  4. iob fix und iob diag ohne Reaktion
    6.4k
94 Beiträge 8 Kommentatoren 12.8k Aufrufe 4 Beobachtet
  • G Offline
    George_Best
    1. npm ls:
    cd /opt/iobroker
    npm ls
    npm ls graceful-fs
    ── component-inherit@ extraneous
    ├── compress-commons@ extraneous
    ├── compressible@ extraneous
    ├── compression@ extraneous
    ├── concat-map@ extraneous
    ├── concat-stream@ extraneous
    ├── connect-flash@ extraneous
    ├── connect-history-api-fallback@ extraneous
    ├── connect@ extraneous
    ├── console-control-strings@ extraneous
    ├── content-disposition@ extraneous
    ├── content-type@ extraneous
    ├── cookie-parser@ extraneous
    ├── cookie-signature@ extraneous
    ├── cookie@ extraneous
    ├── core-util-is@ extraneous
    ├── cors@ extraneous
    ├── country-data@ extraneous
    ├── cpu-features@ extraneous
    ├── crc-32@ extraneous
    ├── crc32-stream@ extraneous
    ├── cron-parser@ extraneous
    ├── cron@ extraneous
    ├── cross-spawn@ extraneous
    ├── crypto-js@ extraneous
    ├── css-select@ extraneous
    ├── css-what@ extraneous
    ├── cssom@ extraneous
    ├── cssstyle@ extraneous
    ├── currency-symbol-map@ extraneous
    ├── cycle@ extraneous
    ├── dashdash@ extraneous
    ├── data-view-buffer@ extraneous
    ├── data-view-byte-length@ extraneous
    ├── data-view-byte-offset@ extraneous
    ├── dateformat@ extraneous
    ├── dbus-next@ extraneous
    ├── debug@ extraneous
    ├── decache@ extraneous
    ├── decamelize@ extraneous
    ├── decompress-response@ extraneous
    ├── deep-clone@ extraneous
    ├── deep-eql@ extraneous
    ├── deep-extend@0.6.0 extraneous
    ├── deep-is@ extraneous
    ├── define-data-property@ extraneous
    ├── define-lazy-prop@ extraneous
    ├── define-properties@ extraneous
    ├── delayed-stream@ extraneous
    ├── delegates@ extraneous
    ├── denque@ extraneous
    ├── depd@ extraneous
    ├── destroy@ extraneous
    ├── detect-libc@ extraneous
    ├── dev-ip@ extraneous
    ├── dev-null@ extraneous
    ├── dgram@ extraneous
    ├── diff@ extraneous
    ├── diskusage@ extraneous
    ├── dns-packet@ extraneous
    ├── docker-modem@ extraneous
    ├── dockerode@ extraneous
    ├── dom-compare-temp@ extraneous
    ├── dom-serializer@ extraneous
    ├── domelementtype@ extraneous
    ├── domhandler@ extraneous
    ├── domutils@ extraneous
    ├── dunder-proto@ extraneous
    ├── duplexer@ extraneous
    ├── duplexify@ extraneous
    ├── eastasianwidth@ extraneous
    ├── easy-extender@ extraneous
    ├── eazy-logger@ extraneous
    ├── ecc-jsbn@ extraneous
    ├── ecdsa-sig-formatter@ extraneous
    ├── ee-first@ extraneous
    ├── emoji-regex@ extraneous
    ├── enabled@ extraneous
    ├── encodeurl@ extraneous
    ├── encoding-sniffer@ extraneous
    ├── encoding@ extraneous
    ├── end-of-stream@ extraneous
    ├── engine.io-client@ extraneous
    ├── engine.io-parser@ extraneous
    ├── engine.io@ extraneous
    ├── enquirer@ extraneous
    ├── entities@ extraneous
    ├── env-paths@ extraneous
    ├── err-code@ extraneous
    ├── error-ex@ extraneous
    ├── es-abstract@ extraneous
    ├── es-aggregate-error@ extraneous
    ├── es-define-property@ extraneous
    ├── es-errors@ extraneous
    ├── es-object-atoms@ extraneous
    ├── es-set-tostringtag@ extraneous
    ├── es-shim-unscopables@ extraneous
    ├── es-to-primitive@ extraneous
    ├── es6-promise@ extraneous
    ├── esbuild@ extraneous
    ├── escalade@ extraneous
    ├── escape-html@ extraneous
    ├── escape-string-regexp@ extraneous
    ├── escodegen@ extraneous
    ├── esprima@ extraneous
    ├── estraverse@ extraneous
    ├── esutils@ extraneous
    ├── etag@ extraneous
    ├── event-stream@ extraneous
    ├── event-target-shim@ extraneous
    ├── eventemitter2@ extraneous
    ├── eventemitter3@ extraneous
    ├── events-universal@ extraneous
    ├── events@ extraneous
    ├── evilscan@ extraneous
    ├── execa@ extraneous
    ├── expand-template@ extraneous
    ├── exponential-backoff@ extraneous
    ├── express-fileupload@ extraneous
    ├── express-session@ extraneous
    ├── express@ extraneous
    ├── extend@3.0.2 extraneous
    ├── extsprintf@ extraneous
    ├── eyes@ extraneous
    ├── fast-deep-equal@ extraneous
    ├── fast-fifo@ extraneous
    ├── fast-glob@ extraneous
    ├── fast-json-stable-stringify@ extraneous
    ├── fast-levenshtein@ extraneous
    ├── fast-unique-numbers@ extraneous
    ├── fast-uri@ extraneous
    ├── fast-xml-parser@ extraneous
    ├── fastq@ extraneous
    ├── fecha@ extraneous
    ├── fetch-enhanced@ extraneous
    ├── file-stream-rotator@ extraneous
    ├── file-type@ extraneous
    ├── file-uri-to-path@ extraneous
    ├── fill-range@ extraneous
    ├── finalhandler@ extraneous
    ├── find-up@ extraneous
    ├── find-yarn-workspace-root@ extraneous
    ├── flat@ extraneous
    ├── fn.name@ extraneous
    ├── follow-redirects@ extraneous
    ├── for-each@ extraneous
    ├── foreground-child@ extraneous
    ├── forever-agent@ extraneous
    ├── form-data@ extraneous
    ├── forwarded@ extraneous
    ├── fresh@ extraneous
    ├── from@ extraneous
    ├── fs-constants@1.0.0 extraneous
    ├── fs-extra@7.0.1
    ├── fs-minipass@ extraneous
    ├── fs.realpath@ extraneous
    ├── fsevents@ extraneous
    ├── ftp-response-parser@ extraneous
    ├── function-bind@ extraneous
    ├── function.prototype.name@ extraneous
    ├── functions-have-names@ extraneous
    ├── gauge@ extraneous
    ├── gaxios@ extraneous
    ├── gcp-metadata@ extraneous
    ├── generate-function@ extraneous
    ├── generator-function@ extraneous
    ├── get-caller-file@1.0.3 extraneous
    ├── get-func-name@ extraneous
    ├── get-intrinsic@ extraneous
    ├── get-proto@ extraneous
    ├── get-stream@ extraneous
    ├── get-symbol-description@ extraneous
    ├── getpass@ extraneous
    ├── github-from-package@ extraneous
    ├── glob-parent@ extraneous
    ├── glob@ extraneous
    ├── globalthis@ extraneous
    ├── glossy@ extraneous
    ├── google-auth-library@ extraneous
    ├── google-logging-utils@ extraneous
    ├── google-tts-api@ extraneous
    ├── googleapis-common@ extraneous
    ├── googleapis@ extraneous
    ├── gopd@ extraneous
    ├── gtoken@ extraneous
    ├── har-schema@ extraneous
    ├── har-validator@ extraneous
    ├── has-bigints@ extraneous
    ├── has-binary@ extraneous
    ├── has-binary2@1.0.3 extraneous
    ├── has-cors@ extraneous
    ├── has-flag@ extraneous
    ├── has-property-descriptors@ extraneous
    ├── has-proto@ extraneous
    ├── has-symbols@ extraneous
    ├── has-tostringtag@ extraneous
    ├── has-unicode@ extraneous
    ├── hasown@ extraneous
    ├── he@ extraneous
    ├── help-me@ extraneous
    ├── hexy@ extraneous
    ├── homematic-xmlrpc@ extraneous
    ├── hosted-git-info@ extraneous
    ├── htmlparser2@ extraneous
    ├── http-cache-semantics@ extraneous
    ├── http-errors@ extraneous
    ├── http-proxy-agent@ extraneous
    ├── http-proxy-middleware@ extraneous
    ├── http-proxy@ extraneous
    ├── http-signature@ extraneous
    ├── https-proxy-agent@ extraneous
    ├── https@ extraneous
    ├── human-signals@ extraneous
    ├── humanize-ms@ extraneous
    ├── iconv-lite@ extraneous
    ├── icy@ extraneous
    ├── ieee754@ extraneous
    ├── ignore-by-default@ extraneous
    ├── immediate@ extraneous
    ├── immutable@ extraneous
    ├── imurmurhash@ extraneous
    ├── indent-string@ extraneous
    ├── indexof@ extraneous
    ├── infer-owner@ extraneous
    ├── inflight@ extraneous
    ├── influx@ extraneous
    ├── inherits@ extraneous
    ├── ini@ extraneous
    ├── int64-buffer@ extraneous
    ├── internal-slot@ extraneous
    ├── invert-kv@ extraneous
    ├── iobroker.accuweather@ invalid: "2.1.1" from the root project
    ├── iobroker.admin@ invalid: "7.7.19" from the root project
    ├── iobroker.alias-manager@ invalid: "2.0.0" from the root project
    ├── iobroker.amazon-dash@ invalid: "1.2.0" from the root project
    ├── iobroker.chromecast@ invalid: "4.0.0" from the root project
    ├── iobroker.cloud@ invalid: "5.0.1" from the root project
    ├── iobroker.daswetter@ invalid: "3.2.3" from the root project
    ├── iobroker.deconz@ invalid: "1.6.4" from the root project
    ├── iobroker.devices@ invalid: "1.2.8" from the root project
    ├── iobroker.discovery@ invalid: "5.0.0" from the root project
    ├── iobroker.email@ invalid: "2.0.4" from the root project
    ├── iobroker.flot@ invalid: "1.12.0" from the root project
    ├── iobroker.fronius-solarweb@ invalid: "0.0.3" from the root project
    ├── iobroker.fronius@ invalid: "2.1.1" from the root project
    ├── iobroker.frontier_silicon@ invalid: "0.5.0" from the root project
    ├── iobroker.habpanel@ invalid: "0.5.0" from the root project
    ├── iobroker.history@ invalid: "3.0.1" from the root project
    ├── iobroker.hm-rega@ invalid: "5.1.0" from the root project
    ├── iobroker.hm-rpc@ invalid: "2.0.2" from the root project
    ├── iobroker.hs100@ invalid: "3.0.5" from the root project
    ├── iobroker.icons-addictive-flavour-png@ invalid: "^0.1.0" from the root project
    ├── iobroker.icons-fatcow-hosting@ invalid: "^0.1.0" from the root project
    ├── iobroker.icons-icons8@ invalid: "0.0.1" from the root project
    ├── iobroker.icons-material-png@ invalid: "^0.1.0" from the root project
    ├── iobroker.icons-material-svg@ invalid: "^0.1.0" from the root project
    ├── iobroker.icons-mfd-png@ invalid: "1.2.1" from the root project
    ├── iobroker.icons-mfd-svg@ invalid: "1.2.0" from the root project
    ├── iobroker.icons-open-icon-library-png@ invalid: "0.1.2" from the root project
    ├── iobroker.icons-ultimate-png@ invalid: "^1.0.1" from the root project
    ├── iobroker.influxdb@ invalid: "4.0.2" from the root project
    ├── iobroker.info@ invalid: "2.0.0" from the root project
    ├── iobroker.iot@ invalid: "5.0.7" from the root project
    ├── iobroker.javascript@ invalid: "8.9.2" from the root project
    ├── iobroker.js-controller@ invalid: "^7.0.7" from the root project
    ├── iobroker.mihome-vacuum@ invalid: "5.2.0" from the root project
    ├── iobroker.mqtt@ invalid: "6.1.4" from the root project
    ├── iobroker.net-tools@ invalid: "1.1.2" from the root project
    ├── iobroker.octoprint@ invalid: "5.1.0" from the root project
    ├── iobroker.openweathermap@ invalid: "1.1.2" from the root project
    ├── iobroker.parser@ invalid: "2.2.4" from the root project
    ├── iobroker.ping@ invalid: "1.6.2" from the root project
    ├── iobroker.proxmox@ invalid: "2.4.0" from the root project
    ├── iobroker.radar@ invalid: "^1.2.1" from the root project
    ├── iobroker.radar2@ invalid: "^2.0.3" from the root project
    ├── iobroker.reolink@ invalid: "1.2.3" from the root project
    ├── iobroker.rickshaw@ invalid: "^1.0.0" from the root project
    ├── iobroker.s7@ invalid: "1.5.0" from the root project
    ├── iobroker.sayit@ invalid: "5.0.0" from the root project
    ├── iobroker.smartmeter@ invalid: "3.4.0" from the root project
    ├── iobroker.socketio@ invalid: "6.7.1" from the root project
    ├── iobroker.sql@ invalid: "3.0.1" from the root project
    ├── iobroker.statistics@ invalid: "2.4.0" from the root project
    ├── iobroker.systeminfo@ invalid: "1.3.0" from the root project
    ├── iobroker.telegram@ invalid: "4.1.0" from the root project
    ├── iobroker.terminal@ invalid: "1.0.0" from the root project
    ├── iobroker.tr-064@ invalid: "4.3.0" from the root project
    ├── iobroker.unifi@ invalid: "0.7.0" from the root project
    ├── iobroker.upnp@ invalid: "1.1.0" from the root project
    ├── iobroker.vis-2-widgets-inventwo@ invalid: "0.2.2" from the root project
    ├── iobroker.vis-2-widgets-material@ invalid: "1.4.10" from the root project
    ├── iobroker.vis-2@ invalid: "2.13.4" from the root project
    ├── iobroker.vis-bars@ invalid: "^0.1.4" from the root project
    ├── iobroker.vis-canvas-gauges@ invalid: "1.0.1" from the root project
    ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
    ├── iobroker.vis-fancyswitch@ invalid: "^1.1.0" from the root project
    ├── iobroker.vis-google-fonts@ invalid: "1.0.4" from the root project
    ├── iobroker.vis-history@ invalid: "^1.0.0" from the root project
    ├── iobroker.vis-hqwidgets@ invalid: "1.5.1" from the root project
    ├── iobroker.vis-jqui-mfd@ invalid: "^1.0.12" from the root project
    ├── iobroker.vis-justgage@ invalid: "2.1.7" from the root project
    ├── iobroker.vis-keyboard@ invalid: "0.0.2" from the root project
    ├── iobroker.vis-lcars@ invalid: "1.1.1" from the root project
    ├── iobroker.vis-map@ invalid: "1.1.2" from the root project
    ├── iobroker.vis-materialdesign@ invalid: "0.5.9" from the root project
    ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
    ├── iobroker.vis-rgraph@ invalid: "0.0.2" from the root project
    ├── iobroker.vis-weather@ invalid: "2.5.12" from the root project
    ├── iobroker.vis@ invalid: "1.5.6" from the root project
    ├── iobroker.weatherunderground@ invalid: "3.7.0" from the root project
    ├── iobroker.web@ invalid: "7.0.8" from the root project
    ├── iobroker.ws@ invalid: "2.6.2" from the root project
    ├── iobroker@ invalid: "^2.0.2" from the root project
    ├── ioredis@ extraneous
    ├── ip-address@ extraneous
    ├── ip@ extraneous
    ├── ipaddr.js@ extraneous
    ├── is-arguments@ extraneous
    ├── is-array-buffer@ extraneous
    ├── is-arrayish@ extraneous
    ├── is-async-function@ extraneous
    ├── is-bigint@ extraneous
    ├── is-binary-path@ extraneous
    ├── is-boolean-object@ extraneous
    ├── is-callable@ extraneous
    ├── is-core-module@ extraneous
    ├── is-data-view@ extraneous
    ├── is-date-object@ extraneous
    ├── is-docker@ extraneous
    ├── is-extglob@ extraneous
    ├── is-finalizationregistry@ extraneous
    ├── is-fullwidth-code-point@ extraneous
    ├── is-generator-function@ extraneous
    ├── is-generator@ extraneous
    ├── is-glob@ extraneous
    ├── is-lambda@ extraneous
    ├── is-map@ extraneous
    ├── is-negative-zero@ extraneous
    ├── is-number-like@ extraneous
    ├── is-number-object@ extraneous
    ├── is-number@ extraneous
    ├── is-path-inside@ extraneous
    ├── is-plain-obj@ extraneous
    ├── is-plain-object@ extraneous
    ├── is-promise@ extraneous
    ├── is-property@ extraneous
    ├── is-regex@ extraneous
    ├── is-set@ extraneous
    ├── is-shared-array-buffer@ extraneous
    ├── is-stream@ extraneous
    ├── is-string@ extraneous
    ├── is-symbol@ extraneous
    ├── is-typed-array@ extraneous
    ├── is-typedarray@ extraneous
    ├── is-unicode-supported@ extraneous
    ├── is-utf8@ extraneous
    ├── is-weakmap@ extraneous
    ├── is-weakref@ extraneous
    ├── is-weakset@ extraneous
    ├── is-wsl@ extraneous
    ├── is@ extraneous
    ├── isarray@ extraneous
    ├── isexe@ extraneous
    ├── isomorphic-ws@ extraneous
    ├── isstream@ extraneous
    ├── jackspeak@ extraneous
    ├── jose@ extraneous
    ├── js-md4@ extraneous
    ├── js-sdsl@ extraneous
    ├── js-yaml@ extraneous
    ├── jsbi@ extraneous
    ├── jsbn@ extraneous
    ├── jsdom@ extraneous
    ├── jsftp@ extraneous
    ├── jshashes@ extraneous
    ├── json-bigint@ extraneous
    ├── json-logic-js@ extraneous
    ├── json-schema-traverse@ extraneous
    ├── json-schema@ extraneous
    ├── json-stable-stringify@ extraneous
    ├── json-stringify-safe@ extraneous
    ├── json3@ extraneous
    ├── json5@ extraneous
    ├── jsonata@ extraneous
    ├── jsonc-parser@ extraneous
    ├── jsonify@ extraneous
    ├── jsonwebtoken@ extraneous
    ├── jsprim@ extraneous
    ├── jszip@ extraneous
    ├── jwa@ extraneous
    ├── jwks-rsa@ extraneous
    ├── jws@ extraneous
    ├── klaw-sync@ extraneous
    ├── kuler@ extraneous
    ├── lazystream@ extraneous
    ├── lcid@ extraneous
    ├── leven@ extraneous
    ├── levn@ extraneous
    ├── lie@ extraneous
    ├── limiter@ extraneous
    ├── load-json-file@ extraneous
    ├── loadavg-windows@ extraneous
    ├── localforage@ extraneous
    ├── locate-path@ extraneous
    ├── lodash.camelcase@ extraneous
    ├── lodash.castarray@ extraneous
    ├── lodash.clone@ extraneous
    ├── lodash.clonedeep@ extraneous
    ├── lodash.defaults@ extraneous
    ├── lodash.defaultto@ extraneous
    ├── lodash.flatten@ extraneous
    ├── lodash.get@ extraneous
    ├── lodash.groupby@ extraneous
    ├── lodash.includes@ extraneous
    ├── lodash.isarguments@ extraneous
    ├── lodash.isboolean@ extraneous
    ├── lodash.isequal@ extraneous
    ├── lodash.isfinite@ extraneous
    ├── lodash.isinteger@ extraneous
    ├── lodash.isnumber@ extraneous
    ├── lodash.isplainobject@ extraneous
    ├── lodash.isstring@ extraneous
    ├── lodash.once@ extraneous
    ├── lodash.truncate@ extraneous
    ├── lodash@ extraneous
    ├── log-symbols@ extraneous
    ├── logform@ extraneous
    ├── loglevel@ extraneous
    ├── long-timeout@ extraneous
    ├── long@ extraneous
    ├── loupe@ extraneous
    ├── lru-cache@ extraneous
    ├── lru-memoizer@ extraneous
    ├── lru.min@ extraneous
    ├── luxon@ extraneous
    ├── make-dir@ extraneous
    ├── make-fetch-happen@ extraneous
    ├── map-stream@ extraneous
    ├── math-intrinsics@ extraneous
    ├── mdns-discovery@ extraneous
    ├── mdns@ extraneous
    ├── media-typer@ extraneous
    ├── merge-descriptors@ extraneous
    ├── merge-stream@ extraneous
    ├── merge2@ extraneous
    ├── methods@ extraneous
    ├── micromatch@ extraneous
    ├── mime-db@ extraneous
    ├── mime-types@ extraneous
    ├── mime@ extraneous
    ├── mimic-fn@ extraneous
    ├── mimic-response@ extraneous
    ├── minimatch@ extraneous
    ├── minimist@ extraneous
    ├── minipass-collect@ extraneous
    ├── minipass-fetch@ extraneous
    ├── minipass-flush@ extraneous
    ├── minipass-pipeline@ extraneous
    ├── minipass-sized@ extraneous
    ├── minipass@ extraneous
    ├── minizlib@ extraneous
    ├── mitt@ extraneous
    ├── mkdirp-classic@ extraneous
    ├── mkdirp@ extraneous
    ├── mocha@ extraneous
    ├── moment@ extraneous
    ├── mp3-duration@ extraneous
    ├── mqtt-connection@ extraneous
    ├── mqtt-packet@ extraneous
    ├── mqtt@ extraneous
    ├── ms@ extraneous
    ├── mssql@ extraneous
    ├── multicast-dns@ extraneous
    ├── mute-stream@ extraneous
    ├── mysql2@ extraneous
    ├── named-placeholders@ extraneous
    ├── nan@ extraneous
    ├── napi-build-utils@ extraneous
    ├── napi-thread-safe-callback@ extraneous
    ├── native-duplexpair@ extraneous
    ├── needle@ extraneous
    ├── negotiator@ extraneous
    ├── net-ping@ extraneous
    ├── netmask@ extraneous
    ├── noble@ extraneous
    ├── node-abi@ extraneous
    ├── node-abort-controller@ extraneous
    ├── node-addon-api@ extraneous
    ├── node-arp@ extraneous
    ├── node-ble@ extraneous
    ├── node-fetch@ extraneous
    ├── node-forge@ extraneous
    ├── node-gyp-build@ extraneous
    ├── node-gyp@ extraneous
    ├── node-inspect@ extraneous
    ├── node-mndp@ extraneous
    ├── node-schedule@ extraneous
    ├── node-snap7@ extraneous
    ├── node-ssdp@ extraneous
    ├── node-telegram-bot-api@ extraneous
    ├── node-unifi@ extraneous
    ├── node.extend@ extraneous
    ├── nodemailer@ extraneous
    ├── nodemon@ extraneous
    ├── nopt@ extraneous
    ├── normalize-package-data@ extraneous
    ├── normalize-path@ extraneous
    ├── npm-run-path@ extraneous
    ├── npmlog@ extraneous
    ├── nth-check@ extraneous
    ├── number-allocator@ extraneous
    ├── number-is-nan@ extraneous
    ├── nwmatcher@ extraneous
    ├── oauth-sign@0.9.0 extraneous
    ├── oauth2-server@ extraneous
    ├── object-assign@ extraneous
    ├── object-component@ extraneous
    ├── object-hash@ extraneous
    ├── object-inspect@ extraneous
    ├── object-keys@ extraneous
    ├── object.assign@ extraneous
    ├── on-finished@ extraneous
    ├── on-headers@ extraneous
    ├── once@ extraneous
    ├── one-time@ extraneous
    ├── onetime@ extraneous
    ├── open-sml@ extraneous
    ├── open@ extraneous
    ├── opn@ extraneous
    ├── optionator@ extraneous
    ├── options@ extraneous
    ├── os-locale@ extraneous
    ├── osx-temperature-sensor@ extraneous
    ├── oui@ extraneous
    ├── own-keys@ extraneous
    ├── p-limit@ extraneous
    ├── p-locate@ extraneous
    ├── p-map@ extraneous
    ├── package-json-from-dist@ extraneous
    ├── pako@ extraneous
    ├── parse-json@ extraneous
    ├── parse-listing@ extraneous
    ├── parse5-htmlparser2-tree-adapter@ extraneous
    ├── parse5-parser-stream@ extraneous
    ├── parse5@ extraneous
    ├── parsejson@ extraneous
    ├── parseqs@ extraneous
    ├── parseuri@ extraneous
    ├── parseurl@ extraneous
    ├── parsexmlresponse@ extraneous
    ├── passport-local@ extraneous
    ├── passport-strategy@ extraneous
    ├── passport@ extraneous
    ├── patch-package@ extraneous
    ├── path-exists@ extraneous
    ├── path-is-absolute@ extraneous
    ├── path-key@ extraneous
    ├── path-parse@ extraneous
    ├── path-scurry@ extraneous
    ├── path-to-regexp@ extraneous
    ├── path-type@ extraneous
    ├── pathval@ extraneous
    ├── pause-stream@ extraneous
    ├── pause@ extraneous
    ├── pcap@ extraneous
    ├── performance-now@ extraneous
    ├── pg-cloudflare@ extraneous
    ├── pg-connection-string@ extraneous
    ├── pg-int8@ extraneous
    ├── pg-pool@ extraneous
    ├── pg-protocol@ extraneous
    ├── pg-types@ extraneous
    ├── pg@ extraneous
    ├── pgpass@ extraneous
    ├── picocolors@ extraneous
    ├── picomatch@ extraneous
    ├── pidtree@ extraneous
    ├── pidusage@ extraneous
    ├── pify@ extraneous
    ├── ping@ extraneous
    ├── pinkie-promise@ extraneous
    ├── pinkie@ extraneous
    ├── playlist-parser@ extraneous
    ├── portfinder@ extraneous
    ├── portscanner@ extraneous
    ├── possible-typed-array-names@ extraneous
    ├── postgres-array@ extraneous
    ├── postgres-bytea@ extraneous
    ├── postgres-date@ extraneous
    ├── postgres-interval@ extraneous
    ├── prebuild-install@ extraneous
    ├── prelude-ls@ extraneous
    ├── proc-log@ extraneous
    ├── process-nextick-args@ extraneous
    ├── process@ extraneous
    ├── promise-inflight@ extraneous
    ├── promise-queue@ extraneous
    ├── promise-retry@ extraneous
    ├── promisify-any@ extraneous
    ├── promisify-child-process@ extraneous
    ├── prompt@ extraneous
    ├── protobufjs@ extraneous
    ├── proxy-addr@ extraneous
    ├── proxy-from-env@ extraneous
    ├── ps-tree@ extraneous
    ├── psl@ extraneous
    ├── pstree.remy@ extraneous
    ├── pump@ extraneous
    ├── punycode@ extraneous
    ├── put@ extraneous
    ├── q@ extraneous
    ├── qjobs@ extraneous
    ├── qs@ extraneous
    ├── querystringify@ extraneous
    ├── queue-microtask@ extraneous
    ├── quick-lru@ extraneous
    ├── random-bytes@ extraneous
    ├── randombytes@ extraneous
    ├── range-parser@ extraneous
    ├── raw-body@ extraneous
    ├── raw-socket@ extraneous
    ├── rc@1.2.8 extraneous
    ├── read-pkg-up@ extraneous
    ├── read-pkg@ extraneous
    ├── read@ extraneous
    ├── readable-stream@ extraneous
    ├── readdir-glob@ extraneous
    ├── readdirp@ extraneous
    ├── readline-sync@ extraneous
    ├── readline@ extraneous
    ├── redis-errors@ extraneous
    ├── redis-parser@ extraneous
    ├── reflect.getprototypeof@ extraneous
    ├── regexp.prototype.flags@ extraneous
    ├── reinterval@ extraneous
    ├── request-promise-core@ extraneous
    ├── request@ extraneous
    ├── require-directory@ extraneous
    ├── require-from-string@ extraneous
    ├── require-main-filename@ extraneous
    ├── requires-port@ extraneous
    ├── resolve@ extraneous
    ├── resp-modifier@ extraneous
    ├── respjs@ extraneous
    ├── retry@ extraneous
    ├── reusify@ extraneous
    ├── revalidator@ extraneous
    ├── rfdc@ extraneous
    ├── rimraf@ extraneous
    ├── router@ extraneous
    ├── run-parallel@ extraneous
    ├── rx@ extraneous
    ├── safe-array-concat@ extraneous
    ├── safe-buffer@ extraneous
    ├── safe-push-apply@ extraneous
    ├── safe-regex-test@ extraneous
    ├── safe-stable-stringify@ extraneous
    ├── safer-buffer@2.1.2 extraneous
    ├── sax@ extraneous
    ├── semver@ invalid: "^5.6.0" from the root project
    ├── send@ extraneous
    ├── seq-logging@ extraneous
    ├── seq-queue@ extraneous
    ├── serialize-javascript@ extraneous
    ├── serialport@ extraneous
    ├── serve-index@ extraneous
    ├── serve-static@ extraneous
    ├── server-destroy@ extraneous
    ├── set-blocking@ extraneous
    ├── set-function-length@ extraneous
    ├── set-function-name@ extraneous
    ├── set-proto@ extraneous
    ├── setimmediate@ extraneous
    ├── setprototypeof@ extraneous
    ├── shebang-command@ extraneous
    ├── shebang-regex@ extraneous
    ├── side-channel-list@ extraneous
    ├── side-channel-map@ extraneous
    ├── side-channel-weakmap@ extraneous
    ├── side-channel@ extraneous
    ├── siginfo@ extraneous
    ├── signal-exit@ extraneous
    ├── simple-concat@ extraneous
    ├── simple-get@ extraneous
    ├── simple-update-notifier@ extraneous
    ├── sinon-chai@ extraneous
    ├── sinon@ extraneous
    ├── slash@ extraneous
    ├── slice-ansi@ extraneous
    ├── smart-buffer@ extraneous
    ├── smartmeter-obis@ extraneous
    ├── socket.io-adapter@ extraneous
    ├── socket.io-client@ extraneous
    ├── socket.io-parser@ extraneous
    ├── socket.io@ extraneous
    ├── socks-proxy-agent@ extraneous
    ├── socks@ extraneous
    ├── sorted-array-functions@ extraneous
    ├── source-map-support@ extraneous
    ├── source-map@ extraneous
    ├── spdx-correct@ extraneous
    ├── spdx-exceptions@ extraneous
    ├── spdx-expression-parse@ extraneous
    ├── spdx-license-ids@ extraneous
    ├── split-ca@ extraneous
    ├── split@ extraneous
    ├── split2@ extraneous
    ├── sprintf-js@ extraneous
    ├── sql-client@ extraneous
    ├── sqlite3@ extraneous
    ├── sqlstring@ extraneous
    ├── ssh2@ extraneous
    ├── sshpk@ extraneous
    ├── ssri@ extraneous
    ├── stack-trace@ extraneous
    ├── stackback@ extraneous
    ├── standard-as-callback@ extraneous
    ├── statuses@ extraneous
    ├── stealthy-require@ extraneous
    ├── stop-iteration-iterator@ extraneous
    ├── stoppable@ extraneous
    ├── stream-combiner@ extraneous
    ├── stream-parser@ extraneous
    ├── stream-shift@ extraneous
    ├── stream-throttle@ extraneous
    ├── streamsearch@ extraneous
    ├── streamx@ extraneous
    ├── string_decoder@ extraneous
    ├── string-width-cjs@ extraneous
    ├── string-width@ extraneous
    ├── string.prototype.trim@ extraneous
    ├── string.prototype.trimend@ extraneous
    ├── string.prototype.trimstart@ extraneous
    ├── strip-ansi-cjs@ extraneous
    ├── strip-ansi@ extraneous
    ├── strip-bom@ extraneous
    ├── strip-final-newline@ extraneous
    ├── strip-json-comments@ extraneous
    ├── strnum@ extraneous
    ├── suncalc2@ extraneous
    ├── supports-color@ extraneous
    ├── supports-preserve-symlinks-flag@ extraneous
    ├── symbol-tree@ extraneous
    ├── systeminformation@ extraneous
    ├── table@ extraneous
    ├── tar-fs@ extraneous
    ├── tar-stream@ extraneous
    ├── tar@ extraneous
    ├── tarn@ extraneous
    ├── tedious@ extraneous
    ├── text-decoder@ extraneous
    ├── text-hex@ extraneous
    ├── text-table@ extraneous
    ├── through@ extraneous
    ├── through2@ extraneous
    ├── thunky@ extraneous
    ├── tldts-core@ extraneous
    ├── tldts@ extraneous
    ├── tmp@ extraneous
    ├── to-array@ extraneous
    ├── to-regex-range@ extraneous
    ├── toidentifier@ extraneous
    ├── touch@ extraneous
    ├── tough-cookie@ extraneous
    ├── tplink-smarthome-api@ extraneous
    ├── tplink-smarthome-crypto@ extraneous
    ├── tr-O64@ extraneous
    ├── tr46@ extraneous
    ├── traverse@ extraneous
    ├── treemap-js@ extraneous
    ├── triple-beam@ extraneous
    ├── tslib@ extraneous
    ├── tunnel-agent@ extraneous
    ├── tweetnacl@ extraneous
    ├── type-check@ extraneous
    ├── type-detect@ extraneous
    ├── type-fest@ extraneous
    ├── type-is@ extraneous
    ├── typed-array-buffer@ extraneous
    ├── typed-array-byte-length@ extraneous
    ├── typed-array-byte-offset@ extraneous
    ├── typed-array-length@ extraneous
    ├── typedarray@ extraneous
    ├── typescript@ extraneous
    ├── ua-parser-js@ extraneous
    ├── uid-number@ extraneous
    ├── uid-safe@2.1.5 extraneous
    ├── ultron@ extraneous
    ├── unbox-primitive@ extraneous
    ├── undefsafe@ extraneous
    ├── underscore@ extraneous
    ├── undici-types@ extraneous
    ├── undici@ extraneous
    ├── unique-filename@ extraneous
    ├── unique-slug@ extraneous
    ├── unix-dgram@ extraneous
    ├── unorm@ extraneous
    ├── unpipe@ extraneous
    ├── uri-js@ extraneous
    ├── url-parse@ extraneous
    ├── url-template@ extraneous
    ├── url@ extraneous
    ├── usb@ extraneous
    ├── usocket@ extraneous
    ├── util-deprecate@ extraneous
    ├── util@ extraneous
    ├── utils-merge@ extraneous
    ├── uuid@ extraneous
    ├── validate-npm-package-license@3.0.4 extraneous
    ├── vary@ extraneous
    ├── verror@ extraneous
    ├── virtual-tsc@ extraneous
    ├── wake_on_lan@ extraneous
    ├── weak-daemon@ extraneous
    ├── webidl-conversions@ extraneous
    ├── websocket-stream@ extraneous
    ├── whatwg-encoding@ extraneous
    ├── whatwg-mimetype@ extraneous
    ├── whatwg-url-compat@ extraneous
    ├── whatwg-url@ extraneous
    ├── which-boxed-primitive@ extraneous
    ├── which-builtin-type@ extraneous
    ├── which-collection@ extraneous
    ├── which-module@ extraneous
    ├── which-typed-array@ extraneous
    ├── which@ extraneous
    ├── why-is-node-running@ extraneous
    ├── wide-align@ extraneous
    ├── widest-line@ extraneous
    ├── winston-daily-rotate-file@ extraneous
    ├── winston-seq-updated@ extraneous
    ├── winston-syslog@ extraneous
    ├── winston-transport@ extraneous
    ├── winston@ extraneous
    ├── wol@ extraneous
    ├── word-wrap@ extraneous
    ├── worker-factory@ extraneous
    ├── worker-timers-broker@ extraneous
    ├── worker-timers-worker@ extraneous
    ├── worker-timers@ extraneous
    ├── workerpool@ extraneous
    ├── wrap-ansi-cjs@ extraneous
    ├── wrap-ansi@ extraneous
    ├── wrappy@ extraneous
    ├── ws@ extraneous
    ├── wtf-8@ extraneous
    ├── xml-name-validator@ extraneous
    ├── xml2js@ extraneous
    ├── xml2json-light@ extraneous
    ├── xmlbuilder@ extraneous
    ├── xmldom@ extraneous
    ├── xmlhttprequest-ssl@ extraneous
    ├── xmlhttprequest@ extraneous
    ├── xpc-connection@ extraneous
    ├── xtend@ extraneous
    ├── y18n@ extraneous
    ├── yallist@ extraneous
    ├── yaml@ extraneous
    ├── yargs-parser@ extraneous
    ├── yargs-unparser@ extraneous
    ├── yargs@ invalid: "^7.0.2" from the root project
    ├── yeast@ extraneous
    ├── yocto-queue@ extraneous
    ├── youtube-remote@ extraneous
    └── zip-stream@ extraneous
    npm error code ELSPROBLEMS
    npm error extraneous: @abandonware/bluetooth-hci-socket@ /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
    npm error extraneous: @abandonware/noble@ /opt/iobroker/node_modules/@abandonware/noble
    npm error extraneous: @alcalzone/esbuild-register@ /opt/iobroker/node_modules/@alcalzone/esbuild-register
    npm error extraneous: @alcalzone/jsonl-db@ /opt/iobroker/node_modules/@alcalzone/jsonl-db
    npm error extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/@alcalzone/pak
    npm error extraneous: @alcalzone/proper-lockfile@ /opt/iobroker/node_modules/@alcalzone/proper-lockfile
    npm error extraneous: @all-smart/all-smart-tools@ /opt/iobroker/node_modules/@all-smart/all-smart-tools
    npm error extraneous: @aws-crypto/sha256-browser@ /opt/iobroker/node_modules/@aws-crypto/sha256-browser
    npm error extraneous: @aws-crypto/sha256-js@ /opt/iobroker/node_modules/@aws-crypto/sha256-js
    npm error extraneous: @aws-crypto/supports-web-crypto@ /opt/iobroker/node_modules/@aws-crypto/supports-web-crypto
    npm error extraneous: @aws-crypto/util@ /opt/iobroker/node_modules/@aws-crypto/util
    npm error extraneous: @aws-sdk/client-polly@ /opt/iobroker/node_modules/@aws-sdk/client-polly
    npm error extraneous: @aws-sdk/client-sso@ /opt/iobroker/node_modules/@aws-sdk/client-sso
    npm error extraneous: @aws-sdk/core@ /opt/iobroker/node_modules/@aws-sdk/core
    npm error extraneous: @aws-sdk/credential-provider-env@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-env
    npm error extraneous: @aws-sdk/credential-provider-http@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-http
    npm error extraneous: @aws-sdk/credential-provider-ini@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-ini
    npm error extraneous: @aws-sdk/credential-provider-node@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-node
    npm error extraneous: @aws-sdk/credential-provider-process@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-process
    npm error extraneous: @aws-sdk/credential-provider-sso@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-sso
    npm error extraneous: @aws-sdk/credential-provider-web-identity@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-web-identity
    npm error extraneous: @aws-sdk/middleware-host-header@ /opt/iobroker/node_modules/@aws-sdk/middleware-host-header
    npm error extraneous: @aws-sdk/middleware-logger@ /opt/iobroker/node_modules/@aws-sdk/middleware-logger
    npm error extraneous: @aws-sdk/middleware-recursion-detection@ /opt/iobroker/node_modules/@aws-sdk/middleware-recursion-detection
    npm error extraneous: @aws-sdk/middleware-user-agent@ /opt/iobroker/node_modules/@aws-sdk/middleware-user-agent
    npm error extraneous: @aws-sdk/nested-clients@ /opt/iobroker/node_modules/@aws-sdk/nested-clients
    npm error extraneous: @aws-sdk/region-config-resolver@ /opt/iobroker/node_modules/@aws-sdk/region-config-resolver
    npm error extraneous: @aws-sdk/token-providers@ /opt/iobroker/node_modules/@aws-sdk/token-providers
    npm error extraneous: @aws-sdk/types@ /opt/iobroker/node_modules/@aws-sdk/types
    npm error extraneous: @aws-sdk/util-endpoints@ /opt/iobroker/node_modules/@aws-sdk/util-endpoints
    npm error extraneous: @aws-sdk/util-locate-window@ /opt/iobroker/node_modules/@aws-sdk/util-locate-window
    npm error extraneous: @aws-sdk/util-user-agent-browser@ /opt/iobroker/node_modules/@aws-sdk/util-user-agent-browser
    npm error extraneous: @aws-sdk/util-user-agent-node@ /opt/iobroker/node_modules/@aws-sdk/util-user-agent-node
    npm error extraneous: @aws-sdk/xml-builder@ /opt/iobroker/node_modules/@aws-sdk/xml-builder
    npm error extraneous: @aws/lambda-invoke-store@ /opt/iobroker/node_modules/@aws/lambda-invoke-store
    npm error extraneous: @azure-rest/core-client@ /opt/iobroker/node_modules/@azure-rest/core-client
    npm error extraneous: @azure/abort-controller@ /opt/iobroker/node_modules/@azure/abort-controller
    npm error extraneous: @azure/core-auth@ /opt/iobroker/node_modules/@azure/core-auth
    npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
    npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
    npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
    npm error extraneous: @azure/core-paging@ /opt/iobroker/node_modules/@azure/core-paging
    npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
    npm error extraneous: @azure/core-tracing@ /opt/iobroker/node_modules/@azure/core-tracing
    npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
    npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
    npm error extraneous: @azure/keyvault-common@ /opt/iobroker/node_modules/@azure/keyvault-common
    npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
    npm error extraneous: @azure/logger@ /opt/iobroker/node_modules/@azure/logger
    npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
    npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
    npm error extraneous: @azure/msal-node@ /opt/iobroker/node_modules/@azure/msal-node
    npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
    npm error extraneous: @balena/dockerignore@ /opt/iobroker/node_modules/@balena/dockerignore
    npm error extraneous: @colors/colors@ /opt/iobroker/node_modules/@colors/colors
    npm error extraneous: @cypress/request-promise@ /opt/iobroker/node_modules/@cypress/request-promise
    npm error extraneous: @cypress/request@ /opt/iobroker/node_modules/@cypress/request
    npm error extraneous: @dabh/diagnostics@ /opt/iobroker/node_modules/@dabh/diagnostics
    npm error extraneous: @datalust/winston-seq@ /opt/iobroker/node_modules/@datalust/winston-seq
    npm error extraneous: @fastify/busboy@ /opt/iobroker/node_modules/@fastify/busboy
    npm error extraneous: @gar/promisify@ /opt/iobroker/node_modules/@gar/promisify
    npm error extraneous: @grpc/grpc-js@ /opt/iobroker/node_modules/@grpc/grpc-js
    npm error extraneous: @grpc/proto-loader@ /opt/iobroker/node_modules/@grpc/proto-loader
    npm error extraneous: @httptoolkit/websocket-stream@ /opt/iobroker/node_modules/@httptoolkit/websocket-stream
    npm error extraneous: @influxdata/influxdb-client-apis@ /opt/iobroker/node_modules/@influxdata/influxdb-client-apis
    npm error extraneous: @influxdata/influxdb-client@ /opt/iobroker/node_modules/@influxdata/influxdb-client
    npm error invalid: @iobroker-javascript.0/moment-parseformat@ /opt/iobroker/node_modules/@iobroker-javascript.0/moment-parseformat
    npm error invalid: @iobroker-javascript.0/moment@ /opt/iobroker/node_modules/@iobroker-javascript.0/moment
    npm error extraneous: @iobroker/adapter-core@ /opt/iobroker/node_modules/@iobroker/adapter-core
    npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
    npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
    npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
    npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
    npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
    npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
    npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
    npm error extraneous: @iobroker/dev-server@ /opt/iobroker/node_modules/@iobroker/dev-server
    npm error extraneous: @iobroker/dm-utils@ /opt/iobroker/node_modules/@iobroker/dm-utils
    npm error extraneous: @iobroker/i18n@ /opt/iobroker/node_modules/@iobroker/i18n
    npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
    npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
    npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
    npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
    npm error extraneous: @iobroker/plugin-base@ /opt/iobroker/node_modules/@iobroker/plugin-base
    npm error extraneous: @iobroker/plugin-docker@ /opt/iobroker/node_modules/@iobroker/plugin-docker
    npm error extraneous: @iobroker/plugin-sentry@ /opt/iobroker/node_modules/@iobroker/plugin-sentry
    npm error extraneous: @iobroker/socket-classes@ /opt/iobroker/node_modules/@iobroker/socket-classes
    npm error extraneous: @iobroker/testing@ /opt/iobroker/node_modules/@iobroker/testing
    npm error extraneous: @iobroker/type-detector@ /opt/iobroker/node_modules/@iobroker/type-detector
    npm error extraneous: @iobroker/types@ /opt/iobroker/node_modules/@iobroker/types
    npm error extraneous: @iobroker/webserver@ /opt/iobroker/node_modules/@iobroker/webserver
    npm error extraneous: @iobroker/ws-server@ /opt/iobroker/node_modules/@iobroker/ws-server
    npm error extraneous: @iobroker/ws@ /opt/iobroker/node_modules/@iobroker/ws
    npm error extraneous: @ioredis/commands@ /opt/iobroker/node_modules/@ioredis/commands
    npm error extraneous: @isaacs/balanced-match@ /opt/iobroker/node_modules/@isaacs/balanced-match
    npm error extraneous: @isaacs/brace-expansion@ /opt/iobroker/node_modules/@isaacs/brace-expansion
    npm error extraneous: @isaacs/cliui@ /opt/iobroker/node_modules/@isaacs/cliui
    npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
    npm error extraneous: @js-sdsl/ordered-map@ /opt/iobroker/node_modules/@js-sdsl/ordered-map
    npm error extraneous: @leichtgewicht/ip-codec@ /opt/iobroker/node_modules/@leichtgewicht/ip-codec
    npm error extraneous: @mapbox/node-pre-gyp@ /opt/iobroker/node_modules/@mapbox/node-pre-gyp
    npm error extraneous: @network-utils/arp-lookup@ /opt/iobroker/node_modules/@network-utils/arp-lookup
    npm error extraneous: @nodelib/fs.scandir@ /opt/iobroker/node_modules/@nodelib/fs.scandir
    npm error extraneous: @nodelib/fs.stat@ /opt/iobroker/node_modules/@nodelib/fs.stat
    npm error extraneous: @nodelib/fs.walk@ /opt/iobroker/node_modules/@nodelib/fs.walk
    npm error extraneous: @nornagon/put@ /opt/iobroker/node_modules/@nornagon/put
    npm error extraneous: @npmcli/agent@ /opt/iobroker/node_modules/@npmcli/agent
    npm error extraneous: @npmcli/fs@ /opt/iobroker/node_modules/@npmcli/fs
    npm error extraneous: @npmcli/move-file@ /opt/iobroker/node_modules/@npmcli/move-file
    npm error extraneous: @pkgjs/parseargs@ /opt/iobroker/node_modules/@pkgjs/parseargs
    npm error extraneous: @protobufjs/aspromise@ /opt/iobroker/node_modules/@protobufjs/aspromise
    npm error extraneous: @protobufjs/base64@ /opt/iobroker/node_modules/@protobufjs/base64
    npm error extraneous: @protobufjs/codegen@ /opt/iobroker/node_modules/@protobufjs/codegen
    npm error extraneous: @protobufjs/eventemitter@ /opt/iobroker/node_modules/@protobufjs/eventemitter
    npm error extraneous: @protobufjs/fetch@ /opt/iobroker/node_modules/@protobufjs/fetch
    npm error extraneous: @protobufjs/float@ /opt/iobroker/node_modules/@protobufjs/float
    npm error extraneous: @protobufjs/inquire@ /opt/iobroker/node_modules/@protobufjs/inquire
    npm error extraneous: @protobufjs/path@ /opt/iobroker/node_modules/@protobufjs/path
    npm error extraneous: @protobufjs/pool@ /opt/iobroker/node_modules/@protobufjs/pool
    npm error extraneous: @protobufjs/utf8@ /opt/iobroker/node_modules/@protobufjs/utf8
    npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
    npm error extraneous: @sentry/core@ /opt/iobroker/node_modules/@sentry/core
    npm error extraneous: @sentry/integrations@ /opt/iobroker/node_modules/@sentry/integrations
    npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
    npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
    npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
    npm error extraneous: @serialport/binding-mock@ /opt/iobroker/node_modules/@serialport/binding-mock
    npm error extraneous: @serialport/bindings-cpp@ /opt/iobroker/node_modules/@serialport/bindings-cpp
    npm error extraneous: @serialport/bindings-interface@ /opt/iobroker/node_modules/@serialport/bindings-interface
    npm error extraneous: @serialport/parser-byte-length@ /opt/iobroker/node_modules/@serialport/parser-byte-length
    npm error extraneous: @serialport/parser-cctalk@ /opt/iobroker/node_modules/@serialport/parser-cctalk
    npm error extraneous: @serialport/parser-delimiter@ /opt/iobroker/node_modules/@serialport/parser-delimiter
    npm error extraneous: @serialport/parser-inter-byte-timeout@ /opt/iobroker/node_modules/@serialport/parser-inter-byte-timeout
    npm error extraneous: @serialport/parser-packet-length@ /opt/iobroker/node_modules/@serialport/parser-packet-length
    npm error extraneous: @serialport/parser-readline@ /opt/iobroker/node_modules/@serialport/parser-readline
    npm error extraneous: @serialport/parser-ready@ /opt/iobroker/node_modules/@serialport/parser-ready
    npm error extraneous: @serialport/parser-regex@ /opt/iobroker/node_modules/@serialport/parser-regex
    npm error extraneous: @serialport/parser-slip-encoder@ /opt/iobroker/node_modules/@serialport/parser-slip-encoder
    npm error extraneous: @serialport/parser-spacepacket@ /opt/iobroker/node_modules/@serialport/parser-spacepacket
    npm error extraneous: @serialport/stream@ /opt/iobroker/node_modules/@serialport/stream
    npm error extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/@sinonjs/commons
    npm error extraneous: @sinonjs/fake-timers@ /opt/iobroker/node_modules/@sinonjs/fake-timers
    npm error extraneous: @sinonjs/samsam@ /opt/iobroker/node_modules/@sinonjs/samsam
    npm error extraneous: @smithy/abort-controller@ /opt/iobroker/node_modules/@smithy/abort-controller
    npm error extraneous: @smithy/config-resolver@ /opt/iobroker/node_modules/@smithy/config-resolver
    npm error extraneous: @smithy/core@ /opt/iobroker/node_modules/@smithy/core
    npm error extraneous: @smithy/credential-provider-imds@ /opt/iobroker/node_modules/@smithy/credential-provider-imds
    npm error extraneous: @smithy/fetch-http-handler@ /opt/iobroker/node_modules/@smithy/fetch-http-handler
    npm error extraneous: @smithy/hash-node@ /opt/iobroker/node_modules/@smithy/hash-node
    npm error extraneous: @smithy/invalid-dependency@ /opt/iobroker/node_modules/@smithy/invalid-dependency
    npm error extraneous: @smithy/is-array-buffer@ /opt/iobroker/node_modules/@smithy/is-array-buffer
    npm error extraneous: @smithy/middleware-content-length@ /opt/iobroker/node_modules/@smithy/middleware-content-length
    npm error extraneous: @smithy/middleware-endpoint@ /opt/iobroker/node_modules/@smithy/middleware-endpoint
    npm error extraneous: @smithy/middleware-retry@ /opt/iobroker/node_modules/@smithy/middleware-retry
    npm error extraneous: @smithy/middleware-serde@ /opt/iobroker/node_modules/@smithy/middleware-serde
    npm error extraneous: @smithy/middleware-stack@ /opt/iobroker/node_modules/@smithy/middleware-stack
    npm error extraneous: @smithy/node-config-provider@ /opt/iobroker/node_modules/@smithy/node-config-provider
    npm error extraneous: @smithy/node-http-handler@ /opt/iobroker/node_modules/@smithy/node-http-handler
    npm error extraneous: @smithy/property-provider@ /opt/iobroker/node_modules/@smithy/property-provider
    npm error extraneous: @smithy/protocol-http@ /opt/iobroker/node_modules/@smithy/protocol-http
    npm error extraneous: @smithy/querystring-builder@ /opt/iobroker/node_modules/@smithy/querystring-builder
    npm error extraneous: @smithy/querystring-parser@ /opt/iobroker/node_modules/@smithy/querystring-parser
    npm error extraneous: @smithy/service-error-classification@ /opt/iobroker/node_modules/@smithy/service-error-classification
    npm error extraneous: @smithy/shared-ini-file-loader@ /opt/iobroker/node_modules/@smithy/shared-ini-file-loader
    npm error extraneous: @smithy/signature-v4@ /opt/iobroker/node_modules/@smithy/signature-v4
    npm error extraneous: @smithy/smithy-client@ /opt/iobroker/node_modules/@smithy/smithy-client
    npm error extraneous: @smithy/types@ /opt/iobroker/node_modules/@smithy/types
    npm error extraneous: @smithy/url-parser@ /opt/iobroker/node_modules/@smithy/url-parser
    npm error extraneous: @smithy/util-base64@ /opt/iobroker/node_modules/@smithy/util-base64
    npm error extraneous: @smithy/util-body-length-browser@ /opt/iobroker/node_modules/@smithy/util-body-length-browser
    npm error extraneous: @smithy/util-body-length-node@ /opt/iobroker/node_modules/@smithy/util-body-length-node
    npm error extraneous: @smithy/util-buffer-from@ /opt/iobroker/node_modules/@smithy/util-buffer-from
    npm error extraneous: @smithy/util-config-provider@ /opt/iobroker/node_modules/@smithy/util-config-provider
    npm error extraneous: @smithy/util-defaults-mode-browser@ /opt/iobroker/node_modules/@smithy/util-defaults-mode-browser
    npm error extraneous: @smithy/util-defaults-mode-node@ /opt/iobroker/node_modules/@smithy/util-defaults-mode-node
    npm error extraneous: @smithy/util-endpoints@ /opt/iobroker/node_modules/@smithy/util-endpoints
    npm error extraneous: @smithy/util-hex-encoding@ /opt/iobroker/node_modules/@smithy/util-hex-encoding
    npm error extraneous: @smithy/util-middleware@ /opt/iobroker/node_modules/@smithy/util-middleware
    npm error extraneous: @smithy/util-retry@ /opt/iobroker/node_modules/@smithy/util-retry
    npm error extraneous: @smithy/util-stream@ /opt/iobroker/node_modules/@smithy/util-stream
    npm error extraneous: @smithy/util-uri-escape@ /opt/iobroker/node_modules/@smithy/util-uri-escape
    npm error extraneous: @smithy/util-utf8@ /opt/iobroker/node_modules/@smithy/util-utf8
    npm error extraneous: @smithy/uuid@ /opt/iobroker/node_modules/@smithy/uuid
    npm error extraneous: @so-ric/colorspace@ /opt/iobroker/node_modules/@so-ric/colorspace
    npm error extraneous: @socket.io/component-emitter@ /opt/iobroker/node_modules/@socket.io/component-emitter
    npm error extraneous: @stoprocent/bluetooth-hci-socket@ /opt/iobroker/node_modules/@stoprocent/bluetooth-hci-socket
    npm error extraneous: @stoprocent/noble@ /opt/iobroker/node_modules/@stoprocent/noble
    npm error extraneous: @tediousjs/connection-string@ /opt/iobroker/node_modules/@tediousjs/connection-string
    npm error extraneous: @tootallnate/once@ /opt/iobroker/node_modules/@tootallnate/once
    npm error extraneous: @types/body-parser@ /opt/iobroker/node_modules/@types/body-parser
    npm error extraneous: @types/caseless@ /opt/iobroker/node_modules/@types/caseless
    npm error extraneous: @types/chai-as-promised@ /opt/iobroker/node_modules/@types/chai-as-promised
    npm error extraneous: @types/chai@ /opt/iobroker/node_modules/@types/chai
    npm error extraneous: @types/connect@ /opt/iobroker/node_modules/@types/connect
    npm error extraneous: @types/cors@ /opt/iobroker/node_modules/@types/cors
    npm error extraneous: @types/express-serve-static-core@ /opt/iobroker/node_modules/@types/express-serve-static-core
    npm error extraneous: @types/express@ /opt/iobroker/node_modules/@types/express
    npm error extraneous: @types/http-errors@ /opt/iobroker/node_modules/@types/http-errors
    npm error extraneous: @types/http-proxy@ /opt/iobroker/node_modules/@types/http-proxy
    npm error extraneous: @types/jsonwebtoken@ /opt/iobroker/node_modules/@types/jsonwebtoken
    npm error extraneous: @types/long@ /opt/iobroker/node_modules/@types/long
    npm error extraneous: @types/luxon@ /opt/iobroker/node_modules/@types/luxon
    npm error extraneous: @types/mime@ /opt/iobroker/node_modules/@types/mime
    npm error extraneous: @types/mocha@ /opt/iobroker/node_modules/@types/mocha
    npm error extraneous: @types/ms@ /opt/iobroker/node_modules/@types/ms
    npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
    npm error extraneous: @types/qs@ /opt/iobroker/node_modules/@types/qs
    npm error extraneous: @types/range-parser@ /opt/iobroker/node_modules/@types/range-parser
    npm error extraneous: @types/readable-stream@ /opt/iobroker/node_modules/@types/readable-stream
    npm error extraneous: @types/request@ /opt/iobroker/node_modules/@types/request
    npm error extraneous: @types/send@ /opt/iobroker/node_modules/@types/send
    npm error extraneous: @types/serve-static@ /opt/iobroker/node_modules/@types/serve-static
    npm error extraneous: @types/sinon-chai@ /opt/iobroker/node_modules/@types/sinon-chai
    npm error extraneous: @types/sinon@ /opt/iobroker/node_modules/@types/sinon
    npm error extraneous: @types/sinonjs__fake-timers@ /opt/iobroker/node_modules/@types/sinonjs__fake-timers
    npm error extraneous: @types/tough-cookie@ /opt/iobroker/node_modules/@types/tough-cookie
    npm error extraneous: @types/triple-beam@ /opt/iobroker/node_modules/@types/triple-beam
    npm error extraneous: @types/w3c-web-usb@ /opt/iobroker/node_modules/@types/w3c-web-usb
    npm error extraneous: @types/ws@ /opt/iobroker/node_modules/@types/ws
    npm error extraneous: @typespec/ts-http-runtime@ /opt/iobroker/node_modules/@typespec/ts-http-runtime
    npm error extraneous: @yarnpkg/lockfile@ /opt/iobroker/node_modules/@yarnpkg/lockfile
    npm error extraneous: abbrev@ /opt/iobroker/node_modules/abbrev
    npm error extraneous: abort-controller@ /opt/iobroker/node_modules/abort-controller
    npm error extraneous: accepts@ /opt/iobroker/node_modules/accepts
    npm error extraneous: acorn-globals@ /opt/iobroker/node_modules/acorn-globals
    npm error extraneous: acorn@ /opt/iobroker/node_modules/acorn
    npm error extraneous: after@ /opt/iobroker/node_modules/after
    npm error extraneous: agent-base@ /opt/iobroker/node_modules/agent-base
    npm error extraneous: agentkeepalive@ /opt/iobroker/node_modules/agentkeepalive
    npm error extraneous: aggregate-error@ /opt/iobroker/node_modules/aggregate-error
    npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
    npm error extraneous: alcalzone-shared@ /opt/iobroker/node_modules/alcalzone-shared
    npm error extraneous: ansi-align@ /opt/iobroker/node_modules/ansi-align
    npm error extraneous: ansi-colors@ /opt/iobroker/node_modules/ansi-colors
    npm error extraneous: ansi-regex@ /opt/iobroker/node_modules/ansi-regex
    npm error extraneous: ansi-styles@ /opt/iobroker/node_modules/ansi-styles
    npm error extraneous: anymatch@ /opt/iobroker/node_modules/anymatch
    npm error extraneous: aproba@ /opt/iobroker/node_modules/aproba
    npm error extraneous: archiver-utils@ /opt/iobroker/node_modules/archiver-utils
    npm error extraneous: archiver@ /opt/iobroker/node_modules/archiver
    npm error extraneous: are-we-there-yet@ /opt/iobroker/node_modules/are-we-there-yet
    npm error extraneous: argf@ /opt/iobroker/node_modules/argf
    npm error extraneous: argparse@ /opt/iobroker/node_modules/argparse
    npm error extraneous: array-buffer-byte-length@ /opt/iobroker/node_modules/array-buffer-byte-length
    npm error extraneous: array-find@ /opt/iobroker/node_modules/array-find
    npm error extraneous: array-flatten@ /opt/iobroker/node_modules/array-flatten
    npm error extraneous: array.prototype.findindex@ /opt/iobroker/node_modules/array.prototype.findindex
    npm error extraneous: arraybuffer.prototype.slice@ /opt/iobroker/node_modules/arraybuffer.prototype.slice
    npm error extraneous: arraybuffer.slice@ /opt/iobroker/node_modules/arraybuffer.slice
    npm error extraneous: asn1@ /opt/iobroker/node_modules/asn1
    npm error extraneous: assert-plus@ /opt/iobroker/node_modules/assert-plus
    npm error extraneous: assertion-error@ /opt/iobroker/node_modules/assertion-error
    npm error extraneous: astral-regex@ /opt/iobroker/node_modules/astral-regex
    npm error extraneous: async-each-series@ /opt/iobroker/node_modules/async-each-series
    npm error extraneous: async-function@ /opt/iobroker/node_modules/async-function
    npm error extraneous: async-limiter@ /opt/iobroker/node_modules/async-limiter
    npm error extraneous: async@ /opt/iobroker/node_modules/async
    npm error extraneous: asynckit@ /opt/iobroker/node_modules/asynckit
    npm error extraneous: authenticate-pam@ /opt/iobroker/node_modules/authenticate-pam
    npm error extraneous: available-typed-arrays@ /opt/iobroker/node_modules/available-typed-arrays
    npm error extraneous: aws-iot-device-sdk@ /opt/iobroker/node_modules/aws-iot-device-sdk
    npm error extraneous: aws-sign2@ /opt/iobroker/node_modules/aws-sign2
    npm error extraneous: aws-ssl-profiles@ /opt/iobroker/node_modules/aws-ssl-profiles
    npm error extraneous: aws4@ /opt/iobroker/node_modules/aws4
    npm error extraneous: axios@ /opt/iobroker/node_modules/axios
    npm error extraneous: b4a@ /opt/iobroker/node_modules/b4a
    npm error extraneous: backo2@ /opt/iobroker/node_modules/backo2
    npm error extraneous: balanced-match@ /opt/iobroker/node_modules/balanced-match
    npm error extraneous: bare-events@ /opt/iobroker/node_modules/bare-events
    npm error extraneous: base-64@ /opt/iobroker/node_modules/base-64
    npm error extraneous: base64-arraybuffer@ /opt/iobroker/node_modules/base64-arraybuffer
    npm error extraneous: base64-js@ /opt/iobroker/node_modules/base64-js
    npm error extraneous: base64id@ /opt/iobroker/node_modules/base64id
    npm error extraneous: basic-auth@ /opt/iobroker/node_modules/basic-auth
    npm error extraneous: batch@ /opt/iobroker/node_modules/batch
    npm error extraneous: bcrypt-pbkdf@ /opt/iobroker/node_modules/bcrypt-pbkdf
    npm error extraneous: better-assert@ /opt/iobroker/node_modules/better-assert
    npm error extraneous: bignumber.js@ /opt/iobroker/node_modules/bignumber.js
    npm error extraneous: binary-extensions@ /opt/iobroker/node_modules/binary-extensions
    npm error extraneous: binary@ /opt/iobroker/node_modules/binary
    npm error extraneous: bindings@ /opt/iobroker/node_modules/bindings
    npm error extraneous: binrpc@ /opt/iobroker/node_modules/binrpc
    npm error extraneous: bl@ /opt/iobroker/node_modules/bl
    npm error extraneous: blob@ /opt/iobroker/node_modules/blob
    npm error extraneous: bluebird-co@ /opt/iobroker/node_modules/bluebird-co
    npm error extraneous: bluebird@ /opt/iobroker/node_modules/bluebird
    npm error extraneous: bluetooth-hci-socket@ /opt/iobroker/node_modules/bluetooth-hci-socket
    npm error extraneous: body-parser@ /opt/iobroker/node_modules/body-parser
    npm error extraneous: boolbase@ /opt/iobroker/node_modules/boolbase
    npm error extraneous: bower@ /opt/iobroker/node_modules/bower
    npm error extraneous: bowser@ /opt/iobroker/node_modules/bowser
    npm error extraneous: boxen@ /opt/iobroker/node_modules/boxen
    npm error extraneous: bplist-parser@ /opt/iobroker/node_modules/bplist-parser
    npm error extraneous: brace-expansion@ /opt/iobroker/node_modules/brace-expansion
    npm error extraneous: braces@ /opt/iobroker/node_modules/braces
    npm error extraneous: broker-factory@ /opt/iobroker/node_modules/broker-factory
    npm error extraneous: browser-request@ /opt/iobroker/node_modules/browser-request
    npm error extraneous: browser-stdout@ /opt/iobroker/node_modules/browser-stdout
    npm error extraneous: browser-sync-client@ /opt/iobroker/node_modules/browser-sync-client
    npm error extraneous: browser-sync-ui@ /opt/iobroker/node_modules/browser-sync-ui
    npm error extraneous: browser-sync@ /opt/iobroker/node_modules/browser-sync
    npm error extraneous: bs-html-injector@ /opt/iobroker/node_modules/bs-html-injector
    npm error extraneous: bs-recipes@ /opt/iobroker/node_modules/bs-recipes
    npm error extraneous: buffer-crc32@ /opt/iobroker/node_modules/buffer-crc32
    npm error extraneous: buffer-equal-constant-time@ /opt/iobroker/node_modules/buffer-equal-constant-time
    npm error extraneous: buffer-from@ /opt/iobroker/node_modules/buffer-from
    npm error extraneous: buffer@ /opt/iobroker/node_modules/buffer
    npm error extraneous: buffers@ /opt/iobroker/node_modules/buffers
    npm error extraneous: buildcheck@ /opt/iobroker/node_modules/buildcheck
    npm error extraneous: busboy@ /opt/iobroker/node_modules/busboy
    npm error extraneous: bytes@ /opt/iobroker/node_modules/bytes
    npm error extraneous: cacache@ /opt/iobroker/node_modules/cacache
    npm error extraneous: call-bind-apply-helpers@ /opt/iobroker/node_modules/call-bind-apply-helpers
    npm error extraneous: call-bind@ /opt/iobroker/node_modules/call-bind
    npm error extraneous: call-bound@ /opt/iobroker/node_modules/call-bound
    npm error extraneous: callsite@ /opt/iobroker/node_modules/callsite
    npm error extraneous: camelcase@ /opt/iobroker/node_modules/camelcase
    npm error extraneous: canvas@ /opt/iobroker/node_modules/canvas
    npm error extraneous: caseless@ /opt/iobroker/node_modules/caseless
    npm error extraneous: castv2-client@ /opt/iobroker/node_modules/castv2-client
    npm error extraneous: castv2-player@ /opt/iobroker/node_modules/castv2-player
    npm error extraneous: castv2@ /opt/iobroker/node_modules/castv2
    npm error extraneous: chai-as-promised@ /opt/iobroker/node_modules/chai-as-promised
    npm error extraneous: chai@ /opt/iobroker/node_modules/chai
    npm error extraneous: chainsaw@ /opt/iobroker/node_modules/chainsaw
    npm error extraneous: chalk@ /opt/iobroker/node_modules/chalk
    npm error extraneous: char-spinner@ /opt/iobroker/node_modules/char-spinner
    npm error extraneous: check-error@ /opt/iobroker/node_modules/check-error
    npm error extraneous: cheerio-select@ /opt/iobroker/node_modules/cheerio-select
    npm error extraneous: cheerio@ /opt/iobroker/node_modules/cheerio
    npm error extraneous: chokidar@ /opt/iobroker/node_modules/chokidar
    npm error extraneous: chownr@ /opt/iobroker/node_modules/chownr
    npm error extraneous: ci-info@ /opt/iobroker/node_modules/ci-info
    npm error extraneous: clean-stack@ /opt/iobroker/node_modules/clean-stack
    npm error extraneous: cli-boxes@ /opt/iobroker/node_modules/cli-boxes
    npm error extraneous: cliui@ /opt/iobroker/node_modules/cliui
    npm error extraneous: cluster-key-slot@ /opt/iobroker/node_modules/cluster-key-slot
    npm error extraneous: co-bluebird@ /opt/iobroker/node_modules/co-bluebird
    npm error extraneous: co-use@ /opt/iobroker/node_modules/co-use
    npm error extraneous: code-point-at@ /opt/iobroker/node_modules/code-point-at
    npm error extraneous: color-convert@ /opt/iobroker/node_modules/color-convert
    npm error extraneous: color-name@ /opt/iobroker/node_modules/color-name
    npm error extraneous: color-string@ /opt/iobroker/node_modules/color-string
    npm error extraneous: color-support@ /opt/iobroker/node_modules/color-support
    npm error extraneous: color@ /opt/iobroker/node_modules/color
    npm error invalid: colors@ /opt/iobroker/node_modules/colors
    npm error extraneous: combined-stream@ /opt/iobroker/node_modules/combined-stream
    npm error extraneous: commander@ /opt/iobroker/node_modules/commander
    npm error extraneous: commist@ /opt/iobroker/node_modules/commist
    npm error extraneous: component-bind@ /opt/iobroker/node_modules/component-bind
    npm error extraneous: component-emitter@ /opt/iobroker/node_modules/component-emitter
    npm error extraneous: component-inherit@ /opt/iobroker/node_modules/component-inherit
    npm error extraneous: compress-commons@ /opt/iobroker/node_modules/compress-commons
    npm error extraneous: compressible@ /opt/iobroker/node_modules/compressible
    npm error extraneous: compression@ /opt/iobroker/node_modules/compression
    npm error extraneous: concat-map@ /opt/iobroker/node_modules/concat-map
    npm error extraneous: concat-stream@ /opt/iobroker/node_modules/concat-stream
    npm error extraneous: connect-flash@ /opt/iobroker/node_modules/connect-flash
    npm error extraneous: connect-history-api-fallback@ /opt/iobroker/node_modules/connect-history-api-fallback
    npm error extraneous: connect@ /opt/iobroker/node_modules/connect
    npm error extraneous: console-control-strings@ /opt/iobroker/node_modules/console-control-strings
    npm error extraneous: content-disposition@ /opt/iobroker/node_modules/content-disposition
    npm error extraneous: content-type@ /opt/iobroker/node_modules/content-type
    npm error extraneous: cookie-parser@ /opt/iobroker/node_modules/cookie-parser
    npm error extraneous: cookie-signature@ /opt/iobroker/node_modules/cookie-signature
    npm error extraneous: cookie@ /opt/iobroker/node_modules/cookie
    npm error extraneous: core-util-is@ /opt/iobroker/node_modules/core-util-is
    npm error extraneous: cors@ /opt/iobroker/node_modules/cors
    npm error extraneous: country-data@ /opt/iobroker/node_modules/country-data
    npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
    npm error extraneous: crc-32@ /opt/iobroker/node_modules/crc-32
    npm error extraneous: crc32-stream@ /opt/iobroker/node_modules/crc32-stream
    npm error extraneous: cron-parser@ /opt/iobroker/node_modules/cron-parser
    npm error extraneous: cron@ /opt/iobroker/node_modules/cron
    npm error extraneous: cross-spawn@ /opt/iobroker/node_modules/cross-spawn
    npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
    npm error extraneous: css-select@ /opt/iobroker/node_modules/css-select
    npm error extraneous: css-what@ /opt/iobroker/node_modules/css-what
    npm error extraneous: cssom@ /opt/iobroker/node_modules/cssom
    npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
    npm error extraneous: currency-symbol-map@ /opt/iobroker/node_modules/currency-symbol-map
    npm error extraneous: cycle@ /opt/iobroker/node_modules/cycle
    npm error extraneous: dashdash@ /opt/iobroker/node_modules/dashdash
    npm error extraneous: data-view-buffer@ /opt/iobroker/node_modules/data-view-buffer
    npm error extraneous: data-view-byte-length@ /opt/iobroker/node_modules/data-view-byte-length
    npm error extraneous: data-view-byte-offset@ /opt/iobroker/node_modules/data-view-byte-offset
    npm error extraneous: dateformat@ /opt/iobroker/node_modules/dateformat
    npm error extraneous: dbus-next@ /opt/iobroker/node_modules/dbus-next
    npm error extraneous: debug@ /opt/iobroker/node_modules/debug
    npm error extraneous: decache@ /opt/iobroker/node_modules/decache
    npm error extraneous: decamelize@ /opt/iobroker/node_modules/decamelize
    npm error extraneous: decompress-response@ /opt/iobroker/node_modules/decompress-response
    npm error extraneous: deep-clone@ /opt/iobroker/node_modules/deep-clone
    npm error extraneous: deep-eql@ /opt/iobroker/node_modules/deep-eql
    npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
    npm error extraneous: deep-is@ /opt/iobroker/node_modules/deep-is
    npm error extraneous: define-data-property@ /opt/iobroker/node_modules/define-data-property
    npm error extraneous: define-lazy-prop@ /opt/iobroker/node_modules/define-lazy-prop
    npm error extraneous: define-properties@ /opt/iobroker/node_modules/define-properties
    npm error extraneous: delayed-stream@ /opt/iobroker/node_modules/delayed-stream
    npm error extraneous: delegates@ /opt/iobroker/node_modules/delegates
    npm error extraneous: denque@ /opt/iobroker/node_modules/denque
    npm error extraneous: depd@ /opt/iobroker/node_modules/depd
    npm error extraneous: destroy@ /opt/iobroker/node_modules/destroy
    npm error extraneous: detect-libc@ /opt/iobroker/node_modules/detect-libc
    npm error extraneous: dev-ip@ /opt/iobroker/node_modules/dev-ip
    npm error extraneous: dev-null@ /opt/iobroker/node_modules/dev-null
    npm error extraneous: dgram@ /opt/iobroker/node_modules/dgram
    npm error extraneous: diff@ /opt/iobroker/node_modules/diff
    npm error extraneous: diskusage@ /opt/iobroker/node_modules/diskusage
    npm error extraneous: dns-packet@ /opt/iobroker/node_modules/dns-packet
    npm error extraneous: docker-modem@ /opt/iobroker/node_modules/docker-modem
    npm error extraneous: dockerode@ /opt/iobroker/node_modules/dockerode
    npm error extraneous: dom-compare-temp@ /opt/iobroker/node_modules/dom-compare-temp
    npm error extraneous: dom-serializer@ /opt/iobroker/node_modules/dom-serializer
    npm error extraneous: domelementtype@ /opt/iobroker/node_modules/domelementtype
    npm error extraneous: domhandler@ /opt/iobroker/node_modules/domhandler
    npm error extraneous: domutils@ /opt/iobroker/node_modules/domutils
    npm error extraneous: dunder-proto@ /opt/iobroker/node_modules/dunder-proto
    npm error extraneous: duplexer@ /opt/iobroker/node_modules/duplexer
    npm error extraneous: duplexify@ /opt/iobroker/node_modules/duplexify
    npm error extraneous: eastasianwidth@ /opt/iobroker/node_modules/eastasianwidth
    npm error extraneous: easy-extender@ /opt/iobroker/node_modules/easy-extender
    npm error extraneous: eazy-logger@ /opt/iobroker/node_modules/eazy-logger
    npm error extraneous: ecc-jsbn@ /opt/iobroker/node_modules/ecc-jsbn
    npm error extraneous: ecdsa-sig-formatter@ /opt/iobroker/node_modules/ecdsa-sig-formatter
    npm error extraneous: ee-first@ /opt/iobroker/node_modules/ee-first
    npm error extraneous: emoji-regex@ /opt/iobroker/node_modules/emoji-regex
    npm error extraneous: enabled@ /opt/iobroker/node_modules/enabled
    npm error extraneous: encodeurl@ /opt/iobroker/node_modules/encodeurl
    npm error extraneous: encoding-sniffer@ /opt/iobroker/node_modules/encoding-sniffer
    npm error extraneous: encoding@ /opt/iobroker/node_modules/encoding
    npm error extraneous: end-of-stream@ /opt/iobroker/node_modules/end-of-stream
    npm error extraneous: engine.io-client@ /opt/iobroker/node_modules/engine.io-client
    npm error extraneous: engine.io-parser@ /opt/iobroker/node_modules/engine.io-parser
    npm error extraneous: engine.io@ /opt/iobroker/node_modules/engine.io
    npm error extraneous: enquirer@ /opt/iobroker/node_modules/enquirer
    npm error extraneous: entities@ /opt/iobroker/node_modules/entities
    npm error extraneous: env-paths@ /opt/iobroker/node_modules/env-paths
    npm error extraneous: err-code@ /opt/iobroker/node_modules/err-code
    npm error extraneous: error-ex@ /opt/iobroker/node_modules/error-ex
    npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
    npm error extraneous: es-aggregate-error@ /opt/iobroker/node_modules/es-aggregate-error
    npm error extraneous: es-define-property@ /opt/iobroker/node_modules/es-define-property
    npm error extraneous: es-errors@ /opt/iobroker/node_modules/es-errors
    • G George_Best
      1. npm ls:
      cd /opt/iobroker
      npm ls
      npm ls graceful-fs
      ── component-inherit@ extraneous
      ├── compress-commons@ extraneous
      ├── compressible@ extraneous
      ├── compression@ extraneous
      ├── concat-map@ extraneous
      ├── concat-stream@ extraneous
      ├── connect-flash@ extraneous
      ├── connect-history-api-fallback@ extraneous
      ├── connect@ extraneous
      ├── console-control-strings@ extraneous
      ├── content-disposition@ extraneous
      ├── content-type@ extraneous
      ├── cookie-parser@ extraneous
      ├── cookie-signature@ extraneous
      ├── cookie@ extraneous
      ├── core-util-is@ extraneous
      ├── cors@ extraneous
      ├── country-data@ extraneous
      ├── cpu-features@ extraneous
      ├── crc-32@ extraneous
      ├── crc32-stream@ extraneous
      ├── cron-parser@ extraneous
      ├── cron@ extraneous
      ├── cross-spawn@ extraneous
      ├── crypto-js@ extraneous
      ├── css-select@ extraneous
      ├── css-what@ extraneous
      ├── cssom@ extraneous
      ├── cssstyle@ extraneous
      ├── currency-symbol-map@ extraneous
      ├── cycle@ extraneous
      ├── dashdash@ extraneous
      ├── data-view-buffer@ extraneous
      ├── data-view-byte-length@ extraneous
      ├── data-view-byte-offset@ extraneous
      ├── dateformat@ extraneous
      ├── dbus-next@ extraneous
      ├── debug@ extraneous
      ├── decache@ extraneous
      ├── decamelize@ extraneous
      ├── decompress-response@ extraneous
      ├── deep-clone@ extraneous
      ├── deep-eql@ extraneous
      ├── deep-extend@0.6.0 extraneous
      ├── deep-is@ extraneous
      ├── define-data-property@ extraneous
      ├── define-lazy-prop@ extraneous
      ├── define-properties@ extraneous
      ├── delayed-stream@ extraneous
      ├── delegates@ extraneous
      ├── denque@ extraneous
      ├── depd@ extraneous
      ├── destroy@ extraneous
      ├── detect-libc@ extraneous
      ├── dev-ip@ extraneous
      ├── dev-null@ extraneous
      ├── dgram@ extraneous
      ├── diff@ extraneous
      ├── diskusage@ extraneous
      ├── dns-packet@ extraneous
      ├── docker-modem@ extraneous
      ├── dockerode@ extraneous
      ├── dom-compare-temp@ extraneous
      ├── dom-serializer@ extraneous
      ├── domelementtype@ extraneous
      ├── domhandler@ extraneous
      ├── domutils@ extraneous
      ├── dunder-proto@ extraneous
      ├── duplexer@ extraneous
      ├── duplexify@ extraneous
      ├── eastasianwidth@ extraneous
      ├── easy-extender@ extraneous
      ├── eazy-logger@ extraneous
      ├── ecc-jsbn@ extraneous
      ├── ecdsa-sig-formatter@ extraneous
      ├── ee-first@ extraneous
      ├── emoji-regex@ extraneous
      ├── enabled@ extraneous
      ├── encodeurl@ extraneous
      ├── encoding-sniffer@ extraneous
      ├── encoding@ extraneous
      ├── end-of-stream@ extraneous
      ├── engine.io-client@ extraneous
      ├── engine.io-parser@ extraneous
      ├── engine.io@ extraneous
      ├── enquirer@ extraneous
      ├── entities@ extraneous
      ├── env-paths@ extraneous
      ├── err-code@ extraneous
      ├── error-ex@ extraneous
      ├── es-abstract@ extraneous
      ├── es-aggregate-error@ extraneous
      ├── es-define-property@ extraneous
      ├── es-errors@ extraneous
      ├── es-object-atoms@ extraneous
      ├── es-set-tostringtag@ extraneous
      ├── es-shim-unscopables@ extraneous
      ├── es-to-primitive@ extraneous
      ├── es6-promise@ extraneous
      ├── esbuild@ extraneous
      ├── escalade@ extraneous
      ├── escape-html@ extraneous
      ├── escape-string-regexp@ extraneous
      ├── escodegen@ extraneous
      ├── esprima@ extraneous
      ├── estraverse@ extraneous
      ├── esutils@ extraneous
      ├── etag@ extraneous
      ├── event-stream@ extraneous
      ├── event-target-shim@ extraneous
      ├── eventemitter2@ extraneous
      ├── eventemitter3@ extraneous
      ├── events-universal@ extraneous
      ├── events@ extraneous
      ├── evilscan@ extraneous
      ├── execa@ extraneous
      ├── expand-template@ extraneous
      ├── exponential-backoff@ extraneous
      ├── express-fileupload@ extraneous
      ├── express-session@ extraneous
      ├── express@ extraneous
      ├── extend@3.0.2 extraneous
      ├── extsprintf@ extraneous
      ├── eyes@ extraneous
      ├── fast-deep-equal@ extraneous
      ├── fast-fifo@ extraneous
      ├── fast-glob@ extraneous
      ├── fast-json-stable-stringify@ extraneous
      ├── fast-levenshtein@ extraneous
      ├── fast-unique-numbers@ extraneous
      ├── fast-uri@ extraneous
      ├── fast-xml-parser@ extraneous
      ├── fastq@ extraneous
      ├── fecha@ extraneous
      ├── fetch-enhanced@ extraneous
      ├── file-stream-rotator@ extraneous
      ├── file-type@ extraneous
      ├── file-uri-to-path@ extraneous
      ├── fill-range@ extraneous
      ├── finalhandler@ extraneous
      ├── find-up@ extraneous
      ├── find-yarn-workspace-root@ extraneous
      ├── flat@ extraneous
      ├── fn.name@ extraneous
      ├── follow-redirects@ extraneous
      ├── for-each@ extraneous
      ├── foreground-child@ extraneous
      ├── forever-agent@ extraneous
      ├── form-data@ extraneous
      ├── forwarded@ extraneous
      ├── fresh@ extraneous
      ├── from@ extraneous
      ├── fs-constants@1.0.0 extraneous
      ├── fs-extra@7.0.1
      ├── fs-minipass@ extraneous
      ├── fs.realpath@ extraneous
      ├── fsevents@ extraneous
      ├── ftp-response-parser@ extraneous
      ├── function-bind@ extraneous
      ├── function.prototype.name@ extraneous
      ├── functions-have-names@ extraneous
      ├── gauge@ extraneous
      ├── gaxios@ extraneous
      ├── gcp-metadata@ extraneous
      ├── generate-function@ extraneous
      ├── generator-function@ extraneous
      ├── get-caller-file@1.0.3 extraneous
      ├── get-func-name@ extraneous
      ├── get-intrinsic@ extraneous
      ├── get-proto@ extraneous
      ├── get-stream@ extraneous
      ├── get-symbol-description@ extraneous
      ├── getpass@ extraneous
      ├── github-from-package@ extraneous
      ├── glob-parent@ extraneous
      ├── glob@ extraneous
      ├── globalthis@ extraneous
      ├── glossy@ extraneous
      ├── google-auth-library@ extraneous
      ├── google-logging-utils@ extraneous
      ├── google-tts-api@ extraneous
      ├── googleapis-common@ extraneous
      ├── googleapis@ extraneous
      ├── gopd@ extraneous
      ├── gtoken@ extraneous
      ├── har-schema@ extraneous
      ├── har-validator@ extraneous
      ├── has-bigints@ extraneous
      ├── has-binary@ extraneous
      ├── has-binary2@1.0.3 extraneous
      ├── has-cors@ extraneous
      ├── has-flag@ extraneous
      ├── has-property-descriptors@ extraneous
      ├── has-proto@ extraneous
      ├── has-symbols@ extraneous
      ├── has-tostringtag@ extraneous
      ├── has-unicode@ extraneous
      ├── hasown@ extraneous
      ├── he@ extraneous
      ├── help-me@ extraneous
      ├── hexy@ extraneous
      ├── homematic-xmlrpc@ extraneous
      ├── hosted-git-info@ extraneous
      ├── htmlparser2@ extraneous
      ├── http-cache-semantics@ extraneous
      ├── http-errors@ extraneous
      ├── http-proxy-agent@ extraneous
      ├── http-proxy-middleware@ extraneous
      ├── http-proxy@ extraneous
      ├── http-signature@ extraneous
      ├── https-proxy-agent@ extraneous
      ├── https@ extraneous
      ├── human-signals@ extraneous
      ├── humanize-ms@ extraneous
      ├── iconv-lite@ extraneous
      ├── icy@ extraneous
      ├── ieee754@ extraneous
      ├── ignore-by-default@ extraneous
      ├── immediate@ extraneous
      ├── immutable@ extraneous
      ├── imurmurhash@ extraneous
      ├── indent-string@ extraneous
      ├── indexof@ extraneous
      ├── infer-owner@ extraneous
      ├── inflight@ extraneous
      ├── influx@ extraneous
      ├── inherits@ extraneous
      ├── ini@ extraneous
      ├── int64-buffer@ extraneous
      ├── internal-slot@ extraneous
      ├── invert-kv@ extraneous
      ├── iobroker.accuweather@ invalid: "2.1.1" from the root project
      ├── iobroker.admin@ invalid: "7.7.19" from the root project
      ├── iobroker.alias-manager@ invalid: "2.0.0" from the root project
      ├── iobroker.amazon-dash@ invalid: "1.2.0" from the root project
      ├── iobroker.chromecast@ invalid: "4.0.0" from the root project
      ├── iobroker.cloud@ invalid: "5.0.1" from the root project
      ├── iobroker.daswetter@ invalid: "3.2.3" from the root project
      ├── iobroker.deconz@ invalid: "1.6.4" from the root project
      ├── iobroker.devices@ invalid: "1.2.8" from the root project
      ├── iobroker.discovery@ invalid: "5.0.0" from the root project
      ├── iobroker.email@ invalid: "2.0.4" from the root project
      ├── iobroker.flot@ invalid: "1.12.0" from the root project
      ├── iobroker.fronius-solarweb@ invalid: "0.0.3" from the root project
      ├── iobroker.fronius@ invalid: "2.1.1" from the root project
      ├── iobroker.frontier_silicon@ invalid: "0.5.0" from the root project
      ├── iobroker.habpanel@ invalid: "0.5.0" from the root project
      ├── iobroker.history@ invalid: "3.0.1" from the root project
      ├── iobroker.hm-rega@ invalid: "5.1.0" from the root project
      ├── iobroker.hm-rpc@ invalid: "2.0.2" from the root project
      ├── iobroker.hs100@ invalid: "3.0.5" from the root project
      ├── iobroker.icons-addictive-flavour-png@ invalid: "^0.1.0" from the root project
      ├── iobroker.icons-fatcow-hosting@ invalid: "^0.1.0" from the root project
      ├── iobroker.icons-icons8@ invalid: "0.0.1" from the root project
      ├── iobroker.icons-material-png@ invalid: "^0.1.0" from the root project
      ├── iobroker.icons-material-svg@ invalid: "^0.1.0" from the root project
      ├── iobroker.icons-mfd-png@ invalid: "1.2.1" from the root project
      ├── iobroker.icons-mfd-svg@ invalid: "1.2.0" from the root project
      ├── iobroker.icons-open-icon-library-png@ invalid: "0.1.2" from the root project
      ├── iobroker.icons-ultimate-png@ invalid: "^1.0.1" from the root project
      ├── iobroker.influxdb@ invalid: "4.0.2" from the root project
      ├── iobroker.info@ invalid: "2.0.0" from the root project
      ├── iobroker.iot@ invalid: "5.0.7" from the root project
      ├── iobroker.javascript@ invalid: "8.9.2" from the root project
      ├── iobroker.js-controller@ invalid: "^7.0.7" from the root project
      ├── iobroker.mihome-vacuum@ invalid: "5.2.0" from the root project
      ├── iobroker.mqtt@ invalid: "6.1.4" from the root project
      ├── iobroker.net-tools@ invalid: "1.1.2" from the root project
      ├── iobroker.octoprint@ invalid: "5.1.0" from the root project
      ├── iobroker.openweathermap@ invalid: "1.1.2" from the root project
      ├── iobroker.parser@ invalid: "2.2.4" from the root project
      ├── iobroker.ping@ invalid: "1.6.2" from the root project
      ├── iobroker.proxmox@ invalid: "2.4.0" from the root project
      ├── iobroker.radar@ invalid: "^1.2.1" from the root project
      ├── iobroker.radar2@ invalid: "^2.0.3" from the root project
      ├── iobroker.reolink@ invalid: "1.2.3" from the root project
      ├── iobroker.rickshaw@ invalid: "^1.0.0" from the root project
      ├── iobroker.s7@ invalid: "1.5.0" from the root project
      ├── iobroker.sayit@ invalid: "5.0.0" from the root project
      ├── iobroker.smartmeter@ invalid: "3.4.0" from the root project
      ├── iobroker.socketio@ invalid: "6.7.1" from the root project
      ├── iobroker.sql@ invalid: "3.0.1" from the root project
      ├── iobroker.statistics@ invalid: "2.4.0" from the root project
      ├── iobroker.systeminfo@ invalid: "1.3.0" from the root project
      ├── iobroker.telegram@ invalid: "4.1.0" from the root project
      ├── iobroker.terminal@ invalid: "1.0.0" from the root project
      ├── iobroker.tr-064@ invalid: "4.3.0" from the root project
      ├── iobroker.unifi@ invalid: "0.7.0" from the root project
      ├── iobroker.upnp@ invalid: "1.1.0" from the root project
      ├── iobroker.vis-2-widgets-inventwo@ invalid: "0.2.2" from the root project
      ├── iobroker.vis-2-widgets-material@ invalid: "1.4.10" from the root project
      ├── iobroker.vis-2@ invalid: "2.13.4" from the root project
      ├── iobroker.vis-bars@ invalid: "^0.1.4" from the root project
      ├── iobroker.vis-canvas-gauges@ invalid: "1.0.1" from the root project
      ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
      ├── iobroker.vis-fancyswitch@ invalid: "^1.1.0" from the root project
      ├── iobroker.vis-google-fonts@ invalid: "1.0.4" from the root project
      ├── iobroker.vis-history@ invalid: "^1.0.0" from the root project
      ├── iobroker.vis-hqwidgets@ invalid: "1.5.1" from the root project
      ├── iobroker.vis-jqui-mfd@ invalid: "^1.0.12" from the root project
      ├── iobroker.vis-justgage@ invalid: "2.1.7" from the root project
      ├── iobroker.vis-keyboard@ invalid: "0.0.2" from the root project
      ├── iobroker.vis-lcars@ invalid: "1.1.1" from the root project
      ├── iobroker.vis-map@ invalid: "1.1.2" from the root project
      ├── iobroker.vis-materialdesign@ invalid: "0.5.9" from the root project
      ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
      ├── iobroker.vis-rgraph@ invalid: "0.0.2" from the root project
      ├── iobroker.vis-weather@ invalid: "2.5.12" from the root project
      ├── iobroker.vis@ invalid: "1.5.6" from the root project
      ├── iobroker.weatherunderground@ invalid: "3.7.0" from the root project
      ├── iobroker.web@ invalid: "7.0.8" from the root project
      ├── iobroker.ws@ invalid: "2.6.2" from the root project
      ├── iobroker@ invalid: "^2.0.2" from the root project
      ├── ioredis@ extraneous
      ├── ip-address@ extraneous
      ├── ip@ extraneous
      ├── ipaddr.js@ extraneous
      ├── is-arguments@ extraneous
      ├── is-array-buffer@ extraneous
      ├── is-arrayish@ extraneous
      ├── is-async-function@ extraneous
      ├── is-bigint@ extraneous
      ├── is-binary-path@ extraneous
      ├── is-boolean-object@ extraneous
      ├── is-callable@ extraneous
      ├── is-core-module@ extraneous
      ├── is-data-view@ extraneous
      ├── is-date-object@ extraneous
      ├── is-docker@ extraneous
      ├── is-extglob@ extraneous
      ├── is-finalizationregistry@ extraneous
      ├── is-fullwidth-code-point@ extraneous
      ├── is-generator-function@ extraneous
      ├── is-generator@ extraneous
      ├── is-glob@ extraneous
      ├── is-lambda@ extraneous
      ├── is-map@ extraneous
      ├── is-negative-zero@ extraneous
      ├── is-number-like@ extraneous
      ├── is-number-object@ extraneous
      ├── is-number@ extraneous
      ├── is-path-inside@ extraneous
      ├── is-plain-obj@ extraneous
      ├── is-plain-object@ extraneous
      ├── is-promise@ extraneous
      ├── is-property@ extraneous
      ├── is-regex@ extraneous
      ├── is-set@ extraneous
      ├── is-shared-array-buffer@ extraneous
      ├── is-stream@ extraneous
      ├── is-string@ extraneous
      ├── is-symbol@ extraneous
      ├── is-typed-array@ extraneous
      ├── is-typedarray@ extraneous
      ├── is-unicode-supported@ extraneous
      ├── is-utf8@ extraneous
      ├── is-weakmap@ extraneous
      ├── is-weakref@ extraneous
      ├── is-weakset@ extraneous
      ├── is-wsl@ extraneous
      ├── is@ extraneous
      ├── isarray@ extraneous
      ├── isexe@ extraneous
      ├── isomorphic-ws@ extraneous
      ├── isstream@ extraneous
      ├── jackspeak@ extraneous
      ├── jose@ extraneous
      ├── js-md4@ extraneous
      ├── js-sdsl@ extraneous
      ├── js-yaml@ extraneous
      ├── jsbi@ extraneous
      ├── jsbn@ extraneous
      ├── jsdom@ extraneous
      ├── jsftp@ extraneous
      ├── jshashes@ extraneous
      ├── json-bigint@ extraneous
      ├── json-logic-js@ extraneous
      ├── json-schema-traverse@ extraneous
      ├── json-schema@ extraneous
      ├── json-stable-stringify@ extraneous
      ├── json-stringify-safe@ extraneous
      ├── json3@ extraneous
      ├── json5@ extraneous
      ├── jsonata@ extraneous
      ├── jsonc-parser@ extraneous
      ├── jsonify@ extraneous
      ├── jsonwebtoken@ extraneous
      ├── jsprim@ extraneous
      ├── jszip@ extraneous
      ├── jwa@ extraneous
      ├── jwks-rsa@ extraneous
      ├── jws@ extraneous
      ├── klaw-sync@ extraneous
      ├── kuler@ extraneous
      ├── lazystream@ extraneous
      ├── lcid@ extraneous
      ├── leven@ extraneous
      ├── levn@ extraneous
      ├── lie@ extraneous
      ├── limiter@ extraneous
      ├── load-json-file@ extraneous
      ├── loadavg-windows@ extraneous
      ├── localforage@ extraneous
      ├── locate-path@ extraneous
      ├── lodash.camelcase@ extraneous
      ├── lodash.castarray@ extraneous
      ├── lodash.clone@ extraneous
      ├── lodash.clonedeep@ extraneous
      ├── lodash.defaults@ extraneous
      ├── lodash.defaultto@ extraneous
      ├── lodash.flatten@ extraneous
      ├── lodash.get@ extraneous
      ├── lodash.groupby@ extraneous
      ├── lodash.includes@ extraneous
      ├── lodash.isarguments@ extraneous
      ├── lodash.isboolean@ extraneous
      ├── lodash.isequal@ extraneous
      ├── lodash.isfinite@ extraneous
      ├── lodash.isinteger@ extraneous
      ├── lodash.isnumber@ extraneous
      ├── lodash.isplainobject@ extraneous
      ├── lodash.isstring@ extraneous
      ├── lodash.once@ extraneous
      ├── lodash.truncate@ extraneous
      ├── lodash@ extraneous
      ├── log-symbols@ extraneous
      ├── logform@ extraneous
      ├── loglevel@ extraneous
      ├── long-timeout@ extraneous
      ├── long@ extraneous
      ├── loupe@ extraneous
      ├── lru-cache@ extraneous
      ├── lru-memoizer@ extraneous
      ├── lru.min@ extraneous
      ├── luxon@ extraneous
      ├── make-dir@ extraneous
      ├── make-fetch-happen@ extraneous
      ├── map-stream@ extraneous
      ├── math-intrinsics@ extraneous
      ├── mdns-discovery@ extraneous
      ├── mdns@ extraneous
      ├── media-typer@ extraneous
      ├── merge-descriptors@ extraneous
      ├── merge-stream@ extraneous
      ├── merge2@ extraneous
      ├── methods@ extraneous
      ├── micromatch@ extraneous
      ├── mime-db@ extraneous
      ├── mime-types@ extraneous
      ├── mime@ extraneous
      ├── mimic-fn@ extraneous
      ├── mimic-response@ extraneous
      ├── minimatch@ extraneous
      ├── minimist@ extraneous
      ├── minipass-collect@ extraneous
      ├── minipass-fetch@ extraneous
      ├── minipass-flush@ extraneous
      ├── minipass-pipeline@ extraneous
      ├── minipass-sized@ extraneous
      ├── minipass@ extraneous
      ├── minizlib@ extraneous
      ├── mitt@ extraneous
      ├── mkdirp-classic@ extraneous
      ├── mkdirp@ extraneous
      ├── mocha@ extraneous
      ├── moment@ extraneous
      ├── mp3-duration@ extraneous
      ├── mqtt-connection@ extraneous
      ├── mqtt-packet@ extraneous
      ├── mqtt@ extraneous
      ├── ms@ extraneous
      ├── mssql@ extraneous
      ├── multicast-dns@ extraneous
      ├── mute-stream@ extraneous
      ├── mysql2@ extraneous
      ├── named-placeholders@ extraneous
      ├── nan@ extraneous
      ├── napi-build-utils@ extraneous
      ├── napi-thread-safe-callback@ extraneous
      ├── native-duplexpair@ extraneous
      ├── needle@ extraneous
      ├── negotiator@ extraneous
      ├── net-ping@ extraneous
      ├── netmask@ extraneous
      ├── noble@ extraneous
      ├── node-abi@ extraneous
      ├── node-abort-controller@ extraneous
      ├── node-addon-api@ extraneous
      ├── node-arp@ extraneous
      ├── node-ble@ extraneous
      ├── node-fetch@ extraneous
      ├── node-forge@ extraneous
      ├── node-gyp-build@ extraneous
      ├── node-gyp@ extraneous
      ├── node-inspect@ extraneous
      ├── node-mndp@ extraneous
      ├── node-schedule@ extraneous
      ├── node-snap7@ extraneous
      ├── node-ssdp@ extraneous
      ├── node-telegram-bot-api@ extraneous
      ├── node-unifi@ extraneous
      ├── node.extend@ extraneous
      ├── nodemailer@ extraneous
      ├── nodemon@ extraneous
      ├── nopt@ extraneous
      ├── normalize-package-data@ extraneous
      ├── normalize-path@ extraneous
      ├── npm-run-path@ extraneous
      ├── npmlog@ extraneous
      ├── nth-check@ extraneous
      ├── number-allocator@ extraneous
      ├── number-is-nan@ extraneous
      ├── nwmatcher@ extraneous
      ├── oauth-sign@0.9.0 extraneous
      ├── oauth2-server@ extraneous
      ├── object-assign@ extraneous
      ├── object-component@ extraneous
      ├── object-hash@ extraneous
      ├── object-inspect@ extraneous
      ├── object-keys@ extraneous
      ├── object.assign@ extraneous
      ├── on-finished@ extraneous
      ├── on-headers@ extraneous
      ├── once@ extraneous
      ├── one-time@ extraneous
      ├── onetime@ extraneous
      ├── open-sml@ extraneous
      ├── open@ extraneous
      ├── opn@ extraneous
      ├── optionator@ extraneous
      ├── options@ extraneous
      ├── os-locale@ extraneous
      ├── osx-temperature-sensor@ extraneous
      ├── oui@ extraneous
      ├── own-keys@ extraneous
      ├── p-limit@ extraneous
      ├── p-locate@ extraneous
      ├── p-map@ extraneous
      ├── package-json-from-dist@ extraneous
      ├── pako@ extraneous
      ├── parse-json@ extraneous
      ├── parse-listing@ extraneous
      ├── parse5-htmlparser2-tree-adapter@ extraneous
      ├── parse5-parser-stream@ extraneous
      ├── parse5@ extraneous
      ├── parsejson@ extraneous
      ├── parseqs@ extraneous
      ├── parseuri@ extraneous
      ├── parseurl@ extraneous
      ├── parsexmlresponse@ extraneous
      ├── passport-local@ extraneous
      ├── passport-strategy@ extraneous
      ├── passport@ extraneous
      ├── patch-package@ extraneous
      ├── path-exists@ extraneous
      ├── path-is-absolute@ extraneous
      ├── path-key@ extraneous
      ├── path-parse@ extraneous
      ├── path-scurry@ extraneous
      ├── path-to-regexp@ extraneous
      ├── path-type@ extraneous
      ├── pathval@ extraneous
      ├── pause-stream@ extraneous
      ├── pause@ extraneous
      ├── pcap@ extraneous
      ├── performance-now@ extraneous
      ├── pg-cloudflare@ extraneous
      ├── pg-connection-string@ extraneous
      ├── pg-int8@ extraneous
      ├── pg-pool@ extraneous
      ├── pg-protocol@ extraneous
      ├── pg-types@ extraneous
      ├── pg@ extraneous
      ├── pgpass@ extraneous
      ├── picocolors@ extraneous
      ├── picomatch@ extraneous
      ├── pidtree@ extraneous
      ├── pidusage@ extraneous
      ├── pify@ extraneous
      ├── ping@ extraneous
      ├── pinkie-promise@ extraneous
      ├── pinkie@ extraneous
      ├── playlist-parser@ extraneous
      ├── portfinder@ extraneous
      ├── portscanner@ extraneous
      ├── possible-typed-array-names@ extraneous
      ├── postgres-array@ extraneous
      ├── postgres-bytea@ extraneous
      ├── postgres-date@ extraneous
      ├── postgres-interval@ extraneous
      ├── prebuild-install@ extraneous
      ├── prelude-ls@ extraneous
      ├── proc-log@ extraneous
      ├── process-nextick-args@ extraneous
      ├── process@ extraneous
      ├── promise-inflight@ extraneous
      ├── promise-queue@ extraneous
      ├── promise-retry@ extraneous
      ├── promisify-any@ extraneous
      ├── promisify-child-process@ extraneous
      ├── prompt@ extraneous
      ├── protobufjs@ extraneous
      ├── proxy-addr@ extraneous
      ├── proxy-from-env@ extraneous
      ├── ps-tree@ extraneous
      ├── psl@ extraneous
      ├── pstree.remy@ extraneous
      ├── pump@ extraneous
      ├── punycode@ extraneous
      ├── put@ extraneous
      ├── q@ extraneous
      ├── qjobs@ extraneous
      ├── qs@ extraneous
      ├── querystringify@ extraneous
      ├── queue-microtask@ extraneous
      ├── quick-lru@ extraneous
      ├── random-bytes@ extraneous
      ├── randombytes@ extraneous
      ├── range-parser@ extraneous
      ├── raw-body@ extraneous
      ├── raw-socket@ extraneous
      ├── rc@1.2.8 extraneous
      ├── read-pkg-up@ extraneous
      ├── read-pkg@ extraneous
      ├── read@ extraneous
      ├── readable-stream@ extraneous
      ├── readdir-glob@ extraneous
      ├── readdirp@ extraneous
      ├── readline-sync@ extraneous
      ├── readline@ extraneous
      ├── redis-errors@ extraneous
      ├── redis-parser@ extraneous
      ├── reflect.getprototypeof@ extraneous
      ├── regexp.prototype.flags@ extraneous
      ├── reinterval@ extraneous
      ├── request-promise-core@ extraneous
      ├── request@ extraneous
      ├── require-directory@ extraneous
      ├── require-from-string@ extraneous
      ├── require-main-filename@ extraneous
      ├── requires-port@ extraneous
      ├── resolve@ extraneous
      ├── resp-modifier@ extraneous
      ├── respjs@ extraneous
      ├── retry@ extraneous
      ├── reusify@ extraneous
      ├── revalidator@ extraneous
      ├── rfdc@ extraneous
      ├── rimraf@ extraneous
      ├── router@ extraneous
      ├── run-parallel@ extraneous
      ├── rx@ extraneous
      ├── safe-array-concat@ extraneous
      ├── safe-buffer@ extraneous
      ├── safe-push-apply@ extraneous
      ├── safe-regex-test@ extraneous
      ├── safe-stable-stringify@ extraneous
      ├── safer-buffer@2.1.2 extraneous
      ├── sax@ extraneous
      ├── semver@ invalid: "^5.6.0" from the root project
      ├── send@ extraneous
      ├── seq-logging@ extraneous
      ├── seq-queue@ extraneous
      ├── serialize-javascript@ extraneous
      ├── serialport@ extraneous
      ├── serve-index@ extraneous
      ├── serve-static@ extraneous
      ├── server-destroy@ extraneous
      ├── set-blocking@ extraneous
      ├── set-function-length@ extraneous
      ├── set-function-name@ extraneous
      ├── set-proto@ extraneous
      ├── setimmediate@ extraneous
      ├── setprototypeof@ extraneous
      ├── shebang-command@ extraneous
      ├── shebang-regex@ extraneous
      ├── side-channel-list@ extraneous
      ├── side-channel-map@ extraneous
      ├── side-channel-weakmap@ extraneous
      ├── side-channel@ extraneous
      ├── siginfo@ extraneous
      ├── signal-exit@ extraneous
      ├── simple-concat@ extraneous
      ├── simple-get@ extraneous
      ├── simple-update-notifier@ extraneous
      ├── sinon-chai@ extraneous
      ├── sinon@ extraneous
      ├── slash@ extraneous
      ├── slice-ansi@ extraneous
      ├── smart-buffer@ extraneous
      ├── smartmeter-obis@ extraneous
      ├── socket.io-adapter@ extraneous
      ├── socket.io-client@ extraneous
      ├── socket.io-parser@ extraneous
      ├── socket.io@ extraneous
      ├── socks-proxy-agent@ extraneous
      ├── socks@ extraneous
      ├── sorted-array-functions@ extraneous
      ├── source-map-support@ extraneous
      ├── source-map@ extraneous
      ├── spdx-correct@ extraneous
      ├── spdx-exceptions@ extraneous
      ├── spdx-expression-parse@ extraneous
      ├── spdx-license-ids@ extraneous
      ├── split-ca@ extraneous
      ├── split@ extraneous
      ├── split2@ extraneous
      ├── sprintf-js@ extraneous
      ├── sql-client@ extraneous
      ├── sqlite3@ extraneous
      ├── sqlstring@ extraneous
      ├── ssh2@ extraneous
      ├── sshpk@ extraneous
      ├── ssri@ extraneous
      ├── stack-trace@ extraneous
      ├── stackback@ extraneous
      ├── standard-as-callback@ extraneous
      ├── statuses@ extraneous
      ├── stealthy-require@ extraneous
      ├── stop-iteration-iterator@ extraneous
      ├── stoppable@ extraneous
      ├── stream-combiner@ extraneous
      ├── stream-parser@ extraneous
      ├── stream-shift@ extraneous
      ├── stream-throttle@ extraneous
      ├── streamsearch@ extraneous
      ├── streamx@ extraneous
      ├── string_decoder@ extraneous
      ├── string-width-cjs@ extraneous
      ├── string-width@ extraneous
      ├── string.prototype.trim@ extraneous
      ├── string.prototype.trimend@ extraneous
      ├── string.prototype.trimstart@ extraneous
      ├── strip-ansi-cjs@ extraneous
      ├── strip-ansi@ extraneous
      ├── strip-bom@ extraneous
      ├── strip-final-newline@ extraneous
      ├── strip-json-comments@ extraneous
      ├── strnum@ extraneous
      ├── suncalc2@ extraneous
      ├── supports-color@ extraneous
      ├── supports-preserve-symlinks-flag@ extraneous
      ├── symbol-tree@ extraneous
      ├── systeminformation@ extraneous
      ├── table@ extraneous
      ├── tar-fs@ extraneous
      ├── tar-stream@ extraneous
      ├── tar@ extraneous
      ├── tarn@ extraneous
      ├── tedious@ extraneous
      ├── text-decoder@ extraneous
      ├── text-hex@ extraneous
      ├── text-table@ extraneous
      ├── through@ extraneous
      ├── through2@ extraneous
      ├── thunky@ extraneous
      ├── tldts-core@ extraneous
      ├── tldts@ extraneous
      ├── tmp@ extraneous
      ├── to-array@ extraneous
      ├── to-regex-range@ extraneous
      ├── toidentifier@ extraneous
      ├── touch@ extraneous
      ├── tough-cookie@ extraneous
      ├── tplink-smarthome-api@ extraneous
      ├── tplink-smarthome-crypto@ extraneous
      ├── tr-O64@ extraneous
      ├── tr46@ extraneous
      ├── traverse@ extraneous
      ├── treemap-js@ extraneous
      ├── triple-beam@ extraneous
      ├── tslib@ extraneous
      ├── tunnel-agent@ extraneous
      ├── tweetnacl@ extraneous
      ├── type-check@ extraneous
      ├── type-detect@ extraneous
      ├── type-fest@ extraneous
      ├── type-is@ extraneous
      ├── typed-array-buffer@ extraneous
      ├── typed-array-byte-length@ extraneous
      ├── typed-array-byte-offset@ extraneous
      ├── typed-array-length@ extraneous
      ├── typedarray@ extraneous
      ├── typescript@ extraneous
      ├── ua-parser-js@ extraneous
      ├── uid-number@ extraneous
      ├── uid-safe@2.1.5 extraneous
      ├── ultron@ extraneous
      ├── unbox-primitive@ extraneous
      ├── undefsafe@ extraneous
      ├── underscore@ extraneous
      ├── undici-types@ extraneous
      ├── undici@ extraneous
      ├── unique-filename@ extraneous
      ├── unique-slug@ extraneous
      ├── unix-dgram@ extraneous
      ├── unorm@ extraneous
      ├── unpipe@ extraneous
      ├── uri-js@ extraneous
      ├── url-parse@ extraneous
      ├── url-template@ extraneous
      ├── url@ extraneous
      ├── usb@ extraneous
      ├── usocket@ extraneous
      ├── util-deprecate@ extraneous
      ├── util@ extraneous
      ├── utils-merge@ extraneous
      ├── uuid@ extraneous
      ├── validate-npm-package-license@3.0.4 extraneous
      ├── vary@ extraneous
      ├── verror@ extraneous
      ├── virtual-tsc@ extraneous
      ├── wake_on_lan@ extraneous
      ├── weak-daemon@ extraneous
      ├── webidl-conversions@ extraneous
      ├── websocket-stream@ extraneous
      ├── whatwg-encoding@ extraneous
      ├── whatwg-mimetype@ extraneous
      ├── whatwg-url-compat@ extraneous
      ├── whatwg-url@ extraneous
      ├── which-boxed-primitive@ extraneous
      ├── which-builtin-type@ extraneous
      ├── which-collection@ extraneous
      ├── which-module@ extraneous
      ├── which-typed-array@ extraneous
      ├── which@ extraneous
      ├── why-is-node-running@ extraneous
      ├── wide-align@ extraneous
      ├── widest-line@ extraneous
      ├── winston-daily-rotate-file@ extraneous
      ├── winston-seq-updated@ extraneous
      ├── winston-syslog@ extraneous
      ├── winston-transport@ extraneous
      ├── winston@ extraneous
      ├── wol@ extraneous
      ├── word-wrap@ extraneous
      ├── worker-factory@ extraneous
      ├── worker-timers-broker@ extraneous
      ├── worker-timers-worker@ extraneous
      ├── worker-timers@ extraneous
      ├── workerpool@ extraneous
      ├── wrap-ansi-cjs@ extraneous
      ├── wrap-ansi@ extraneous
      ├── wrappy@ extraneous
      ├── ws@ extraneous
      ├── wtf-8@ extraneous
      ├── xml-name-validator@ extraneous
      ├── xml2js@ extraneous
      ├── xml2json-light@ extraneous
      ├── xmlbuilder@ extraneous
      ├── xmldom@ extraneous
      ├── xmlhttprequest-ssl@ extraneous
      ├── xmlhttprequest@ extraneous
      ├── xpc-connection@ extraneous
      ├── xtend@ extraneous
      ├── y18n@ extraneous
      ├── yallist@ extraneous
      ├── yaml@ extraneous
      ├── yargs-parser@ extraneous
      ├── yargs-unparser@ extraneous
      ├── yargs@ invalid: "^7.0.2" from the root project
      ├── yeast@ extraneous
      ├── yocto-queue@ extraneous
      ├── youtube-remote@ extraneous
      └── zip-stream@ extraneous
      npm error code ELSPROBLEMS
      npm error extraneous: @abandonware/bluetooth-hci-socket@ /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
      npm error extraneous: @abandonware/noble@ /opt/iobroker/node_modules/@abandonware/noble
      npm error extraneous: @alcalzone/esbuild-register@ /opt/iobroker/node_modules/@alcalzone/esbuild-register
      npm error extraneous: @alcalzone/jsonl-db@ /opt/iobroker/node_modules/@alcalzone/jsonl-db
      npm error extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/@alcalzone/pak
      npm error extraneous: @alcalzone/proper-lockfile@ /opt/iobroker/node_modules/@alcalzone/proper-lockfile
      npm error extraneous: @all-smart/all-smart-tools@ /opt/iobroker/node_modules/@all-smart/all-smart-tools
      npm error extraneous: @aws-crypto/sha256-browser@ /opt/iobroker/node_modules/@aws-crypto/sha256-browser
      npm error extraneous: @aws-crypto/sha256-js@ /opt/iobroker/node_modules/@aws-crypto/sha256-js
      npm error extraneous: @aws-crypto/supports-web-crypto@ /opt/iobroker/node_modules/@aws-crypto/supports-web-crypto
      npm error extraneous: @aws-crypto/util@ /opt/iobroker/node_modules/@aws-crypto/util
      npm error extraneous: @aws-sdk/client-polly@ /opt/iobroker/node_modules/@aws-sdk/client-polly
      npm error extraneous: @aws-sdk/client-sso@ /opt/iobroker/node_modules/@aws-sdk/client-sso
      npm error extraneous: @aws-sdk/core@ /opt/iobroker/node_modules/@aws-sdk/core
      npm error extraneous: @aws-sdk/credential-provider-env@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-env
      npm error extraneous: @aws-sdk/credential-provider-http@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-http
      npm error extraneous: @aws-sdk/credential-provider-ini@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-ini
      npm error extraneous: @aws-sdk/credential-provider-node@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-node
      npm error extraneous: @aws-sdk/credential-provider-process@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-process
      npm error extraneous: @aws-sdk/credential-provider-sso@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-sso
      npm error extraneous: @aws-sdk/credential-provider-web-identity@ /opt/iobroker/node_modules/@aws-sdk/credential-provider-web-identity
      npm error extraneous: @aws-sdk/middleware-host-header@ /opt/iobroker/node_modules/@aws-sdk/middleware-host-header
      npm error extraneous: @aws-sdk/middleware-logger@ /opt/iobroker/node_modules/@aws-sdk/middleware-logger
      npm error extraneous: @aws-sdk/middleware-recursion-detection@ /opt/iobroker/node_modules/@aws-sdk/middleware-recursion-detection
      npm error extraneous: @aws-sdk/middleware-user-agent@ /opt/iobroker/node_modules/@aws-sdk/middleware-user-agent
      npm error extraneous: @aws-sdk/nested-clients@ /opt/iobroker/node_modules/@aws-sdk/nested-clients
      npm error extraneous: @aws-sdk/region-config-resolver@ /opt/iobroker/node_modules/@aws-sdk/region-config-resolver
      npm error extraneous: @aws-sdk/token-providers@ /opt/iobroker/node_modules/@aws-sdk/token-providers
      npm error extraneous: @aws-sdk/types@ /opt/iobroker/node_modules/@aws-sdk/types
      npm error extraneous: @aws-sdk/util-endpoints@ /opt/iobroker/node_modules/@aws-sdk/util-endpoints
      npm error extraneous: @aws-sdk/util-locate-window@ /opt/iobroker/node_modules/@aws-sdk/util-locate-window
      npm error extraneous: @aws-sdk/util-user-agent-browser@ /opt/iobroker/node_modules/@aws-sdk/util-user-agent-browser
      npm error extraneous: @aws-sdk/util-user-agent-node@ /opt/iobroker/node_modules/@aws-sdk/util-user-agent-node
      npm error extraneous: @aws-sdk/xml-builder@ /opt/iobroker/node_modules/@aws-sdk/xml-builder
      npm error extraneous: @aws/lambda-invoke-store@ /opt/iobroker/node_modules/@aws/lambda-invoke-store
      npm error extraneous: @azure-rest/core-client@ /opt/iobroker/node_modules/@azure-rest/core-client
      npm error extraneous: @azure/abort-controller@ /opt/iobroker/node_modules/@azure/abort-controller
      npm error extraneous: @azure/core-auth@ /opt/iobroker/node_modules/@azure/core-auth
      npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
      npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
      npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
      npm error extraneous: @azure/core-paging@ /opt/iobroker/node_modules/@azure/core-paging
      npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
      npm error extraneous: @azure/core-tracing@ /opt/iobroker/node_modules/@azure/core-tracing
      npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
      npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
      npm error extraneous: @azure/keyvault-common@ /opt/iobroker/node_modules/@azure/keyvault-common
      npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
      npm error extraneous: @azure/logger@ /opt/iobroker/node_modules/@azure/logger
      npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
      npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
      npm error extraneous: @azure/msal-node@ /opt/iobroker/node_modules/@azure/msal-node
      npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
      npm error extraneous: @balena/dockerignore@ /opt/iobroker/node_modules/@balena/dockerignore
      npm error extraneous: @colors/colors@ /opt/iobroker/node_modules/@colors/colors
      npm error extraneous: @cypress/request-promise@ /opt/iobroker/node_modules/@cypress/request-promise
      npm error extraneous: @cypress/request@ /opt/iobroker/node_modules/@cypress/request
      npm error extraneous: @dabh/diagnostics@ /opt/iobroker/node_modules/@dabh/diagnostics
      npm error extraneous: @datalust/winston-seq@ /opt/iobroker/node_modules/@datalust/winston-seq
      npm error extraneous: @fastify/busboy@ /opt/iobroker/node_modules/@fastify/busboy
      npm error extraneous: @gar/promisify@ /opt/iobroker/node_modules/@gar/promisify
      npm error extraneous: @grpc/grpc-js@ /opt/iobroker/node_modules/@grpc/grpc-js
      npm error extraneous: @grpc/proto-loader@ /opt/iobroker/node_modules/@grpc/proto-loader
      npm error extraneous: @httptoolkit/websocket-stream@ /opt/iobroker/node_modules/@httptoolkit/websocket-stream
      npm error extraneous: @influxdata/influxdb-client-apis@ /opt/iobroker/node_modules/@influxdata/influxdb-client-apis
      npm error extraneous: @influxdata/influxdb-client@ /opt/iobroker/node_modules/@influxdata/influxdb-client
      npm error invalid: @iobroker-javascript.0/moment-parseformat@ /opt/iobroker/node_modules/@iobroker-javascript.0/moment-parseformat
      npm error invalid: @iobroker-javascript.0/moment@ /opt/iobroker/node_modules/@iobroker-javascript.0/moment
      npm error extraneous: @iobroker/adapter-core@ /opt/iobroker/node_modules/@iobroker/adapter-core
      npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
      npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
      npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
      npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
      npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
      npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
      npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
      npm error extraneous: @iobroker/dev-server@ /opt/iobroker/node_modules/@iobroker/dev-server
      npm error extraneous: @iobroker/dm-utils@ /opt/iobroker/node_modules/@iobroker/dm-utils
      npm error extraneous: @iobroker/i18n@ /opt/iobroker/node_modules/@iobroker/i18n
      npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
      npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
      npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
      npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
      npm error extraneous: @iobroker/plugin-base@ /opt/iobroker/node_modules/@iobroker/plugin-base
      npm error extraneous: @iobroker/plugin-docker@ /opt/iobroker/node_modules/@iobroker/plugin-docker
      npm error extraneous: @iobroker/plugin-sentry@ /opt/iobroker/node_modules/@iobroker/plugin-sentry
      npm error extraneous: @iobroker/socket-classes@ /opt/iobroker/node_modules/@iobroker/socket-classes
      npm error extraneous: @iobroker/testing@ /opt/iobroker/node_modules/@iobroker/testing
      npm error extraneous: @iobroker/type-detector@ /opt/iobroker/node_modules/@iobroker/type-detector
      npm error extraneous: @iobroker/types@ /opt/iobroker/node_modules/@iobroker/types
      npm error extraneous: @iobroker/webserver@ /opt/iobroker/node_modules/@iobroker/webserver
      npm error extraneous: @iobroker/ws-server@ /opt/iobroker/node_modules/@iobroker/ws-server
      npm error extraneous: @iobroker/ws@ /opt/iobroker/node_modules/@iobroker/ws
      npm error extraneous: @ioredis/commands@ /opt/iobroker/node_modules/@ioredis/commands
      npm error extraneous: @isaacs/balanced-match@ /opt/iobroker/node_modules/@isaacs/balanced-match
      npm error extraneous: @isaacs/brace-expansion@ /opt/iobroker/node_modules/@isaacs/brace-expansion
      npm error extraneous: @isaacs/cliui@ /opt/iobroker/node_modules/@isaacs/cliui
      npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
      npm error extraneous: @js-sdsl/ordered-map@ /opt/iobroker/node_modules/@js-sdsl/ordered-map
      npm error extraneous: @leichtgewicht/ip-codec@ /opt/iobroker/node_modules/@leichtgewicht/ip-codec
      npm error extraneous: @mapbox/node-pre-gyp@ /opt/iobroker/node_modules/@mapbox/node-pre-gyp
      npm error extraneous: @network-utils/arp-lookup@ /opt/iobroker/node_modules/@network-utils/arp-lookup
      npm error extraneous: @nodelib/fs.scandir@ /opt/iobroker/node_modules/@nodelib/fs.scandir
      npm error extraneous: @nodelib/fs.stat@ /opt/iobroker/node_modules/@nodelib/fs.stat
      npm error extraneous: @nodelib/fs.walk@ /opt/iobroker/node_modules/@nodelib/fs.walk
      npm error extraneous: @nornagon/put@ /opt/iobroker/node_modules/@nornagon/put
      npm error extraneous: @npmcli/agent@ /opt/iobroker/node_modules/@npmcli/agent
      npm error extraneous: @npmcli/fs@ /opt/iobroker/node_modules/@npmcli/fs
      npm error extraneous: @npmcli/move-file@ /opt/iobroker/node_modules/@npmcli/move-file
      npm error extraneous: @pkgjs/parseargs@ /opt/iobroker/node_modules/@pkgjs/parseargs
      npm error extraneous: @protobufjs/aspromise@ /opt/iobroker/node_modules/@protobufjs/aspromise
      npm error extraneous: @protobufjs/base64@ /opt/iobroker/node_modules/@protobufjs/base64
      npm error extraneous: @protobufjs/codegen@ /opt/iobroker/node_modules/@protobufjs/codegen
      npm error extraneous: @protobufjs/eventemitter@ /opt/iobroker/node_modules/@protobufjs/eventemitter
      npm error extraneous: @protobufjs/fetch@ /opt/iobroker/node_modules/@protobufjs/fetch
      npm error extraneous: @protobufjs/float@ /opt/iobroker/node_modules/@protobufjs/float
      npm error extraneous: @protobufjs/inquire@ /opt/iobroker/node_modules/@protobufjs/inquire
      npm error extraneous: @protobufjs/path@ /opt/iobroker/node_modules/@protobufjs/path
      npm error extraneous: @protobufjs/pool@ /opt/iobroker/node_modules/@protobufjs/pool
      npm error extraneous: @protobufjs/utf8@ /opt/iobroker/node_modules/@protobufjs/utf8
      npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
      npm error extraneous: @sentry/core@ /opt/iobroker/node_modules/@sentry/core
      npm error extraneous: @sentry/integrations@ /opt/iobroker/node_modules/@sentry/integrations
      npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
      npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
      npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
      npm error extraneous: @serialport/binding-mock@ /opt/iobroker/node_modules/@serialport/binding-mock
      npm error extraneous: @serialport/bindings-cpp@ /opt/iobroker/node_modules/@serialport/bindings-cpp
      npm error extraneous: @serialport/bindings-interface@ /opt/iobroker/node_modules/@serialport/bindings-interface
      npm error extraneous: @serialport/parser-byte-length@ /opt/iobroker/node_modules/@serialport/parser-byte-length
      npm error extraneous: @serialport/parser-cctalk@ /opt/iobroker/node_modules/@serialport/parser-cctalk
      npm error extraneous: @serialport/parser-delimiter@ /opt/iobroker/node_modules/@serialport/parser-delimiter
      npm error extraneous: @serialport/parser-inter-byte-timeout@ /opt/iobroker/node_modules/@serialport/parser-inter-byte-timeout
      npm error extraneous: @serialport/parser-packet-length@ /opt/iobroker/node_modules/@serialport/parser-packet-length
      npm error extraneous: @serialport/parser-readline@ /opt/iobroker/node_modules/@serialport/parser-readline
      npm error extraneous: @serialport/parser-ready@ /opt/iobroker/node_modules/@serialport/parser-ready
      npm error extraneous: @serialport/parser-regex@ /opt/iobroker/node_modules/@serialport/parser-regex
      npm error extraneous: @serialport/parser-slip-encoder@ /opt/iobroker/node_modules/@serialport/parser-slip-encoder
      npm error extraneous: @serialport/parser-spacepacket@ /opt/iobroker/node_modules/@serialport/parser-spacepacket
      npm error extraneous: @serialport/stream@ /opt/iobroker/node_modules/@serialport/stream
      npm error extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/@sinonjs/commons
      npm error extraneous: @sinonjs/fake-timers@ /opt/iobroker/node_modules/@sinonjs/fake-timers
      npm error extraneous: @sinonjs/samsam@ /opt/iobroker/node_modules/@sinonjs/samsam
      npm error extraneous: @smithy/abort-controller@ /opt/iobroker/node_modules/@smithy/abort-controller
      npm error extraneous: @smithy/config-resolver@ /opt/iobroker/node_modules/@smithy/config-resolver
      npm error extraneous: @smithy/core@ /opt/iobroker/node_modules/@smithy/core
      npm error extraneous: @smithy/credential-provider-imds@ /opt/iobroker/node_modules/@smithy/credential-provider-imds
      npm error extraneous: @smithy/fetch-http-handler@ /opt/iobroker/node_modules/@smithy/fetch-http-handler
      npm error extraneous: @smithy/hash-node@ /opt/iobroker/node_modules/@smithy/hash-node
      npm error extraneous: @smithy/invalid-dependency@ /opt/iobroker/node_modules/@smithy/invalid-dependency
      npm error extraneous: @smithy/is-array-buffer@ /opt/iobroker/node_modules/@smithy/is-array-buffer
      npm error extraneous: @smithy/middleware-content-length@ /opt/iobroker/node_modules/@smithy/middleware-content-length
      npm error extraneous: @smithy/middleware-endpoint@ /opt/iobroker/node_modules/@smithy/middleware-endpoint
      npm error extraneous: @smithy/middleware-retry@ /opt/iobroker/node_modules/@smithy/middleware-retry
      npm error extraneous: @smithy/middleware-serde@ /opt/iobroker/node_modules/@smithy/middleware-serde
      npm error extraneous: @smithy/middleware-stack@ /opt/iobroker/node_modules/@smithy/middleware-stack
      npm error extraneous: @smithy/node-config-provider@ /opt/iobroker/node_modules/@smithy/node-config-provider
      npm error extraneous: @smithy/node-http-handler@ /opt/iobroker/node_modules/@smithy/node-http-handler
      npm error extraneous: @smithy/property-provider@ /opt/iobroker/node_modules/@smithy/property-provider
      npm error extraneous: @smithy/protocol-http@ /opt/iobroker/node_modules/@smithy/protocol-http
      npm error extraneous: @smithy/querystring-builder@ /opt/iobroker/node_modules/@smithy/querystring-builder
      npm error extraneous: @smithy/querystring-parser@ /opt/iobroker/node_modules/@smithy/querystring-parser
      npm error extraneous: @smithy/service-error-classification@ /opt/iobroker/node_modules/@smithy/service-error-classification
      npm error extraneous: @smithy/shared-ini-file-loader@ /opt/iobroker/node_modules/@smithy/shared-ini-file-loader
      npm error extraneous: @smithy/signature-v4@ /opt/iobroker/node_modules/@smithy/signature-v4
      npm error extraneous: @smithy/smithy-client@ /opt/iobroker/node_modules/@smithy/smithy-client
      npm error extraneous: @smithy/types@ /opt/iobroker/node_modules/@smithy/types
      npm error extraneous: @smithy/url-parser@ /opt/iobroker/node_modules/@smithy/url-parser
      npm error extraneous: @smithy/util-base64@ /opt/iobroker/node_modules/@smithy/util-base64
      npm error extraneous: @smithy/util-body-length-browser@ /opt/iobroker/node_modules/@smithy/util-body-length-browser
      npm error extraneous: @smithy/util-body-length-node@ /opt/iobroker/node_modules/@smithy/util-body-length-node
      npm error extraneous: @smithy/util-buffer-from@ /opt/iobroker/node_modules/@smithy/util-buffer-from
      npm error extraneous: @smithy/util-config-provider@ /opt/iobroker/node_modules/@smithy/util-config-provider
      npm error extraneous: @smithy/util-defaults-mode-browser@ /opt/iobroker/node_modules/@smithy/util-defaults-mode-browser
      npm error extraneous: @smithy/util-defaults-mode-node@ /opt/iobroker/node_modules/@smithy/util-defaults-mode-node
      npm error extraneous: @smithy/util-endpoints@ /opt/iobroker/node_modules/@smithy/util-endpoints
      npm error extraneous: @smithy/util-hex-encoding@ /opt/iobroker/node_modules/@smithy/util-hex-encoding
      npm error extraneous: @smithy/util-middleware@ /opt/iobroker/node_modules/@smithy/util-middleware
      npm error extraneous: @smithy/util-retry@ /opt/iobroker/node_modules/@smithy/util-retry
      npm error extraneous: @smithy/util-stream@ /opt/iobroker/node_modules/@smithy/util-stream
      npm error extraneous: @smithy/util-uri-escape@ /opt/iobroker/node_modules/@smithy/util-uri-escape
      npm error extraneous: @smithy/util-utf8@ /opt/iobroker/node_modules/@smithy/util-utf8
      npm error extraneous: @smithy/uuid@ /opt/iobroker/node_modules/@smithy/uuid
      npm error extraneous: @so-ric/colorspace@ /opt/iobroker/node_modules/@so-ric/colorspace
      npm error extraneous: @socket.io/component-emitter@ /opt/iobroker/node_modules/@socket.io/component-emitter
      npm error extraneous: @stoprocent/bluetooth-hci-socket@ /opt/iobroker/node_modules/@stoprocent/bluetooth-hci-socket
      npm error extraneous: @stoprocent/noble@ /opt/iobroker/node_modules/@stoprocent/noble
      npm error extraneous: @tediousjs/connection-string@ /opt/iobroker/node_modules/@tediousjs/connection-string
      npm error extraneous: @tootallnate/once@ /opt/iobroker/node_modules/@tootallnate/once
      npm error extraneous: @types/body-parser@ /opt/iobroker/node_modules/@types/body-parser
      npm error extraneous: @types/caseless@ /opt/iobroker/node_modules/@types/caseless
      npm error extraneous: @types/chai-as-promised@ /opt/iobroker/node_modules/@types/chai-as-promised
      npm error extraneous: @types/chai@ /opt/iobroker/node_modules/@types/chai
      npm error extraneous: @types/connect@ /opt/iobroker/node_modules/@types/connect
      npm error extraneous: @types/cors@ /opt/iobroker/node_modules/@types/cors
      npm error extraneous: @types/express-serve-static-core@ /opt/iobroker/node_modules/@types/express-serve-static-core
      npm error extraneous: @types/express@ /opt/iobroker/node_modules/@types/express
      npm error extraneous: @types/http-errors@ /opt/iobroker/node_modules/@types/http-errors
      npm error extraneous: @types/http-proxy@ /opt/iobroker/node_modules/@types/http-proxy
      npm error extraneous: @types/jsonwebtoken@ /opt/iobroker/node_modules/@types/jsonwebtoken
      npm error extraneous: @types/long@ /opt/iobroker/node_modules/@types/long
      npm error extraneous: @types/luxon@ /opt/iobroker/node_modules/@types/luxon
      npm error extraneous: @types/mime@ /opt/iobroker/node_modules/@types/mime
      npm error extraneous: @types/mocha@ /opt/iobroker/node_modules/@types/mocha
      npm error extraneous: @types/ms@ /opt/iobroker/node_modules/@types/ms
      npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
      npm error extraneous: @types/qs@ /opt/iobroker/node_modules/@types/qs
      npm error extraneous: @types/range-parser@ /opt/iobroker/node_modules/@types/range-parser
      npm error extraneous: @types/readable-stream@ /opt/iobroker/node_modules/@types/readable-stream
      npm error extraneous: @types/request@ /opt/iobroker/node_modules/@types/request
      npm error extraneous: @types/send@ /opt/iobroker/node_modules/@types/send
      npm error extraneous: @types/serve-static@ /opt/iobroker/node_modules/@types/serve-static
      npm error extraneous: @types/sinon-chai@ /opt/iobroker/node_modules/@types/sinon-chai
      npm error extraneous: @types/sinon@ /opt/iobroker/node_modules/@types/sinon
      npm error extraneous: @types/sinonjs__fake-timers@ /opt/iobroker/node_modules/@types/sinonjs__fake-timers
      npm error extraneous: @types/tough-cookie@ /opt/iobroker/node_modules/@types/tough-cookie
      npm error extraneous: @types/triple-beam@ /opt/iobroker/node_modules/@types/triple-beam
      npm error extraneous: @types/w3c-web-usb@ /opt/iobroker/node_modules/@types/w3c-web-usb
      npm error extraneous: @types/ws@ /opt/iobroker/node_modules/@types/ws
      npm error extraneous: @typespec/ts-http-runtime@ /opt/iobroker/node_modules/@typespec/ts-http-runtime
      npm error extraneous: @yarnpkg/lockfile@ /opt/iobroker/node_modules/@yarnpkg/lockfile
      npm error extraneous: abbrev@ /opt/iobroker/node_modules/abbrev
      npm error extraneous: abort-controller@ /opt/iobroker/node_modules/abort-controller
      npm error extraneous: accepts@ /opt/iobroker/node_modules/accepts
      npm error extraneous: acorn-globals@ /opt/iobroker/node_modules/acorn-globals
      npm error extraneous: acorn@ /opt/iobroker/node_modules/acorn
      npm error extraneous: after@ /opt/iobroker/node_modules/after
      npm error extraneous: agent-base@ /opt/iobroker/node_modules/agent-base
      npm error extraneous: agentkeepalive@ /opt/iobroker/node_modules/agentkeepalive
      npm error extraneous: aggregate-error@ /opt/iobroker/node_modules/aggregate-error
      npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
      npm error extraneous: alcalzone-shared@ /opt/iobroker/node_modules/alcalzone-shared
      npm error extraneous: ansi-align@ /opt/iobroker/node_modules/ansi-align
      npm error extraneous: ansi-colors@ /opt/iobroker/node_modules/ansi-colors
      npm error extraneous: ansi-regex@ /opt/iobroker/node_modules/ansi-regex
      npm error extraneous: ansi-styles@ /opt/iobroker/node_modules/ansi-styles
      npm error extraneous: anymatch@ /opt/iobroker/node_modules/anymatch
      npm error extraneous: aproba@ /opt/iobroker/node_modules/aproba
      npm error extraneous: archiver-utils@ /opt/iobroker/node_modules/archiver-utils
      npm error extraneous: archiver@ /opt/iobroker/node_modules/archiver
      npm error extraneous: are-we-there-yet@ /opt/iobroker/node_modules/are-we-there-yet
      npm error extraneous: argf@ /opt/iobroker/node_modules/argf
      npm error extraneous: argparse@ /opt/iobroker/node_modules/argparse
      npm error extraneous: array-buffer-byte-length@ /opt/iobroker/node_modules/array-buffer-byte-length
      npm error extraneous: array-find@ /opt/iobroker/node_modules/array-find
      npm error extraneous: array-flatten@ /opt/iobroker/node_modules/array-flatten
      npm error extraneous: array.prototype.findindex@ /opt/iobroker/node_modules/array.prototype.findindex
      npm error extraneous: arraybuffer.prototype.slice@ /opt/iobroker/node_modules/arraybuffer.prototype.slice
      npm error extraneous: arraybuffer.slice@ /opt/iobroker/node_modules/arraybuffer.slice
      npm error extraneous: asn1@ /opt/iobroker/node_modules/asn1
      npm error extraneous: assert-plus@ /opt/iobroker/node_modules/assert-plus
      npm error extraneous: assertion-error@ /opt/iobroker/node_modules/assertion-error
      npm error extraneous: astral-regex@ /opt/iobroker/node_modules/astral-regex
      npm error extraneous: async-each-series@ /opt/iobroker/node_modules/async-each-series
      npm error extraneous: async-function@ /opt/iobroker/node_modules/async-function
      npm error extraneous: async-limiter@ /opt/iobroker/node_modules/async-limiter
      npm error extraneous: async@ /opt/iobroker/node_modules/async
      npm error extraneous: asynckit@ /opt/iobroker/node_modules/asynckit
      npm error extraneous: authenticate-pam@ /opt/iobroker/node_modules/authenticate-pam
      npm error extraneous: available-typed-arrays@ /opt/iobroker/node_modules/available-typed-arrays
      npm error extraneous: aws-iot-device-sdk@ /opt/iobroker/node_modules/aws-iot-device-sdk
      npm error extraneous: aws-sign2@ /opt/iobroker/node_modules/aws-sign2
      npm error extraneous: aws-ssl-profiles@ /opt/iobroker/node_modules/aws-ssl-profiles
      npm error extraneous: aws4@ /opt/iobroker/node_modules/aws4
      npm error extraneous: axios@ /opt/iobroker/node_modules/axios
      npm error extraneous: b4a@ /opt/iobroker/node_modules/b4a
      npm error extraneous: backo2@ /opt/iobroker/node_modules/backo2
      npm error extraneous: balanced-match@ /opt/iobroker/node_modules/balanced-match
      npm error extraneous: bare-events@ /opt/iobroker/node_modules/bare-events
      npm error extraneous: base-64@ /opt/iobroker/node_modules/base-64
      npm error extraneous: base64-arraybuffer@ /opt/iobroker/node_modules/base64-arraybuffer
      npm error extraneous: base64-js@ /opt/iobroker/node_modules/base64-js
      npm error extraneous: base64id@ /opt/iobroker/node_modules/base64id
      npm error extraneous: basic-auth@ /opt/iobroker/node_modules/basic-auth
      npm error extraneous: batch@ /opt/iobroker/node_modules/batch
      npm error extraneous: bcrypt-pbkdf@ /opt/iobroker/node_modules/bcrypt-pbkdf
      npm error extraneous: better-assert@ /opt/iobroker/node_modules/better-assert
      npm error extraneous: bignumber.js@ /opt/iobroker/node_modules/bignumber.js
      npm error extraneous: binary-extensions@ /opt/iobroker/node_modules/binary-extensions
      npm error extraneous: binary@ /opt/iobroker/node_modules/binary
      npm error extraneous: bindings@ /opt/iobroker/node_modules/bindings
      npm error extraneous: binrpc@ /opt/iobroker/node_modules/binrpc
      npm error extraneous: bl@ /opt/iobroker/node_modules/bl
      npm error extraneous: blob@ /opt/iobroker/node_modules/blob
      npm error extraneous: bluebird-co@ /opt/iobroker/node_modules/bluebird-co
      npm error extraneous: bluebird@ /opt/iobroker/node_modules/bluebird
      npm error extraneous: bluetooth-hci-socket@ /opt/iobroker/node_modules/bluetooth-hci-socket
      npm error extraneous: body-parser@ /opt/iobroker/node_modules/body-parser
      npm error extraneous: boolbase@ /opt/iobroker/node_modules/boolbase
      npm error extraneous: bower@ /opt/iobroker/node_modules/bower
      npm error extraneous: bowser@ /opt/iobroker/node_modules/bowser
      npm error extraneous: boxen@ /opt/iobroker/node_modules/boxen
      npm error extraneous: bplist-parser@ /opt/iobroker/node_modules/bplist-parser
      npm error extraneous: brace-expansion@ /opt/iobroker/node_modules/brace-expansion
      npm error extraneous: braces@ /opt/iobroker/node_modules/braces
      npm error extraneous: broker-factory@ /opt/iobroker/node_modules/broker-factory
      npm error extraneous: browser-request@ /opt/iobroker/node_modules/browser-request
      npm error extraneous: browser-stdout@ /opt/iobroker/node_modules/browser-stdout
      npm error extraneous: browser-sync-client@ /opt/iobroker/node_modules/browser-sync-client
      npm error extraneous: browser-sync-ui@ /opt/iobroker/node_modules/browser-sync-ui
      npm error extraneous: browser-sync@ /opt/iobroker/node_modules/browser-sync
      npm error extraneous: bs-html-injector@ /opt/iobroker/node_modules/bs-html-injector
      npm error extraneous: bs-recipes@ /opt/iobroker/node_modules/bs-recipes
      npm error extraneous: buffer-crc32@ /opt/iobroker/node_modules/buffer-crc32
      npm error extraneous: buffer-equal-constant-time@ /opt/iobroker/node_modules/buffer-equal-constant-time
      npm error extraneous: buffer-from@ /opt/iobroker/node_modules/buffer-from
      npm error extraneous: buffer@ /opt/iobroker/node_modules/buffer
      npm error extraneous: buffers@ /opt/iobroker/node_modules/buffers
      npm error extraneous: buildcheck@ /opt/iobroker/node_modules/buildcheck
      npm error extraneous: busboy@ /opt/iobroker/node_modules/busboy
      npm error extraneous: bytes@ /opt/iobroker/node_modules/bytes
      npm error extraneous: cacache@ /opt/iobroker/node_modules/cacache
      npm error extraneous: call-bind-apply-helpers@ /opt/iobroker/node_modules/call-bind-apply-helpers
      npm error extraneous: call-bind@ /opt/iobroker/node_modules/call-bind
      npm error extraneous: call-bound@ /opt/iobroker/node_modules/call-bound
      npm error extraneous: callsite@ /opt/iobroker/node_modules/callsite
      npm error extraneous: camelcase@ /opt/iobroker/node_modules/camelcase
      npm error extraneous: canvas@ /opt/iobroker/node_modules/canvas
      npm error extraneous: caseless@ /opt/iobroker/node_modules/caseless
      npm error extraneous: castv2-client@ /opt/iobroker/node_modules/castv2-client
      npm error extraneous: castv2-player@ /opt/iobroker/node_modules/castv2-player
      npm error extraneous: castv2@ /opt/iobroker/node_modules/castv2
      npm error extraneous: chai-as-promised@ /opt/iobroker/node_modules/chai-as-promised
      npm error extraneous: chai@ /opt/iobroker/node_modules/chai
      npm error extraneous: chainsaw@ /opt/iobroker/node_modules/chainsaw
      npm error extraneous: chalk@ /opt/iobroker/node_modules/chalk
      npm error extraneous: char-spinner@ /opt/iobroker/node_modules/char-spinner
      npm error extraneous: check-error@ /opt/iobroker/node_modules/check-error
      npm error extraneous: cheerio-select@ /opt/iobroker/node_modules/cheerio-select
      npm error extraneous: cheerio@ /opt/iobroker/node_modules/cheerio
      npm error extraneous: chokidar@ /opt/iobroker/node_modules/chokidar
      npm error extraneous: chownr@ /opt/iobroker/node_modules/chownr
      npm error extraneous: ci-info@ /opt/iobroker/node_modules/ci-info
      npm error extraneous: clean-stack@ /opt/iobroker/node_modules/clean-stack
      npm error extraneous: cli-boxes@ /opt/iobroker/node_modules/cli-boxes
      npm error extraneous: cliui@ /opt/iobroker/node_modules/cliui
      npm error extraneous: cluster-key-slot@ /opt/iobroker/node_modules/cluster-key-slot
      npm error extraneous: co-bluebird@ /opt/iobroker/node_modules/co-bluebird
      npm error extraneous: co-use@ /opt/iobroker/node_modules/co-use
      npm error extraneous: code-point-at@ /opt/iobroker/node_modules/code-point-at
      npm error extraneous: color-convert@ /opt/iobroker/node_modules/color-convert
      npm error extraneous: color-name@ /opt/iobroker/node_modules/color-name
      npm error extraneous: color-string@ /opt/iobroker/node_modules/color-string
      npm error extraneous: color-support@ /opt/iobroker/node_modules/color-support
      npm error extraneous: color@ /opt/iobroker/node_modules/color
      npm error invalid: colors@ /opt/iobroker/node_modules/colors
      npm error extraneous: combined-stream@ /opt/iobroker/node_modules/combined-stream
      npm error extraneous: commander@ /opt/iobroker/node_modules/commander
      npm error extraneous: commist@ /opt/iobroker/node_modules/commist
      npm error extraneous: component-bind@ /opt/iobroker/node_modules/component-bind
      npm error extraneous: component-emitter@ /opt/iobroker/node_modules/component-emitter
      npm error extraneous: component-inherit@ /opt/iobroker/node_modules/component-inherit
      npm error extraneous: compress-commons@ /opt/iobroker/node_modules/compress-commons
      npm error extraneous: compressible@ /opt/iobroker/node_modules/compressible
      npm error extraneous: compression@ /opt/iobroker/node_modules/compression
      npm error extraneous: concat-map@ /opt/iobroker/node_modules/concat-map
      npm error extraneous: concat-stream@ /opt/iobroker/node_modules/concat-stream
      npm error extraneous: connect-flash@ /opt/iobroker/node_modules/connect-flash
      npm error extraneous: connect-history-api-fallback@ /opt/iobroker/node_modules/connect-history-api-fallback
      npm error extraneous: connect@ /opt/iobroker/node_modules/connect
      npm error extraneous: console-control-strings@ /opt/iobroker/node_modules/console-control-strings
      npm error extraneous: content-disposition@ /opt/iobroker/node_modules/content-disposition
      npm error extraneous: content-type@ /opt/iobroker/node_modules/content-type
      npm error extraneous: cookie-parser@ /opt/iobroker/node_modules/cookie-parser
      npm error extraneous: cookie-signature@ /opt/iobroker/node_modules/cookie-signature
      npm error extraneous: cookie@ /opt/iobroker/node_modules/cookie
      npm error extraneous: core-util-is@ /opt/iobroker/node_modules/core-util-is
      npm error extraneous: cors@ /opt/iobroker/node_modules/cors
      npm error extraneous: country-data@ /opt/iobroker/node_modules/country-data
      npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
      npm error extraneous: crc-32@ /opt/iobroker/node_modules/crc-32
      npm error extraneous: crc32-stream@ /opt/iobroker/node_modules/crc32-stream
      npm error extraneous: cron-parser@ /opt/iobroker/node_modules/cron-parser
      npm error extraneous: cron@ /opt/iobroker/node_modules/cron
      npm error extraneous: cross-spawn@ /opt/iobroker/node_modules/cross-spawn
      npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
      npm error extraneous: css-select@ /opt/iobroker/node_modules/css-select
      npm error extraneous: css-what@ /opt/iobroker/node_modules/css-what
      npm error extraneous: cssom@ /opt/iobroker/node_modules/cssom
      npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
      npm error extraneous: currency-symbol-map@ /opt/iobroker/node_modules/currency-symbol-map
      npm error extraneous: cycle@ /opt/iobroker/node_modules/cycle
      npm error extraneous: dashdash@ /opt/iobroker/node_modules/dashdash
      npm error extraneous: data-view-buffer@ /opt/iobroker/node_modules/data-view-buffer
      npm error extraneous: data-view-byte-length@ /opt/iobroker/node_modules/data-view-byte-length
      npm error extraneous: data-view-byte-offset@ /opt/iobroker/node_modules/data-view-byte-offset
      npm error extraneous: dateformat@ /opt/iobroker/node_modules/dateformat
      npm error extraneous: dbus-next@ /opt/iobroker/node_modules/dbus-next
      npm error extraneous: debug@ /opt/iobroker/node_modules/debug
      npm error extraneous: decache@ /opt/iobroker/node_modules/decache
      npm error extraneous: decamelize@ /opt/iobroker/node_modules/decamelize
      npm error extraneous: decompress-response@ /opt/iobroker/node_modules/decompress-response
      npm error extraneous: deep-clone@ /opt/iobroker/node_modules/deep-clone
      npm error extraneous: deep-eql@ /opt/iobroker/node_modules/deep-eql
      npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
      npm error extraneous: deep-is@ /opt/iobroker/node_modules/deep-is
      npm error extraneous: define-data-property@ /opt/iobroker/node_modules/define-data-property
      npm error extraneous: define-lazy-prop@ /opt/iobroker/node_modules/define-lazy-prop
      npm error extraneous: define-properties@ /opt/iobroker/node_modules/define-properties
      npm error extraneous: delayed-stream@ /opt/iobroker/node_modules/delayed-stream
      npm error extraneous: delegates@ /opt/iobroker/node_modules/delegates
      npm error extraneous: denque@ /opt/iobroker/node_modules/denque
      npm error extraneous: depd@ /opt/iobroker/node_modules/depd
      npm error extraneous: destroy@ /opt/iobroker/node_modules/destroy
      npm error extraneous: detect-libc@ /opt/iobroker/node_modules/detect-libc
      npm error extraneous: dev-ip@ /opt/iobroker/node_modules/dev-ip
      npm error extraneous: dev-null@ /opt/iobroker/node_modules/dev-null
      npm error extraneous: dgram@ /opt/iobroker/node_modules/dgram
      npm error extraneous: diff@ /opt/iobroker/node_modules/diff
      npm error extraneous: diskusage@ /opt/iobroker/node_modules/diskusage
      npm error extraneous: dns-packet@ /opt/iobroker/node_modules/dns-packet
      npm error extraneous: docker-modem@ /opt/iobroker/node_modules/docker-modem
      npm error extraneous: dockerode@ /opt/iobroker/node_modules/dockerode
      npm error extraneous: dom-compare-temp@ /opt/iobroker/node_modules/dom-compare-temp
      npm error extraneous: dom-serializer@ /opt/iobroker/node_modules/dom-serializer
      npm error extraneous: domelementtype@ /opt/iobroker/node_modules/domelementtype
      npm error extraneous: domhandler@ /opt/iobroker/node_modules/domhandler
      npm error extraneous: domutils@ /opt/iobroker/node_modules/domutils
      npm error extraneous: dunder-proto@ /opt/iobroker/node_modules/dunder-proto
      npm error extraneous: duplexer@ /opt/iobroker/node_modules/duplexer
      npm error extraneous: duplexify@ /opt/iobroker/node_modules/duplexify
      npm error extraneous: eastasianwidth@ /opt/iobroker/node_modules/eastasianwidth
      npm error extraneous: easy-extender@ /opt/iobroker/node_modules/easy-extender
      npm error extraneous: eazy-logger@ /opt/iobroker/node_modules/eazy-logger
      npm error extraneous: ecc-jsbn@ /opt/iobroker/node_modules/ecc-jsbn
      npm error extraneous: ecdsa-sig-formatter@ /opt/iobroker/node_modules/ecdsa-sig-formatter
      npm error extraneous: ee-first@ /opt/iobroker/node_modules/ee-first
      npm error extraneous: emoji-regex@ /opt/iobroker/node_modules/emoji-regex
      npm error extraneous: enabled@ /opt/iobroker/node_modules/enabled
      npm error extraneous: encodeurl@ /opt/iobroker/node_modules/encodeurl
      npm error extraneous: encoding-sniffer@ /opt/iobroker/node_modules/encoding-sniffer
      npm error extraneous: encoding@ /opt/iobroker/node_modules/encoding
      npm error extraneous: end-of-stream@ /opt/iobroker/node_modules/end-of-stream
      npm error extraneous: engine.io-client@ /opt/iobroker/node_modules/engine.io-client
      npm error extraneous: engine.io-parser@ /opt/iobroker/node_modules/engine.io-parser
      npm error extraneous: engine.io@ /opt/iobroker/node_modules/engine.io
      npm error extraneous: enquirer@ /opt/iobroker/node_modules/enquirer
      npm error extraneous: entities@ /opt/iobroker/node_modules/entities
      npm error extraneous: env-paths@ /opt/iobroker/node_modules/env-paths
      npm error extraneous: err-code@ /opt/iobroker/node_modules/err-code
      npm error extraneous: error-ex@ /opt/iobroker/node_modules/error-ex
      npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
      npm error extraneous: es-aggregate-error@ /opt/iobroker/node_modules/es-aggregate-error
      npm error extraneous: es-define-property@ /opt/iobroker/node_modules/es-define-property
      npm error extraneous: es-errors@ /opt/iobroker/node_modules/es-errors
      @george_best
      Da gilt dann auch für dich:
      Die mit Invalid gekennzeichneten Adapter mal neuinstallieren, tote Adapter rauskicken.
      Sieht mir aber insgesamt SEHR strubbelig aus.
      G 1 Antwort Letzte Antwort
        @george_best
        George_Best
        ich musste nun auch den js-controller neu installieren:
        npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
        npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
        npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
        npm warn deprecated uid-number@0.0.6: This package is no longer supported.
        npm warn deprecated npmlog@5.0.1: This package is no longer supported.
        npm warn deprecated lodash.get@4.4.2: This package is deprecated. Use the optional chaining (?.) operator instead.
        npm warn deprecated npmlog@6.0.2: This package is no longer supported.
        npm warn deprecated lodash.isequal@4.5.0: This package is deprecated. Use require('node:util').isDeepStrictEqual instead.
        npm warn deprecated lodash.clone@4.5.0: This package is deprecated. Use structuredClone instead.
        npm warn deprecated har-validator@5.1.5: this library is no longer supported
        npm warn deprecated npmlog@4.1.2: This package is no longer supported.
        npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
        npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
        npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
        npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
        npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
        npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
        npm warn deprecated q@1.5.1: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
        npm warn deprecated
        npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
        npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
        npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
        npm warn deprecated gauge@3.0.2: This package is no longer supported.
        npm warn deprecated gauge@4.0.4: This package is no longer supported.
        npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm warn deprecated gauge@2.7.4: This package is no longer supported.
        npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm warn deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
        changed 1848 packages in 3m
        205 packages are looking for funding
          run `npm fund` for details
        Aber:
        Ist das normal?
        • G George_Best
          npm warn deprecated
          Aber:
          Ist das normal?
          @george_best sagte in iob fix und iob diag ohne Reaktion:
          Ist das normal?
          Bei dem strubbeligen npm-Tree kann das normal sein.
            Ist das normal?
            George_Best
            npm ls:
            iobroker.inst@2.0.2 /opt/iobroker
            ├── @iobroker-javascript.0/moment-parseformat@npm:moment-parseformat@4.0.0
            ├── @iobroker-javascript.0/moment@npm:moment@2.30.1
            ├── colors@1.4.0
            ├── fs-extra@7.0.1
            ├── iobroker.accuweather@2.1.1
            ├── iobroker.admin@7.7.19
            ├── iobroker.alias-manager@2.0.0
            ├── iobroker.amazon-dash@1.2.0
            ├── iobroker.chromecast@4.0.0
            ├── iobroker.cloud@5.0.1
            ├── iobroker.daswetter@3.2.3
            ├── iobroker.deconz@1.6.4
            ├── iobroker.devices@1.2.8
            ├── iobroker.discovery@5.0.0
            ├── iobroker.email@2.0.4
            ├── iobroker.flot@1.12.0
            ├── iobroker.fronius-solarweb@0.0.3
            ├── iobroker.fronius@2.1.1
            ├── iobroker.frontier_silicon@0.5.0
            ├── iobroker.habpanel@0.5.0
            ├── iobroker.history@3.0.1
            ├── iobroker.hm-rega@5.1.0
            ├── iobroker.hm-rpc@2.0.2
            ├── iobroker.hs100@3.0.5
            ├── iobroker.icons-addictive-flavour-png@0.1.0
            ├── iobroker.icons-fatcow-hosting@0.1.0
            ├── iobroker.icons-icons8@0.0.1
            ├── iobroker.icons-material-png@0.1.0
            ├── iobroker.icons-material-svg@0.1.0
            ├── iobroker.icons-mfd-png@1.2.1
            ├── iobroker.icons-mfd-svg@1.2.0
            ├── iobroker.icons-open-icon-library-png@0.1.2
            ├── iobroker.icons-ultimate-png@1.0.1
            ├── iobroker.influxdb@4.0.2
            ├── iobroker.info@2.0.0
            ├── iobroker.iot@5.0.7
            ├── iobroker.javascript@8.9.2
            ├── iobroker.js-controller@7.0.7
            ├── iobroker.mihome-vacuum@5.2.0
            ├── iobroker.mqtt@6.1.4
            ├── iobroker.net-tools@1.1.2
            ├── iobroker.octoprint@5.1.0
            ├── iobroker.openweathermap@1.1.2
            ├── iobroker.parser@2.2.4
            ├── iobroker.ping@1.6.2
            ├── iobroker.proxmox@2.4.0
            ├── iobroker.radar@1.2.1
            ├── iobroker.radar2@2.4.0
            ├── iobroker.reolink@1.2.3
            ├── iobroker.rickshaw@1.0.0
            ├── iobroker.s7@1.5.0
            ├── iobroker.sayit@5.0.0
            ├── iobroker.smartmeter@3.4.0
            ├── iobroker.socketio@6.7.1
            ├── iobroker.sql@3.0.1
            ├── iobroker.statistics@2.4.0
            ├── iobroker.systeminfo@1.3.0
            ├── iobroker.telegram@4.1.0
            ├── iobroker.terminal@1.0.0
            ├── iobroker.tr-064@4.3.0
            ├── iobroker.unifi@0.7.0
            ├── iobroker.upnp@1.1.0
            ├── iobroker.vis-2-widgets-inventwo@0.2.2
            ├── iobroker.vis-2-widgets-material@1.4.10
            ├── iobroker.vis-2@2.13.4
            ├── iobroker.vis-bars@0.1.4
            ├── iobroker.vis-canvas-gauges@1.0.1
            ├── iobroker.vis-colorpicker@2.0.3
            ├── iobroker.vis-fancyswitch@1.1.0
            ├── iobroker.vis-google-fonts@1.0.4
            ├── iobroker.vis-history@1.0.0
            ├── iobroker.vis-hqwidgets@1.5.1
            ├── iobroker.vis-jqui-mfd@1.1.1
            ├── iobroker.vis-justgage@2.1.7
            ├── iobroker.vis-keyboard@0.0.2
            ├── iobroker.vis-lcars@1.1.1
            ├── iobroker.vis-map@1.1.2
            ├── iobroker.vis-materialdesign@0.5.9
            ├── iobroker.vis-metro@1.2.0
            ├── iobroker.vis-rgraph@0.0.2
            ├── iobroker.vis-weather@2.5.12
            ├── iobroker.vis@1.5.6
            ├── iobroker.weatherunderground@3.7.0
            ├── iobroker.web@7.0.8
            ├── iobroker.ws@2.6.2
            ├── iobroker@2.0.3
            ├── semver@5.7.2
            └── yargs@7.1.2
            npm ls graceful-fs
            ├── colors@1.4.0
            ├── fs-extra@7.0.1
            ├── iobroker@2.0.3
            ├── semver@5.7.2
            └── yargs@7.1.2
            ├─┬ fs-extra@7.0.1
            │ ├── graceful-fs@4.2.11
            │ └─┬ jsonfile@4.0.0
            │   └── graceful-fs@4.2.11 deduped
            ├─┬ iobroker.admin@7.7.19
            │ └─┬ archiver@7.0.1
            │   └─┬ archiver-utils@5.0.2
            ├─┬ iobroker.js-controller@7.0.7
            │ ├─┬ @iobroker/db-objects-file@7.0.7
            │ │ ├─┬ @iobroker/db-base@7.0.7
            │ │ │ └─┬ fs-extra@11.3.2
            │ │ │   ├── graceful-fs@4.2.11 deduped
            │ │ │   └─┬ jsonfile@6.2.0
            │ │ │     └── graceful-fs@4.2.11 deduped
            │ ├─┬ @iobroker/db-objects-jsonl@7.0.7
            │ │ ├─┬ @alcalzone/jsonl-db@3.1.1
            │ │ │ ├─┬ @alcalzone/proper-lockfile@4.1.3-0
            │ │ │ │ └── graceful-fs@4.2.11 deduped
            │ │ │ └─┬ fs-extra@10.1.0
            │ ├─┬ @iobroker/js-controller-adapter@7.0.7
            │ │ ├─┬ @alcalzone/pak@0.8.1
            │ ├─┬ @iobroker/js-controller-cli@7.0.7
            │ ├─┬ @iobroker/js-controller-common-db@7.0.7
            │ ├─┬ @iobroker/js-controller-common@7.0.7
            ├─┬ iobroker.radar@1.2.1
            │ └─┬ @abandonware/noble@1.9.2-26
            │   └─┬ @abandonware/bluetooth-hci-socket@0.5.3-12
            │     └─┬ node-gyp@10.3.1
            ├─┬ iobroker.radar2@2.4.0
            │ └─┬ @stoprocent/noble@1.19.1
            │   └─┬ @stoprocent/bluetooth-hci-socket@1.5.2
            │     └─┬ patch-package@8.0.1
            │       ├─┬ fs-extra@10.1.0
            │       └─┬ klaw-sync@6.0.0
            ├─┬ iobroker.sql@3.0.1
            │ └─┬ sqlite3@5.1.7
            │   └─┬ node-gyp@8.4.1
            ├─┬ iobroker.vis-map@1.1.2
            │ └─┬ @iobroker/dev-server@0.7.8
            │   ├─┬ @iobroker/testing@5.2.2
            │   ├─┬ browser-sync@3.0.4
            │   │ └─┬ fs-extra@3.0.1
            │   │   └─┬ jsonfile@3.0.1
            └─┬ yargs@7.1.2
              └─┬ read-pkg-up@1.0.1
                └─┬ read-pkg@1.1.0
                  ├─┬ load-json-file@1.1.0
                  └─┬ path-type@1.1.0
            Jetzt sieht es auf einmal wieder gut aus, oder?
            G Thomas BraunT 2 Antworten Letzte Antwort
            • G George_Best
              npm ls:
              ├── colors@1.4.0
              ├── fs-extra@7.0.1
              ├── iobroker@2.0.3
              ├── semver@5.7.2
              └── yargs@7.1.2
              npm ls graceful-fs
              ├── colors@1.4.0
              ├── fs-extra@7.0.1
              ├── iobroker@2.0.3
              ├── semver@5.7.2
              └── yargs@7.1.2
              ├─┬ fs-extra@7.0.1
              │ └─┬ sqlite3@5.1.7
              └─┬ yargs@7.1.2
                  └─┬ read-pkg@1.1.0
                    └─┬ path-type@1.1.0
              George_Best
              und zack... iobroker ist wieder weg..
              jonny@ioBroker-V2:/opt/iobroker$ iob status
              node:internal/modules/cjs/loader:1386
                throw err;
              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                  at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                  at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                  at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                  at Function._load (node:internal/modules/cjs/loader:1192:37)
                  at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                  at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                  at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:171:5)
                  at node:internal/main/run_main_module:36:49 {
                code: 'MODULE_NOT_FOUND',
                requireStack: []
              Node.js v22.21.0
              • G Offline
                George_Best
                Es scheint (lt. Logs) immer bei diesem Eintrag los zugehen:
                2025-11-12 16:16:29.213  - error: host.ioBroker-V2 Error: Could not determine controller directory
                    at getControllerDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1833:11)
                    at Module.getPidsFileName (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:3368:22)
                    at Timeout._onTimeout (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:2871:91)
                    at listOnTimeout (node:internal/timers:581:17)
                    at processTimers (node:internal/timers:519:7)
                Davor fangen scheinbar alle Adapter an neu starten - oder was auch immer...
                z.B.
                2025-11-12 16:16:24.689  - error: hm-rpc.0 (8741) hm-rpc.0 already running
                2025-11-12 16:16:24.691  - warn: hm-rpc.0 (8741) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                Ich bin leider völlig ratlos...
                • G Offline
                  George_Best
                  Das "Adapter Requested Termintation" ist doch seltsam:
                  2025-11-12 16:32:31.619  - info: discovery.0 (15882) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2025-11-12 16:32:31.616  - info: hm-rpc.1 (15825) xmlrpc -> 192.168.178.155:2010/ init ["http://192.168.178.121:2010",""]
                  2025-11-12 16:32:31.649  - info: hm-rpc.1 (15825) Disconnected
                  2025-11-12 16:32:31.649  - info: hm-rpc.1 (15825) terminating
                  2025-11-12 16:32:31.650  - info: hm-rpc.1 (15825) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2025-11-12 16:32:31.562  - info: hm-rpc.0 (14348) xmlrpc -> 192.168.178.155:2001/ init ["http://192.168.178.121:2001",""]
                  2025-11-12 16:32:31.571  - info: hm-rpc.0 (14348) Disconnected
                  2025-11-12 16:32:31.572  - info: hm-rpc.0 (14348) terminating
                  2025-11-12 16:32:31.572  - info: hm-rpc.0 (14348) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2025-11-12 16:32:31.685  - info: host.ioBroker-V2 stopInstance system.adapter.admin.0 send kill signal
                  2025-11-12 16:32:31.725  - info: host.ioBroker-V2 stopInstance system.adapter.javascript.0 send kill signal
                  2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.javascript.1 send kill signal
                  2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.email.0 send kill signal
                  2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.telegram.0 send kill signal
                  2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.s7.0 send kill signal
                  2025-11-12 16:32:31.726  - info: host.ioBroker-V2 stopInstance system.adapter.s7.1 send kill signal
                  oder
                  2025-11-12 16:54:15.882  - info: admin.0 (20463) Got terminate signal TERMINATE_YOURSELF
                  2025-11-12 16:54:15.882  - info: javascript.0 (20529) Got terminate signal TERMINATE_YOURSELF
                  2025-11-12 16:54:15.883  - info: telegram.0 (20605) Got terminate signal TERMINATE_YOURSELF
                  2025-11-12 16:54:15.884  - info: javascript.0 (20529) terminating
                  2025-11-12 16:54:15.885  - info: javascript.0 (20529) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2025-11-12 16:54:15.884  - info: s7.1 (20635) Got terminate signal TERMINATE_YOURSELF
                  2025-11-12 16:54:15.885  - info: s7.0 (20620) Got terminate signal TERMINATE_YOURSELF
                  2025-11-12 16:54:15.883  - info: admin.0 (20463) terminating https server on port 8081
                  2025-11-12 16:54:15.884  - info: admin.0 (20463) terminating
                  2025-11-12 16:54:15.885  - info: admin.0 (20463) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  Das ist vermutlich der Grund für die Abstürze?
                  Anbei mal der komplette Log
                  iobroker.2025-11-12.log
                  • G Offline
                    George_Best
                    Neuer Versuch - und wieder:
                    2025-11-12 17:36:08.400  - info: web.0 (28941) starting. Version 7.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v22.21.0, js-controller: 7.0.7
                    2025-11-12 17:36:08.571  - info: web.0 (28941) socket.io server listening on port 8082
                    2025-11-12 17:36:08.572  - info: web.0 (28941) Connecting extension "habpanel/lib/habpanelapi.js"
                    2025-11-12 17:36:08.572  - info: web.0 (28941) habpanel server listening on port 8082
                    2025-11-12 17:36:08.573  - info: web.0 (28941) habpanel web extension - Install extension on /rest/habpanel/
                    2025-11-12 17:36:08.575  - info: web.0 (28941) http server listening on port 8082
                    2025-11-12 17:36:10.873  - error: host.ioBroker-V2 uncaught exception: Could not determine controller directory
                    2025-11-12 17:36:10.873  - error: host.ioBroker-V2 Error: Could not determine controller directory
                        at Module.getAdapterDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1306:37)
                        at startInstance (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:3219:30)
                    Es scheint fast so, als wird immer der js-controller gekillt....
                    Hat jemand eine Idee wie ich das lösen kann?
                    • G George_Best
                      @thomas-braun sagte in iob fix und iob diag ohne Reaktion:
                      @george_best
                      Das Betriebssystem aber nicht.
                      Ich befürchte ich habe das gleiche Problem wie hier: https://forum.iobroker.net/topic/81185/system-admin-upgrade-exited-with-code-25-start-schleife/60
                      1. Betriebssystem habe ich nun geupdatet
                      2. iob fix gemacht
                      library: loaded
                      Library version=2025-08-09
                          Welcome to the ioBroker installation fixer!
                          Script version: 2025-08-09
                          You might need to enter your password a couple of times.
                          Installing prerequisites (1/5)
                      OK:1 http://deb.debian.org/debian bookworm InRelease
                      OK:2 http://deb.debian.org/debian bookworm-updates InRelease
                      OK:3 http://deb.debian.org/debian-security bookworm-security InRelease
                      OK:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                          Checking ioBroker user and directory permissions (2/5)
                          Check and cleanup npm temporary directories (3/5)
                      Done.
                          Database maintenance (4/5)
                      Checking for uncompressed JSONL databases... This might take a while!
                      Compressing /opt/iobroker/iobroker-data/states.jsonl
                      Compressing /opt/iobroker/iobroker-data/objects.jsonl
                      Compressed 2 JSONL files. Done
                          Checking autostart (5/5)
                      ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
                      Legitimierung ist zum Stoppen von »iobroker.service« notwendig.
                      Authenticating as: jonny,,, (jonny)
                      Password:
                      ==== AUTHENTICATION COMPLETE ====
                      Enabling autostart...
                      Autostart enabled!
                          Your installation was fixed successfully
                          Run iobroker start to start ioBroker again!
                      1. iob diag sagt:
                      ```bash
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                       Static hostname: ioBroker-V2
                             Icon name: computer-vm
                               Chassis: vm 🖴
                        Virtualization: kvm
                                Kernel: Linux 6.1.0-41-amd64
                          Architecture: x86-64
                       Hardware Vendor: QEMU
                        Hardware Model: Standard PC _i440FX + PIIX, 1996_
                      Firmware Version: rel-1.16.1-0-g3208b098f51a-prebuilt.qemu.org
                      OS is similar to:
                      model name      : Common KVM processor
                      Docker          : false
                      Virtualization  : kvm
                      Kernel          : x86_64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       16:30:54 up 29 min,  2 users,  load average: 0.64, 0.37, 0.62
                      CPU threads: 8
                      *** LIFE CYCLE STATUS ***
                      Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                      *** TIME AND TIMEZONES ***
                                     Local time: Wed 2025-11-12 16:30:54 CET
                                 Universal time: Wed 2025-11-12 15:30:54 UTC
                                       RTC time: Wed 2025-11-12 15:30:54
                                    NTP service: active
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      jonny
                      HOME=/home/jonny
                      GROUPS=jonny adm cdrom floppy sudo audio dip video plugdev systemd-journal netdev iobroker
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video plugdev bluetooth
                      *** DISPLAY-SERVER SETUP ***
                      Display-Server:         false
                      Unit display-manager.service could not be found.
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Mem:             12G        1.9G        8.1G        561K        2.5G         10G
                      Swap:           4.3G          0B        4.3G
                      Total:           16G        1.9G         12G
                      Active iob-Instances:   6
                              11644 M total memory
                               1812 M used memory
                               1465 M active memory
                               1926 M inactive memory
                               7764 M free memory
                                343 M buffer memory
                               2036 M swap cache
                               4093 M total swap
                                  0 M used swap
                               4093 M free swap
                      top - 16:30:55 up 29 min,  2 users,  load average: 0.64, 0.37, 0.62
                      Tasks: 124 total,   1 running, 123 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :  11644.7 total,   7765.0 free,   1812.8 used,   2380.2 buff/cache
                      MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.   9831.8 avail Mem
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** DMESG CRITICAL ERRORS ***
                      No critical errors detected
                      *** FILESYSTEM ***
                      udev           devtmpfs  5.7G     0  5.7G   0% /dev
                      tmpfs          tmpfs     1.2G  548K  1.2G   1% /run
                      /dev/sda1      ext4       28G   11G   16G  40% /
                      tmpfs          tmpfs     5.7G     0  5.7G   0% /dev/shm
                      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                      tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
                      [Wed Nov 12 16:01:54 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                      [Wed Nov 12 16:01:54 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
                      Show mounted filesystems:
                      TARGET SOURCE    FSTYPE OPTIONS
                      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                      /var:
                      1.9G    /var/
                      889M    /var/cache
                      870M    /var/cache/apt
                      805M    /var/log
                      793M    /var/cache/apt/archives
                      Archived and active journals take up 782.1M in the file system.
                      /opt/iobroker/backups:
                      22M     /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      676M    /opt/iobroker/iobroker-data/
                      450M    /opt/iobroker/iobroker-data/files
                      166M    /opt/iobroker/iobroker-data/backup-objects
                      81M     /opt/iobroker/iobroker-data/files/vis
                      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                      25M     /opt/iobroker/iobroker-data/objects.jsonl
                      12M     /opt/iobroker/iobroker-data/objects.json.migrated
                      12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                      9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
                      4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                      USB-Devices by-id:
                      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2195735-if00
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v22.21.0
                      /usr/bin/node           v22.21.0
                      /usr/bin/npm            10.9.4
                      /usr/bin/npx            10.9.4
                      /usr/bin/corepack       0.34.0
                      nodejs:
                        Installed: 22.21.0-1nodesource1
                        Candidate: 22.21.0-1nodesource1
                        Version table:
                       *** 22.21.0-1nodesource1 1001
                           22.20.0-1nodesource1 1001
                           22.19.0-1nodesource1 1001
                           22.18.0-1nodesource1 1001
                           22.17.1-1nodesource1 1001
                           22.17.0-1nodesource1 1001
                           22.16.0-1nodesource1 1001
                           22.15.1-1nodesource1 1001
                           22.15.0-1nodesource1 1001
                           22.14.0-1nodesource1 1001
                           22.13.1-1nodesource1 1001
                           22.13.0-1nodesource1 1001
                           22.12.0-1nodesource1 1001
                           22.11.0-1nodesource1 1001
                           22.10.0-1nodesource1 1001
                           22.9.0-1nodesource1 1001
                           22.8.0-1nodesource1 1001
                           22.7.0-1nodesource1 1001
                           22.6.0-1nodesource1 1001
                           22.5.1-1nodesource1 1001
                           22.5.0-1nodesource1 1001
                           22.4.1-1nodesource1 1001
                           22.4.0-1nodesource1 1001
                           22.3.0-1nodesource1 1001
                           22.2.0-1nodesource1 1001
                           22.1.0-1nodesource1 1001
                           22.0.0-1nodesource1 1001
                           18.20.4+dfsg-1~deb12u1 500
                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                              500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                      No problems detected
                      Errors in npm tree: 0
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      ioBroker-V2         ioBroker-V2 (version: 7.0.7, hostname: ioBroker-V2   , alive, uptime: 32)
                      Core adapters versions
                      admin:          7.7.19
                      javascript:     8.9.2
                      nodejs modules from github:     2
                      |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
                      | +-- tplink-smarthome-api@5.0.0 invalid: "https://github.com/arteck/tplink-smarthome-api/tarball/08bcca9334c701b60d1eeb18b0ec72350aa3bf7a" from node_modules/iobroker.hs100
                      Adapter State
                        system.adapter.accuweather.0            : accuweather           : ioBroker-V2                              -  enabled
                      + system.adapter.admin.0                  : admin                 : ioBroker-V2                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                        system.adapter.alias-manager.0          : alias-manager         : ioBroker-V2                              -  enabled
                        system.adapter.amazon-dash.0            : amazon-dash           : ioBroker-V2                              - disabled
                        system.adapter.chromecast.0             : chromecast            : ioBroker-V2                              -  enabled
                        system.adapter.cloud.0                  : cloud                 : ioBroker-V2                              - disabled
                        system.adapter.daswetter.0              : daswetter             : ioBroker-V2                              -  enabled
                        system.adapter.deconz.0                 : deconz                : ioBroker-V2                              - disabled, port: 80
                        system.adapter.devices.0                : devices               : ioBroker-V2                              -  enabled
                        system.adapter.discovery.0              : discovery             : ioBroker-V2                              -  enabled
                      + system.adapter.email.0                  : email                 : ioBroker-V2                              -  enabled
                        system.adapter.flot.0                   : flot                  : ioBroker-V2                              -  enabled
                        system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker-V2                              -  enabled
                        system.adapter.fronius.0                : fronius               : ioBroker-V2                              -  enabled
                        system.adapter.frontier_silicon.0       : frontier_silicon      : ioBroker-V2                              -  enabled
                        system.adapter.habpanel.0               : habpanel              : ioBroker-V2                              -  enabled
                        system.adapter.history.0                : history               : ioBroker-V2                              -  enabled
                        system.adapter.hm-rega.0                : hm-rega               : ioBroker-V2                              -  enabled
                        system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-V2                              -  enabled, port: 0
                        system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-V2                              -  enabled, port: 0
                        system.adapter.hs100.0                  : hs100                 : ioBroker-V2                              -  enabled
                        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker-V2                              -  enabled
                        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker-V2                              -  enabled
                        system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-V2                              -  enabled
                        system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-V2                              -  enabled
                        system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker-V2                              -  enabled
                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-V2                              -  enabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-V2                              -  enabled
                        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker-V2                              -  enabled
                        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-V2                              -  enabled
                        system.adapter.influxdb.0               : influxdb              : ioBroker-V2                              - disabled, port: 8086
                        system.adapter.influxdb.1               : influxdb              : ioBroker-V2                              - disabled, port: 8086
                        system.adapter.info.0                   : info                  : ioBroker-V2                              -  enabled
                        system.adapter.iot.0                    : iot                   : ioBroker-V2                              -  enabled
                      + system.adapter.javascript.0             : javascript            : ioBroker-V2                              -  enabled
                      + system.adapter.javascript.1             : javascript            : ioBroker-V2                              -  enabled
                        system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-V2                              - disabled, port: 54321
                        system.adapter.mqtt.0                   : mqtt                  : ioBroker-V2                              -  enabled, port: 1883, bind: 192.168.178.121
                        system.adapter.net-tools.0              : net-tools             : ioBroker-V2                              - disabled
                        system.adapter.net-tools.1              : net-tools             : ioBroker-V2                              -  enabled
                        system.adapter.octoprint.0              : octoprint             : ioBroker-V2                              -  enabled
                        system.adapter.parser.0                 : parser                : ioBroker-V2                              -  enabled
                        system.adapter.ping.0                   : ping                  : ioBroker-V2                              - disabled
                        system.adapter.proxmox.0                : proxmox               : ioBroker-V2                              -  enabled, port: 8006
                        system.adapter.radar.0                  : radar                 : ioBroker-V2                              - disabled
                        system.adapter.radar2.0                 : radar2                : ioBroker-V2                              - disabled
                        system.adapter.radar2.1                 : radar2                : ioBroker-V2                              -  enabled
                        system.adapter.reolink.0                : reolink               : ioBroker-V2                              -  enabled
                        system.adapter.reolink.1                : reolink               : ioBroker-V2                              -  enabled
                        system.adapter.rickshaw.0               : rickshaw              : ioBroker-V2                              -  enabled
                        system.adapter.s7.0                     : s7                    : ioBroker-V2                              -  enabled
                        system.adapter.s7.1                     : s7                    : ioBroker-V2                              -  enabled
                        system.adapter.s7.2                     : s7                    : ioBroker-V2                              -  enabled
                        system.adapter.sayit.0                  : sayit                 : ioBroker-V2                              -  enabled
                        system.adapter.sayit.1                  : sayit                 : ioBroker-V2                              -  enabled
                        system.adapter.sayit.2                  : sayit                 : ioBroker-V2                              -  enabled
                        system.adapter.simple-api.0             : simple-api            : ioBroker-V2                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        system.adapter.smartmeter.0             : smartmeter            : ioBroker-V2                              - disabled
                        system.adapter.smartmeter.2             : smartmeter            : ioBroker-V2                              - disabled
                        system.adapter.socketio.0               : socketio              : ioBroker-V2                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                      + system.adapter.sql.0                    : sql                   : ioBroker-V2                              -  enabled, port: 3306
                        system.adapter.sql.1                    : sql                   : ioBroker-V2                              - disabled, port: 3306
                        system.adapter.statistics.0             : statistics            : ioBroker-V2                              -  enabled
                        system.adapter.systeminfo.0             : systeminfo            : ioBroker-V2                              - disabled
                        system.adapter.telegram.0               : telegram              : ioBroker-V2                              -  enabled, port: 8443, bind: 0.0.0.0
                        system.adapter.terminal.0               : terminal              : ioBroker-V2                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                        system.adapter.tr-064.0                 : tr-064                : ioBroker-V2                              -  enabled
                        system.adapter.unifi.0                  : unifi                 : ioBroker-V2                              -  enabled
                        system.adapter.upnp.0                   : upnp                  : ioBroker-V2                              -  enabled
                        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker-V2                              -  enabled
                        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker-V2                              -  enabled
                        system.adapter.vis-2.0                  : vis-2                 : ioBroker-V2                              -  enabled
                        system.adapter.vis-bars.0               : vis-bars              : ioBroker-V2                              -  enabled
                        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-V2                              -  enabled
                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-V2                              -  enabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-V2                              -  enabled
                        system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker-V2                              -  enabled
                        system.adapter.vis-history.0            : vis-history           : ioBroker-V2                              -  enabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-V2                              -  enabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-V2                              -  enabled
                        system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-V2                              -  enabled
                        system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-V2                              -  enabled
                        system.adapter.vis-lcars.0              : vis-lcars             : ioBroker-V2                              -  enabled
                        system.adapter.vis-map.0                : vis-map               : ioBroker-V2                              -  enabled
                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker-V2                              -  enabled
                        system.adapter.vis-metro.0              : vis-metro             : ioBroker-V2                              -  enabled
                        system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-V2                              -  enabled
                        system.adapter.vis-weather.0            : vis-weather           : ioBroker-V2                              -  enabled
                        system.adapter.vis.0                    : vis                   : ioBroker-V2                              -  enabled
                        system.adapter.weatherunderground.0     : weatherunderground    : ioBroker-V2                              -  enabled
                        system.adapter.web.0                    : web                   : ioBroker-V2                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): stable
                      Upgrade policy: none
                      Installed ioBroker-Adapters
                      Used repository: stable
                      Adapter    "accuweather"  : 2.1.1    , installed 2.1.1
                      Adapter    "admin"        : 7.7.19   , installed 7.7.19
                      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                      Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
                      Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
                      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                      Adapter    "deconz"       : 1.6.4    , installed 1.6.4
                      Adapter    "devices"      : 1.2.8    , installed 1.2.8
                      Adapter    "email"        : 2.0.4    , installed 2.0.4
                      Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                      Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                      Adapter    "frontier_silicon": 0.5.0 , installed 0.5.0
                      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                      Adapter    "hs100"        : 3.0.5    , installed 3.0.5
                      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                      Adapter    "iot"          : 5.0.7    , installed 5.0.7
                      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                      Controller "js-controller": 7.0.7    , installed 7.0.7
                      Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
                      Adapter    "net-tools"    : 1.1.2    , installed 1.1.2
                      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                      Adapter    "parser"       : 2.2.4    , installed 2.2.4
                      Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                      Adapter    "radar2"       : 2.4.0    , installed 2.4.0
                      Adapter    "reolink"      : 1.2.3    , installed 1.2.3
                      Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
                      Adapter    "s7"           : 1.5.0    , installed 1.5.0
                      Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                      Adapter    "sql"          : 3.0.1    , installed 3.0.1
                      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                      Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
                      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                      Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                      Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
                      Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
                      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                      Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
                      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                      Adapter    "web"          : 7.0.8    , installed 7.0.8
                      Objects and States
                      Objects:        24997
                      States:         20033
                      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                      Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                      Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 192.168.178.121:2001    0.0.0.0:*               LISTEN      1001       66571      14348/io.hm-rpc.0
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17410      736/exim4
                      tcp        0      0 192.168.178.121:1883    0.0.0.0:*               LISTEN      1001       61291      14044/io.mqtt.0
                      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       62504      12617/iobroker.js-c
                      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       59698      12617/iobroker.js-c
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15485      553/sshd: /usr/sbin
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       59780      12641/io.admin.0
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17411      736/exim4
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          15487      553/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:35015           0.0.0.0:*                           107        13947      440/avahi-daemon: r
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       65677      14275/io.chromecast
                      udp        0      0 192.168.178.121:5353    0.0.0.0:*                           1001       64680      14141/io.tr-064.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        13945      440/avahi-daemon: r
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13849      376/dhclient
                      udp6       0      0 :::36795                :::*                                107        13948      440/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                107        13946      440/avahi-daemon: r
                      2025-11-12 16:31:21.431  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] connected with secret 1762961481430_2245
                      2025-11-12 16:31:21.446  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] subscribes on "Wemos_DisplayV2_6/#" with regex /^Wemos_DisplayV2_6\..*/
                      2025-11-12 16:31:21.447  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] subscribes on "Wemos_DisplayV2_6/#"  with regex /^mqtt\.0\.Wemos_DisplayV2_6\..*/
                      2025-11-12 16:31:21.647  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] publishOnSubscribe send all known states
                      2025-11-12 16:31:22.266  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 1(Jonny-Pixel3/3C:28:6D:E8:64:45) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                      2025-11-12 16:31:22.409  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 2(Jenny-Pixel3a/58:CB:52:8E:4E:68) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                      2025-11-12 16:31:22.548  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 3(Jonny-Arbeit-A40/F0:8A:76:20:A8:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                      2025-11-12 16:31:22.766  - info: chromecast.0 (14275) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.chromecast, node: v22.21.0, js-controller: 7.0.7
                      2025-11-12 16:31:23.348  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 7(Pixel-3a/BA:DC:2D:6F:F1:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                      2025-11-12 16:31:23.407  - info: chromecast.0 (14275) Google_HomeKueche - Connected client
                      2025-11-12 16:31:23.438  - info: chromecast.0 (14275) Küche - Connected client
                      2025-11-12 16:31:23.905  - info: host.ioBroker-V2 instance system.adapter.hm-rpc.0 in version "2.0.2" started with pid 14348
                      2025-11-12 16:31:26.245  - info: hm-rpc.0 (14348) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v22.21.0, js-controller: 7.0.7
                      2025-11-12 16:31:26.463  - info: hm-rpc.0 (14348) xmlrpc server is trying to listen on 192.168.178.121:2001
                      2025-11-12 16:31:26.464  - info: hm-rpc.0 (14348) xmlrpc client is trying to connect to 192.168.178.155:2001/ with ["http://192.168.178.121:2001","ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
                      2025-11-12 16:31:26.492  - info: hm-rpc.0 (14348) xmlrpc <- system.listMethods ["ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
                      2025-11-12 16:31:26.498  - info: hm-rpc.0 (14348) xmlrpc <- listDevices ["ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
                      2025-11-12 16:31:26.528  - info: hm-rpc.0 (14348) xmlrpc -> 64 devices
                      2025-11-12 16:31:26.547  - info: hm-rpc.0 (14348) Connected
                      2025-11-12 16:31:27.831  - info: host.ioBroker-V2 instance system.adapter.hm-rega.0 in version "5.1.0" started with pid 14782
                      2025-11-12 16:31:30.487  - info: hm-rega.0 (14782) starting. Version 5.1.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v22.21.0, js-controller: 7.0.7
                      2025-11-12 16:31:30.694  - info: hm-rega.0 (14782) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                      2025-11-12 16:31:30.763  - info: hm-rega.0 (14782) ReGaHSS 192.168.178.155 up
                      2025-11-12 16:31:30.869  - info: hm-rega.0 (14782) time difference local-ccu 1s
                      2025-11-12 16:31:31.325  - info: hm-rega.0 (14782) request state values
                      Ro75R Offline
                      Ro75R Offline
                      Ro75
                      @george_best
                      Was ist das? Woher kommt das?
                      Ro75.
                      • Ro75R Ro75
                        @george_best
                        Ro75.
                        George_Best
                        @ro75
                        ersteres ist wohl vom hometmatic adapter
                        letzeres ist ein Adapter von TP-Link für smarte Steckdosen
                        Ro75R 1 Antwort Letzte Antwort
                        • G George_Best
                          @ro75
                          Ro75R Offline
                          Ro75R Offline
                          Ro75
                          @george_best mir geht es mehr um das "invalid"
                          Ro75.
                          • Ro75R Ro75
                            Ro75.
                            George_Best
                            @ro75
                            woher hast du die Zeilen genau?
                            Weil der npm-tree am Anfang war als der js-controller nicht mehr da war. Da war/ist so ziemlich alles auf "invalid"
                            • G George_Best
                              @ro75
                              Ro75R Offline
                              Ro75R Offline
                              Ro75
                              aus deinem iob diag log
                              Ro75.
                              • Ro75R Ro75
                                Ro75.
                                George_Best
                                @ro75
                                ok.
                                Adapter mal löschen? Neu installieren?
                                • G George_Best
                                  @ro75
                                  ok.
                                  Ro75R Offline
                                  Ro75R Offline
                                  Ro75
                                  @george_best keine Ahnung. Auf alle Fälle, die, die man nicht (mehr) braucht können auch weg. Weniger Last, weniger Probleme.
                                  Ro75.
                                  • G George_Best
                                    npm ls:
                                    ├── colors@1.4.0
                                    ├── fs-extra@7.0.1
                                    ├── iobroker@2.0.3
                                    ├── semver@5.7.2
                                    └── yargs@7.1.2
                                    npm ls graceful-fs
                                    ├── colors@1.4.0
                                    ├── fs-extra@7.0.1
                                    ├── iobroker@2.0.3
                                    ├── semver@5.7.2
                                    └── yargs@7.1.2
                                    ├─┬ fs-extra@7.0.1
                                    │ └─┬ sqlite3@5.1.7
                                    └─┬ yargs@7.1.2
                                        └─┬ read-pkg@1.1.0
                                          └─┬ path-type@1.1.0
                                    ├── semver@5.7.2
                                    ├── semver@5.7.2
                                    └── yargs@7.1.2
                                    ├─┬ fs-extra@7.0.1
                                    Die Stelle schau auch komisch aus...
                                    Bitte NICHT die LogInPrompts löschen und IMMER die vollständigen Ein- und Ausgaben posten. Man kann sich ohne die Dinger als Helfer nur schlecht durch die zusammenkopierten Ausgaben hangeln.
                                    • G Offline
                                      George_Best
                                      hm... es läuft nun schon einige Minuten stabil...
                                      Möglicherweise war es der HS100 Adapter
                                      Ro75R Thomas BraunT 2 Antworten Letzte Antwort
                                      • G George_Best
                                        Ro75R Offline
                                        Ro75R Offline
                                        Ro75
                                        @george_best der HS100 läuft bei mir. Installiere den, falls du den brauchst, einfach mal neu.
                                        Ro75.
                                        • G George_Best
                                          @george_best
                                          Du kannst auch mal schauen, was da passiert:
                                          cd /opt/iobroker && npm ci
                                          Wird was länger laufen, vermutlich.
