  4. IoB web page nicht erreichbar Update Admin adapter
46 Beiträge 9 Kommentatoren 6.2k Aufrufe 7 Beobachtet
    @takahara sagte in IoB web page nicht erreichbar Update Admin adapter:
    den gesamten Ausgabetext
    als Text in code-tags
    trotzdem sieht man, dass der Vorschlag von @paul53 erfolgreich sein müsste/könnte
    Takahara
    @homoran ```
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer
              Kernel: Linux 6.6.74+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     18:57:05 up 1 day,  1:54,  2 users,  load average: 0.03, 0.02, 0.02
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    ~ Under-voltage detected
    ~ Arm frequency capped
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-03-31 18:57:05 CEST
               Universal time: Mon 2025-03-31 16:57:05 UTC
                     RTC time: Mon 2025-03-31 16:57:05
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.4G        995M        6.2G        5.5M        1.3G        7.4G
    Swap:           536M          0B        536M
    Total:          9.0G        995M        6.8G
    Active iob-Instances:   9
             8052 M total memory
              949 M used memory
             1095 M active memory
              793 M inactive memory
             5935 M free memory
              126 M buffer memory
             1142 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 18:57:05 up 1 day,  1:54,  2 users,  load average: 0.11, 0.03, 0.02
    Tasks: 165 total,   2 running, 163 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8052.2 total,   5935.6 free,    949.9 used,   1268.9 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7102.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    1 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     806M  5.2M  801M   1% /run
    /dev/mmcblk0p2 ext4      117G  9.2G  102G   9% /
    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   55M  456M  11% /boot/firmware
    tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
    [Sun Mar 30 17:02:30 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:66:EC:20 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=f9e3762a-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Mar 30 17:02:35 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Sun Mar 30 17:02:36 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    4.0G    /var/
    2.8G    /var/log/journal/a787909f1af9441ba59c4ccec33e25d4
    2.8G    /var/log
    437M    /var/lib
    Archived and active journals take up 2.7G in the file system.
    /opt/iobroker/backups:
    19M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    696M    /opt/iobroker/iobroker-data/
    644M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/objects.jsonl
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.7e9d7842.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.3
    /usr/bin/node           v20.18.3
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.30.0
    nodejs:
      Installed: 20.18.3-1nodesource1
      Candidate: 20.19.0-1nodesource1
      Version table:
         20.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
     *** 20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1367)
    Core adapters versions
    js-controller:  6.0.11
    admin:          "admin" not found
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
      system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common//../node_modules/iobroker.admin/io-package.json: /opt/iobroker/node_modules/iobroker.admin/package.json: Unexpected end of JSON input
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 6.0.11 [Updatable]
    Adapter    "shelly"       : 8.5.1    , installed 8.5.1
    Adapter    "telegram"     : 4.0.0    , installed 4.0.0
    Objects and States
    Objects:        1887
    States:         1411
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 36
    *** Listening Ports ***
    tcp        0      0 192.168.178.188:2001    0.0.0.0:*               LISTEN      1001       541872     9091/io.hm-rpc.0
    tcp        0      0 192.168.178.188:2010    0.0.0.0:*               LISTEN      1001       541289     9121/io.hm-rpc.1
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2976       655/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       541059     9013/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       541064     9013/iobroker.js-co
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       539600     9076/io.shelly.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          2978       655/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      106        6203       770/grafana
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        6179       709/influxd
    udp        0      0 0.0.0.0:35230           0.0.0.0:*                           104        4899       529/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4897       529/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        4898       529/avahi-daemon: r
    udp6       0      0 :::59283                :::*                                104        4900       529/avahi-daemon: r
    2025-03-31 18:57:42.338  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.memHeapUsed:{"val":49.39,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
    2025-03-31 18:57:42.339  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.load:{"val":0.37,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
    2025-03-31 18:57:42.339  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.uptime:{"val":1412,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
    2025-03-31 18:57:42.339  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.mem:{"val":13,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440247335}
    2025-03-31 18:57:42.340  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.freemem:{"val":7022,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
    2025-03-31 18:57:42.340  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.memAvailable:{"val":7364,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
    2025-03-31 18:57:42.340  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.inputCount:{"val":9,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
    2025-03-31 18:57:42.340  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.outputCount:{"val":13,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1743440082335}
    2025-03-31 18:57:42.341  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.eventLoopLag:{"val":1,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1743440262335}
    2025-03-31 18:57:42.341  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.compactgroupProcesses:{"val":0,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1732122139005}
    2025-03-31 18:57:42.346  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.instancesAsProcess:{"val":8,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1743438882325}
    2025-03-31 18:57:42.346  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.instancesAsCompact:{"val":0,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1732122139005}
    2025-03-31 18:57:42.346  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.cpu:{"val":2.13,"ack":true,"ts":1743440262344,"q":0,"from":"system.host.iobroker","lc":1743440262344}
    2025-03-31 18:57:42.346  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.cputime:{"val":26.96,"ack":true,"ts":1743440262344,"q":0,"from":"system.host.iobroker","lc":1743440262344}
    2025-03-31 18:57:42.586  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.alive:{"val":true,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743438882553,"expire":true}
    2025-03-31 18:57:42.586  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.connected:{"val":true,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743438882553,"expire":true}
    2025-03-31 18:57:42.587  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.memRss:{"val":69.42,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743440217584,"expire":true}
    2025-03-31 18:57:42.587  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.memHeapTotal:{"val":23.19,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743439077547,"expire":true}
    2025-03-31 18:57:42.588  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.memHeapUsed:{"val":21.25,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743440262585,"expire":true}
    2025-03-31 18:57:42.588  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.eventLoopLag:{"val":2,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743440217584,"expire":true}
    2025-03-31 18:57:42.589  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.uptime:{"val":1382,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743440262585,"expire":true}
    2025-03-31 18:57:42.590  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.inputCount:{"val":0,"ack":true,"ts":1743440262588,"q":0,"from":"system.adapter.discovery.0","lc":1743438912542,"expire":true}
    2025-03-31 18:57:42.590  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.outputCount:{"val":11,"ack":true,"ts":1743440262589,"q":0,"from":"system.adapter.discovery.0","lc":1743438912542,"expire":true}
    2025-03-31 18:57:42.593  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.cpu:{"val":0.07,"ack":true,"ts":1743440262592,"q":0,"from":"system.adapter.discovery.0","lc":1743440262592,"expire":true}
    2025-03-31 18:57:42.594  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.cputime:{"val":2.99,"ack":true,"ts":1743440262592,"q":0,"from":"system.adapter.discovery.0","lc":1743440262592,"expire":true}
    iob diag has finished.
    Press any key for a summary
      @takahara
      Der gesamte Text der Langfassung ist gefragt.
      Ich sehe aber jetzt schon, dass die komplette Kiste schwer sanierungsbedürftig ist.
      Takahara
      @thomas-braun : Ich befürchte, dass du mir sagen wirst, dass ich grundlegende Fehler bei der Installation vom IoBroker gemacht habe?!?
      Kannst du bitte etwas genauer werden?
      • T Takahara
        geht erst jetzt mit der vollständigen Langfassung
        stay tuned
        • T Takahara
          @takahara
          Deine Spannungsversorgung ist zu schwach auf der Brust.
          Der Admin ist kaputt.
          Der Js-Controller ist veraltet.
          • T Takahara
            @homoran ```
            Script v.2025-02-23
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
            CPU threads: 4
            Current issues:
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:           536M          0B        536M
                     8052 M total memory
                      949 M used memory
                     5935 M free memory
                      126 M buffer memory
                     1142 M swap cache
                      511 M total swap
                        0 M used swap
                      511 M free swap
            *** FILESYSTEM ***
            /var:
            4.0G    /var/
            2.8G    /var/log
            437M    /var/lib
            USB-Devices by-id:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            javascript:     8.8.3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        1887
            States:         1411
            Pending Updates: 36
            Netzteilprobleme!
            thermische Probleme
            warum, müssen wir suchen.
            Das könnte fue Ursache sein
              Netzteilprobleme!
              thermische Probleme
              Takahara
              @homoran : Danke dir.
              Kannst du mir sagen, was ich machen soll?
              Den js-controller updaten?
              • T Takahara
                @takahara würde ich mit anfangen, und dann nochmal den admin
                  Takahara
                  @homoran : wäre es in Ordnung, wenn du mir die Befehle unten auflisten kannst?
                  Vielen Dank für deine Unterstützung!
                  • T Takahara
                    @Takahara
                    erst einmal den controller
                    iob stop
                    iob update
                    iob upgrade self
                    iob start
                    einzeln nacheinander eingeben
                    • T Takahara
                      @takahara
                      Zuvor würde ich die Basis noch aktualisieren.
                      iob stop
                      sudo apt update
                      sudo apt full-upgrade
                      sudo reboot
                      • T Takahara
                        @homoran ```
                        Script v.2025-02-23
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        OS is similar to:
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                        CPU threads: 4
                        Current issues:
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        HOME=/home/pi
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:           536M          0B        536M
                                 8052 M total memory
                                  949 M used memory
                                 5935 M free memory
                                  126 M buffer memory
                                 1142 M swap cache
                                  511 M total swap
                                    0 M used swap
                                  511 M free swap
                        *** FILESYSTEM ***
                        /var:
                        4.0G    /var/
                        2.8G    /var/log
                        437M    /var/lib
                        USB-Devices by-id:
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        javascript:     8.8.3
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        1887
                        States:         1411
                        Pending Updates: 36
                        @Thomas-Braun
                        ooops!
                        Hatte ich schon geschrieben und wieder gelöscht.
                        Hatte diese
                        Pending Updates: 36
                        übersehen
                          @Thomas-Braun
                          ooops!
                          Hatte diese
                          Pending Updates: 36
                          übersehen
                          Heute kam auch der aktuelle LTS-Kernel per update rein:
                          Linux chet 6.12.20+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.20-1+rpt1~bpo12+1 (2025-03-19) aarch64 GNU/Linux
                          Wichtig.
                            @takahara
                            iob stop
                            sudo apt update
                            sudo reboot
                            Takahara
                            @thomas-braun : Primar :) Hat funktioniert. Vielen Dank nochmals für deine / eure Unterstützung.
                            • T Takahara
                              @takahara
                              Wo stehst du denn jetzt mit dem Ding?
                              • T Takahara
                                ich habe gestern den Admin Adapters (7.6.3) aktualisiert. Komme jetzt aber nicht mehr auf den IoBroker XX.XX.XX.XX:8081.
                                Über Putty komme ich noch auf den Raspberry und kann leider mit dem Befehl "sudo iobroker start web.0" den Service nicht starten.
                                "for security reasons iobroker should not be run or administrated as root"
                                kann mir jemand helfen, den Web-Zugriff auf den IoBroker wieder herzustellen?
                                Vielen Dank
                                legro
                                schrieb am zuletzt editiert von legro
                                @takahara
                                Auch ich habe ähnliche Erfahrungen nach dem Update des Admin-Adapters gemacht. Anders als bei dir sollte jedoch mein System auf aktuellem Stand sein.
                                Ich rettete mich in diesen Situationen mit einem Neustart des Safari-Browsers auf meinem MacBook. Irgendwie vermag ich das Ganze wohl noch nicht so richtig einzuschätzen. Nun werde ich ebenfalls einmal alle hier vorgeschlagenen Schritte durchführen. Ich habe bisher upgrade anstelle von full-upgrade verwendet.
                                Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
                                • L legro
                                  @takahara
                                  @legro
                                  Mit solchen allgemeinen Aussagen kann man nichts anfangen. Schau dir an, ob die Dienste laufen, ob die per SSL abgesichert sind, auf welchem Port die lauschen usw.
                                  Das und noch mehr steht alles in
                                  iob diag
                                  drin
                                  L 2 Antworten Letzte Antwort
                                    @legro
                                    iob diag
                                    drin
                                    legro
                                    @thomas-braun sagte in IoB web page nicht erreichbar Update Admin adapter:
                                    Mit solchen allgemeinen Aussagen kann man nichts anfangen. ..
                                    Stimmt. Aber wenn ich‘s genauer eingrenzen könnte, hätte ich es auch getan.
                                    iob diag zeigt keine Auffälligkeiten. Auch wurde mittels der Option full-upgrade nichts nachträglich installiert.
                                    Da dieses seltsame und seltene Verhalten nach dem Update auftrat, hatte ich die Hoffnung, hier Ideen für eine Lösung zu finden. Aber es scheint wohl bei mir etwas mit dem Safari Browser auf dem MacBook zu tun zu haben: Wenn der Admin Adapter auf dem MacBook sich nicht zeigt, kann ich mittels Aufruf vom iPad aus oder Neustarten von Safari das Problem beheben. Einfach bloß seltsam.😕
                                    I 1 Antwort Letzte Antwort
                                    • L legro
                                      I Offline
                                      I Offline
                                      ichwersonst
                                      Ich würde mich hier mal mit einreihen und folgendes Problem schildern:
                                      Ich bin im Iobroker angemeldet und es vergehen ein paar Stunden ohne das ich was mache.
                                      Wenn ich dann wieder was machen will, z.B. das Menü wechseln, geht es nicht, da er die ganze Zeit einfach nur lädt.
                                      Wenn ich das Webinterface schließe und wieder darauf zugreifen will, lädt dann der Intro Tab ewig ohne das was passiert.
                                      Könnt ihr mir dabei helfen?
                                      • I ichwersonst
                                        @ichwersonst sagte in IoB web page nicht erreichbar Update Admin adapter:
                                        Nein.
                                        Gib die Ausgabe von
                                        iob diag
                                        in der Langfassung bekannt.
                                          Nein.
                                          Gib die Ausgabe von
                                          iob diag
                                          I Offline
                                          I Offline
                                          ichwersonst
                                          ```bash
                                          Script v.2025-02-23
                                          *** BASE SYSTEM ***
                                           Static hostname: RaspberryPV
                                                 Icon name: computer
                                                    Kernel: Linux 6.6.74+rpt-rpi-v8
                                              Architecture: arm64
                                          OS is similar to:
                                          Model           : Raspberry Pi 4 Model B Rev 1.5
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                           10:23:13 up 2 days, 31 min,  3 users,  load average: 0.31, 0.21, 0.18
                                          CPU threads: 4
                                          Current issues:
                                                         Local time: Thu 2025-04-03 10:23:13 CEST
                                                     Universal time: Thu 2025-04-03 08:23:13 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          wib
                                          HOME=/home/wib
                                          GROUPS=wib adm dialout cdrom sudo audio video plugdev games users input render n        etdev gpio i2c spi iobroker
                                          iobroker
                                          HOME=/home/iobroker
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            4.0G        795M        1.9G        1.3M        1.4G        3.2G
                                          Swap:           536M          0B        536M
                                          Total:          4.5G        795M        2.4G
                                          Active iob-Instances:   6
                                                   3790 M total memory
                                                    758 M used memory
                                                    802 M active memory
                                                    947 M inactive memory
                                                   1811 M free memory
                                                    162 M buffer memory
                                                   1135 M swap cache
                                                    511 M total swap
                                                      0 M used swap
                                                    511 M free swap
                                          top - 10:23:14 up 2 days, 31 min,  3 users,  load average: 0.31, 0.21, 0.18
                                          Tasks: 169 total,   1 running, 168 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s):  0.0 us, 14.3 sy,  0.0 ni, 71.4 id, 14.3 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :   3790.9 total,   1810.1 free,    759.4 used,   1298.4 buff/cache
                                          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3031.5 avail Mem
                                          No critical errors detected
                                          *** FILESYSTEM ***
                                          udev           devtmpfs  1.6G     0  1.6G   0% /dev
                                          tmpfs          tmpfs     380M  1.3M  378M   1% /run
                                          /dev/sda2      ext4       56G  7.3G   46G  14% /
                                          tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                                          /dev/sda1      vfat      510M   56M  455M  11% /boot/firmware
                                          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                          /                /dev/sda2 ext4   rw,noatime
                                          `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437        ,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          1.7G    /var/
                                          715M    /var/log/journal/952349f4f3da4e138b5320ebf14f2a46
                                          715M    /var/log
                                          271M    /var/cache
                                          Archived and active journals take up 714.1M in the file system.
                                          62M     /opt/iobroker/backups/
                                          768M    /opt/iobroker/iobroker-data/
                                          717M    /opt/iobroker/iobroker-data/files
                                          24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.j        s.map
                                          9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.j        s
                                          8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb        0.chunk.js.map
                                          8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae        1.chunk.js.map
                                          7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34        a.chunk.js.map
                                          USB-Devices by-id:
                                          USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
                                          zigbee.X
                                          Extended Pan ID:
                                          *** MASKED ***
                                          Pan ID:
                                          *** MASKED ***
                                          Channel:
                                          *** MASKED ***
                                          Network Key:
                                          *** MASKED ***
                                          /usr/bin/nodejs         v20.19.0
                                          /usr/bin/node           v20.19.0
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          /usr/bin/corepack       0.31.0
                                          nodejs:
                                            Installed: 20.19.0-1nodesource1
                                            Version table:
                                           *** 20.19.0-1nodesource1 1001
                                                  500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          RaspberryPV         RaspberryPV (version: 7.0.6, hostname: RaspberryPV   , alive, uptime: 99371)
                                          js-controller:  7.0.6
                                          admin:          7.6.3
                                          javascript:     8.8.3
                                          Adapter State
                                          + system.adapter.admin.0                  : admin                 : RaspberryPV                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          + system.adapter.backitup.0               : backitup              : RaspberryPV                              -  enabled
                                          + system.adapter.javascript.0             : javascript            : RaspberryPV                              -  enabled
                                            system.adapter.modbus.0                 : modbus                : RaspberryPV                              - disabled
                                            system.adapter.modbus.1                 : modbus                : RaspberryPV                              - disabled
                                            system.adapter.modbus.2                 : modbus                : RaspberryPV                              - disabled
                                            system.adapter.modbus.3                 : modbus                : RaspberryPV                              - disabled
                                            system.adapter.ping.0                   : ping                  : RaspberryPV                              - disabled
                                          + system.adapter.rpi2.0                   : rpi2                  : RaspberryPV                              -  enabled
                                          + system.adapter.web.0                    : web                   : RaspberryPV                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          + instance is alive
                                          Adapter    "admin"        : 7.6.3    , installed 7.6.3
                                          Controller "js-controller": 7.0.6    , installed 7.0.6
                                          Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                                          Adapter    "rpi2"         : 2.3.1    , installed 2.3.1
                                          Adapter    "web"          : 7.0.8    , installed 7.0.8
                                          Objects and States
                                          Objects:        630
                                          States:         470
                                          Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                                          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                          Get:6 https://pkgs.tailscale.com/stable/debian bookworm InRelease
                                          Fetched 6581 B in 1s (4879 B/s)
                                          Pending Updates: 0
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       306438     56308/iobroker.js-c
                                          tcp        0      0 100.71.28.54:35475      0.0.0.0:*               LISTEN      0          315720     63047/tailscaled
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       306433     56308/iobroker.js-c
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4858       585/sshd: /usr/sbin
                                          tcp6       0      0 :::37541                :::*                    LISTEN      1001       682313     56382/io.backitup.0
                                          tcp6       0      0 fd7a:115c:a1e0::d:52087 :::*                    LISTEN      0          315724     63047/tailscaled
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          4860       585/sshd: /usr/sbin
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       305694     56326/io.admin.0
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       322619     68840/io.web.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2930       454/avahi-daemon: r
                                          udp        0      0 0.0.0.0:41641           0.0.0.0:*                           0          637048     63047/tailscaled
                                          udp        0      0 0.0.0.0:45779           0.0.0.0:*                           104        2932       454/avahi-daemon: r
                                          udp6       0      0 :::5353                 :::*                                104        2931       454/avahi-daemon: r
                                          udp6       0      0 :::38177                :::*                                104        2933       454/avahi-daemon: r
                                          udp6       0      0 :::41641                :::*                                0          637047     63047/tailscaled
                                          2025-04-03 01:47:04.762  - info: host.RaspberryPV Delete log file iobroker.2025-03-26.log.gz
                                          2025-04-03 01:47:04.780  - error: host.RaspberryPV Cannot delete file "/opt/iobroker/log/iobroker.2025-03-26.log.gz": Error: ENOENT: no such file or directory, unlink '/opt/iobroker/log/iobroker.2025-03-26.log.gz'
                                          2025-04-03 06:47:10.853  - info: admin.0 (56326) Adapter rating updated
                                          2025-04-03 07:03:34.573  - error: admin.0 (56326) socket.io [init] Cannot detect user
                                          2025-04-03 07:05:33.116  - info: admin.0 (56326) ==> Connected system.user.admin from ::ffff:192.168.50.250
                                          2025-04-03 09:42:13.773  - info: admin.0 (56326) ==> Connected system.user.admin from ::ffff:192.168.50.250
                                          2025-04-03 09:43:32.158  - info: admin.0 (56326) <== Disconnect system.user.admin from ::ffff:192.168.50.250 backitup
