  4. mihome vacuum - login failed
    6.1k
loginmihomevacuum
51 Beiträge 9 Kommentatoren 5.7k Aufrufe 11 Beobachtet
  • D dirkhe
    @thomas-braun Also in dem log sagt er ja, dass er die map aktualisiert hat. Wie sieht denn das log aus, wenn du get Devices drückst? Bitte auch mal schauen, ob der Browser keinen Fehler wirft
    @dirkhe
    Im Grunde passiert im Log nichts, wenn ich get devices anklicke:
    2025-07-24 18:04:24.351  - debug: mihome-vacuum.0 (168226) discover__{}
    2025-07-24 18:04:27.706  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c68956882598bffffffffffffffffffffffffffffffff
    2025-07-24 18:04:37.709  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c689568825995ffffffffffffffffffffffffffffffff
    2025-07-24 18:04:47.712  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c68956882599fffffffffffffffffffffffffffffffff
    2025-07-24 18:04:56.642  - debug: mihome-vacuum.0 (168226) get params for stock Vacuum
    2025-07-24 18:04:56.642  - debug: mihome-vacuum.0 (168226) Message= {"id":96,"method":"get_status"}
    2025-07-24 18:04:56.648  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":947,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":96}
    2025-07-24 18:04:56.649  - debug: mihome-vacuum.0 (168226) setGetStatus {"msg_ver":8,"msg_seq":947,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
    2025-07-24 18:04:56.650  - debug: mihome-vacuum.0 (168226) Message= {"id":97,"method":"get_network_info"}
    2025-07-24 18:04:56.655  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":"unknown_method","id":97}
    2025-07-24 18:04:56.656  - debug: mihome-vacuum.0 (168226) Message= {"id":98,"method":"get_sound_volume"}
    2025-07-24 18:04:56.663  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[90],"id":98}
    2025-07-24 18:04:56.664  - debug: mihome-vacuum.0 (168226) Message= {"id":99,"method":"get_carpet_mode"}
    2025-07-24 18:04:56.674  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":99}
    Es wird nur die erste Zeile ausgeworfen:
      dirkhe
      @thomas-braun Das ist seltsam, denn es müssten im debug ja auch die Loginversuche auftauchen. Kannst du ggf. mla deinenen Browser refreshen?
      D Thomas BraunT 2 Antworten Letzte Antwort
      • D dirkhe
        dirkhe
        Also ich habe den Adapter auch gerade im produktiven System installiert, bei mir funktioniert soweit alles. Da müssen wir dann mal sehen, wo es genau hakt bei euch
        • D dirkhe
          @dirkhe sagte in mihome vacuum - login failed:
          Browser neugestartet, sieht aber exakt aus wie zuvor.
          D 2 Antworten Letzte Antwort
            dirkhe
            @thomas-braun Kanst du mal die Browser console aufmachen, ob er da irgendeinen Fehler wirft? Obwohl das bei der Anfrage zumindest komisch ist, er müsste da auf jeden Fall was loggen... Der discovery Eintrag kommt ja dann zum Schluß...
              dirkhe
              @thomas-braun Schau mal bitte in dein Log, die Einträge vorher. Die Einträge direkt vor dem discovery kommen von der Kommunikation mit dem Sauger selber, das kann sein, dass mdu da ein bisschen früher schauen muss.
              Die Fangen alle mit CloudApi an
              • D dirkhe
                @dirkhe
                2025-07-24 18:49:52.416  - debug: mihome-vacuum.0 (172290) CloudApi-Login gestartet…
                2025-07-24 18:49:52.417  - debug: mihome-vacuum.0 (172290) CloudApi-CloudApi-Step 1: Getting sign token
                2025-07-24 18:49:52.559  - debug: mihome-vacuum.0 (172290) CloudApi-Step 2: Authenticating user
                2025-07-24 18:49:52.684  - debug: mihome-vacuum.0 (172290) CloudApi-Step 3: Fetching service token
                2025-07-24 18:49:52.836  - debug: mihome-vacuum.0 (172290) CloudApi-Login erfolgreich!
                2025-07-24 18:49:52.846  - debug: mihome-vacuum.0 (172290) CloudApi-call: https://-.api.io.mi.com/app/v2/homeroom/gethome with {"data":"{\"fg\":true,\"fetch_share\":true,\"fetch_share_dev\":true,\"limit\":300,\"app_ver\":7}"}
                2025-07-24 18:49:52.995  - error: mihome-vacuum.0 (172290) CloudApi: executeEncryptedApiCall Error:
                2025-07-24 18:49:52.996  - debug: mihome-vacuum.0 (172290) discover__{}
                2025-07-24 18:49:55.667  - debug: mihome-vacuum.0 (172290) Receive <<< Helo <<< 2131002000000000046c689568826433ffffffffffffffffffffffffffffffff
                2025-07-24 18:50:01.793  - debug: mihome-vacuum.0 (172290) get params for stock Vacuum
                2025-07-24 18:50:01.794  - debug: mihome-vacuum.0 (172290) Message= {"id":10,"method":"get_status"}
                2025-07-24 18:50:01.805  - debug: mihome-vacuum.0 (172290) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":991,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":10}
                2025-07-24 18:50:01.807  - debug: mihome-vacuum.0 (172290) setGetStatus {"msg_ver":8,"msg_seq":991,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
                2025-07-24 18:50:01.932  - debug: mihome-vacuum.0 (172290) Message= {"id":11,"method":"get_map_v1"}
                2025-07-24 18:50:01.939  - debug: mihome-vacuum.0 (172290) MIIO RECIVE: {"result":["retry"],"id":11}
                2025-07-24 18:50:02.242  - debug: mihome-vacuum.0 (172290) Message= {"id":12,"method":"get_map_v1"}
                2025-07-24 18:50:02.250  - debug: mihome-vacuum.0 (172290) MIIO RECIVE: {"result":["retry"],"id":12}
                2025-07-24 18:50:02.552  - debug: mihome-vacuum.0 (172290) Message= {"id":13,"method":"get_map_v1"}
                2025-07-24 18:50:04.556  - debug: mihome-vacuum.0 (172290) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                2025-07-24 18:50:04.858  - debug: mihome-vacuum.0 (172290) Message= {"id":14,"method":"get_map_v1"}
                2025-07-24 18:50:04.864  - debug: mihome-vacuum.0 (172290) MIIO RECIVE: {"result":["roboroommap%2F74213525%2F6"],"id":14}
                2025-07-24 18:50:04.865  - debug: mihome-vacuum.0 (172290) Mappointer_updated
                2025-07-24 18:50:04.869  - debug: mihome-vacuum.0 (172290) update_Map Mimap enabled
                2025-07-24 18:50:04.870  - debug: mihome-vacuum.0 (172290) update_Map need new mapurl
                2025-07-24 18:50:04.874  - debug: mihome-vacuum.0 (172290) CloudApi-call: https://api.io.mi.com/app/home/getmapfileurl with {"data":"{\"obj_name\":\"roboroommap%2F74213525%2F6\"}"}
                2025-07-24 18:50:04.884  - debug: mihome-vacuum.0 (172290) Message= {"id":15,"method":"get_room_mapping"}
                2025-07-24 18:50:04.894  - debug: mihome-vacuum.0 (172290) MIIO RECIVE: {"result":"unknown_method","id":15}
                2025-07-24 18:50:04.896  - debug: mihome-vacuum.0 (172290) Message= {"id":16,"method":"get_consumable"}
                2025-07-24 18:50:04.898  - debug: mihome-vacuum.0 (172290) Message= {"id":17,"method":"get_network_info"}
                  dirkhe
                  @thomas-braun ok, die entscheiden Zeile ist der executeEncryptedApiCall error, allerdings gibt er da nichts aus.
                  Kannst mal bitte direkt in Datei /ioBroker/iobroker.mihome-vacuum/lib/XiaomiCloudConnector.js gehen und bei folgender Zeile 304
                  aus err.message ein err machen, also das message wegmachen, bitte
                  • D dirkhe
                    @dirkhe
                    Gemacht, Zeile 304:
                                this.logger.error('CloudApi: executeEncryptedApiCall Error:', err);
                    aber da steht nix drin:
                    2025-07-24 19:01:04.008  - debug: mihome-vacuum.0 (172612) CloudApi-Login gestartet…
                    2025-07-24 19:01:04.009  - debug: mihome-vacuum.0 (172612) CloudApi-CloudApi-Step 1: Getting sign token
                    2025-07-24 19:01:04.112  - debug: mihome-vacuum.0 (172612) CloudApi-Step 2: Authenticating user
                    2025-07-24 19:01:04.244  - debug: mihome-vacuum.0 (172612) CloudApi-Step 3: Fetching service token
                    2025-07-24 19:01:04.407  - debug: mihome-vacuum.0 (172612) CloudApi-Login erfolgreich!
                    2025-07-24 19:01:04.418  - debug: mihome-vacuum.0 (172612) CloudApi-call: https://-.api.io.mi.com/app/v2/homeroom/gethome with {"data":"{\"fg\":true,\"fetch_share\":true,\"fetch_share_dev\":true,\"limit\":300,\"app_ver\":7}"}
                    2025-07-24 19:01:04.590  - error: mihome-vacuum.0 (172612) CloudApi: executeEncryptedApiCall Error:
                    2025-07-24 19:01:04.591  - debug: mihome-vacuum.0 (172612) discover__{}
                      @dirkhe
                      Gemacht, Zeile 304:
                      dirkhe
                      @thomas-braun Ach ich dummbacke, das muss so sein
                      this.logger.error(`CloudApi: executeEncryptedApiCall Error:${err.message}`);
                      Thomas BraunT bahnuhrB 2 Antworten Letzte Antwort
                      • D dirkhe
                        @dirkhe
                        2025-07-24 19:15:21.641  - debug: mihome-vacuum.0 (1462) CloudApi-call: https://-.api.io.mi.com/app/v2/homeroom/gethome with {"data":"{\"fg\":true,\"fetch_share\":true,\"fetch_share_dev\":true,\"limit\":300,\"app_ver\":7}"}
                        2025-07-24 19:15:21.833  - error: mihome-vacuum.0 (1462) CloudApi: executeEncryptedApiCall Error:getaddrinfo ENOTFOUND -.api.io.mi.com
                        2025-07-24 19:15:21.834  - debug: mihome-vacuum.0 (1462) discover__{}
                        Thomas BraunT D 2 Antworten Letzte Antwort
                          @dirkhe
                          @thomas-braun sagte in mihome vacuum - login failed:
                          Schaut für mich nach einer ungültigen URL aus.
                          Ich bin im übrigen auf dem chinesischen Server mit dem Sauger angemeldet. Falls das einen Unterschied macht.
                          • D dirkhe
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            @dirkhe
                            so Rückinfo von mir.
                            Nochmal neu von git geholt.
                            login Fehler im log ist nun weg.
                            get devices geht auch; Sauger werden geholt.
                            Und die map geht auch wieder.
                            Vielen lieben Dank für deinen Ansatz und die Lösung.
                            Fazit:
                            Bei mir geht wieder alles.
                            (Anmerkung: Ich bin auf dem deutschen Server)
                            Danke.
                              @dirkhe
                              dirkhe
                              @thomas-braun stimmt, sehe den Fehler auch schon, Fix kommt gleich
                                dirkhe
                                @thomas-braun bitte noch mal neu von github holen, ich hatte da noch ein bug drin. hatte das ja alles neu geschrieben....
                                • D dirkhe
                                  @dirkhe
                                  Nope. Get devices geht noch nicht.
                                  2025-07-24 19:59:42.943  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c68956882748fffffffffffffffffffffffffffffffff
                                  2025-07-24 19:59:42.943  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                  2025-07-24 19:59:52.947  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827499ffffffffffffffffffffffffffffffff
                                  2025-07-24 19:59:52.947  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                  2025-07-24 20:00:02.950  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c6895688274a3ffffffffffffffffffffffffffffffff
                                  2025-07-24 20:00:02.951  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                  2025-07-24 20:00:07.909  - debug: mihome-vacuum.0 (1462) discover__{}
                                  2025-07-24 20:00:12.954  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c6895688274adffffffffffffffffffffffffffffffff
                                  2025-07-24 20:00:12.955  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                  2025-07-24 20:00:22.329  - debug: mihome-vacuum.0 (1462) get params for stock Vacuum
                                  2025-07-24 20:00:22.330  - debug: mihome-vacuum.0 (1462) Message= {"id":142,"method":"get_status"}
                                  2025-07-24 20:00:22.339  - debug: mihome-vacuum.0 (1462) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":1051,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":142}
                                  2025-07-24 20:00:22.340  - debug: mihome-vacuum.0 (1462) setGetStatus {"msg_ver":8,"msg_seq":1051,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
                                  2025-07-24 20:00:22.342  - debug: mihome-vacuum.0 (1462) Message= {"id":143,"method":"get_network_info"}
                                  2025-07-24 20:00:22.350  - debug: mihome-vacuum.0 (1462) MIIO RECIVE: {"result":"unknown_method","id":143}
                                  2025-07-24 20:00:22.351  - debug: mihome-vacuum.0 (1462) Message= {"id":144,"method":"get_sound_volume"}
                                  2025-07-24 20:00:22.361  - debug: mihome-vacuum.0 (1462) MIIO RECIVE: {"result":[90],"id":144}
                                  2025-07-24 20:00:24.956  - debug: mihome-vacuum.0 (1462) Helo message Timeout
                                    @dirkhe
                                    dirkhe
                                    @thomas-braun gib mal bitte die passenden Logzeilen, die sind in dem Auschnitt nicht drin
                                    Thomas BraunT Eduard77E 4 Antworten Letzte Antwort
                                    • D dirkhe
                                      @dirkhe
                                      Da ist auch nicht mehr. get devices geklickt um 20:40:23.105
                                      2025-07-24 20:40:08.922  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e09ffffffffffffffffffffffffffffffff
                                      2025-07-24 20:40:08.922  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                      2025-07-24 20:40:18.926  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e13ffffffffffffffffffffffffffffffff
                                      2025-07-24 20:40:18.927  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                      2025-07-24 20:40:23.105  - debug: mihome-vacuum.0 (1462) discover__{}
                                      2025-07-24 20:40:28.930  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e1dffffffffffffffffffffffffffffffff
                                      2025-07-24 20:40:28.931  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                      2025-07-24 20:40:38.934  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e27ffffffffffffffffffffffffffffffff
                                      2025-07-24 20:40:38.935  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                      • D dirkhe
                                        @dirkhe
                                        Ah! Nochmal neugestartet, jetzt funktioniert es!
                                        • D dirkhe
                                          @dirkhe
                                          Hi!
                                          Die Version aus 'latest' funktioniert nicht:
                                          2025-07-25 11:52:30.448  - info: mihome-vacuum.0 (59185) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v24.4.1, js-controller: 7.0.7
                                          2025-07-25 11:53:41.089  - debug: mihome-vacuum.0 (59185) CloudApi-Login gestartet…
                                          2025-07-25 11:53:41.090  - debug: mihome-vacuum.0 (59185) CloudApi-CloudApi-Step 1: Getting sign token
                                          2025-07-25 11:53:41.229  - debug: mihome-vacuum.0 (59185) CloudApi-Step 2: Authenticating user
                                          2025-07-25 11:53:41.327  - error: mihome-vacuum.0 (59185) CloudApi-Login failed, because no captcha resolving possible
                                          2025-07-25 11:53:41.328  - info: mihome-vacuum.0 (59185) discover Login failed, because no captcha resolving possible
