  4. iob fix und iob diag ohne Reaktion
    6.4k
94 Beiträge 8 Kommentatoren 12.8k Aufrufe 4 Beobachtet
  • G George_Best
    @thomas-braun sagte in iob fix und iob diag ohne Reaktion:
    @george_best
    Das Betriebssystem aber nicht.
    Ich befürchte ich habe das gleiche Problem wie hier: https://forum.iobroker.net/topic/81185/system-admin-upgrade-exited-with-code-25-start-schleife/60
    1. Betriebssystem habe ich nun geupdatet
    2. iob fix gemacht
    library: loaded
    Library version=2025-08-09
        Welcome to the ioBroker installation fixer!
        Script version: 2025-08-09
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    OK:1 http://deb.debian.org/debian bookworm InRelease
    OK:2 http://deb.debian.org/debian bookworm-updates InRelease
    OK:3 http://deb.debian.org/debian-security bookworm-security InRelease
    OK:4 https://deb.nodesource.com/node_22.x nodistro InRelease
        Checking ioBroker user and directory permissions (2/5)
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
    Legitimierung ist zum Stoppen von »iobroker.service« notwendig.
    Authenticating as: jonny,,, (jonny)
    Password:
    ==== AUTHENTICATION COMPLETE ====
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    1. iob diag sagt:
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: ioBroker-V2
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-41-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.1-0-g3208b098f51a-prebuilt.qemu.org
    OS is similar to:
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     16:30:54 up 29 min,  2 users,  load average: 0.64, 0.37, 0.62
    CPU threads: 8
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-11-12 16:30:54 CET
               Universal time: Wed 2025-11-12 15:30:54 UTC
                     RTC time: Wed 2025-11-12 15:30:54
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    jonny
    HOME=/home/jonny
    GROUPS=jonny adm cdrom floppy sudo audio dip video plugdev systemd-journal netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev bluetooth
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             12G        1.9G        8.1G        561K        2.5G         10G
    Swap:           4.3G          0B        4.3G
    Total:           16G        1.9G         12G
    Active iob-Instances:   6
            11644 M total memory
             1812 M used memory
             1465 M active memory
             1926 M inactive memory
             7764 M free memory
              343 M buffer memory
             2036 M swap cache
             4093 M total swap
                0 M used swap
             4093 M free swap
    top - 16:30:55 up 29 min,  2 users,  load average: 0.64, 0.37, 0.62
    Tasks: 124 total,   1 running, 123 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  11644.7 total,   7765.0 free,   1812.8 used,   2380.2 buff/cache
    MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.   9831.8 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  5.7G     0  5.7G   0% /dev
    tmpfs          tmpfs     1.2G  548K  1.2G   1% /run
    /dev/sda1      ext4       28G   11G   16G  40% /
    tmpfs          tmpfs     5.7G     0  5.7G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
    [Wed Nov 12 16:01:54 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Nov 12 16:01:54 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    1.9G    /var/
    889M    /var/cache
    870M    /var/cache/apt
    805M    /var/log
    793M    /var/cache/apt/archives
    Archived and active journals take up 782.1M in the file system.
    /opt/iobroker/backups:
    22M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    676M    /opt/iobroker/iobroker-data/
    450M    /opt/iobroker/iobroker-data/files
    166M    /opt/iobroker/iobroker-data/backup-objects
    81M     /opt/iobroker/iobroker-data/files/vis
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/objects.json.migrated
    12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2195735-if00
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker-V2         ioBroker-V2 (version: 7.0.7, hostname: ioBroker-V2   , alive, uptime: 32)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     8.9.2
    nodejs modules from github:     2
    |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
    | +-- tplink-smarthome-api@5.0.0 invalid: "https://github.com/arteck/tplink-smarthome-api/tarball/08bcca9334c701b60d1eeb18b0ec72350aa3bf7a" from node_modules/iobroker.hs100
    Adapter State
      system.adapter.accuweather.0            : accuweather           : ioBroker-V2                              -  enabled
    + system.adapter.admin.0                  : admin                 : ioBroker-V2                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.alias-manager.0          : alias-manager         : ioBroker-V2                              -  enabled
      system.adapter.amazon-dash.0            : amazon-dash           : ioBroker-V2                              - disabled
      system.adapter.chromecast.0             : chromecast            : ioBroker-V2                              -  enabled
      system.adapter.cloud.0                  : cloud                 : ioBroker-V2                              - disabled
      system.adapter.daswetter.0              : daswetter             : ioBroker-V2                              -  enabled
      system.adapter.deconz.0                 : deconz                : ioBroker-V2                              - disabled, port: 80
      system.adapter.devices.0                : devices               : ioBroker-V2                              -  enabled
      system.adapter.discovery.0              : discovery             : ioBroker-V2                              -  enabled
    + system.adapter.email.0                  : email                 : ioBroker-V2                              -  enabled
      system.adapter.flot.0                   : flot                  : ioBroker-V2                              -  enabled
      system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker-V2                              -  enabled
      system.adapter.fronius.0                : fronius               : ioBroker-V2                              -  enabled
      system.adapter.frontier_silicon.0       : frontier_silicon      : ioBroker-V2                              -  enabled
      system.adapter.habpanel.0               : habpanel              : ioBroker-V2                              -  enabled
      system.adapter.history.0                : history               : ioBroker-V2                              -  enabled
      system.adapter.hm-rega.0                : hm-rega               : ioBroker-V2                              -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-V2                              -  enabled, port: 0
      system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-V2                              -  enabled, port: 0
      system.adapter.hs100.0                  : hs100                 : ioBroker-V2                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker-V2                              -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker-V2                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-V2                              -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-V2                              -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker-V2                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-V2                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-V2                              -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker-V2                              -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-V2                              -  enabled
      system.adapter.influxdb.0               : influxdb              : ioBroker-V2                              - disabled, port: 8086
      system.adapter.influxdb.1               : influxdb              : ioBroker-V2                              - disabled, port: 8086
      system.adapter.info.0                   : info                  : ioBroker-V2                              -  enabled
      system.adapter.iot.0                    : iot                   : ioBroker-V2                              -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker-V2                              -  enabled
    + system.adapter.javascript.1             : javascript            : ioBroker-V2                              -  enabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-V2                              - disabled, port: 54321
      system.adapter.mqtt.0                   : mqtt                  : ioBroker-V2                              -  enabled, port: 1883, bind: 192.168.178.121
      system.adapter.net-tools.0              : net-tools             : ioBroker-V2                              - disabled
      system.adapter.net-tools.1              : net-tools             : ioBroker-V2                              -  enabled
      system.adapter.octoprint.0              : octoprint             : ioBroker-V2                              -  enabled
      system.adapter.parser.0                 : parser                : ioBroker-V2                              -  enabled
      system.adapter.ping.0                   : ping                  : ioBroker-V2                              - disabled
      system.adapter.proxmox.0                : proxmox               : ioBroker-V2                              -  enabled, port: 8006
      system.adapter.radar.0                  : radar                 : ioBroker-V2                              - disabled
      system.adapter.radar2.0                 : radar2                : ioBroker-V2                              - disabled
      system.adapter.radar2.1                 : radar2                : ioBroker-V2                              -  enabled
      system.adapter.reolink.0                : reolink               : ioBroker-V2                              -  enabled
      system.adapter.reolink.1                : reolink               : ioBroker-V2                              -  enabled
      system.adapter.rickshaw.0               : rickshaw              : ioBroker-V2                              -  enabled
      system.adapter.s7.0                     : s7                    : ioBroker-V2                              -  enabled
      system.adapter.s7.1                     : s7                    : ioBroker-V2                              -  enabled
      system.adapter.s7.2                     : s7                    : ioBroker-V2                              -  enabled
      system.adapter.sayit.0                  : sayit                 : ioBroker-V2                              -  enabled
      system.adapter.sayit.1                  : sayit                 : ioBroker-V2                              -  enabled
      system.adapter.sayit.2                  : sayit                 : ioBroker-V2                              -  enabled
      system.adapter.simple-api.0             : simple-api            : ioBroker-V2                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.smartmeter.0             : smartmeter            : ioBroker-V2                              - disabled
      system.adapter.smartmeter.2             : smartmeter            : ioBroker-V2                              - disabled
      system.adapter.socketio.0               : socketio              : ioBroker-V2                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sql.0                    : sql                   : ioBroker-V2                              -  enabled, port: 3306
      system.adapter.sql.1                    : sql                   : ioBroker-V2                              - disabled, port: 3306
      system.adapter.statistics.0             : statistics            : ioBroker-V2                              -  enabled
      system.adapter.systeminfo.0             : systeminfo            : ioBroker-V2                              - disabled
      system.adapter.telegram.0               : telegram              : ioBroker-V2                              -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.terminal.0               : terminal              : ioBroker-V2                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      system.adapter.tr-064.0                 : tr-064                : ioBroker-V2                              -  enabled
      system.adapter.unifi.0                  : unifi                 : ioBroker-V2                              -  enabled
      system.adapter.upnp.0                   : upnp                  : ioBroker-V2                              -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker-V2                              -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker-V2                              -  enabled
      system.adapter.vis-2.0                  : vis-2                 : ioBroker-V2                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : ioBroker-V2                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-V2                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-V2                              -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-V2                              -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker-V2                              -  enabled
      system.adapter.vis-history.0            : vis-history           : ioBroker-V2                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-V2                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-V2                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-V2                              -  enabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-V2                              -  enabled
      system.adapter.vis-lcars.0              : vis-lcars             : ioBroker-V2                              -  enabled
      system.adapter.vis-map.0                : vis-map               : ioBroker-V2                              -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker-V2                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : ioBroker-V2                              -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-V2                              -  enabled
      system.adapter.vis-weather.0            : vis-weather           : ioBroker-V2                              -  enabled
      system.adapter.vis.0                    : vis                   : ioBroker-V2                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker-V2                              -  enabled
      system.adapter.web.0                    : web                   : ioBroker-V2                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "accuweather"  : 2.1.1    , installed 2.1.1
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "deconz"       : 1.6.4    , installed 1.6.4
    Adapter    "devices"      : 1.2.8    , installed 1.2.8
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "fronius"      : 2.1.1    , installed 2.1.1
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
    Adapter    "frontier_silicon": 0.5.0 , installed 0.5.0
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "hs100"        : 3.0.5    , installed 3.0.5
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iot"          : 5.0.7    , installed 5.0.7
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "net-tools"    : 1.1.2    , installed 1.1.2
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "parser"       : 2.2.4    , installed 2.2.4
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "radar2"       : 2.4.0    , installed 2.4.0
    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "s7"           : 1.5.0    , installed 1.5.0
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Objects and States
    Objects:        24997
    States:         20033
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.121:2001    0.0.0.0:*               LISTEN      1001       66571      14348/io.hm-rpc.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17410      736/exim4
    tcp        0      0 192.168.178.121:1883    0.0.0.0:*               LISTEN      1001       61291      14044/io.mqtt.0
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       62504      12617/iobroker.js-c
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       59698      12617/iobroker.js-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15485      553/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       59780      12641/io.admin.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17411      736/exim4
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15487      553/sshd: /usr/sbin
    udp        0      0 0.0.0.0:35015           0.0.0.0:*                           107        13947      440/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       65677      14275/io.chromecast
    udp        0      0 192.168.178.121:5353    0.0.0.0:*                           1001       64680      14141/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        13945      440/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13849      376/dhclient
    udp6       0      0 :::36795                :::*                                107        13948      440/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                107        13946      440/avahi-daemon: r
    2025-11-12 16:31:21.431  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] connected with secret 1762961481430_2245
    2025-11-12 16:31:21.446  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] subscribes on "Wemos_DisplayV2_6/#" with regex /^Wemos_DisplayV2_6\..*/
    2025-11-12 16:31:21.447  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] subscribes on "Wemos_DisplayV2_6/#"  with regex /^mqtt\.0\.Wemos_DisplayV2_6\..*/
    2025-11-12 16:31:21.647  - info: mqtt.0 (14044) Client [Wemos_DisplayV2_6_6] publishOnSubscribe send all known states
    2025-11-12 16:31:22.266  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 1(Jonny-Pixel3/3C:28:6D:E8:64:45) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2025-11-12 16:31:22.409  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 2(Jenny-Pixel3a/58:CB:52:8E:4E:68) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2025-11-12 16:31:22.548  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 3(Jonny-Arbeit-A40/F0:8A:76:20:A8:C4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2025-11-12 16:31:22.766  - info: chromecast.0 (14275) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.chromecast, node: v22.21.0, js-controller: 7.0.7
    2025-11-12 16:31:23.348  - info: tr-064.0 (14141) forEachConfiguredDevice: in GetSpecificHostEntry 7(Pixel-3a/BA:DC:2D:6F:F1:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2025-11-12 16:31:23.407  - info: chromecast.0 (14275) Google_HomeKueche - Connected client
    2025-11-12 16:31:23.438  - info: chromecast.0 (14275) Küche - Connected client
    2025-11-12 16:31:23.905  - info: host.ioBroker-V2 instance system.adapter.hm-rpc.0 in version "2.0.2" started with pid 14348
    2025-11-12 16:31:26.245  - info: hm-rpc.0 (14348) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v22.21.0, js-controller: 7.0.7
    2025-11-12 16:31:26.463  - info: hm-rpc.0 (14348) xmlrpc server is trying to listen on 192.168.178.121:2001
    2025-11-12 16:31:26.464  - info: hm-rpc.0 (14348) xmlrpc client is trying to connect to 192.168.178.155:2001/ with ["http://192.168.178.121:2001","ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
    2025-11-12 16:31:26.492  - info: hm-rpc.0 (14348) xmlrpc <- system.listMethods ["ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
    2025-11-12 16:31:26.498  - info: hm-rpc.0 (14348) xmlrpc <- listDevices ["ioBroker-V2:hm-rpc.0:cdcb77aa3039a2b66116c21d0739e6a5"]
    2025-11-12 16:31:26.528  - info: hm-rpc.0 (14348) xmlrpc -> 64 devices
    2025-11-12 16:31:26.547  - info: hm-rpc.0 (14348) Connected
    2025-11-12 16:31:27.831  - info: host.ioBroker-V2 instance system.adapter.hm-rega.0 in version "5.1.0" started with pid 14782
    2025-11-12 16:31:30.487  - info: hm-rega.0 (14782) starting. Version 5.1.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v22.21.0, js-controller: 7.0.7
    2025-11-12 16:31:30.694  - info: hm-rega.0 (14782) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
    2025-11-12 16:31:30.763  - info: hm-rega.0 (14782) ReGaHSS 192.168.178.155 up
    2025-11-12 16:31:30.869  - info: hm-rega.0 (14782) time difference local-ccu 1s
    2025-11-12 16:31:31.325  - info: hm-rega.0 (14782) request state values
    Ro75R Offline
    Ro75R Offline
    Ro75
    @george_best
    Was ist das? Woher kommt das?
    Ro75.
    G 1 Antwort Letzte Antwort
    • Ro75R Ro75
      @george_best
      Ro75.
      George_Best
      @ro75
      ersteres ist wohl vom hometmatic adapter
      letzeres ist ein Adapter von TP-Link für smarte Steckdosen
      Ro75R 1 Antwort Letzte Antwort
      • G George_Best
        @ro75
        Ro75R Offline
        Ro75R Offline
        Ro75
        @george_best mir geht es mehr um das "invalid"
        Ro75.
        • Ro75R Ro75
          Ro75.
          George_Best
          @ro75
          woher hast du die Zeilen genau?
          Weil der npm-tree am Anfang war als der js-controller nicht mehr da war. Da war/ist so ziemlich alles auf "invalid"
          • G George_Best
            @ro75
            Ro75R Offline
            Ro75R Offline
            Ro75
            @george_best sagte in iob fix und iob diag ohne Reaktion:
            aus deinem iob diag log
            Ro75.
            • Ro75R Ro75
              Ro75.
              George_Best
              @ro75
              ok.
              Adapter mal löschen? Neu installieren?
              • G George_Best
                @ro75
                ok.
                Ro75R Offline
                Ro75R Offline
                Ro75
                @george_best keine Ahnung. Auf alle Fälle, die, die man nicht (mehr) braucht können auch weg. Weniger Last, weniger Probleme.
                Ro75.
                • G George_Best
                  npm ls:
                  iobroker.inst@2.0.2 /opt/iobroker
                  ├── @iobroker-javascript.0/moment-parseformat@npm:moment-parseformat@4.0.0
                  ├── @iobroker-javascript.0/moment@npm:moment@2.30.1
                  ├── colors@1.4.0
                  ├── fs-extra@7.0.1
                  ├── iobroker.accuweather@2.1.1
                  ├── iobroker.admin@7.7.19
                  ├── iobroker.alias-manager@2.0.0
                  ├── iobroker.amazon-dash@1.2.0
                  ├── iobroker.chromecast@4.0.0
                  ├── iobroker.cloud@5.0.1
                  ├── iobroker.daswetter@3.2.3
                  ├── iobroker.deconz@1.6.4
                  ├── iobroker.devices@1.2.8
                  ├── iobroker.discovery@5.0.0
                  ├── iobroker.email@2.0.4
                  ├── iobroker.flot@1.12.0
                  ├── iobroker.fronius-solarweb@0.0.3
                  ├── iobroker.fronius@2.1.1
                  ├── iobroker.frontier_silicon@0.5.0
                  ├── iobroker.habpanel@0.5.0
                  ├── iobroker.history@3.0.1
                  ├── iobroker.hm-rega@5.1.0
                  ├── iobroker.hm-rpc@2.0.2
                  ├── iobroker.hs100@3.0.5
                  ├── iobroker.icons-addictive-flavour-png@0.1.0
                  ├── iobroker.icons-fatcow-hosting@0.1.0
                  ├── iobroker.icons-icons8@0.0.1
                  ├── iobroker.icons-material-png@0.1.0
                  ├── iobroker.icons-material-svg@0.1.0
                  ├── iobroker.icons-mfd-png@1.2.1
                  ├── iobroker.icons-mfd-svg@1.2.0
                  ├── iobroker.icons-open-icon-library-png@0.1.2
                  ├── iobroker.icons-ultimate-png@1.0.1
                  ├── iobroker.influxdb@4.0.2
                  ├── iobroker.info@2.0.0
                  ├── iobroker.iot@5.0.7
                  ├── iobroker.javascript@8.9.2
                  ├── iobroker.js-controller@7.0.7
                  ├── iobroker.mihome-vacuum@5.2.0
                  ├── iobroker.mqtt@6.1.4
                  ├── iobroker.net-tools@1.1.2
                  ├── iobroker.octoprint@5.1.0
                  ├── iobroker.openweathermap@1.1.2
                  ├── iobroker.parser@2.2.4
                  ├── iobroker.ping@1.6.2
                  ├── iobroker.proxmox@2.4.0
                  ├── iobroker.radar@1.2.1
                  ├── iobroker.radar2@2.4.0
                  ├── iobroker.reolink@1.2.3
                  ├── iobroker.rickshaw@1.0.0
                  ├── iobroker.s7@1.5.0
                  ├── iobroker.sayit@5.0.0
                  ├── iobroker.smartmeter@3.4.0
                  ├── iobroker.socketio@6.7.1
                  ├── iobroker.sql@3.0.1
                  ├── iobroker.statistics@2.4.0
                  ├── iobroker.systeminfo@1.3.0
                  ├── iobroker.telegram@4.1.0
                  ├── iobroker.terminal@1.0.0
                  ├── iobroker.tr-064@4.3.0
                  ├── iobroker.unifi@0.7.0
                  ├── iobroker.upnp@1.1.0
                  ├── iobroker.vis-2-widgets-inventwo@0.2.2
                  ├── iobroker.vis-2-widgets-material@1.4.10
                  ├── iobroker.vis-2@2.13.4
                  ├── iobroker.vis-bars@0.1.4
                  ├── iobroker.vis-canvas-gauges@1.0.1
                  ├── iobroker.vis-colorpicker@2.0.3
                  ├── iobroker.vis-fancyswitch@1.1.0
                  ├── iobroker.vis-google-fonts@1.0.4
                  ├── iobroker.vis-history@1.0.0
                  ├── iobroker.vis-hqwidgets@1.5.1
                  ├── iobroker.vis-jqui-mfd@1.1.1
                  ├── iobroker.vis-justgage@2.1.7
                  ├── iobroker.vis-keyboard@0.0.2
                  ├── iobroker.vis-lcars@1.1.1
                  ├── iobroker.vis-map@1.1.2
                  ├── iobroker.vis-materialdesign@0.5.9
                  ├── iobroker.vis-metro@1.2.0
                  ├── iobroker.vis-rgraph@0.0.2
                  ├── iobroker.vis-weather@2.5.12
                  ├── iobroker.vis@1.5.6
                  ├── iobroker.weatherunderground@3.7.0
                  ├── iobroker.web@7.0.8
                  ├── iobroker.ws@2.6.2
                  ├── iobroker@2.0.3
                  ├── semver@5.7.2
                  └── yargs@7.1.2
                  npm ls graceful-fs
                  ├── colors@1.4.0
                  ├── fs-extra@7.0.1
                  ├── iobroker@2.0.3
                  ├── semver@5.7.2
                  └── yargs@7.1.2
                  ├─┬ fs-extra@7.0.1
                  │ ├── graceful-fs@4.2.11
                  │ └─┬ jsonfile@4.0.0
                  │   └── graceful-fs@4.2.11 deduped
                  ├─┬ iobroker.admin@7.7.19
                  │ └─┬ archiver@7.0.1
                  │   └─┬ archiver-utils@5.0.2
                  ├─┬ iobroker.js-controller@7.0.7
                  │ ├─┬ @iobroker/db-objects-file@7.0.7
                  │ │ ├─┬ @iobroker/db-base@7.0.7
                  │ │ │ └─┬ fs-extra@11.3.2
                  │ │ │   ├── graceful-fs@4.2.11 deduped
                  │ │ │   └─┬ jsonfile@6.2.0
                  │ │ │     └── graceful-fs@4.2.11 deduped
                  │ ├─┬ @iobroker/db-objects-jsonl@7.0.7
                  │ │ ├─┬ @alcalzone/jsonl-db@3.1.1
                  │ │ │ ├─┬ @alcalzone/proper-lockfile@4.1.3-0
                  │ │ │ │ └── graceful-fs@4.2.11 deduped
                  │ │ │ └─┬ fs-extra@10.1.0
                  │ ├─┬ @iobroker/js-controller-adapter@7.0.7
                  │ │ ├─┬ @alcalzone/pak@0.8.1
                  │ ├─┬ @iobroker/js-controller-cli@7.0.7
                  │ ├─┬ @iobroker/js-controller-common-db@7.0.7
                  │ ├─┬ @iobroker/js-controller-common@7.0.7
                  ├─┬ iobroker.radar@1.2.1
                  │ └─┬ @abandonware/noble@1.9.2-26
                  │   └─┬ @abandonware/bluetooth-hci-socket@0.5.3-12
                  │     └─┬ node-gyp@10.3.1
                  ├─┬ iobroker.radar2@2.4.0
                  │ └─┬ @stoprocent/noble@1.19.1
                  │   └─┬ @stoprocent/bluetooth-hci-socket@1.5.2
                  │     └─┬ patch-package@8.0.1
                  │       ├─┬ fs-extra@10.1.0
                  │       └─┬ klaw-sync@6.0.0
                  ├─┬ iobroker.sql@3.0.1
                  │ └─┬ sqlite3@5.1.7
                  │   └─┬ node-gyp@8.4.1
                  ├─┬ iobroker.vis-map@1.1.2
                  │ └─┬ @iobroker/dev-server@0.7.8
                  │   ├─┬ @iobroker/testing@5.2.2
                  │   ├─┬ browser-sync@3.0.4
                  │   │ └─┬ fs-extra@3.0.1
                  │   │   └─┬ jsonfile@3.0.1
                  └─┬ yargs@7.1.2
                    └─┬ read-pkg-up@1.0.1
                      └─┬ read-pkg@1.1.0
                        ├─┬ load-json-file@1.1.0
                        └─┬ path-type@1.1.0
                  Jetzt sieht es auf einmal wieder gut aus, oder?
                  ├── semver@5.7.2
                  ├── semver@5.7.2
                  └── yargs@7.1.2
                  ├─┬ fs-extra@7.0.1
                  Die Stelle schau auch komisch aus...
                  Bitte NICHT die LogInPrompts löschen und IMMER die vollständigen Ein- und Ausgaben posten. Man kann sich ohne die Dinger als Helfer nur schlecht durch die zusammenkopierten Ausgaben hangeln.
                  • G Offline
                    George_Best
                    hm... es läuft nun schon einige Minuten stabil...
                    Möglicherweise war es der HS100 Adapter
                    Ro75R Thomas BraunT 2 Antworten Letzte Antwort
                    • G George_Best
                      Ro75R Offline
                      Ro75R Offline
                      Ro75
                      @george_best der HS100 läuft bei mir. Installiere den, falls du den brauchst, einfach mal neu.
                      Ro75.
                      • G George_Best
                        @george_best
                        Du kannst auch mal schauen, was da passiert:
                        cd /opt/iobroker && npm ci
                        Wird was länger laufen, vermutlich.
                          @george_best
                          George_Best
                          Ich glaube das sieht nicht gut aus:
                          jonny@ioBroker-V2:/opt/iobroker$ cd /opt/iobroker && npm ci
                          [sudo] Passwort für jonny:
                          npm warn old lockfile
                          npm warn old lockfile The package-lock.json file was created with an old version of npm,
                          npm warn old lockfile so supplemental metadata must be fetched from the registry.
                          npm warn old lockfile This is a one-time fix-up, please be patient...
                          npm error code EUSAGE
                          npm error
                          npm error `npm ci` can only install packages when your package.json and package-lock.json or npm-shrinkwrap.json are in sync. Please update your lock file with `npm install` before continuing.
                          npm error
                          npm error Missing: @iobroker-javascript.0/moment@2.30.1 from lock file
                          npm error Missing: @iobroker-javascript.0/moment-parseformat@4.0.0 from lock file
                          npm error Missing: iobroker.accuweather@2.1.1 from lock file
                          npm error Invalid: lock file's iobroker.admin@3.5.10 does not satisfy iobroker.admin@7.7.19
                          npm error Missing: iobroker.alias-manager@2.0.0 from lock file
                          npm error Missing: iobroker.amazon-dash@1.2.0 from lock file
                          npm error Missing: iobroker.chromecast@4.0.0 from lock file
                          npm error Missing: iobroker.cloud@5.0.1 from lock file
                          npm error Missing: iobroker.daswetter@3.2.3 from lock file
                          npm error Missing: iobroker.deconz@1.6.4 from lock file
                          npm error Missing: iobroker.devices@1.2.8 from lock file
                          npm error Invalid: lock file's iobroker.discovery@1.2.4 does not satisfy iobroker.discovery@5.0.0
                          npm error Missing: iobroker.email@2.0.4 from lock file
                          npm error Missing: iobroker.flot@1.12.0 from lock file
                          npm error Missing: iobroker.fronius@2.1.1 from lock file
                          npm error Missing: iobroker.fronius-solarweb@0.0.3 from lock file
                          npm error Missing: iobroker.frontier_silicon@0.5.0 from lock file
                          npm error Missing: iobroker.habpanel@0.5.0 from lock file
                          npm error Missing: iobroker.history@3.0.1 from lock file
                          npm error Missing: iobroker.hm-rega@5.1.0 from lock file
                          npm error Missing: iobroker.hm-rpc@2.0.2 from lock file
                          npm error Missing: iobroker.hs100@3.0.5 from lock file
                          npm error Missing: iobroker.icons-addictive-flavour-png@0.1.0 from lock file
                          npm error Missing: iobroker.icons-fatcow-hosting@0.1.0 from lock file
                          npm error Missing: iobroker.icons-icons8@0.0.1 from lock file
                          npm error Missing: iobroker.icons-material-png@0.1.0 from lock file
                          npm error Missing: iobroker.icons-material-svg@0.1.0 from lock file
                          npm error Missing: iobroker.icons-mfd-png@1.2.1 from lock file
                          npm error Missing: iobroker.icons-mfd-svg@1.2.0 from lock file
                          npm error Missing: iobroker.icons-open-icon-library-png@0.1.2 from lock file
                          npm error Missing: iobroker.icons-ultimate-png@1.0.1 from lock file
                          npm error Missing: iobroker.influxdb@4.0.2 from lock file
                          npm error Missing: iobroker.info@2.0.0 from lock file
                          npm error Missing: iobroker.iot@5.0.7 from lock file
                          npm error Missing: iobroker.javascript@8.9.2 from lock file
                          npm error Invalid: lock file's iobroker.js-controller@1.4.2 does not satisfy iobroker.js-controller@7.0.7
                          npm error Missing: iobroker.mihome-vacuum@5.2.0 from lock file
                          ==> weitere ist im file.2025-11-12T17_36_48_294Z-debug-0.log
                          Oder hätte ich iobroker vorher stoppen sollen?
                          • G George_Best
                            npm error
                            npm error
                            #66
                            npm error npm ci can only install packages when your package.json and package-lock.json or npm-shrinkwrap.json are in sync. Please update your lock file with npm install before continuing.
                            Das dürfte das auslösende Moment sein.
                            • G George_Best
                              npm error
                              npm error
                              #67
                              Ist die Installation echt so alt?
                                George_Best
                                schrieb am zuletzt editiert von George_Best
                                #68
                                Naja - schon ein paar Jährchen...
                                Wie kann ich das lösen?
                                Ich kann auch aktuell keinen Adapter bzw. Instanz mehr installieren:
                                Installing iobroker.lg-ess-home@0.4.1... (System call)
                                npm error code ENOTEMPTYnpm error syscall rename
                                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-11-12T17_47_52_218Z-debug-0.log
                                Try to solve ENOTEMPTY error automatically
                                Could not handle ENOTEMPTY, because no deletable files were foundnpm error code ENOTEMPTYnpm error syscall renamenpm error path /opt/iobroker/node_modules/abbrevnpm error dest /opt/iobroker/node_modules/.abbrev-5eNud0FYnpm error errno -39npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abbrev' -> '/opt/iobroker/node_modules/.abbrev-5eNud0FY'npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-11-12T17_47_52_218Z-debug-0.loghost.ioBroker-V2 Cannot install iobroker.lg-ess-home@0.4.1: 217
                                ERROR: Process exited with code 25
                                • G George_Best
                                  #69
                                  @george_best
                                  npm i
                                  im Verzeichnis /opt/iobroker probieren.
                                    @george_best
                                    npm i
                                    George_Best
                                    #70
                                    hm... irgendwie auch immer die gleiche Fehlermeldung:
                                    jonny@ioBroker-V2:/opt/iobroker$ npm i
                                    npm error errno -39
                                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-11-12T17_50_28_886Z-debug-0.log
                                    • G George_Best
                                      npm error errno -39
                                      #71
                                      @george_best
                                      Da hilft ein
                                      iob stop
                                      iob fix
                                        @george_best
                                        Da hilft ein
                                        iob stop
                                        iob fix
                                        George_Best
                                        #72
                                        Ok - sieht das jetzt gut aus?
                                        npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                        npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                                        npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                                        npm warn deprecated lodash.get@4.4.2: This package is deprecated. Use the optional chaining (?.) operator instead.
                                        npm warn deprecated uid-number@0.0.6: This package is no longer supported.
                                        npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                                        npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                                        npm warn deprecated lodash.isequal@4.5.0: This package is deprecated. Use require('node:util').isDeepStrictEqual instead.
                                        npm warn deprecated lodash.clone@4.5.0: This package is deprecated. Use structuredClone instead.
                                        npm warn deprecated har-validator@5.1.5: this library is no longer supported
                                        npm warn deprecated npmlog@4.1.2: This package is no longer supported.
                                        npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                                        npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                                        npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
                                        npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                                        npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                        npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                                        npm warn deprecated q@1.5.1: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                                        npm warn deprecated
                                        npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                                        npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                        npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                        npm warn deprecated gauge@3.0.2: This package is no longer supported.
                                        npm warn deprecated gauge@4.0.4: This package is no longer supported.
                                        npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                        npm warn deprecated gauge@2.7.4: This package is no longer supported.
                                        npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                        npm warn deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
                                        > iobroker.inst@2.0.2 install
                                        > node lib/checkVersions.js
                                        NPM version: 10.9.4
                                        > iobroker.inst@2.0.2 postinstall
                                        > node lib/install.js
                                        lib/install.js is not being run as part of an installation - skipping...
                                        added 1019 packages, and changed 826 packages in 3m
                                        205 packages are looking for funding
                                          run `npm fund` for details
                                        • G George_Best
                                          npm warn deprecated
                                          NPM version: 10.9.4
                                          > node lib/install.js
                                          #73
                                          Ich würde sagen das geht in die richtige Richtung.
                                          Gib mir nochmal ein
                                          iob diag
