  5. Skript funktionieren nicht nach Neustart - Gelöst
    6.5k
30 Beiträge 6 Kommentatoren 1.8k Aufrufe 3 Beobachtet
  • SvaggyS Svaggy
    Reicht das?
    2024-11-08 19:06:51.057  - info: host.iobroker "system.adapter.javascript.1" disabled
    2024-11-08 19:06:51.057  - info: host.iobroker stopInstance system.adapter.javascript.1 (force=false, process=true)
    2024-11-08 19:06:51.060  - info: javascript.1 (2032) Got terminate signal TERMINATE_YOURSELF
    2024-11-08 19:06:51.062  - info: javascript.1 (2032) terminating
    2024-11-08 19:06:51.063  - info: javascript.1 (2032) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-11-08 19:06:51.100  - info: host.iobroker stopInstance system.adapter.javascript.1 send kill signal
    2024-11-08 19:06:51.561  - info: javascript.1 (2032) terminating
    2024-11-08 19:06:51.599  - info: host.iobroker instance system.adapter.javascript.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-11-08 19:06:52.309  - info: host.iobroker "system.adapter.javascript.1" enabled
    2024-11-08 19:06:52.582  - info: host.iobroker instance system.adapter.javascript.1 in version "8.8.3" started with pid 2047
    2024-11-08 19:06:53.565  - info: javascript.1 (2047) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.0, js-controller: 6.0.11
    2024-11-08 19:06:53.810  - info: javascript.1 (2047) requesting all states
    2024-11-08 19:06:53.811  - info: javascript.1 (2047) requesting all objects
    2024-11-08 19:06:54.226  - info: javascript.1 (2047) received all states
    2024-11-08 19:06:54.442  - info: javascript.1 (2047) received all objects
    2024-11-08 19:06:54.493  - error: javascript.1 (2047) Cannot find view "script" for search "javascript"
    @svaggy
    Und was ist mit javascript.0?
    Warum überhaupt zwei Instanzen?
    SvaggyS 1 Antwort Letzte Antwort
      @svaggy
      SvaggyS Offline
      SvaggyS Offline
      Svaggy
      Zwei Instanzen, weil ich zum Probieren nicht immer wieder alle benötigten Skripte neustarten wollte ;-). Hier Instanz 0
      2024-11-08 19:11:15.349  - info: host.iobroker "system.adapter.javascript.0" disabled
      2024-11-08 19:11:15.349  - info: host.iobroker stopInstance system.adapter.javascript.0 (force=false, process=true)
      2024-11-08 19:11:15.351  - info: javascript.0 (348) Got terminate signal TERMINATE_YOURSELF
      2024-11-08 19:11:15.354  - info: javascript.0 (348) terminating
      2024-11-08 19:11:15.354  - info: javascript.0 (348) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-11-08 19:11:15.392  - info: host.iobroker stopInstance system.adapter.javascript.0 send kill signal
      2024-11-08 19:11:15.853  - info: javascript.0 (348) terminating
      2024-11-08 19:11:15.886  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-11-08 19:11:18.596  - info: host.iobroker "system.adapter.javascript.0" enabled
      2024-11-08 19:11:18.865  - info: host.iobroker instance system.adapter.javascript.0 in version "8.8.3" started with pid 2081
      2024-11-08 19:11:19.820  - info: javascript.0 (2081) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.0, js-controller: 6.0.11
      2024-11-08 19:11:20.060  - info: javascript.0 (2081) requesting all states
      2024-11-08 19:11:20.061  - info: javascript.0 (2081) requesting all objects
      2024-11-08 19:11:20.680  - info: javascript.0 (2081) received all objects
      2024-11-08 19:11:20.682  - info: javascript.0 (2081) received all states
      2024-11-08 19:11:20.748  - error: javascript.0 (2081) Cannot find view "script" for search "javascript"
      Ro75R 1 Antwort Letzte Antwort
      • SvaggyS Svaggy
        Ro75R Offline
        Ro75R Offline
        Ro75
        @svaggy zeig mal bitte bildlich deine Skripte / Blockly's
        Ro75.
        • Ro75R Ro75
          Ro75.
          SvaggyS Offline
          SvaggyS Offline
          Svaggy
          @ro75
          Ganz oben habe ich doch ein super simples aus der Instanz 1 gezeigt, was nicht funktioniert
          Hier was größeres aus der Instanz 0
          • SvaggyS Svaggy
            @ro75
            Ro75R Offline
            Ro75R Offline
            Ro75
            @svaggy das meinte ich nicht. Eher so:
            Ro75.
            • Ro75R Ro75
              Ro75.
              SvaggyS Offline
              SvaggyS Offline
              Svaggy
              @ro75 Ah.. :-)
              • SvaggyS Svaggy
                ich habe das Problem, dass meine Blockly Skripte nach einem Neustart nicht funktionieren.
                Hierbei scheint es bereits auszureichen, wenn die Javaskript Instanz neugestartet wird. Die Skripte werden alle als laufend angezeigt, funktionieren jedoch nicht. Erst ein manuelles Neustarten der Skripte lässt diese wieder arbeiten.
                Was kann hierfür die Ursache sein?
                Hardware/ SW Infos:
                NUK
                Proxmox
                iobroker im lxc container
                Grüße,
                Sven
                crunchipC Offline
                crunchipC Offline
                @svaggy sagte in Skript funktionieren nicht nach Neustart:
                nach einem Neustart
                nur ein einfacher Neustart, oder vllt doch das ein odere andere Update gemacht?
                mach mal im terminal ein
                iob upload all
                  nach einem Neustart
                  iob upload all
                  SvaggyS Offline
                  SvaggyS Offline
                  Svaggy
                  @crunchip
                  Yeah :-) Das hat´s gebracht!! Vielen Dank!!
                  Kannst du mir noch sagen, was der Befehl gemacht hat/ wo mein Problem war?
                  • crunchipC Offline
                    crunchipC Offline
                    @svaggy wahrscheinlich sind Pakete beim upgrade irgendwo auf der Strecke geblieben und mit diesem Befehl nochmals neu hochgeladen...vereinfacht ausgedrückt
                      SvaggyS Offline
                      SvaggyS Offline
                      Svaggy
                      Alles klar - nochmal vielen Dank an euch alle!
