  4. iob fix und iob diag ohne Reaktion
    6.4k
94 Beiträge 8 Kommentatoren 12.8k Aufrufe 4 Beobachtet
    @george_best sagte in iob fix und iob diag ohne Reaktion:
    You are currently not seeing messages from other users and the system.
    das braucht man aber um zu sehen warum
    Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    George_Best
    @homoran sagte in iob fix und iob diag ohne Reaktion:
    ok... Aber was kann ich da tun?
    • G George_Best
      setz deinen
      jonny
      in groups 'adm', 'systemd-journal'
      G 1 Antwort Letzte Antwort
        setz deinen
        jonny
        George_Best
        Ok - hab ich gemacht. Ergebnis:
        groups jonny
        jonny : jonny adm cdrom floppy sudo audio dip video plugdev systemd-journal netdev iobroker
        iob diag sagt nun:
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
         Static hostname: ioBroker-V2
               Icon name: computer-vm
                 Chassis: vm 🖴
          Virtualization: kvm
                  Kernel: Linux 6.1.0-40-amd64
            Architecture: x86-64
         Hardware Vendor: QEMU
          Hardware Model: Standard PC _i440FX + PIIX, 1996_
        Firmware Version: rel-1.16.1-0-g3208b098f51a-prebuilt.qemu.org
        OS is similar to:
        model name      : Common KVM processor
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         14:28:47 up 0 min,  2 users,  load average: 0.00, 0.00, 0.00
        CPU threads: 8
        *** LIFE CYCLE STATUS ***
        Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
        *** TIME AND TIMEZONES ***
                       Local time: Tue 2025-11-11 14:28:48 CET
                   Universal time: Tue 2025-11-11 13:28:48 UTC
                         RTC time: Tue 2025-11-11 13:28:48
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        jonny
        HOME=/home/jonny
        GROUPS=jonny adm cdrom floppy sudo audio dip video plugdev systemd-journal netdev iobroker
        js-controller is not running
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         false
        Unit display-manager.service could not be found.
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Mem:             12G        396M         11G        548K        233M         11G
        Swap:           4.3G          0B        4.3G
        Total:           16G        396M         16G
        Active iob-Instances:   0
                11644 M total memory
                  378 M used memory
                  104 M active memory
                  132 M inactive memory
                11286 M free memory
                   36 M buffer memory
                  186 M swap cache
                 4093 M total swap
                    0 M used swap
                 4093 M free swap
        top - 14:28:48 up 0 min,  2 users,  load average: 0.00, 0.00, 0.00
        Tasks: 113 total,   1 running, 112 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  11644.7 total,  11285.7 free,    379.1 used,    223.6 buff/cache
        MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.  11265.6 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  5.7G     0  5.7G   0% /dev
        tmpfs          tmpfs     1.2G  536K  1.2G   1% /run
        /dev/sda1      ext4       28G  9.2G   17G  36% /
        tmpfs          tmpfs     5.7G     0  5.7G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
        [Tue Nov 11 14:28:04 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
        [Tue Nov 11 14:28:04 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        1.9G    /var/
        923M    /var/log
        872M    /var/log/journal/123d1e3573ba4b7d9135f498a7b4789a
        792M    /var/cache
        Archived and active journals take up 871.4M in the file system.
        /opt/iobroker/backups:
        4.0K    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        673M    /opt/iobroker/iobroker-data/
        443M    /opt/iobroker/iobroker-data/files
        166M    /opt/iobroker/iobroker-data/backup-objects
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        73M     /opt/iobroker/iobroker-data/files/vis
        29M     /opt/iobroker/iobroker-data/objects.jsonl
        12M     /opt/iobroker/iobroker-data/objects.json.migrated
        12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
        4.7M    /opt/iobroker/iobroker-data/states.jsonl
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2195735-if00
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v22.21.0
        /usr/bin/node           v22.21.0
        /usr/bin/npm            10.9.4
        /usr/bin/npx            10.9.4
        /usr/bin/corepack       0.34.0
        nodejs:
          Installed: 22.21.0-1nodesource1
          Candidate: 22.21.0-1nodesource1
          Version table:
         *** 22.21.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             22.20.0-1nodesource1 1001
             22.19.0-1nodesource1 1001
             22.18.0-1nodesource1 1001
             22.17.1-1nodesource1 1001
             22.17.0-1nodesource1 1001
             22.16.0-1nodesource1 1001
             22.15.1-1nodesource1 1001
             22.15.0-1nodesource1 1001
             22.14.0-1nodesource1 1001
             22.13.1-1nodesource1 1001
             22.13.0-1nodesource1 1001
             22.12.0-1nodesource1 1001
             22.11.0-1nodesource1 1001
             22.10.0-1nodesource1 1001
             22.9.0-1nodesource1 1001
             22.8.0-1nodesource1 1001
             22.7.0-1nodesource1 1001
             22.6.0-1nodesource1 1001
             22.5.1-1nodesource1 1001
             22.5.0-1nodesource1 1001
             22.4.1-1nodesource1 1001
             22.4.0-1nodesource1 1001
             22.3.0-1nodesource1 1001
             22.2.0-1nodesource1 1001
             22.1.0-1nodesource1 1001
             22.0.0-1nodesource1 1001
             18.20.4+dfsg-1~deb12u1 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
                500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
        Temp directories causing deletion problem: 1204
        Some problems detected, please run iob fix
        Errors in npm tree: 0
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        node:internal/modules/cjs/loader:1386
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
            at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
            at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
            at Function._load (node:internal/modules/cjs/loader:1192:37)
            at TracingChannel.traceSync (node:diagnostics_channel:328:14)
            at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:171:5)
            at node:internal/main/run_main_module:36:49 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
        Node.js v22.21.0
        Hosts:
          throw err;
          requireStack: []
        Node.js v22.21.0
        Core adapters versions
          throw err;
          requireStack: []
        Node.js v22.21.0
        js-controller:
          throw err;
          requireStack: []
        Node.js v22.21.0
        admin:
          throw err;
          requireStack: []
        Node.js v22.21.0
        javascript:
        nodejs modules from github:     0
        Adapter State
        ioBroker-Repositories
          throw err;
          requireStack: []
        Node.js v22.21.0
        Installed ioBroker-Adapters
          throw err;
          requireStack: []
        Node.js v22.21.0
        Objects and States
        Objects:        0
        States:         0
        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15158      718/exim4
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14107      453/sshd: /usr/sbin
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14118      453/sshd: /usr/sbin
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          15159      718/exim4
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        14087      425/avahi-daemon: r
        udp        0      0 0.0.0.0:55628           0.0.0.0:*                           107        14089      425/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15001      355/dhclient
        udp6       0      0 :::5353                 :::*                                107        14088      425/avahi-daemon: r
        udp6       0      0 :::59888                :::*                                107        14090      425/avahi-daemon: r
        2025-11-11 13:02:19.356  - info: parser.0 (1617) terminating with timeout
        2025-11-11 13:02:19.680  - warn: sql.0 (1043) No Connection to database
        2025-11-11 13:02:19.681  - warn: sql.0 (1043) No Connection to database
        2025-11-11 13:02:19.681  - error: sql.0 (1043) No database connection
        2025-11-11 13:02:19.922  - info: vis.0 (1647) Terminated (NO_ERROR): Without reason
        2025-11-11 13:02:20.679  - warn: sql.0 (1043) No Connection to database
        2025-11-11 13:02:20.680  - warn: sql.0 (1043) No Connection to database
        2025-11-11 13:02:23.745  - warn: vis.0 (1647) get state error: DB closed
        2025-11-11 13:02:23.751  - error: parser.0 (1617) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
        2025-11-11 13:02:23.829  - error: sql.0 (1043) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
        2025-11-11 13:02:23.831  - error: sql.0 (1043) States database error: connect ECONNREFUSED 0.0.0.0:9000
        2025-11-11 13:02:28.831  - error: sql.0 (1043) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
        2025-11-11 13:02:28.835  - error: sql.0 (1043) States database error: connect ECONNREFUSED 0.0.0.0:9000
        2025-11-11 13:02:29.397  - info: sql.0 (1043) terminating with timeout
        2025-11-11 13:02:29.398  - info: sql.0 (1043) Terminated (NO_ERROR): Without reason
        2025-11-11 13:02:33.832  - error: sql.0 (1043) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
        2025-11-11 13:02:33.838  - warn: sql.0 (1043) get state error: DB closed
        • G George_Best
          groups jonny
          iob diag sagt nun:
          ```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
            Virtualization: kvm
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 8
                        NTP service: active
                    RTC in local TZ: no
          jonny
          HOME=/home/jonny
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:           4.3G          0B        4.3G
          Total:           16G        396M         16G
                    378 M used memory
                    104 M active memory
                  11286 M free memory
                     36 M buffer memory
                    186 M swap cache
                   4093 M total swap
                      0 M used swap
                   4093 M free swap
          *** FILESYSTEM ***
          /var:
          1.9G    /var/
          923M    /var/log
          792M    /var/cache
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          nodejs:
            Version table:
          ioBroker Status
            throw err;
            requireStack: []
          Node.js v22.21.0
          Hosts:
            throw err;
            requireStack: []
          Node.js v22.21.0
            throw err;
            requireStack: []
          Node.js v22.21.0
          js-controller:
            throw err;
            requireStack: []
          Node.js v22.21.0
          admin:
            throw err;
            requireStack: []
          Node.js v22.21.0
          javascript:
          Adapter State
            throw err;
            requireStack: []
          Node.js v22.21.0
            throw err;
            requireStack: []
          Node.js v22.21.0
          Objects and States
          Objects:        0
          States:         0
          Pending Updates: 0
          Jag da mal den
          iob fix
          drüber.
          • G George_Best
            groups jonny
            iob diag sagt nun:
            ```bash
            Script v.2025-08-09
            *** BASE SYSTEM ***
                     Chassis: vm 🖴
              Virtualization: kvm
            OS is similar to:
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
            CPU threads: 8
                          NTP service: active
                      RTC in local TZ: no
            jonny
            HOME=/home/jonny
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Swap:           4.3G          0B        4.3G
            Total:           16G        396M         16G
                      378 M used memory
                      104 M active memory
                    11286 M free memory
                       36 M buffer memory
                      186 M swap cache
                     4093 M total swap
                        0 M used swap
                     4093 M free swap
            *** FILESYSTEM ***
            /var:
            1.9G    /var/
            923M    /var/log
            792M    /var/cache
            USB-Devices by-id:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.9.4
            /usr/bin/npx            10.9.4
            nodejs:
              Version table:
            ioBroker Status
              throw err;
              requireStack: []
            Node.js v22.21.0
            Hosts:
              throw err;
              requireStack: []
            Node.js v22.21.0
              throw err;
              requireStack: []
            Node.js v22.21.0
            js-controller:
              throw err;
              requireStack: []
            Node.js v22.21.0
            admin:
              throw err;
              requireStack: []
            Node.js v22.21.0
            javascript:
            Adapter State
              throw err;
              requireStack: []
            Node.js v22.21.0
              throw err;
              requireStack: []
            Node.js v22.21.0
            Objects and States
            Objects:        0
            States:         0
            Pending Updates: 0
            iob diag sagt nun:
            und jetzt bin ich überfordert warum er keine Adapter und Instanzen anzeigt.
            Vielleicht hat @Thomas-Braun noch eine Idee
            • G Offline
              George_Best
              iob fix:
              library: loaded
              Library version=2025-08-09
                  Welcome to the ioBroker installation fixer!
                  Script version: 2025-08-09
                  You might need to enter your password a couple of times.
                  Installing prerequisites (1/5)
              OK:1 http://deb.debian.org/debian bookworm InRelease
              OK:2 http://deb.debian.org/debian bookworm-updates InRelease
              OK:3 http://deb.debian.org/debian-security bookworm-security InRelease
              OK:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                  Checking ioBroker user and directory permissions (2/5)
              Created /etc/sudoers.d/iobroker
                  Check and cleanup npm temporary directories (3/5)
              Done.
                  Database maintenance (4/5)
              Checking for uncompressed JSONL databases... This might take a while!
              Compressing /opt/iobroker/iobroker-data/states.jsonl
              Compressing /opt/iobroker/iobroker-data/objects.jsonl
              Compressed 2 JSONL files. Done
                  Checking autostart (5/5)
              ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
              Legitimierung ist zum Stoppen von »iobroker.service« notwendig.
              Authenticating as: jonny,,, (jonny)
              Password:
              ==== AUTHENTICATION COMPLETE ====
              Enabling autostart...
              Autostart enabled!
              iob diag:
              ```bash
              Script v.2025-08-09
              *** BASE SYSTEM ***
                       Chassis: vm 🖴
                Virtualization: kvm
              OS is similar to:
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
               15:20:29 up 52 min,  2 users,  load average: 0.09, 0.07, 0.02
              CPU threads: 8
                             Local time: Tue 2025-11-11 15:20:29 CET
                         Universal time: Tue 2025-11-11 14:20:29 UTC
                               RTC time: Tue 2025-11-11 14:20:29
                            NTP service: active
                        RTC in local TZ: no
              jonny
              HOME=/home/jonny
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
              Mem:             12G        461M         11G        544K        704M         11G
              Swap:           4.3G          0B        4.3G
              Total:           16G        461M         15G
                        440 M used memory
                        361 M active memory
                        262 M inactive memory
                      10812 M free memory
                        163 M buffer memory
                        508 M swap cache
                       4093 M total swap
                          0 M used swap
                       4093 M free swap
              top - 15:20:29 up 52 min,  2 users,  load average: 0.16, 0.08, 0.02
              Tasks: 112 total,   1 running, 111 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :  11644.7 total,  10811.1 free,    442.2 used,    671.9 buff/cache
              MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.  11202.4 avail Mem
              *** FILESYSTEM ***
              tmpfs          tmpfs     1.2G  540K  1.2G   1% /run
              /dev/sda1      ext4       28G  7.9G   19G  31% /
              /var:
              1.9G    /var/
              941M    /var/log
              888M    /var/log/journal/123d1e3573ba4b7d9135f498a7b4789a
              792M    /var/cache
              Archived and active journals take up 887.4M in the file system.
              668M    /opt/iobroker/iobroker-data/
              25M     /opt/iobroker/iobroker-data/objects.jsonl
              4.6M    /opt/iobroker/iobroker-data/states.jsonl
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.9.4
              /usr/bin/npx            10.9.4
              nodejs:
                Version table:
              ioBroker Status
                throw err;
                requireStack: []
              Node.js v22.21.0
              Hosts:
                throw err;
                requireStack: []
              Node.js v22.21.0
                throw err;
                requireStack: []
              Node.js v22.21.0
              js-controller:
                throw err;
                requireStack: []
              Node.js v22.21.0
              admin:
                throw err;
                requireStack: []
              Node.js v22.21.0
              javascript:
              Adapter State
                throw err;
                requireStack: []
              Node.js v22.21.0
                throw err;
                requireStack: []
              Node.js v22.21.0
              Objects and States
              Objects:        0
              States:         0
              Pending Updates: 0
              • G George_Best
                iob fix:
                library: loaded
                Done.
                Password:
                Autostart enabled!
                iob diag:
                ```bash
                Script v.2025-08-09
                *** BASE SYSTEM ***
                         Chassis: vm 🖴
                  Virtualization: kvm
                OS is similar to:
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                CPU threads: 8
                              NTP service: active
                          RTC in local TZ: no
                jonny
                HOME=/home/jonny
                Display-Manager:
                Desktop:
                Session:                tty
                *** MEMORY ***
                Swap:           4.3G          0B        4.3G
                Total:           16G        461M         15G
                          440 M used memory
                          361 M active memory
                        10812 M free memory
                          163 M buffer memory
                          508 M swap cache
                         4093 M total swap
                            0 M used swap
                         4093 M free swap
                *** FILESYSTEM ***
                /var:
                1.9G    /var/
                941M    /var/log
                792M    /var/cache
                USB-Devices by-id:
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/npm            10.9.4
                /usr/bin/npx            10.9.4
                nodejs:
                  Version table:
                ioBroker Status
                  throw err;
                  requireStack: []
                Node.js v22.21.0
                Hosts:
                  throw err;
                  requireStack: []
                Node.js v22.21.0
                  throw err;
                  requireStack: []
                Node.js v22.21.0
                js-controller:
                  throw err;
                  requireStack: []
                Node.js v22.21.0
                admin:
                  throw err;
                  requireStack: []
                Node.js v22.21.0
                javascript:
                Adapter State
                  throw err;
                  requireStack: []
                Node.js v22.21.0
                  throw err;
                  requireStack: []
                Node.js v22.21.0
                Objects and States
                Objects:        0
                States:         0
                Pending Updates: 0
                @george_best
                Dann bügel den aktuellen js-controller noch mal rein:
                cd /opt/iobroker
                npm install iobroker.js-controller@7.0.7 --omit=dev
                  @george_best
                  cd /opt/iobroker
                  George_Best
                  @thomas-braun sagte in iob fix und iob diag ohne Reaktion:
                  ok
                  sagt:
                  jonny@ioBroker-V2:/opt/iobroker$ npm install iobroker.js-controller@7.0.7 --omit=dev
                  npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                  npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                  npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                  npm warn deprecated uid-number@0.0.6: This package is no longer supported.
                  npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                  npm warn deprecated lodash.get@4.4.2: This package is deprecated. Use the optional chaining (?.) operator instead.
                  npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                  npm warn deprecated lodash.isequal@4.5.0: This package is deprecated. Use require('node:util').isDeepStrictEqual instead.
                  npm warn deprecated lodash.clone@4.5.0: This package is deprecated. Use structuredClone instead.
                  npm warn deprecated har-validator@5.1.5: this library is no longer supported
                  npm warn deprecated npmlog@4.1.2: This package is no longer supported.
                  npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                  npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                  npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
                  npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                  npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                  npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                  npm warn deprecated q@1.5.1: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                  npm warn deprecated
                  npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                  npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                  npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                  npm warn deprecated gauge@3.0.2: This package is no longer supported.
                  npm warn deprecated gauge@4.0.4: This package is no longer supported.
                  npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                  npm warn deprecated gauge@2.7.4: This package is no longer supported.
                  npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                  npm warn deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
                  changed 1848 packages in 3m
                  205 packages are looking for funding
                    run `npm fund` for details
                  iob diag:
                  ```bash
                  Script v.2025-08-09
                  *** BASE SYSTEM ***
                           Chassis: vm 🖴
                    Virtualization: kvm
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                   15:32:56 up  1:04,  2 users,  load average: 0.84, 0.56, 0.23
                  CPU threads: 8
                                 Local time: Tue 2025-11-11 15:32:56 CET
                             Universal time: Tue 2025-11-11 14:32:56 UTC
                                   RTC time: Tue 2025-11-11 14:32:56
                                NTP service: active
                            RTC in local TZ: no
                  jonny
                  HOME=/home/jonny
                  Display-Manager:
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                  Mem:             12G        527M        9.1G        544K        2.9G         11G
                  Swap:           4.3G          0B        4.3G
                  Total:           16G        527M         13G
                  Active iob-Instances:   1
                            502 M used memory
                            580 M active memory
                           1988 M inactive memory
                           8648 M free memory
                            215 M buffer memory
                           2591 M swap cache
                           4093 M total swap
                              0 M used swap
                           4093 M free swap
                  top - 15:32:56 up  1:04,  2 users,  load average: 0.84, 0.56, 0.23
                  Tasks: 114 total,   1 running, 113 sleeping,   0 stopped,   0 zombie
                  %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :  11644.7 total,   8647.8 free,    503.6 used,   2806.2 buff/cache
                  MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.  11141.0 avail Mem
                  *** FILESYSTEM ***
                  /dev/sda1      ext4       28G  9.1G   17G  35% /
                  /var:
                  1.9G    /var/
                  941M    /var/log
                  792M    /var/cache
                  USB-Devices by-id:
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/npm            10.9.4
                  /usr/bin/npx            10.9.4
                  nodejs:
                    Version table:
                  ioBroker Status
                  iobroker is not running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  ioBroker-V2         ioBroker-V2 (version: 7.0.7, hostname: ioBroker-V2   , dead, uptime: 107)
                  raspberrypi         raspberrypi (version: 2.1.0, hostname: raspberrypi   , dead, uptime: 8438)
                  js-controller:  7.0.7
                  admin:          7.7.19
                  javascript:     8.9.2
                  Adapter State
                    system.adapter.accuweather.0            : accuweather           : ioBroker-V2                              -  enabled
                    system.adapter.admin.0                  : admin                 : ioBroker-V2                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                    system.adapter.alias-manager.0          : alias-manager         : ioBroker-V2                              -  enabled
                    system.adapter.amazon-dash.0            : amazon-dash           : ioBroker-V2                              - disabled
                    system.adapter.chromecast.0             : chromecast            : ioBroker-V2                              -  enabled
                    system.adapter.cloud.0                  : cloud                 : ioBroker-V2                              - disabled
                    system.adapter.daswetter.0              : daswetter             : ioBroker-V2                              -  enabled
                    system.adapter.deconz.0                 : deconz                : ioBroker-V2                              - disabled, port: 80
                    system.adapter.devices.0                : devices               : ioBroker-V2                              -  enabled
                    system.adapter.discovery.0              : discovery             : ioBroker-V2                              -  enabled
                    system.adapter.email.0                  : email                 : ioBroker-V2                              -  enabled
                    system.adapter.flot.0                   : flot                  : ioBroker-V2                              -  enabled
                    system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker-V2                              -  enabled
                    system.adapter.fronius.0                : fronius               : ioBroker-V2                              -  enabled
                    system.adapter.frontier_silicon.0       : frontier_silicon      : ioBroker-V2                              -  enabled
                    system.adapter.habpanel.0               : habpanel              : ioBroker-V2                              -  enabled
                    system.adapter.history.0                : history               : ioBroker-V2                              -  enabled
                    system.adapter.hm-rega.0                : hm-rega               : ioBroker-V2                              -  enabled
                    system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-V2                              -  enabled, port: 0
                    system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-V2                              -  enabled, port: 0
                    system.adapter.hs100.0                  : hs100                 : ioBroker-V2                              -  enabled
                    system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker-V2                              -  enabled
                    system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker-V2                              -  enabled
                    system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-V2                              -  enabled
                    system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-V2                              -  enabled
                    system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker-V2                              -  enabled
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-V2                              -  enabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-V2                              -  enabled
                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker-V2                              -  enabled
                    system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-V2                              -  enabled
                    system.adapter.influxdb.0               : influxdb              : ioBroker-V2                              - disabled, port: 8086
                    system.adapter.influxdb.1               : influxdb              : ioBroker-V2                              - disabled, port: 8086
                    system.adapter.info.0                   : info                  : ioBroker-V2                              -  enabled
                    system.adapter.iot.0                    : iot                   : ioBroker-V2                              -  enabled
                    system.adapter.javascript.0             : javascript            : ioBroker-V2                              -  enabled
                    system.adapter.javascript.1             : javascript            : ioBroker-V2                              -  enabled
                    system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-V2                              - disabled, port: 54321
                    system.adapter.mqtt.0                   : mqtt                  : ioBroker-V2                              -  enabled, port: 1883, bind: 192.168.178.121
                    system.adapter.net-tools.0              : net-tools             : ioBroker-V2                              - disabled
                    system.adapter.net-tools.1              : net-tools             : ioBroker-V2                              -  enabled
                    system.adapter.octoprint.0              : octoprint             : ioBroker-V2                              -  enabled
                    system.adapter.parser.0                 : parser                : ioBroker-V2                              -  enabled
                    system.adapter.ping.0                   : ping                  : ioBroker-V2                              - disabled
                    system.adapter.proxmox.0                : proxmox               : ioBroker-V2                              -  enabled, port: 8006
                    system.adapter.radar.0                  : radar                 : ioBroker-V2                              - disabled
                    system.adapter.radar2.0                 : radar2                : ioBroker-V2                              - disabled
                    system.adapter.radar2.1                 : radar2                : ioBroker-V2                              -  enabled
                    system.adapter.reolink.0                : reolink               : ioBroker-V2                              -  enabled
                    system.adapter.reolink.1                : reolink               : ioBroker-V2                              -  enabled
                    system.adapter.rickshaw.0               : rickshaw              : ioBroker-V2                              -  enabled
                    system.adapter.s7.0                     : s7                    : ioBroker-V2                              -  enabled
                    system.adapter.s7.1                     : s7                    : ioBroker-V2                              -  enabled
                    system.adapter.s7.2                     : s7                    : ioBroker-V2                              -  enabled
                    system.adapter.sayit.0                  : sayit                 : ioBroker-V2                              -  enabled
                    system.adapter.sayit.1                  : sayit                 : ioBroker-V2                              -  enabled
                    system.adapter.sayit.2                  : sayit                 : ioBroker-V2                              -  enabled
                    system.adapter.simple-api.0             : simple-api            : ioBroker-V2                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                    system.adapter.smartmeter.0             : smartmeter            : ioBroker-V2                              - disabled
                    system.adapter.smartmeter.2             : smartmeter            : ioBroker-V2                              - disabled
                    system.adapter.socketio.0               : socketio              : ioBroker-V2                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    system.adapter.sql.0                    : sql                   : ioBroker-V2                              -  enabled, port: 3306
                    system.adapter.sql.1                    : sql                   : ioBroker-V2                              - disabled, port: 3306
                    system.adapter.statistics.0             : statistics            : ioBroker-V2                              -  enabled
                    system.adapter.systeminfo.0             : systeminfo            : ioBroker-V2                              - disabled
                    system.adapter.telegram.0               : telegram              : ioBroker-V2                              -  enabled, port: 8443, bind: 0.0.0.0
                    system.adapter.terminal.0               : terminal              : ioBroker-V2                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                    system.adapter.tr-064.0                 : tr-064                : ioBroker-V2                              -  enabled
                    system.adapter.unifi.0                  : unifi                 : ioBroker-V2                              -  enabled
                    system.adapter.upnp.0                   : upnp                  : ioBroker-V2                              -  enabled
                    system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker-V2                              -  enabled
                    system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker-V2                              -  enabled
                    system.adapter.vis-2.0                  : vis-2                 : ioBroker-V2                              -  enabled
                    system.adapter.vis-bars.0               : vis-bars              : ioBroker-V2                              -  enabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-V2                              -  enabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-V2                              -  enabled
                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-V2                              -  enabled
                    system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker-V2                              -  enabled
                    system.adapter.vis-history.0            : vis-history           : ioBroker-V2                              -  enabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-V2                              -  enabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-V2                              -  enabled
                    system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-V2                              -  enabled
                    system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-V2                              -  enabled
                    system.adapter.vis-lcars.0              : vis-lcars             : ioBroker-V2                              -  enabled
                    system.adapter.vis-map.0                : vis-map               : ioBroker-V2                              -  enabled
                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker-V2                              -  enabled
                    system.adapter.vis-metro.0              : vis-metro             : ioBroker-V2                              -  enabled
                    system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-V2                              -  enabled
                    system.adapter.vis-weather.0            : vis-weather           : ioBroker-V2                              -  enabled
                    system.adapter.vis.0                    : vis                   : ioBroker-V2                              -  enabled
                    system.adapter.weatherunderground.0     : weatherunderground    : ioBroker-V2                              -  enabled
                    system.adapter.web.0                    : web                   : ioBroker-V2                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + instance is alive
                  Active repo(s): stable
                  Upgrade policy: none
                  Used repository: stable
                  Adapter    "accuweather"  : 2.1.1    , installed 2.1.1
                  Adapter    "admin"        : 7.7.19   , installed 7.7.19
                  Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                  Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
                  Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
                  Adapter    "cloud"        : 5.0.1    , installed 5.0.1
                  Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                  Adapter    "deconz"       : 1.6.4    , installed 1.6.4
                  Adapter    "devices"      : 1.2.8    , installed 1.2.8
                  Adapter    "email"        : 2.0.4    , installed 2.0.4
                  Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                  Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                  Adapter    "frontier_silicon": 0.5.0 , installed 0.5.0
                  Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                  Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                  Adapter    "hs100"        : 3.0.5    , installed 3.0.5
                  Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
                  Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                  Adapter    "icons-material-png": 0.1.0, installed 0.1.0
                  Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                  Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                  Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                  Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
                  Adapter    "iot"          : 5.0.7    , installed 5.0.7
                  Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                  Controller "js-controller": 7.0.7    , installed 7.0.7
                  Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
                  Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
                  Adapter    "net-tools"    : 1.1.2    , installed 1.1.2
                  Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                  Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                  Adapter    "parser"       : 2.2.4    , installed 2.2.4
                  Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                  Adapter    "radar2"       : 2.4.0    , installed 2.4.0
                  Adapter    "reolink"      : 1.2.3    , installed 1.2.3
                  Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
                  Adapter    "s7"           : 1.5.0    , installed 1.5.0
                  Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                  Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                  Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                  Adapter    "sql"          : 3.0.1    , installed 3.0.1
                  Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                  Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
                  Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                  Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                  Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                  Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
                  Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
                  Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                  Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
                  Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
                  Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                  Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                  Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                  Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                  Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
                  Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
                  Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                  Adapter    "web"          : 7.0.8    , installed 7.0.8
                  Adapter    "ws"           : 2.6.2    , installed 2.6.2
                  Objects and States
                  Objects:        25018
                  States:         19884
                  Pending Updates: 0
                  2025-11-11 15:31:10.971  - warn: sayit.0 (14072) no connection to objects DB. Terminating
                  2025-11-11 15:31:10.972  - info: sayit.0 (14072) Terminated (NO_ERROR): Without reason
                  2025-11-11 15:31:11.563  - warn: vis.0 (14113) no connection to objects DB. Terminating
                  2025-11-11 15:31:11.564  - info: vis.0 (14113) Terminated (NO_ERROR): Without reason
                  2025-11-11 15:31:22.251  - warn: vis-google-fonts.0 (14134) no connection to objects DB. Terminating
                  2025-11-11 15:31:22.253  - info: vis-google-fonts.0 (14134) Terminated (NO_ERROR): Without reason
                  Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                  • G George_Best
                    ok
                    sagt:
                    npm warn deprecated
                    iob diag:
                    ```bash
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                             Chassis: vm 🖴
                      Virtualization: kvm
                    OS is similar to:
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64 bit
                    CPU threads: 8
                                  NTP service: active
                              RTC in local TZ: no
                    jonny
                    HOME=/home/jonny
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Swap:           4.3G          0B        4.3G
                    Total:           16G        527M         13G
                              502 M used memory
                              580 M active memory
                             8648 M free memory
                              215 M buffer memory
                             2591 M swap cache
                             4093 M total swap
                                0 M used swap
                             4093 M free swap
                    *** FILESYSTEM ***
                    /var:
                    1.9G    /var/
                    941M    /var/log
                    792M    /var/cache
                    USB-Devices by-id:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm            10.9.4
                    /usr/bin/npx            10.9.4
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.7.19
                    javascript:     8.9.2
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        25018
                    States:         19884
                    Pending Updates: 0
                    @george_best
                    iob restart
                    sagt? Schau mal in einer anderen Session in das Log:
                    iob logs --watch
                    • G George_Best
                      ok
                      sagt:
                      npm warn deprecated
                      iob diag:
                      ```bash
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                               Chassis: vm 🖴
                        Virtualization: kvm
                      OS is similar to:
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                      CPU threads: 8
                                    NTP service: active
                                RTC in local TZ: no
                      jonny
                      HOME=/home/jonny
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Swap:           4.3G          0B        4.3G
                      Total:           16G        527M         13G
                                502 M used memory
                                580 M active memory
                               8648 M free memory
                                215 M buffer memory
                               2591 M swap cache
                               4093 M total swap
                                  0 M used swap
                               4093 M free swap
                      *** FILESYSTEM ***
                      /var:
                      1.9G    /var/
                      941M    /var/log
                      792M    /var/cache
                      USB-Devices by-id:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.9.4
                      /usr/bin/npx            10.9.4
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      admin:          7.7.19
                      javascript:     8.9.2
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        25018
                      States:         19884
                      Pending Updates: 0
                      wo ist die dependency denn drin?
                      • G George_Best
                        ok
                        sagt:
                        npm warn deprecated
                        iob diag:
                        ```bash
                        Script v.2025-08-09
                        *** BASE SYSTEM ***
                                 Chassis: vm 🖴
                          Virtualization: kvm
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                        CPU threads: 8
                                      NTP service: active
                                  RTC in local TZ: no
                        jonny
                        HOME=/home/jonny
                        Display-Manager:
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                        Swap:           4.3G          0B        4.3G
                        Total:           16G        527M         13G
                                  502 M used memory
                                  580 M active memory
                                 8648 M free memory
                                  215 M buffer memory
                                 2591 M swap cache
                                 4093 M total swap
                                    0 M used swap
                                 4093 M free swap
                        *** FILESYSTEM ***
                        /var:
                        1.9G    /var/
                        941M    /var/log
                        792M    /var/cache
                        USB-Devices by-id:
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.9.4
                        /usr/bin/npx            10.9.4
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.7.19
                        javascript:     8.9.2
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        25018
                        States:         19884
                        Pending Updates: 0
                        Seh ich ja gerade erst...
                        Du kurvst da mit einem js-controller@2.1.0 auf dem raspberrypi herum.
                        Das schreit geradezu nach Problemen.
                        Koppel den mal ab, du verwendest den ja eh nicht.
                        • G Offline
                          George_Best
                          iobroker startete und ich konnte auch (kurz) zugreifen. Jetzt ist aber wieder alles tot. Anbei die Logs.
                          log.txt
                            George_Best
                            Ja - stimmt. Der hing mal als Slave dran...
                            Wie bringe ich den am einfachsten weg? Zugriff auf die Oberfläche ist aktuell leider nicht drin...
                            • G George_Best
                              log.txt
                              Da musst du da mal reinschauen:
                              https://www.iobroker.net/#de/documentation/config/multihost.md
                              • G George_Best
                                und jetzt ist der definitiv inaktiv? und nicht mehr im Netz?
                                • G Offline
                                  George_Best
                                  So - Dampfhammer....
                                  Backup von vor 3 Tage eingespielt. Läuft soweit und (vermeintlich) alles geupdated und Slave Host gelöscht.
                                  Das sagt nun
                                  iob diag
                                  ```bash
                                  Script v.2025-08-09
                                  *** BASE SYSTEM ***
                                           Chassis: vm 🖴
                                    Virtualization: kvm
                                            Kernel: Linux 6.1.0-30-amd64
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : 64 bit
                                   21:24:09 up 40 min,  2 users,  load average: 0.00, 0.23, 0.52
                                  CPU threads: 8
                                  Operating System is the current Debian stable version codenamed 'bookworm'!
                                                 Local time: Tue 2025-11-11 21:24:10 CET
                                             Universal time: Tue 2025-11-11 20:24:10 UTC
                                                   RTC time: Tue 2025-11-11 20:24:10
                                                NTP service: active
                                            RTC in local TZ: no
                                  jonny
                                  HOME=/home/jonny
                                  GROUPS=jonny cdrom floppy sudo audio dip video plugdev netdev iobroker
                                  Display-Manager:
                                  Desktop:
                                  Session:                tty
                                  System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                                  *** MEMORY ***
                                  Mem:             12G        533M        8.3G        552K        3.8G         11G
                                  Swap:           4.3G          0B        4.3G
                                  Total:           16G        533M         12G
                                            509 M used memory
                                            995 M active memory
                                           2273 M inactive memory
                                           7871 M free memory
                                            362 M buffer memory
                                           3215 M swap cache
                                           4093 M total swap
                                              0 M used swap
                                           4093 M free swap
                                  top - 21:24:10 up 40 min,  2 users,  load average: 0.00, 0.23, 0.52
                                  Tasks: 109 total,   1 running, 108 sleeping,   0 stopped,   0 zombie
                                  MiB Mem :  11644.7 total,   7870.9 free,    509.5 used,   3577.4 buff/cache
                                  MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.  11135.2 avail Mem
                                    UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                                  * iobroker.service loaded failed failed ioBroker Server
                                  1 loaded units listed.
                                  *** FILESYSTEM ***
                                  tmpfs          tmpfs     1.2G  544K  1.2G   1% /run
                                  tmpfs          tmpfs     1.1G     0  1.1G   0% /run/user/1000
                                  [Tue Nov 11 20:43:41 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Tue Nov 11 20:43:41 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
                                  /var:
                                  1.6G    /var/
                                  825M    /var/log
                                  805M    /var/log/journal/123d1e3573ba4b7d9135f498a7b4789a
                                  600M    /var/cache
                                  Archived and active journals take up 8.0M in the file system.
                                  22M     /opt/iobroker/backups/
                                  670M    /opt/iobroker/iobroker-data/
                                  27M     /opt/iobroker/iobroker-data/objects.jsonl
                                  USB-Devices by-id:
                                  zigbee.X
                                  Extended Pan ID:
                                  *** MASKED ***
                                  Pan ID:
                                  *** MASKED ***
                                  Channel:
                                  *** MASKED ***
                                  Network Key:
                                  *** MASKED ***
                                  /usr/bin/nodejs         v20.18.2
                                  /usr/bin/node           v20.18.2
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  /usr/bin/corepack       0.29.4
                                  nodejs:
                                    Installed: 20.18.2-1nodesource1
                                    Candidate: 20.19.5-1nodesource1
                                    Version table:
                                       20.19.5-1nodesource1 1001
                                          500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                       20.19.4-1nodesource1 1001
                                       20.19.3-1nodesource1 1001
                                       20.19.2-1nodesource1 1001
                                       20.19.1-1nodesource1 1001
                                       20.19.0-1nodesource1 1001
                                       20.18.3-1nodesource1 1001
                                   *** 20.18.2-1nodesource1 1001
                                       20.18.1-1nodesource1 1001
                                       20.18.0-1nodesource1 1001
                                       20.17.0-1nodesource1 1001
                                       20.16.0-1nodesource1 1001
                                       20.15.1-1nodesource1 1001
                                       20.15.0-1nodesource1 1001
                                       20.14.0-1nodesource1 1001
                                       20.13.1-1nodesource1 1001
                                       20.13.0-1nodesource1 1001
                                       20.12.2-1nodesource1 1001
                                       20.12.1-1nodesource1 1001
                                       20.12.0-1nodesource1 1001
                                       20.11.1-1nodesource1 1001
                                       20.11.0-1nodesource1 1001
                                       20.10.0-1nodesource1 1001
                                       20.9.0-1nodesource1 1001
                                       20.8.1-1nodesource1 1001
                                       20.8.0-1nodesource1 1001
                                       20.7.0-1nodesource1 1001
                                       20.6.1-1nodesource1 1001
                                       20.6.0-1nodesource1 1001
                                       20.5.1-1nodesource1 1001
                                       20.5.0-1nodesource1 1001
                                       20.4.0-1nodesource1 1001
                                       20.3.1-1nodesource1 1001
                                       20.3.0-1nodesource1 1001
                                       20.2.0-1nodesource1 1001
                                       20.1.0-1nodesource1 1001
                                       20.0.0-1nodesource1 1001
                                  The current Node.js version (v20.18.2) is vulnerable to the following CVEs:
                                  CVE-2025-23166(high):  The C++ method SignTraits::DeriveBits() may incorrectly call ThrowException() based on user-supplied inputs when executing in a background thread, crashing the Node.js process. Such cryptographic operations are commonly applied to untrusted inputs. Thus, this mechanism potentially allows an adversary to remotely crash a Node.js runtime.
                                  Patched versions: ^20.19.2 || ^22.15.1 || ^23.11.1 || ^24.0.2
                                  CVE-2025-23167(medium): A flaw in Node.js 20's HTTP parser allows improper termination of HTTP/1 headers using `\r\n\rX` instead of the required `\r\n\r\n`.
                                  This inconsistency enables request smuggling, allowing attackers to bypass proxy-based access controls and submit unauthorized requests.
                                  The issue was resolved by upgrading `llhttp` to version 9, which enforces correct header termination.
                                  Impact:
                                  * This vulnerability affects only Node.js 20.x users prior to the `llhttp` v9 upgrade.
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  ioBroker-V2         ioBroker-V2 (version: 7.0.6, hostname: ioBroker-V2   , alive, uptime: 212)
                                  admin:          7.7.19
                                  javascript:     8.9.2
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        25056
                                  States:         20026
                                  Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                  Pending Updates: 153
                                  tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       61327      25814/nc
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15823      468/sshd: /usr/sbin
                                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          15912      753/exim4
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          15834      468/sshd: /usr/sbin
                                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          15913      753/exim4
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          805        355/dhclient
                                  udp        0      0 0.0.0.0:41774           0.0.0.0:*                           107        14143      446/avahi-daemon: r
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        14141      446/avahi-daemon: r
                                  udp6       0      0 :::48224                :::*                                107        14144      446/avahi-daemon: r
                                  udp6       0      0 :::5353                 :::*                                107        14142      446/avahi-daemon: r
                                  2025-11-11 20:53:16.472  - warn: host.ioBroker-V2 instance system.adapter.tr-064.0 terminated due to SIGKILL
                                  2025-11-11 20:53:16.472  - info: host.ioBroker-V2 instance system.adapter.tr-064.0 terminated with code null ()
                                  2025-11-11 20:53:16.518  - warn: host.ioBroker-V2 instance system.adapter.hm-rpc.0 terminated due to SIGKILL
                                  2025-11-11 20:53:16.518  - info: host.ioBroker-V2 instance system.adapter.hm-rpc.0 terminated with code null ()
                                  2025-11-11 20:53:16.518  - warn: host.ioBroker-V2 instance system.adapter.hm-rega.0 terminated due to SIGKILL
                                  2025-11-11 20:53:16.519  - info: host.ioBroker-V2 instance system.adapter.hm-rega.0 terminated with code null ()
                                  2025-11-11 20:53:16.533  - warn: host.ioBroker-V2 instance system.adapter.frontier_silicon.0 terminated due to SIGKILL
                                  2025-11-11 20:53:16.533  - info: host.ioBroker-V2 instance system.adapter.frontier_silicon.0 terminated with code null ()
                                  2025-11-11 20:53:16.552  - warn: host.ioBroker-V2 instance system.adapter.fronius.0 terminated due to SIGKILL
                                  2025-11-11 20:53:16.552  - info: host.ioBroker-V2 instance system.adapter.fronius.0 terminated with code null ()
                                  2025-11-11 20:53:16.580  - warn: host.ioBroker-V2 instance system.adapter.hm-rpc.1 terminated due to SIGKILL
                                  2025-11-11 20:53:16.580  - info: host.ioBroker-V2 instance system.adapter.hm-rpc.1 terminated with code null ()
                                  2025-11-11 20:53:16.611  - warn: host.ioBroker-V2 instance system.adapter.web.0 terminated due to SIGKILL
                                  2025-11-11 20:53:16.611  - info: host.ioBroker-V2 instance system.adapter.web.0 terminated with code null ()
                                  2025-11-11 20:53:16.612  - warn: host.ioBroker-V2 instance system.adapter.parser.0 terminated due to SIGKILL
                                  2025-11-11 20:53:16.612  - info: host.ioBroker-V2 instance system.adapter.parser.0 terminated with code null ()a
                                  2025-11-11 20:53:16.637  - info: host.ioBroker-V2 instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
                                  2025-11-11 20:53:16.637  - info: host.ioBroker-V2 All instances are stopped.
                                  2025-11-11 20:53:16.712  - info: host.ioBroker-V2 terminated
                                  2025-11-11 21:05:19.386  - warn: vis.0 (13925) no connection to objects DB. Terminating
                                  2025-11-11 21:05:19.388  - info: vis.0 (13925) Terminated (NO_ERROR): Without reason
                                  2025-11-11 21:05:19.448  - warn: sayit.0 (13918) no connection to objects DB. Terminating
                                  2025-11-11 21:05:19.450  - info: sayit.0 (13918) Terminated (NO_ERROR): Without reason
                                  2025-11-11 21:05:21.179  - info: vis-google-fonts.0 (13942) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v20.18.2, js-controller: 7.0.7
                                  2025-11-11 21:05:21.769  - info: vis-google-fonts.0 (13942) Terminated (NO_ERROR): Without reason
                                  • G George_Best
                                    Das sagt nun
                                    iob diag
                                    ```bash
                                    Script v.2025-08-09
                                    *** BASE SYSTEM ***
                                             Chassis: vm 🖴
                                      Virtualization: kvm
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : 64 bit
                                    CPU threads: 8
                                                  NTP service: active
                                              RTC in local TZ: no
                                    jonny
                                    HOME=/home/jonny
                                    Display-Manager:
                                    Desktop:
                                    Session:                tty
                                    *** MEMORY ***
                                    Swap:           4.3G          0B        4.3G
                                    Total:           16G        533M         12G
                                              509 M used memory
                                              995 M active memory
                                             7871 M free memory
                                              362 M buffer memory
                                             3215 M swap cache
                                             4093 M total swap
                                                0 M used swap
                                             4093 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    1.6G    /var/
                                    825M    /var/log
                                    600M    /var/cache
                                    USB-Devices by-id:
                                    zigbee.X
                                    Extended Pan ID:
                                    *** MASKED ***
                                    Pan ID:
                                    *** MASKED ***
                                    Channel:
                                    *** MASKED ***
                                    Network Key:
                                    *** MASKED ***
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Version table:
                                    Impact:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    admin:          7.7.19
                                    javascript:     8.9.2
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        25056
                                    States:         20026
                                    • G George_Best
                                      Das sagt nun
                                      iob diag
                                      ```bash
                                      Script v.2025-08-09
                                      *** BASE SYSTEM ***
                                               Chassis: vm 🖴
                                        Virtualization: kvm
                                      OS is similar to:
                                      Docker          : false
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                      CPU threads: 8
                                                    NTP service: active
                                                RTC in local TZ: no
                                      jonny
                                      HOME=/home/jonny
                                      Display-Manager:
                                      Desktop:
                                      Session:                tty
                                      *** MEMORY ***
                                      Swap:           4.3G          0B        4.3G
                                      Total:           16G        533M         12G
                                                509 M used memory
                                                995 M active memory
                                               7871 M free memory
                                                362 M buffer memory
                                               3215 M swap cache
                                               4093 M total swap
                                                  0 M used swap
                                               4093 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      1.6G    /var/
                                      825M    /var/log
                                      600M    /var/cache
                                      USB-Devices by-id:
                                      zigbee.X
                                      Extended Pan ID:
                                      *** MASKED ***
                                      Pan ID:
                                      *** MASKED ***
                                      Channel:
                                      *** MASKED ***
                                      Network Key:
                                      *** MASKED ***
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      nodejs:
                                        Version table:
                                      Impact:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      admin:          7.7.19
                                      javascript:     8.9.2
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        25056
                                      States:         20026
                                      @Thomas-Braun
                                      und
                                      • iobroker.service loaded failed failed ioBroker Server
                                      • G Offline
                                        George_Best
                                        Leider zu früh gefreut....
                                        Wieder das gleich Spiel:
                                        1. Iobroker startet
                                        2. Ich kann darauf zugreifen
                                        3. Dann wird alles wieder grau und das Anmelde-Fenster erscheint erneut
                                        4. Es starten dann auch alle Instanzen neu..
                                        Es scheint so, alles würde iobroker selbstständig neustarten.
                                        Ich bin echt langsam verzweifelt. Hat noch jemand eine Idee?
                                        Das sagt aktuell
                                        iob Diag
                                        ```bash
                                        Script v.2025-08-09
                                        *** BASE SYSTEM ***
                                                 Chassis: vm 🖴
                                          Virtualization: kvm
                                        OS is similar to:
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                         21:51:14 up 20 min,  2 users,  load average: 0.25, 1.32, 1.19
                                        CPU threads: 8
                                                       Local time: Tue 2025-11-11 21:51:14 CET
                                                   Universal time: Tue 2025-11-11 20:51:14 UTC
                                                         RTC time: Tue 2025-11-11 20:51:14
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        jonny
                                        HOME=/home/jonny
                                        Display-Manager:
                                        Desktop:
                                        Session:                tty
                                        *** MEMORY ***
                                        Mem:             12G        522M        9.0G        552K        3.1G         11G
                                        Swap:           4.3G          0B        4.3G
                                        Total:           16G        522M         13G
                                                  498 M used memory
                                                 1244 M active memory
                                                 1422 M inactive memory
                                                 8548 M free memory
                                                  235 M buffer memory
                                                 2675 M swap cache
                                                 4093 M total swap
                                                    0 M used swap
                                                 4093 M free swap
                                        top - 21:51:15 up 21 min,  2 users,  load average: 0.25, 1.32, 1.19
                                        Tasks: 108 total,   1 running, 107 sleeping,   0 stopped,   0 zombie
                                        MiB Mem :  11644.7 total,   8547.9 free,    498.1 used,   2911.7 buff/cache
                                        MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.  11146.5 avail Mem
                                        *** FILESYSTEM ***
                                        tmpfs          tmpfs     1.2G  548K  1.2G   1% /run
                                        [Tue Nov 11 21:30:22 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Tue Nov 11 21:30:23 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
                                        /var:
                                        1.6G    /var/
                                        813M    /var/log
                                        792M    /var/log/journal/123d1e3573ba4b7d9135f498a7b4789a
                                        600M    /var/cache
                                        Archived and active journals take up 11.8M in the file system.
                                        679M    /opt/iobroker/iobroker-data/
                                        450M    /opt/iobroker/iobroker-data/files
                                        81M     /opt/iobroker/iobroker-data/files/vis
                                        28M     /opt/iobroker/iobroker-data/objects.jsonl
                                        4.9M    /opt/iobroker/iobroker-data/states.jsonl
                                        USB-Devices by-id:
                                        zigbee.X
                                        Extended Pan ID:
                                        *** MASKED ***
                                        Pan ID:
                                        *** MASKED ***
                                        Channel:
                                        *** MASKED ***
                                        Network Key:
                                        *** MASKED ***
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        nodejs:
                                          Version table:
                                        Impact:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        ioBroker-V2         ioBroker-V2 (version: 7.0.7, hostname: ioBroker-V2   , dead, uptime: 47)
                                        admin:          7.7.19
                                        javascript:     8.9.2
                                        nodejs modules from github:     2
                                        |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
                                        | +-- tplink-smarthome-api@5.0.0 invalid: "https://github.com/arteck/tplink-smarthome-api/tarball/08bcca9334c701b60d1eeb18b0ec72350aa3bf7a" from node_modules/iobroker.hs100
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        24997
                                        States:         19935
                                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          16620      738/exim4
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12879      509/sshd: /usr/sbin
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          12881      509/sshd: /usr/sbin
                                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          16621      738/exim4
                                        udp        0      0 0.0.0.0:56593           0.0.0.0:*                           107        16493      435/avahi-daemon: r
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13880      348/dhclient
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        16491      435/avahi-daemon: r
                                        udp6       0      0 :::5353                 :::*                                107        16492      435/avahi-daemon: r
                                        udp6       0      0 :::47395                :::*                                107        16494      435/avahi-daemon: r
                                        2025-11-11 21:48:10.464  - info: host.ioBroker-V2 stopInstance system.adapter.javascript.0 send kill signal
                                        2025-11-11 21:48:10.464  - info: host.ioBroker-V2 stopInstance system.adapter.javascript.1 send kill signal
                                        2025-11-11 21:48:10.464  - info: host.ioBroker-V2 stopInstance system.adapter.email.0 send kill signal
                                        2025-11-11 21:48:10.464  - info: host.ioBroker-V2 stopInstance system.adapter.telegram.0 send kill signal
                                        2025-11-11 21:48:10.464  - info: host.ioBroker-V2 stopInstance system.adapter.s7.0 send kill signal
                                        2025-11-11 21:48:10.464  - info: host.ioBroker-V2 stopInstance system.adapter.s7.1 send kill signal
                                        2025-11-11 21:48:10.464  - info: host.ioBroker-V2 stopInstance system.adapter.s7.2 send kill signal
                                        2025-11-11 21:48:10.464  - info: host.ioBroker-V2 stopInstance system.adapter.chromecast.0 send kill signal
                                        2025-11-11 21:48:10.472  - info: chromecast.0 (9137) Google_HomeKueche - Connected client
                                        2025-11-11 21:48:10.492  - info: history.0 (9089) Terminated (NO_ERROR): Without reason
                                        2025-11-11 21:48:10.891  - info: javascript.1 (9029) terminating
                                        2025-11-11 21:48:10.892  - info: telegram.0 (9121) terminating
                                        2025-11-11 21:48:10.893  - info: telegram.0 (9121) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2025-11-11 21:48:11.893  - info: javascript.1 (9029) terminating with timeout
                                        2025-11-11 21:48:11.894  - info: telegram.0 (9121) terminating with timeout
                                        2025-11-11 21:48:15.638  - error: telegram.0 (9121) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                        2025-11-11 21:48:15.632  - warn: history.0 (9089) get state error: Connection is closed.
                                        2025-11-11 21:48:15.642  - error: sql.0 (8917) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                        2025-11-11 21:48:15.645  - error: javascript.1 (9029) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                        2025-11-11 21:48:15.643  - error: sql.0 (8917) States database error: connect ECONNREFUSED 0.0.0.0:9000
                                        2025-11-11 21:48:20.648  - error: sql.0 (8917) States database error: connect ECONNREFUSED 0.0.0.0:9000
                                        2025-11-11 21:48:20.649  - error: sql.0 (8917) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                        2025-11-11 21:48:21.643  - info: sql.0 (8917) terminating with timeout
                                        2025-11-11 21:48:21.644  - info: sql.0 (8917) Terminated (NO_ERROR): Without reason
                                        2025-11-11 21:48:25.651  - error: sql.0 (8917) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                        • G Offline
                                          George_Best
                                          stimmt! Ich muss ja den User wieder in den Gruppen hinzufügen. Das ist jetzt erledigt.
                                          Aber das Verhalten (auch nach iob fix) ist immer noch gleich:
                                          iobroker läuft hoch - d.h. die instanzen starten, aber dann scheinen alle zu stoppen
                                          iob diag sagt atkuell:
                                          ```bash
                                          Script v.2025-08-09
                                          *** BASE SYSTEM ***
                                                   Chassis: vm 🖴
                                            Virtualization: kvm
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                           22:04:14 up 6 min,  2 users,  load average: 0.20, 0.28, 0.14
                                          CPU threads: 8
                                                         Local time: Tue 2025-11-11 22:04:14 CET
                                                     Universal time: Tue 2025-11-11 21:04:14 UTC
                                                           RTC time: Tue 2025-11-11 21:04:14
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          jonny
                                          HOME=/home/jonny
                                          Display-Manager:
                                          Desktop:
                                          Session:                tty
                                          *** MEMORY ***
                                          Mem:             12G        504M         10G        548K        1.6G         11G
                                          Swap:           4.3G          0B        4.3G
                                          Total:           16G        504M         14G
                                                    481 M used memory
                                                    587 M active memory
                                                    720 M inactive memory
                                                   9976 M free memory
                                                    200 M buffer memory
                                                   1299 M swap cache
                                                   4093 M total swap
                                                      0 M used swap
                                                   4093 M free swap
                                          top - 22:04:14 up 6 min,  2 users,  load average: 0.20, 0.28, 0.14
                                          Tasks: 107 total,   1 running, 106 sleeping,   0 stopped,   0 zombie
                                          MiB Mem :  11644.7 total,   9973.5 free,    484.2 used,   1500.3 buff/cache
                                          MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.  11160.5 avail Mem
                                          *** FILESYSTEM ***
                                          [Tue Nov 11 21:57:33 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                                          [Tue Nov 11 21:57:34 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
                                          /var:
                                          1.6G    /var/
                                          798M    /var/log
                                          776M    /var/log/journal/123d1e3573ba4b7d9135f498a7b4789a
                                          600M    /var/cache
                                          Archived and active journals take up 775.9M in the file system.
                                          676M    /opt/iobroker/iobroker-data/
                                          26M     /opt/iobroker/iobroker-data/objects.jsonl
                                          USB-Devices by-id:
                                          zigbee.X
                                          Extended Pan ID:
                                          *** MASKED ***
                                          Pan ID:
                                          *** MASKED ***
                                          Channel:
                                          *** MASKED ***
                                          Network Key:
                                          *** MASKED ***
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                            Version table:
                                          Impact:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          admin:          7.7.19
                                          javascript:     8.9.2
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        24997
                                          States:         19923
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15854      497/sshd: /usr/sbin
                                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          16500      733/exim4
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          15856      497/sshd: /usr/sbin
                                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          16501      733/exim4
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1979       334/dhclient
                                          udp        0      0 0.0.0.0:33468           0.0.0.0:*                           107        382        440/avahi-daemon: r
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        380        440/avahi-daemon: r
                                          udp6       0      0 :::34467                :::*                                107        383        440/avahi-daemon: r
                                          udp6       0      0 :::5353                 :::*                                107        381        440/avahi-daemon: r
                                          2025-11-11 22:01:40.743  - info: radar2.1 (3290) terminating with timeout
                                          2025-11-11 22:01:40.745  - info: fronius.0 (3375) terminating with timeout
                                          2025-11-11 22:01:41.081  - warn: sql.0 (2920) No Connection to database
                                          2025-11-11 22:01:41.082  - warn: sql.0 (2920) No Connection to database
                                          2025-11-11 22:01:41.083  - error: sql.0 (2920) No database connection
                                          2025-11-11 22:01:42.082  - warn: sql.0 (2920) No Connection to database
                                          2025-11-11 22:01:44.464  - error: fronius.0 (3375) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                          2025-11-11 22:01:44.463  - error: hm-rega.0 (3190) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                          2025-11-11 22:01:44.473  - error: radar2.1 (3290) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                          2025-11-11 22:01:44.488  - error: javascript.1 (2970) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                          2025-11-11 22:01:44.485  - warn: history.0 (3005) get state error: Connection is closed.
                                          2025-11-11 22:01:44.484  - error: telegram.0 (3020) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                          2025-11-11 22:01:44.491  - error: sql.0 (2920) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                          2025-11-11 22:01:44.492  - error: sql.0 (2920) States database error: connect ECONNREFUSED 0.0.0.0:9000
                                          2025-11-11 22:01:49.494  - error: sql.0 (2920) States database error: connect ECONNREFUSED 0.0.0.0:9000
                                          2025-11-11 22:01:49.495  - error: sql.0 (2920) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                          2025-11-11 22:01:50.490  - info: sql.0 (2920) terminating with timeout
                                          2025-11-11 22:01:50.490  - info: sql.0 (2920) Terminated (NO_ERROR): Without reason
                                          2025-11-11 22:01:54.497  - error: sql.0 (2920) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
                                          2025-11-11 22:01:54.498  - warn: sql.0 (2920) get state error: Connection is closed.
                                          2025-11-11 22:01:54.499  - warn: sql.0 (2920) get state error: DB closed
                                          2025-11-11 22:01:54.499  - info: sql.0 (2920) terminating
                                          2025-11-11 22:01:59.501  - error: sql.0 (2920) Cannot find view "system" for search "instance" : Connection is closed.
                                          ```![Screenshot 2025-11-11 220204.png](/assets/uploads/files/1762895295022-screenshot-2025-11-11-220204.png)
