : ioBroker-V2                              -  enabled
          system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-V2                              -  enabled, port: 0
          system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-V2                              -  enabled, port: 0
          system.adapter.hs100.0                  : hs100                 : ioBroker-V2                              -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker-V2                              -  enabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker-V2                              -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-V2                              -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-V2                              -  enabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker-V2                              -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-V2                              -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-V2                              -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker-V2                              -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-V2                              -  enabled
          system.adapter.influxdb.0               : influxdb              : ioBroker-V2                              - disabled, port: 8086
          system.adapter.influxdb.1               : influxdb              : ioBroker-V2                              - disabled, port: 8086
          system.adapter.info.0                   : info                  : ioBroker-V2                              -  enabled
          system.adapter.iot.0                    : iot                   : ioBroker-V2                              -  enabled
        + system.adapter.javascript.0             : javascript            : ioBroker-V2                              -  enabled
        + system.adapter.javascript.1             : javascript            : ioBroker-V2                              -  enabled
          system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-V2                              - disabled, port: 54321
          system.adapter.mqtt.0                   : mqtt                  : ioBroker-V2                              -  enabled, port: 1883, bind: 192.168.178.121
          system.adapter.net-tools.0              : net-tools             : ioBroker-V2                              - disabled
          system.adapter.net-tools.1              : net-tools             : ioBroker-V2                              -  enabled
          system.adapter.octoprint.0              : octoprint             : ioBroker-V2                              -  enabled
          system.adapter.parser.0                 : parser                : ioBroker-V2                              -  enabled
          system.adapter.ping.0                   : ping                  : ioBroker-V2                              - disabled
          system.adapter.proxmox.0                : proxmox               : ioBroker-V2                              -  enabled, port: 8006
          system.adapter.radar.0                  : radar                 : ioBroker-V2                              - disabled
          system.adapter.radar2.0                 : radar2                : ioBroker-V2                              - disabled
          system.adapter.radar2.1                 : radar2                : ioBroker-V2                              -  enabled
          system.adapter.reolink.0                : reolink               : ioBroker-V2                              -  enabled
          system.adapter.reolink.1                : reolink               : ioBroker-V2                              -  enabled
          system.adapter.rickshaw.0               : rickshaw              : ioBroker-V2                              -  enabled
          system.adapter.s7.0                     : s7                    : ioBroker-V2                              -  enabled
          system.adapter.s7.1                     : s7                    : ioBroker-V2                              -  enabled
          system.adapter.s7.2                     : s7                    : ioBroker-V2                              -  enabled
          system.adapter.sayit.0                  : sayit                 : ioBroker-V2                              -  enabled
          system.adapter.sayit.1                  : sayit                 : ioBroker-V2                              -  enabled
          system.adapter.sayit.2                  : sayit                 : ioBroker-V2                              -  enabled
          system.adapter.simple-api.0             : simple-api            : ioBroker-V2                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          system.adapter.smartmeter.0             : smartmeter            : ioBroker-V2                              - disabled
          system.adapter.smartmeter.2             : smartmeter            : ioBroker-V2                              - disabled
          system.adapter.socketio.0               : socketio              : ioBroker-V2                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.sql.0                    : sql                   : ioBroker-V2                              -  enabled, port: 3306
          system.adapter.sql.1                    : sql                   : ioBroker-V2                              - disabled, port: 3306
          system.adapter.statistics.0             : statistics            : ioBroker-V2                              -  enabled
          system.adapter.systeminfo.0             : systeminfo            : ioBroker-V2                              - disabled
          system.adapter.telegram.0               : telegram              : ioBroker-V2                              -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.terminal.0               : terminal              : ioBroker-V2                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
          system.adapter.tr-064.0                 : tr-064                : ioBroker-V2                              -  enabled
          system.adapter.unifi.0                  : unifi                 : ioBroker-V2                              -  enabled
          system.adapter.upnp.0                   : upnp                  : ioBroker-V2                              -  enabled
          system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker-V2                              -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker-V2                              -  enabled
          system.adapter.vis-2.0                  : vis-2                 : ioBroker-V2                              -  enabled
          system.adapter.vis-bars.0               : vis-bars              : ioBroker-V2                              -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-V2                              -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-V2                              -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-V2                              -  enabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker-V2                              -  enabled
          system.adapter.vis-history.0            : vis-history           : ioBroker-V2                              -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-V2                              -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-V2                              -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-V2                              -  enabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-V2                              -  enabled
          system.adapter.vis-lcars.0              : vis-lcars             : ioBroker-V2                              -  enabled
          system.adapter.vis-map.0                : vis-map               : ioBroker-V2                              -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker-V2                              -  enabled
          system.adapter.vis-metro.0              : vis-metro             : ioBroker-V2                              -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-V2                              -  enabled
          system.adapter.vis-weather.0            : vis-weather           : ioBroker-V2                              -  enabled
          system.adapter.vis.0                    : vis                   : ioBroker-V2                              -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : ioBroker-V2                              -  enabled
          system.adapter.web.0                    : web                   : ioBroker-V2                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "accuweather"  : 2.1.1    , installed 2.1.1
        Adapter    "admin"        : 7.7.19   , installed 7.7.19
        Adapter    "alias-manager": 2.0.0    , installed 2.0.0
        Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
        Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
        Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
        Adapter    "deconz"       : 1.6.4    , installed 1.6.4
        Adapter    "devices"      : 1.2.8    , installed 1.2.8
        Adapter    "email"        : 2.0.4    , installed 2.0.4
        Adapter    "fronius"      : 2.1.1    , installed 2.1.1
        Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
        Adapter    "frontier_silicon": 0.5.0 , installed 0.5.0
        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "hs100"        : 3.0.5    , installed 3.0.5
        Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "iot"          : 5.0.7    , installed 5.0.7
        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
        Adapter    "net-tools"    : 1.1.2    , installed 1.1.2
        Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
        Adapter    "parser"       : 2.2.4    , installed 2.2.4
        Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
        Adapter    "radar2"       : 2.4.0    , installed 2.4.0
        Adapter    "reolink"      : 1.2.3    , installed 1.2.3
        Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
        Adapter    "s7"           : 1.5.0    , installed 1.5.0
        Adapter    "sayit"        : 5.0.0    , installed 5.0.0
        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
        Adapter    "sql"          : 3.0.1    , installed 3.0.1
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "upnp"         : 1.1.0    , installed 1.1.0
        Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
        Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
        Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "web"          : 7.0.8    , installed 7.0.8
        Objects and States
        Objects:        24997
        States:         20033
        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.178.121:2001    0.0.0.0:*               LISTEN      1001       66571      14348/io.hm-rpc.0
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17410      736/exim4
        tcp        0      0 192.168.178.121:1883    0.0.0.0:*               LISTEN      1001       61291      14044/io.mqtt.0
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       62504      12617/iobroker.js-c
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       59698      12617/iobroker.js-c
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15485      553/sshd: /usr/sbin
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       59780      12641/io.admin.0
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17411      736/exim4
        tcp6       0      0 :::22                   :::*                    LISTEN      0          15487      553/sshd: /usr/sbin
        udp        0      0 0.0.0.0:35015           0.0.0.0:*                           107        13947      440/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       65677      14275/io.chromecast
        udp        0      0 192.168.178.121:5353    0.0.0.0:*                           1001       64680      14141/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        13945      440/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13849      376/dhclient
        udp6       0      0 :::36795                :::*                                107        13948      440/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                107        13946      440/avahi-daemon: r
        2025-11-12 16:31:21.431  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] connected with secret 1762961481430_2245
        2025-11-12 16:31:21.446  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] subscribes on "Wemos_DisplayV2_6/#" with regex /^Wemos_DisplayV2_6\..*/
        2025-11-12 16:31:21.447  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] subscribes on "Wemos_DisplayV2_6/#"  with regex /^mqtt\.0\.Wemos_DisplayV2_6\..*/
        2025-11-12 16:31:21.647  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] publishOnSubscribe send all known states
        2025-11-12 16:31:22.266  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 1(Jonny-Pixel3/3C:28:6D:E8:64:45) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2025-11-12 16:31:22.409  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 2(Jenny-Pixel3a/58:CB:52:8E:4E:68) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2025-11-12 16:31:22.548  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 3(Jonny-Arbeit-A40/F0:8A:76:20:A8:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2025-11-12 16:31:22.766  - info: chromecast.0 (14275) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.chromecast, node: v22.21.0, js-controller: 7.0.7
        2025-11-12 16:31:23.348  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 7(Pixel-3a/BA:DC:2D:6F:F1:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2025-11-12 16:31:23.407  - info: chromecast.0 (14275) Google_HomeKueche - Connected client
        2025-11-12 16:31:23.438  - info: chromecast.0 (14275) Küche - Connected client
        2025-11-12 16:31:23.905  - info: host.ioBroker-V2 instance system.adapter.hm-rpc.0 in version "2.0.2" started with pid 14348
        2025-11-12 16:31:26.245  - info: hm-rpc.0 (14348) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v22.21.0, js-controller: 7.0.7
        2025-11-12 16:31:26.463  - info: hm-rpc.0 (14348) xmlrpc server is trying to listen on 192.168.178.121:2001
        2025-11-12 16:31:26.464  - info: hm-rpc.0 (14348) xmlrpc client is trying to connect to 192.168.178.155:2001/ with ["http://192.168.178.121:2001","ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
        2025-11-12 16:31:26.492  - info: hm-rpc.0 (14348) xmlrpc <- system.listMethods ["ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
        2025-11-12 16:31:26.498  - info: hm-rpc.0 (14348) xmlrpc <- listDevices ["ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
        2025-11-12 16:31:26.528  - info: hm-rpc.0 (14348) xmlrpc -> 64 devices
        2025-11-12 16:31:26.547  - info: hm-rpc.0 (14348) Connected
        2025-11-12 16:31:27.831  - info: host.ioBroker-V2 instance system.adapter.hm-rega.0 in version "5.1.0" started with pid 14782
        2025-11-12 16:31:30.487  - info: hm-rega.0 (14782) starting. Version 5.1.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v22.21.0, js-controller: 7.0.7
        2025-11-12 16:31:30.694  - info: hm-rega.0 (14782) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
        2025-11-12 16:31:30.763  - info: hm-rega.0 (14782) ReGaHSS 192.168.178.155 up
        2025-11-12 16:31:30.869  - info: hm-rega.0 (14782) time difference local-ccu 1s
        2025-11-12 16:31:31.325  - info: hm-rega.0 (14782) request state values
        Ro75R Offline
        Ro75R Offline
        Ro75
        @george_best
        Was ist das? Woher kommt das?
        Ro75.
        G 1 Antwort Letzte Antwort
        • Ro75R Ro75
          @george_best
          Ro75.
          George_Best
          @ro75
          ersteres ist wohl vom hometmatic adapter
          letzeres ist ein Adapter von TP-Link für smarte Steckdosen
          Ro75R 1 Antwort Letzte Antwort
          • G George_Best
            @ro75
            Ro75R Offline
            Ro75R Offline
            Ro75
            @george_best mir geht es mehr um das "invalid"
            Ro75.
            • Ro75R Ro75
              Ro75.
              George_Best
              @ro75
              woher hast du die Zeilen genau?
              Weil der npm-tree am Anfang war als der js-controller nicht mehr da war. Da war/ist so ziemlich alles auf "invalid"
              • G George_Best
                @ro75
                Ro75R Offline
                Ro75R Offline
                Ro75
                @george_best sagte in iob fix und iob diag ohne Reaktion:
                aus deinem iob diag log
                Ro75.
                • Ro75R Ro75
                  Ro75.
                  George_Best
                  @ro75
                  ok.
                  Adapter mal löschen? Neu installieren?
                  • G George_Best
                    @ro75
                    ok.
                    Ro75R Offline
                    Ro75R Offline
                    Ro75
                    @george_best keine Ahnung. Auf alle Fälle, die, die man nicht (mehr) braucht können auch weg. Weniger Last, weniger Probleme.
                    Ro75.
                    • G George_Best
                      npm ls:
                      iobroker.inst@2.0.2 /opt/iobroker
                      ├── @iobroker-javascript.0/moment-parseformat@npm:moment-parseformat@4.0.0
                      ├── @iobroker-javascript.0/moment@npm:moment@2.30.1
                      ├── colors@1.4.0
                      ├── fs-extra@7.0.1
                      ├── iobroker.accuweather@2.1.1
                      ├── iobroker.admin@7.7.19
                      ├── iobroker.alias-manager@2.0.0
                      ├── iobroker.amazon-dash@1.2.0
                      ├── iobroker.chromecast@4.0.0
                      ├── iobroker.cloud@5.0.1
                      ├── iobroker.daswetter@3.2.3
                      ├── iobroker.deconz@1.6.4
                      ├── iobroker.devices@1.2.8
                      ├── iobroker.discovery@5.0.0
                      ├── iobroker.email@2.0.4
                      ├── iobroker.flot@1.12.0
                      ├── iobroker.fronius-solarweb@0.0.3
                      ├── iobroker.fronius@2.1.1
                      ├── iobroker.frontier_silicon@0.5.0
                      ├── iobroker.habpanel@0.5.0
                      ├── iobroker.history@3.0.1
                      ├── iobroker.hm-rega@5.1.0
                      ├── iobroker.hm-rpc@2.0.2
                      ├── iobroker.hs100@3.0.5
                      ├── iobroker.icons-addictive-flavour-png@0.1.0
                      ├── iobroker.icons-fatcow-hosting@0.1.0
                      ├── iobroker.icons-icons8@0.0.1
                      ├── iobroker.icons-material-png@0.1.0
                      ├── iobroker.icons-material-svg@0.1.0
                      ├── iobroker.icons-mfd-png@1.2.1
                      ├── iobroker.icons-mfd-svg@1.2.0
                      ├── iobroker.icons-open-icon-library-png@0.1.2
                      ├── iobroker.icons-ultimate-png@1.0.1
                      ├── iobroker.influxdb@4.0.2
                      ├── iobroker.info@2.0.0
                      ├── iobroker.iot@5.0.7
                      ├── iobroker.javascript@8.9.2
                      ├── iobroker.js-controller@7.0.7
                      ├── iobroker.mihome-vacuum@5.2.0
                      ├── iobroker.mqtt@6.1.4
                      ├── iobroker.net-tools@1.1.2
                      ├── iobroker.octoprint@5.1.0
                      ├── iobroker.openweathermap@1.1.2
                      ├── iobroker.parser@2.2.4
                      ├── iobroker.ping@1.6.2
                      ├── iobroker.proxmox@2.4.0
                      ├── iobroker.radar@1.2.1
                      ├── iobroker.radar2@2.4.0
                      ├── iobroker.reolink@1.2.3
                      ├── iobroker.rickshaw@1.0.0
                      ├── iobroker.s7@1.5.0
                      ├── iobroker.sayit@5.0.0
                      ├── iobroker.smartmeter@3.4.0
                      ├── iobroker.socketio@6.7.1
                      ├── iobroker.sql@3.0.1
                      ├── iobroker.statistics@2.4.0
                      ├── iobroker.systeminfo@1.3.0
                      ├── iobroker.telegram@4.1.0
                      ├── iobroker.terminal@1.0.0
                      ├── iobroker.tr-064@4.3.0
                      ├── iobroker.unifi@0.7.0
                      ├── iobroker.upnp@1.1.0
                      ├── iobroker.vis-2-widgets-inventwo@0.2.2
                      ├── iobroker.vis-2-widgets-material@1.4.10
                      ├── iobroker.vis-2@2.13.4
                      ├── iobroker.vis-bars@0.1.4
                      ├── iobroker.vis-canvas-gauges@1.0.1
                      ├── iobroker.vis-colorpicker@2.0.3
                      ├── iobroker.vis-fancyswitch@1.1.0
                      ├── iobroker.vis-google-fonts@1.0.4
                      ├── iobroker.vis-history@1.0.0
                      ├── iobroker.vis-hqwidgets@1.5.1
                      ├── iobroker.vis-jqui-mfd@1.1.1
                      ├── iobroker.vis-justgage@2.1.7
                      ├── iobroker.vis-keyboard@0.0.2
                      ├── iobroker.vis-lcars@1.1.1
                      ├── iobroker.vis-map@1.1.2
                      ├── iobroker.vis-materialdesign@0.5.9
                      ├── iobroker.vis-metro@1.2.0
                      ├── iobroker.vis-rgraph@0.0.2
                      ├── iobroker.vis-weather@2.5.12
                      ├── iobroker.vis@1.5.6
                      ├── iobroker.weatherunderground@3.7.0
                      ├── iobroker.web@7.0.8
                      ├── iobroker.ws@2.6.2
                      ├── iobroker@2.0.3
                      ├── semver@5.7.2
                      └── yargs@7.1.2
                      npm ls graceful-fs
                      ├── colors@1.4.0
                      ├── fs-extra@7.0.1
                      ├── iobroker@2.0.3
                      ├── semver@5.7.2
                      └── yargs@7.1.2
                      ├─┬ fs-extra@7.0.1
                      │ ├── graceful-fs@4.2.11
                      │ └─┬ jsonfile@4.0.0
                      │   └── graceful-fs@4.2.11 deduped
                      ├─┬ iobroker.admin@7.7.19
                      │ └─┬ archiver@7.0.1
                      │   └─┬ archiver-utils@5.0.2
                      ├─┬ iobroker.js-controller@7.0.7
                      │ ├─┬ @iobroker/db-objects-file@7.0.7
                      │ │ ├─┬ @iobroker/db-base@7.0.7
                      │ │ │ └─┬ fs-extra@11.3.2
                      │ │ │   ├── graceful-fs@4.2.11 deduped
                      │ │ │   └─┬ jsonfile@6.2.0
                      │ │ │     └── graceful-fs@4.2.11 deduped
                      │ ├─┬ @iobroker/db-objects-jsonl@7.0.7
                      │ │ ├─┬ @alcalzone/jsonl-db@3.1.1
                      │ │ │ ├─┬ @alcalzone/proper-lockfile@4.1.3-0
                      │ │ │ │ └── graceful-fs@4.2.11 deduped
                      │ │ │ └─┬ fs-extra@10.1.0
                      │ ├─┬ @iobroker/js-controller-adapter@7.0.7
                      │ │ ├─┬ @alcalzone/pak@0.8.1
                      │ ├─┬ @iobroker/js-controller-cli@7.0.7
                      │ ├─┬ @iobroker/js-controller-common-db@7.0.7
                      │ ├─┬ @iobroker/js-controller-common@7.0.7
                      ├─┬ iobroker.radar@1.2.1
                      │ └─┬ @abandonware/noble@1.9.2-26
                      │   └─┬ @abandonware/bluetooth-hci-socket@0.5.3-12
                      │     └─┬ node-gyp@10.3.1
                      ├─┬ iobroker.radar2@2.4.0
                      │ └─┬ @stoprocent/noble@1.19.1
                      │   └─┬ @stoprocent/bluetooth-hci-socket@1.5.2
                      │     └─┬ patch-package@8.0.1
                      │       ├─┬ fs-extra@10.1.0
                      │       └─┬ klaw-sync@6.0.0
                      ├─┬ iobroker.sql@3.0.1
                      │ └─┬ sqlite3@5.1.7
                      │   └─┬ node-gyp@8.4.1
                      ├─┬ iobroker.vis-map@1.1.2
                      │ └─┬ @iobroker/dev-server@0.7.8
                      │   ├─┬ @iobroker/testing@5.2.2
                      │   ├─┬ browser-sync@3.0.4
                      │   │ └─┬ fs-extra@3.0.1
                      │   │   └─┬ jsonfile@3.0.1
                      └─┬ yargs@7.1.2
                        └─┬ read-pkg-up@1.0.1
                          └─┬ read-pkg@1.1.0
                            ├─┬ load-json-file@1.1.0
                            └─┬ path-type@1.1.0
                      Jetzt sieht es auf einmal wieder gut aus, oder?
                      ├── semver@5.7.2
                      ├── semver@5.7.2
                      └── yargs@7.1.2
                      ├─┬ fs-extra@7.0.1
                      Die Stelle schau auch komisch aus...
                      Bitte NICHT die LogInPrompts löschen und IMMER die vollständigen Ein- und Ausgaben posten. Man kann sich ohne die Dinger als Helfer nur schlecht durch die zusammenkopierten Ausgaben hangeln.
                      • G Offline
                        George_Best
                        hm... es läuft nun schon einige Minuten stabil...
                        Möglicherweise war es der HS100 Adapter
                        Ro75R Thomas BraunT 2 Antworten Letzte Antwort
                        • G George_Best
                          Ro75R Offline
                          Ro75R Offline
                          Ro75
                          @george_best der HS100 läuft bei mir. Installiere den, falls du den brauchst, einfach mal neu.
                          Ro75.
                          • G George_Best
                            @george_best
                            Du kannst auch mal schauen, was da passiert:
                            cd /opt/iobroker && npm ci
                            Wird was länger laufen, vermutlich.
                              @george_best
                              George_Best
                              Ich glaube das sieht nicht gut aus:
                              jonny@ioBroker-V2:/opt/iobroker$ cd /opt/iobroker && npm ci
                              [sudo] Passwort für jonny:
                              npm warn old lockfile
                              npm warn old lockfile The package-lock.json file was created with an old version of npm,
                              npm warn old lockfile so supplemental metadata must be fetched from the registry.
                              npm warn old lockfile This is a one-time fix-up, please be patient...
                              npm error code EUSAGE
                              npm error
                              npm error `npm ci` can only install packages when your package.json and package-lock.json or npm-shrinkwrap.json are in sync. Please update your lock file with `npm install` before continuing.
                              npm error
                              npm error Missing: @iobroker-javascript.0/moment@2.30.1 from lock file
                              npm error Missing: @iobroker-javascript.0/moment-parseformat@4.0.0 from lock file
                              npm error Missing: iobroker.accuweather@2.1.1 from lock file
                              npm error Invalid: lock file's iobroker.admin@3.5.10 does not satisfy iobroker.admin@7.7.19
                              npm error Missing: iobroker.alias-manager@2.0.0 from lock file
                              npm error Missing: iobroker.amazon-dash@1.2.0 from lock file
                              npm error Missing: iobroker.chromecast@4.0.0 from lock file
                              npm error Missing: iobroker.cloud@5.0.1 from lock file
                              npm error Missing: iobroker.daswetter@3.2.3 from lock file
                              npm error Missing: iobroker.deconz@1.6.4 from lock file
                              npm error Missing: iobroker.devices@1.2.8 from lock file
                              npm error Invalid: lock file's iobroker.discovery@1.2.4 does not satisfy iobroker.discovery@5.0.0
                              npm error Missing: iobroker.email@2.0.4 from lock file
                              npm error Missing: iobroker.flot@1.12.0 from lock file
                              npm error Missing: iobroker.fronius@2.1.1 from lock file
                              npm error Missing: iobroker.fronius-solarweb@0.0.3 from lock file
                              npm error Missing: iobroker.frontier_silicon@0.5.0 from lock file
                              npm error Missing: iobroker.habpanel@0.5.0 from lock file
                              npm error Missing: iobroker.history@3.0.1 from lock file
                              npm error Missing: iobroker.hm-rega@5.1.0 from lock file
                              npm error Missing: iobroker.hm-rpc@2.0.2 from lock file
                              npm error Missing: iobroker.hs100@3.0.5 from lock file
                              npm error Missing: iobroker.icons-addictive-flavour-png@0.1.0 from lock file
                              npm error Missing: iobroker.icons-fatcow-hosting@0.1.0 from lock file
                              npm error Missing: iobroker.icons-icons8@0.0.1 from lock file
                              npm error Missing: iobroker.icons-material-png@0.1.0 from lock file
                              npm error Missing: iobroker.icons-material-svg@0.1.0 from lock file
                              npm error Missing: iobroker.icons-mfd-png@1.2.1 from lock file
                              npm error Missing: iobroker.icons-mfd-svg@1.2.0 from lock file
                              npm error Missing: iobroker.icons-open-icon-library-png@0.1.2 from lock file
                              npm error Missing: iobroker.icons-ultimate-png@1.0.1 from lock file
                              npm error Missing: iobroker.influxdb@4.0.2 from lock file
                              npm error Missing: iobroker.info@2.0.0 from lock file
                              npm error Missing: iobroker.iot@5.0.7 from lock file
                              npm error Missing: iobroker.javascript@8.9.2 from lock file
                              npm error Invalid: lock file's iobroker.js-controller@1.4.2 does not satisfy iobroker.js-controller@7.0.7
                              npm error Missing: iobroker.mihome-vacuum@5.2.0 from lock file
                              ==> weitere ist im file.2025-11-12T17_36_48_294Z-debug-0.log
                              Oder hätte ich iobroker vorher stoppen sollen?
                              • G George_Best
                                npm error
                                npm error
                                #66
                                npm error npm ci can only install packages when your package.json and package-lock.json or npm-shrinkwrap.json are in sync. Please update your lock file with npm install before continuing.
                                Das dürfte das auslösende Moment sein.
                                • G George_Best
                                  npm error
                                  npm error
                                  #67
                                  Ist die Installation echt so alt?
                                    George_Best
                                    schrieb am zuletzt editiert von George_Best
                                    #68
                                    Naja - schon ein paar Jährchen...
                                    Wie kann ich das lösen?
                                    Ich kann auch aktuell keinen Adapter bzw. Instanz mehr installieren:
                                    Installing iobroker.lg-ess-home@0.4.1... (System call)
                                    npm error code ENOTEMPTYnpm error syscall rename
                                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-11-12T17_47_52_218Z-debug-0.log
                                    Try to solve ENOTEMPTY error automatically
                                    Could not handle ENOTEMPTY, because no deletable files were foundnpm error code ENOTEMPTYnpm error syscall renamenpm error path /opt/iobroker/node_modules/abbrevnpm error dest /opt/iobroker/node_modules/.abbrev-5eNud0FYnpm error errno -39npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abbrev' -> '/opt/iobroker/node_modules/.abbrev-5eNud0FY'npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-11-12T17_47_52_218Z-debug-0.loghost.ioBroker-V2 Cannot install iobroker.lg-ess-home@0.4.1: 217
                                    ERROR: Process exited with code 25
                                    • G George_Best
                                      #69
                                      @george_best
                                      npm i
                                      im Verzeichnis /opt/iobroker probieren.
                                        @george_best
                                        npm i
                                        George_Best
                                        #70
                                        hm... irgendwie auch immer die gleiche Fehlermeldung:
                                        jonny@ioBroker-V2:/opt/iobroker$ npm i
                                        npm error errno -39
                                        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-11-12T17_50_28_886Z-debug-0.log
                                        • G George_Best
                                          npm error errno -39
                                          #71
                                          @george_best
                                          Da hilft ein
                                          iob stop
                                          iob fix
