  3. Cloud Dienste
  4. Iobroker skill in Alexa nicht verfügbar
219 Beiträge 56 Kommentatoren 49.6k Aufrufe 89 Beobachtet
  • realwaxR realwax
    Herzlichen Dank!
    Nun muss man natürlich alte Geräte löschen - Alle - und die neuen wieder in die richtigen Räume adden. Hauptsache er ist wieder da.
    Spannenderweise klappt aber meine alte Config mit den Lichtern von Deconz nicht mehr.
    sobald ich jene in der Alexa App schalte erhalte ich...
    deconz.0
    2025-07-23 20:27:25.837	warn	{"address":"/lights/40/state/bri","description":"invalid value, true, for parameter, bri","type":7}
    deconz.0
    2025-07-23 20:27:25.837	warn	Failed action "bri" on light 40! Description: invalid value, true, for parameter, bri
    deconz.0
    2025-07-23 20:27:25.832	warn	{"address":"/lights/40/state/sat","description":"parameter, sat, is not modifiable. Device is set to off.","type":201}
    deconz.0
    2025-07-23 20:27:25.831	warn	Failed action "sat" on light 40! Description: parameter, sat, is not modifiable. Device is set to off.
    deconz.0
    2025-07-23 20:27:25.830	warn	Code 400: Bad request set light state 40: [{"error":{"address":"/lights/40/state","description":"body contains invalid JSON","type":2}}]
    iot.0
    2025-07-23 20:27:25.819	info	State value to set for "deconz.0.Lights.40.sat" has to be type "number" but received type "boolean"
    iot.0
    2025-07-23 20:27:25.819	info	State value to set for "deconz.0.Lights.40.hue" has to be type "number" but received type "boolean"
    iot.0
    2025-07-23 20:27:25.818	info	State value to set for "deconz.0.Lights.40.bri" has to be type "number" but received type "boolean"
    iot.0
    2025-07-23 20:27:25.818	info	State value to set for "0_userdata.0.lights.colortemp.colortemp_ledoffice" has to be type "number" but received type "boolean"
    Mod-Edit
    Bitte Code-Tags </> benutzen
    #61
    @realwax Naja der neue Skill ist jetzt Alexa V3 basiert, also andere Schnittstelle und Logik. Bitte issue im iot Anlagen und am besten Debug log erstellen und anhängen. Scheinbar müssen wir bei v3 noch letzte Probleme fixen
    • totocotonioT totocotonio
      Hi, ich habe den Skill auch wieder aktiviert aber er findet die Geräte von Node Red nicht mehr.
      Hat da jemand eine Idee?
      Gruß TM
      #62
      @totocotonio Ehrlich ... Ohne das du genauer sagst was "Geräte von node-red" sind ... nein :-)
      totocotonioT 1 Antwort Letzte Antwort
      • apollon77A apollon77
        totocotonioT Offline
        totocotonio
        schrieb am zuletzt editiert von totocotonio
        #63
        @apollon77
        HI, ich habe Flows in Node Red. zB. so:
        Amazon-HUB----Geräte
        Hat immer funktioniert. Nun findet er halt diese Geräte nicht mehr.
        Gruß TM
        Gruß Totocotonio
        Bin noch Anfänger in Sachen IO-Broker und lerne gerne dazu. :P
        Basti97B 1 Antwort Letzte Antwort
          Bongo
          schrieb am zuletzt editiert von Bongo
          #64
          ich habe den Skill auch wieder aktiviert. IOT Pro Passwort eingegeben.
          Alle Geräte sind noch da. Schalter/Licht Ein/Aus funktioniert.
          Aber wenn ich Routinen benutze und und in Alexa2 Trigger/Rescann anstoße, bekomme ich keine Rückmeldung.
          Alexa2 und iot neu gestartet. Hat aber nichts gebracht.
          Jetzt ist der Stand so wie der Skill noch verschwunden war.
          Hab ich was vergessen? Muss ich noch was machen?
          Edit:
          Hm, manchmal kommt bei Trigger/Rescann nichts zurück und manchmal dauert es größer 10 Sekunden.
          Edit:
          Heute reagiert Trigger/Rescann nach ca. 2 Sekunden. Jetzt scheint alles wie gewohnt zu laufen.
          Bongo
          Script - Die sprechende Kaffeemaschine – Home Connect
          Script - JUDO Wasserenthärtung - Connectivity-Modul API
          realwaxR 1 Antwort Letzte Antwort
          • B Bongo
            Edit:
            Edit:
            realwaxR Offline
            realwaxR Offline
            realwax
            schrieb am zuletzt editiert von realwax
            #65
            Ich habe einige Probleme im Zusammenhang mit dem neuen iobroker.assistent skill. Den iobroker.iot skill gibt es ja nicht mehr.
            Der neue scheint nur via der V3 Beta zu kommunizieren. Diese hat aber im iobroker.iot adapter einige Themen wie es scheint. Ich bekomme meine Lichter (deconz adapter) nicht im iot adapter auf der V3 Seite hinein. Es kommt die Fehlermeldung Gerät konnte nicht hinzugefügt werden. Bei der alten Version habe ich bei solchen Fehlern immer das Objekt selbst modifiziert
            "custom": {
               "iot.0": {
                 "smartName": {
                   "de": "Esstisch",
                   "smartType": "LIGHT",
                   "byON": "90"
            aber das scheint der V3 egal zu sein. Das Problem dadurch. Ich bekomme meine Geräte nicht mehr in Alexa und funktionierend.... Wie kann ich das manuell fixen?
            Also danke dass der Skill wieder da ist, aber aktuell funktionieren keine Lichter bei mir via deconz da ich sich nicht einbinden kann... Szenen kommen auch nicht durch.
            Selbst manche einfach Schalter/Steckdosen existieren unter Alexa Geräte, aber nicht unter Alexa Geräte V3. Dort kann man sie nicht adden, und somit kommen sie auch nicht in die Alexa app. Kann ich manuell nachbessern? Config ähnlich wie mit der custom config im objekt. Diese scheint aber nur V1/2 zu betreffen...
            Bin gerade ratlos, auch wenn alles wieder up ist, funktioniert gerade wenig...
            Ich habe 58 Einträge in der V1/V2 Geräte Seite und 14 unter V3 und keine Chance dort welche zu adden.
            https://github.com/ioBroker/ioBroker.iot/issues/938
            Danke für Hilfe, oder Tipps.
            Wolfgang
            • Michael SchmittM Michael Schmitt
              irgendwie steig ich da nicht durch 😲 . Könnte mal jemand ein kleines Howto für dummies wie mich machen. Wie nutzt man das ganze um einfach seine Lichter mit Alexa zu steuern? So das man den Iot Adapter nicht mehr braucht.
              Master67M Offline
              Master67M Offline
              Master67
              #66
              @michael-schmitt sagte in Iobroker skill in Alexa nicht verfügbar:
              irgendwie steig ich da nicht durch . Könnte mal jemand ein kleines Howto für dummies wie mich machen. Wie nutzt man das ganze um einfach seine Lichter mit Alexa zu steuern? So das man den Iot Adapter nicht mehr braucht.
              Ich würde das unterstützen 👍
              Matter mach mir echt Probleme, sobald die USB-Sticks (Sender/Empfänger) Stromlos waren muss ich alles neu in den Matter Adapter Eintragen, ich glaube nicht dass das so sein soll.
              @apollon77 die links zum Thema "Matter" kennen ich, sind aber für jemanden der das erste mal was mit Matter zu tun hat, sehr Umfangreich und echt verwirrende, die Anleitung zur Einrichtung der Geräte passt, aber hier mache ich wohl schon was falsch, denn wenn es richtig wäre, würden die Geräte nach der neuen Stromzufuhr immer noch da sein :-)
              Und nun, soll man noch seine Alexa in Matter einbauen? tja ohne Anleitung für DAUs (ich bin ein DAU) wird das wohl nichts werden :-)
              Gruß Master67
              • ChristianMC Offline
                ChristianMC Offline
                ChristianM
                #67
                Läuft ja bei mir, bergab und rückwärts. Screenshot_20250725-191425_Samsung Internet.jpg
                  Ja wir sind auch überrascht. Es gab keinerlei Kommunikation von Amazon zu irgendwas. Denis hat bereits den Amazon Support angeschrieben und wartet auf Antwort.
                  Ingo
                  FabioF Offline
                  FabioF Offline
                  Fabio
                  schrieb am zuletzt editiert von Fabio
                  #68
                  Guten morgen @apollon77 gibt es was neues?
                  Bin jetzt auch raus, seid gestern Abend. 😒
                  Habe dann den iot Adapter auf Version Alexa V 3 umgestellt und nach mehrmaligen versuchen klappt es auch wieder mit dem Alexa Skill.
                  Jetzt habe ich alle Geräte doppelt in Alexa.
                  Eben kam dann von ioBroker eine Email das ich zu viele Anfragen gestellt habe und bis Mitternacht gesperrt bin. Habe aber laut iobroker Clout 748 also noch einiges bis 1000. iobrkerclout.jpg
                  Ganz erlich ich verstehe hier nur noch Bahnhof.
                  Ich würde mich sehr darüber freuen wenn ihr euch mal bitte äußern könntet wie es weiter geht und evtl. und auch wie?
                  Herzliche Grüße und Danke schön ;-)
                  Fabio
                  PS: In diesem Moment kam dann das:
                  1001 Heute wurden zu viele Befehle gesendet. Sie haben eine ungültige Konfiguration mit hoher Wahrscheinlichkeit.
                  Iobroker:
                  • Matter over Thread Hilfe
                  DuffyD apollon77A 3 Antworten Letzte Antwort
                  • FabioF Fabio
                    Fabio
                    DuffyD Offline
                    DuffyD Offline
                    Duffy
                    #69
                    Hallo an Alle,
                    ich bin total verwirrt.
                    Kann vielleich jemand in einfachen Worten zusammenfassen ob und wie man wieder Lichter über Alexa schalten kann?
                    Ich blick da leider überhaupt nicht mehr durch, Matter, iobroker.iot, iobroker.assistent Alexa 2 Alexa 3 vip6 ......
                    Ich finde nicht mal einen Ansatz um bei mir den Fehler zu beheben.
                    Dazu auch mein Post: (https://forum.iobroker.net/topic/81749/alexa-sprachsteuerung-in-iob-nur-noch-sehr-eingeschränkt)
                    Vielleicht ist die Frage von mir wirklich so dämlich das ich keine Antwort bekomme aber ich würde mich echt freuen wenn mir jemand den Hirnknoten mit einer Antwort entfernen könnte.
                    Es grüsst euch Duffy
                    Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
                    Node.js: v22.23.2
                    NPM: 10.9.4
                    js-controller 7.1.2
                    Linux: Trixie
                      @apollon77
                      Gruß TM
                      Basti97B Offline
                      Basti97B Offline
                      Basti97
                      #70
                      @totocotonio Funktioniert bei dir die Verbindung richtig? Bei mir gibt es eine verzögerung erst dreht sich der ring dann sagt Alexa "Gerät reagiert nicht" und dann schaltet sie es trotzdem. Finde den Fehler in meinen Geräten nicht schon zich mal neugestartet Skill neu Installiert. Aber trotzdem die verzögerung. aber ich bin glücklich das es überhaupt noch funktoniert was man so hier ließt. Geräte werden als Online in Nodered angezeigt.
                      Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
                      • ChristianMC ChristianM
                        #71
                        @christianm Naja, DAS hat jetzt mit dem Skill eher nix zu tun :-)
                        • FabioF Fabio
                          Fabio
                          #72
                          @fabio sagte in Iobroker skill in Alexa nicht verfügbar:
                          Sobald ich Infos von Denis und der von Amazon hat werden wir das auch tun. Ich kann nichts sagen was ich nicht weiss.
                          • DuffyD Duffy
                            Hallo an Alle,
                            #73
                            @duffy Du hast den Thread hier schon richtig gefunden. Aktuell ist der ioBroker.io Skill von Amazon deaktiviert. Es wird einen Nachfolgerskill geben und wir werden kommunizieren sobald alles geklärt ist.
                            • FabioF Fabio
                              Fabio
                              #74
                              @fabio Dazu kann ich jetzt eher wenig sagen. Hat es sich wieder gefangen?
                                FabioF Offline
                                FabioF Offline
                                Fabio
                                #75
                                @apollon77 vielen Dank für deine Antworten.
                                Ich habe jetzt den Matter Adapter installiert und dann meine Steckdosen, Lampen in die ioBroker Matter Bridge eingepflegt.
                                Dann mit dem Handy und der Alexa App ein Matter Gerät hinzugefügt und dann den QR gescannt.
                                Also das ist schon mal der Wahsinn ohne Skill zu schalten und gefühlt tausend mal schneller.
                                Da habt ihr jaaaa echt abgeliefert, der Hammer. 👌👌👌👌👌👌👍👍👍👍
                                Herzliche Grüße
                                Fabio
                                Iobroker:
                                  FabioF Offline
                                  FabioF Offline
                                  Fabio
                                  #76
                                  @apollon77 nein ich kann keine Geräte schalten. Weil ich angeblich über 1000 Aufrufe habe.
                                  Iobroker:
                                  • Christian EttenhoferC Offline
                                    #77
                                    @apollon77
                                    Zunächst einmal möchte ich meine Anerkennung für eure hervorragende Arbeit rund um ioBroker ausdrücken – ich nutze das System seit Jahren intensiv zur Automatisierung unseres gesamten Haushalts und bin nach wie vor überzeugt vom Projekt.
                                    Allerdings empfinde ich den aktuellen Umgang mit der Problematik rund um den IoT-Adapter als nicht ganz angemessen.
                                    Viele Nutzer – mich eingeschlossen – sind zahlende Kunden mit PRO- oder NET-Abos und verlassen sich im Alltag stark auf die Funktionen des IoT-Adapters, z. B. zur Steuerung von Smart-Home-Geräten oder auch – wie bei uns – zur Einbindung der Kinder in den Alltag.
                                    Gerade deshalb wäre es aus meiner Sicht wichtig, die Kommunikation zu verbessern.
                                    Ich weiß, dass Amazon in solchen Dingen kein einfacher Partner ist, aber gerade deshalb würde ich mir einen strukturierten Kommunikationsansatz wünschen:
                                    Gibt es bereits einen Zeitplan oder einen Eskalationspfad?
                                    Welche konkreten Optionen werden aktuell geprüft?
                                    Wie kann die Community ggf. unterstützen?
                                    Ein dedizierter Info-Thread, der regelmäßig – auch wenn es nur kleine Updates sind – gepflegt wird, wäre aus meiner Sicht ein sinnvoller Schritt. Es geht nicht darum, jemanden unter Druck zu setzen, sondern darum, Vertrauen in die Weiterentwicklung und Problemlösung zu stärken.
                                    Ich bleibe euch natürlich treu – aber ein bisschen mehr Transparenz wäre in der jetzigen Situation sicher für viele hilfreich.
                                    Ein Anfang wäre auch, die erlaubten täglichen Anfragen von 1000 hoch zu setzten, alle versuchen aktuell alternativen (Assistent Skill, Matter usw.), hier sollte etwas Kulanz in Spiel kommen.
                                    Grüße aus Niederbayern
                                    Christian
                                    Samson71S Michael SchmittM HomoranH apollon77A 4 Antworten Letzte Antwort
                                    • Christian EttenhoferC Christian Ettenhofer
                                      @apollon77
                                      Christian
                                      Samson71S Offline
                                      Samson71S Offline
                                      Samson71
                                      #78
                                      @christian-ettenhofer sagte in Iobroker skill in Alexa nicht verfügbar:
                                      Sollte sich ergeben, wenn man den Thread aufmerksam liest. Genauso wie
                                      Was bekannt ist wird auch kommuniziert.
                                      Passiert aktuell doch genau hier. Was nicht bekannt ist kann man auch nicht kommunizieren.
                                      Du bezahlst dann diese (Mehr-)Kapazitäten bei den entsprechenden Servern, die dafür bereitgestellt werden müssen? Diese Grenzen sind ja nicht aus Spaß oder zum User ärgern gemacht worden.
                                      Zu einigen Punkten wie "Verlässlichkeit" und "Kinderintegration" äußere ich mich lieber nicht weiter.
                                      Markus
                                      Bitte beachten:
                                      Christian EttenhoferC 1 Antwort Letzte Antwort
                                        @apollon77
                                        Christian
                                        Michael SchmittM Online
                                        Michael Schmitt
                                        #79
                                        Hi, der Beitrag hier ist vom 11. Juli 2025, 08:21 wenn man diesen von oben bis unter durchliest sind doch fast alle Fragen von dir darin beantwortet.
                                        Ich selbst war von dem ganzen noch nicht betroffen, es hatte noch alles (Alexa) funktioniert, wobei ich eh nur Lichter damit steuere, aber ich wollte nicht warten bis nichts mehr geht und habe das ganze nun mit dem Matter Adapter gelöst. Sicher muß man sich in viele Dinge einlesen und das nimmt Zeit in Anspruch. Ich hab dazu im Iobroker Forum nach Matter gesucht und alle Beiträge die für mich interesant waren aboniert und dann schön mitgelesen. Danach war die Umsetzung Matter+Alexa nicht so schwer wie zuerst gedacht.
                                        • Samson71S Samson71
                                          #80
                                          @samson71
                                          Ich glaube das mit der Kinderintegration hast du falsch verstanden!
                                          Vermutlich liegt es aber an der Schreibweise, meine Rechtschreibung ist nicht die allerbeste und ich lasse die Texte immer durch ChatGPT.
                                          Ich meine damit, mit der Kinderintegration - sie sind es gewohnt "Florian aus" zu sagen, und lieben es und es ist für sie wie "das normale"!
                                          Aber nochmal, ohne das ChatGPT meine Rechtschreibung prüft und überarbeitet:
                                          1. ich schätze eure Arbeit
                                          2. ich verstehe das Problem, dass ihr nichts dafür könnte da ihr von Amazon abhängig seit
                                          3. meine Intension ist es nicht, hier etwas schlecht zu reden
                                          4. eigener Thread "evtl mit schreibrechten nur für die MODS" daher, da hier vieles steht, mit verschiedenen Workarounds, ich kann nicht erkennen, wer ist einer von EUCH oder ein User, der sich gerade etwas zusammenbastelt oder eben seine Meinung wiedergeben will.
                                          Das ganze war nicht böse gemeint - ganz im Gegenteil!
                                          Einzig beim Thema - Wer zahlt die zusätzlichen Anfragen.
                                          Da muss ich klar wiedersprechen! Ich zahle für die PRO Version, der Umstand ist letztendlich dem geschuldet, der den Service betreibt! Dies nennt man unternehmerisches Risiko.
                                          Es war ja auch nur die Frage - ob man aus Kulanz eventuell dieses Limit erhöhen könnte.
                                          Dass hier gleich, wenn es ums Geld geht, ein harter Ton angeschlagen werden muss, finde ich unangemessen.
                                          Du darfst gerne meine Histroie bezüglich wie viele Jahre ich schon die PRO Version beziehe prüfen - immer bezahlt - eine Geschäftsbeziehung, sollte vom MITEINANDER geprägt sein und nicht davon, dass wenn der Kunde einmal Reklamiert, dieser gleich dumm angemacht wird.
                                          Aber ich bedanke mich, für das Gespräch mit Ihnen.
                                          Gruß aus Niederbayern
                                          Christian
