  4. Bin total überfordert mit Reaktivierung meines Systems
    6.8k
backit upnode js
43 Beiträge 8 Kommentatoren 5.1k Aufrufe 6 Beobachtet
  • B Bernd 3
    @mcm1957
    So scheinbar funktioniert das Forum ja wieder.
    Ich glaube die Update Probleme konnte ich selbst lösen. Dennoch hier mein aktuelles Log. Vielleicht findet Ihr ja noch etwas. Mein Backup funktioniert immer noch nicht. Dazu später mehr.
    ```bash
    Script v.2025-02-23
    *** BASE SYSTEM ***
       Static hostname: iOBroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     12:03:19 up 66 days, 22:35,  1 user,  load average: 0.46, 0.48, 0.43
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed 'bullseye'. Please check yourself if the Operating System is actively maintained.
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-04-16 12:03:19 CEST
               Universal time: Wed 2025-04-16 10:03:19 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    Bernd571
    HOME=/home/Bernd571
    GROUPS=Bernd571 adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        1.5G        294M        1.0M        2.0G        2.2G
    Swap:            99M          0B         99M
    Total:          3.9G        1.5G        394M
    Active iob-Instances:   19
             3794 M total memory
             1502 M used memory
             1629 M active memory
             1605 M inactive memory
              294 M free memory
               73 M buffer memory
             1924 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 12:03:20 up 66 days, 22:35,  1 user,  load average: 0.46, 0.48, 0.43
    Tasks: 169 total,   1 running, 168 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  1.5 us,  2.9 sy,  0.0 ni, 95.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3794.3 total,    293.8 free,   1503.0 used,   1997.5 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2214.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4       59G   16G   41G  28% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     759M  1.1M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sat Feb  8 12:28:14 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:E2:AD:A5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fcc6c46d-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sat Feb  8 12:28:15 2025] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Sat Feb  8 12:28:15 2025] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Sat Feb  8 12:28:16 2025] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Sat Feb  8 12:28:16 2025] EXT4-fs (mmcblk0p2): 2 orphan inodes deleted
    [Sat Feb  8 12:28:16 2025] EXT4-fs (mmcblk0p2): recovery complete
    [Sat Feb  8 12:28:16 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Feb  8 12:28:16 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sat Feb  8 12:28:18 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.6G    /var/
    1007M   /var/log
    1001M   /var/log/journal/f0afd730650d435998ff424a7140192e
    382M    /var/cache
    Archived and active journals take up 1000.2M in the file system.
    /opt/iobroker/backups:
    6.6G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.5G    /opt/iobroker/iobroker-data/
    1.5G    /opt/iobroker/iobroker-data/history
    922M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
    20M     /opt/iobroker/iobroker-data/objects.jsonl
    18M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.5fe9c7da.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.0
    /usr/bin/node           v20.19.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.0-1nodesource1
      Candidate: 20.19.0-1nodesource1
      Version table:
     *** 20.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u6 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iOBroker            iOBroker (version: 7.0.6, hostname: iOBroker      , alive, uptime: 45399)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.3
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iOBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iOBroker                                 -  enabled
      system.adapter.broadlink2.0             : broadlink2            : iOBroker                                 - disabled
      system.adapter.chromecast.0             : chromecast            : iOBroker                                 - disabled
      system.adapter.daswetter.0              : daswetter             : iOBroker                                 -  enabled
      system.adapter.daswetter.1              : daswetter             : iOBroker                                 -  enabled
      system.adapter.daswetter.2              : daswetter             : iOBroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iOBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iOBroker                                 - disabled
    + system.adapter.echarts.0                : echarts               : iOBroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iOBroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iOBroker                                 -  enabled
    + system.adapter.history.0                : history               : iOBroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iOBroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iOBroker                                 -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : iOBroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.6                 : hm-rpc                : iOBroker                                 -  enabled, port: 12010
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iOBroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iOBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iOBroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iOBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iOBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iOBroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iOBroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iOBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iOBroker                                 -  enabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iOBroker                                 -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iOBroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iOBroker                                 -  enabled
      system.adapter.vis-weather.0            : vis-weather           : iOBroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iOBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : iOBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iOBroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
    Active repo(s): stable
    Upgrade policy: minor
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.3    , installed 7.6.3
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "fritzdect"    : 2.6.1    , installed 2.6.1
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "shelly"       : 9.2.0    , installed 9.2.0
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-weather"  : 2.5.11   , installed 2.5.11
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Objects and States
    Objects:        8746
    States:         7579
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       84905396   2934931/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          84899611   2933384/sshd: /usr/
    tcp        0      0 192.168.178.33:18701    0.0.0.0:*               LISTEN      1001       85450525   2969921/io.hm-rpc.0
    tcp        0      0 192.168.178.33:12010    0.0.0.0:*               LISTEN      1001       85451809   2969802/io.hm-rpc.6
    tcp        0      0 192.168.178.33:2001     0.0.0.0:*               LISTEN      1001       85452861   2969809/io.hm-rpc.1
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       84904300   2934602/iobroker.js
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       84903053   2934602/iobroker.js
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       84917811   2936869/io.shelly.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          84899613   2933384/sshd: /usr/
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       84905010   2934623/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       84906286   2934972/io.web.0
    udp        0      0 0.0.0.0:53291           0.0.0.0:*                           108        84900662   2933491/avahi-daemo
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13697      722/dhcpcd
    udp        0      0 192.168.178.33:5353     0.0.0.0:*                           1001       85487742   2972466/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        84900660   2933491/avahi-daemo
    udp6       0      0 :::55109                :::*                                108        84900663   2933491/avahi-daemo
    udp6       0      0 :::546                  :::*                                0          13710      722/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        84900661   2933491/avahi-daemo
    2025-04-16 11:45:34.634  - info: daswetter.0 (2978455) cleaned everything up...
    2025-04-16 11:45:34.659  - info: host.iOBroker instance system.adapter.daswetter.0 having pid 2978455 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-04-16 11:45:36.742  - info: daswetter.2 (2978475) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.19.0, js-controller: 7.0.6
    2025-04-16 11:45:37.693  - info: daswetter.2 (2978475) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-04-16 11:45:38.210  - info: daswetter.2 (2978475) cleaned everything up...
    2025-04-16 11:45:38.232  - info: host.iOBroker instance system.adapter.daswetter.2 having pid 2978475 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-04-16 11:55:59.519  - info: shelly.0 (2936869) [MQTT] Device with client id "shellyhtg3-ecda3bc0b4cc" connected from 192.168.178.52!
    2025-04-16 11:56:00.706  - info: shelly.0 (2936869) [authEnabled] 192.168.178.52 (shellyhtg3 / shellyhtg3-ecda3bc0b4cc / shellyhtg3#ecda3bc0b4cc#1): This device is not protected via restricted login (see adapter documentation for details)
    2025-04-16 11:56:03.563  - info: shelly.0 (2936869) [MQTT] Client Close: 192.168.178.52 (shellyhtg3 / shellyhtg3-ecda3bc0b4cc / shellyhtg3#ecda3bc0b4cc#1) (false)
    2025-04-16 12:00:06.041  - info: host.iOBroker instance system.adapter.daswetter.1 in version "3.2.3" started with pid 2978886
    2025-04-16 12:00:08.775  - info: daswetter.1 (2978886) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.19.0, js-controller: 7.0.6
    2025-04-16 12:00:10.600  - info: web.0 (2934972) ==> Connected system.user.admin from ::ffff:192.168.178.54
    2025-04-16 12:00:15.767  - info: daswetter.1 (2978886) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-04-16 12:00:16.282  - info: daswetter.1 (2978886) cleaned everything up...
    2025-04-16 12:00:16.306  - info: host.iOBroker instance system.adapter.daswetter.1 having pid 2978886 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-04-16 12:00:19.035  - info: host.iOBroker instance system.adapter.daswetter.0 in version "3.2.3" started with pid 2978908
    2025-04-16 12:00:21.613  - info: daswetter.0 (2978908) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.19.0, js-controller: 7.0.6
    2025-04-16 12:00:33.475  - info: daswetter.0 (2978908) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-04-16 12:00:33.992  - info: daswetter.0 (2978908) cleaned everything up...
    2025-04-16 12:00:34.035  - info: host.iOBroker instance system.adapter.daswetter.2 in version "3.2.3" started with pid 2978923
    2025-04-16 12:00:34.037  - info: host.iOBroker instance system.adapter.daswetter.0 having pid 2978908 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-04-16 12:00:36.853  - info: daswetter.2 (2978923) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.19.0, js-controller: 7.0.6
    2025-04-16 12:00:37.819  - info: daswetter.2 (2978923) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-04-16 12:00:38.354  - info: daswetter.2 (2978923) cleaned everything up...
    2025-04-16 12:00:38.374  - info: host.iOBroker instance system.adapter.daswetter.2 having pid 2978923 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    @bernd-3
    Jag da mal den
    iob fix
    drüber.
    Im Februar hat es auch mal Einschläge im Dateisystem gegeben:
    Starte die Kiste mal sauber durch:
    iob stop
    sudo reboot
    • B Bernd 3
      @mcm1957
      ```bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      Bernd571
      HOME=/home/Bernd571
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               3794 M total memory
               1502 M used memory
                294 M free memory
                 73 M buffer memory
               1924 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      /var:
      1.6G    /var/
      1007M   /var/log
      382M    /var/cache
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.3
      javascript:     8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        8746
      States:         7579
      Pending Updates: 0
      @bernd-3 sagte in Bin total überfordert mit Reaktivierung meines Systems:
      Wahrscheinlich hat sich dein Browser an der Session-ID verschluckt.
      Kommt vorwiegend bei Firefox, aber auch bei anderen Browsern immer mal vor.
      • B Bernd 3
        @mcm1957
        ```bash
        Script v.2025-02-23
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        Bernd571
        HOME=/home/Bernd571
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 3794 M total memory
                 1502 M used memory
                  294 M free memory
                   73 M buffer memory
                 1924 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        *** FILESYSTEM ***
        /var:
        1.6G    /var/
        1007M   /var/log
        382M    /var/cache
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.6.3
        javascript:     8.8.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        8746
        States:         7579
        Pending Updates: 0
        Bernd 3
        @mcm1957
        Zum Backup: Ich denke alle weiter oben genannten Hinweise berücksichtigt zu haben.
        Jedoch zeigt das Backup immer in Fehler und kommt nicht zum Ende.
        Was mich stutzig macht ist Zeile 15 mit der Meldung. Das Passwort hqbe ich mehrfach überprüft. Auch habe ich mit unteerschiedlichen Nutzernamen - Passwortkombinationen getestet - immer das gleiche.
        Was kann ich da noch machen?
        code_tgui
        Backup gestartet ...
        [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.58","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":true,"dir":"Ext_FP_1_Backups_1.0_A_u_B/Backups_iOBroker","dirMinimal":"Ext_FP_1_Backups_1.0_A_u_B/Backups_iOBroker","user":"Bernd571","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false}
        12:16:05.363
        DEBUG
        mount
        cifs-mount command: "mount -t cifs -o username=Bernd571,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.58/Ext_FP_1_Backups_1.0_A_u_B/Backups_iOBroker /opt/iobroker/backups"
        12:16:05.396
        DEBUG
        mount
        cifs-mount command: "mount -t cifs -o username=Bernd571,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.58/Ext_FP_1_Backups_1.0_A_u_B/Backups_iOBroker /opt/iobroker/backups"
        12:16:05.515
        DEBUG
        mount
        Error: Command failed: mount -t cifs -o username=Bernd571,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.58/Ext_FP_1_Backups_1.0_A_u_B/Backups_iOBroker /opt/iobroker/backups
        mount.cifs: permission denied: no match for /opt/iobroker/backups found in /etc/fstab
        [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"23:15","cronjob":"00 48 02 */1 * *","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.58","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":true,"dir":"/Ext_FP_1_Backups_1.0_A_u_B/Backups_iOBroker","dirMinimal":"Ext_FP_1_Backups_1.0_A_u_B/Backups_iOBroker","user":"Bernd571","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false,"context":{"fileNames":[],"errors":{"mount":{"code":1,"killed":false,"signal":null,"cmd":"mount -t cifs -o username=Bernd571,password=\"Was571serQNA\",rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.58/Ext_FP_1_Backups_1.0_A_u_B/Backups_iOBroker /opt/iobroker/backups"}},"done":[],"types":[]},"timestamp":1744798555425,"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":true,"dir":"iOBroker","dirMinimal":"iOBroker","user":"Bernd571","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.58","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.0","sudo":false,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":true,"dir":"Ext_FP_1_Backups_1.0_A_u_B/Backups_iOBroker","dirMinimal":"Ext_FP_1_Backups_1.0_A_u_B/Backups_iOBroker","user":"Bernd571","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=ext
        • B Bernd 3
          @mcm1957
          ```bash
          Script v.2025-02-23
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          Bernd571
          HOME=/home/Bernd571
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   3794 M total memory
                   1502 M used memory
                    294 M free memory
                     73 M buffer memory
                   1924 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          *** FILESYSTEM ***
          /var:
          1.6G    /var/
          1007M   /var/log
          382M    /var/cache
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.6.3
          javascript:     8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        8746
          States:         7579
          Pending Updates: 0
          schlechte Nachricht!
          Dein Dateisystem ist wurmstichig!
          Beim Neuaufsetzen mit bookworm bitte eine neue Karte nehmen.
          • B Bernd 3
            @mcm1957
            code_tgui
            12:16:05.363
            DEBUG
            mount
            12:16:05.396
            DEBUG
            mount
            12:16:05.515
            DEBUG
            mount
            Hast du da die Experten-Einstellungen aktiv?
            Denn soweit ich weiß muss es im Standard in der /etc/fstab keine Einträge geben.
            Das 'permission denied' bezieht sich auch nicht auf die user/pw - Kombination sondern auf das mounten an sich. Das darf (ohne passende Einstellungen) so nur root.
            B 1 Antwort Letzte Antwort
              Bernd 3
              Experten-Einstellung ist "off (default)"
              • B Bernd 3
                @bernd-3
                Dann setz in 'Als root mounten' den Haken.
                • B Bernd 3
                  bitte zeigen!
                  auch die cifs Einstellungen
                  (ggf. Passwort o.ä. unkenntlich machen)
                    @bernd-3
                    Bernd 3
                    @thomas-braun sagte in Bin total überfordert mit Reaktivierung meines Systems:
                    @bernd-3
                    und wo ist diese Einstellung zu finden?
                      bitte zeigen!
                      Bernd 3
                      @homoran sagte in Bin total überfordert mit Reaktivierung meines Systems:
                      bitte zeigen!
                      Meinst Du das mit CIFS -Einstellungen?
                      Hier die Experten-Einstellung OFF
                      • B Bernd 3
                        @bernd-3
                        Genau heißt es
                        'Als root Benutzer mounten (sudo)'
                        Und den SMB-Dialekt würde ich auch so hoch wie möglich einstellen. Sollte 3.1.1 statt 2.0 sein.
                        • B Bernd 3
                          bitte zeigen!
                          CodierknechtC Offline
                          Codierknecht
                          @bernd-3
                          So in etwa sollte das aussehen:
                          (natürlich mit anderer IP und Pfad)
                          Edit
                          Hab nochmal den Screenshot geändert und die Einstellungen meines Testsystems genommen.
                          HmIP|ZigBee|Tasmota|Unifi
                          Zabbix Certified Specialist
                            Genau heißt es
                            Bernd 3
                            schrieb am zuletzt editiert von Bernd 3
                            Genau heißt es
                            Okay, SMB-Einstellung sagt mir etwas. Hatte ich aber vorher auch schon mal auf 3.1.1. Versuche ich aber nochmals.
                            "Als root Benutzer mounten (sudo)" - Kannst Du mir das bitte genauer erklären, für den totalen Newbie oder den im Windoof hängengebliebenen Idioten? Danke! Hat sich erledigt - Codierknecht war schon so frei! Danke
                            • CodierknechtC Codierknecht
                              @bernd-3
                              Edit
                              @codierknecht
                              Ja, wobei man die Optionen 'noserverino' und 'cache loose' nur setzen sollte, wenn die unbedingt erforderlich sind. Erstmal ohne probieren.
                              Beim FritzNAS sind die aber erforderlich.
                                @codierknecht
                                Bernd 3
                                Es handelt sich um ein QNAP-NAS (mit externen Erweiterungs-Festplatten), kein FritzNAS.
                                Mit 3.1.1 aber ohne "nosevervino" und ohne "cache loose" getestet:
                                backitup.0
                                	2025-04-16 15:14:31.316	error	[iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                                backitup.0
                                	2025-04-16 15:13:12.229	error	[iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                                backitup.0
                                	2025-04-16 15:13:12.229	error	[iobroker/mount] mount error(2): No such file or directory
                                backitup.0
                                	2025-04-16 15:13:12.228	error	[iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.58/Ext_FP_1_Backups_1.0_A_u_B/Backups_iOBroker /opt/iobroker/backups
                                backitup.0
                                	2025-04-16 15:12:21.122	error	Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.58/Ext_FP_1_Backups_1.0_A_u_B/Backups_iOBroker /opt/iobroker/backupsmount error(2): No such file or directoryRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                                backitup.0
                                	2025-04-16 15:09:35.786	error	[iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                                Als nächstes versuche ich mit "noserverino" und "cacheloose". Berichte dann
                                HomoranH B 2 Antworten Letzte Antwort
                                • B Bernd 3
                                  backitup.0
                                  backitup.0
                                  backitup.0
                                  backitup.0
                                  backitup.0
                                  backitup.0
                                  ....die Instanz auf Logstufe "debug" zu stellen ;-)
                                  Näheres siehe hier: https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge/1
                                    worauf bezieht sich das?
                                    Ziel oder Mountpoint?
                                    J 1 Antwort Letzte Antwort
                                      Jan1
                                      @Bernd-3
                                      Ist das "Ext_FP_1_Backups_1.0_A_u_B/Backups_iOBroker" der Freigabe Name des Mount, oder ein Verzeichnis?
                                      • B Bernd 3
                                        backitup.0
                                        backitup.0
                                        backitup.0
                                        backitup.0
                                        backitup.0
                                        backitup.0
                                        Bernd 3
                                        backitup.0
                                        backitup.0
                                        backitup.0
                                        backitup.0
                                        backitup.0
                                        backitup.0
                                        Jetzt mit :
                                        00
                                        Log-Größe: 1.9 MB
                                        Zeit
                                        backitup.0
                                        	2025-04-16 15:31:38.142	error	[iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                                        backitup.0
                                        	2025-04-16 15:30:11.806	error	[iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                                        backitup.0
                                        	2025-04-16 15:30:11.805	error	[iobroker/mount] mount error(2): No such file or directory
                                        backitup.0
                                        	2025-04-16 15:30:11.804	error	[iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.58/Ext_FP_1_Backups_1.0_A_u_B/Backups_iOBroker /opt/iobroker/backups
                                        • J Jan1
                                          @Bernd-3
                                          Bernd 3
                                          @jan1
                                          Das ist das Verzeichnis in meinem QNAP-NAS. Eine externe Festplatte (mit dem Namen "Ext_FP_1_Backups_1.0_A_u_B" darin das Verzeichnis "Backups_iOBroker"
                                          HomoranH J 2 Antworten Letzte Antwort
