  4. Cannot find module '@iobroker/plugin-sentry
21 Beiträge 4 Kommentatoren 2.5k Aufrufe 3 Beobachtet
  • Thomas BraunT Online
    @toller-tenya
    Mit solchen exotischen Setups tust du dir keinen Gefallen.
    • Toller TenyaT Toller Tenya
      nach einem Update von IOBroker taucht im Log folgende Meldung auf:
      Couldnot add plugins: Cannot find module '@iobroker/plugin-sentry'Require stack:- /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/lib/PluginHandler.js- /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/index.js- /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js- /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/index.js- /opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js
      die Diagnose sagt folgendes:
      Script v.2024-10-19
      *** BASE SYSTEM ***
      Failed to connect to bus: No such file or directory
      OS is similar to:
      model name	: Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       11:00:05 up  3:02,  1 user,  load average: 0.31, 0.16, 0.09
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
      *** TIME AND TIMEZONES ***
      *** Users and Groups ***
      User that called 'iob diag':
      iobrokeruser
      HOME=/home/iobrokeruser
      GROUPS=iobrokeruser adm dialout sudo audio video plugdev users iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            2.9G        862M        1.7G         15M        366M        1.8G
      Swap:             0B          0B          0B
      Total:          2.9G        862M        1.7G
      Active iob-Instances: 	9
               2911 M total memory
                862 M used memory
                214 M active memory
                905 M inactive memory
               1682 M free memory
                 44 M buffer memory
                321 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      top - 11:00:06 up  3:02,  1 user,  load average: 0.31, 0.16, 0.09
      Tasks:  99 total,   1 running,  98 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  3.1 us,  0.0 sy,  0.0 ni, 96.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   2911.4 total,   1682.3 free,    862.6 used,    366.5 buff/cache
      MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1819.4 avail Mem
      *** FAILED SERVICES ***
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs   10M     0   10M   0% /dev
      /dev/sda1      ext4      7.9G  5.3G  2.3G  70% /
      tmpfs          tmpfs     1.5G     0  1.5G   0% /dev/shm
      tmpfs          tmpfs     583M   16M  568M   3% /run
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     985M   80K  985M   1% /tmp
      tmpfs          tmpfs      50M  184K   50M   1% /var/log
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,noatime,lazytime
      /var:
      927M	/var/
      570M	/var/lib
      540M	/var/lib/unifi
      539M	/var/lib/unifi/db
      356M	/var/cache
      Archived and active journals take up 14.5M in the file system.
      /opt/iobroker/backups:
      25M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      263M	/opt/iobroker/iobroker-data/
      185M	/opt/iobroker/iobroker-data/files
      158M	/opt/iobroker/iobroker-data/files/admin.admin
      157M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      21M	/opt/iobroker/iobroker-data/objects.jsonl
      7.4M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
      7.0M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
      7.0M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
      7.0M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AD0K9IZZ-if00-port0
      /dev/serial/by-id/usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01063C1C-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v20.18.1
      /usr/bin/node 		v20.18.1
      /usr/bin/npm 		11.0.0
      /usr/bin/npx 		11.0.0
      /usr/bin/corepack 	0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u5 500
              500 https://deb.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 https://deb.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      smarti              smarti (version: 7.0.6, hostname: smarti        , alive, uptime: 10923)
      Core adapters versions
      js-controller: 	7.0.6
      admin: 		7.4.7
      javascript: 	"javascript" not found
      nodejs modules from github: 	0
      Adapter State
      + system.adapter.admin.0                  : admin                 : smarti                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : smarti                                   -  enabled
      + system.adapter.bmw.0                    : bmw                   : smarti                                   -  enabled
        system.adapter.daswetter.0              : daswetter             : smarti                                   -  enabled
      + system.adapter.discovery.0              : discovery             : smarti                                   -  enabled
        system.adapter.feiertage.0              : feiertage             : smarti                                   -  enabled
        system.adapter.ical.0                   : ical                  : smarti                                   -  enabled
        system.adapter.mielecloudservice.0      : mielecloudservice     : smarti                                   -  enabled
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : smarti                                   -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : smarti                                   -  enabled
        system.adapter.schoolfree.0             : schoolfree            : smarti                                   -  enabled
      + system.adapter.simple-api.0             : simple-api            : smarti                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartmeter.0             : smartmeter            : smarti                                   -  enabled
      + system.adapter.smartmeter.1             : smartmeter            : smarti                                   -  enabled
      + instance is alive
      ioBroker-Repositories
      │ 0       │ 'stable' │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.4.7    , installed 7.4.7
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "bmw"          : 2.9.0    , installed 2.9.0
      Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "mielecloudservice": 6.5.7, installed 6.5.7
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
      Adapter    "schoolfree"   : 1.1.6    , installed 1.1.6
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Objects and States
      Objects: 	8894
      States: 	8147
      W: GPG error: https://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/3.6 Release: The following signatures were invalid: EXPKEYSIG 58712A2291FA4AD5 MongoDB 3.6 Release Signing Key <packaging@mongodb.com>
      Hit:1 https://deb.debian.org/debian bullseye InRelease
      Hit:2 https://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 https://deb.debian.org/debian-security bullseye-security InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:5 https://deb.debian.org/debian bullseye-backports InRelease
      Ign:6 https://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/3.6 InRelease
      Hit:8 http://repo.mongodb.org/apt/debian bullseye/mongodb-org/7.0 InRelease
      Hit:7 https://dl.ui.com/unifi/debian stable InRelease
      Hit:9 https://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/3.6 Release
      Get:10 https://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/3.6 Release.gpg [801 B]
      Ign:10 https://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/3.6 Release.gpg
      Fetched 801 B in 1s (720 B/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       11708      450/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11703      450/iobroker.js-con
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          9156       1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12487      387/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          9160       1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12836      520/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12498      387/sshd: /usr/sbin
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       15706      786/io.simple-api.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11493      255/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9157       1/init
      udp6       0      0 :::111                  :::*                                0          9163       1/init
      2024-12-17 11:00:30.096  - info: smartmeter.1 (690) Received 11 values, 3 updated
      2024-12-17 11:00:33.008  - info: host.smarti instance system.adapter.daswetter.0 in version "3.2.2" started with pid 18013
      2024-12-17 11:00:33.810  - error: Could not add plugins: Cannot find module '@iobroker/plugin-sentry'
      Require stack:
      2024-12-17 11:00:34.078  - info: daswetter.0 (18013) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
      2024-12-17 11:00:36.542  - info: smartmeter.0 (672) Received 7 values, 3 updated
      2024-12-17 11:00:41.057  - info: daswetter.0 (18013) still wrong data structure from server received! repaired...
      2024-12-17 11:00:42.841  - info: daswetter.0 (18013) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2024-12-17 11:00:43.008  - info: host.smarti instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 18653
      2024-12-17 11:00:43.350  - info: daswetter.0 (18013) cleaned everything up...
      2024-12-17 11:00:43.362  - info: host.smarti instance system.adapter.daswetter.0 having pid 18013 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-12-17 11:00:44.013  - error: Could not add plugins: Cannot find module '@iobroker/plugin-sentry'
      Require stack:
      2024-12-17 11:00:44.290  - info: netatmo-crawler.0 (18653) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.1, js-controller: 7.0.6
      2024-12-17 11:00:44.323  - info: netatmo-crawler.0 (18653) Getting data for stationid:70:ee:50:14:3f:98
      iob diag has finished.
      Press any key for a summary
      Kann man das sentry admin irgendwie nachinstallieren?
      mcm1957M Online
      mcm1957M Online
      mcm1957
      @toller-tenya
      Ich tippe drauf dass dein problem durch den Adapter SMARTMETER ausgelöst wird.
      Ich frag mal bei @apollon77 nach ob das sein kann.
      Bin nicht siche - kann auch total falsch liegen.
      EDIT: Vermutung war falsch
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • mcm1957M mcm1957
        @toller-tenya
        mcm1957M Online
        mcm1957M Online
        mcm1957
        @Toller-Tenya
        Bitte zeig mal den Output von npm ls @iobroker/plugin-sentry (in /opt/iobroker)
        Toller TenyaT 1 Antwort Letzte Antwort
        • mcm1957M mcm1957
          @Toller-Tenya
          Toller TenyaT Offline
          Toller Tenya
          schrieb am zuletzt editiert von Toller Tenya
          @mcm1957 der Output ist:
          iobrokeruser@smarti:/opt/iobroker$ npm ls @iobroker/plugin-sentry
          [sudo] password for iobrokeruser:
          iobroker.inst@3.0.0 /opt/iobroker
          └─┬ iobroker.js-controller@7.0.6
            └── @iobroker/plugin-sentry@2.0.4
          Soweit ich gelesen habe ist sentry dazu da um Fehler/Abbrüche in Instanzen zu Reporten. Der Smartmeter Adapter läuft jedoch einwandfrei bei mir.
            mcm1957M Online
            mcm1957M Online
            mcm1957
            @toller-tenya said in Cannot find module '@iobroker/plugin-sentry:
        iobrokeruser@smarti:/opt/iobroker$ npm ls @iobroker/plugin-sentry        [sudo] password for iobrokeruser:        iobroker.inst@3.0.0 /opt/iobroker        └─┬ iobroker.js-controller@7.0.6        └── @iobroker/plugin-sentry@2.0.4
            Sieht für mich mal was den npm Tree betrifft normal aus.
            Bezüglich smartmeter Adapter dürfte auch alles OK sein. Es gab ein Problem mit js-controller und Adaptern die Sentry explizit als Dependency drinnen hatten. Das war aber nur der Fall wenn sie das ioBroker sentry plugin explizit drinnen hatten. Das hat der smartmeter nicht - ergo alles OK. Meine Erinnerung war da nur teilweise richtig.
            Was mich aber wundert ist die "[sudo] password ..." Abfrage an der Stelle.
            @thomas-braun kannst du da was dazu segen?
            Bezüglich allfällige Betriebssystemdinge bin ich aber eher raus.
            Toller TenyaT Thomas BraunT 2 Antworten Letzte Antwort
            • mcm1957M mcm1957
              Toller Tenya
              @mcm1957 Ich habe mir die Logs jetzt nochmal genauer angesehen.
              Der Fehler tritt bei allen Adaptern mit scheduling auf.
              Z.b. Netatmo und dasWetter
                mcm1957M Online
                mcm1957M Online
                mcm1957
                @toller-tenya
                Bitte mal den vollständigen Log zumindest eines solchen Adapters (ab start) posten.
                Der Log im Eröffnungspost wirkt als würde beim Start des js-controllers die Meldung kommen. Das scheint ja falsch zu sein.
                • mcm1957M mcm1957
                  @toller-tenya
                  Toller Tenya
                  @mcm1957
                  HomoranH mcm1957M 2 Antworten Letzte Antwort
                    @mcm1957
                    @toller-tenya bitte als Text in code-tags posten
                      @mcm1957
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      @toller-tenya
                      Generell BITTE keine Bildchen sondern logs als Text uznter code tags posten.
                      Als Bild it der Test nicht kopierbar und weiterleitbar was die Analyse eher erschwert.
                      • mcm1957M mcm1957
                        @toller-tenya
                        Toller Tenya
                        @mcm1957 sorry :( hier nochmal als Text
                        host.smarti
                        2024-12-18 08:30:07.176	info	instance system.adapter.ical.0 having pid 112850 terminated with code 0 (NO_ERROR)
                        ical.0
                        2024-12-18 08:30:06.654	info	Terminated (NO_ERROR): Without reason
                        smartmeter.1
                        2024-12-18 08:30:05.084	info	Received 11 values, 3 updated
                        ical.0
                        2024-12-18 08:30:01.605	info	processing URL: Restmuell https://abfall.alzey-worms.de/WasteManagementAlzeyworms/WasteManagementServiceServlet?ApplicationName=Calendar&SubmitAction=sync&StandortID=1076237001&AboID=233065&Fra=P;R;B;S;C;L
                        ical.0
                        2024-12-18 08:30:01.170	info	starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.1, js-controller: 7.0.6
                        2024-12-18 08:30:00.882	error	Couldnot add plugins: Cannot find module '@iobroker/plugin-sentry'Require stack:- /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/lib/PluginHandler.js- /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/index.js- /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js- /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/index.js- /opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js
                        host.smarti
                        2024-12-18 08:30:00.019	info	instance system.adapter.ical.0 in version "1.16.1" started with pid 112850
                        • mcm1957M mcm1957
                          @mcm1957 sagte in Cannot find module '@iobroker/plugin-sentry:
                          Dazu kann ich sagen, das für mich das gesamte Basissystem krumm und schief aussieht. Da ist eine Anfrage zu Berechtigungen nebensächlich.
                          • Toller TenyaT Offline
                            Toller Tenya
                            Es muss hier jetzt auch niemand großen Aufwand reinstecken.
                            Ich werde zwischen den Jahren nochmal neu aufsetzen und ein Backup einspielen.
                            Welche Linux Distribution ist zu bevorzugen?
                            HomoranH Thomas BraunT mcm1957M 3 Antworten Letzte Antwort
                              @toller-tenya sagte in Cannot find module '@iobroker/plugin-sentry:
                              Ist für viele Geschmackssache, ich würde Debian 12 light (ohne Desktop) nehmen
                                Als Serversystem: Debian 12 - Bookworm
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  @toller-tenya
                                  Danke für deine ausführlichen Infos.
                                  Leider (oder Gott sei Dank?) ist das Problem nicht trivial nachvollziehbar. Hab eben nochmal mit ical und identer js-congtroller Version gechecked - no problem.
                                  Rücksprache mit core Team hat auch nichts ergeben.
                                  Wenn zumutbar bitte wirklich zuerst das System auf aktuellen Stand bringen (= neu installieren wenn ich Thomas richtig verstanden habe) - dann sehen wir weiter.
                                  • mcm1957M mcm1957
                                    @toller-tenya
                                    Bei den vielen Ungereimtheiten würde ich das dringend empfehlen.
