  4. Motion eye startet nicht
27 Beiträge 6 Kommentatoren 4.0k Aufrufe 4 Beobachtet
  • L Offline
    line
    Ich wollte heute Motion Eye auf meinem Raspi installieren. Aber er startet mit dem Port 8756 nicht.
    Mit systemctl status motioneye
     motioneye.service - motionEye Server
         Loaded: loaded (/etc/systemd/system/motioneye.service; enabled; vendor preset: enabled)
         Active: active (running) since Sun 2024-10-13 13:07:22 CEST; 1h 12min ago
       Main PID: 385 (meyectl)
          Tasks: 5 (limit: 4915)
            CPU: 7.958s
         CGroup: /system.slice/motioneye.service
                 ├─385 /usr/bin/python2 /usr/local/bin/meyectl startserver -c /etc/motioneye/motioneye.conf
                 └─564 /usr/bin/python2 /usr/local/bin/meyectl startserver -c /etc/motioneye/motioneye.conf
    Oct 13 13:07:22 iobroker-pi systemd[1]: Started motionEye Server.
    Oct 13 13:07:25 iobroker-pi meyectl[385]:     INFO: hello! this is motionEye server 0.42.1
    Oct 13 13:07:27 iobroker-pi meyectl[385]:     INFO: main config file /etc/motioneye/motion.conf does not exist, using default values
    Oct 13 13:07:27 iobroker-pi meyectl[385]:     INFO: cleanup started
    Oct 13 13:07:27 iobroker-pi meyectl[385]:     INFO: wsswitch started
    Oct 13 13:07:27 iobroker-pi meyectl[385]:     INFO: tasks started
    Oct 13 13:07:27 iobroker-pi meyectl[385]:     INFO: mjpg client garbage collector started
    Oct 13 13:07:27 iobroker-pi meyectl[385]:     INFO: server started
    Mit sudo systemctl status motion
    motion.service - Motion - Security camera monitoring software.
         Loaded: loaded (/lib/systemd/system/motion.service; disabled; vendor preset: enabled)
         Active: inactive (dead)
           Docs: man:motion(1)
    Oct 13 13:34:50 iobroker-pi motion[3038]: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
    Oct 13 13:34:50 iobroker-pi motion[3038]: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directo>
    Oct 13 13:34:50 iobroker-pi motion[3038]: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
    Oct 13 13:34:52 iobroker-pi motion[3038]: [0:motion] [NTC] [ALL] sig_handler: Received signal 15.
    Oct 13 13:34:52 iobroker-pi systemd[1]: Stopping Motion - Security camera monitoring software....
    Oct 13 13:34:52 iobroker-pi motion[3038]: [1:ml1] [NTC] [ALL] motion_loop: Thread exiting
    Oct 13 13:34:52 iobroker-pi motion[3038]: [0:motion] [NTC] [ALL] main: Threads finished
    Oct 13 13:34:52 iobroker-pi motion[3038]: [0:motion] [NTC] [ALL] main: Motion terminating
    Oct 13 13:34:52 iobroker-pi systemd[1]: motion.service: Succeeded.
    Oct 13 13:34:52 iobroker-pi systemd[1]: Stopped Motion - Security camera monitoring software..
    Wisst ihr was fehlt oder was hier nicht geklappt hat?
    Thomas BraunT haselchenH 2 Antworten Letzte Antwort
    • L line
              CPU: 7.958s
             Docs: man:motion(1)
      @line
      Wie wurde das auf welchem System installiert?
      Ich würde mir auch eher eine andere Software suchen, motioneye ist ein 'wenig' eingeschlafen.
      python2 ist auch schon seit Jahren abgekündigt.
      L 1 Antwort Letzte Antwort
        @line
        line
        @thomas-braun bullseye Version 11
        • crunchipC Abwesend
          crunchipC Abwesend
          @thomas-braun sagte in Motion eye startet nicht:
          python2
          gäbe es auch schon mit version 3
          @line sagte in Motion eye startet nicht:
          bullseye Version 11
          aktuell ist V12
            python2
            bullseye Version 11
            aktuell ist V12
            line
            @crunchip
            Ist dies gleich zu setzten mit Motion Eye? Ich habe eine ip Kamara die ich gerne in die Iqontrol einbinden will.
            • L line
              @crunchip
              crunchipC Abwesend
              crunchipC Abwesend
              @line https://github.com/motioneye-project/motioneye/releases
              • L line
                        CPU: 7.958s
                       Docs: man:motion(1)
                haselchenH Offline
                haselchenH Offline
                haselchen
                @line
                Hast Du Dich verschrieben bei dem Port?
                Er ist 8765 und nicht , wie Du geschrieben hast 8756.
                "Öffnen Sie die MotionEye-Benutzeroberfläche mit Ihren Webbrowsern, indem Sie die IP-Adresse Ihres Raspberry Pi gefolgt von Port 8765 eingeben"
                • haselchenH haselchen
                  @line
                  line
                  @haselchen
                  Sowas doofes. Du hast recht! Ich dachte es wäre 8756. Danke dir, jetzt gehts
                  • L line
                    @haselchen
                    line
                    schrieb am zuletzt editiert von line
                    @line ok Kamara konnte ich nun einbinden.
                    Der Status zeigt folgenden Fehler
                    Oct 13 16:49:12 iobroker-pi meyectl[385]:    ERROR: rtsp client error: Connection refused
                    Oct 13 16:49:23 iobroker-pi meyectl[385]:     INFO: adding new netcam camera with id 1...
                    Oct 13 16:49:23 iobroker-pi motion[11559]: [0:motion] [NTC] [ALL] conf_load: Processing thread 0 - config file /etc/motioneye/motion.conf
                    Oct 13 16:49:23 iobroker-pi motion[11559]: [0:motion] [NTC] [ALL] config_camera: Processing camera config file camera-1.conf
                    Oct 13 16:49:23 iobroker-pi motion[11559]: [0:motion] [ALR] [ALL] conf_cmdparse: "netcam_keepalive" replaced with "netcam_params" after version >
                    Oct 13 16:49:23 iobroker-pi motion[11559]: [0:motion] [ALR] [ALL] conf_cmdparse: "netcam_tolerant_check" replaced with "netcam_params" after ver>
                    Oct 13 16:49:23 iobroker-pi motion[11559]: [0:motion] [NTC] [ALL] motion_startup: Logging to syslog
                    Oct 13 16:49:23 iobroker-pi motion[11559]: [0:motion] [NTC] [ALL] motion_startup: Motion 4.7.0 Started
                    Oct 13 16:49:23 iobroker-pi motion[11559]: [0:motion] [NTC] [ALL] motion_startup: Using default log type (ALL)
                    Oct 13 16:49:23 iobroker-pi motion[11559]: [0:motion] [NTC] [ALL] motion_startup: Using log type (ALL) log level (WRN)
                      crunchipC Abwesend
                      crunchipC Abwesend
                      welche und wie?
                      • L line
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        @line
                        Connection refused deutet auf ein Problem mit der Verbindung zur Kamera hin.
                        Wie lautet deine RTSP URL?
                        Und wo haste die her ?
                        Hersteller oder aus dem Netz ?
                          @line
                          line
                          @haselchen
                          Vom Gerät hab ich die rtsp. Sie lautet rtsp://ip:554/live/ch1
                          Ich bekomm auch ein Bild, jedoch wundert mich die Fehlermeldung
                          wendy2702W haselchenH 2 Antworten Letzte Antwort
                          • L line
                            @haselchen
                            wendy2702W Offline
                            wendy2702W Offline
                            wendy2702
                            @line welche Fehlermeldung?
                            Sehe im log fitzel keinen Error
                            • wendy2702W wendy2702
                              line
                              @wendy2702
                              Oct 13 16:53:47 iobroker-pi motion[11715]: [0:motion] [NTC] [ALL] motion_startup: Using log type (ALL) log level (WRN)
                              Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] conf_load: Processing thread 0 - config file /etc/motioneye/motion.conf
                              Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] config_camera: Processing camera config file camera-1.conf
                              Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [ALR] [ALL] conf_cmdparse: "netcam_keepalive" replaced with "netcam_params" after version >
                              Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [ALR] [ALL] conf_cmdparse: "netcam_tolerant_check" replaced with "netcam_params" after ver>
                              Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] motion_startup: Logging to syslog
                              Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] motion_startup: Motion 4.7.0 Started
                              Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] motion_startup: Using default log type (ALL)
                              Oct 13 16:54:32 iobroker-pi motion[11792]: [0:motion] [NTC] [ALL] motion_startup: Using log type (ALL) log level (WRN)
                              Oct 13 17:25:38 iobroker-pi motion[11792]: [2:nc2:Hausgang] [ERR] [NET] netcam_rtsp_handler_reconnect: norm: Reconnecting with camera....
                              • L line
                                @haselchen
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                @line
                                Also, korrigiert mich , aber meine Streams haben entweder einen Token oder ich muss Benutzername und Passwort mit in die URL packen.
                                Hast Du mal den ONVIF Manager ausprobiert (Windows). Der liefert dir die genaue Stream URL.
                                  @line
                                  line
                                  @haselchen der obere RTSP habe ich im Motion Eye eingegeben. Dieser ist ja dann mit User und PW.
                                  Laut der Einstellung in meiner Kamara ist die RTSP wie folgt:
                                  rtsp://User:PW@IP_Nummer:544/live/ch1
                                  Aber wie gesagt, den User/PW gebe ich ja in der Motion Eye Setup ein
                                  bahnuhrB haselchenH 2 Antworten Letzte Antwort
                                  • L line
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    Dann musst du auch die von ME zur Verfügung gestellte url eingeben; und nicht die rtsp
                                    Danke.
                                    gute Forenbeiträge: https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
                                    • L line
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      @line
                                      Vermutlich ein Kommunikationsfehler.
                                      Also beim Anlegen der Kamera gibst Du ja Network Kamera an.
                                      Da kommt dann die RTSP URL rein OHNE Benutzername und Passwort.
                                      Und in den Feldern darunter, da gibst Du dann Benutzername und Passwort ein.
                                      Vorausgesetzt, so ist das bei Deiner Kamera vorgesehen.
                                      Bei meiner Wansview muss ich nen Token mit angeben (herausgefunden über ONVIF Manager).
                                      Bei meiner Tapo muss ich das so eingeben, wie oben beschrieben.
                                      • bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        In ME hier den rtsp:
                                        Und hier erhälts du die Streaming url:
                                        Bei mir:
                                        Und diesen dann in vis.
                                        Danke.
                                          @line
                                          line
                                          @haselchen ich musste den motion eye nochmals deinstallieren und neu aufsetzten, weil er zu viele Fehler hatte.
                                          Nun konnte ich meinen Iobroker nicht mehr wie gewohnt auf dem Port 8081 erreichen, sondern auf dem 8082.
                                          in der Iobroker list instance zeigt er mir jedoch den 8081 an:
                                          system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          Die Ports von motion und motion eye sind in der config auf 8765 gesetzt. Das passt.
                                          Jedoch hab ich unternetstart -n -a -p TCP so viele Dienste drin - teilweise auch doppelt. Kann das zusammenhängen mit dem neuen Iobroker Port 8082?
