  3. Einsteigerfragen
  4. Zigbee kabelgebundene Geräte reagieren nicht
    5.4k
74 Beiträge 10 Kommentatoren 9.5k Aufrufe 7 Beobachtet
    @maxpd sagte in Zigbee kabelgebundene Geräte reagieren nicht:
    hat nichts gebracht. Der empfiehlt immer noch Version 18 ^^
    Dann ist deine Installation grundsätzlich schief.
    Versuch es per
    iob nodejs-update 20
    gerade zurücken.
    maxpd
    @thomas-braun geholfen hat's leider nicht.
    Hier auch mal noch das Debuglog, wenn ich den Status eines kabelgebunden Gerätes im Zigbee Interface ändere.
    zigbee.0
    2025-02-11 13:45:28.103	debug	target: {"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":16,"inputClusters":[4096,0,3,4,5,6,2820,64527],"outputClusters":[25],"profileID":49246,"ID":3,"clusters":{"genOnOff":{"attributes":{"onOff":1}},"genBasic":{"attributes":{"zclVersion":1}}},"deviceIeeeAddress":"0x7cb03eaa0a0c47ed","deviceNetworkAddress":40198,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa68bd","endpointID":1}],"_configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":3,"deviceIeeeAddress":"0x7cb03eaa0a0c47ed"}}
    zigbee.0
    2025-02-11 13:45:28.101	debug	entity: 0x7cb03eaa0a0c47ed AB3257001NJ {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":67,"_applicationVersion":9,"_dateCode":"20140331DEOS****","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":16,"inputClusters":[4096,0,3,4,5,6,2820,64527],"outputClusters":[25],"profileID":49246,"ID":3,"clusters":{"genOnOff":{"attributes":{"onOff":1}},"genBasic":{"attributes":{"zclVersion":1}}},"deviceIeeeAddress":"0x7cb03eaa0a0c47ed","deviceNetworkAddress":40198,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa68bd","endpointID":1}],"_configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":3,"deviceIeeeAddress":"0x7cb03eaa0a0c47ed"}}],"_hardwareVersion":1,"_ieeeAddr":"0x7cb03eaa0a0c47ed","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1739269392020,"_manufacturerID":48042,"_manufacturerName":"OSRAM","_modelID":"Plug 01","_networkAddress":40198,"_powerSource":"Mains (single phase)","_softwareBuildID":"V1.05.09","_stackVersion":2,"_type":"Router","_zclVersion":1,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":1}},"mapped":{"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"],"options":[{"name":"state_action","label":"State action","access":2,"type":"binary","property":"state_action","description":"State actions will also be published as 'action' when true (default false).","value_on":true,"value_off":false}]}],"exposes":[{"type":"switch","features":[{"name":"state","label":"State","access":7,"type":"binary","property":"state","description":"On/off state of the switch","value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"onEvent":null,"ota":{},"zigbeeModel":["Plug 01"],"model":"AB3257001NJ","description":"Smart+ plug","vendor":"OSRAM","whiteLabel":[{"vendor":"LEDVANCE","model":"AB3257001NJ"},{"vendor":"LEDVANCE","model":"AC03360"}],"options":["[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x7cb03eaa0a0c47ed"}
    zigbee.0
    2025-02-11 13:45:28.100	debug	publishFromState : 0x7cb03eaa0a0c47ed AB3257001NJ [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"value":false,"index":0,"timeout":0}]
    zigbee.0
    2025-02-11 13:45:28.096	debug	Change state 'state' at device 0x7cb03eaa0a0c47ed type 'AB3257001NJ'
    maxpd
    Raspi 4 8gb | iobroker + pivccu3 | 46 Adapter | 68 Scripte, 120 Devices
    • M maxpd
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      Heißt konkret?
      Meldungen?
      Ausgabe von
      iob diag
      Ausgabe von
      iob nodejs-update
        Heißt konkret?
        Meldungen?
        Ausgabe von
        iob diag
        Ausgabe von
        iob nodejs-update
        maxpd
        @thomas-braun ich ging von dem Zigbee Problem und der Anzeige der empfohlenen nodejs Version aus, die noch 18 ist. Ist vielleicht ein Anzeigefehler im Admin, denn mit deinem Befehl erkennt er die korrekte empfohlene Version.
        ioBroker nodejs fixer 2024-10-10
        Recommended nodejs-version is: 20.18.3
        Checking your installation now. Please be patient!
        Your current setup is:
        /usr/bin/nodejs         v20.18.3
        /usr/bin/node           v20.18.3
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.30.0
        We found these nodejs versions available for installation:
        nodejs:
          Installed: 20.18.3-1nodesource1
          Candidate: 20.18.3-1nodesource1
          Version table:
         *** 20.18.3-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                100 /var/lib/dpkg/status
             20.18.2-1nodesource1 1001
             20.18.1-1nodesource1 1001
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u5 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        Nothing to do - Your installation is using the correct paths.
        Nothing to do - Your version is the recommended one.
        ***You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands. ***
        *** DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation! ***
         *** DO NOT use 'nodejs-update' as part of a regular update process! ***
        iob diag
        ```bash
        Script v.2025-02-02
        *** BASE SYSTEM ***
           Static hostname: donbroker
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         14:11:34 up 39 min,  1 user,  load average: 1.04, 1.11, 1.11
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Tue 2025-02-11 14:11:34 CET
                   Universal time: Tue 2025-02-11 13:11:34 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pd
        HOME=/home/pd
        GROUPS=pd adm dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.8G        3.3G        3.5G        1.0M        992M        4.3G
        Swap:            99M          0B         99M
        Total:          7.9G        3.3G        3.6G
        Active iob-Instances:   53
                 7811 M total memory
                 3325 M used memory
                 3412 M active memory
                  659 M inactive memory
                 3493 M free memory
                  127 M buffer memory
                  864 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 14:11:34 up 39 min,  1 user,  load average: 1.04, 1.11, 1.11
        Tasks: 240 total,   2 running, 238 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 19.4 us,  5.6 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   7811.3 total,   3494.6 free,   3324.4 used,    992.3 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   4331.8 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        /dev/root      ext4      110G   12G   94G  11% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
        /dev/sda1      vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     782M  8.0K  782M   1% /run/user/1000
        [Tue Feb 11 13:32:08 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:57:31:D7 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=4e235c07-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Tue Feb 11 13:32:10 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Tue Feb 11 13:32:10 2025] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Tue Feb 11 13:32:11 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
        3.0G    /var/
        1.2G    /var/log/journal/44d2b021246e425b9ef7fe15da6bfb6b
        1.2G    /var/log
        894M    /var/cache
        Archived and active journals take up 1.1G in the file system.
        /opt/iobroker/backups:
        15M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.6G    /opt/iobroker/iobroker-data/
        1.1G    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        52M     /opt/iobroker/iobroker-data/objects.jsonl
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        32M     /opt/iobroker/iobroker-data/states.jsonl
        26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
        26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100F9Y-if03
        /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100F9Y-if00
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/ttyACM0
        *** NodeJS-Installation ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        donbroker           donbroker (version: 7.0.6, hostname: donbroker     , alive, uptime: 2357)
        Core adapters versions
        js-controller:  7.0.6
        admin:          7.4.10
        javascript:     8.8.3
        nodejs modules from github:     6
        +-- iobroker.ble@0.14.1 (git+ssh://git@github.com/AlCalzone/ioBroker.ble.git#f0dd1214a8482b2d60cbf48f642e2add12ece177)
        +-- iobroker.google-sharedlocations@2.2.1 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#0db73d57d00aa5dff22ff22e853f1231ce141dc1)
        +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
        +-- iobroker.govee@0.0.6 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#73ec80b6350890015d95428dd3bbd3f72417a073)
        +-- iobroker.motionblinds@0.3.0 (git+ssh://git@github.com/VBen/ioBroker.motionblinds.git#0967a7b127274ef06e0327585267c313339b3b10)
        | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
        Adapter State
        + system.adapter.admin.0                  : admin                 : donbroker                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.admin.1                  : admin                 : donbroker                                -  enabled, port: 8083, bind: 0.0.0.0 (SSL), run as: admin
          system.adapter.alias-manager.0          : alias-manager         : donbroker                                - disabled
        + system.adapter.backitup.0               : backitup              : donbroker                                -  enabled
        + system.adapter.ble.0                    : ble                   : donbroker                                -  enabled
        + system.adapter.chromecast.0             : chromecast            : donbroker                                -  enabled
          system.adapter.cloud.0                  : cloud                 : donbroker                                - disabled
          system.adapter.coronavirus-statistics.0 : coronavirus-statistics: donbroker                                -  enabled
        + system.adapter.daikin-cloud.0           : daikin-cloud          : donbroker                                -  enabled
          system.adapter.daikin.0                 : daikin                : donbroker                                - disabled
          system.adapter.daswetter.0              : daswetter             : donbroker                                -  enabled
        + system.adapter.denon.0                  : denon                 : donbroker                                -  enabled
          system.adapter.discovery.0              : discovery             : donbroker                                - disabled
        + system.adapter.doorbird.0               : doorbird              : donbroker                                -  enabled
        + system.adapter.echarts.0                : echarts               : donbroker                                -  enabled
          system.adapter.feiertage.0              : feiertage             : donbroker                                -  enabled
          system.adapter.flot.0                   : flot                  : donbroker                                - disabled
          system.adapter.go-e.0                   : go-e                  : donbroker                                - disabled
        + system.adapter.google-sharedlocations.0 : google-sharedlocations: donbroker                                -  enabled
          system.adapter.govee-app.0              : govee-app             : donbroker                                - disabled
          system.adapter.govee-local.0            : govee-local           : donbroker                                - disabled
        + system.adapter.govee.0                  : govee                 : donbroker                                -  enabled
        + system.adapter.hass.0                   : hass                  : donbroker                                -  enabled, port: 8123
        + system.adapter.history.0                : history               : donbroker                                -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : donbroker                                -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : donbroker                                -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : donbroker                                -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : donbroker                                -  enabled
        + system.adapter.influxdb.0               : influxdb              : donbroker                                -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : donbroker                                -  enabled
        + system.adapter.iot.0                    : iot                   : donbroker                                -  enabled
        + system.adapter.javascript.0             : javascript            : donbroker                                -  enabled
          system.adapter.lgtv.0                   : lgtv                  : donbroker                                - disabled
          system.adapter.lovelace.0               : lovelace              : donbroker                                - disabled, port: 8091, bind: 0.0.0.0, run as: admin
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : donbroker                                -  enabled, port: 54321
        + system.adapter.modbus.0                 : modbus                : donbroker                                -  enabled
        + system.adapter.modbus.1                 : modbus                : donbroker                                -  enabled
        + system.adapter.modbus.2                 : modbus                : donbroker                                -  enabled
        + system.adapter.motionblinds.0           : motionblinds          : donbroker                                -  enabled
        + system.adapter.mqtt-client.0            : mqtt-client           : donbroker                                -  enabled, port: 1884
          system.adapter.mqtt.0                   : mqtt                  : donbroker                                - disabled, port: 36669, bind: 192.168.178.30
          system.adapter.net-tools.0              : net-tools             : donbroker                                - disabled
        + system.adapter.ping.0                   : ping                  : donbroker                                -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : donbroker                                -  enabled
        + system.adapter.pvforecast.0             : pvforecast            : donbroker                                -  enabled
        + system.adapter.pvforecast.1             : pvforecast            : donbroker                                -  enabled
        + system.adapter.pvforecast.2             : pvforecast            : donbroker                                -  enabled
          system.adapter.radar2.0                 : radar2                : donbroker                                - disabled
        + system.adapter.roborock.0               : roborock              : donbroker                                -  enabled
          system.adapter.rpi2.0                   : rpi2                  : donbroker                                - disabled
        + system.adapter.sayit.0                  : sayit                 : donbroker                                -  enabled
        + system.adapter.sayit.1                  : sayit                 : donbroker                                -  enabled
        + system.adapter.sayit.2                  : sayit                 : donbroker                                -  enabled
        + system.adapter.sayit.3                  : sayit                 : donbroker                                -  enabled
        + system.adapter.sayit.4                  : sayit                 : donbroker                                -  enabled
          system.adapter.schoolfree.0             : schoolfree            : donbroker                                -  enabled
        + system.adapter.shelly.0                 : shelly                : donbroker                                -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : donbroker                                -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shuttercontrol.0         : shuttercontrol        : donbroker                                -  enabled
          system.adapter.simple-api.0             : simple-api            : donbroker                                - disabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.simple-api.1             : simple-api            : donbroker                                -  enabled, port: 8101, bind: 0.0.0.0, run as: admin
        + system.adapter.sma-em.0                 : sma-em                : donbroker                                -  enabled
        + system.adapter.sonoff.0                 : sonoff                : donbroker                                -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.spotify-premium.0        : spotify-premium       : donbroker                                - disabled
          system.adapter.synology.0               : synology              : donbroker                                - disabled, port: 5000
          system.adapter.synology.1               : synology              : donbroker                                - disabled, port: 5001
          system.adapter.systeminfo.0             : systeminfo            : donbroker                                - disabled
        + system.adapter.telegram.0               : telegram              : donbroker                                -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : donbroker                                -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.2               : telegram              : donbroker                                -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.terminal.0               : terminal              : donbroker                                - disabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.tr-064.0                 : tr-064                : donbroker                                -  enabled
        + system.adapter.tuya.0                   : tuya                  : donbroker                                -  enabled
        + system.adapter.web.0                    : web                   : donbroker                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : donbroker                                - disabled
        + system.adapter.wifilight.0              : wifilight             : donbroker                                -  enabled
        + system.adapter.wled.0                   : wled                  : donbroker                                -  enabled
          system.adapter.yeelight-2.0             : yeelight-2            : donbroker                                - disabled
        + system.adapter.zigbee.0                 : zigbee                : donbroker                                -  enabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.4.10   , installed 7.4.10
        Adapter    "alias-manager": 2.0.0    , installed 2.0.0
        Adapter    "backitup"     : 3.0.31   , installed 3.0.25 [Updatable]
        Adapter    "ble"          : 0.14.0   , installed 0.14.1
        Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
        Adapter    "cloud"        : 5.0.1    , installed 5.0.1
        Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
        Adapter    "daikin"       : 1.4.2    , installed 1.4.2
        Adapter    "daikin-cloud" : 0.4.11   , installed 0.4.11
        Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
        Adapter    "denon"        : 1.15.12  , installed 1.15.12
        Adapter    "doorbird"     : 2.0.0    , installed 2.0.0
        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
        Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
        Adapter    "go-e"         : 1.0.41   , installed 1.0.41
        Adapter    "govee-local"  : 0.2.7    , installed 0.2.7
        Adapter    "hass"         : 1.4.0    , installed 1.4.0
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "ical"         : 1.16.1   , installed 1.16.1
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "lgtv"         : 2.4.0    , installed 2.3.1  [Updatable]
        Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
        Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
        Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
        Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
        Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
        Adapter    "radar2"       : 2.2.0    , installed 2.2.0
        Adapter    "roborock"     : 0.6.18   , installed 0.6.18
        Adapter    "rpi2"         : 2.3.1    , installed 2.3.1
        Adapter    "sayit"        : 5.0.0    , installed 3.0.0  [Updatable]
        Adapter    "schoolfree"   : 1.1.7    , installed 1.1.6  [Updatable]
        Adapter    "shelly"       : 8.5.1    , installed 8.2.1  [Updatable]
        Adapter    "shuttercontrol": 1.8.5   , installed 1.8.5
        Adapter    "sma-em"       : 1.1.0    , installed 1.1.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
        Adapter    "spotify-premium": 1.5.2  , installed 1.5.0  [Updatable]
        Adapter    "synology"     : 3.1.0    , installed 3.1.0
        Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
        Adapter    "telegram"     : 4.0.0    , installed 3.9.0  [Updatable]
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
        Adapter    "wifilight"    : 1.2.2    , installed 1.2.2
        Adapter    "wled"         : 0.7.2    , installed 0.7.2
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
        Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
        Objects and States
        Objects:        25624
        States:         21191
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
        Reading package lists...
        Pending Updates: 2
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20175      2685/io.sonoff.0
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19450      2797/io.shelly.1
        tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          15132      975/dnsmasq
        tcp        0      0 192.168.178.30:2001     0.0.0.0:*               LISTEN      1001       16169      2415/io.hm-rpc.0
        tcp        0      0 192.168.178.30:2010     0.0.0.0:*               LISTEN      1001       18912      2435/io.hm-rpc.1
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15102      942/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14226      906/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14215      906/iobroker.js-con
        tcp        0      0 192.168.178.30:8100     0.0.0.0:*               LISTEN      1001       23718      3185/io.doorbird.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          15104      942/sshd: /usr/sbin
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15674      1804/io.admin.0
        tcp6       0      0 :::8083                 :::*                    LISTEN      1001       17457      1830/io.admin.1
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21952      3133/io.web.0
        tcp6       0      0 :::8101                 :::*                    LISTEN      1001       22880      3107/io.simple-api.
        udp        0      0 0.0.0.0:54566           0.0.0.0:*                           1001       20928      3286/io.motionblind
        udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1001       20147      2670/io.sma-em.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       20799      2653/io.shelly.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       18160      2744/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       18161      2744/io.tuya.0
        udp        0      0 0.0.0.0:32101           0.0.0.0:*                           1001       20927      3286/io.motionblind
        udp        0      0 0.0.0.0:44935           0.0.0.0:*                           108        13688      426/avahi-daemon: r
        udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          15131      975/dnsmasq
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          15128      975/dnsmasq
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12020      751/dhclient
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       20034      2500/io.mihome-vacu
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       20742      3157/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       16881      2232/io.chromecast.
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13686      426/avahi-daemon: r
        udp6       0      0 :::58836                :::*                                108        13689      426/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        13687      426/avahi-daemon: r
        2025-02-11 14:12:10.040  - debug: zigbee.0 (2763) Type of toZigbee is 'object', Contains key ["read"]
        2025-02-11 14:12:10.041  - debug: zigbee.0 (2763) Type of toZigbee is 'object', Contains key ["write"]
        2025-02-11 14:12:10.043  - debug: zigbee.0 (2763) Type of toZigbee is 'object', Contains key ["command"]
        2025-02-11 14:12:10.043  - debug: zigbee.0 (2763) Type of toZigbee is 'object', Contains key ["reset"]
        2025-02-11 14:12:10.044  - debug: zigbee.0 (2763) Type of toZigbee is 'object', Contains key ["zclcommand"]
        2025-02-11 14:12:10.045  - debug: zigbee.0 (2763) convert state, "ON", {"state":"ON"}
        2025-02-11 14:12:10.045  - debug: zigbee.0 (2763) target: {"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":16,"inputClusters":[4096,0,3,4,5,6,2820,64527],"outputClusters":[25],"profileID":49246,"ID":3,"clusters":{"genOnOff":{"attributes":{"onOff":1}},"genBasic":{"attributes":{"zclVersion":1}}},"deviceIeeeAddress":"0x7cb03eaa0a0c47ed","deviceNetworkAddress":40198,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b001caa68bd","endpointID":1}],"_configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":3,"deviceIeeeAddress":"0x7cb03eaa0a0c47ed"}}
        2025-02-11 14:12:10.080  - info: shelly.1 (2797) [authEnabled] 192.168.178.183 (shellyplus1pm / shellyplus1pm-fce8c0fd7248 / shellyplus1pm#fce8c0fd7248#1): This device is not protected via restricted login (see adapter documentation for details)
        2025-02-11 14:12:10.091  - info: chromecast.0 (2232) Keller - getStatus
        2025-02-11 14:12:10.141  - info: chromecast.0 (2232) Keller - getStatus
        2025-02-11 14:12:10.242  - warn: shelly.1 (2797) [Mqtt.statusNotifications] 192.168.178.183 (shellyplus1pm / shellyplus1pm-fce8c0fd7248 / shellyplus1pm#fce8c0fd7248#1): "General Status Notifications" are disabled (see adapter documentation for details)
        2025-02-11 14:12:14.750  - info: influxdb.0 (2176) Connecting http://localhost:8086/ ...
        2025-02-11 14:12:14.751  - info: influxdb.0 (2176) Influx DB Version used: 1.x
        2025-02-11 14:12:14.757  - error: influxdb.0 (2176) AggregateError
        2025-02-11 14:12:19.971  - debug: motionblinds.0 (3286) heartbeat timed out
        2025-02-11 14:12:24.758  - info: influxdb.0 (2176) Connecting http://localhost:8086/ ...
        2025-02-11 14:12:24.758  - info: influxdb.0 (2176) Influx DB Version used: 1.x
        2025-02-11 14:12:24.764  - error: influxdb.0 (2176) AggregateError
        2025-02-11 14:12:25.422  - info: shelly.1 (2797) [authEnabled] 192.168.178.183 (shellyplus1pm / shellyplus1pm-fce8c0fd7248 / shellyplus1pm#fce8c0fd7248#1): This device is not protected via restricted login (see adapter documentation for details)
        2025-02-11 14:12:25.608  - warn: shelly.1 (2797) [Mqtt.statusNotifications] 192.168.178.183 (shellyplus1pm / shellyplus1pm-fce8c0fd7248 / shellyplus1pm#fce8c0fd7248#1): "General Status Notifications" are disabled (see adapter documentation for details)
        2025-02-11 14:12:34.764  - info: influxdb.0 (2176) Connecting http://localhost:8086/ ...
        2025-02-11 14:12:34.765  - info: influxdb.0 (2176) Influx DB Version used: 1.x
        2025-02-11 14:12:34.771  - error: influxdb.0 (2176) AggregateError
        2025-02-11 14:12:40.877  - info: shelly.1 (2797) [authEnabled] 192.168.178.183 (shellyplus1pm / shellyplus1pm-fce8c0fd7248 / shellyplus1pm#fce8c0fd7248#1): This device is not protected via restricted login (see adapter documentation for details)
        2025-02-11 14:12:40.975  - warn: shelly.1 (2797) [Mqtt.statusNotifications] 192.168.178.183 (shellyplus1pm / shellyplus1pm-fce8c0fd7248 / shellyplus1pm#fce8c0fd7248#1): "General Status Notifications" are disabled (see adapter documentation for details)
        maxpd
        Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
        • M maxpd
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          iob diag
          ```bash
          Script v.2025-02-02
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pd
          HOME=/home/pd
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   7811 M total memory
                   3325 M used memory
                   3493 M free memory
                    127 M buffer memory
                    864 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          *** FILESYSTEM ***
          /var:
          3.0G    /var/
          1.2G    /var/log
          894M    /var/cache
          USB-Devices by-id:
          HINT:
          /dev/ttyACM0
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.4.10
          javascript:     8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        25624
          States:         21191
          Pending Updates: 2
          GUIs lügen. Lad die Web-Seite nochmal. Dann muss es passen.
            maxpd
            @thomas-braun auch mit inkognito mode, also leerem browser cache und Reboot lügt die GUI dann weiter ;)
            maxpd
            • M maxpd
              @maxpd was steht bei dir im Expertenmodus unter system.host.xxyy.versions
                maxpd
                @homoran da haste was entdeckt!
                maxpd
                • M maxpd
                  @maxpd hast du multihost?
                  davon sieht man im iob diag aber nichts.
                  wie wurde der slave installiert/ konfiguriert?
                  wo läuft zigbee?
                    wo läuft zigbee?
                    maxpd
                    @homoran nein, nur einen 2. Admin Adapter mit https Zertifikat für Daikin Adapter.
                    maxpd
                    • M maxpd
                      never!
                      du hast 2 Hostnamen
                        never!
                        du hast 2 Hostnamen
                        maxpd
                        @homoran wie Multihost funktioniert und was dies bringt weiß ich nicht. Wie der 2. Host da rein und wieder raus kommt ist mir auch unerklärlich ;)
                        maxpd
                        • M maxpd
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          iob diag
                          ```bash
                          Script v.2025-02-02
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pd
                          HOME=/home/pd
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            99M          0B         99M
                                   7811 M total memory
                                   3325 M used memory
                                   3493 M free memory
                                    127 M buffer memory
                                    864 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          *** FILESYSTEM ***
                          /var:
                          3.0G    /var/
                          1.2G    /var/log
                          894M    /var/cache
                          USB-Devices by-id:
                          HINT:
                          /dev/ttyACM0
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.4.10
                          javascript:     8.8.3
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        25624
                          States:         21191
                          Pending Updates: 2
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          Da du geschrieben hast das du nichts verändert hast müsste das Problem in Deiner Funkstrecke liegen - ansonsten hätten die Probleme mit dem Update des Systems anfangen müssen.
                          Allein - glauben mag ich das nicht. Ich bin mir (fast) sicher, das du da doch etwas getan hast.
                          Bitte installier über den Admin (Expert mode) mal die Version 1.10.3 des Zigbee Adapters.
                          A.
                            maxpd
                            @asgothian Die Installation erfolgt bei mir grundsätzlich mit einem Error, unabhängig von der Version.
                            Installing iobroker.zigbee@1.10.3... (System call)
                            npm warn deprecated npmlog@4.1.2: This package is no longer supported.
                            npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
                            npm warn deprecated gauge@2.7.4: This package is no longer supported.
                            > usocket@0.3.0 install> node-gyp rebuild
                            gyp info it worked if it ends with ok
                            gyp info using node-gyp@7.1.2gyp info using node@20.18.3 | linux | arm64
                            gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
                            gyp ERR! UNCAUGHT EXCEPTION
                            gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/usocket/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/usocket/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:188:23)gyp ERR! System Linux 6.1.21-v8+gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/usocket/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/usocketgyp ERR! node -v v20.18.3gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                            added 7 packages, removed 16 packages, and changed 4 packages in 23s
                            Allerdings wird bei mir Version 1.10.3 gar nicht mehr grün und verbleibt in Gelb.
                            zigbee.0
                            2025-02-11 21:22:00.375	error	Error herdsman start
                            zigbee.0
                            2025-02-11 21:22:00.374	error	Failed to start Zigbee
                            zigbee.0
                            2025-02-11 21:22:00.372	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
                            zigbee.0
                            2025-02-11 21:22:00.157	info	Installed Version: iobroker.zigbee@1.10.3
                            zigbee.0
                            2025-02-11 21:22:00.132	info	Starting Zigbee npm ...
                            zigbee.0
                            2025-02-11 21:22:00.130	info	Try to reconnect. 1 attempts left
                            zigbee.0
                            2025-02-11 21:21:50.125	error	Error herdsman start
                            zigbee.0
                            2025-02-11 21:21:50.123	error	Failed to start Zigbee
                            zigbee.0
                            2025-02-11 21:21:50.122	error	Starting zigbee-herdsman problem : "Attempt to access memory outside buffer bounds"
                            zigbee.0
                            2025-02-11 21:21:49.355	info	Installed Version: iobroker.zigbee@1.10.3
                            zigbee.0
                            2025-02-11 21:21:48.882	info	Starting Zigbee npm ...
                            zigbee.0
                            2025-02-11 21:21:48.879	info	delete old Backup files. keep only last 10
                            zigbee.0
                            2025-02-11 21:21:48.764	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.3, js-controller: 7.0.6
                            zigbee.0
                            2025-02-11 21:21:07.911	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            zigbee.0
                            2025-02-11 21:21:07.906	info	terminating
                            zigbee.0
                            2025-02-11 21:21:07.314	info	Zigbee: disabling joining new devices.
                            zigbee.0
                            2025-02-11 21:21:07.311	info	cleaned everything up...
                            zigbee.0
                            2025-02-11 21:21:07.309	info	Got terminate signal TERMINATE_YOURSELF
                            Allerdings steht auch bei der Installation, dass wenn man mal bei Version 1.10.14 war, ein Downgrade nicht mehr möglich ist.
                            "BREAKING CHANGE. after update to this Version you can't go back to Version <= 1.10.3. Only option is your Backup
                            Ich bin aber gerade auch auf dieses Topic gestoßen und damit scheinbar gar kein Einzelfall:
                            https://forum.iobroker.net/topic/79634/zigbee-empfangen-geht-senden-geht-nicht
                            Dennoch habe ich noch herausgefunden, was ich am System geändert hatte.
                            Folgende Befehle hatte ich die Tage im Rahmen meiner Bluetooth Odyssee in die Konsole geschickt. Bei den ersten 2 bin ich mir nicht sicher, ob die nicht schon länger her sind:
                            curl -sL https://deb.nodesource.com/setup_20.x | sudo -E bash -
                            sudo dpkg --configure -a
                            sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
                            sudo setcap cap_net_raw+eip $(eval readlink -f 'which node')
                            sudo apt-get update
                            sudo apt-get upgrade -y
                            sudo apt-get dist-upgrade -y
                            sudo usermod -G bluetooth -a pd
                            cat /etc/group | grep bluetooth
                            sudo systemctl enable hciuart.service
                            hcitool dev
                            sudo apt-get install pi-bluetooth
                            sudo apt-get install bluetooth bluez blueman
                            sudo rmmod btusb
                            sudo modprobe btusb
                            sudo hciconfig hci0 up
                            Gehen die gesendeten Daten evtl. an den aktivierten hciuart.service? - aber ein Deaktivieren löst das Problem auch nicht.
                            Und ein bisschen in der Nase hängt mir noch das die Tage gemachte jscontroller update von 7.0.5 auf .6
                            maxpd
                            • arteckA Offline
                              arteckA Offline
                              arteck
                              doch.... mit so strubbeligen system schon.. das von dir gepostete Thema hat so nix nix mit deinem Problem zu tun
                              • arteckA arteck
                                maxpd
                                @arteck Abgesehen von all dem, was dazwischen zu Tage kam 😉 (ein ungewolltes Multihost, falsche empfohlene nodejs Version, bald veraltetes OS) ist das geschilderte Problem, dass meine Geräte nur Daten empfangen, aber nicht senden, aus meiner Perspektive, exakt das Thema aus dem verlinkten Topic? Zumindest das Fehlerbild. Es mögen die Ursachen abweichen.
                                Auch hier kamen neuerlich das Thema auf: https://github.com/ioBroker/ioBroker.zigbee/issues/2343, https://github.com/ioBroker/ioBroker.zigbee/issues/2306
                                PS: Ergänzung zu meinem vorherigen Beitrag: Bei der Zigbee Kopplung läuft auch keine Zeit mehr runter (analog dem zuvor verlinkten Topic).
                                maxpd
                                • M maxpd
                                  @maxpd Setz mal ein ganz neues System sauber auf, damit du alle Ungereimtheiten los wirst.
                                  Spiel dein iobroker backup zurück, und wenn du nicht sowieso lieber alles neu Anlernen möchtest auch dein Zigbee backup.
                                  Das ist dich bei einem Raspi überhaupt kein Problem wenn du rine zweite Karte verwendest.
                                  Erst dann kann man einen krummen Unterbau als Ursache wirklich ausschließen.
                                    maxpd
                                    schrieb am zuletzt editiert von maxpd
                                    Update: Hab zwar noch kein neues System aufgesetzt (hat bei den 4-5x davor nicht problemlos funktioniert | also geht bei mir nicht schnell)
                                    Aber hab das Problem jetzt mal auf die USB Funkmodule einschränken können. Das Homematic Modul direkt auf der Platine aufgesteckt funktioniert weiterhin, aber das Zigbee und 433er Modul an den USB Ports des Pi haben das gleiche Problem. Auch das 433er empfängt, aber sendet nicht.
                                    Gelistet werden sie.
                                     $ lsusb
                                    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                    Bus 001 Device 005: ID 152d:0562 JMicron Technology Corp. / JMicron USA Technology Corp. JMS567 SATA 6Gb/s bridge
                                    Bus 001 Device 004: ID 0bda:5411 Realtek Semiconductor Corp. RTS5411 Hub
                                    Bus 001 Device 003: ID 0451:bef3 Texas Instruments, Inc. CC1352R1 Launchpad
                                    Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
                                    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                                    Update 2: Brauche ich eine Netzwerkbrücke wenn ich pivCCU zu iob dazu installiere? Habs jetzt 3x versucht aufzusetzen und immer ist der Pi nach Step8 nicht mehr erreichbar: https://github.com/alexreinert/piVCCU/blob/master/docs/setup/raspberrypi.md
                                    maxpd
                                    • M maxpd
                                       $ lsusb
                                      Mach es andersherum. Zuerst pivCCU und dann denn ioBroker dazu.
                                        maxpd
                                        @thomas-braun Aber auch dann, mit Step 8 geht SSH kaputt, egal ob hostname oder IP. Die Fritz.Box sagt es wäre weiterhin die gleiche IP. habs auch versucht mit der Vergabe einer festen IP. Ich probiers jetzt ganz ohne Step 8.
                                        maxpd
                                          maxpd
                                          Ich hab nun paar mal iobroker aufgesetzt.
                                          Ganz straight forwars habe ich nur Bookworm mit iobroker drauf gespielt und ein 2 Wochen altes Backup importiert.
                                          Keine CCU installiert und keine Settings auf dem Raspi geändert.
                                          Keine Adapter aktiviert außer Backitup, admin, zigbee und testweise motionblinds
                                          WLAN im Haus testweise deaktiviert.
                                          Aber sowohl Zigbee, als auch der 433er Dongle (motionsblinds) empfangen Daten, senden aber nicht.
                                          Der Dongle ist an einem Hub mit zusätzlicher Stromversorgung.
                                          Auch den USB Hub und den 433er Dongle komplett entfernt bringt nichts.
                                          Einen Hint hat iob diag noch
                                          HINT:
                                          /dev/ttyACM0
                                          Aber das sind die zuvor funktionerenden Settings und nur mit ACM0 wird der Adapter grün:
                                          ```bash
                                          Script v.2025-02-02
                                          *** BASE SYSTEM ***
                                                 Icon name: computer
                                                    Kernel: Linux 6.6.74+rpt-rpi-v8
                                              Architecture: arm64
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                           21:50:51 up 23 min,  2 users,  load average: 0.23, 0.47, 0.54
                                          CPU threads: 4
                                          Operating System is the current Debian stable version codenamed 'bookworm'!
                                          Current issues:
                                                         Local time: Sun 2025-02-16 21:50:52 CET
                                                     Universal time: Sun 2025-02-16 20:50:52 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pd
                                          HOME=/home/pd
                                          GROUPS=pd adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                          iobroker
                                          HOME=/home/iobroker
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            8.2G        1.1G        6.7G        1.2M        496M        7.1G
                                          Swap:           536M          0B        536M
                                          Total:          8.7G        1.1G        7.3G
                                          Active iob-Instances:   6
                                                   7809 M total memory
                                                   1024 M used memory
                                                   1039 M active memory
                                                    234 M inactive memory
                                                   6428 M free memory
                                                     55 M buffer memory
                                                    418 M swap cache
                                                    511 M total swap
                                                      0 M used swap
                                                    511 M free swap
                                          top - 21:50:52 up 23 min,  2 users,  load average: 0.23, 0.47, 0.54
                                          Tasks: 177 total,   1 running, 176 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s): 20.0 us,  0.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :   7809.9 total,   6427.4 free,   1024.9 used,    474.2 buff/cache
                                          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6785.0 avail Mem
                                          *** FILESYSTEM ***
                                          udev           devtmpfs  3.6G     0  3.6G   0% /dev
                                          tmpfs          tmpfs     781M  1.2M  780M   1% /run
                                          /dev/mmcblk0p2 ext4       29G  7.3G   21G  27% /
                                          tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                                          /dev/mmcblk0p1 vfat      510M   55M  456M  11% /boot/firmware
                                          tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
                                          [Sun Feb 16 21:27:44 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:57:31:D7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c624a46e-02 rootfstype=ext4 fsck.repair=yes rootwait
                                          [Sun Feb 16 21:28:01 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                                          [Sun Feb 16 21:28:02 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                                          /                /dev/mmcblk0p2 ext4   rw,noatime
                                          `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          945M    /var/
                                          205M    /var/cache
                                          200M    /var/cache/apt
                                          168M    /var/lib
                                          135M    /var/lib/apt/lists
                                          Archived and active journals take up 60.0M in the file system.
                                          4.0K    /opt/iobroker/backups/
                                          50M     /opt/iobroker/iobroker-data/objects.jsonl
                                          24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                                          USB-Devices by-id:
                                          HINT:
                                          /dev/ttyACM0
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                            Version table:
                                               18.19.0+dfsg-6~deb12u2 500
                                               18.19.0+dfsg-6~deb12u1 500
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          donbroker           donbroker (version: 7.0.6, hostname: donbroker     , alive, uptime: 1374)
                                          admin:          7.4.10
                                          javascript:     8.8.3
                                          nodejs modules from github:     5
                                          Adapter State
                                            system.adapter.ble.0                    : ble                   : donbroker                                - disabled
                                            system.adapter.chromecast.0             : chromecast            : donbroker                                - disabled
                                            system.adapter.coronavirus-statistics.0 : coronavirus-statistics: donbroker                                - disabled
                                            system.adapter.daikin-cloud.0           : daikin-cloud          : donbroker                                - disabled
                                            system.adapter.daswetter.0              : daswetter             : donbroker                                - disabled
                                            system.adapter.denon.0                  : denon                 : donbroker                                - disabled
                                            system.adapter.doorbird.0               : doorbird              : donbroker                                - disabled
                                            system.adapter.echarts.0                : echarts               : donbroker                                - disabled
                                            system.adapter.feiertage.0              : feiertage             : donbroker                                - disabled
                                            system.adapter.google-sharedlocations.0 : google-sharedlocations: donbroker                                - disabled
                                            system.adapter.govee.0                  : govee                 : donbroker                                - disabled
                                            system.adapter.hass.0                   : hass                  : donbroker                                - disabled, port: 8123
                                            system.adapter.history.0                : history               : donbroker                                - disabled
                                            system.adapter.hm-rega.0                : hm-rega               : donbroker                                - disabled
                                            system.adapter.hm-rpc.0                 : hm-rpc                : donbroker                                - disabled, port: 0
                                            system.adapter.hm-rpc.1                 : hm-rpc                : donbroker                                - disabled, port: 0
                                            system.adapter.ical.0                   : ical                  : donbroker                                - disabled
                                            system.adapter.info.0                   : info                  : donbroker                                - disabled
                                            system.adapter.iot.0                    : iot                   : donbroker                                - disabled
                                            system.adapter.javascript.0             : javascript            : donbroker                                - disabled
                                            system.adapter.mihome-vacuum.0          : mihome-vacuum         : donbroker                                - disabled, port: 54321
                                            system.adapter.modbus.0                 : modbus                : donbroker                                - disabled
                                            system.adapter.modbus.1                 : modbus                : donbroker                                - disabled
                                            system.adapter.modbus.2                 : modbus                : donbroker                                - disabled
                                            system.adapter.motionblinds.0           : motionblinds          : donbroker                                - disabled
                                            system.adapter.mqtt-client.0            : mqtt-client           : donbroker                                - disabled, port: 1884
                                          + system.adapter.net-tools.0              : net-tools             : donbroker                                -  enabled
                                            system.adapter.ping.0                   : ping                  : donbroker                                - disabled
                                            system.adapter.pollenflug.0             : pollenflug            : donbroker                                - disabled
                                            system.adapter.pvforecast.0             : pvforecast            : donbroker                                - disabled
                                            system.adapter.pvforecast.1             : pvforecast            : donbroker                                - disabled
                                            system.adapter.pvforecast.2             : pvforecast            : donbroker                                - disabled
                                            system.adapter.roborock.0               : roborock              : donbroker                                - disabled
                                            system.adapter.sayit.0                  : sayit                 : donbroker                                - disabled
                                            system.adapter.sayit.1                  : sayit                 : donbroker                                - disabled
                                            system.adapter.sayit.2                  : sayit                 : donbroker                                - disabled
                                            system.adapter.sayit.3                  : sayit                 : donbroker                                - disabled
                                            system.adapter.sayit.4                  : sayit                 : donbroker                                - disabled
                                            system.adapter.schoolfree.0             : schoolfree            : donbroker                                - disabled
                                            system.adapter.shelly.0                 : shelly                : donbroker                                - disabled, port: 1882, bind: 0.0.0.0
                                            system.adapter.shelly.1                 : shelly                : donbroker                                - disabled, port: 1882, bind: 0.0.0.0
                                            system.adapter.shuttercontrol.0         : shuttercontrol        : donbroker                                - disabled
                                            system.adapter.simple-api.1             : simple-api            : donbroker                                - disabled, port: 8101, bind: 0.0.0.0, run as: admin
                                            system.adapter.sma-em.0                 : sma-em                : donbroker                                - disabled
                                            system.adapter.sonoff.0                 : sonoff                : donbroker                                - disabled, port: 1883, bind: 0.0.0.0
                                            system.adapter.telegram.0               : telegram              : donbroker                                - disabled, port: 8443, bind: 0.0.0.0
                                            system.adapter.telegram.1               : telegram              : donbroker                                - disabled, port: 8443, bind: 0.0.0.0
                                            system.adapter.telegram.2               : telegram              : donbroker                                - disabled, port: 8443, bind: 0.0.0.0
                                            system.adapter.tr-064.0                 : tr-064                : donbroker                                - disabled
                                            system.adapter.tuya.0                   : tuya                  : donbroker                                - disabled
                                            system.adapter.web.0                    : web                   : donbroker                                - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                            system.adapter.wifilight.0              : wifilight             : donbroker                                - disabled
                                            system.adapter.wled.0                   : wled                  : donbroker                                - disabled
                                          + instance is alive
                                          Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common//../node_modules/iobroker.socketio/io-package.json: /opt/iobroker/node_modules/iobroker.socketio/io-package.json: Unexpected token '', ""... is not valid JSON
                                          Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common//../node_modules/iobroker.web/io-package.json: /opt/iobroker/node_modules/iobroker.web/package.json: Unexpected end of JSON input
                                          Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common//../node_modules/iobroker.ws/io-package.json: /opt/iobroker/node_modules/iobroker.ws/io-package.json: Unexpected token '', ""... is not valid JSON
                                          Adapter    "ble"          : 0.14.0   , installed 0.14.0
                                          Adapter    "net-tools"    : 1.0.11   , installed 1.1.0
                                          Adapter    "sma-em"       : 1.2.0    , installed 1.1.0  [Updatable]
                                          Adapter    "zigbee"       : 1.10.14  , installed 1.10.13 [Updatable]
                                          Objects and States
                                          Objects:        25451
                                          States:         20577
                                          Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                                          Hit:2 http://deb.debian.org/debian bookworm InRelease
                                          Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                                          Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                                          Pending Updates: 0
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2860       590/sshd: /usr/sbin
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5514       581/iobroker.js-con
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5519       581/iobroker.js-con
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          2862       590/sshd: /usr/sbin
                                          tcp6       0      0 :::8083                 :::*                    LISTEN      1001       4995       782/io.admin.1
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5716       771/io.admin.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4084       455/avahi-daemon: r
                                          udp        0      0 0.0.0.0:52282           0.0.0.0:*                           104        4086       455/avahi-daemon: r
                                          udp6       0      0 fe80::64f4:522f:5b9:546 :::*                                0          6208       531/NetworkManager
                                          udp6       0      0 :::5353                 :::*                                104        4085       455/avahi-daemon: r
                                          udp6       0      0 :::60256                :::*                                104        4087       455/avahi-daemon: r
                                          2025-02-16 21:43:46.318  - info: zigbee.0 (1121) 0x54ef4410000c1ed5 (addr 61170): GZCGQ01LM - Xiaomi Mi light sensor (EndDevice)
                                          2025-02-16 21:43:46.319  - info: zigbee.0 (1121) 0x54ef4410000c298d (addr 58684): GZCGQ01LM - Xiaomi Mi light sensor (EndDevice)
                                          2025-02-16 21:43:46.320  - info: zigbee.0 (1121) 0x7cb03eaa0a0c1130 (addr 24831): AB3257001NJ - OSRAM Smart+ plug (Router)
                                          2025-02-16 21:43:46.322  - info: zigbee.0 (1121) 0x00158d0004910d68 (addr 30987): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice)
                                          2025-02-16 21:43:46.323  - info: zigbee.0 (1121) 0x00158d0006ba82be (addr 56203): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                                          2025-02-16 21:43:46.324  - info: zigbee.0 (1121) 0x00158d000809443c (addr 50143): WXKG11LM - Aqara Wireless mini switch (EndDevice)
                                          2025-02-16 21:43:46.325  - info: zigbee.0 (1121) 0x00158d0003232318 (addr 35648): DJT11LM - Aqara Vibration sensor (EndDevice)
                                          2025-02-16 21:43:46.326  - info: zigbee.0 (1121) 0x842e14fffe0f530f (addr 22943): MS-SP-LE27WRGB - Mycket E27 RGBW bulb (Router)
                                          2025-02-16 21:43:46.327  - info: zigbee.0 (1121) 0xa4c1381d064246ab (addr 38128): RSH-HS06_1 - Tuya Temperature & humidity sensor (EndDevice)
                                          2025-02-16 21:43:46.328  - info: zigbee.0 (1121) 0x00158d000af2de24 (addr 59952): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                                          2025-02-16 21:43:46.330  - info: zigbee.0 (1121) 0x842e14fffe0f5322 (addr 62047): MS-SP-LE27WRGB - Mycket E27 RGBW bulb (Router)
                                          2025-02-16 21:43:46.331  - info: zigbee.0 (1121) 0x842e14fffe0f5318 (addr 2296): MS-SP-LE27WRGB - Mycket E27 RGBW bulb (Router)
                                          2025-02-16 21:43:46.332  - info: zigbee.0 (1121) Zigbee started
                                          2025-02-16 21:43:46.611  - info: zigbee.0 (1121) debug devices set to []
                                          2025-02-16 21:43:50.935  - info: admin.0 (771) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                          2025-02-16 21:43:51.263  - info: zigbee.0 (1121) List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100F9Y","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100F9Y-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100F9Y","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100F9Y-if03","vendorId":"0451","productId":"bef3"}]
                                          2025-02-16 21:43:53.979  - info: zigbee.0 (1121) Zigbee: allowing new devices to join.
                                          2025-02-16 21:44:12.549  - info: admin.0 (771) <== Disconnect system.user.admin from ::ffff:192.168.178.130
                                          2025-02-16 21:44:44.566  - info: host.donbroker "system.adapter.net-tools.0" enabled
                                          2025-02-16 21:44:46.388  - info: host.donbroker instance system.adapter.net-tools.0 in version "1.1.0" started with pid 1140
                                          2025-02-16 21:44:48.835  - info: net-tools.0 (1140) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.net-tools, node: v20.18.3, js-controller: 7.0.6
                                          2025-02-16 21:44:48.895  - error: net-tools.0 (1140) License Key is not set! Enter a valid license key in the adapter settings.
                                          2025-02-16 21:45:03.760  - info: admin.0 (771) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                          2025-02-16 21:45:04.073  - info: zigbee.0 (1121) List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100F9Y","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100F9Y-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100F9Y","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.25__Embed_with_CMSIS-DAP_L1100F9Y-if03","vendorId":"0451","productId":"bef3"}]
                                          2025-02-16 21:45:06.639  - info: zigbee.0 (1121) Zigbee: allowing new devices to join.
                                          maxpd
                                          Meister MopperM HomoranH 2 Antworten Letzte Antwort
