  4. IoB web page nicht erreichbar Update Admin adapter
46 Beiträge 9 Kommentatoren 6.2k Aufrufe 7 Beobachtet
    @takahara würde ich mit anfangen, und dann nochmal den admin
    Takahara
    @homoran : wäre es in Ordnung, wenn du mir die Befehle unten auflisten kannst?
    Vielen Dank für deine Unterstützung!
    • T Takahara
      @Takahara
      erst einmal den controller
      iob stop
      iob update
      iob upgrade self
      iob start
      einzeln nacheinander eingeben
      • T Takahara
        @takahara
        Zuvor würde ich die Basis noch aktualisieren.
        iob stop
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        • T Takahara
          @homoran ```
          Script v.2025-02-23
          *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
                    Kernel: Linux 6.6.74+rpt-rpi-2712
              Architecture: arm64
          OS is similar to:
          Model           : Raspberry Pi 5 Model B Rev 1.0
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           18:57:05 up 1 day,  1:54,  2 users,  load average: 0.03, 0.02, 0.02
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'bookworm'!
          *** RASPBERRY THROTTLING ***
          Current issues:
          ~ Under-voltage detected
          ~ Arm frequency capped
          Previously detected issues:
          ~ Under-voltage has occurred
          ~ Arm frequency capping has occurred
          *** TIME AND TIMEZONES ***
                         Local time: Mon 2025-03-31 18:57:05 CEST
                     Universal time: Mon 2025-03-31 16:57:05 UTC
                           RTC time: Mon 2025-03-31 16:57:05
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            8.4G        995M        6.2G        5.5M        1.3G        7.4G
          Swap:           536M          0B        536M
          Total:          9.0G        995M        6.8G
          Active iob-Instances:   9
                   8052 M total memory
                    949 M used memory
                   1095 M active memory
                    793 M inactive memory
                   5935 M free memory
                    126 M buffer memory
                   1142 M swap cache
                    511 M total swap
                      0 M used swap
                    511 M free swap
          top - 18:57:05 up 1 day,  1:54,  2 users,  load average: 0.11, 0.03, 0.02
          Tasks: 165 total,   2 running, 163 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   8052.2 total,   5935.6 free,    949.9 used,   1268.9 buff/cache
          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7102.4 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          1 CRITICAL ERRORS DETECTED!
          Check 'sudo dmesg --level=emerg,alert,crit -T' for details
          *** FILESYSTEM ***
          udev           devtmpfs  3.9G     0  3.9G   0% /dev
          tmpfs          tmpfs     806M  5.2M  801M   1% /run
          /dev/mmcblk0p2 ext4      117G  9.2G  102G   9% /
          tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
          tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
          /dev/mmcblk0p1 vfat      510M   55M  456M  11% /boot/firmware
          tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
          [Sun Mar 30 17:02:30 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:66:EC:20 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=f9e3762a-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Sun Mar 30 17:02:35 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
          [Sun Mar 30 17:02:36 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET           SOURCE         FSTYPE OPTIONS
          /                /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          4.0G    /var/
          2.8G    /var/log/journal/a787909f1af9441ba59c4ccec33e25d4
          2.8G    /var/log
          437M    /var/lib
          Archived and active journals take up 2.7G in the file system.
          /opt/iobroker/backups:
          19M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          696M    /opt/iobroker/iobroker-data/
          644M    /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
          8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
          7.0M    /opt/iobroker/iobroker-data/objects.jsonl
          7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
          7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.7e9d7842.chunk.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.18.3
          /usr/bin/node           v20.18.3
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.30.0
          nodejs:
            Installed: 20.18.3-1nodesource1
            Candidate: 20.19.0-1nodesource1
            Version table:
               20.19.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
           *** 20.18.3-1nodesource1 1001
                  100 /var/lib/dpkg/status
               20.18.2-1nodesource1 1001
               20.18.1-1nodesource1 1001
               20.18.0-1nodesource1 1001
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
               18.19.0+dfsg-6~deb12u1 500
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1367)
          Core adapters versions
          js-controller:  6.0.11
          admin:          "admin" not found
          javascript:     8.8.3
          nodejs modules from github:     0
          Adapter State
            system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
            system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Adapters
          Used repository: stable
          Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common//../node_modules/iobroker.admin/io-package.json: /opt/iobroker/node_modules/iobroker.admin/package.json: Unexpected end of JSON input
          Adapter    "backitup"     : 3.0.31   , installed 3.0.31
          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 6.0.11 [Updatable]
          Adapter    "shelly"       : 8.5.1    , installed 8.5.1
          Adapter    "telegram"     : 4.0.0    , installed 4.0.0
          Objects and States
          Objects:        1887
          States:         1411
          Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:4 https://repos.influxdata.com/debian stable InRelease
          Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 36
          *** Listening Ports ***
          tcp        0      0 192.168.178.188:2001    0.0.0.0:*               LISTEN      1001       541872     9091/io.hm-rpc.0
          tcp        0      0 192.168.178.188:2010    0.0.0.0:*               LISTEN      1001       541289     9121/io.hm-rpc.1
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2976       655/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       541059     9013/iobroker.js-co
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       541064     9013/iobroker.js-co
          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       539600     9076/io.shelly.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          2978       655/sshd: /usr/sbin
          tcp6       0      0 :::3000                 :::*                    LISTEN      106        6203       770/grafana
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        6179       709/influxd
          udp        0      0 0.0.0.0:35230           0.0.0.0:*                           104        4899       529/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4897       529/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                104        4898       529/avahi-daemon: r
          udp6       0      0 :::59283                :::*                                104        4900       529/avahi-daemon: r
          2025-03-31 18:57:42.338  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.memHeapUsed:{"val":49.39,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
          2025-03-31 18:57:42.339  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.load:{"val":0.37,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
          2025-03-31 18:57:42.339  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.uptime:{"val":1412,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
          2025-03-31 18:57:42.339  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.mem:{"val":13,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440247335}
          2025-03-31 18:57:42.340  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.freemem:{"val":7022,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
          2025-03-31 18:57:42.340  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.memAvailable:{"val":7364,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
          2025-03-31 18:57:42.340  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.inputCount:{"val":9,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
          2025-03-31 18:57:42.340  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.outputCount:{"val":13,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1743440082335}
          2025-03-31 18:57:42.341  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.eventLoopLag:{"val":1,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1743440262335}
          2025-03-31 18:57:42.341  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.compactgroupProcesses:{"val":0,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1732122139005}
          2025-03-31 18:57:42.346  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.instancesAsProcess:{"val":8,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1743438882325}
          2025-03-31 18:57:42.346  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.instancesAsCompact:{"val":0,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1732122139005}
          2025-03-31 18:57:42.346  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.cpu:{"val":2.13,"ack":true,"ts":1743440262344,"q":0,"from":"system.host.iobroker","lc":1743440262344}
          2025-03-31 18:57:42.346  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.cputime:{"val":26.96,"ack":true,"ts":1743440262344,"q":0,"from":"system.host.iobroker","lc":1743440262344}
          2025-03-31 18:57:42.586  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.alive:{"val":true,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743438882553,"expire":true}
          2025-03-31 18:57:42.586  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.connected:{"val":true,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743438882553,"expire":true}
          2025-03-31 18:57:42.587  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.memRss:{"val":69.42,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743440217584,"expire":true}
          2025-03-31 18:57:42.587  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.memHeapTotal:{"val":23.19,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743439077547,"expire":true}
          2025-03-31 18:57:42.588  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.memHeapUsed:{"val":21.25,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743440262585,"expire":true}
          2025-03-31 18:57:42.588  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.eventLoopLag:{"val":2,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743440217584,"expire":true}
          2025-03-31 18:57:42.589  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.uptime:{"val":1382,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743440262585,"expire":true}
          2025-03-31 18:57:42.590  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.inputCount:{"val":0,"ack":true,"ts":1743440262588,"q":0,"from":"system.adapter.discovery.0","lc":1743438912542,"expire":true}
          2025-03-31 18:57:42.590  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.outputCount:{"val":11,"ack":true,"ts":1743440262589,"q":0,"from":"system.adapter.discovery.0","lc":1743438912542,"expire":true}
          2025-03-31 18:57:42.593  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.cpu:{"val":0.07,"ack":true,"ts":1743440262592,"q":0,"from":"system.adapter.discovery.0","lc":1743440262592,"expire":true}
          2025-03-31 18:57:42.594  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.cputime:{"val":2.99,"ack":true,"ts":1743440262592,"q":0,"from":"system.adapter.discovery.0","lc":1743440262592,"expire":true}
          iob diag has finished.
          Press any key for a summary
          @Thomas-Braun
          ooops!
          Hatte ich schon geschrieben und wieder gelöscht.
          Hatte diese
          @takahara sagte in IoB web page nicht erreichbar Update Admin adapter:
          Pending Updates: 36
          übersehen
            @Thomas-Braun
            ooops!
            Hatte diese
            Pending Updates: 36
            übersehen
            Heute kam auch der aktuelle LTS-Kernel per update rein:
            Linux chet 6.12.20+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.20-1+rpt1~bpo12+1 (2025-03-19) aarch64 GNU/Linux
            Wichtig.
              @takahara
              iob stop
              sudo apt update
              sudo reboot
              Takahara
              @thomas-braun : Primar :) Hat funktioniert. Vielen Dank nochmals für deine / eure Unterstützung.
              • T Takahara
                @takahara
                Wo stehst du denn jetzt mit dem Ding?
                • T Takahara
                  ich habe gestern den Admin Adapters (7.6.3) aktualisiert. Komme jetzt aber nicht mehr auf den IoBroker XX.XX.XX.XX:8081.
                  Über Putty komme ich noch auf den Raspberry und kann leider mit dem Befehl "sudo iobroker start web.0" den Service nicht starten.
                  "for security reasons iobroker should not be run or administrated as root"
                  kann mir jemand helfen, den Web-Zugriff auf den IoBroker wieder herzustellen?
                  Vielen Dank
                  legro
                  schrieb am zuletzt editiert von legro
                  @takahara
                  Auch ich habe ähnliche Erfahrungen nach dem Update des Admin-Adapters gemacht. Anders als bei dir sollte jedoch mein System auf aktuellem Stand sein.
                  Ich rettete mich in diesen Situationen mit einem Neustart des Safari-Browsers auf meinem MacBook. Irgendwie vermag ich das Ganze wohl noch nicht so richtig einzuschätzen. Nun werde ich ebenfalls einmal alle hier vorgeschlagenen Schritte durchführen. Ich habe bisher upgrade anstelle von full-upgrade verwendet.
                  Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
                  • L legro
                    @takahara
                    @legro
                    Mit solchen allgemeinen Aussagen kann man nichts anfangen. Schau dir an, ob die Dienste laufen, ob die per SSL abgesichert sind, auf welchem Port die lauschen usw.
                    Das und noch mehr steht alles in
                    iob diag
                    drin
                    L 2 Antworten Letzte Antwort
                      @legro
                      iob diag
                      drin
                      legro
                      @thomas-braun sagte in IoB web page nicht erreichbar Update Admin adapter:
                      Mit solchen allgemeinen Aussagen kann man nichts anfangen. ..
                      Stimmt. Aber wenn ich‘s genauer eingrenzen könnte, hätte ich es auch getan.
                      iob diag zeigt keine Auffälligkeiten. Auch wurde mittels der Option full-upgrade nichts nachträglich installiert.
                      Da dieses seltsame und seltene Verhalten nach dem Update auftrat, hatte ich die Hoffnung, hier Ideen für eine Lösung zu finden. Aber es scheint wohl bei mir etwas mit dem Safari Browser auf dem MacBook zu tun zu haben: Wenn der Admin Adapter auf dem MacBook sich nicht zeigt, kann ich mittels Aufruf vom iPad aus oder Neustarten von Safari das Problem beheben. Einfach bloß seltsam.😕
                      I 1 Antwort Letzte Antwort
                      • L legro
                        I Offline
                        I Offline
                        ichwersonst
                        Ich würde mich hier mal mit einreihen und folgendes Problem schildern:
                        Ich bin im Iobroker angemeldet und es vergehen ein paar Stunden ohne das ich was mache.
                        Wenn ich dann wieder was machen will, z.B. das Menü wechseln, geht es nicht, da er die ganze Zeit einfach nur lädt.
                        Wenn ich das Webinterface schließe und wieder darauf zugreifen will, lädt dann der Intro Tab ewig ohne das was passiert.
                        Könnt ihr mir dabei helfen?
                        • I ichwersonst
                          @ichwersonst sagte in IoB web page nicht erreichbar Update Admin adapter:
                          Nein.
                          Gib die Ausgabe von
                          iob diag
                          in der Langfassung bekannt.
                            Nein.
                            Gib die Ausgabe von
                            iob diag
                            I Offline
                            I Offline
                            ichwersonst
                            ```bash
                            Script v.2025-02-23
                            *** BASE SYSTEM ***
                             Static hostname: RaspberryPV
                                   Icon name: computer
                                      Kernel: Linux 6.6.74+rpt-rpi-v8
                                Architecture: arm64
                            OS is similar to:
                            Model           : Raspberry Pi 4 Model B Rev 1.5
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 64 bit
                             10:23:13 up 2 days, 31 min,  3 users,  load average: 0.31, 0.21, 0.18
                            CPU threads: 4
                            Current issues:
                                           Local time: Thu 2025-04-03 10:23:13 CEST
                                       Universal time: Thu 2025-04-03 08:23:13 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            wib
                            HOME=/home/wib
                            GROUPS=wib adm dialout cdrom sudo audio video plugdev games users input render n        etdev gpio i2c spi iobroker
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            4.0G        795M        1.9G        1.3M        1.4G        3.2G
                            Swap:           536M          0B        536M
                            Total:          4.5G        795M        2.4G
                            Active iob-Instances:   6
                                     3790 M total memory
                                      758 M used memory
                                      802 M active memory
                                      947 M inactive memory
                                     1811 M free memory
                                      162 M buffer memory
                                     1135 M swap cache
                                      511 M total swap
                                        0 M used swap
                                      511 M free swap
                            top - 10:23:14 up 2 days, 31 min,  3 users,  load average: 0.31, 0.21, 0.18
                            Tasks: 169 total,   1 running, 168 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  0.0 us, 14.3 sy,  0.0 ni, 71.4 id, 14.3 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   3790.9 total,   1810.1 free,    759.4 used,   1298.4 buff/cache
                            MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3031.5 avail Mem
                            No critical errors detected
                            *** FILESYSTEM ***
                            udev           devtmpfs  1.6G     0  1.6G   0% /dev
                            tmpfs          tmpfs     380M  1.3M  378M   1% /run
                            /dev/sda2      ext4       56G  7.3G   46G  14% /
                            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                            tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                            /dev/sda1      vfat      510M   56M  455M  11% /boot/firmware
                            tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                            /                /dev/sda2 ext4   rw,noatime
                            `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437        ,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            1.7G    /var/
                            715M    /var/log/journal/952349f4f3da4e138b5320ebf14f2a46
                            715M    /var/log
                            271M    /var/cache
                            Archived and active journals take up 714.1M in the file system.
                            62M     /opt/iobroker/backups/
                            768M    /opt/iobroker/iobroker-data/
                            717M    /opt/iobroker/iobroker-data/files
                            24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.j        s.map
                            9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.j        s
                            8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb        0.chunk.js.map
                            8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae        1.chunk.js.map
                            7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34        a.chunk.js.map
                            USB-Devices by-id:
                            USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/nodejs         v20.19.0
                            /usr/bin/node           v20.19.0
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            /usr/bin/corepack       0.31.0
                            nodejs:
                              Installed: 20.19.0-1nodesource1
                              Version table:
                             *** 20.19.0-1nodesource1 1001
                                    500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            RaspberryPV         RaspberryPV (version: 7.0.6, hostname: RaspberryPV   , alive, uptime: 99371)
                            js-controller:  7.0.6
                            admin:          7.6.3
                            javascript:     8.8.3
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : RaspberryPV                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.backitup.0               : backitup              : RaspberryPV                              -  enabled
                            + system.adapter.javascript.0             : javascript            : RaspberryPV                              -  enabled
                              system.adapter.modbus.0                 : modbus                : RaspberryPV                              - disabled
                              system.adapter.modbus.1                 : modbus                : RaspberryPV                              - disabled
                              system.adapter.modbus.2                 : modbus                : RaspberryPV                              - disabled
                              system.adapter.modbus.3                 : modbus                : RaspberryPV                              - disabled
                              system.adapter.ping.0                   : ping                  : RaspberryPV                              - disabled
                            + system.adapter.rpi2.0                   : rpi2                  : RaspberryPV                              -  enabled
                            + system.adapter.web.0                    : web                   : RaspberryPV                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + instance is alive
                            Adapter    "admin"        : 7.6.3    , installed 7.6.3
                            Controller "js-controller": 7.0.6    , installed 7.0.6
                            Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                            Adapter    "rpi2"         : 2.3.1    , installed 2.3.1
                            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                            Adapter    "web"          : 7.0.8    , installed 7.0.8
                            Adapter    "ws"           : 2.6.2    , installed 2.6.2
                            Objects and States
                            Objects:        630
                            States:         470
                            Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                            Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Get:6 https://pkgs.tailscale.com/stable/debian bookworm InRelease
                            Fetched 6581 B in 1s (4879 B/s)
                            Pending Updates: 0
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       306438     56308/iobroker.js-c
                            tcp        0      0 100.71.28.54:35475      0.0.0.0:*               LISTEN      0          315720     63047/tailscaled
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       306433     56308/iobroker.js-c
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4858       585/sshd: /usr/sbin
                            tcp6       0      0 :::37541                :::*                    LISTEN      1001       682313     56382/io.backitup.0
                            tcp6       0      0 fd7a:115c:a1e0::d:52087 :::*                    LISTEN      0          315724     63047/tailscaled
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          4860       585/sshd: /usr/sbin
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       305694     56326/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       322619     68840/io.web.0
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2930       454/avahi-daemon: r
                            udp        0      0 0.0.0.0:41641           0.0.0.0:*                           0          637048     63047/tailscaled
                            udp        0      0 0.0.0.0:45779           0.0.0.0:*                           104        2932       454/avahi-daemon: r
                            udp6       0      0 :::5353                 :::*                                104        2931       454/avahi-daemon: r
                            udp6       0      0 :::38177                :::*                                104        2933       454/avahi-daemon: r
                            udp6       0      0 :::41641                :::*                                0          637047     63047/tailscaled
                            2025-04-03 01:47:04.762  - info: host.RaspberryPV Delete log file iobroker.2025-03-26.log.gz
                            2025-04-03 01:47:04.780  - error: host.RaspberryPV Cannot delete file "/opt/iobroker/log/iobroker.2025-03-26.log.gz": Error: ENOENT: no such file or directory, unlink '/opt/iobroker/log/iobroker.2025-03-26.log.gz'
                            2025-04-03 06:47:10.853  - info: admin.0 (56326) Adapter rating updated
                            2025-04-03 07:03:34.573  - error: admin.0 (56326) socket.io [init] Cannot detect user
                            2025-04-03 07:05:33.116  - info: admin.0 (56326) ==> Connected system.user.admin from ::ffff:192.168.50.250
                            2025-04-03 09:42:13.773  - info: admin.0 (56326) ==> Connected system.user.admin from ::ffff:192.168.50.250
                            2025-04-03 09:43:32.158  - info: admin.0 (56326) <== Disconnect system.user.admin from ::ffff:192.168.50.250 backitup
                              @legro
                              iob diag
                              drin
                              legro
                              Mühsam ernährt sich das Eichhörnchen.😖
                              Ich habe in der Zwischenzeit fleißig getestet ..
                              Wenn ich die Website mit dem Admin-Adapters auf dem MacBook offen lasse, so wird vermutlich irgendwann einmal die sog. Session-Key ungültig. Im Gegensatz zum alten Admin-Adapter genügte ein Neuladen der Seite und diese erschien wieder - ggf. musste man sich zusätzlich neu anmelden. Dies ist nun nicht mehr der Fall. Safari meldet, dass der Server nicht (mehr) erreichbar sei.
                              Obwohl sich der Admin-Adapter mit dieser Fehlermeldung nicht mehr aufrufen lässt, kann man sehr wohl noch die VIS aufrufen. Alles damit verbundene funktioniert nach wie vor.
                              Zwei Methoden helfen ..
                              • Ich rufe die Seite von einem zweiten Gerät (z.B. iPad) ab, dann funktioniert i.d.R. auch wieder ein Aufruf auf dem MacBook.
                              • Ich beende Safari auf dem MacBook komplett. Nach dem Neustart von Safari geht die Verbindung zum Admin-Adapter wieder.
                              Nachdem ich nun weiß, wie ich damit umgehen muss, ist für mich alles wieder gut.🙂
                              CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
                              • L legro
                                CodierknechtC Offline
                                Codierknecht
                                @legro sagte in IoB web page nicht erreichbar Update Admin adapter:
                                Oder Methode 3: Ohne Login arbeiten ;-)
                                HmIP|ZigBee|Tasmota|Unifi
                                Zabbix Certified Specialist
                                • L legro
                                  @legro
                                  Das ist aber kein Bug, das ist das durch die Absicherung der Verbindung geforderte und erwartete Verhalten.
                                    @legro
                                    I Offline
                                    I Offline
                                    ichwersonst
                                    Konnte jemand anhand meiner iob diag Ausgabe etwas erkennen, warum ich nach einer Zeit nicht mehr im Webinterface agieren kann?
                                    • I ichwersonst
                                      @ichwersonst
                                      Da steht nichts auffälliges drin.
                                        @ichwersonst
                                        I Offline
                                        I Offline
                                        ichwersonst
                                        Was ist mit dem Fehler gemeint bzw. wie entsteht er?
                                        admin.0 2025-04-07 06:27:34.308	error	socket.io [init] Cannot detect user
                                        Vielleicht hat es ja etwas damit zutun
                                        Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
                                        • I ichwersonst
                                          Weiß ich nicht. Hab ich auf meinen Systemen auch nicht.
                                          Allerdings fahre ich auch keine verschlüsselten Kisten.
