  4. js-controller Lucy (Version 7.0) jetzt im Stable Repository
backupdynamic notificationsjs-controllerlucystabletest
116 Beiträge 35 Kommentatoren 43.8k Aufrufe 29 Beobachtet
    BugBuster1701
    Nachdem ich auf 7.0.3 aktualisiert habe, bekomme ich Probleme mit meinem Heitzungsthermostat.
    Ich musste die Batterien tauschen und habe den dann neu gekoppelt. Dabei kommen Fehlermeldungen mit Hinweis auf js-controller 7.0.
    Das Thermostat koppelt war, ist aber nicht mehr steuerbar.
    Start Kopplung
    2024-11-30 16:16:24.485 - info: zigbee.0 (1924) Starting interview of '0x847127fffe11dad6'
    2024-11-30 16:16:24.734 - info: zigbee.0 (1924) Device '0x847127fffe11dad6' announced itself
    2024-11-30 16:16:24.891 - warn: zigbee.0 (1924) Object 847127fffe11dad6.mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" This will throw an error up from js-controller version 7.0.0!
    2024-11-30 16:16:24.893 - warn: zigbee.0 (1924) Object 847127fffe11dad6.mode_force is invalid: obj.common.states has an invalid type! Expected "object", received "string" This will throw an error up from js-controller version 7.0.0!
    2024-11-30 16:16:25.034 - warn: zigbee.0 (1924) Object zigbee.0.847127fffe11dad6.mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" This will throw an error up from js-controller version 7.0.0!
    2024-11-30 16:16:25.035 - warn: zigbee.0 (1924) Object zigbee.0.847127fffe11dad6.mode_force is invalid: obj.common.states has an invalid type! Expected "object", received "string" This will throw an error up from js-controller version 7.0.0!
    2024-11-30 16:16:26.001 - info: zigbee.0 (1924) Successfully interviewed '0x847127fffe11dad6', device has successfully been paired
    2024-11-30 16:16:26.001 - info: zigbee.0 (1924) Device '0x847127fffe11dad6' is supported, identified as: Siterwell Radiator valve with thermostat (GS361A-H04)
    2024-11-30 16:17:19.580 - info: zigbee.0 (1924) Zigbee: stop joining
    2024-11-30 16:17:43.286 - info: zigbee.0 (1924) -> Configuring 0x847127fffe11dad6 TS0601
    Start Reconfigure
    2024-11-30 16:17:43.290 - warn: zigbee.0 (1924) DeviceConfigure: 0x847127fffe11dad6 TS0601 Failed to configure. When device works is all fine when not wake up the device and check again
    Was nun? Ist mein altes Zigbee Thermostat zu alt und nun inkompatible mit js-controller 7?
    B 1 Antwort Letzte Antwort
    • B BugBuster1701
      Start Kopplung
      Start Reconfigure
      BugBuster1701
      Nachtrag: Habe baugleiches Thermostat gewechselt. Die Fehlermeldungen bleiben, das ist aber trotzdem steuerbar. Macht die Sache nicht einfacher.
      • B BugBuster1701
        foxriver76F Offline
        foxriver76F Offline
        foxriver76
        @bugbuster1701 die Controller Warnung hat nix damit zu.
        Videotutorials & mehr
        jolicJ 1 Antwort Letzte Antwort
        • foxriver76F foxriver76
          jolicJ Online
          jolicJ Online
          jolic
          schrieb am zuletzt editiert von jolic
          Problem mit Snapshot-Update im VIS2 nach Upgrade des js-Controllers auf Version 7.0.3
          Hallo, ich habe im VIS2 für eine Kamera ein Basic Image-Widget mit der URL zum Snapshot meiner Kamera eingebunden. Die Snapshot-URL funktioniert einwandfrei, und ich erhalte alle 2 Sekunden ein aktuelles Bild, da ich die Updatezeit(ms) auf 2000 eingestellt habe, um eine angemessene Bildaktualisierung zu erhalten.
          Seit dem gestrigen Update des js-Controllers von Version 6.0.11 auf 7.0.3 funktioniert diese Updatezeit (basic_refreshInterval) jedoch nicht mehr. Das Bild wird nur noch aktualisiert, wenn ich die gesamte Seite neu lade. Getestet mit Fully Browser 1.53, Google Chrome 131.0.6778.86, Brave 1.73.91 und ioBroker Visu 1.3.0.
          Kann dies jemand bestätigen (möglicherweise ein Bug) oder kennt eine Lösung dafür?
          Das Update wurde erfolgreich über die Konsole durchgeführt, keine Fehler unter Protokolle, anbei meine aktuelle Konfiguration:
          PlatformBetriebssystem:linux
          Architektur:arm64
          CPUs:4
          Geschwindigkeit:1500 MHz
          Modell:Cortex-A72
          RAM:7.6 GB
          System-Betriebszeit:23:33:38
          Node.js:v20.18.0
          time:1732988101669
          timeOffset:-60
          NPM:10.9.0
          Adapter-Anzahl:547
          Datenträgergröße:916.6 GB
          Freier Festplattenspeicher:909.7 GB
          Aktive Instanzen:14
          Pfad:/opt/iobroker/
          Betriebszeit:23:33:21
          aktiv:true
          _nodeCurrent:20.18.0
          _nodeNewest:20.18.1
          _nodeNewestNext:20.18.1
          _npmCurrent:10.9.0
          _npmNewest:10.8.2
          _npmNewestNext:10.8.2
          PS: Die Node.js-Version 20.18.1 wird bald für mein OS verfügbar sein. Ich vermute, dass dies kaum mit dem aktuellen Problem zusammenhängt.
          Nachtrag: Sorry, da lag ich wohl falsch! Ich bin zurück auf Version 6.0.11, aber das Problem bleibt bestehen. In den letzten Tagen habe ich eigentlich nichts am ioBroker verändert, daher hatte ich vermutet, dass es am js-Controller liegt. Ich werde meine Logs noch einmal genauer durchsehen – möglicherweise hängt es mit einem Systemupdate zusammen.
          ioBroker | RPi 4 (SSD) | EndeavourOS (headless)
          • jolicJ jolic
            Architektur:arm64
            CPUs:4
            Modell:Cortex-A72
            RAM:7.6 GB
            Node.js:v20.18.0
            time:1732988101669
            timeOffset:-60
            NPM:10.9.0
            Adapter-Anzahl:547
            Aktive Instanzen:14
            Pfad:/opt/iobroker/
            aktiv:true
            _nodeNewest:20.18.1
            _npmCurrent:10.9.0
            _npmNewest:10.8.2
            Thomas BraunT Offline
            @jolic sagte in js-controller Lucy (Version 7.0) jetzt im Stable Repository:
            Und wie und wo und womit bist du da genau unterwegs?
            iob diag
            anschauen.
              iob diag
              anschauen.
              jolicJ Online
              jolicJ Online
              jolic
              Hallo Thomas, wie du vielleicht aus dem alten Thread iobroker-auf-manjaro-und-raspberry-4 weißt, nutze ich Manjaro ARM auf einem Pi4.
              Der "iob fix" funktioniert nach wie vor wie im Thread beschrieben, mit Ausnahme der Debian-Warnungen wie „apt-get: Befehl nicht gefunden“ hier mit curl gestartet:
              [pi4m@manjaro-arm ~]$ curl -fsSL https://iobroker.net/fix.sh | bash -
              library: loaded
              Library version=2024-10-22
                  Welcome to the ioBroker installation fixer!
                  Script version: 2024-10-22
                  You might need to enter your password a couple of times.
                  Installing prerequisites (1/5)
              sudo: apt-get: Befehl nicht gefunden
              Installed acl
              Installed sudo
              Installed libcap2-bin
              Installed build-essential
              Installed gcc
              Installed make
              Installed libavahi-compat-libdnssd-dev
              Installed libudev-dev
              Installed libpam0g-dev
              Installed pkg-config
              Installed git
              Installed curl
              Installed unzip
              Installed distro-info
              Installed libcairo2-dev
              Installed libpango1.0-dev
              Installed libjpeg-dev
              Installed libgif-dev
              Installed librsvg2-dev
              Installed libpixman-1-dev
              Installed net-tools
              Installed cmake
              Installed polkitd
              Installed passwd
                  Checking ioBroker user and directory permissions (2/5)
              Created /etc/sudoers.d/iobroker
                  Check and cleanup npm temporary directories (3/5)
              Done.
                  Database maintenance (4/5)
              Checking for uncompressed JSONL databases... This might take a while!
              Compressing /opt/iobroker/iobroker-data/states.jsonl
              Compressing /opt/iobroker/iobroker-data/objects.jsonl
              Compressed 2 JSONL files. Done
                  Checking autostart (5/5)
              Enabling autostart...
              Autostart enabled!
              Der "iob diag" hatte im August auch funktioniert, heute erhalte ich diese Meldung:
              *** iob diag is starting up, please wait ***
              iob diag needs to be updated. Please execute 'iobroker fix' first.
              Mir ist bewusst, dass ioBroker offiziell nur Debian unterstützt und supportet. Aber vielleicht hast du trotzdem eine Idee, wie ich „iob diag“ unter Manjaro wieder zum Laufen bringen könnte?
              • jolicJ jolic
                library: loaded
                Installed acl
                Installed sudo
                Installed gcc
                Installed make
                Installed git
                Installed curl
                Installed unzip
                Installed net-tools
                Installed cmake
                Installed polkitd
                Installed passwd
                Done.
                Autostart enabled!
                Hab ich.
                pacman -S distro-info
                und es sollte laufen.
                Mein EndeavourOS meldet sich nämlich so:
                *** BASE SYSTEM ***
                 Static hostname: roamer
                       Icon name: computer-laptop
                         Chassis: laptop 💻
                Operating System: EndeavourOS
                          Kernel: Linux 6.12.1-arch1-1
                    Architecture: x86-64
                 Hardware Vendor: Lenovo
                  Hardware Model: Lenovo V17 G4 IRU
                Firmware Version: MCCN29WW
                   Firmware Date: Sun 2024-09-29
                    Firmware Age: 2month 2d
                OS is similar to: arch
                model name      : 13th Gen Intel(R) Core(TM) i5-1335U
                Docker          : false
                Virtualization  : none
                Kernel          : x86_64
                Userland        : 64 bit
                Systemuptime and Load:
                 23:42:06 up 14:44,  2 users,  load average: 0.22, 0.33, 0.37
                CPU threads: 12
                *** LIFE CYCLE STATUS ***
                Unknown release codenamed 'rolling'. Please check yourself if the Operating System is actively maintained.
                  Hab ich.
                  *** BASE SYSTEM ***
                           Chassis: laptop 💻
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                  CPU threads: 12
                  jolicJ Online
                  jolicJ Online
                  jolic
                  Prima! langt die SUMMARY?
                  Nachtrag, wahrscheinlich nein, hier alles:
                  Script v.2024-10-19
                  *** BASE SYSTEM ***
                   Static hostname: manjaro-arm
                         Icon name: computer
                  Operating System: Manjaro ARM Linux
                            Kernel: Linux 6.6.59-1-MANJARO-RPI4
                      Architecture: arm64
                  Model           : Raspberry Pi 4 Model B Rev 1.5
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                   23:47:13 up  1:04,  2 users,  load average: 0.32, 0.33, 0.28
                  CPU threads: 4
                  Unknown release codenamed 'n/a'. Please check yourself if the Operating System is actively maintained.
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** TIME AND TIMEZONES ***
                                 Local time: Sat 2024-11-30 23:47:13 CET
                             Universal time: Sat 2024-11-30 22:47:13 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  pi4m
                  HOME=/home/pi4m
                  GROUPS=sys network power users video storage lp input audio wheel pi4m iobroker
                  js-controller is not running
                  *** DISPLAY-SERVER SETUP ***
                  Display-Server: false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            8.2G        302M        6.3G        3.1M        1.7G        7.9G
                  Swap:            12G          0B         12G
                  Total:           20G        302M         18G
                  Active iob-Instances:   1
                           7806 M total memory
                            289 M used memory
                           1130 M active memory
                            460 M inactive memory
                           5989 M free memory
                            118 M buffer memory
                           1519 M swap cache
                          11709 M total swap
                              0 M used swap
                          11709 M free swap
                  top - 23:47:14 up  1:04,  2 users,  load average: 0.32, 0.33, 0.28
                  Tasks: 160 total,   3 running, 157 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  2.1 us,  4.2 sy,  0.0 ni, 93.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   7806.6 total,   5988.0 free,    290.4 used,   1638.3 buff/cache
                  MiB Swap:  11710.0 total,  11710.0 free,      0.0 used.   7516.3 avail Mem
                  *** FAILED SERVICES ***
                    UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                  * iobroker.service loaded failed failed ioBroker Server
                  Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                          ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                          SUB    -> The low-level unit activation state, values depend on unit type.
                  1 loaded units listed.
                  *** DMESG CRITICAL ERRORS ***
                  No critical errors detected
                  *** FILESYSTEM ***
                  dev            devtmpfs  3.8G     0  3.8G   0% /dev
                  run            tmpfs     3.9G  1.1M  3.9G   1% /run
                  /dev/sda2      ext4      917G  7.2G  873G   1% /
                  tmpfs          tmpfs     3.9G  1.9M  3.9G   1% /dev/shm
                  tmpfs          tmpfs     3.9G   20K  3.9G   1% /tmp
                  tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                  tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-network-generator.service
                  tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-udev-load-credentials.service
                  tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup-dev-early.service
                  tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysctl.service
                  tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup-dev.service
                  tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-networkd.service
                  tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-vconsole-setup.service
                  /dev/sda1      vfat      458M   51M  407M  12% /boot
                  tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup.service
                  tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                  tmpfs          tmpfs     781M  4.0K  781M   1% /run/user/1000
                  [Sat Nov 30 22:42:51 2024] EXT4-fs (sda2): mounted filesystem 4f15f9f9-8c71-4493-986e-d850a02a0242 r/w with ordered data mode. Quota mode: none.
                  [Sat Nov 30 22:42:53 2024] EXT4-fs (sda2): re-mounted 4f15f9f9-8c71-4493-986e-d850a02a0242 r/w. Quota mode: none.
                  Show mounted filesystems:
                  TARGET  SOURCE    FSTYPE OPTIONS
                  /       /dev/sda2 ext4   rw,noatime
                  `-/boot /dev/sda1 vfat   rw,nodev,noexec,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,errors=remount-ro
                  /var:
                  526M    /var/
                  498M    /var/log
                  497M    /var/log/journal/256940e9bd0e49078df2cc99156a71f7
                  23M     /var/lib/pacman
                  Archived and active journals take up 496.5M in the file system.
                  /opt/iobroker/backups:
                  11M     /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  1.1G    /opt/iobroker/iobroker-data/
                  950M    /opt/iobroker/iobroker-data/files
                  617M    /opt/iobroker/iobroker-data/files/javascript.admin
                  560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                  558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                  24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
                  24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
                  24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
                  13M     /opt/iobroker/iobroker-data/objects.jsonl
                  USB-Devices by-id:
                  No Devices found 'by-id'
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.18.0
                  /usr/bin/node           v20.18.0
                  /usr/bin/npm            10.9.0
                  /usr/bin/npx            10.9.0
                  /usr/bin/corepack       0.29.3
                  No problems detected
                  Errors in npm tree: 0
                  *** ioBroker-Installation ***
                  ioBroker Status
                  iobroker is not running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  manjaro-arm         manjaro-arm (version: 7.0.3, hostname: manjaro-arm   , alive, uptime: 619)
                  Core adapters versions
                  js-controller:  7.0.3
                  admin:          7.1.5
                  javascript:     8.8.3
                  nodejs modules from github:     0
                  Adapter State
                    system.adapter.admin.0                  : admin                 : manjaro-arm                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                    system.adapter.backitup.0               : backitup              : manjaro-arm                              -  enabled
                    system.adapter.dwd.0                    : dwd                   : manjaro-arm                              -  enabled
                    system.adapter.email.0                  : email                 : manjaro-arm                              -  enabled
                    system.adapter.fullybrowser.0           : fullybrowser          : manjaro-arm                              -  enabled
                    system.adapter.ical.0                   : ical                  : manjaro-arm                              -  enabled
                    system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : manjaro-arm                              - disabled
                    system.adapter.javascript.0             : javascript            : manjaro-arm                              -  enabled
                    system.adapter.mqtt.0                   : mqtt                  : manjaro-arm                              -  enabled, port: 1883, bind: 0.0.0.0
                    system.adapter.ping.0                   : ping                  : manjaro-arm                              -  enabled
                    system.adapter.shelly.0                 : shelly                : manjaro-arm                              -  enabled, port: 1882, bind: 0.0.0.0
                    system.adapter.simple-api.0             : simple-api            : manjaro-arm                              -  enabled, port: 8087, bind: 192.168.0.164, run as: admin
                    system.adapter.tr-064.0                 : tr-064                : manjaro-arm                              -  enabled
                    system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: manjaro-arm                              -  enabled
                    system.adapter.vis-2.0                  : vis-2                 : manjaro-arm                              -  enabled
                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : manjaro-arm                              -  enabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : manjaro-arm                              -  enabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : manjaro-arm                              -  enabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : manjaro-arm                              -  enabled
                    system.adapter.vis.0                    : vis                   : manjaro-arm                              -  enabled
                    system.adapter.web.0                    : web                   : manjaro-arm                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    system.adapter.yahka.0                  : yahka                 : manjaro-arm                              -  enabled
                    system.adapter.zwave2.0                 : zwave2                : manjaro-arm                              -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  │ (index) │ name               │ url                                                     │ auto upgrade │
                  │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                  │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                  Upgrade policy: none
                  Installed ioBroker-Instances
                  Adapter    "admin"        : 7.1.5    , installed 7.1.5
                  Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                  Adapter    "email"        : 1.3.1    , installed 1.3.1
                  Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                  Adapter    "ical"         : 1.16.1   , installed 1.16.1
                  Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                  Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                  Controller "js-controller": 7.0.3    , installed 7.0.3
                  Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                  Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                  Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                  Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                  Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                  Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                  Adapter    "ws"           : 2.6.2    , installed 2.6.2
                  Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                  Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
                  Objects and States
                  Objects:        2325
                  States:         1800
                  No Debian-based Linux detected.
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      968        5055       563/pihole-FTL
                  tcp        0      0 127.0.0.1:5335          0.0.0.0:*               LISTEN      0          5975       450/unbound
                  tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      968        5051       563/pihole-FTL
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4094       552/sshd: /usr/bin/
                  tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          3973       472/lighttpd
                  tcp6       0      0 ::1:4711                :::*                    LISTEN      968        5056       563/pihole-FTL
                  tcp6       0      0 :::53                   :::*                    LISTEN      968        5053       563/pihole-FTL
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          4096       552/sshd: /usr/bin/
                  udp        0      0 0.0.0.0:53              0.0.0.0:*                           968        5050       563/pihole-FTL
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          6685       453/dhcpcd: [networ
                  udp        0      0 127.0.0.1:5335          0.0.0.0:*                           0          5974       450/unbound
                  udp6       0      0 :::53                   :::*                                968        5052       563/pihole-FTL
                  udp6       0      0 :::546                  :::*                                0          6687       453/dhcpcd: [networ
                  2024-11-30 23:06:39.942  - info: host.manjaro-arm instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
                  2024-11-30 23:06:40.004  - info: host.manjaro-arm instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
                  2024-11-30 23:06:40.004  - info: host.manjaro-arm instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                  2024-11-30 23:06:40.124  - info: host.manjaro-arm stopInstance timeout system.adapter.javascript.0 killing pid 1637
                  2024-11-30 23:06:40.125  - info: host.manjaro-arm stopInstance timeout system.adapter.ping.0 killing pid 1727
                  2024-11-30 23:06:40.125  - info: host.manjaro-arm stopInstance timeout system.adapter.zwave2.0 killing pid 1769
                  2024-11-30 23:06:40.126  - info: host.manjaro-arm stopInstance timeout system.adapter.web.0 killing pid 1875
                  2024-11-30 23:06:40.262  - info: host.manjaro-arm instance system.adapter.email.0 terminated with code 0 (NO_ERROR)
                  2024-11-30 23:06:40.263  - info: host.manjaro-arm instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                  2024-11-30 23:06:40.286  - info: host.manjaro-arm instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                  2024-11-30 23:06:40.343  - info: host.manjaro-arm instance system.adapter.fullybrowser.0 terminated with code 0 (NO_ERROR)
                  2024-11-30 23:06:40.343  - info: host.manjaro-arm All instances are stopped.
                  2024-11-30 23:06:40.544  - warn: host.manjaro-arm instance system.adapter.javascript.0 terminated due to SIGKILL
                  2024-11-30 23:06:40.544  - info: host.manjaro-arm instance system.adapter.javascript.0 terminated with code null ()
                  2024-11-30 23:06:40.545  - info: host.manjaro-arm All instances are stopped.
                  2024-11-30 23:06:40.545  - warn: host.manjaro-arm instance system.adapter.ping.0 terminated due to SIGKILL
                  2024-11-30 23:06:40.545  - info: host.manjaro-arm instance system.adapter.ping.0 terminated with code null ()
                  2024-11-30 23:06:40.585  - warn: host.manjaro-arm instance system.adapter.zwave2.0 terminated due to SIGKILL
                  2024-11-30 23:06:40.585  - info: host.manjaro-arm instance system.adapter.zwave2.0 terminated with code null ()
                  2024-11-30 23:06:40.585  - info: host.manjaro-arm All instances are stopped.
                  2024-11-30 23:06:40.586  - warn: host.manjaro-arm instance system.adapter.web.0 terminated due to SIGKILL
                  2024-11-30 23:06:40.586  - info: host.manjaro-arm instance system.adapter.web.0 terminated with code null ()
                  2024-11-30 23:06:40.586  - info: host.manjaro-arm All instances are stopped.
                  2024-11-30 23:06:40.750  - info: host.manjaro-arm terminated
                                          v.2024-10-19
                         Icon name: computer
                      Architecture: arm64
                  Installation:           native
                  Kernel:                 aarch64
                  Userland:               64 bit
                  Timezone:               Europe/Berlin (CET, +0100)
                  User-ID:                1000
                  Boot Target:            multi-user.target
                  Pending OS-Updates:     0
                  Pending iob updates:    0
                  Nodejs-Installation:
                  /usr/bin/npm            10.9.0
                  /usr/bin/npx            10.9.0
                  Recommended versions are nodejs 20.18.1 and npm 10.8.2
                  nodeJS installation is correct
                  MEMORY:
                  Mem:            8.2G        297M        6.3G        3.1M        1.7G        7.9G
                  Swap:            12G          0B         12G
                  Total:           20G        297M         18G
                  ioBroker Core:          js-controller           7.0.3
                                          admin                   7.1.5
                  ioBroker Status:        iobroker is not running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                2325
                  States:                 1800
                  Size of iob-Database:
                  376K    /opt/iobroker/iobroker-data/states.jsonl
                  • jolicJ jolic
                    Script v.2024-10-19
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi4m
                    HOME=/home/pi4m
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:            12G          0B         12G
                    Total:           20G        302M         18G
                             7806 M total memory
                              289 M used memory
                             5989 M free memory
                              118 M buffer memory
                             1519 M swap cache
                            11709 M total swap
                                0 M used swap
                            11709 M free swap
                    *** FILESYSTEM ***
                    /var:
                    526M    /var/
                    498M    /var/log
                    23M     /var/lib/pacman
                    USB-Devices by-id:
                    /usr/bin/npm            10.9.0
                    /usr/bin/npx            10.9.0
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.1.5
                    javascript:     8.8.3
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        2325
                    States:         1800
                                            v.2024-10-19
                           Icon name: computer
                        Architecture: arm64
                    Kernel:                 aarch64
                    Userland:               64 bit
                    User-ID:                1000
                    /usr/bin/npm            10.9.0
                    /usr/bin/npx            10.9.0
                    MEMORY:
                    Swap:            12G          0B         12G
                    Total:           20G        297M         18G
                                            admin                   7.1.5
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                2325
                    States:                 1800
                    @jolic
                    Außer, das der ioBroker nicht läuft, sieht man da halt nicht viel.
                      @jolic
                      jolicJ Online
                      jolicJ Online
                      jolic
                      Ja, hatte zu schnell "Press any key for a summary" gedrückt, habe oben alles hinzugefügt. Erkennst du dort ein Problem?
                      • jolicJ jolic
                        @jolic
                        Der ioBroker läuft halt nicht.
                        Startet der nicht per
                        iob start
                        Dann mal in den
                        systemctl status iobroker.service
                        werfen.
                          @jolic
                          iob start
                          Dann mal in den
                          werfen.
                          jolicJ Online
                          jolicJ Online
                          jolic
                          Sorry, war wegen "iob fix", sicherheitshalber mache ich nun ein reboot und dann nocheinmal eine "iob diag".
                          • jolicJ jolic
                            jolicJ Online
                            jolicJ Online
                            jolic
                            2ter Versuch, ioB läuft und keine Fehler im Webinterface Protokoll, iob diag:
                            Script v.2024-10-19
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 64 bit
                             00:02:46 up 5 min,  2 users,  load average: 1.13, 1.00, 0.48
                            CPU threads: 4
                            Current issues:
                                           Local time: Sun 2024-12-01 00:02:47 CET
                                       Universal time: Sat 2024-11-30 23:02:47 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi4m
                            HOME=/home/pi4m
                            iobroker
                            HOME=/home/iobroker
                            SUDO_HOME=/home/pi4m
                            GROUPS=tty video uucp audio iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            8.2G        1.4G        6.2G        2.7M        660M        6.8G
                            Swap:            12G          0B         12G
                            Total:           20G        1.4G         18G
                            Active iob-Instances:   15
                                     7806 M total memory
                                     1335 M used memory
                                     1321 M active memory
                                      347 M inactive memory
                                     5950 M free memory
                                       77 M buffer memory
                                      552 M swap cache
                                    11709 M total swap
                                        0 M used swap
                                    11709 M free swap
                            top - 00:02:48 up 5 min,  2 users,  load average: 1.13, 1.00, 0.48
                            Tasks: 177 total,   1 running, 176 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  2.0 us,  3.9 sy,  0.0 ni, 94.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   7806.6 total,   5949.5 free,   1336.6 used,    630.3 buff/cache
                            MiB Swap:  11710.0 total,  11710.0 free,      0.0 used.   6470.1 avail Mem
                            0 loaded units listed.
                            *** FILESYSTEM ***
                            run            tmpfs     3.9G  744K  3.9G   1% /run
                            /dev/sda2      ext4      917G  7.1G  873G   1% /
                            tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
                            [Sat Nov 30 23:57:45 2024] EXT4-fs (sda2): mounted filesystem 4f15f9f9-8c71-4493-986e-d850a02a0242 r/w with ordered data mode. Quota mode: none.
                            [Sat Nov 30 23:57:48 2024] EXT4-fs (sda2): re-mounted 4f15f9f9-8c71-4493-986e-d850a02a0242 r/w. Quota mode: none.
                            /var:
                            456M    /var/
                            428M    /var/log
                            427M    /var/log/journal/256940e9bd0e49078df2cc99156a71f7
                            23M     /var/lib/pacman
                            Archived and active journals take up 426.2M in the file system.
                            14M     /opt/iobroker/iobroker-data/objects.jsonl
                            USB-Devices by-id:
                            /usr/bin/npm            10.9.0
                            /usr/bin/npx            10.9.0
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            manjaro-arm         manjaro-arm (version: 7.0.3, hostname: manjaro-arm   , alive, uptime: 306)
                            admin:          7.1.5
                            javascript:     8.8.3
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : manjaro-arm                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                            + system.adapter.backitup.0               : backitup              : manjaro-arm                              -  enabled
                            + system.adapter.email.0                  : email                 : manjaro-arm                              -  enabled
                            + system.adapter.fullybrowser.0           : fullybrowser          : manjaro-arm                              -  enabled
                            + system.adapter.javascript.0             : javascript            : manjaro-arm                              -  enabled
                            + system.adapter.mqtt.0                   : mqtt                  : manjaro-arm                              -  enabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.ping.0                   : ping                  : manjaro-arm                              -  enabled
                            + system.adapter.shelly.0                 : shelly                : manjaro-arm                              -  enabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.simple-api.0             : simple-api            : manjaro-arm                              -  enabled, port: 8087, bind: 192.168.0.164, run as: admin
                            + system.adapter.tr-064.0                 : tr-064                : manjaro-arm                              -  enabled
                            + system.adapter.vis-2.0                  : vis-2                 : manjaro-arm                              -  enabled
                            + system.adapter.web.0                    : web                   : manjaro-arm                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + system.adapter.yahka.0                  : yahka                 : manjaro-arm                              -  enabled
                            + system.adapter.zwave2.0                 : zwave2                : manjaro-arm                              -  enabled
                            + instance is alive
                            Objects and States
                            Objects:        2325
                            States:         1952
                            tcp        0      0 127.0.0.1:38919         0.0.0.0:*               LISTEN      1001       15199      1131/io.yahka.0
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7840       557/iobroker.js-con
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1015       557/iobroker.js-con
                            tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      968        6421       571/pihole-FTL
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          919        559/sshd: /usr/bin/
                            tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      968        7466       571/pihole-FTL
                            tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          8248       471/lighttpd
                            tcp        0      0 192.168.0.164:8087      0.0.0.0:*               LISTEN      1001       15568      1092/io.simple-api.
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       6669       997/io.mqtt.0
                            tcp        0      0 0.0.0.0:42169           0.0.0.0:*               LISTEN      1001       15193      1131/io.yahka.0
                            tcp        0      0 127.0.0.1:5335          0.0.0.0:*               LISTEN      0          7390       460/unbound
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8446       789/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15166      1112/io.web.0
                            tcp6       0      0 ::1:4711                :::*                    LISTEN      968        6422       571/pihole-FTL
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          921        559/sshd: /usr/bin/
                            tcp6       0      0 :::53                   :::*                    LISTEN      968        7468       571/pihole-FTL
                            udp        0      0 127.0.0.1:5335          0.0.0.0:*                           0          7389       460/unbound
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       15195      1131/io.yahka.0
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       15194      1131/io.yahka.0
                            udp        0      0 192.168.0.164:5353      0.0.0.0:*                           1001       13543      1037/io.tr-064.0
                            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11209      1026/io.shelly.0
                            udp        0      0 0.0.0.0:53              0.0.0.0:*                           968        7465       571/pihole-FTL
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          6273       457/dhcpcd: [networ
                            udp6       0      0 :::53                   :::*                                968        7467       571/pihole-FTL
                            udp6       0      0 :::546                  :::*                                0          6275       457/dhcpcd: [networ
                            2024-12-01 00:00:00.111  - info: host.manjaro-arm instance system.adapter.ical.0 in version "1.16.1" started with pid 1177
                            2024-12-01 00:00:02.735  - info: admin.0 (789) failed connection to socket.io from ::ffff:192.168.0.45: Passport was not initialized
                            2024-12-01 00:00:03.497  - info: ical.0 (1177) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 7.0.3
                            2024-12-01 00:00:04.045  - info: ical.0 (1177) processing URL: AbfuhrkalenderMasholder https://art-trier.de/ics-feed/54634:Bitburg-Masholder::Masholder@.ics
                            2024-12-01 00:00:04.097  - info: javascript.0 (860) script.js.common.Abfall: <table class='Abfall'><tr><td class='Abfallimage'><img width='80' height='80' src='/vis-2.0/Abfall/gelber_sack_und_papierabfall.png'></td><td class='Abfallimage'><img width='80' height='80' src='/vis-2.0/Abfall/restmuell.png'></td><td class='Abfallimage'><img width='80' height='80' src='/vis-2.0/Abfall/restmuell.png'></td><td class='Abfallimage'><img width='80' height='80' src='/vis-2.0/Abfall/gelber_sack_und_papierabfall.png'></td></tr><tr><td class='AbfallText'>02.12.2024</td><td class='AbfallText'>12.12.2024</td><td class='AbfallText'>27.12.2024</td><td class='AbfallText'>30.12.2024</td></tr></table>
                            2024-12-01 00:00:07.559  - info: admin.0 (789) ==> Connected system.user.admin from ::ffff:192.168.0.45
                            2024-12-01 00:00:09.334  - info: ical.0 (1177) Terminated (NO_ERROR): Without reason
                            2024-12-01 00:00:10.238  - info: host.manjaro-arm instance system.adapter.ical.0 having pid 1177 terminated with code 0 (NO_ERROR)
                            2024-12-01 00:00:45.047  - info: host.manjaro-arm instance system.adapter.dwd.0 in version "2.8.5" started with pid 1280
                            2024-12-01 00:00:47.463  - info: dwd.0 (1280) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 7.0.3
                            2024-12-01 00:00:48.030  - info: dwd.0 (1280) State value to set for "dwd.0.warning1.begin" has to be type "string" but received type "number"
                            2024-12-01 00:00:48.079  - info: dwd.0 (1280) State value to set for "dwd.0.warning1.end" has to be type "string" but received type "number"
                            2024-12-01 00:00:48.185  - info: dwd.0 (1280) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2024-12-01 00:00:48.769  - info: host.manjaro-arm instance system.adapter.dwd.0 having pid 1280 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2024-12-01 00:00:49.838  - info: web.0 (1112) ==> Connected system.user.admin from ::ffff:192.168.0.3
                            2024-12-01 00:00:52.057  - info: web.0 (1112) <== Disconnect system.user.admin from ::ffff:192.168.0.3 vis-2
                            2024-12-01 00:00:56.783  - info: web.0 (1112) ==> Connected system.user.admin from ::ffff:192.168.0.3
                            2024-12-01 00:00:57.410  - info: javascript.0 (860) script.js.common.tabletLadestatus: Tablet Akku 30%  -> Ladestrom einschalten
                                                    v.2024-10-19
                                   Icon name: computer
                                Architecture: arm64
                            Kernel:                 aarch64
                            Userland:               64 bit
                            User-ID:                1000
                            /usr/bin/npm            10.9.0
                            /usr/bin/npx            10.9.0
                            MEMORY:
                            Mem:            8.2G        1.5G        5.3G        2.7M        1.5G        6.7G
                            Swap:            12G          0B         12G
                            Total:           20G        1.5G         17G
                                                    admin                   7.1.5
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                2325
                            States:                 1952
                            728K    /opt/iobroker/iobroker-data/states.jsonl
                            • jolicJ jolic
                              Script v.2024-10-19
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 64 bit
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi4m
                              HOME=/home/pi4m
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            12G          0B         12G
                              Total:           20G        1.4G         18G
                                       7806 M total memory
                                       1335 M used memory
                                       5950 M free memory
                                         77 M buffer memory
                                        552 M swap cache
                                      11709 M total swap
                                          0 M used swap
                                      11709 M free swap
                              *** FILESYSTEM ***
                              /var:
                              456M    /var/
                              428M    /var/log
                              23M     /var/lib/pacman
                              USB-Devices by-id:
                              /usr/bin/npm            10.9.0
                              /usr/bin/npx            10.9.0
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          7.1.5
                              javascript:     8.8.3
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        2325
                              States:         1952
                                                      v.2024-10-19
                                     Icon name: computer
                                  Architecture: arm64
                              Kernel:                 aarch64
                              Userland:               64 bit
                              User-ID:                1000
                              /usr/bin/npm            10.9.0
                              /usr/bin/npx            10.9.0
                              MEMORY:
                              Swap:            12G          0B         12G
                              Total:           20G        1.5G         17G
                                                      admin                   7.1.5
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                2325
                              States:                 1952
                              @jolic
                              Schaut doch gut aus.
                              Zu vis2 und cams kann ich aber nix sagen.
                                @jolic
                                jolicJ Online
                                jolicJ Online
                                jolic
                                OK, trotzdem vielen Dank für deine großartige Unterstützung und den Hinweis auf die "distro-info"!
                                Das mit dem Refresh der Bilder ist wirklich kurios. Mal sehen, ob es an mir liegt oder ob jemand anderes ein ähnliches Problem hat. Falls jemand das bestätigen oder eine Lösung anbieten kann, gerne Bescheid geben!
                                Ich habe mir das im Browser über die Konsole (F12) im Tab "Netzwerk" angesehen. Dort sehe ich, dass der Webcam-Snapshot geladen wird, aber es gibt scheinbar keinen "Refresh". Das könnte also an VIS2 liegen. Blöd, dass mir das nicht früher aufgefallen ist. Ich werde mal weiter nachforschen...
                                • jolicJ jolic
                                  jolicJ Online
                                  jolicJ Online
                                  jolic
                                  Es scheint ein Bug in VIS2 zu sein. Tatsächlich ist mir das zunächst nicht aufgefallen – es handelt sich ja um Standbilder, die nur alle paar Sekunden wechseln. Ich lasse nun die Uhrzeit im Bild einblenden.
                                  github Quellen:
                                  Basic image does not refresh itself anymore when using a binding
                                  und
                                  Basic Image Updatezeit V2.9.50
                                  Sorry, dass ich den Thread dafür genutzt habe. Anfangs sah es so aus, als würde das Problem am neuen JS-Controller liegen – dieser läuft aber absolut problemlos!
                                  Nachtrag: Ich habe als Workaround ein Script geschrieben, das mit mehreren Widgets funktioniert (GitHub Link).
                                    steinchen
                                    Leider startet nach update des js-controllers mein Lupusec Adapter nicht mehr.
                                    eine neuinstallation des Adapters hat nicht geholfen.
                                    Was könnte ich denn da tun ?
                                    vg steinchen
                                    Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
                                    • S steinchen
                                      vg steinchen
                                      @steinchen
                                      Du könntest den Text aus dem LogFile
                                      iob logs --watch
                                      in Textform in CodeTags eingebettet posten und nicht als Screenshot.
                                      Und du könntest die empfohlene nodejs-Version verwenden...
                                      iob nodejs-update
                                      S 2 Antworten Letzte Antwort
                                        @steinchen
                                        iob logs --watch
                                        iob nodejs-update
                                        steinchen
                                        so hier ein neuer Versuch
                                        2024-12-02 13:22:07.346  - info: host.lichtenhain instance system.adapter.lupusec.0 terminated with code 0 (NO_ERROR)
                                        2024-12-02 13:22:07.347  - info: host.lichtenhain Restart adapter system.adapter.lupusec.0 because enabled
                                        2024-12-02 13:22:38.156  - info: host.lichtenhain instance system.adapter.lupusec.0 in version "1.3.6" started with pid 1867
                                        2024-12-02 13:22:41.378  - info: lupusec.0 (1867) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                        2024-12-02 13:22:41.553  - info: lupusec.0 (1867) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.lupusec, node: v18.20.4, js-controller: 7.0.3
                                        2024-12-02 13:22:41.579  - info: lupusec.0 (1867) Starting Adapter lupusec.0 in version 1.3.6
                                        2024-12-02 13:22:41.693  - info: lupusec.0 (1867) Restarting Adapter because of changeing Sentry settings
                                        2024-12-02 13:22:41.694  - warn: lupusec.0 (1867) Restart initiated
                                        2024-12-02 13:22:41.704  - info: lupusec.0 (1867) terminating
                                        2024-12-02 13:22:41.706  - info: lupusec.0 (1867) Terminated (NO_ERROR): Without reason
                                        2024-12-02 13:22:42.202  - info: lupusec.0 (1867) terminating
                                        2024-12-02 13:22:42.305  - info: host.lichtenhain instance system.adapter.lupusec.0 terminated with code 0 (NO_ERROR)
                                        2024-12-02 13:22:42.306  - info: host.lichtenhain Restart adapter system.adapter.lupusec.0 because enabled
                                          @steinchen
                                          iob logs --watch
                                          iob nodejs-update
                                          steinchen
                                          hab leider noch Debian Buster
                                          Debian 10 'Buster' has reached End of Life and is not supported anymore.
                                          Recent versions of nodejs won't install.
                                          Please install the current Debian Stable
