  4. IoB web page nicht erreichbar Update Admin adapter
46 Beiträge 9 Kommentatoren 6.2k Aufrufe 7 Beobachtet
  • T Takahara
    @homoran : Danke dir.
    Kannst du mir sagen, was ich machen soll?
    Den js-controller updaten?
    @takahara würde ich mit anfangen, und dann nochmal den admin
      Takahara
      @homoran : wäre es in Ordnung, wenn du mir die Befehle unten auflisten kannst?
      Vielen Dank für deine Unterstützung!
      • T Takahara
        @Takahara
        erst einmal den controller
        iob stop
        iob update
        iob upgrade self
        iob start
        einzeln nacheinander eingeben
        • T Takahara
          @takahara
          Zuvor würde ich die Basis noch aktualisieren.
          iob stop
          sudo apt update
          sudo apt full-upgrade
          sudo reboot
          • T Takahara
            @homoran ```
            Script v.2025-02-23
            *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer
                      Kernel: Linux 6.6.74+rpt-rpi-2712
                Architecture: arm64
            OS is similar to:
            Model           : Raspberry Pi 5 Model B Rev 1.0
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 64 bit
            Systemuptime and Load:
             18:57:05 up 1 day,  1:54,  2 users,  load average: 0.03, 0.02, 0.02
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Operating System is the current Debian stable version codenamed 'bookworm'!
            *** RASPBERRY THROTTLING ***
            Current issues:
            ~ Under-voltage detected
            ~ Arm frequency capped
            Previously detected issues:
            ~ Under-voltage has occurred
            ~ Arm frequency capping has occurred
            *** TIME AND TIMEZONES ***
                           Local time: Mon 2025-03-31 18:57:05 CEST
                       Universal time: Mon 2025-03-31 16:57:05 UTC
                             RTC time: Mon 2025-03-31 16:57:05
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            pi
            HOME=/home/pi
            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            iobroker
            HOME=/home/iobroker
            *** DISPLAY-SERVER SETUP ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            8.4G        995M        6.2G        5.5M        1.3G        7.4G
            Swap:           536M          0B        536M
            Total:          9.0G        995M        6.8G
            Active iob-Instances:   9
                     8052 M total memory
                      949 M used memory
                     1095 M active memory
                      793 M inactive memory
                     5935 M free memory
                      126 M buffer memory
                     1142 M swap cache
                      511 M total swap
                        0 M used swap
                      511 M free swap
            top - 18:57:05 up 1 day,  1:54,  2 users,  load average: 0.11, 0.03, 0.02
            Tasks: 165 total,   2 running, 163 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   8052.2 total,   5935.6 free,    949.9 used,   1268.9 buff/cache
            MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7102.4 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            1 CRITICAL ERRORS DETECTED!
            Check 'sudo dmesg --level=emerg,alert,crit -T' for details
            *** FILESYSTEM ***
            udev           devtmpfs  3.9G     0  3.9G   0% /dev
            tmpfs          tmpfs     806M  5.2M  801M   1% /run
            /dev/mmcblk0p2 ext4      117G  9.2G  102G   9% /
            tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
            tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
            /dev/mmcblk0p1 vfat      510M   55M  456M  11% /boot/firmware
            tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
            [Sun Mar 30 17:02:30 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:66:EC:20 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=f9e3762a-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Sun Mar 30 17:02:35 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
            [Sun Mar 30 17:02:36 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
            Show mounted filesystems:
            TARGET           SOURCE         FSTYPE OPTIONS
            /                /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            4.0G    /var/
            2.8G    /var/log/journal/a787909f1af9441ba59c4ccec33e25d4
            2.8G    /var/log
            437M    /var/lib
            Archived and active journals take up 2.7G in the file system.
            /opt/iobroker/backups:
            19M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            696M    /opt/iobroker/iobroker-data/
            644M    /opt/iobroker/iobroker-data/files
            617M    /opt/iobroker/iobroker-data/files/javascript.admin
            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
            8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
            7.0M    /opt/iobroker/iobroker-data/objects.jsonl
            7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
            7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.7e9d7842.chunk.js.map
            USB-Devices by-id:
            No Devices found 'by-id'
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.18.3
            /usr/bin/node           v20.18.3
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.30.0
            nodejs:
              Installed: 20.18.3-1nodesource1
              Candidate: 20.19.0-1nodesource1
              Version table:
                 20.19.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
             *** 20.18.3-1nodesource1 1001
                 20.18.2-1nodesource1 1001
                 20.18.1-1nodesource1 1001
                 20.18.0-1nodesource1 1001
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 18.19.0+dfsg-6~deb12u2 500
                    500 http://deb.debian.org/debian bookworm/main arm64 Packages
                 18.19.0+dfsg-6~deb12u1 500
                    500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 1367)
            Core adapters versions
            js-controller:  6.0.11
            admin:          "admin" not found
            javascript:     8.8.3
            nodejs modules from github:     0
            Adapter State
              system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
              system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Adapters
            Used repository: stable
            Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common//../node_modules/iobroker.admin/io-package.json: /opt/iobroker/node_modules/iobroker.admin/package.json: Unexpected end of JSON input
            Adapter    "backitup"     : 3.0.31   , installed 3.0.31
            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
            Controller "js-controller": 7.0.6    , installed 6.0.11 [Updatable]
            Adapter    "shelly"       : 8.5.1    , installed 8.5.1
            Adapter    "telegram"     : 4.0.0    , installed 4.0.0
            Objects and States
            Objects:        1887
            States:         1411
            Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
            Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
            Hit:4 https://repos.influxdata.com/debian stable InRelease
            Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists...
            Pending Updates: 36
            *** Listening Ports ***
            tcp        0      0 192.168.178.188:2001    0.0.0.0:*               LISTEN      1001       541872     9091/io.hm-rpc.0
            tcp        0      0 192.168.178.188:2010    0.0.0.0:*               LISTEN      1001       541289     9121/io.hm-rpc.1
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2976       655/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       541059     9013/iobroker.js-co
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       541064     9013/iobroker.js-co
            tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       539600     9076/io.shelly.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          2978       655/sshd: /usr/sbin
            tcp6       0      0 :::3000                 :::*                    LISTEN      106        6203       770/grafana
            tcp6       0      0 :::8086                 :::*                    LISTEN      999        6179       709/influxd
            udp        0      0 0.0.0.0:35230           0.0.0.0:*                           104        4899       529/avahi-daemon: r
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4897       529/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                104        4898       529/avahi-daemon: r
            udp6       0      0 :::59283                :::*                                104        4900       529/avahi-daemon: r
            2025-03-31 18:57:42.338  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.memHeapUsed:{"val":49.39,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
            2025-03-31 18:57:42.339  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.load:{"val":0.37,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
            2025-03-31 18:57:42.339  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.uptime:{"val":1412,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
            2025-03-31 18:57:42.339  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.mem:{"val":13,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440247335}
            2025-03-31 18:57:42.340  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.freemem:{"val":7022,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
            2025-03-31 18:57:42.340  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.memAvailable:{"val":7364,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
            2025-03-31 18:57:42.340  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.inputCount:{"val":9,"ack":true,"ts":1743440262334,"q":0,"from":"system.host.iobroker","lc":1743440262334}
            2025-03-31 18:57:42.340  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.outputCount:{"val":13,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1743440082335}
            2025-03-31 18:57:42.341  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.eventLoopLag:{"val":1,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1743440262335}
            2025-03-31 18:57:42.341  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.compactgroupProcesses:{"val":0,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1732122139005}
            2025-03-31 18:57:42.346  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.instancesAsProcess:{"val":8,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1743438882325}
            2025-03-31 18:57:42.346  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.instancesAsCompact:{"val":0,"ack":true,"ts":1743440262335,"q":0,"from":"system.host.iobroker","lc":1732122139005}
            2025-03-31 18:57:42.346  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.cpu:{"val":2.13,"ack":true,"ts":1743440262344,"q":0,"from":"system.host.iobroker","lc":1743440262344}
            2025-03-31 18:57:42.346  - silly: influxdb.0 (9046) States user redis pmessage */system.host.iobroker.cputime:{"val":26.96,"ack":true,"ts":1743440262344,"q":0,"from":"system.host.iobroker","lc":1743440262344}
            2025-03-31 18:57:42.586  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.alive:{"val":true,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743438882553,"expire":true}
            2025-03-31 18:57:42.586  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.connected:{"val":true,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743438882553,"expire":true}
            2025-03-31 18:57:42.587  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.memRss:{"val":69.42,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743440217584,"expire":true}
            2025-03-31 18:57:42.587  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.memHeapTotal:{"val":23.19,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743439077547,"expire":true}
            2025-03-31 18:57:42.588  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.memHeapUsed:{"val":21.25,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743440262585,"expire":true}
            2025-03-31 18:57:42.588  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.eventLoopLag:{"val":2,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743440217584,"expire":true}
            2025-03-31 18:57:42.589  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.uptime:{"val":1382,"ack":true,"ts":1743440262585,"q":0,"from":"system.adapter.discovery.0","lc":1743440262585,"expire":true}
            2025-03-31 18:57:42.590  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.inputCount:{"val":0,"ack":true,"ts":1743440262588,"q":0,"from":"system.adapter.discovery.0","lc":1743438912542,"expire":true}
            2025-03-31 18:57:42.590  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.outputCount:{"val":11,"ack":true,"ts":1743440262589,"q":0,"from":"system.adapter.discovery.0","lc":1743438912542,"expire":true}
            2025-03-31 18:57:42.593  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.cpu:{"val":0.07,"ack":true,"ts":1743440262592,"q":0,"from":"system.adapter.discovery.0","lc":1743440262592,"expire":true}
            2025-03-31 18:57:42.594  - silly: influxdb.0 (9046) States user redis pmessage */system.adapter.discovery.0.cputime:{"val":2.99,"ack":true,"ts":1743440262592,"q":0,"from":"system.adapter.discovery.0","lc":1743440262592,"expire":true}
            iob diag has finished.
            Press any key for a summary
            @Thomas-Braun
            ooops!
            Hatte ich schon geschrieben und wieder gelöscht.
            Hatte diese
            @takahara sagte in IoB web page nicht erreichbar Update Admin adapter:
            Pending Updates: 36
            übersehen
              @Thomas-Braun
              ooops!
              Hatte diese
              Pending Updates: 36
              übersehen
              Heute kam auch der aktuelle LTS-Kernel per update rein:
              Linux chet 6.12.20+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.20-1+rpt1~bpo12+1 (2025-03-19) aarch64 GNU/Linux
              Wichtig.
                @takahara
                iob stop
                sudo apt update
                sudo reboot
                Takahara
                @thomas-braun : Primar :) Hat funktioniert. Vielen Dank nochmals für deine / eure Unterstützung.
                • T Takahara
                  @takahara
                  Wo stehst du denn jetzt mit dem Ding?
                  • T Takahara
                    ich habe gestern den Admin Adapters (7.6.3) aktualisiert. Komme jetzt aber nicht mehr auf den IoBroker XX.XX.XX.XX:8081.
                    Über Putty komme ich noch auf den Raspberry und kann leider mit dem Befehl "sudo iobroker start web.0" den Service nicht starten.
                    "for security reasons iobroker should not be run or administrated as root"
                    kann mir jemand helfen, den Web-Zugriff auf den IoBroker wieder herzustellen?
                    Vielen Dank
                    legro
                    schrieb am zuletzt editiert von legro
                    @takahara
                    Auch ich habe ähnliche Erfahrungen nach dem Update des Admin-Adapters gemacht. Anders als bei dir sollte jedoch mein System auf aktuellem Stand sein.
                    Ich rettete mich in diesen Situationen mit einem Neustart des Safari-Browsers auf meinem MacBook. Irgendwie vermag ich das Ganze wohl noch nicht so richtig einzuschätzen. Nun werde ich ebenfalls einmal alle hier vorgeschlagenen Schritte durchführen. Ich habe bisher upgrade anstelle von full-upgrade verwendet.
                    Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
                    • L legro
                      @takahara
                      @legro
                      Mit solchen allgemeinen Aussagen kann man nichts anfangen. Schau dir an, ob die Dienste laufen, ob die per SSL abgesichert sind, auf welchem Port die lauschen usw.
                      Das und noch mehr steht alles in
                      iob diag
                      drin
                      L 2 Antworten Letzte Antwort
                        @legro
                        iob diag
                        drin
                        legro
                        @thomas-braun sagte in IoB web page nicht erreichbar Update Admin adapter:
                        Mit solchen allgemeinen Aussagen kann man nichts anfangen. ..
                        Stimmt. Aber wenn ich‘s genauer eingrenzen könnte, hätte ich es auch getan.
                        iob diag zeigt keine Auffälligkeiten. Auch wurde mittels der Option full-upgrade nichts nachträglich installiert.
                        Da dieses seltsame und seltene Verhalten nach dem Update auftrat, hatte ich die Hoffnung, hier Ideen für eine Lösung zu finden. Aber es scheint wohl bei mir etwas mit dem Safari Browser auf dem MacBook zu tun zu haben: Wenn der Admin Adapter auf dem MacBook sich nicht zeigt, kann ich mittels Aufruf vom iPad aus oder Neustarten von Safari das Problem beheben. Einfach bloß seltsam.😕
                        I 1 Antwort Letzte Antwort
                        • L legro
                          I Offline
                          I Offline
                          ichwersonst
                          Ich würde mich hier mal mit einreihen und folgendes Problem schildern:
                          Ich bin im Iobroker angemeldet und es vergehen ein paar Stunden ohne das ich was mache.
                          Wenn ich dann wieder was machen will, z.B. das Menü wechseln, geht es nicht, da er die ganze Zeit einfach nur lädt.
                          Wenn ich das Webinterface schließe und wieder darauf zugreifen will, lädt dann der Intro Tab ewig ohne das was passiert.
                          Könnt ihr mir dabei helfen?
                          • I ichwersonst
                            @ichwersonst sagte in IoB web page nicht erreichbar Update Admin adapter:
                            Nein.
                            Gib die Ausgabe von
                            iob diag
                            in der Langfassung bekannt.
                              Nein.
                              Gib die Ausgabe von
                              iob diag
                              I Offline
                              I Offline
                              ichwersonst
                              ```bash
                              Script v.2025-02-23
                              *** BASE SYSTEM ***
                               Static hostname: RaspberryPV
                                     Icon name: computer
                                        Kernel: Linux 6.6.74+rpt-rpi-v8
                                  Architecture: arm64
                              OS is similar to:
                              Model           : Raspberry Pi 4 Model B Rev 1.5
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 64 bit
                               10:23:13 up 2 days, 31 min,  3 users,  load average: 0.31, 0.21, 0.18
                              CPU threads: 4
                              Current issues:
                                             Local time: Thu 2025-04-03 10:23:13 CEST
                                         Universal time: Thu 2025-04-03 08:23:13 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              wib
                              HOME=/home/wib
                              GROUPS=wib adm dialout cdrom sudo audio video plugdev games users input render n        etdev gpio i2c spi iobroker
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            4.0G        795M        1.9G        1.3M        1.4G        3.2G
                              Swap:           536M          0B        536M
                              Total:          4.5G        795M        2.4G
                              Active iob-Instances:   6
                                       3790 M total memory
                                        758 M used memory
                                        802 M active memory
                                        947 M inactive memory
                                       1811 M free memory
                                        162 M buffer memory
                                       1135 M swap cache
                                        511 M total swap
                                          0 M used swap
                                        511 M free swap
                              top - 10:23:14 up 2 days, 31 min,  3 users,  load average: 0.31, 0.21, 0.18
                              Tasks: 169 total,   1 running, 168 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  0.0 us, 14.3 sy,  0.0 ni, 71.4 id, 14.3 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   3790.9 total,   1810.1 free,    759.4 used,   1298.4 buff/cache
                              MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3031.5 avail Mem
                              No critical errors detected
                              *** FILESYSTEM ***
                              udev           devtmpfs  1.6G     0  1.6G   0% /dev
                              tmpfs          tmpfs     380M  1.3M  378M   1% /run
                              /dev/sda2      ext4       56G  7.3G   46G  14% /
                              tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                              /dev/sda1      vfat      510M   56M  455M  11% /boot/firmware
                              tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                              /                /dev/sda2 ext4   rw,noatime
                              `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437        ,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              1.7G    /var/
                              715M    /var/log/journal/952349f4f3da4e138b5320ebf14f2a46
                              715M    /var/log
                              271M    /var/cache
                              Archived and active journals take up 714.1M in the file system.
                              62M     /opt/iobroker/backups/
                              768M    /opt/iobroker/iobroker-data/
                              717M    /opt/iobroker/iobroker-data/files
                              24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.j        s.map
                              9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.j        s
                              8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb        0.chunk.js.map
                              8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae        1.chunk.js.map
                              7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34        a.chunk.js.map
                              USB-Devices by-id:
                              USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/nodejs         v20.19.0
                              /usr/bin/node           v20.19.0
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              /usr/bin/corepack       0.31.0
                              nodejs:
                                Installed: 20.19.0-1nodesource1
                                Version table:
                               *** 20.19.0-1nodesource1 1001
                                      500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              RaspberryPV         RaspberryPV (version: 7.0.6, hostname: RaspberryPV   , alive, uptime: 99371)
                              js-controller:  7.0.6
                              admin:          7.6.3
                              javascript:     8.8.3
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : RaspberryPV                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.backitup.0               : backitup              : RaspberryPV                              -  enabled
                              + system.adapter.javascript.0             : javascript            : RaspberryPV                              -  enabled
                                system.adapter.modbus.0                 : modbus                : RaspberryPV                              - disabled
                                system.adapter.modbus.1                 : modbus                : RaspberryPV                              - disabled
                                system.adapter.modbus.2                 : modbus                : RaspberryPV                              - disabled
                                system.adapter.modbus.3                 : modbus                : RaspberryPV                              - disabled
                                system.adapter.ping.0                   : ping                  : RaspberryPV                              - disabled
                              + system.adapter.rpi2.0                   : rpi2                  : RaspberryPV                              -  enabled
                              + system.adapter.web.0                    : web                   : RaspberryPV                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + instance is alive
                              Adapter    "admin"        : 7.6.3    , installed 7.6.3
                              Controller "js-controller": 7.0.6    , installed 7.0.6
                              Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                              Adapter    "rpi2"         : 2.3.1    , installed 2.3.1
                              Adapter    "web"          : 7.0.8    , installed 7.0.8
                              Objects and States
                              Objects:        630
                              States:         470
                              Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                              Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Get:6 https://pkgs.tailscale.com/stable/debian bookworm InRelease
                              Fetched 6581 B in 1s (4879 B/s)
                              Pending Updates: 0
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       306438     56308/iobroker.js-c
                              tcp        0      0 100.71.28.54:35475      0.0.0.0:*               LISTEN      0          315720     63047/tailscaled
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       306433     56308/iobroker.js-c
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4858       585/sshd: /usr/sbin
                              tcp6       0      0 :::37541                :::*                    LISTEN      1001       682313     56382/io.backitup.0
                              tcp6       0      0 fd7a:115c:a1e0::d:52087 :::*                    LISTEN      0          315724     63047/tailscaled
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          4860       585/sshd: /usr/sbin
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       305694     56326/io.admin.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       322619     68840/io.web.0
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2930       454/avahi-daemon: r
                              udp        0      0 0.0.0.0:41641           0.0.0.0:*                           0          637048     63047/tailscaled
                              udp        0      0 0.0.0.0:45779           0.0.0.0:*                           104        2932       454/avahi-daemon: r
                              udp6       0      0 :::5353                 :::*                                104        2931       454/avahi-daemon: r
                              udp6       0      0 :::38177                :::*                                104        2933       454/avahi-daemon: r
                              udp6       0      0 :::41641                :::*                                0          637047     63047/tailscaled
                              2025-04-03 01:47:04.762  - info: host.RaspberryPV Delete log file iobroker.2025-03-26.log.gz
                              2025-04-03 01:47:04.780  - error: host.RaspberryPV Cannot delete file "/opt/iobroker/log/iobroker.2025-03-26.log.gz": Error: ENOENT: no such file or directory, unlink '/opt/iobroker/log/iobroker.2025-03-26.log.gz'
                              2025-04-03 06:47:10.853  - info: admin.0 (56326) Adapter rating updated
                              2025-04-03 07:03:34.573  - error: admin.0 (56326) socket.io [init] Cannot detect user
                              2025-04-03 07:05:33.116  - info: admin.0 (56326) ==> Connected system.user.admin from ::ffff:192.168.50.250
                              2025-04-03 09:42:13.773  - info: admin.0 (56326) ==> Connected system.user.admin from ::ffff:192.168.50.250
                              2025-04-03 09:43:32.158  - info: admin.0 (56326) <== Disconnect system.user.admin from ::ffff:192.168.50.250 backitup
                                @legro
                                iob diag
                                drin
                                legro
                                Mühsam ernährt sich das Eichhörnchen.😖
                                Ich habe in der Zwischenzeit fleißig getestet ..
                                Wenn ich die Website mit dem Admin-Adapters auf dem MacBook offen lasse, so wird vermutlich irgendwann einmal die sog. Session-Key ungültig. Im Gegensatz zum alten Admin-Adapter genügte ein Neuladen der Seite und diese erschien wieder - ggf. musste man sich zusätzlich neu anmelden. Dies ist nun nicht mehr der Fall. Safari meldet, dass der Server nicht (mehr) erreichbar sei.
                                Obwohl sich der Admin-Adapter mit dieser Fehlermeldung nicht mehr aufrufen lässt, kann man sehr wohl noch die VIS aufrufen. Alles damit verbundene funktioniert nach wie vor.
                                Zwei Methoden helfen ..
                                • Ich rufe die Seite von einem zweiten Gerät (z.B. iPad) ab, dann funktioniert i.d.R. auch wieder ein Aufruf auf dem MacBook.
                                • Ich beende Safari auf dem MacBook komplett. Nach dem Neustart von Safari geht die Verbindung zum Admin-Adapter wieder.
                                Nachdem ich nun weiß, wie ich damit umgehen muss, ist für mich alles wieder gut.🙂
                                CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
                                • L legro
                                  CodierknechtC Offline
                                  Codierknecht
                                  @legro sagte in IoB web page nicht erreichbar Update Admin adapter:
                                  Oder Methode 3: Ohne Login arbeiten ;-)
                                  HmIP|ZigBee|Tasmota|Unifi
                                  Zabbix Certified Specialist
                                  • L legro
                                    @legro
                                    Das ist aber kein Bug, das ist das durch die Absicherung der Verbindung geforderte und erwartete Verhalten.
                                      @legro
                                      I Offline
                                      I Offline
                                      ichwersonst
                                      Konnte jemand anhand meiner iob diag Ausgabe etwas erkennen, warum ich nach einer Zeit nicht mehr im Webinterface agieren kann?
                                      • I ichwersonst
                                        @ichwersonst
                                        Da steht nichts auffälliges drin.
                                          @ichwersonst
                                          I Offline
                                          I Offline
                                          ichwersonst
                                          Was ist mit dem Fehler gemeint bzw. wie entsteht er?
                                          admin.0 2025-04-07 06:27:34.308	error	socket.io [init] Cannot detect user
                                          Vielleicht hat es ja etwas damit zutun
                                          Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
