  4. IoB web page nicht erreichbar Update Admin adapter
46 Beiträge 9 Kommentatoren 6.2k Aufrufe 7 Beobachtet
  • T Takahara
    @homoran ```
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer
              Kernel: Linux 6.6.74+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     18:57:05 up 1 day,  1:54,  2 users,  load average: 0.03, 0.02, 0.02
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    ~ Under-voltage detected
    ~ Arm frequency capped
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-03-31 18:57:05 CEST
               Universal time: Mon 2025-03-31 16:57:05 UTC
                     RTC time: Mon 2025-03-31 16:57:05
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.4G        995M        6.2G        5.5M        1.3G        7.4G
    Swap:           536M          0B        536M
    Total:          9.0G        995M        6.8G
    Active iob-Instances:   9
             8052 M total memory
              949 M used memory
             1095 M active memory
              793 M inactive memory
             5935 M free memory
              126 M buffer memory
             1142 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 18:57:05 up 1 day,  1:54,  2 users,  load average: 0.11, 0.03, 0.02
    Tasks: 165 total,   2 running, 163 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8052.2 total,   5935.6 free,    949.9 used,   1268.9 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7102.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    1 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     806M  5.2M  801M   1% /run
    /dev/mmcblk0p2 ext4      117G  9.2G  102G   9% /
    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   55M  456M  11% /boot/firmware
    tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
    [Sun Mar 30 17:02:30 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:66:EC:20 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=f9e3762a-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Mar 30 17:02:35 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Sun Mar 30 17:02:36 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    4.0G    /var/
    2.8G    /var/log/journal/a787909f1af9441ba59c4ccec33e25d4
    2.8G    /var/log
    437M    /var/lib
    Archived and active journals take up 2.7G in the file system.
    /opt/iobroker/backups:
    19M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    696M    /opt/iobroker/iobroker-data/
    644M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/objects.jsonl
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.7e9d7842.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.3
    /usr/bin/node           v20.18.3
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.30.0
    nodejs:
      Installed: 20.18.3-1nodesource1
      Candidate: 20.19.0-1nodesource1
      Version table:
         20.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
     *** 20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1367)
    Core adapters versions
    js-controller:  6.0.11
    admin:          "admin" not found
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
      system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common//../node_modules/iobroker.admin/io-package.json: /opt/iobroker/node_modules/iobroker.admin/package.json: Unexpected end of JSON input
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 6.0.11 [Updatable]
    Adapter    "shelly"       : 8.5.1    , installed 8.5.1
    Adapter    "telegram"     : 4.0.0    , installed 4.0.0
    Objects and States
    Objects:        1887
    States:         1411
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 36
    *** Listening Ports ***
    tcp        0      0 192.168.178.188:2001    0.0.0.0:*               LISTEN      1001       541872     9091/io.hm-rpc.0
    tcp        0      0 192.168.178.188:2010    0.0.0.0:*               LISTEN      1001       541289     9121/io.hm-rpc.1
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2976       655/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       541059     9013/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       541064     9013/iobroker.js-co
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       539600     9076/io.shelly.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          2978       655/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      106        6203       770/grafana
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        6179       709/influxd
    udp        0      0 0.0.0.0:35230           0.0.0.0:*                           104        4899       529/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4897       529/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        4898       529/avahi-daemon: r
    udp6       0      0 :::59283                :::*                                104        4900       529/avahi-daemon: r
    2025-03-31 18:57:42.338  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.memHeapUsed:{"val":49.39,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
    2025-03-31 18:57:42.339  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.load:{"val":0.37,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
    2025-03-31 18:57:42.339  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.uptime:{"val":1412,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
    2025-03-31 18:57:42.339  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.mem:{"val":13,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440247335}
    2025-03-31 18:57:42.340  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.freemem:{"val":7022,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
    2025-03-31 18:57:42.340  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.memAvailable:{"val":7364,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
    2025-03-31 18:57:42.340  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.inputCount:{"val":9,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
    2025-03-31 18:57:42.340  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.outputCount:{"val":13,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1743440082335}
    2025-03-31 18:57:42.341  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.eventLoopLag:{"val":1,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1743440262335}
    2025-03-31 18:57:42.341  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.compactgroupProcesses:{"val":0,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1732122139005}
    2025-03-31 18:57:42.346  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.instancesAsProcess:{"val":8,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1743438882325}
    2025-03-31 18:57:42.346  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.instancesAsCompact:{"val":0,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1732122139005}
    2025-03-31 18:57:42.346  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.cpu:{"val":2.13,"ack":true,"ts":1743440262344,"q":0,"from":"system.host.iobroker","lc":1743440262344}
    2025-03-31 18:57:42.346  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.cputime:{"val":26.96,"ack":true,"ts":1743440262344,"q":0,"from":"system.host.iobroker","lc":1743440262344}
    2025-03-31 18:57:42.586  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.alive:{"val":true,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743438882553,"expire":true}
    2025-03-31 18:57:42.586  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.connected:{"val":true,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743438882553,"expire":true}
    2025-03-31 18:57:42.587  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.memRss:{"val":69.42,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743440217584,"expire":true}
    2025-03-31 18:57:42.587  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.memHeapTotal:{"val":23.19,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743439077547,"expire":true}
    2025-03-31 18:57:42.588  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.memHeapUsed:{"val":21.25,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743440262585,"expire":true}
    2025-03-31 18:57:42.588  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.eventLoopLag:{"val":2,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743440217584,"expire":true}
    2025-03-31 18:57:42.589  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.uptime:{"val":1382,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743440262585,"expire":true}
    2025-03-31 18:57:42.590  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.inputCount:{"val":0,"ack":true,"ts":1743440262588,"q":0,"from":"system.adapter.discovery.0","lc":1743438912542,"expire":true}
    2025-03-31 18:57:42.590  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.outputCount:{"val":11,"ack":true,"ts":1743440262589,"q":0,"from":"system.adapter.discovery.0","lc":1743438912542,"expire":true}
    2025-03-31 18:57:42.593  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.cpu:{"val":0.07,"ack":true,"ts":1743440262592,"q":0,"from":"system.adapter.discovery.0","lc":1743440262592,"expire":true}
    2025-03-31 18:57:42.594  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.cputime:{"val":2.99,"ack":true,"ts":1743440262592,"q":0,"from":"system.adapter.discovery.0","lc":1743440262592,"expire":true}
    iob diag has finished.
    Press any key for a summary
    @Thomas-Braun
    ooops!
    Hatte ich schon geschrieben und wieder gelöscht.
    Hatte diese
    @takahara sagte in IoB web page nicht erreichbar Update Admin adapter:
    Pending Updates: 36
    übersehen
      @Thomas-Braun
      ooops!
      Hatte diese
      Pending Updates: 36
      übersehen
      Heute kam auch der aktuelle LTS-Kernel per update rein:
      Linux chet 6.12.20+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.20-1+rpt1~bpo12+1 (2025-03-19) aarch64 GNU/Linux
      Wichtig.
        @takahara
        Zuvor würde ich die Basis noch aktualisieren.
        iob stop
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        Takahara
        @thomas-braun : Primar :) Hat funktioniert. Vielen Dank nochmals für deine / eure Unterstützung.
        • T Takahara
          @takahara
          Wo stehst du denn jetzt mit dem Ding?
          • T Takahara
            ich habe gestern den Admin Adapters (7.6.3) aktualisiert. Komme jetzt aber nicht mehr auf den IoBroker XX.XX.XX.XX:8081.
            Über Putty komme ich noch auf den Raspberry und kann leider mit dem Befehl "sudo iobroker start web.0" den Service nicht starten.
            "for security reasons iobroker should not be run or administrated as root"
            kann mir jemand helfen, den Web-Zugriff auf den IoBroker wieder herzustellen?
            Vielen Dank
            legro
            schrieb am zuletzt editiert von legro
            @takahara
            Auch ich habe ähnliche Erfahrungen nach dem Update des Admin-Adapters gemacht. Anders als bei dir sollte jedoch mein System auf aktuellem Stand sein.
            Ich rettete mich in diesen Situationen mit einem Neustart des Safari-Browsers auf meinem MacBook. Irgendwie vermag ich das Ganze wohl noch nicht so richtig einzuschätzen. Nun werde ich ebenfalls einmal alle hier vorgeschlagenen Schritte durchführen. Ich habe bisher upgrade anstelle von full-upgrade verwendet.
            Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
            • L legro
              @takahara
              @legro
              Mit solchen allgemeinen Aussagen kann man nichts anfangen. Schau dir an, ob die Dienste laufen, ob die per SSL abgesichert sind, auf welchem Port die lauschen usw.
              Das und noch mehr steht alles in
              iob diag
              drin
              L 2 Antworten Letzte Antwort
                @legro
                iob diag
                drin
                legro
                @thomas-braun sagte in IoB web page nicht erreichbar Update Admin adapter:
                Mit solchen allgemeinen Aussagen kann man nichts anfangen. ..
                Stimmt. Aber wenn ich‘s genauer eingrenzen könnte, hätte ich es auch getan.
                iob diag zeigt keine Auffälligkeiten. Auch wurde mittels der Option full-upgrade nichts nachträglich installiert.
                Da dieses seltsame und seltene Verhalten nach dem Update auftrat, hatte ich die Hoffnung, hier Ideen für eine Lösung zu finden. Aber es scheint wohl bei mir etwas mit dem Safari Browser auf dem MacBook zu tun zu haben: Wenn der Admin Adapter auf dem MacBook sich nicht zeigt, kann ich mittels Aufruf vom iPad aus oder Neustarten von Safari das Problem beheben. Einfach bloß seltsam.😕
                I 1 Antwort Letzte Antwort
                • L legro
                  I Offline
                  I Offline
                  ichwersonst
                  Ich würde mich hier mal mit einreihen und folgendes Problem schildern:
                  Ich bin im Iobroker angemeldet und es vergehen ein paar Stunden ohne das ich was mache.
                  Wenn ich dann wieder was machen will, z.B. das Menü wechseln, geht es nicht, da er die ganze Zeit einfach nur lädt.
                  Wenn ich das Webinterface schließe und wieder darauf zugreifen will, lädt dann der Intro Tab ewig ohne das was passiert.
                  Könnt ihr mir dabei helfen?
                  • I ichwersonst
                    @ichwersonst sagte in IoB web page nicht erreichbar Update Admin adapter:
                    Nein.
                    Gib die Ausgabe von
                    iob diag
                    in der Langfassung bekannt.
                      Nein.
                      Gib die Ausgabe von
                      iob diag
                      I Offline
                      I Offline
                      ichwersonst
                      ```bash
                      Script v.2025-02-23
                      *** BASE SYSTEM ***
                       Static hostname: RaspberryPV
                             Icon name: computer
                                Kernel: Linux 6.6.74+rpt-rpi-v8
                          Architecture: arm64
                      OS is similar to:
                      Model           : Raspberry Pi 4 Model B Rev 1.5
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                       10:23:13 up 2 days, 31 min,  3 users,  load average: 0.31, 0.21, 0.18
                      CPU threads: 4
                      Current issues:
                                     Local time: Thu 2025-04-03 10:23:13 CEST
                                 Universal time: Thu 2025-04-03 08:23:13 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      wib
                      HOME=/home/wib
                      GROUPS=wib adm dialout cdrom sudo audio video plugdev games users input render n        etdev gpio i2c spi iobroker
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            4.0G        795M        1.9G        1.3M        1.4G        3.2G
                      Swap:           536M          0B        536M
                      Total:          4.5G        795M        2.4G
                      Active iob-Instances:   6
                               3790 M total memory
                                758 M used memory
                                802 M active memory
                                947 M inactive memory
                               1811 M free memory
                                162 M buffer memory
                               1135 M swap cache
                                511 M total swap
                                  0 M used swap
                                511 M free swap
                      top - 10:23:14 up 2 days, 31 min,  3 users,  load average: 0.31, 0.21, 0.18
                      Tasks: 169 total,   1 running, 168 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  0.0 us, 14.3 sy,  0.0 ni, 71.4 id, 14.3 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   3790.9 total,   1810.1 free,    759.4 used,   1298.4 buff/cache
                      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3031.5 avail Mem
                      No critical errors detected
                      *** FILESYSTEM ***
                      udev           devtmpfs  1.6G     0  1.6G   0% /dev
                      tmpfs          tmpfs     380M  1.3M  378M   1% /run
                      /dev/sda2      ext4       56G  7.3G   46G  14% /
                      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                      /dev/sda1      vfat      510M   56M  455M  11% /boot/firmware
                      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                      /                /dev/sda2 ext4   rw,noatime
                      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437        ,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      1.7G    /var/
                      715M    /var/log/journal/952349f4f3da4e138b5320ebf14f2a46
                      715M    /var/log
                      271M    /var/cache
                      Archived and active journals take up 714.1M in the file system.
                      62M     /opt/iobroker/backups/
                      768M    /opt/iobroker/iobroker-data/
                      717M    /opt/iobroker/iobroker-data/files
                      24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.j        s.map
                      9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.j        s
                      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb        0.chunk.js.map
                      8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae        1.chunk.js.map
                      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34        a.chunk.js.map
                      USB-Devices by-id:
                      USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/nodejs         v20.19.0
                      /usr/bin/node           v20.19.0
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      /usr/bin/corepack       0.31.0
                      nodejs:
                        Installed: 20.19.0-1nodesource1
                        Version table:
                       *** 20.19.0-1nodesource1 1001
                              500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      RaspberryPV         RaspberryPV (version: 7.0.6, hostname: RaspberryPV   , alive, uptime: 99371)
                      js-controller:  7.0.6
                      admin:          7.6.3
                      javascript:     8.8.3
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : RaspberryPV                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.backitup.0               : backitup              : RaspberryPV                              -  enabled
                      + system.adapter.javascript.0             : javascript            : RaspberryPV                              -  enabled
                        system.adapter.modbus.0                 : modbus                : RaspberryPV                              - disabled
                        system.adapter.modbus.1                 : modbus                : RaspberryPV                              - disabled
                        system.adapter.modbus.2                 : modbus                : RaspberryPV                              - disabled
                        system.adapter.modbus.3                 : modbus                : RaspberryPV                              - disabled
                        system.adapter.ping.0                   : ping                  : RaspberryPV                              - disabled
                      + system.adapter.rpi2.0                   : rpi2                  : RaspberryPV                              -  enabled
                      + system.adapter.web.0                    : web                   : RaspberryPV                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + instance is alive
                      Adapter    "admin"        : 7.6.3    , installed 7.6.3
                      Controller "js-controller": 7.0.6    , installed 7.0.6
                      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                      Adapter    "rpi2"         : 2.3.1    , installed 2.3.1
                      Adapter    "web"          : 7.0.8    , installed 7.0.8
                      Objects and States
                      Objects:        630
                      States:         470
                      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Get:6 https://pkgs.tailscale.com/stable/debian bookworm InRelease
                      Fetched 6581 B in 1s (4879 B/s)
                      Pending Updates: 0
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       306438     56308/iobroker.js-c
                      tcp        0      0 100.71.28.54:35475      0.0.0.0:*               LISTEN      0          315720     63047/tailscaled
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       306433     56308/iobroker.js-c
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4858       585/sshd: /usr/sbin
                      tcp6       0      0 :::37541                :::*                    LISTEN      1001       682313     56382/io.backitup.0
                      tcp6       0      0 fd7a:115c:a1e0::d:52087 :::*                    LISTEN      0          315724     63047/tailscaled
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          4860       585/sshd: /usr/sbin
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       305694     56326/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       322619     68840/io.web.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2930       454/avahi-daemon: r
                      udp        0      0 0.0.0.0:41641           0.0.0.0:*                           0          637048     63047/tailscaled
                      udp        0      0 0.0.0.0:45779           0.0.0.0:*                           104        2932       454/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                104        2931       454/avahi-daemon: r
                      udp6       0      0 :::38177                :::*                                104        2933       454/avahi-daemon: r
                      udp6       0      0 :::41641                :::*                                0          637047     63047/tailscaled
                      2025-04-03 01:47:04.762  - info: host.RaspberryPV Delete log file iobroker.2025-03-26.log.gz
                      2025-04-03 01:47:04.780  - error: host.RaspberryPV Cannot delete file "/opt/iobroker/log/iobroker.2025-03-26.log.gz": Error: ENOENT: no such file or directory, unlink '/opt/iobroker/log/iobroker.2025-03-26.log.gz'
                      2025-04-03 06:47:10.853  - info: admin.0 (56326) Adapter rating updated
                      2025-04-03 07:03:34.573  - error: admin.0 (56326) socket.io [init] Cannot detect user
                      2025-04-03 07:05:33.116  - info: admin.0 (56326) ==> Connected system.user.admin from ::ffff:192.168.50.250
                      2025-04-03 09:42:13.773  - info: admin.0 (56326) ==> Connected system.user.admin from ::ffff:192.168.50.250
                      2025-04-03 09:43:32.158  - info: admin.0 (56326) <== Disconnect system.user.admin from ::ffff:192.168.50.250 backitup
                        @legro
                        iob diag
                        drin
                        legro
                        Mühsam ernährt sich das Eichhörnchen.😖
                        Ich habe in der Zwischenzeit fleißig getestet ..
                        Wenn ich die Website mit dem Admin-Adapters auf dem MacBook offen lasse, so wird vermutlich irgendwann einmal die sog. Session-Key ungültig. Im Gegensatz zum alten Admin-Adapter genügte ein Neuladen der Seite und diese erschien wieder - ggf. musste man sich zusätzlich neu anmelden. Dies ist nun nicht mehr der Fall. Safari meldet, dass der Server nicht (mehr) erreichbar sei.
                        Obwohl sich der Admin-Adapter mit dieser Fehlermeldung nicht mehr aufrufen lässt, kann man sehr wohl noch die VIS aufrufen. Alles damit verbundene funktioniert nach wie vor.
                        Zwei Methoden helfen ..
                        • Ich rufe die Seite von einem zweiten Gerät (z.B. iPad) ab, dann funktioniert i.d.R. auch wieder ein Aufruf auf dem MacBook.
                        • Ich beende Safari auf dem MacBook komplett. Nach dem Neustart von Safari geht die Verbindung zum Admin-Adapter wieder.
                        Nachdem ich nun weiß, wie ich damit umgehen muss, ist für mich alles wieder gut.🙂
                        CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
                        • L legro
                          CodierknechtC Offline
                          Codierknecht
                          @legro sagte in IoB web page nicht erreichbar Update Admin adapter:
                          Oder Methode 3: Ohne Login arbeiten ;-)
                          HmIP|ZigBee|Tasmota|Unifi
                          Zabbix Certified Specialist
                          • L legro
                            @legro
                            Das ist aber kein Bug, das ist das durch die Absicherung der Verbindung geforderte und erwartete Verhalten.
                              @legro
                              I Offline
                              I Offline
                              ichwersonst
                              Konnte jemand anhand meiner iob diag Ausgabe etwas erkennen, warum ich nach einer Zeit nicht mehr im Webinterface agieren kann?
                              • I ichwersonst
                                @ichwersonst
                                Da steht nichts auffälliges drin.
                                  @ichwersonst
                                  I Offline
                                  I Offline
                                  ichwersonst
                                  Was ist mit dem Fehler gemeint bzw. wie entsteht er?
                                  admin.0 2025-04-07 06:27:34.308	error	socket.io [init] Cannot detect user
                                  Vielleicht hat es ja etwas damit zutun
                                  Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
                                  • I ichwersonst
                                    Weiß ich nicht. Hab ich auf meinen Systemen auch nicht.
                                    Allerdings fahre ich auch keine verschlüsselten Kisten.
                                      I Offline
                                      I Offline
                                      ichwersonst
                                      Ich fahre eine verschlüsselte Kiste? Was ist denn an meiner Kiste verschlüsselt? Wo ließt du das raus?
                                      Socket.io ist automatisch installiert. Jedenfalls hab ich das nicht selber installiert.
                                      • I ichwersonst
                                        @ichwersonst
                                        Hab ich mit was anderem verwechselt. Ich dachte du hättest da eine SSL-Verschlüsselung am Start.
                                        • I ichwersonst
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          @ichwersonst said in IoB web page nicht erreichbar Update Admin adapter:
                                          Kann ignoriert werden (= nur optisches Problem).
                                          Ist mit admin 7.6.4 behoben.
                                          https://github.com/ioBroker/ioBroker.admin/issues/3030
                                          Support Repositoryverwaltung.
                                          LESEN - gute Forenbeitrage
