  4. Fehler beim Start Javascript nach Neuinstallation
    1.0k
    6.1k
51 Beiträge 5 Kommentatoren 6.6k Aufrufe 4 Beobachtet
    matrose65
    schrieb am zuletzt editiert von matrose65
    Hallo
    Ich habe mein System neu aufsetzten müssen.
    Nach dem zurückspielen des Updates sind fast alle Instanzen wieder in Ordnung.
    Nur wenn ich den Javascript Adapter starte, bekomme ich in einer Schleife folgende Fehler:
    2025-02-03 09:59:35.346 - info: host.IOB "system.adapter.javascript.0" disabled
    2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:135490
    2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: ScriptElementKijdModifier2["ambientModifier"] = "declare";
    2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: ^
    2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: ReferenceError: ScriptElementKijdModifier2 is not defined
    2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at /opt/iobroker/node_modules/typescript/lib/typescript.js:135490:3
    2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at /opt/iobroker/node_modules/typescript/lib/typescript.js:135508:3
    2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at Object. (/opt/iobroker/node_modules/typescript/lib/typescript.js:195004:3)
    2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
    2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
    2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
    2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
    2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
    2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
    2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptSettings.js:1:20)
    2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: Node.js v20.18.2
    2025-02-03 09:59:40.173 - error: host.IOB instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2025-02-03 09:59:40.173 - info: host.IOB Do not restart adapter system.adapter.javascript.0 because disabled or deleted
    Ich habe den Adaper auch schon neu installiert und auch den Fixer laufen lassen. Aber keine Änderung
    • Adaptername: Javascript
    • Link zu Adapterrepository: www.github.com...
    • Adapterversion: 8.8.3
    • js-controller Version: 7.0.6
    • Admin Version: 7.4.10
    • Hardwaresystem: NUC,
    • Arbeitsspeicher: 16GB
    • Festplattenart: HDD, - Betriebssystem: Linux auf Proxmox
    • Nodejs-Version: 20.18.2
    • NPM-Version: 10.8.2
    • Installationsart: Manuell
    • Image, Docker genutzt: nein
    Und hier noch die lange Diag Version
    ```bash
    Script v.2025-02-02
    *** BASE SYSTEM ***
     Static hostname: IOB
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-30-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
    OS is similar to:
    model name      : QEMU Virtual CPU version 2.5+
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     10:10:33 up  1:25,  2 users,  load average: 0.22, 0.07, 0.08
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-02-03 10:10:33 CET
               Universal time: Mon 2025-02-03 09:10:33 UTC
                     RTC time: Mon 2025-02-03 09:10:33
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    uwe
    HOME=/home/uwe
    GROUPS=uwe cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:             16G        2.1G         12G        561K        2.8G         14G
    Swap:           1.0G          0B        1.0G
    Total:           17G        2.1G         13G
    Active iob-Instances:   21
            15992 M total memory
             2009 M used memory
              467 M active memory
             3484 M inactive memory
            11677 M free memory
               89 M buffer memory
             2546 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    top - 10:10:33 up  1:25,  2 users,  load average: 0.22, 0.07, 0.08
    Tasks: 126 total,   1 running, 125 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  15992.7 total,  11677.7 free,   2009.3 used,   2635.8 buff/cache
    MiB Swap:    975.0 total,    975.0 free,      0.0 used.  13983.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  7.8G     0  7.8G   0% /dev
    tmpfs          tmpfs     1.6G  556K  1.6G   1% /run
    /dev/sda1      ext4       31G  6.5G   23G  23% /
    tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
    [Mon Feb  3 08:44:58 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Feb  3 08:44:58 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    461M    /var/
    248M    /var/cache
    241M    /var/cache/apt
    174M    /var/lib
    165M    /var/cache/apt/archives
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    12M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.2G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    30M     /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
    22M     /opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.2
    /usr/bin/node           v20.18.2
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.2-1nodesource1
      Candidate: 20.18.2-1nodesource1
      Version table:
     *** 20.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    IOB                 IOB (version: 7.0.6, hostname: IOB           , alive, uptime: 2371)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.4.10
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : IOB                                      -  enabled
    + system.adapter.admin.0                  : admin                 : IOB                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : IOB                                      -  enabled
      system.adapter.bmw.0                    : bmw                   : IOB                                      - disabled
      system.adapter.daswetter.0              : daswetter             : IOB                                      -  enabled
      system.adapter.devices.0                : devices               : IOB                                      - disabled
      system.adapter.dwd.0                    : dwd                   : IOB                                      -  enabled
      system.adapter.feiertage.0              : feiertage             : IOB                                      -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : IOB                                      -  enabled
    + system.adapter.history.0                : history               : IOB                                      -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : IOB                                      -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : IOB                                      -  enabled, port: 8081
      system.adapter.ical.0                   : ical                  : IOB                                      -  enabled
      system.adapter.ical.1                   : ical                  : IOB                                      -  enabled
      system.adapter.ical.2                   : ical                  : IOB                                      -  enabled
      system.adapter.ical.3                   : ical                  : IOB                                      -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : IOB                                      - disabled
      system.adapter.javascript.0             : javascript            : IOB                                      - disabled
    + system.adapter.mqtt.0                   : mqtt                  : IOB                                      -  enabled, port: 1888, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : IOB                                      -  enabled
    + system.adapter.roborock.0               : roborock              : IOB                                      -  enabled
    + system.adapter.scenes.0                 : scenes                : IOB                                      -  enabled
    + system.adapter.shelly.1                 : shelly                : IOB                                      -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.2                 : shelly                : IOB                                      -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : IOB                                      -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : IOB                                      -  enabled
    + system.adapter.tr-064.0                 : tr-064                : IOB                                      -  enabled
    + system.adapter.unifi.0                  : unifi                 : IOB                                      -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : IOB                                      - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : IOB                                      - disabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: IOB                                      - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: IOB                                      - disabled
    + system.adapter.vis-2.0                  : vis-2                 : IOB                                      -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : IOB                                      - disabled
    + system.adapter.web.0                    : web                   : IOB                                      -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : IOB                                      -  enabled
      system.adapter.worx.0                   : worx                  : IOB                                      - disabled
    + system.adapter.zigbee.0                 : zigbee                : IOB                                      -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
    Adapter    "admin"        : 7.4.10   , installed 7.4.10
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "roborock"     : 0.6.18   , installed 0.6.18
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 8.5.1    , installed 8.5.1
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.11.2
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
    Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
    Adapter    "web"          : 6.2.5    , installed 6.3.0
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "worx"         : 3.1.1    , installed 3.1.1
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
    Objects and States
    Objects:        7970
    States:         6912
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.1.13:8082       0.0.0.0:*               LISTEN      1001       54411      4864/io.hm-rpc.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       52306      4646/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       51830      4646/iobroker.js-co
    tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       53566      4939/io.mqtt.0
    tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       53567      4939/io.mqtt.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       52645      4954/io.shelly.1
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17857      528/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15361      1/init
    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       55590      5135/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       51877      4675/io.admin.0
    tcp6       0      0 :::7906                 :::*                    LISTEN      1001       52591      4752/io.roborock.0
    tcp6       0      0 :::6824                 :::*                    LISTEN      1001       52590      4752/io.roborock.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17859      528/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          15362      1/init
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       54525      4984/io.sonos.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      1001       53772      5090/io.fullybrowse
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       54845      5150/io.wled.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       54496      4969/io.shelly.2
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14911      370/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14497      1/init
    udp6       0      0 :::111                  :::*                                0          14498      1/init
    2025-02-03 09:59:09.226  - info: host.IOB Restart adapter system.adapter.javascript.0 because enabled
    2025-02-03 09:59:40.173  - error: host.IOB Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/typescript/lib/typescript.js:195004:3)
    2025-02-03 09:59:40.173  - error: host.IOB Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptSettings.js:1:20)
    2025-02-03 10:00:00.010  - info: host.IOB instance system.adapter.ical.0 in version "1.16.1" started with pid 6641
    2025-02-03 10:00:00.875  - info: ical.0 (6641) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.2, js-controller: 7.0.6
    2025-02-03 10:00:01.459  - info: ical.0 (6641) processing URL:
    2025-02-03 10:00:06.631  - info: ical.0 (6641) Terminated (NO_ERROR): Without reason
    2025-02-03 10:00:07.144  - info: host.IOB instance system.adapter.ical.0 having pid 6641 terminated with code 0 (NO_ERROR)
    2025-02-03 10:01:28.324  - error: accuweather.0 (4804) Error: Forecast cannot be retrieved. ERROR: {"Code":"ServiceUnavailable","Message":"The allowed number of requests has been exceeded.","Reference":"/currentconditions/v1/1026016?apikey=yWHAR7zDoQ5Si2Ds8SVdlNipITAtyDZp%20&language=de&metric=true&details=true"}
    • M matrose65
      Hallo
      ```bash
      Script v.2025-02-02
      *** BASE SYSTEM ***
               Chassis: vm 🖴
        Virtualization: kvm
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      uwe
      HOME=/home/uwe
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           1.0G          0B        1.0G
      Total:           17G        2.1G         13G
               2009 M used memory
                467 M active memory
              11677 M free memory
                 89 M buffer memory
               2546 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FILESYSTEM ***
      /var:
      461M    /var/
      248M    /var/cache
      241M    /var/cache/apt
      174M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.4.10
      javascript:     8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        7970
      States:         6912
      Pending Updates: 0
      CodierknechtC Online
      Codierknecht
      @matrose65
      Brauchen Deine Scripte zusätzliche NPM-Module, die jetzt nicht mehr geladen werden?
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      • CodierknechtC Codierknecht
        @matrose65
        matrose65
        @codierknecht
        Es waren 4 Module installiert.
        qr-image
        Moment
        moment-parseformat
        axios
        Diese habe ich mal rausgenommen, weil ich dachte das sie stören
        • M matrose65
          @codierknecht
          qr-image
          Moment
          moment-parseformat
          axios
          Codierknecht
          @matrose65 sagte in Fehler beim Start Javascript nach Neuinstallation:
          Da dürfte eher das Gegenteil der Fall sein.
          Wenn da benötigte Pakete fehlen (darum heißt es ja auch "required") gehen die Scripte auf die Bretter.
            matrose65
            @codierknecht
            Ok, das sehe ich ein aber auch mit den Modulen beginnen die Fehler wieder
            2025-02-03 10:35:20.003 - info: host.IOB "system.adapter.javascript.0" enabled
            2025-02-03 10:35:20.332 - info: host.IOB instance system.adapter.javascript.0 in version "8.8.3" started with pid 7772
            2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:135490
            2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: ScriptElementKijdModifier2["ambientModifier"] = "declare";
            2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: ^
            2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: ReferenceError: ScriptElementKijdModifier2 is not defined
            2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: at /opt/iobroker/node_modules/typescript/lib/typescript.js:135490:3
            2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: at /opt/iobroker/node_modules/typescript/lib/typescript.js:135508:3
            2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: at Object. (/opt/iobroker/node_modules/typescript/lib/typescript.js:195004:3)
            2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
            2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
            2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
            2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
            2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
            2025-02-03 10:35:20.929 - error: host.IOB Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
            2025-02-03 10:35:20.929 - error: host.IOB Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptSettings.js:1:20)
            2025-02-03 10:35:20.929 - error: host.IOB Caught by controller[0]: Node.js v20.18.2
            2025-02-03 10:35:20.929 - error: host.IOB instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2025-02-03 10:35:20.929 - info: host.IOB Restart adapter system.adapter.javascript.0 because enabled
            2025-02-03 10:35:51.237 - info: host.IOB instance system.adapter.javascript.0 in version "8.8.3" started with pid 7779
            2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:135490
            2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: ScriptElementKijdModifier2["ambientModifier"] = "declare";
            2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: ^
            2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: ReferenceError: ScriptElementKijdModifier2 is not defined
            2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: at /opt/iobroker/node_modules/typescript/lib/typescript.js:135490:3
            2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: at /opt/iobroker/node_modules/typescript/lib/typescript.js:135508:3
            2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: at Object. (/opt/iobroker/node_modules/typescript/lib/typescript.js:195004:3)
            2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
            2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
            2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
            2025-02-03 10:35:51.831 - error: host.IOB Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
            2025-02-03 10:35:51.831 - error: host.IOB Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
            2025-02-03 10:35:51.831 - error: host.IOB Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
            2025-02-03 10:35:51.831 - error: host.IOB Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptSettings.js:1:20)
            2025-02-03 10:35:51.831 - error: host.IOB Caught by controller[0]: Node.js v20.18.2
            2025-02-03 10:35:51.831 - error: host.IOB instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2025-02-03 10:35:51.831 - info: host.IOB Restart adapter system.adapter.javascript.0 because enabled
            • M matrose65
              @codierknecht
              matrose65
              Hallo
              Muss jetzt leider erstmal auf Arbeit.
              Kann sicher mitlesen und antworten, aber nichts testen.
              Melde mich heute Abend nochmal
              • M matrose65
                Hallo
                matrose65
                Hallo
                Bin wieder am Rechner.
                Habe jetzt alle Scripte angehalten und dann Javascript gestartet. Aber keine Änderung.
                Versuche noch einmal zu deinstallieren, sonst weiß ich nicht weiter.
                • M matrose65
                  Hallo
                  matrose65
                  Guten Morgen zusammen
                  Hat keiner eine Idee was ich noch machen soll?
                  Mein Plan ist, ich werde heute alles nochmal neu aufsetzen. Mal sehen.
                  Wenn das auch nichts wird, dann besorge ich mir eine neue SSD. Irgendwie habe ich das Gefühl das von da die Probleme kommen
                  • M matrose65
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    @matrose65
                    Startet der Adapter auch ohne aktivierte Skripte?
                    Ich habe mal nach dieser Referenz das Internet durchsucht,
                    Leider nichts gefunden. Selbst im Repository von TypeSkript taucht das nicht auf.
                    Obwohl die Fehlermeldung dorthin zeigt.
                    Wenn der Adapter ohne Skript startet, dann liegt es wohl an einem deiner Skripte.
                    Dann musst du die der Reihe nach aktivieren und schauen, an welchem es liegt.
                    Meine Adapter und Widgets
                    Links im Profil
                      matrose65
                      @oliverio
                      Guten Morgen
                      Ich habe gestern Abend alle Scripte gestoppt und trotzdem kamen die Fehler.
                      • M matrose65
                        @oliverio
                        Guten Morgen
                        matrose65
                        Jetzt habe ich die ganze Sache neu aufgesetzt.
                        Also eine VM und den IOB.
                        Beim Start habe ich nur den Haken beim installieren vom Javascript Adapter gesetzt.
                        Und schon habe ich wieder 2 Fehler
                        2025-02-04 08:31:17.335 - info: host.iobroker iobroker.js-controller version 7.0.6 js-controller starting
                        2025-02-04 08:31:17.337 - info: host.iobroker Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                        2025-02-04 08:31:17.338 - info: host.iobroker hostname: iobroker, node: v20.18.2
                        2025-02-04 08:31:17.338 - info: host.iobroker ip addresses: 192.168.1.13 fe80::be24:11ff:fe8e:f452
                        2025-02-04 08:31:17.590 - info: host.iobroker connected to Objects and States
                        2025-02-04 08:31:17.607 - info: host.iobroker Node.js version has changed from unknown to 20.18.2
                        2025-02-04 08:31:17.617 - info: host.iobroker added notifications configuration of host
                        2025-02-04 08:31:17.619 - info: host.iobroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                        2025-02-04 08:31:17.728 - info: host.iobroker 3 instances found
                        2025-02-04 08:31:17.731 - info: host.iobroker starting 3 instances
                        2025-02-04 08:31:17.803 - info: host.iobroker instance system.adapter.admin.0 in version "7.4.10" started with pid 11091
                        2025-02-04 08:31:18.654 - info: admin.0 (11091) starting. Version 7.4.10 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.2, js-controller: 7.0.6
                        2025-02-04 08:31:18.670 - info: admin.0 (11091) requesting all objects
                        2025-02-04 08:31:18.748 - info: admin.0 (11091) received all objects
                        2025-02-04 08:31:18.756 - info: admin.0 (11091) Request actual repository...
                        2025-02-04 08:31:18.768 - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                        2025-02-04 08:31:18.770 - info: admin.0 (11091) socket.io server listening on port 8081
                        2025-02-04 08:31:18.772 - info: admin.0 (11091) http server listening on port 8081
                        2025-02-04 08:31:18.772 - info: admin.0 (11091) Use link "http://127.0.0.1:8081" to configure.
                        2025-02-04 08:31:18.936 - warn: admin.0 (11091) Repository cannot be read: Active repo - stable
                        2025-02-04 08:31:18.950 - warn: admin.0 (11091) Active repository "stable" cannot be read
                        2025-02-04 08:31:20.314 - info: admin.0 (11091) Repository received successfully.
                        2025-02-04 08:31:21.851 - info: host.iobroker instance system.adapter.backitup.0 in version "3.0.31" started with pid 11136
                        2025-02-04 08:31:22.555 - info: backitup.0 (11136) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.18.2, js-controller: 7.0.6
                        2025-02-04 08:31:22.579 - info: backitup.0 (11136) [iobroker] backup will be activated at 02:48 every 1 day(s)
                        2025-02-04 08:31:25.870 - info: host.iobroker instance system.adapter.discovery.0 in version "5.0.0" started with pid 11157
                        2025-02-04 08:31:26.515 - info: discovery.0 (11157) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.18.2, js-controller: 7.0.6
                        2025-02-04 08:37:22.917 - info: admin.0 (11091) ==> Connected system.user.admin from ::ffff:192.168.1.121
                        2025-02-04 08:39:00.544 - info: host.iobroker iobroker add javascript
                        2025-02-04 08:39:01.440 - info: host.iobroker iobroker NPM version: 10.8.2
                        2025-02-04 08:39:01.441 - info: host.iobroker iobroker Installing iobroker.javascript@8.8.3... (System call)
                        2025-02-04 08:39:20.335 - error: host.iobroker iobroker npm error code ERR_SSL_CIPHER_OPERATION_FAILEDnpm error 800C2FCEF07F0000:error:1C800066:Provider routines:ossl_gcm_stream_update:cipher operation failed:../deps/openssl/openssl/providers/implementations/ciphers/ciphercommon_gcm.c:325:npm errornpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-02-04T07_39_01_538Z-debug-0.log
                        2025-02-04 08:39:20.336 - error: host.iobroker iobroker host.iobroker Cannot install iobroker.javascript@8.8.3: 1
                        2025-02-04 08:39:21.346 - info: host.iobroker iobroker exit 25
                        2025-02-04 08:39:54.620 - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
                        2025-02-04 08:39:54.622 - info: admin.0 (11091) Got terminate signal TERMINATE_YOURSELF
                        2025-02-04 08:39:54.624 - info: admin.0 (11091) terminating http server on port 8081
                        2025-02-04 08:39:54.626 - info: admin.0 (11091) terminating
                        2025-02-04 08:39:54.626 - info: admin.0 (11091) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2025-02-04 08:39:54.663 - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
                        2025-02-04 08:39:55.127 - info: admin.0 (11091) terminating
                        2025-02-04 08:39:55.145 - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2025-02-04 08:39:58.295 - info: host.iobroker instance system.adapter.admin.0 in version "7.4.10" started with pid 11314
                        2025-02-04 08:39:59.125 - info: admin.0 (11314) starting. Version 7.4.10 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.2, js-controller: 7.0.6
                        2025-02-04 08:39:59.143 - info: admin.0 (11314) requesting all objects
                        2025-02-04 08:39:59.393 - info: admin.0 (11314) received all objects
                        2025-02-04 08:39:59.527 - info: admin.0 (11314) socket.io server listening on port 8081
                        2025-02-04 08:39:59.528 - info: admin.0 (11314) http server listening on port 8081
                        CodierknechtC OliverIOO HomoranH 3 Antworten Letzte Antwort
                        • M matrose65
                          Codierknecht
                          Wie installiert?
                          Hast Du SSL und/oder Authentication konfiguriert?
                          • M matrose65
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            @matrose65
                            Zeile 32 sieht nach einem ssl Fehler aus. Daher wird nicht oder nicht vollständig installiert.
                            Links im Profil
                              Wie installiert?
                              matrose65
                              @codierknecht
                              Ja habe zugriff über SSL
                              OliverIOO CodierknechtC 2 Antworten Letzte Antwort
                              • M matrose65
                                  matrose65
                                  Hallo
                                  Würde ich gern raussuchen, aber jetzt ist iob abgestürzt und startet auch gerade nicht neu
                                  • M matrose65
                                    @codierknecht
                                    OliverIOO Offline
                                    OliverIOO Offline
                                    OliverIO
                                    @matrose65
                                    Gemäß stackoverflow mach mal folgendes
                                    npm cache clear --force
                                    Wenn das nicht funktioniert, dann mal probieren die ganzen SSL Basis Zertifikate in deinem Image aktualisieren
                                    https://manpages.debian.org/buster/ca-certificates/update-ca-certificates.8.en.html
                                    Ich weiß ja nicht wie alt das Image ist beziehungsweise wann da das letzte Mal ein Update drüber gemacht worden ist
                                    Und natürlich auch in das Detaillog einmal reinschauen, eventuell gibt es da noch Hinweise
                                    Links im Profil
                                    • OliverIOO OliverIO
                                      @matrose65
                                      matrose65
                                      @oliverio
                                      Ich habe jetzt das obere ausgeführt.
                                      Jetzt habe ich den Javascript Adapter ohne Probleme installiert und auch gestartet.
                                      Soll ich nochwas versuchen, bevor ich die Sicherung zurückspiele?
                                      • M matrose65
                                        @codierknecht
                                        Codierknecht
                                        Nur so als Anmerkung:
                                        SSL im lokalen Netz ist eigentlich unnötig, solange das alles tatsächlich lokal bleibt. Eine Fehlerquelle weniger.
                                        Auch Authentifizierung am ioBroker in der Web-GUI kann man sich schenken, wenn nicht gerade irgendwelche Pupertisten im Haus sind die dem Vater gerne mal einen Streich spielen.
                                          matrose65
                                          @codierknecht
                                          Ok Danke Ja es soll alles lokal bleiben.
                                          Und das mit den Pupertisten hat sich schon eine Weile erledigt
