  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Shellys per mqtt keine Verbindung
    2.8k
    4.9k
    4.1k
61 Beiträge 5 Kommentatoren 8.5k Aufrufe 3 Beobachtet
  • A Accuface
    @homoran said in Shellys per mqtt keine Verbindung:
    @accuface sagte in Shellys per mqtt keine Verbindung:
    Weil das Forum mir dass sagt.
    was?
    Du sollst ja nicht den ganzen Tag posten.
    nur die Zeilen nach Restart der Instanz
     2024-10-15 19:16:52.154 - info: admin.0 (802) <== Disconnect system.user.admin from ::ffff:192.168.178.22 admin
    2024-10-15 19:16:58.199 - info: admin.0 (802) ==> Connected system.user.admin from ::ffff:192.168.178.22
    2024-10-15 19:19:32.829 - info: admin.0 (802) <== Disconnect system.user.admin from ::ffff:192.168.178.22 admin
    2024-10-15 19:20:30.707 - info: admin.0 (802) terminating http server on port 8081
    2024-10-15 19:20:30.706 - info: host.raspberrypi5 received SIGTERM
    2024-10-15 19:20:30.710 - info: trashschedule.0 (1175) cleaned everything up...
    2024-10-15 19:20:30.716 - info: javascript.0 (864) Stopping script script.js.Skript_1
    2024-10-15 19:20:30.720 - info: backitup.0 (941) cleaned everything up...
    2024-10-15 19:20:30.728 - info: cloud.0 (959) Connection changed: disconnect
    2024-10-15 19:20:30.708 - info: host.raspberrypi5 stopInstance system.adapter.admin.0 (force=false, process=true)
    2024-10-15 19:20:30.708 - info: host.raspberrypi5 stopInstance system.adapter.javascript.0 (force=false, process=true)
    2024-10-15 19:20:30.708 - info: host.raspberrypi5 stopInstance system.adapter.scenes.0 (force=false, process=true)
    2024-10-15 19:20:30.709 - info: host.raspberrypi5 stopInstance system.adapter.sql.0 (force=false, process=true)
    2024-10-15 19:20:30.710 - info: host.raspberrypi5 stopInstance system.adapter.history.0 (force=false, process=true)
    2024-10-15 19:20:30.713 - info: host.raspberrypi5 stopInstance system.adapter.whatsapp-cmb.0 (force=false, process=true)
    2024-10-15 19:20:30.713 - info: host.raspberrypi5 stopInstance system.adapter.backitup.0 (force=false, process=true)
    2024-10-15 19:20:30.714 - info: host.raspberrypi5 stopInstance system.adapter.cloud.0 (force=false, process=true)
    2024-10-15 19:20:30.714 - info: host.raspberrypi5 stopInstance system.adapter.weatherunderground.0 (force=false, process=false)
    2024-10-15 19:20:30.714 - info: host.raspberrypi5 stopInstance system.adapter.ping.0 (force=false, process=false)
    2024-10-15 19:20:30.714 - info: host.raspberrypi5 stopInstance system.adapter.fronius.0 (force=false, process=true)
    2024-10-15 19:20:30.715 - info: host.raspberrypi5 stopInstance system.adapter.fronius.1 (force=false, process=true)
    2024-10-15 19:20:30.715 - info: host.raspberrypi5 stopInstance system.adapter.synology.0 (force=false, process=true)
    2024-10-15 19:20:30.715 - info: host.raspberrypi5 stopInstance system.adapter.ical.0 (force=false, process=false)
    2024-10-15 19:20:30.716 - info: host.raspberrypi5 stopInstance canceled schedule system.adapter.ical.0
    2024-10-15 19:20:30.716 - info: host.raspberrypi5 stopInstance system.adapter.feiertage.0 (force=false, process=false)
    2024-10-15 19:20:30.716 - info: host.raspberrypi5 stopInstance system.adapter.tankerkoenig.0 (force=false, process=true)
    2024-10-15 19:20:30.716 - info: host.raspberrypi5 stopInstance system.adapter.shelly.0 (force=false, process=true)
    2024-10-15 19:20:30.716 - info: host.raspberrypi5 stopInstance system.adapter.discovery.0 (force=false, process=true)
    2024-10-15 19:20:30.717 - info: host.raspberrypi5 stopInstance system.adapter.iot.0 (force=false, process=true)
    2024-10-15 19:20:30.717 - info: host.raspberrypi5 stopInstance system.adapter.web.0 (force=false, process=true)
    2024-10-15 19:20:30.717 - info: host.raspberrypi5 stopInstance system.adapter.vis-2.0 (force=false, process=true)
    2024-10-15 19:20:30.717 - info: host.raspberrypi5 stopInstance system.adapter.echarts.0 (force=false, process=true)
    2024-10-15 19:20:30.718 - info: host.raspberrypi5 stopInstance system.adapter.iqontrol.0 (force=false, process=false)
    2024-10-15 19:20:30.718 - info: host.raspberrypi5 stopInstance system.adapter.jarvis.0 (force=false, process=true)
    2024-10-15 19:20:30.718 - info: host.raspberrypi5 stopInstance system.adapter.fronius-solarweb.0 (force=false, process=true)
    2024-10-15 19:20:30.718 - info: host.raspberrypi5 stopInstance system.adapter.trashschedule.0 (force=false, process=true)
    2024-10-15 19:20:30.718 - info: host.raspberrypi5 stopInstance system.adapter.vis.0 (force=false, process=false)
    2024-10-15 19:20:30.719 - info: host.raspberrypi5 stopInstance system.adapter.vis-metro.0 (force=false, process=false)
    2024-10-15 19:20:30.719 - info: host.raspberrypi5 stopInstance system.adapter.dwd.0 (force=false, process=false)
    2024-10-15 19:20:30.719 - info: host.raspberrypi5 stopInstance system.adapter.vis-timeandweather.0 (force=false, process=false)
    2024-10-15 19:20:30.719 - info: jarvis.0 (1145) Adapter stopped und unloaded.
    2024-10-15 19:20:30.736 - warn: web.0 (1100) setTimeout called, but adapter is shutting down
    2024-10-15 19:20:30.766 - info: admin.0 (802) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:20:30.767 - info: javascript.0 (864) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:20:30.768 - info: whatsapp-cmb.0 (926) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:20:30.769 - info: scenes.0 (880) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:20:30.771 - info: backitup.0 (941) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:20:30.770 - info: cloud.0 (959) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:20:30.772 - info: fronius.1 (989) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:20:30.772 - info: fronius.0 (974) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:20:30.773 - info: synology.0 (1010) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:20:30.785 - info: iot.0 (1085) Connection changed: disconnect
    2024-10-15 19:20:30.789 - info: sql.0 (895) terminating
    2024-10-15 19:20:30.790 - info: trashschedule.0 (1175) terminating
    2024-10-15 19:20:30.790 - info: javascript.0 (864) terminating
    2024-10-15 19:20:30.790 - info: admin.0 (802) terminating
    2024-10-15 19:20:30.794 - info: backitup.0 (941) terminating
    2024-10-15 19:20:30.791 - info: trashschedule.0 (1175) Terminated (NO_ERROR): Without reason
    2024-10-15 19:20:30.795 - info: backitup.0 (941) Terminated (NO_ERROR): Without reason
    2024-10-15 19:20:30.790 - info: history.0 (911) terminating
    2024-10-15 19:20:30.792 - info: sql.0 (895) Terminated (NO_ERROR): Without reason
    2024-10-15 19:20:30.798 - info: tankerkoenig.0 (1040) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:20:30.798 - info: jarvis.0 (1145) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:20:30.799 - info: trashschedule.0 (1175) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:20:30.796 - info: discovery.0 (1070) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:20:30.794 - info: fronius-solarweb.0 (1160) terminating
    2024-10-15 19:20:30.786 - info: iot.0 (1085) Connection lost
    2024-10-15 19:20:30.802 - info: tankerkoenig.0 (1040) terminating
    2024-10-15 19:20:30.793 - info: history.0 (911) Terminated (NO_ERROR): Without reason
    2024-10-15 19:20:30.800 - info: echarts.0 (1130) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:20:30.791 - info: admin.0 (802) Terminated (NO_ERROR): Without reason
    2024-10-15 19:20:30.805 - info: vis-2.0 (1115) terminating
    2024-10-15 19:20:30.791 - info: javascript.0 (864) Terminated (NO_ERROR): Without reason
    2024-10-15 19:20:30.792 - info: synology.0 (1010) terminating
    2024-10-15 19:20:30.801 - info: shelly.0 (1286) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:20:30.807 - info: web.0 (1100) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:20:30.793 - info: synology.0 (1010) Terminated (NO_ERROR): Without reason
    2024-10-15 19:20:30.803 - info: iot.0 (1085) terminating
    2024-10-15 19:20:30.804 - info: iot.0 (1085) Terminated (NO_ERROR): Without reason
    2024-10-15 19:20:30.805 - info: iot.0 (1085) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:20:30.803 - info: tankerkoenig.0 (1040) Terminated (NO_ERROR): Without reason
    2024-10-15 19:20:30.801 - info: fronius-solarweb.0 (1160) Terminated (NO_ERROR): Without reason
    2024-10-15 19:20:30.809 - info: fronius-solarweb.0 (1160) Got terminate signal TERMINATE_YOURSELF
    Accuface
    Hier mal ein Auszug zum Shelly
     2024-10-15 19:21:46.751  - info: host.raspberrypi5 instance system.adapter.shelly.0 in version "8.2.1" started with pid 1091
    2024-10-15 19:21:47.898  - info: shelly.0 (1091) starting. Version 8.2.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v20.18.0, js-controller: 6.0.11
    2024-10-15 19:21:48.050  - info: shelly.0 (1091) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
    2024-10-15 19:21:49.437  - info: shelly.0 (1091) [MQTT] Device with client id "shellyplus1-cc7b5c85af80" connected!
    2024-10-15 19:21:50.765  - info: host.raspberrypi5 instance system.adapter.discovery.0 in version "5.0.0" started with pid 1106
    2024-10-15 19:21:51.563  - info: discovery.0 (1106) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.18.0, js-controller: 6.0.11
    2024-10-15 19:21:52.504  - info: shelly.0 (1091) [MQTT] Device with client id "shellyplus1pm-10061cca8844" connected!
    2024-10-15 19:21:52.601  - info: shelly.0 (1091) [MQTT] Device with client id "shellyplus1pm-cc7b5c0dd95c" connected!
    2024-10-15 19:21:52.692  - info: shelly.0 (1091) [MQTT] Device with client id "shellyplus1pm-10061ccb0c48" connected!
    2024-10-15 19:21:53.444  - info: shelly.0 (1091) [MQTT] Device with client id "shellyplus1pm-d4d4daeb2ddc" connected!
    2024-10-15 19:21:53.610  - info: shelly.0 (1091) [MQTT] Device with client id "shellyplus1pm-10061ccad010" connected!
    2024-10-15 19:21:54.759  - info: host.raspberrypi5 instance system.adapter.iot.0 in version "3.3.0" started with pid 1121
    2024-10-15 19:21:55.275  - info: shelly.0 (1091) [MQTT] Device with client id "shellyplus1pm-fcb46727891c" connected!
    2024-10-15 19:21:56.069  - info: iot.0 (1121) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.iot, node: v20.18.0, js-controller: 6.0.11
    2024-10-15 19:21:56.107  - info: iot.0 (1121) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2024-10-15 19:21:56.554  - info: iot.0 (1121) Connection changed: connect "bernd_order_gmx_de"
    2024-10-15 19:21:56.966  - info: shelly.0 (1091) [MQTT] Device with client id "shellyplus1pm-d4d4da35853c" connected!
    2024-10-15 19:21:58.507  - info: shelly.0 (1091) [MQTT] Device with client id "shellyplus1pm-b0b21c1b4e14" connected!
    2024-10-15 19:21:58.750  - info: host.raspberrypi5 instance system.adapter.web.0 in version "6.2.5" started with pid 1136
    2024-10-15 19:21:59.803  - info: web.0 (1136) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.0, js-controller: 6.0.11
    2024-10-15 19:22:00.220  - info: web.0 (1136) socket.io server listening on port 8082
    2024-10-15 19:22:00.223  - info: web.0 (1136) http server listening on port 8082
    2024-10-15 19:22:02.751  - info: host.raspberrypi5 instance system.adapter.vis-2.0 in version "2.9.32" started with pid 1151
    2024-10-15 19:22:03.560  - info: vis-2.0 (1151) starting. Version 2.9.32 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.18.0, js-controller: 6.0.11
    2024-10-15 19:22:03.764  - info: vis-2.0 (1151) vis-2 license is OK.
    2024-10-15 19:22:06.740  - info: host.raspberrypi5 instance system.adapter.echarts.0 in version "1.9.2" started with pid 1166
    2024-10-15 19:22:07.443  - info: echarts.0 (1166) starting. Version 1.9.2 in /opt/iobroker/node_modules/iobroker.echarts, node: v20.18.0, js-controller: 6.0.11
    2024-10-15 19:22:10.783  - info: host.raspberrypi5 instance system.adapter.jarvis.0 in version "3.1.8" started with pid 1181
    2024-10-15 19:22:12.296  - info: jarvis.0 (1181) starting. Version 3.1.8 in /opt/iobroker/node_modules/iobroker.jarvis, node: v20.18.0, js-controller: 6.0.11
    2024-10-15 19:22:12.312  - info: jarvis.0 (1181) No Backup found for layout, thus backing up initially.
    2024-10-15 19:22:12.313  - info: jarvis.0 (1181) No Backup found for scripts, thus backing up initially.
    2024-10-15 19:22:12.313  - info: jarvis.0 (1181) No Backup found for styles, thus backing up initially.
    2024-10-15 19:22:12.314  - info: jarvis.0 (1181) No Backup found for widgets, thus backing up initially.
    2024-10-15 19:22:12.365  - info: jarvis.0 (1181) Connection: WebSocket opened on port 8400 using http...
    2024-10-15 19:22:12.373  - info: jarvis.0 (1181) Found Backups for devices.
    2024-10-15 19:22:12.374  - info: jarvis.0 (1181) Found Backups for settings.
    2024-10-15 19:22:14.767  - info: host.raspberrypi5 instance system.adapter.fronius-solarweb.0 in version "0.0.3" started with pid 1196
    2024-10-15 19:22:15.644  - info: fronius-solarweb.0 (1196) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.fronius-solarweb, node: v20.18.0, js-controller: 6.0.11
    2024-10-15 19:22:17.092  - info: fronius-solarweb.0 (1196) Disable Pro Endpoints
    2024-10-15 19:22:17.093  - info: fronius-solarweb.0 (1196) {"responseError":3503,"responseMessage":"Not a Pro PV system."}
    2024-10-15 19:22:18.775  - info: host.raspberrypi5 instance system.adapter.trashschedule.0 in version "3.3.0" started with pid 1211
    2024-10-15 19:22:19.636  - info: trashschedule.0 (1211) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v20.18.0, js-controller: 6.0.11
    2024-10-15 19:22:19.687  - info: trashschedule.0 (1211) [onReady] starting with source "ical" -> ical
    2024-10-15 19:22:19.732  - info: trashschedule.0 (1211) [ical] configured ical preview is 31 days (until 15.11.2024) - increase this value to find more events in the future
    2024-10-15 19:22:19.732  - info: trashschedule.0 (1211) [ical] found configured ical event "Vacation" without "display" flag. Activate the display flag on this entry if this is a relevant "trash event".
    2024-10-15 19:22:23.433  - info: vis.0 (1226) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.0, js-controller: 6.0.11
    2024-10-15 19:22:24.553  - info: cloud.0 (969) Trying to connect as system.user.admin to cloud
    2024-10-15 19:22:24.703  - info: cloud.0 (969) Connection changed: connect
    2024-10-15 19:22:27.486  - info: vis.0 (1226) Terminated (NO_ERROR): Without reason
    2024-10-15 19:22:28.021  - info: host.raspberrypi5 instance system.adapter.vis.0 terminated while should be started once
    2024-10-15 19:22:35.020  - info: shelly.0 (1091) [MQTT] Device with client id "shellyplus1-e465b8f46ac4" connected!
    2024-10-15 19:22:37.498  - info: shelly.0 (1091) [MQTT] Device with client id "shellyplus1pm-10061ccb9fc0" connected!
    2024-10-15 19:24:09.673  - info: host.raspberrypi5 stopInstance system.adapter.shelly.0 (force=false, process=true)
    2024-10-15 19:24:09.678  - info: shelly.0 (1091) Got terminate signal TERMINATE_YOURSELF
    2024-10-15 19:24:09.681  - info: shelly.0 (1091) terminating
    2024-10-15 19:24:09.681  - info: shelly.0 (1091) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-10-15 19:24:09.743  - info: host.raspberrypi5 stopInstance system.adapter.shelly.0 send kill signal
    2024-10-15 19:24:10.182  - info: shelly.0 (1091) terminating
    2024-10-15 19:24:10.211  - info: host.raspberrypi5 instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-10-15 19:24:13.364  - info: host.raspberrypi5 instance system.adapter.shelly.0 in version "8.2.1" started with pid 1241
    2024-10-15 19:24:13.971  - debug: shelly.0 (1241) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-10-15 19:24:13.986  - debug: shelly.0 (1241) Objects client ready ... initialize now
    2024-10-15 19:24:13.986  - debug: shelly.0 (1241) Objects create System PubSub Client
    2024-10-15 19:24:13.987  - debug: shelly.0 (1241) Objects create User PubSub Client
    2024-10-15 19:24:14.007  - debug: shelly.0 (1241) Objects client initialize lua scripts
    2024-10-15 19:24:14.010  - debug: shelly.0 (1241) Objects connected to redis: 127.0.0.1:9001
    2024-10-15 19:24:14.024  - debug: shelly.0 (1241) Redis States: Use Redis connection: 127.0.0.1:9000
    2024-10-15 19:24:14.030  - debug: shelly.0 (1241) States create System PubSub Client
    2024-10-15 19:24:14.031  - debug: shelly.0 (1241) States create User PubSub Client
    2024-10-15 19:24:14.082  - debug: shelly.0 (1241) States connected to redis: 127.0.0.1:9000
    2024-10-15 19:24:14.099  - debug: shelly.0 (1241) Plugin sentry Initialize Plugin (enabled=true)
    2024-10-15 19:24:14.294  - info: shelly.0 (1241) starting. Version 8.2.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v20.18.0, js-controller: 6.0.11
    2024-10-15 19:24:14.436  - debug: shelly.0 (1241) [onlineCheck] Checking shellyplus1#cc7b5c85af80#1 on 192.168.178.29:80
    2024-10-15 19:24:14.456  - debug: shelly.0 (1241) [deviceStatusUpdate] shellyplus1#cc7b5c85af80#1: true
    2024-10-15 19:24:14.457  - debug: shelly.0 (1241) [onlineCheck] Checking shellyplus1pm#10061ccad010#1 on 192.168.178.40:80
    2024-10-15 19:24:14.467  - debug: shelly.0 (1241) [deviceStatusUpdate] shellyplus1pm#10061ccad010#1: true
    2024-10-15 19:24:14.468  - debug: shelly.0 (1241) [onlineCheck] Checking shellyplus1pm#cc7b5c0dd95c#1 on 192.168.178.33:80
    2024-10-15 19:24:14.478  - debug: shelly.0 (1241) [onlineCheck] Checking shellyplus1pm#d4d4da35853c#1 on 192.168.178.38:80
    2024-10-15 19:24:14.479  - debug: shelly.0 (1241) [onlineCheck] Checking shellyplus1pm#10061ccb9fc0#1 on 192.168.178.63:80
    2024-10-15 19:24:14.480  - debug: shelly.0 (1241) [deviceStatusUpdate] shellyplus1pm#cc7b5c0dd95c#1: true
    2024-10-15 19:24:14.483  - debug: shelly.0 (1241) [deviceStatusUpdate] Online devices: ["shellyplus1#cc7b5c85af80#1"]
    2024-10-15 19:24:14.489  - debug: shelly.0 (1241) [deviceStatusUpdate] shellyplus1pm#d4d4da35853c#1: true
    2024-10-15 19:24:14.490  - debug: shelly.0 (1241) [deviceStatusUpdate] shellyplus1pm#10061ccb9fc0#1: true
    2024-10-15 19:24:14.491  - debug: shelly.0 (1241) [onlineCheck] Checking shellyplus1pm#d4d4daeb2ddc#1 on 192.168.178.35:80
    2024-10-15 19:24:14.499  - debug: shelly.0 (1241) [deviceStatusUpdate] shellyplus1pm#d4d4daeb2ddc#1: true
    2024-10-15 19:24:14.514  - debug: shelly.0 (1241) [onlineCheck] Checking shellyplus1pm#10061ccb0c48#1 on 192.168.178.39:80
    2024-10-15 19:24:14.515  - debug: shelly.0 (1241) [deviceStatusUpdate] Online devices: ["shellyplus1#cc7b5c85af80#1","shellyplus1pm#10061ccad010#1"]
    2024-10-15 19:24:14.525  - debug: shelly.0 (1241) [deviceStatusUpdate] shellyplus1pm#10061ccb0c48#1: true
    2024-10-15 19:24:14.525  - debug: shelly.0 (1241) [onlineCheck] Checking shellyplus1pm#10061cca8844#1 on 192.168.178.32:80
    2024-10-15 19:24:14.535  - debug: shelly.0 (1241) [deviceStatusUpdate] shellyplus1pm#10061cca8844#1: true
    2024-10-15 19:24:14.537  - debug: shelly.0 (1241) [deviceStatusUpdate] Online devices: ["shellyplus1#cc7b5c85af80#1","shellyplus1pm#10061ccad010#1","shellyplus1pm#cc7b5c0dd95c#1"]
    2024-10-15 19:24:14.539  - debug: shelly.0 (1241) [onlineCheck] Checking shellyplus1pm#fcb46727891c#1 on 192.168.178.26:80
    2024-10-15 19:24:14.550  - debug: shelly.0 (1241) [deviceStatusUpdate] shellyplus1pm#fcb46727891c#1: true
    2024-10-15 19:24:14.553  - debug: shelly.0 (1241) [onlineCheck] Checking shellyplus1pm#b0b21c1b4e14#1 on 192.168.178.34:80
    2024-10-15 19:24:14.554  - debug: shelly.0 (1241) [deviceStatusUpdate] Online devices: ["shellyplus1#cc7b5c85af80#1","shellyplus1pm#10061ccad010#1","shellyplus1pm#cc7b5c0dd95c#1","shellyplus1pm#d4d4da35853c#1"]
    2024-10-15 19:24:14.556  - debug: shelly.0 (1241) [deviceStatusUpdate] Online devices: ["shellyplus1#cc7b5c85af80#1","shellyplus1pm#10061ccad010#1","shellyplus1pm#cc7b5c0dd95c#1","shellyplus1pm#d4d4da35853c#1","shellyplus1pm#10061ccb9fc0#1"]
    2024-10-15 19:24:14.557  - debug: shelly.0 (1241) [deviceStatusUpdate] Online devices: ["shellyplus1#cc7b5c85af80#1","shellyplus1pm#10061ccad010#1","shellyplus1pm#cc7b5c0dd95c#1","shellyplus1pm#d4d4da35853c#1","shellyplus1pm#10061ccb9fc0#1","shellyplus1pm#d4d4daeb2ddc#1"]
    2024-10-15 19:24:14.564  - debug: shelly.0 (1241) [deviceStatusUpdate] shellyplus1pm#b0b21c1b4e14#1: true
    2024-10-15 19:24:14.565  - debug: shelly.0 (1241) [onlineCheck] Checking shellyplus1#e465b8f46ac4#1 on 192.168.178.31:80
    2024-10-15 19:24:14.566  - info: shelly.0 (1241) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
    2024-10-15 19:24:14.569  - debug: shelly.0 (1241) [MQTT Server] Started listener on 0.0.0.0:1882
    2024-10-15 19:24:14.571  - debug: shelly.0 (1241) [deviceStatusUpdate] shellyplus1#e465b8f46ac4#1: true
    2024-10-15 19:24:14.619  - debug: shelly.0 (1241) [deviceStatusUpdate] Online devices: ["shellyplus1#cc7b5c85af80#1","shellyplus1pm#10061ccad010#1","shellyplus1pm#cc7b5c0dd95c#1","shellyplus1pm#d4d4da35853c#1","shellyplus1pm#10061ccb9fc0#1","shellyplus1pm#d4d4daeb2ddc#1","shellyplus1pm#10061ccb0c48#1"]
    2024-10-15 19:24:14.620  - debug: shelly.0 (1241) [deviceStatusUpdate] Online devices: ["shellyplus1#cc7b5c85af80#1","shellyplus1pm#10061ccad010#1","shellyplus1pm#cc7b5c0dd95c#1","shellyplus1pm#d4d4da35853c#1","shellyplus1pm#10061ccb9fc0#1","shellyplus1pm#d4d4daeb2ddc#1","shellyplus1pm#10061ccb0c48#1","shellyplus1pm#10061cca8844#1"]
    2024-10-15 19:24:14.632  - debug: shelly.0 (1241) [deviceStatusUpdate] Online devices: ["shellyplus1#cc7b5c85af80#1","shellyplus1pm#10061ccad010#1","shellyplus1pm#cc7b5c0dd95c#1","shellyplus1pm#d4d4da35853c#1","shellyplus1pm#10061ccb9fc0#1","shellyplus1pm#d4d4daeb2ddc#1","shellyplus1pm#10061ccb0c48#1","shellyplus1pm#10061cca8844#1","shellyplus1pm#fcb46727891c#1"]
    2024-10-15 19:24:14.633  - debug: shelly.0 (1241) [deviceStatusUpdate] Online devices: ["shellyplus1#cc7b5c85af80#1","shellyplus1pm#10061ccad010#1","shellyplus1pm#cc7b5c0dd95c#1","shellyplus1pm#d4d4da35853c#1","shellyplus1pm#10061ccb9fc0#1","shellyplus1pm#d4d4daeb2ddc#1","shellyplus1pm#10061ccb0c48#1","shellyplus1pm#10061cca8844#1","shellyplus1pm#fcb46727891c#1","shellyplus1pm#b0b21c1b4e14#1"]
    2024-10-15 19:24:14.635  - debug: shelly.0 (1241) [deviceStatusUpdate] Online devices: ["shellyplus1#cc7b5c85af80#1","shellyplus1pm#10061ccad010#1","shellyplus1pm#cc7b5c0dd95c#1","shellyplus1pm#d4d4da35853c#1","shellyplus1pm#10061ccb9fc0#1","shellyplus1pm#d4d4daeb2ddc#1","shellyplus1pm#10061ccb0c48#1","shellyplus1pm#10061cca8844#1","shellyplus1pm#fcb46727891c#1","shellyplus1pm#b0b21c1b4e14#1","shellyplus1#e465b8f46ac4#1"]
    2024-10-15 19:24:15.516  - debug: shelly.0 (1241) [MQTT Server] New connection from 192.168.178.35
    2024-10-15 19:24:15.526  - debug: shelly.0 (1241) [MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":101,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"shellyplus1pm-d4d4daeb2ddc/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellyplus1pm-d4d4daeb2ddc","username":"mqttuser","password":{"type":"Buffer","data":[80,97,115,115,97,116,51,53,105]}}
    2024-10-15 19:24:15.527  - info: shelly.0 (1241) [MQTT] Device with client id "shellyplus1pm-d4d4daeb2ddc" connected!
    2024-10-15 19:24:15.673  - debug: shelly.0 (1241) [createObjects] Starting object creation of (shellyplus1pm / shellyplus1pm-d4d4daeb2ddc / shellyplus1pm#d4d4daeb2ddc#1) for mode: <not set>
    2024-10-15 19:24:15.687  - debug: shelly.0 (1241) [MQTT Server] New connection from 192.168.178.32
    2024-10-15 19:24:15.688  - debug: shelly.0 (1241) [MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":101,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"shellyplus1pm-10061cca8844/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellyplus1pm-10061cca8844","username":"mqttuser","password":{"type":"Buffer","data":[80,97,115,115,97,116,51,53,105]}}
    2024-10-15 19:24:15.689  - info: shelly.0 (1241) [MQTT] Device with client id "shellyplus1pm-10061cca8844" connected!
    2024-10-15 19:24:15.707  - debug: shelly.0 (1241) [MQTT Server] New connection from 192.168.178.34
    2024-10-15 19:24:15.708  - debug: shelly.0 (1241) [MQTT Server] New connection from 192.168.178.40
    2024-10-15 19:24:15.710  - debug: shelly.0 (1241) [MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":101,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"shellyplus1pm-b0b21c1b4e14/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellyplus1pm-b0b21c1b4e14","username":"mqttuser","password":{"type":"Buffer","data":[80,97,115,115,97,116,51,53,105]}}
    2024-10-15 19:24:15.710  - info: shelly.0 (1241) [MQTT] Device with client id "shellyplus1pm-b0b21c1b4e14" connected!
    2024-10-15 19:24:15.712  - debug: shelly.0 (1241) [MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":101,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"shellyplus1pm-10061ccad010/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellyplus1pm-10061ccad010","username":"mqttuser","password":{"type":"Buffer","data":[80,97,115,115,97,116,51,53,105]}}
    2024-10-15 19:24:15.713  - info: shelly.0 (1241) [MQTT] Device with client id "shellyplus1pm-10061ccad010" connected!
    2024-10-15 19:24:15.774  - debug: shelly.0 (1241) [createObjects] Starting object creation of (shellyplus1pm / shellyplus1pm-10061cca8844 / shellyplus1pm#10061cca8844#1) for mode: <not set>
    • A Accuface
      was?
      Hast du den Raspi oder iobroker neu gestartet?
      A 1 Antwort Letzte Antwort
        Accuface
        schrieb am zuletzt editiert von Accuface
        ich bin jetzt verwirrt... ich hab den Raspi auch neu gestartet, kommt drauf an wann du meinst?
        Ich sollte den doch rebooten
        Ich brauch klare ansagen wass ich wann und wie machen soll, ich hab doch null plan, schon vergessen 😥
        HomoranH crunchipC 2 Antworten Letzte Antwort
        • A Accuface
          aber doch nicht jedesmal für ein log
            Accuface
            sorry, dass muss mir doch gesagt werden. ich hab im Geschäft gelernt, lieber einmal mehr rebooten als zu wenig, sagen unsere ITler immer
            • A Accuface
              schadet auch nicht.
              Aber es ging doch um ein debug-log vom shrlly.
              Da nutzt das log vom reboot nichts.
              Kein Wunder dass es so viele Zeichen hat.
                schadet auch nicht.
                Accuface
                schadet auch nicht.
                ok, was soll ich jetzt machen?
                • A Accuface
                  schadet auch nicht.
                  das log mit den debug Ausgaben zum Shelly sieht soweit problemlos aus.
                  Wo liegt das Problem?
                  oder sind die entsprechenden Zeilen nicht dabei?
                  A 2 Antworten Letzte Antwort
                    Accuface
                    Wenn ich das nur wüsste, müsste ich euch nicht Nerven 😬
                    Weiß ich leider nicht. Ich weiß ja nicht wonach gesucht wird.
                    es wurde ein log verlangt, der zu lang ist, dann hab ich halt was rauskopiert.
                    • A Accuface
                      crunchipC Abwesend
                      crunchipC Abwesend
                      das kommt mir komisch vor
                      for mode: <not set>
                      ansonsten steht ja überall connectet
                      • A Accuface
                        crunchipC Abwesend
                        crunchipC Abwesend
                        hatte ich doch ...einmal neu starten, wegen
                        @crunchip sagte in Shellys per mqtt keine Verbindung:
                        code 7 (ADAPTER_ALREADY_RUNNING
                          for mode: <not set>
                          Accuface
                          @crunchip said in Shellys per mqtt keine Verbindung:
                          for mode: <not set>
                          Dass ist der Shelly wo der Kühlschrank dranhängt. Der funktioniert ordnungsgemäß und wird auch unter den Objekten geführt
                            Accuface
                            das Problem ist weiterhin, dass ich seid ..... zeitpunkt unbekannt...... keine Shellys per MQTT mehr in iob einbinden kann.
                            HomoranH Samson71S 2 Antworten Letzte Antwort
                            • A Accuface
                              zusätzlich zum shelly Adapter?
                              bitte iob diag in der Langfassung posten
                              • A Accuface
                                Samson71S Offline
                                Samson71S Offline
                                Samson71
                                @accuface
                                Ich hab bis hier nur sporadisch gelesen/überflogen, bin aber auch mehr verwirrt was jetzt GENAU das Problem ist.
                                Vorschlag:
                                • Aktuelle Screenshots der Einstellungen EINES Shellys der aktuell nachweislich nicht einzubinden ist
                                • aktuelle Screenshots der momentanen Einstellungen des Shelly-Adapters
                                Nochmal zu meinem Verständnis. Du meinst mit MQTT aber schon den Shelly Adapter selbst und nicht zufällig den MQTT-Adapter?
                                Markus
                                Bitte beachten:
                                  Accuface
                                  Ich versteh die frage nicht. es lassen sich eben keine Shellys mehr in den Shelly Adapter mehr einfügen.
                                  wenn ich in einem Shelly den MQTT über die weboberfläche aktivieren und alles einstelle/eingebe und den Shelly neu starte, dann zeigt er mir in der Shelly App auf dem Iphone unter MQTT an dass er trozdem getrennt ist.
                                  in der Shelly Instanz/Objekten taucht er auch nicht auf, somit schließe ich dass irgendwo ein Problem besteht, das die Telefonate verhindert.
                                  kommt
                                  • Samson71S Samson71
                                    @accuface
                                    Vorschlag:
                                    Accuface
                                    @samson71 said in Shellys per mqtt keine Verbindung:
                                    @accuface
                                    Vorschlag:
                                    ist alles in meinem ersten Post drin. erstellt gestern Abend. am Sonntagabend hab ich festgestellt dass es nicht mehr funktioniert.
                                    MQTT-Adapter? hatte ich Nie drauf
                                    • A Accuface
                                      kommt
                                      ich hatte befürchtet, wie auch @samson71, dass du zusätzlich zum Shelly Adapter auch noch den MQTT Adapter nutzen wolltest
                                      • A Accuface
                                        for mode: <not set>
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        @accuface war auch nicht auf den shelly bezogen, sondern generell die Meldung
                                          Accuface
                                          Skript v.2024-08-12
                                          *** BASE SYSTEM ***
                                          ======== Start marking the full check here =========
                                          ```bash
                                          Skript v.2024-08-12
                                          *** BASE SYSTEM ***
                                           Static hostname: raspberrypi5
                                                 Icon name: computer
                                                    Kernel: Linux 6.6.47+rpt-rpi-2712
                                              Architecture: arm64
                                          OS is similar to:
                                          Model           : Raspberry Pi 5 Model B Rev 1.0
                                          Docker          : false
                                          Virtualization  : none
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                          Systemuptime and Load:
                                           20:25:12 up  1:04,  2 users,  load average: 0.88, 0.43, 0.28
                                          CPU threads: 4
                                          *** RASPBERRY THROTTLING ***
                                          Current issues:
                                          Previously detected issues:
                                          *** Time and Time Zones ***
                                                         Local time: Tue 2024-10-15 20:25:12 CEST
                                                     Universal time: Tue 2024-10-15 18:25:12 UTC
                                                           RTC time: Tue 2024-10-15 18:25:12
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          *** Users and Groups ***
                                          User that called 'iob diag':
                                          Bernd
                                          HOME=/home/Bernd
                                          GROUPS=Bernd adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                          iobroker
                                          HOME=/home/iobroker
                                          *** Display-Server-Setup ***
                                          Display-Server: false
                                          Desktop:
                                          Terminal:       tty
                                          Boot Target:    multi-user.target
                                          *** MEMORY ***
                                          Mem:            8.4G        1.7G        5.9G        5.4M        993M        6.7G
                                          Swap:           209M          0B        209M
                                          Total:          8.7G        1.7G        6.1G
                                          Active iob-Instances:   22
                                                   8052 M total memory
                                                   1621 M used memory
                                                   1479 M active memory
                                                    726 M inactive memory
                                                   5585 M free memory
                                                    101 M buffer memory
                                                    845 M swap cache
                                                    199 M total swap
                                                      0 M used swap
                                                    199 M free swap
                                          top - 20:25:12 up  1:04,  2 users,  load average: 0.88, 0.43, 0.28
                                          Tasks: 180 total,   1 running, 179 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :   8052.3 total,   5585.5 free,   1621.4 used,    947.4 buff/cache
                                          MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6430.9 avail Mem
                                          *** FAILED SERVICES ***
                                          0 loaded units listed.
                                          *** FILESYSTEM ***
                                          udev           devtmpfs  3.8G     0  3.8G   0% /dev
                                          tmpfs          tmpfs     806M  5.2M  801M   1% /run
                                          /dev/mmcblk0p2 ext4       29G  7.1G   21G  26% /
                                          tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                                          tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                          /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
                                          tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
                                          [Tue Oct 15 19:20:45 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:56:18:0A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=8959849a-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                                          [Tue Oct 15 19:20:48 2024] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                                          [Tue Oct 15 19:20:49 2024] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
                                          Show mounted filesystems:
                                          TARGET           SOURCE         FSTYPE OPTIONS
                                          /                /dev/mmcblk0p2 ext4   rw,noatime
                                          `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          884M    /var/
                                          265M    /var/log/journal/9ba9919aad384e6eaaa1e9cb2eaa4832
                                          265M    /var/log
                                          252M    /var/cache
                                          Archived and active journals take up 264.6M in the file system.
                                          /opt/iobroker/backups:
                                          41M     /opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          1.4G    /opt/iobroker/iobroker-data/
                                          1.3G    /opt/iobroker/iobroker-data/files
                                          617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                          27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                          26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                                          26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                                          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                          USB-Devices by-id:
                                          No Devices found 'by-id'
                                          *** NodeJS-Installation ***
                                          /usr/bin/nodejs         v20.18.0
                                          /usr/bin/node           v20.18.0
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          /usr/bin/corepack       0.29.3
                                          nodejs:
                                            Installed: 20.18.0-1nodesource1
                                            Candidate: 20.18.0-1nodesource1
                                            Version table:
                                           *** 20.18.0-1nodesource1 1001
                                                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                                  100 /var/lib/dpkg/status
                                               20.17.0-1nodesource1 1001
                                               20.16.0-1nodesource1 1001
                                               20.15.1-1nodesource1 1001
                                               20.15.0-1nodesource1 1001
                                               20.14.0-1nodesource1 1001
                                               20.13.1-1nodesource1 1001
                                               20.13.0-1nodesource1 1001
                                               20.12.2-1nodesource1 1001
                                               20.12.1-1nodesource1 1001
                                               20.12.0-1nodesource1 1001
                                               20.11.1-1nodesource1 1001
                                               20.11.0-1nodesource1 1001
                                               20.10.0-1nodesource1 1001
                                               20.9.0-1nodesource1 1001
                                               20.8.1-1nodesource1 1001
                                               20.8.0-1nodesource1 1001
                                               20.7.0-1nodesource1 1001
                                               20.6.1-1nodesource1 1001
                                               20.6.0-1nodesource1 1001
                                               20.5.1-1nodesource1 1001
                                               20.5.0-1nodesource1 1001
                                               20.4.0-1nodesource1 1001
                                               20.3.1-1nodesource1 1001
                                               20.3.0-1nodesource1 1001
                                               20.2.0-1nodesource1 1001
                                               20.1.0-1nodesource1 1001
                                               20.0.0-1nodesource1 1001
                                               18.19.0+dfsg-6~deb12u2 500
                                               18.19.0+dfsg-6~deb12u1 500
                                          No problems detected
                                          Errors in npm tree:
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Core adapters versions
                                          admin:          7.1.5
                                          javascript:     8.8.3
                                          nodejs modules from github:     1
                                          | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                                          Adapter State
                                          + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
                                          + system.adapter.cloud.0                  : cloud                 : raspberrypi5                             -  enabled
                                          + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
                                            system.adapter.dwd.0                    : dwd                   : raspberrypi5                             - disabled
                                          + system.adapter.echarts.0                : echarts               : raspberrypi5                             -  enabled
                                            system.adapter.feiertage.0              : feiertage             : raspberrypi5                             - disabled
                                          + system.adapter.fronius-solarweb.0       : fronius-solarweb      : raspberrypi5                             -  enabled
                                          + system.adapter.fronius.0                : fronius               : raspberrypi5                             -  enabled
                                          + system.adapter.fronius.1                : fronius               : raspberrypi5                             -  enabled
                                          + system.adapter.history.0                : history               : raspberrypi5                             -  enabled
                                            system.adapter.ical.0                   : ical                  : raspberrypi5                             -  enabled
                                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi5                             -  enabled
                                          + system.adapter.iot.0                    : iot                   : raspberrypi5                             -  enabled
                                            system.adapter.iqontrol.0               : iqontrol              : raspberrypi5                             - disabled
                                          + system.adapter.jarvis.0                 : jarvis                : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          + system.adapter.javascript.0             : javascript            : raspberrypi5                             -  enabled
                                            system.adapter.ping.0                   : ping                  : raspberrypi5                             - disabled
                                          + system.adapter.scenes.0                 : scenes                : raspberrypi5                             -  enabled
                                          + system.adapter.shelly.0                 : shelly                : raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
                                          + system.adapter.sql.0                    : sql                   : raspberrypi5                             -  enabled
                                          + system.adapter.synology.0               : synology              : raspberrypi5                             -  enabled, port: 5000
                                          + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi5                             -  enabled
                                          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi5                             -  enabled
                                            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi5                             -  enabled
                                            system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi5                             -  enabled
                                            system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: raspberrypi5                             -  enabled
                                            system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: raspberrypi5                             -  enabled
                                            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi5                             -  enabled
                                          + system.adapter.vis-2.0                  : vis-2                 : raspberrypi5                             -  enabled
                                            system.adapter.vis-metro.0              : vis-metro             : raspberrypi5                             -  enabled
                                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi5                             -  enabled
                                            system.adapter.vis-weather.0            : vis-weather           : raspberrypi5                             -  enabled
                                            system.adapter.vis.0                    : vis                   : raspberrypi5                             -  enabled
                                            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi5                             - disabled
                                          + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi5                             -  enabled
                                          + instance is alive
                                          ioBroker-Repositories
                                          Active repo(s): stable
                                          Upgrade policy: none
                                          Installed ioBroker-Instances
                                          Used repository: stable
                                          Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                          Adapter    "backitup"     : 3.0.25   , installed 3.0.22 [Updatable]
                                          Adapter    "cloud"        : 5.0.1    , installed 5.0.1
                                          Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                                          Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                                          Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                                          Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                                          Adapter    "ical"         : 1.15.0   , installed 1.15.0
                                          Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                                          Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                                          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                          Controller "js-controller": 6.0.11   , installed 6.0.11
                                          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                                          Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                                          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                          Adapter    "sql"          : 3.0.1    , installed 3.0.1
                                          Adapter    "synology"     : 3.1.0    , installed 3.1.0
                                          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                          Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                                          Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                                          Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
                                          Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
                                          Adapter    "vis-2-widgets-jaeger-design": 1.2.7, installed 1.2.7
                                          Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                                          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                          Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                          Objects and States
                                          Objects:        5608
                                          States:         4481
                                          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                          Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                                          Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                                          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                          Reading package lists...
                                          Pending Updates: 0
                                          *** Listening Ports ***
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5626       777/sshd: /usr/sbin
                                          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       7833       1181/io.jarvis.0
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6380       766/iobroker.js-con
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7383       766/iobroker.js-con
                                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       43171      1414/io.shelly.0
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       7749       1136/io.web.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7422       812/io.admin.0
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          5628       777/sshd: /usr/sbin
                                          udp        0      0 0.0.0.0:48252           0.0.0.0:*                           104        6279       655/avahi-daemon: r
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6277       655/avahi-daemon: r
                                          udp6       0      0 :::60397                :::*                                104        6280       655/avahi-daemon: r
                                          udp6       0      0 fe80::dc25:f03d:c31:546 :::*                                0          6638       738/NetworkManager
                                          udp6       0      0 :::5353                 :::*                                104        6278       655/avahi-daemon: r
                                          2024-10-15 20:25:25.325  - debug: shelly.0 (1414) [MQTT] Publish: 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1) - topic: shellyplus1pm-b0b21c1b4e14/events/rpc, qos: 1, payload: {"src":"shellyplus1pm-b0b21c1b4e14","dst":"shellyplus1pm-b0b21c1b4e14/events","method":"NotifyStatus","params":{"ts":1729016724.29,"switch:0":{"id":0,"apower":3.9}}}
                                          2024-10-15 20:25:25.340  - debug: shelly.0 (1414) [MQTT] Publish: 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1) - topic: shellyplus1pm-b0b21c1b4e14/status/switch:0, qos: 1, payload: {"id":0, "source":"SHC", "output":true, "apower":4.5, "voltage":228.5, "current":0.047, "aenergy":{"total":550.191,"by_minute":[71.439,80.471,65.280],"minute_ts":1729016700},"temperature":{"tC":54.1, "tF":129.4}}
                                          2024-10-15 20:25:25.340  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.Power, value: 4.5
                                          2024-10-15 20:25:25.341  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.Voltage, value: 228.5
                                          2024-10-15 20:25:25.341  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.Current, value: 0.047
                                          2024-10-15 20:25:25.341  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.Energy, value: 550.191
                                          2024-10-15 20:25:26.819  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.31 (shellyplus1 / shellyplus1-e465b8f46ac4 / shellyplus1#e465b8f46ac4#1): state: shellyplus1#e465b8f46ac4#1.uptime, value: 1238126
                                          2024-10-15 20:25:26.844  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.63 (shellyplus1pm / shellyplus1pm-10061ccb9fc0 / shellyplus1pm#10061ccb9fc0#1): state: shellyplus1pm#10061ccb9fc0#1.uptime, value: 775665
                                          2024-10-15 20:25:27.125  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.26 (shellyplus1pm / shellyplus1pm-fcb46727891c / shellyplus1pm#fcb46727891c#1): state: shellyplus1pm#fcb46727891c#1.uptime, value: 1238125
                                          2024-10-15 20:25:27.179  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.39 (shellyplus1pm / shellyplus1pm-10061ccb0c48 / shellyplus1pm#10061ccb0c48#1): state: shellyplus1pm#10061ccb0c48#1.uptime, value: 1238125
                                          2024-10-15 20:25:27.179  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.39 (shellyplus1pm / shellyplus1pm-10061ccb0c48 / shellyplus1pm#10061ccb0c48#1): state: shellyplus1pm#10061ccb0c48#1.rssi, value: -58
                                          2024-10-15 20:25:27.241  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.29 (shellyplus1 / shellyplus1-cc7b5c85af80 / shellyplus1#cc7b5c85af80#1): state: shellyplus1#cc7b5c85af80#1.uptime, value: 994761
                                          2024-10-15 20:25:27.261  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): state: shellyplus1pm#b0b21c1b4e14#1.uptime, value: 1238121
                                          2024-10-15 20:25:27.261  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): state: shellyplus1pm#b0b21c1b4e14#1.rssi, value: -73
                                          2024-10-15 20:25:31.322  - debug: shelly.0 (1414) [MQTT] Publish: 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1) - topic: shellyplus1pm-b0b21c1b4e14/events/rpc, qos: 1, payload: {"src":"shellyplus1pm-b0b21c1b4e14","dst":"shellyplus1pm-b0b21c1b4e14/events","method":"NotifyStatus","params":{"ts":1729016726.29,"switch:0":{"id":0,"apower":4.7}}}
                                          2024-10-15 20:25:31.332  - debug: shelly.0 (1414) [MQTT] Publish: 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1) - topic: shellyplus1pm-b0b21c1b4e14/status/switch:0, qos: 1, payload: {"id":0, "source":"SHC", "output":true, "apower":5.6, "voltage":228.4, "current":0.061, "aenergy":{"total":550.200,"by_minute":[71.439,80.471,65.280],"minute_ts":1729016700},"temperature":{"tC":54.0, "tF":129.3}}
                                          2024-10-15 20:25:31.332  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.temperatureC, value: 54
                                          2024-10-15 20:25:31.332  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.temperatureF, value: 129.3
                                          2024-10-15 20:25:31.332  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.Power, value: 5.6
                                          2024-10-15 20:25:31.332  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.Voltage, value: 228.4
                                          2024-10-15 20:25:31.332  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.Current, value: 0.061
                                          2024-10-15 20:25:31.332  - debug: shelly.0 (1414) [MQTT] State change 192.168.178.34 (shellyplus1pm / shellyplus1pm-b0b21c1b4e14 / shellyplus1pm#b0b21c1b4e14#1): shellyplus1pm-b0b21c1b4e14/status/switch:0 -> state: shellyplus1pm#b0b21c1b4e14#1.Relay0.Energy, value: 550.2
                                          2024-10-15 20:25:31.786  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.35 (shellyplus1pm / shellyplus1pm-d4d4daeb2ddc / shellyplus1pm#d4d4daeb2ddc#1): state: shellyplus1pm#d4d4daeb2ddc#1.uptime, value: 1238120
                                          2024-10-15 20:25:32.606  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.33 (shellyplus1pm / shellyplus1pm-cc7b5c0dd95c / shellyplus1pm#cc7b5c0dd95c#1): state: shellyplus1pm#cc7b5c0dd95c#1.uptime, value: 1238132
                                          2024-10-15 20:25:33.444  - debug: shelly.0 (1414) [httpIoBrokerState] State change 192.168.178.38 (shellyplus1pm / shellyplus1pm-d4d4da35853c / shellyplus1pm#d4d4da35853c#1): state: shellyplus1pm#d4d4da35853c#1.uptime, value: 1238128
