  4. Cannot find module '@iobroker/plugin-sentry
21 Beiträge 4 Kommentatoren 2.5k Aufrufe 3 Beobachtet
  • Toller TenyaT Offline
    Toller Tenya
    nach einem Update von IOBroker taucht im Log folgende Meldung auf:
    Couldnot add plugins: Cannot find module '@iobroker/plugin-sentry'Require stack:- /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/lib/PluginHandler.js- /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/index.js- /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js- /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/index.js- /opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js
    die Diagnose sagt folgendes:
    Script v.2024-10-19
    *** BASE SYSTEM ***
    Failed to connect to bus: No such file or directory
    OS is similar to:
    model name	: Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     11:00:05 up  3:02,  1 user,  load average: 0.31, 0.16, 0.09
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
    *** TIME AND TIMEZONES ***
    *** Users and Groups ***
    User that called 'iob diag':
    iobrokeruser
    HOME=/home/iobrokeruser
    GROUPS=iobrokeruser adm dialout sudo audio video plugdev users iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            2.9G        862M        1.7G         15M        366M        1.8G
    Swap:             0B          0B          0B
    Total:          2.9G        862M        1.7G
    Active iob-Instances: 	9
             2911 M total memory
              862 M used memory
              214 M active memory
              905 M inactive memory
             1682 M free memory
               44 M buffer memory
              321 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    top - 11:00:06 up  3:02,  1 user,  load average: 0.31, 0.16, 0.09
    Tasks:  99 total,   1 running,  98 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  3.1 us,  0.0 sy,  0.0 ni, 96.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   2911.4 total,   1682.3 free,    862.6 used,    366.5 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1819.4 avail Mem
    *** FAILED SERVICES ***
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs   10M     0   10M   0% /dev
    /dev/sda1      ext4      7.9G  5.3G  2.3G  70% /
    tmpfs          tmpfs     1.5G     0  1.5G   0% /dev/shm
    tmpfs          tmpfs     583M   16M  568M   3% /run
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     985M   80K  985M   1% /tmp
    tmpfs          tmpfs      50M  184K   50M   1% /var/log
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,noatime,lazytime
    /var:
    927M	/var/
    570M	/var/lib
    540M	/var/lib/unifi
    539M	/var/lib/unifi/db
    356M	/var/cache
    Archived and active journals take up 14.5M in the file system.
    /opt/iobroker/backups:
    25M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    263M	/opt/iobroker/iobroker-data/
    185M	/opt/iobroker/iobroker-data/files
    158M	/opt/iobroker/iobroker-data/files/admin.admin
    157M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    21M	/opt/iobroker/iobroker-data/objects.jsonl
    7.4M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
    7.0M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
    7.0M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
    7.0M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AD0K9IZZ-if00-port0
    /dev/serial/by-id/usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01063C1C-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.18.1
    /usr/bin/node 		v20.18.1
    /usr/bin/npm 		11.0.0
    /usr/bin/npx 		11.0.0
    /usr/bin/corepack 	0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u5 500
            500 https://deb.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 https://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    smarti              smarti (version: 7.0.6, hostname: smarti        , alive, uptime: 10923)
    Core adapters versions
    js-controller: 	7.0.6
    admin: 		7.4.7
    javascript: 	"javascript" not found
    nodejs modules from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : smarti                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : smarti                                   -  enabled
    + system.adapter.bmw.0                    : bmw                   : smarti                                   -  enabled
      system.adapter.daswetter.0              : daswetter             : smarti                                   -  enabled
    + system.adapter.discovery.0              : discovery             : smarti                                   -  enabled
      system.adapter.feiertage.0              : feiertage             : smarti                                   -  enabled
      system.adapter.ical.0                   : ical                  : smarti                                   -  enabled
      system.adapter.mielecloudservice.0      : mielecloudservice     : smarti                                   -  enabled
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : smarti                                   -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : smarti                                   -  enabled
      system.adapter.schoolfree.0             : schoolfree            : smarti                                   -  enabled
    + system.adapter.simple-api.0             : simple-api            : smarti                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : smarti                                   -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : smarti                                   -  enabled
    + instance is alive
    ioBroker-Repositories
    │ 0       │ 'stable' │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.4.7    , installed 7.4.7
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "bmw"          : 2.9.0    , installed 2.9.0
    Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "mielecloudservice": 6.5.7, installed 6.5.7
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
    Adapter    "schoolfree"   : 1.1.6    , installed 1.1.6
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Objects and States
    Objects: 	8894
    States: 	8147
    W: GPG error: https://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/3.6 Release: The following signatures were invalid: EXPKEYSIG 58712A2291FA4AD5 MongoDB 3.6 Release Signing Key <packaging@mongodb.com>
    Hit:1 https://deb.debian.org/debian bullseye InRelease
    Hit:2 https://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 https://deb.debian.org/debian-security bullseye-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 https://deb.debian.org/debian bullseye-backports InRelease
    Ign:6 https://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/3.6 InRelease
    Hit:8 http://repo.mongodb.org/apt/debian bullseye/mongodb-org/7.0 InRelease
    Hit:7 https://dl.ui.com/unifi/debian stable InRelease
    Hit:9 https://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/3.6 Release
    Get:10 https://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/3.6 Release.gpg [801 B]
    Ign:10 https://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/3.6 Release.gpg
    Fetched 801 B in 1s (720 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       11708      450/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11703      450/iobroker.js-con
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          9156       1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12487      387/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          9160       1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12836      520/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12498      387/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       15706      786/io.simple-api.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11493      255/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9157       1/init
    udp6       0      0 :::111                  :::*                                0          9163       1/init
    2024-12-17 11:00:30.096  - info: smartmeter.1 (690) Received 11 values, 3 updated
    2024-12-17 11:00:33.008  - info: host.smarti instance system.adapter.daswetter.0 in version "3.2.2" started with pid 18013
    2024-12-17 11:00:33.810  - error: Could not add plugins: Cannot find module '@iobroker/plugin-sentry'
    Require stack:
    2024-12-17 11:00:34.078  - info: daswetter.0 (18013) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
    2024-12-17 11:00:36.542  - info: smartmeter.0 (672) Received 7 values, 3 updated
    2024-12-17 11:00:41.057  - info: daswetter.0 (18013) still wrong data structure from server received! repaired...
    2024-12-17 11:00:42.841  - info: daswetter.0 (18013) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2024-12-17 11:00:43.008  - info: host.smarti instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 18653
    2024-12-17 11:00:43.350  - info: daswetter.0 (18013) cleaned everything up...
    2024-12-17 11:00:43.362  - info: host.smarti instance system.adapter.daswetter.0 having pid 18013 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-12-17 11:00:44.013  - error: Could not add plugins: Cannot find module '@iobroker/plugin-sentry'
    Require stack:
    2024-12-17 11:00:44.290  - info: netatmo-crawler.0 (18653) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.1, js-controller: 7.0.6
    2024-12-17 11:00:44.323  - info: netatmo-crawler.0 (18653) Getting data for stationid:70:ee:50:14:3f:98
    iob diag has finished.
    Press any key for a summary
    Kann man das sentry admin irgendwie nachinstallieren?
    HomoranH Thomas BraunT mcm1957M 3 Antworten Letzte Antwort
    • Toller TenyaT Toller Tenya
      Script v.2024-10-19
      *** BASE SYSTEM ***
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
      iobrokeruser
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:             0B          0B          0B
               2911 M total memory
                862 M used memory
                214 M active memory
               1682 M free memory
                 44 M buffer memory
                321 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      927M	/var/
      570M	/var/lib
      540M	/var/lib/unifi
      356M	/var/cache
      USB-Devices by-id:
      /usr/bin/npm 		11.0.0
      /usr/bin/npx 		11.0.0
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin: 		7.4.7
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	8894
      States: 	8147
      Pending Updates: 0
      Require stack:
      Require stack:
      @toller-tenya sagte in Cannot find module '@iobroker/plugin-sentry:
      was läuft denn da?
      auch iob diag scheint überfordert?
      auch da geht es kreuz und quer.
      mal ubuntu, mal Debian.
        Script v.2024-10-19
        *** BASE SYSTEM ***
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 4
        iobrokeruser
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:             0B          0B          0B
                 2911 M total memory
                  862 M used memory
                  214 M active memory
                 1682 M free memory
                   44 M buffer memory
                  321 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        /var:
        927M	/var/
        570M	/var/lib
        540M	/var/lib/unifi
        356M	/var/cache
        USB-Devices by-id:
        /usr/bin/npm 		11.0.0
        /usr/bin/npx 		11.0.0
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin: 		7.4.7
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	8894
        States: 	8147
        Pending Updates: 0
        Require stack:
        Require stack:
        *** BASE SYSTEM ***
        OS is similar to:
        Was ist das für eine seltsame Installation da bei dir?
        Schaut mir fast so aus, als wenn da kein systemd laufen würde.
        /usr/bin/npm 11.0.0
        passt auch nicht übereinander. npm v11 ist in nodejs 20.18.1 von nodesource nicht beigepackt.
        Die Paketquellen sind auch Kraut und Rüben, würde ich behaupten.
          Toller Tenya
          schrieb am zuletzt editiert von Toller Tenya
          Das OS ist ein DietPi als VM auf Proxmox.
          Mh dann werde ich wohl mal frisch installieren und das Backup einspielen
          • Thomas BraunT Online
            @toller-tenya
            Mit solchen exotischen Setups tust du dir keinen Gefallen.
              Script v.2024-10-19
              *** BASE SYSTEM ***
              OS is similar to:
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
              CPU threads: 4
              iobrokeruser
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:
              *** MEMORY ***
              Swap:             0B          0B          0B
                       2911 M total memory
                        862 M used memory
                        214 M active memory
                       1682 M free memory
                         44 M buffer memory
                        321 M swap cache
                          0 M total swap
                          0 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              /var:
              927M	/var/
              570M	/var/lib
              540M	/var/lib/unifi
              356M	/var/cache
              USB-Devices by-id:
              /usr/bin/npm 		11.0.0
              /usr/bin/npx 		11.0.0
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin: 		7.4.7
              Adapter State
              + instance is alive
              Objects and States
              Objects: 	8894
              States: 	8147
              Pending Updates: 0
              Require stack:
              Require stack:
              mcm1957M Online
              mcm1957M Online
              mcm1957
              @toller-tenya
              Ich tippe drauf dass dein problem durch den Adapter SMARTMETER ausgelöst wird.
              Ich frag mal bei @apollon77 nach ob das sein kann.
              Bin nicht siche - kann auch total falsch liegen.
              EDIT: Vermutung war falsch
              Support Repositoryverwaltung.
              LESEN - gute Forenbeitrage
              • mcm1957M mcm1957
                @toller-tenya
                mcm1957M Online
                mcm1957M Online
                mcm1957
                @Toller-Tenya
                Bitte zeig mal den Output von npm ls @iobroker/plugin-sentry (in /opt/iobroker)
                Toller TenyaT 1 Antwort Letzte Antwort
                • mcm1957M mcm1957
                  @Toller-Tenya
                  Toller Tenya
                  @mcm1957 der Output ist:
                  iobrokeruser@smarti:/opt/iobroker$ npm ls @iobroker/plugin-sentry
                  [sudo] password for iobrokeruser:
                  iobroker.inst@3.0.0 /opt/iobroker
                  └─┬ iobroker.js-controller@7.0.6
                    └── @iobroker/plugin-sentry@2.0.4
                  Soweit ich gelesen habe ist sentry dazu da um Fehler/Abbrüche in Instanzen zu Reporten. Der Smartmeter Adapter läuft jedoch einwandfrei bei mir.
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    @toller-tenya said in Cannot find module '@iobroker/plugin-sentry:
        iobrokeruser@smarti:/opt/iobroker$ npm ls @iobroker/plugin-sentry        [sudo] password for iobrokeruser:        iobroker.inst@3.0.0 /opt/iobroker        └─┬ iobroker.js-controller@7.0.6        └── @iobroker/plugin-sentry@2.0.4
                    Sieht für mich mal was den npm Tree betrifft normal aus.
                    Bezüglich smartmeter Adapter dürfte auch alles OK sein. Es gab ein Problem mit js-controller und Adaptern die Sentry explizit als Dependency drinnen hatten. Das war aber nur der Fall wenn sie das ioBroker sentry plugin explizit drinnen hatten. Das hat der smartmeter nicht - ergo alles OK. Meine Erinnerung war da nur teilweise richtig.
                    Was mich aber wundert ist die "[sudo] password ..." Abfrage an der Stelle.
                    @thomas-braun kannst du da was dazu segen?
                    Bezüglich allfällige Betriebssystemdinge bin ich aber eher raus.
                    Toller TenyaT Thomas BraunT 2 Antworten Letzte Antwort
                    • mcm1957M mcm1957
                      Toller Tenya
                      @mcm1957 Ich habe mir die Logs jetzt nochmal genauer angesehen.
                      Der Fehler tritt bei allen Adaptern mit scheduling auf.
                      Z.b. Netatmo und dasWetter
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        @toller-tenya
                        Bitte mal den vollständigen Log zumindest eines solchen Adapters (ab start) posten.
                        Der Log im Eröffnungspost wirkt als würde beim Start des js-controllers die Meldung kommen. Das scheint ja falsch zu sein.
                        • mcm1957M mcm1957
                          @toller-tenya
                          Toller Tenya
                          @mcm1957
                          HomoranH mcm1957M 2 Antworten Letzte Antwort
                            @mcm1957
                            @toller-tenya bitte als Text in code-tags posten
                              @mcm1957
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              @toller-tenya
                              Generell BITTE keine Bildchen sondern logs als Text uznter code tags posten.
                              Als Bild it der Test nicht kopierbar und weiterleitbar was die Analyse eher erschwert.
                              • mcm1957M mcm1957
                                @toller-tenya
                                Toller Tenya
                                @mcm1957 sorry :( hier nochmal als Text
                                host.smarti
                                2024-12-18 08:30:07.176	info	instance system.adapter.ical.0 having pid 112850 terminated with code 0 (NO_ERROR)
                                ical.0
                                2024-12-18 08:30:06.654	info	Terminated (NO_ERROR): Without reason
                                smartmeter.1
                                2024-12-18 08:30:05.084	info	Received 11 values, 3 updated
                                ical.0
                                2024-12-18 08:30:01.605	info	processing URL: Restmuell https://abfall.alzey-worms.de/WasteManagementAlzeyworms/WasteManagementServiceServlet?ApplicationName=Calendar&SubmitAction=sync&StandortID=1076237001&AboID=233065&Fra=P;R;B;S;C;L
                                ical.0
                                2024-12-18 08:30:01.170	info	starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.1, js-controller: 7.0.6
                                2024-12-18 08:30:00.882	error	Couldnot add plugins: Cannot find module '@iobroker/plugin-sentry'Require stack:- /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/lib/PluginHandler.js- /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/index.js- /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js- /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/index.js- /opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js
                                host.smarti
                                2024-12-18 08:30:00.019	info	instance system.adapter.ical.0 in version "1.16.1" started with pid 112850
                                • mcm1957M mcm1957
                                  @mcm1957 sagte in Cannot find module '@iobroker/plugin-sentry:
                                  Dazu kann ich sagen, das für mich das gesamte Basissystem krumm und schief aussieht. Da ist eine Anfrage zu Berechtigungen nebensächlich.
                                    Toller Tenya
                                    Es muss hier jetzt auch niemand großen Aufwand reinstecken.
                                    Ich werde zwischen den Jahren nochmal neu aufsetzen und ein Backup einspielen.
                                    Welche Linux Distribution ist zu bevorzugen?
                                      Ist für viele Geschmackssache, ich würde Debian 12 light (ohne Desktop) nehmen
                                        Als Serversystem: Debian 12 - Bookworm
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          @toller-tenya
                                          Danke für deine ausführlichen Infos.
                                          Leider (oder Gott sei Dank?) ist das Problem nicht trivial nachvollziehbar. Hab eben nochmal mit ical und identer js-congtroller Version gechecked - no problem.
                                          Rücksprache mit core Team hat auch nichts ergeben.
                                          Wenn zumutbar bitte wirklich zuerst das System auf aktuellen Stand bringen (= neu installieren wenn ich Thomas richtig verstanden habe) - dann sehen wir weiter.
