  4. mihome vacuum - login failed
    1.0k
    6.1k
loginmihomevacuum
51 Beiträge 9 Kommentatoren 5.7k Aufrufe 11 Beobachtet
    @bahnuhr @dirkhe
    Kann ich bestätigen, get devices funktioniert nicht.
    Map wohl auch nicht, kann ich aber nicht richtig testen, da keine vis.
    Debug sagt:
    2025-07-24 17:43:13.090  - info: mihome-vacuum.0 (168226) starting. Version 5.2.0 (non-npm: iobroker-community-adapters/ioBroker.mihome-vacuum) in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v24.4.1, js-controller: 7.0.7
    2025-07-24 17:43:13.144  - debug: mihome-vacuum.0 (168226) Create State for deviceInfo
    2025-07-24 17:43:13.145  - debug: mihome-vacuum.0 (168226) Create State for deviceInfomac
    2025-07-24 17:43:13.145  - debug: mihome-vacuum.0 (168226) Create State for deviceInfomodel
    2025-07-24 17:43:13.146  - debug: mihome-vacuum.0 (168226) Create State for deviceInfofw_ver
    2025-07-24 17:43:13.147  - debug: mihome-vacuum.0 (168226) Create State for deviceInfowifi_signal
    2025-07-24 17:43:13.147  - debug: mihome-vacuum.0 (168226) Create State for deviceInfounsupported
    2025-07-24 17:43:13.149  - debug: mihome-vacuum.0 (168226) MIIO: Config: ip:192.168.178.23 token: 753955485aXXXXXXXXX
    2025-07-24 17:43:13.154  - info: mihome-vacuum.0 (168226) IOT enabled, create state
    2025-07-24 17:43:13.157  - debug: mihome-vacuum.0 (168226) server started on 0.0.0.0:53421
    2025-07-24 17:43:13.171  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c689568825491ffffffffffffffffffffffffffffffff
    2025-07-24 17:43:13.172  - debug: mihome-vacuum.0 (168226) MAIN: Connected to device, try to get model..
    2025-07-24 17:43:13.177  - debug: mihome-vacuum.0 (168226) your device is not connected, but this could be temporary
    2025-07-24 17:43:13.179  - debug: mihome-vacuum.0 (168226) GETMODELFROMAPI:Data: {}
    2025-07-24 17:43:13.179  - debug: mihome-vacuum.0 (168226) Get Device data..0
    2025-07-24 17:43:13.181  - debug: mihome-vacuum.0 (168226) Message= {"id":1,"method":"miIO.info"}
    2025-07-24 17:43:13.193  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_004028","ap":{"ssid":"WLana-del-Rey","bssid":"1C:ED:6F:57:F0:44","rssi":-52},"netif":{"localIp":"192.168.178.23","mask":"255.255.255.0","gw":"192.168.178.1"},"miio_ver":"miio-client 3.5.8","model":"rockrobo.vacuum.v1","mac":"78:11:DC:7E:2A:27","token":"753955485aXXXXXXXXX","life":51120}}
    2025-07-24 17:43:13.194  - debug: mihome-vacuum.0 (168226) GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_004028","ap":{"ssid":"WLana-del-Rey","bssid":"1C:ED:6F:57:F0:44","rssi":-52},"netif":{"localIp":"192.168.178.23","mask":"255.255.255.0","gw":"192.168.178.1"},"miio_ver":"miio-client 3.5.8","model":"rockrobo.vacuum.v1","mac":"78:11:DC:7E:2A:27","token":"753955485aXXXXXX":51120}}
    2025-07-24 17:43:13.195  - debug: mihome-vacuum.0 (168226) Get Device data..1
    2025-07-24 17:43:13.195  - debug: mihome-vacuum.0 (168226) Get Device data from robot.. {"hw_ver":"Linux","fw_ver":"3.5.8_004028","ap":{"ssid":"WLana-del-Rey","bssid":"1C:ED:6F:57:F0:44","rssi":-52},"netif":{"localIp":"192.168.178.23","mask":"255.255.255.0","gw":"192.168.178.1"},"miio_ver":"miio-client 3.5.8","model":"rockrobo.vacuum.v1","mac":"78:11:DC:7E:2A:27","token":"753955485aXXXXXX":51120}
    2025-07-24 17:43:13.288  - debug: mihome-vacuum.0 (168226) DeviceModel set to: rockrobo.vacuum.v1
    2025-07-24 17:43:13.319  - debug: mihome-vacuum.0 (168226) load Map creator... true
    2025-07-24 17:43:13.323  - info: mihome-vacuum.0 (168226) select standard vacuum protocol....
    2025-07-24 17:43:13.330  - debug: mihome-vacuum.0 (168226) CloudApi-Login gestartet…
    2025-07-24 17:43:13.331  - debug: mihome-vacuum.0 (168226) CloudApi-CloudApi-Step 1: Getting sign token
    2025-07-24 17:43:13.529  - debug: mihome-vacuum.0 (168226) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2025-07-24 17:43:13.660  - debug: mihome-vacuum.0 (168226) CloudApi-Step 2: Authenticating user
    2025-07-24 17:43:13.794  - debug: mihome-vacuum.0 (168226) CloudApi-Step 3: Fetching service token
    2025-07-24 17:43:13.967  - debug: mihome-vacuum.0 (168226) CloudApi-Login erfolgreich!
    2025-07-24 17:43:14.066  - info: mihome-vacuum.0 (168226) settest next timer: not available
    2025-07-24 17:43:14.150  - debug: mihome-vacuum.0 (168226) Create State for control: {"id":"mihome-vacuum.0.control"}
    2025-07-24 17:43:14.400  - debug: mihome-vacuum.0 (168226) Create State for Queue: queue
    2025-07-24 17:43:14.478  - debug: mihome-vacuum.0 (168226) Create State for map:
    2025-07-24 17:43:14.521  - debug: mihome-vacuum.0 (168226) Create State for map: map64
    2025-07-24 17:43:14.522  - debug: mihome-vacuum.0 (168226) Create State for map: actualMap
    2025-07-24 17:43:14.523  - debug: mihome-vacuum.0 (168226) Create State for map: mapStatus
    2025-07-24 17:43:14.525  - debug: mihome-vacuum.0 (168226) Create State for map: mapURL
    2025-07-24 17:43:14.525  - debug: mihome-vacuum.0 (168226) Create State for map: loadMap
    2025-07-24 17:43:14.526  - debug: mihome-vacuum.0 (168226) Create State done!
    2025-07-24 17:43:14.527  - debug: mihome-vacuum.0 (168226) get params for stock Vacuum
    2025-07-24 17:43:14.528  - debug: mihome-vacuum.0 (168226) Message= {"id":2,"method":"get_status"}
    2025-07-24 17:43:14.536  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":889,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":2}
    2025-07-24 17:43:14.537  - debug: mihome-vacuum.0 (168226) setGetStatus {"msg_ver":8,"msg_seq":889,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
    2025-07-24 17:43:14.691  - debug: mihome-vacuum.0 (168226) Message= {"id":3,"method":"get_map_v1"}
    2025-07-24 17:43:14.699  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":["retry"],"id":3}
    2025-07-24 17:43:15.001  - debug: mihome-vacuum.0 (168226) Message= {"id":4,"method":"get_map_v1"}
    2025-07-24 17:43:17.003  - debug: mihome-vacuum.0 (168226) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
    2025-07-24 17:43:17.305  - debug: mihome-vacuum.0 (168226) Message= {"id":5,"method":"get_map_v1"}
    2025-07-24 17:43:17.313  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":["roboroommap%2F74213525%2F2"],"id":5}
    2025-07-24 17:43:17.313  - debug: mihome-vacuum.0 (168226) Mappointer_updated
    2025-07-24 17:43:17.315  - debug: mihome-vacuum.0 (168226) update_Map Mimap enabled
    2025-07-24 17:43:17.315  - debug: mihome-vacuum.0 (168226) update_Map need new mapurl
    2025-07-24 17:43:17.321  - debug: mihome-vacuum.0 (168226) CloudApi-call: https://api.io.mi.com/app/home/getmapfileurl with {"data":"{\"obj_name\":\"roboroommap%2F74213525%2F2\"}"}
    2025-07-24 17:43:17.328  - debug: mihome-vacuum.0 (168226) Message= {"id":6,"method":"get_room_mapping"}
    2025-07-24 17:43:17.337  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":"unknown_method","id":6}
    2025-07-24 17:43:17.340  - debug: mihome-vacuum.0 (168226) Message= {"id":7,"method":"get_consumable"}
    2025-07-24 17:43:17.342  - debug: mihome-vacuum.0 (168226) Message= {"id":8,"method":"get_network_info"}
    2025-07-24 17:43:17.349  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[{"main_brush_work_time":1320,"side_brush_work_time":330828,"filter_work_time":1320,"sensor_dirty_time":1343}],"id":7}
    2025-07-24 17:43:17.351  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":"unknown_method","id":8}
    2025-07-24 17:43:17.352  - debug: mihome-vacuum.0 (168226) Message= {"id":9,"method":"get_sound_volume"}
    2025-07-24 17:43:17.358  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[90],"id":9}
    2025-07-24 17:43:17.360  - debug: mihome-vacuum.0 (168226) Message= {"id":10,"method":"get_multi_maps_list"}
    2025-07-24 17:43:17.368  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":"unknown_method","id":10}
    2025-07-24 17:43:17.369  - debug: mihome-vacuum.0 (168226) Startup: getMultiMapsList Answer: true
    2025-07-24 17:43:17.370  - debug: mihome-vacuum.0 (168226) Startup: Delete getMultiMapsList
    2025-07-24 17:43:17.371  - debug: mihome-vacuum.0 (168226) Message= {"id":11,"method":"get_clean_summary"}
    2025-07-24 17:43:17.386  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[330035,4140217500,288,[]],"id":11}
    2025-07-24 17:43:17.388  - debug: mihome-vacuum.0 (168226) Startup: setGetCleanSummary Answer: true
    2025-07-24 17:43:17.389  - debug: mihome-vacuum.0 (168226) Startup: Delete setGetCleanSummary
    2025-07-24 17:43:17.389  - debug: mihome-vacuum.0 (168226) Message= {"id":12,"method":"get_consumable"}
    2025-07-24 17:43:17.399  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[{"main_brush_work_time":1320,"side_brush_work_time":330828,"filter_work_time":1320,"sensor_dirty_time":1343}],"id":12}
    2025-07-24 17:43:17.400  - debug: mihome-vacuum.0 (168226) Startup: setGetConsumable Answer: true
    2025-07-24 17:43:17.401  - debug: mihome-vacuum.0 (168226) Startup: Delete setGetConsumable
    2025-07-24 17:43:17.402  - debug: mihome-vacuum.0 (168226) Message= {"id":13,"method":"get_carpet_mode"}
    2025-07-24 17:43:17.411  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":13}
    2025-07-24 17:43:17.412  - info: mihome-vacuum.0 (168226) create state for carpet_mode
    2025-07-24 17:43:17.413  - debug: mihome-vacuum.0 (168226) Message= {"id":14,"method":"get_carpet_mode"}
    2025-07-24 17:43:17.498  - debug: mihome-vacuum.0 (168226) Message= {"id":15,"method":"get_clean_summary"}
    2025-07-24 17:43:19.200  - debug: mihome-vacuum.0 (168226) CloudApi-get {"code":0,"message":"ok","result":{"url":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/74213525/2?Expires=1753373599000&GalaxyAccessKeyId=5ZIFFERN5&Signature=ERSETZT=","obj_name":"roboroommap/74213525/2","method":"GET","expires_time":1753373599,"ok":true}}
    2025-07-24 17:43:19.202  - debug: mihome-vacuum.0 (168226) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/74213525/2?Expires=1753373599000&GalaxyAccessKeyId=5ZIFFERN5&Signature=ERSETZT=
    2025-07-24 17:43:19.203  - debug: mihome-vacuum.0 (168226) update_Map got new expires:1753373599
    2025-07-24 17:43:19.204  - debug: mihome-vacuum.0 (168226) update_Map got new time:1753371797
    2025-07-24 17:43:19.415  - debug: mihome-vacuum.0 (168226) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
    2025-07-24 17:43:19.501  - debug: mihome-vacuum.0 (168226) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
    2025-07-24 17:43:19.657  - debug: mihome-vacuum.0 (168226) creating map
    2025-07-24 17:43:23.181  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c68956882549bffffffffffffffffffffffffffffffff
    2025-07-24 17:43:33.185  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c6895688254a5ffffffffffffffffffffffffffffffff
    2025-07-24 17:43:43.190  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c6895688254afffffffffffffffffffffffffffffffff
    2025-07-24 17:43:53.193  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c6895688254b9ffffffffffffffffffffffffffffffff
    2025-07-24 17:44:03.196  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c6895688254c3ffffffffffffffffffffffffffffffff
    2025-07-24 17:44:13.201  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c6895688254cdffffffffffffffffffffffffffffffff
    2025-07-24 17:44:20.417  - debug: mihome-vacuum.0 (168226) get params for stock Vacuum
    2025-07-24 17:44:20.418  - debug: mihome-vacuum.0 (168226) Message= {"id":16,"method":"get_status"}
    2025-07-24 17:44:22.420  - debug: mihome-vacuum.0 (168226) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
    2025-07-24 17:44:22.420  - debug: mihome-vacuum.0 (168226) Message= {"id":17,"method":"get_network_info"}
    2025-07-24 17:44:23.204  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c6895688254d7ffffffffffffffffffffffffffffffff
    2025-07-24 17:44:24.421  - debug: mihome-vacuum.0 (168226) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
    2025-07-24 17:44:24.422  - debug: mihome-vacuum.0 (168226) Message= {"id":18,"method":"get_sound_volume"}
    2025-07-24 17:44:26.423  - debug: mihome-vacuum.0 (168226) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
    2025-07-24 17:44:26.424  - debug: mihome-vacuum.0 (168226) Message= {"id":19,"method":"get_carpet_mode"}
    2025-07-24 17:44:26.432  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":19}
    2025-07-24 17:44:33.208  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c6895688254e1ffffffffffffffffffffffffffffffff
    2025-07-24 17:44:43.212  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c6895688254ebffffffffffffffffffffffffffffffff
    2025-07-24 17:44:53.214  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c6895688254f5ffffffffffffffffffffffffffffffff
    2025-07-24 17:45:03.220  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c6895688254ffffffffffffffffffffffffffffffffff
    2025-07-24 17:45:13.226  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c689568825509ffffffffffffffffffffffffffffffff
    2025-07-24 17:45:23.233  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c689568825513ffffffffffffffffffffffffffffffff
    2025-07-24 17:45:27.486  - debug: mihome-vacuum.0 (168226) get params for stock Vacuum
    2025-07-24 17:45:27.487  - debug: mihome-vacuum.0 (168226) Message= {"id":20,"method":"get_status"}
    2025-07-24 17:45:27.496  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":890,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":20}
    2025-07-24 17:45:27.497  - debug: mihome-vacuum.0 (168226) setGetStatus {"msg_ver":8,"msg_seq":890,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
    2025-07-24 17:45:27.499  - debug: mihome-vacuum.0 (168226) Message= {"id":21,"method":"get_network_info"}
    2025-07-24 17:45:27.505  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":"unknown_method","id":21}
    2025-07-24 17:45:27.506  - debug: mihome-vacuum.0 (168226) Message= {"id":22,"method":"get_sound_volume"}
    2025-07-24 17:45:27.514  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[90],"id":22}
    2025-07-24 17:45:27.515  - debug: mihome-vacuum.0 (168226) Message= {"id":23,"method":"get_carpet_mode"}
    2025-07-24 17:45:27.644  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":23}
    2025-07-24 17:45:33.238  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c68956882551dffffffffffffffffffffffffffffffff
    2025-07-24 17:45:43.241  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c689568825527ffffffffffffffffffffffffffffffff
    2025-07-24 17:45:53.249  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c689568825531ffffffffffffffffffffffffffffffff
    2025-07-24 17:46:03.254  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c68956882553bffffffffffffffffffffffffffffffff
    2025-07-24 17:46:13.256  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c689568825545ffffffffffffffffffffffffffffffff
    2025-07-24 17:46:23.261  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c68956882554fffffffffffffffffffffffffffffffff
    2025-07-24 17:46:28.758  - debug: mihome-vacuum.0 (168226) get params for stock Vacuum
    2025-07-24 17:46:28.759  - debug: mihome-vacuum.0 (168226) Message= {"id":24,"method":"get_status"}
    2025-07-24 17:46:28.768  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":915,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":24}
    2025-07-24 17:46:28.769  - debug: mihome-vacuum.0 (168226) setGetStatus {"msg_ver":8,"msg_seq":915,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
    2025-07-24 17:46:28.771  - debug: mihome-vacuum.0 (168226) Message= {"id":25,"method":"get_network_info"}
    2025-07-24 17:46:28.782  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":"unknown_method","id":25}
    2025-07-24 17:46:28.783  - debug: mihome-vacuum.0 (168226) Message= {"id":26,"method":"get_sound_volume"}
    2025-07-24 17:46:28.947  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[90],"id":26}
    2025-07-24 17:46:28.948  - debug: mihome-vacuum.0 (168226) Message= {"id":27,"method":"get_carpet_mode"}
    2025-07-24 17:46:28.958  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":27}
    2025-07-24 17:46:33.267  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c689568825559ffffffffffffffffffffffffffffffff
    Schaut aber für mich eigentlich sauber aus.
    D Nicht stören
    D Nicht stören
    dirkhe
    @thomas-braun Also in dem log sagt er ja, dass er die map aktualisiert hat. Wie sieht denn das log aus, wenn du get Devices drückst? Bitte auch mal schauen, ob der Browser keinen Fehler wirft
    • D dirkhe
      @dirkhe
      Im Grunde passiert im Log nichts, wenn ich get devices anklicke:
      2025-07-24 18:04:24.351  - debug: mihome-vacuum.0 (168226) discover__{}
      2025-07-24 18:04:27.706  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c68956882598bffffffffffffffffffffffffffffffff
      2025-07-24 18:04:37.709  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c689568825995ffffffffffffffffffffffffffffffff
      2025-07-24 18:04:47.712  - debug: mihome-vacuum.0 (168226) Receive <<< Helo <<< 2131002000000000046c68956882599fffffffffffffffffffffffffffffffff
      2025-07-24 18:04:56.642  - debug: mihome-vacuum.0 (168226) get params for stock Vacuum
      2025-07-24 18:04:56.642  - debug: mihome-vacuum.0 (168226) Message= {"id":96,"method":"get_status"}
      2025-07-24 18:04:56.648  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":947,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":96}
      2025-07-24 18:04:56.649  - debug: mihome-vacuum.0 (168226) setGetStatus {"msg_ver":8,"msg_seq":947,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
      2025-07-24 18:04:56.650  - debug: mihome-vacuum.0 (168226) Message= {"id":97,"method":"get_network_info"}
      2025-07-24 18:04:56.655  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":"unknown_method","id":97}
      2025-07-24 18:04:56.656  - debug: mihome-vacuum.0 (168226) Message= {"id":98,"method":"get_sound_volume"}
      2025-07-24 18:04:56.663  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[90],"id":98}
      2025-07-24 18:04:56.664  - debug: mihome-vacuum.0 (168226) Message= {"id":99,"method":"get_carpet_mode"}
      2025-07-24 18:04:56.674  - debug: mihome-vacuum.0 (168226) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":99}
      Es wird nur die erste Zeile ausgeworfen:
      • D Nicht stören
        D Nicht stören
        dirkhe
        @thomas-braun Das ist seltsam, denn es müssten im debug ja auch die Loginversuche auftauchen. Kannst du ggf. mla deinenen Browser refreshen?
        D Thomas BraunT 2 Antworten Letzte Antwort
        • D dirkhe
          D Nicht stören
          D Nicht stören
          dirkhe
          Also ich habe den Adapter auch gerade im produktiven System installiert, bei mir funktioniert soweit alles. Da müssen wir dann mal sehen, wo es genau hakt bei euch
          • D dirkhe
            @dirkhe sagte in mihome vacuum - login failed:
            Browser neugestartet, sieht aber exakt aus wie zuvor.
            D 2 Antworten Letzte Antwort
              D Nicht stören
              D Nicht stören
              dirkhe
              @thomas-braun Kanst du mal die Browser console aufmachen, ob er da irgendeinen Fehler wirft? Obwohl das bei der Anfrage zumindest komisch ist, er müsste da auf jeden Fall was loggen... Der discovery Eintrag kommt ja dann zum Schluß...
                D Nicht stören
                D Nicht stören
                dirkhe
                @thomas-braun Schau mal bitte in dein Log, die Einträge vorher. Die Einträge direkt vor dem discovery kommen von der Kommunikation mit dem Sauger selber, das kann sein, dass mdu da ein bisschen früher schauen muss.
                Die Fangen alle mit CloudApi an
                • D dirkhe
                  @dirkhe
                  2025-07-24 18:49:52.416  - debug: mihome-vacuum.0 (172290) CloudApi-Login gestartet…
                  2025-07-24 18:49:52.417  - debug: mihome-vacuum.0 (172290) CloudApi-CloudApi-Step 1: Getting sign token
                  2025-07-24 18:49:52.559  - debug: mihome-vacuum.0 (172290) CloudApi-Step 2: Authenticating user
                  2025-07-24 18:49:52.684  - debug: mihome-vacuum.0 (172290) CloudApi-Step 3: Fetching service token
                  2025-07-24 18:49:52.836  - debug: mihome-vacuum.0 (172290) CloudApi-Login erfolgreich!
                  2025-07-24 18:49:52.846  - debug: mihome-vacuum.0 (172290) CloudApi-call: https://-.api.io.mi.com/app/v2/homeroom/gethome with {"data":"{\"fg\":true,\"fetch_share\":true,\"fetch_share_dev\":true,\"limit\":300,\"app_ver\":7}"}
                  2025-07-24 18:49:52.995  - error: mihome-vacuum.0 (172290) CloudApi: executeEncryptedApiCall Error:
                  2025-07-24 18:49:52.996  - debug: mihome-vacuum.0 (172290) discover__{}
                  2025-07-24 18:49:55.667  - debug: mihome-vacuum.0 (172290) Receive <<< Helo <<< 2131002000000000046c689568826433ffffffffffffffffffffffffffffffff
                  2025-07-24 18:50:01.793  - debug: mihome-vacuum.0 (172290) get params for stock Vacuum
                  2025-07-24 18:50:01.794  - debug: mihome-vacuum.0 (172290) Message= {"id":10,"method":"get_status"}
                  2025-07-24 18:50:01.805  - debug: mihome-vacuum.0 (172290) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":991,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":10}
                  2025-07-24 18:50:01.807  - debug: mihome-vacuum.0 (172290) setGetStatus {"msg_ver":8,"msg_seq":991,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
                  2025-07-24 18:50:01.932  - debug: mihome-vacuum.0 (172290) Message= {"id":11,"method":"get_map_v1"}
                  2025-07-24 18:50:01.939  - debug: mihome-vacuum.0 (172290) MIIO RECIVE: {"result":["retry"],"id":11}
                  2025-07-24 18:50:02.242  - debug: mihome-vacuum.0 (172290) Message= {"id":12,"method":"get_map_v1"}
                  2025-07-24 18:50:02.250  - debug: mihome-vacuum.0 (172290) MIIO RECIVE: {"result":["retry"],"id":12}
                  2025-07-24 18:50:02.552  - debug: mihome-vacuum.0 (172290) Message= {"id":13,"method":"get_map_v1"}
                  2025-07-24 18:50:04.556  - debug: mihome-vacuum.0 (172290) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                  2025-07-24 18:50:04.858  - debug: mihome-vacuum.0 (172290) Message= {"id":14,"method":"get_map_v1"}
                  2025-07-24 18:50:04.864  - debug: mihome-vacuum.0 (172290) MIIO RECIVE: {"result":["roboroommap%2F74213525%2F6"],"id":14}
                  2025-07-24 18:50:04.865  - debug: mihome-vacuum.0 (172290) Mappointer_updated
                  2025-07-24 18:50:04.869  - debug: mihome-vacuum.0 (172290) update_Map Mimap enabled
                  2025-07-24 18:50:04.870  - debug: mihome-vacuum.0 (172290) update_Map need new mapurl
                  2025-07-24 18:50:04.874  - debug: mihome-vacuum.0 (172290) CloudApi-call: https://api.io.mi.com/app/home/getmapfileurl with {"data":"{\"obj_name\":\"roboroommap%2F74213525%2F6\"}"}
                  2025-07-24 18:50:04.884  - debug: mihome-vacuum.0 (172290) Message= {"id":15,"method":"get_room_mapping"}
                  2025-07-24 18:50:04.894  - debug: mihome-vacuum.0 (172290) MIIO RECIVE: {"result":"unknown_method","id":15}
                  2025-07-24 18:50:04.896  - debug: mihome-vacuum.0 (172290) Message= {"id":16,"method":"get_consumable"}
                  2025-07-24 18:50:04.898  - debug: mihome-vacuum.0 (172290) Message= {"id":17,"method":"get_network_info"}
                  • D Nicht stören
                    D Nicht stören
                    dirkhe
                    @thomas-braun ok, die entscheiden Zeile ist der executeEncryptedApiCall error, allerdings gibt er da nichts aus.
                    Kannst mal bitte direkt in Datei /ioBroker/iobroker.mihome-vacuum/lib/XiaomiCloudConnector.js gehen und bei folgender Zeile 304
                    aus err.message ein err machen, also das message wegmachen, bitte
                    • D dirkhe
                      @dirkhe
                      Gemacht, Zeile 304:
                                  this.logger.error('CloudApi: executeEncryptedApiCall Error:', err);
                      aber da steht nix drin:
                      2025-07-24 19:01:04.008  - debug: mihome-vacuum.0 (172612) CloudApi-Login gestartet…
                      2025-07-24 19:01:04.009  - debug: mihome-vacuum.0 (172612) CloudApi-CloudApi-Step 1: Getting sign token
                      2025-07-24 19:01:04.112  - debug: mihome-vacuum.0 (172612) CloudApi-Step 2: Authenticating user
                      2025-07-24 19:01:04.244  - debug: mihome-vacuum.0 (172612) CloudApi-Step 3: Fetching service token
                      2025-07-24 19:01:04.407  - debug: mihome-vacuum.0 (172612) CloudApi-Login erfolgreich!
                      2025-07-24 19:01:04.418  - debug: mihome-vacuum.0 (172612) CloudApi-call: https://-.api.io.mi.com/app/v2/homeroom/gethome with {"data":"{\"fg\":true,\"fetch_share\":true,\"fetch_share_dev\":true,\"limit\":300,\"app_ver\":7}"}
                      2025-07-24 19:01:04.590  - error: mihome-vacuum.0 (172612) CloudApi: executeEncryptedApiCall Error:
                      2025-07-24 19:01:04.591  - debug: mihome-vacuum.0 (172612) discover__{}
                        @dirkhe
                        Gemacht, Zeile 304:
                        D Nicht stören
                        D Nicht stören
                        dirkhe
                        @thomas-braun Ach ich dummbacke, das muss so sein
                        this.logger.error(`CloudApi: executeEncryptedApiCall Error:${err.message}`);
                        Thomas BraunT bahnuhrB 2 Antworten Letzte Antwort
                        • D dirkhe
                          @dirkhe
                          2025-07-24 19:15:21.641  - debug: mihome-vacuum.0 (1462) CloudApi-call: https://-.api.io.mi.com/app/v2/homeroom/gethome with {"data":"{\"fg\":true,\"fetch_share\":true,\"fetch_share_dev\":true,\"limit\":300,\"app_ver\":7}"}
                          2025-07-24 19:15:21.833  - error: mihome-vacuum.0 (1462) CloudApi: executeEncryptedApiCall Error:getaddrinfo ENOTFOUND -.api.io.mi.com
                          2025-07-24 19:15:21.834  - debug: mihome-vacuum.0 (1462) discover__{}
                          Thomas BraunT D 2 Antworten Letzte Antwort
                            @dirkhe
                            @thomas-braun sagte in mihome vacuum - login failed:
                            Schaut für mich nach einer ungültigen URL aus.
                            Ich bin im übrigen auf dem chinesischen Server mit dem Sauger angemeldet. Falls das einen Unterschied macht.
                            • D dirkhe
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              @dirkhe
                              so Rückinfo von mir.
                              Nochmal neu von git geholt.
                              login Fehler im log ist nun weg.
                              get devices geht auch; Sauger werden geholt.
                              Und die map geht auch wieder.
                              Vielen lieben Dank für deinen Ansatz und die Lösung.
                              Fazit:
                              Bei mir geht wieder alles.
                              (Anmerkung: Ich bin auf dem deutschen Server)
                              Danke.
                                @dirkhe
                                D Nicht stören
                                D Nicht stören
                                dirkhe
                                @thomas-braun stimmt, sehe den Fehler auch schon, Fix kommt gleich
                                • D Nicht stören
                                  D Nicht stören
                                  dirkhe
                                  @thomas-braun bitte noch mal neu von github holen, ich hatte da noch ein bug drin. hatte das ja alles neu geschrieben....
                                  • D dirkhe
                                    @dirkhe
                                    Nope. Get devices geht noch nicht.
                                    2025-07-24 19:59:42.943  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c68956882748fffffffffffffffffffffffffffffffff
                                    2025-07-24 19:59:42.943  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                    2025-07-24 19:59:52.947  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827499ffffffffffffffffffffffffffffffff
                                    2025-07-24 19:59:52.947  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                    2025-07-24 20:00:02.950  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c6895688274a3ffffffffffffffffffffffffffffffff
                                    2025-07-24 20:00:02.951  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                    2025-07-24 20:00:07.909  - debug: mihome-vacuum.0 (1462) discover__{}
                                    2025-07-24 20:00:12.954  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c6895688274adffffffffffffffffffffffffffffffff
                                    2025-07-24 20:00:12.955  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                    2025-07-24 20:00:22.329  - debug: mihome-vacuum.0 (1462) get params for stock Vacuum
                                    2025-07-24 20:00:22.330  - debug: mihome-vacuum.0 (1462) Message= {"id":142,"method":"get_status"}
                                    2025-07-24 20:00:22.339  - debug: mihome-vacuum.0 (1462) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":1051,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":142}
                                    2025-07-24 20:00:22.340  - debug: mihome-vacuum.0 (1462) setGetStatus {"msg_ver":8,"msg_seq":1051,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
                                    2025-07-24 20:00:22.342  - debug: mihome-vacuum.0 (1462) Message= {"id":143,"method":"get_network_info"}
                                    2025-07-24 20:00:22.350  - debug: mihome-vacuum.0 (1462) MIIO RECIVE: {"result":"unknown_method","id":143}
                                    2025-07-24 20:00:22.351  - debug: mihome-vacuum.0 (1462) Message= {"id":144,"method":"get_sound_volume"}
                                    2025-07-24 20:00:22.361  - debug: mihome-vacuum.0 (1462) MIIO RECIVE: {"result":[90],"id":144}
                                    2025-07-24 20:00:24.956  - debug: mihome-vacuum.0 (1462) Helo message Timeout
                                      @dirkhe
                                      D Nicht stören
                                      D Nicht stören
                                      dirkhe
                                      @thomas-braun gib mal bitte die passenden Logzeilen, die sind in dem Auschnitt nicht drin
                                      Thomas BraunT Eduard77E 4 Antworten Letzte Antwort
                                      • D dirkhe
                                        @dirkhe
                                        Da ist auch nicht mehr. get devices geklickt um 20:40:23.105
                                        2025-07-24 20:40:08.922  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e09ffffffffffffffffffffffffffffffff
                                        2025-07-24 20:40:08.922  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                        2025-07-24 20:40:18.926  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e13ffffffffffffffffffffffffffffffff
                                        2025-07-24 20:40:18.927  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                        2025-07-24 20:40:23.105  - debug: mihome-vacuum.0 (1462) discover__{}
                                        2025-07-24 20:40:28.930  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e1dffffffffffffffffffffffffffffffff
                                        2025-07-24 20:40:28.931  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                        2025-07-24 20:40:38.934  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e27ffffffffffffffffffffffffffffffff
                                        2025-07-24 20:40:38.935  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                        • D dirkhe
                                          @dirkhe
                                          Ah! Nochmal neugestartet, jetzt funktioniert es!
