  4. IoB web page nicht erreichbar Update Admin adapter
46 Beiträge 9 Kommentatoren 6.2k Aufrufe 7 Beobachtet
    @ichwersonst sagte in IoB web page nicht erreichbar Update Admin adapter:
    Könnt ihr mir dabei helfen?
    Nein.
    Gib die Ausgabe von
    iob diag
    in der Langfassung bekannt.
    I Offline
    I Offline
    ichwersonst
    ```bash
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: RaspberryPV
           Icon name: computer
              Kernel: Linux 6.6.74+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     10:23:13 up 2 days, 31 min,  3 users,  load average: 0.31, 0.21, 0.18
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2025-04-03 10:23:13 CEST
               Universal time: Thu 2025-04-03 08:23:13 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    wib
    HOME=/home/wib
    GROUPS=wib adm dialout cdrom sudo audio video plugdev games users input render n        etdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.0G        795M        1.9G        1.3M        1.4G        3.2G
    Swap:           536M          0B        536M
    Total:          4.5G        795M        2.4G
    Active iob-Instances:   6
             3790 M total memory
              758 M used memory
              802 M active memory
              947 M inactive memory
             1811 M free memory
              162 M buffer memory
             1135 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 10:23:14 up 2 days, 31 min,  3 users,  load average: 0.31, 0.21, 0.18
    Tasks: 169 total,   1 running, 168 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 14.3 sy,  0.0 ni, 71.4 id, 14.3 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3790.9 total,   1810.1 free,    759.4 used,   1298.4 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3031.5 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.3M  378M   1% /run
    /dev/sda2      ext4       56G  7.3G   46G  14% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   56M  455M  11% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437        ,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.7G    /var/
    715M    /var/log/journal/952349f4f3da4e138b5320ebf14f2a46
    715M    /var/log
    271M    /var/cache
    Archived and active journals take up 714.1M in the file system.
    /opt/iobroker/backups:
    62M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    768M    /opt/iobroker/iobroker-data/
    717M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.j        s.map
    9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.j        s
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb        0.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae        1.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34        a.chunk.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.0
    /usr/bin/node           v20.19.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.0-1nodesource1
      Candidate: 20.19.0-1nodesource1
      Version table:
     *** 20.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    RaspberryPV         RaspberryPV (version: 7.0.6, hostname: RaspberryPV   , alive, uptime: 99371)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.3
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : RaspberryPV                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : RaspberryPV                              -  enabled
    + system.adapter.javascript.0             : javascript            : RaspberryPV                              -  enabled
      system.adapter.modbus.0                 : modbus                : RaspberryPV                              - disabled
      system.adapter.modbus.1                 : modbus                : RaspberryPV                              - disabled
      system.adapter.modbus.2                 : modbus                : RaspberryPV                              - disabled
      system.adapter.modbus.3                 : modbus                : RaspberryPV                              - disabled
      system.adapter.ping.0                   : ping                  : RaspberryPV                              - disabled
    + system.adapter.rpi2.0                   : rpi2                  : RaspberryPV                              -  enabled
    + system.adapter.web.0                    : web                   : RaspberryPV                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.3    , installed 7.6.3
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "rpi2"         : 2.3.1    , installed 2.3.1
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Objects and States
    Objects:        630
    States:         470
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Get:6 https://pkgs.tailscale.com/stable/debian bookworm InRelease
    Fetched 6581 B in 1s (4879 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       306438     56308/iobroker.js-c
    tcp        0      0 100.71.28.54:35475      0.0.0.0:*               LISTEN      0          315720     63047/tailscaled
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       306433     56308/iobroker.js-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4858       585/sshd: /usr/sbin
    tcp6       0      0 :::37541                :::*                    LISTEN      1001       682313     56382/io.backitup.0
    tcp6       0      0 fd7a:115c:a1e0::d:52087 :::*                    LISTEN      0          315724     63047/tailscaled
    tcp6       0      0 :::22                   :::*                    LISTEN      0          4860       585/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       305694     56326/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       322619     68840/io.web.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2930       454/avahi-daemon: r
    udp        0      0 0.0.0.0:41641           0.0.0.0:*                           0          637048     63047/tailscaled
    udp        0      0 0.0.0.0:45779           0.0.0.0:*                           104        2932       454/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        2931       454/avahi-daemon: r
    udp6       0      0 :::38177                :::*                                104        2933       454/avahi-daemon: r
    udp6       0      0 :::41641                :::*                                0          637047     63047/tailscaled
    2025-04-03 01:47:04.762  - info: host.RaspberryPV Delete log file iobroker.2025-03-26.log.gz
    2025-04-03 01:47:04.780  - error: host.RaspberryPV Cannot delete file "/opt/iobroker/log/iobroker.2025-03-26.log.gz": Error: ENOENT: no such file or directory, unlink '/opt/iobroker/log/iobroker.2025-03-26.log.gz'
    2025-04-03 06:47:10.853  - info: admin.0 (56326) Adapter rating updated
    2025-04-03 07:03:34.573  - error: admin.0 (56326) socket.io [init] Cannot detect user
    2025-04-03 07:05:33.116  - info: admin.0 (56326) ==> Connected system.user.admin from ::ffff:192.168.50.250
    2025-04-03 09:42:13.773  - info: admin.0 (56326) ==> Connected system.user.admin from ::ffff:192.168.50.250
    2025-04-03 09:43:32.158  - info: admin.0 (56326) <== Disconnect system.user.admin from ::ffff:192.168.50.250 backitup
    iob diag has finished.
    Press any key for a summary
      @legro
      Mit solchen allgemeinen Aussagen kann man nichts anfangen. Schau dir an, ob die Dienste laufen, ob die per SSL abgesichert sind, auf welchem Port die lauschen usw.
      Das und noch mehr steht alles in
      iob diag
      drin
      legro
      schrieb am zuletzt editiert von legro
      Mühsam ernährt sich das Eichhörnchen.😖
      Ich habe in der Zwischenzeit fleißig getestet ..
      Wenn ich die Website mit dem Admin-Adapters auf dem MacBook offen lasse, so wird vermutlich irgendwann einmal die sog. Session-Key ungültig. Im Gegensatz zum alten Admin-Adapter genügte ein Neuladen der Seite und diese erschien wieder - ggf. musste man sich zusätzlich neu anmelden. Dies ist nun nicht mehr der Fall. Safari meldet, dass der Server nicht (mehr) erreichbar sei.
      Obwohl sich der Admin-Adapter mit dieser Fehlermeldung nicht mehr aufrufen lässt, kann man sehr wohl noch die VIS aufrufen. Alles damit verbundene funktioniert nach wie vor.
      Zwei Methoden helfen ..
      • Ich rufe die Seite von einem zweiten Gerät (z.B. iPad) ab, dann funktioniert i.d.R. auch wieder ein Aufruf auf dem MacBook.
      • Ich beende Safari auf dem MacBook komplett. Nach dem Neustart von Safari geht die Verbindung zum Admin-Adapter wieder.
      Nachdem ich nun weiß, wie ich damit umgehen muss, ist für mich alles wieder gut.🙂
      Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
      CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
      • L legro
        CodierknechtC Offline
        Codierknecht
        @legro sagte in IoB web page nicht erreichbar Update Admin adapter:
        Oder Methode 3: Ohne Login arbeiten ;-)
        HmIP|ZigBee|Tasmota|Unifi
        Zabbix Certified Specialist
        • L legro
          @legro
          Das ist aber kein Bug, das ist das durch die Absicherung der Verbindung geforderte und erwartete Verhalten.
          I 1 Antwort Letzte Antwort
            @legro
            I Offline
            I Offline
            ichwersonst
            Konnte jemand anhand meiner iob diag Ausgabe etwas erkennen, warum ich nach einer Zeit nicht mehr im Webinterface agieren kann?
            • I ichwersonst
              @ichwersonst
              Da steht nichts auffälliges drin.
                @ichwersonst
                I Offline
                I Offline
                ichwersonst
                Was ist mit dem Fehler gemeint bzw. wie entsteht er?
                admin.0 2025-04-07 06:27:34.308	error	socket.io [init] Cannot detect user
                Vielleicht hat es ja etwas damit zutun
                Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
                • I ichwersonst
                  Weiß ich nicht. Hab ich auf meinen Systemen auch nicht.
                  Allerdings fahre ich auch keine verschlüsselten Kisten.
                    I Offline
                    I Offline
                    ichwersonst
                    Ich fahre eine verschlüsselte Kiste? Was ist denn an meiner Kiste verschlüsselt? Wo ließt du das raus?
                    Socket.io ist automatisch installiert. Jedenfalls hab ich das nicht selber installiert.
                    • I ichwersonst
                      @ichwersonst
                      Hab ich mit was anderem verwechselt. Ich dachte du hättest da eine SSL-Verschlüsselung am Start.
                      • I ichwersonst
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        @ichwersonst said in IoB web page nicht erreichbar Update Admin adapter:
                        Kann ignoriert werden (= nur optisches Problem).
                        Ist mit admin 7.6.4 behoben.
                        https://github.com/ioBroker/ioBroker.admin/issues/3030
                        Support Repositoryverwaltung.
                        LESEN - gute Forenbeitrage
                        • mcm1957M mcm1957
                          I Offline
                          I Offline
                          ichwersonst
                          schrieb am zuletzt editiert von ichwersonst
                          @mcm1957
                          ich habe bereits 7.6.3 installiert, der Error kommt dennoch.
                          • I ichwersonst
                            @mcm1957
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            @ichwersonst
                            lies den letzten Beitrag bitte nochmals.
                            • mcm1957M mcm1957
                              @ichwersonst
                              I Offline
                              I Offline
                              ichwersonst
                              @mcm1957
                              hoppala 😂
