  4. Update von Adapter führt zu Deinstallation von js-controller
30 Beiträge 5 Kommentatoren 4.0k Aufrufe 4 Beobachtet
  • J Offline
    JanGa
    schrieb am zuletzt editiert von JanGa
    Immer wenn ich Adapter hinzufüge, oder update (hier beispielhaft Update vom Telegramm Adapter), zerlegt es meine IOBroker Installation und am Ende muss ich den js-controller neu installieren, weil dieser fehlt. Im Log finde ich sowas:
    2024-08-21 20:52:24.145  - ^[[31merror^[[39m: kostal-piko-ba.0 (1595) Error: Cannot find module '/opt/iobroker/node_modules/axios/dist/node/axios.cjs'
        at createEsmNotFoundErr (node:internal/modules/cjs/loader:1182:15)
        at finalizeEsmResolution (node:internal/modules/cjs/loader:1170:15)
        at resolveExports (node:internal/modules/cjs/loader:592:14)
        at Function.Module._findPath (node:internal/modules/cjs/loader:669:31)
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1131:27)
        at Function.Module._load (node:internal/modules/cjs/loader:986:27)
        at Module.require (node:internal/modules/cjs/loader:1233:19)
        at require (node:internal/modules/helpers:179:18)
        at KostalPikoBA.ReadPiko (/opt/iobroker/node_modules/iobroker.kostal-piko-ba/main.js:377:23)
        at KostalPikoBA.Scheduler (/opt/iobroker/node_modules/iobroker.kostal-piko-ba/main.js:300:14)
    2024-08-21 20:52:24.145  - ^[[31merror^[[39m: kostal-piko-ba.0 (1595) Exception-Code: MODULE_NOT_FOUND: Cannot find module '/opt/iobroker/node_modules/axios/dist/node/axios.cjs'
    2024-08-21 20:52:24.160  - ^[[32minfo^[[39m: shelly.0 (1570) [authEnabled] 192.168.69.15 (shellyswitch25 / shellyswitch25-10521C45DF27 / SHSW-25#10521C45DF27#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-21 20:52:24.181  - ^[[32minfo^[[39m: kostal-piko-ba.0 (1595) Adapter Kostal-Piko-BA cleaned up everything...
    2024-08-21 20:52:24.181  - ^[[32minfo^[[39m: kostal-piko-ba.0 (1595) terminating
    2024-08-21 20:52:24.182  - ^[[33mwarn^[[39m: kostal-piko-ba.0 (1595) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-08-21 20:52:24.282  - ^[[32minfo^[[39m: shelly.0 (1570) [authEnabled] 192.168.69.32 (shellyplug-s / shellyplug-s-0CB80C / SHPLG-S#0CB80C#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/axios/dist/node/axios.cjs'
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at createEsmNotFoundErr (node:internal/modules/cjs/loader:1182:15)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at finalizeEsmResolution (node:internal/modules/cjs/loader:1170:15)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at resolveExports (node:internal/modules/cjs/loader:592:14)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at Function.Module._findPath (node:internal/modules/cjs/loader:669:31)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1131:27)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:986:27)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at KostalPikoBA.ReadPiko (/opt/iobroker/node_modules/iobroker.kostal-piko-ba/main.js:377:23)
    2024-08-21 20:52:24.342  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at KostalPikoBA.Scheduler (/opt/iobroker/node_modules/iobroker.kostal-piko-ba/main.js:300:14) {
    2024-08-21 20:52:24.342  - ^[[31merror^[[39m: host.automation Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2024-08-21 20:52:24.342  - ^[[31merror^[[39m: host.automation Caught by controller[0]:   path: '/opt/iobroker/node_modules/axios/package.json'
    2024-08-21 20:52:24.342  - ^[[31merror^[[39m: host.automation Caught by controller[0]: }
    2024-08-21 20:52:24.342  - ^[[31merror^[[39m: host.automation instance system.adapter.kostal-piko-ba.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-08-21 20:52:24.342  - ^[[32minfo^[[39m: host.automation Adapter system.adapter.kostal-piko-ba.0 needs rebuild and will be restarted afterwards.
    2024-08-21 20:52:24.342  - ^[[32minfo^[[39m: host.automation system.adapter.kostal-piko-ba.0 will be rebuilt
    2024-08-21 20:52:24.342  - ^[[33mwarn^[[39m: host.automation adapter "kostal-piko-ba" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
    2024-08-21 20:52:24.345  - ^[[31merror^[[39m: host.automation uncaught exception: Could not determine controller directory
    2024-08-21 20:52:24.345  - ^[[31merror^[[39m: host.automation Error: Could not determine controller directory
        at Module.getControllerDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1853:11)
        at installAdapters (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:2900:42)
        at processMessage (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:2373:46)
        at file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:3470:37
        at Immediate.<anonymous> (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:1042:31)
        at processImmediate (node:internal/timers:485:21)
    2024-08-21 20:52:24.346  - ^[[32minfo^[[39m: host.automation stopInstance system.adapter.admin.0 (force=false, process=true)
    2024-08-21 20:52:24.346  - ^[[32minfo^[[39m: host.automation stopInstance system.adapter.javascript.0 (force=false, process=true)
    2024-08-21 20:52:24.346  - ^[[32minfo^[[39m: host.automation stopInstance system.adapter.node-red.0 (force=false, process=false)
    2024-08-21 20:52:24.346  - ^[[32minfo^[[39m: host.automation stopInstance system.adapter.history.0 (force=false, process=true)
    2024-08-21 20:52:24.347  - ^[[32minfo^[[39m: host.automation stopInstance system.adapter.scenes.0 (force=false, process=true)
    2024-08-21 20:52:24.347  - ^[[32minfo^[[39m: host.automation stopInstance system.adapter.telegram.0 (force=false, process=true)
    2024-08-21 20:52:24.347  - ^[[32minfo^[[39m: host.automation stopInstance system.adapter.email.0 (force=false, process=true)
    2024-08-21 20:52:24.347  - ^[[32minfo^[[39m: host.automation stopInstance system.adapter.sql.0 (force=false, process=true)
    Danach werden auch alle anderen Instanzen, Skripte usw. beendet und dann endet das log und startet erst wieder nach Neuinstallation des JS-Controllers. Das ist mir jetzt schon mehrmals im letzten Jahr passiert und jedes Update wird zum Abenteuer. Kann mir eventuell jemand einen Tipp geben, wie ich das richten kann?
    Ein paar Daten zur Installation:
    node v20.16.0
    npm  10.8.1
    js-controller 6.0.11
    Ubuntu 20.04.6 LTS
    Da immer das Modul axios zu fehlen scheint, hatte ich das schonmal mit npm -i axios installiert und danach sah es eigentlich ok aus. Aber heute ist das gleiche jetzt erneut aufgetreten. Ich habe auch schonmal den ganzen node_modules Ordner gelöscht und mit npm -i alles neu installiert. Das lief fehlerfrei durch.
    • J JanGa
      node v20.16.0
      npm  10.8.1
      Ubuntu 20.04.6 LTS
      @janga
      iob diag
      in der Langfassung sagt?
      J 1 Antwort Letzte Antwort
        @janga
        iob diag
        JanGa
        Danke für die schnelle Reaktion! Hier die Ausgabe, das Log am Ende habe ich weg gelassen, weil da nur steht wie unsicher ich meine Shellys eingerichtet habe. :D
        Skript v.2024-05-22
        *** BASE SYSTEM ***
          Static hostname: automation
                Icon name: computer-vm
                  Chassis: vm
           Virtualization: kvm
         Operating System: Ubuntu 20.04.6 LTS
                   Kernel: Linux 5.4.0-193-generic
             Architecture: x86-64
        model name      : Intel(R) Xeon(R) CPU E3-1245 v6 @ 3.70GHz
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
        22:26:02 up  1:21,  2 users,  load average: 0.31, 0.26, 0.30
        CPU threads: 3
        *** Time and Time Zones ***
                      Local time: Wed 2024-08-21 22:26:03 CEST
                  Universal time: Wed 2024-08-21 20:26:03 UTC
                        RTC time: Wed 2024-08-21 20:26:04
                     NTP service: active
                 RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        root
        HOME=/root
        GROUPS=root
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           5.8G        2.8G        922M        1.0M        2.0G        2.6G
        Swap:          2.0G        2.0M        2.0G
        Total:         7.8G        2.8G        3.0G
        Active iob-Instances:   42
                5753 M total memory
                2822 M used memory
                2934 M active memory
                1410 M inactive memory
                 922 M free memory
                 325 M buffer memory
                1683 M swap cache
                2047 M total swap
                   2 M used swap
                2045 M free swap
        top - 22:26:03 up  1:21,  2 users,  load average: 0.31, 0.26, 0.30
        Tasks: 185 total,   1 running, 184 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  2.1 sy,  0.0 ni, 95.7 id,  2.1 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   5753.6 total,    922.7 free,   2821.9 used,   2009.0 buff/cache
        MiB Swap:   2048.0 total,   2045.2 free,      2.8 used.   2624.1 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  3.9G     0  3.9G   0% /dev
        tmpfs          tmpfs     576M  1.2M  575M   1% /run
        /dev/sda1      ext4       32G   25G  5.9G  81% /
        tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     2.9G     0  2.9G   0% /sys/fs/cgroup
        /dev/loop1     squashfs   64M   64M     0 100% /snap/core20/2318
        /dev/loop0     squashfs   64M   64M     0 100% /snap/core20/2264
        /dev/loop2     squashfs   39M   39M     0 100% /snap/snapd/21465
        /dev/loop3     squashfs   39M   39M     0 100% /snap/snapd/21759
        /dev/loop4     squashfs   92M   92M     0 100% /snap/lxd/29619
        /dev/loop5     squashfs   92M   92M     0 100% /snap/lxd/24061
        tmpfs          tmpfs     576M     0  576M   0% /run/user/0
        [Wed Aug 21 21:04:10 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
        [Wed Aug 21 21:04:10 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
        Show mounted filesystems:
        TARGET                                SOURCE                 FSTYPE      OPTIONS
        /                                     /dev/sda1              ext4        rw,relatime,errors=remount-ro
        |-/sys                                sysfs                  sysfs       rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security              securityfs             securityfs  rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup                    tmpfs                  tmpfs       ro,nosuid,nodev,noexec,mode=755
        | | |-/sys/fs/cgroup/unified          cgroup2                cgroup2     rw,nosuid,nodev,noexec,relatime
        | | |-/sys/fs/cgroup/systemd          cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
        | | |-/sys/fs/cgroup/cpuset           cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,cpuset
        | | |-/sys/fs/cgroup/rdma             cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,rdma
        | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
        | | |-/sys/fs/cgroup/pids             cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,pids
        | | |-/sys/fs/cgroup/devices          cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,devices
        | | |-/sys/fs/cgroup/memory           cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,memory
        | | |-/sys/fs/cgroup/freezer          cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,freezer
        | | |-/sys/fs/cgroup/hugetlb          cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,hugetlb
        | | |-/sys/fs/cgroup/net_cls,net_prio cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
        | | |-/sys/fs/cgroup/perf_event       cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,perf_event
        | | `-/sys/fs/cgroup/blkio            cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,blkio
        | |-/sys/fs/pstore                    pstore                 pstore      rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf                       none                   bpf         rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug                 debugfs                debugfs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/tracing               tracefs                tracefs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/fuse/connections          fusectl                fusectl     rw,nosuid,nodev,noexec,relatime
        | `-/sys/kernel/config                configfs               configfs    rw,nosuid,nodev,noexec,relatime
        |-/proc                               proc                   proc        rw,nosuid,nodev,noexec,relatime
        | `-/proc/sys/fs/binfmt_misc          systemd-1              autofs      rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=13195
        |   `-/proc/sys/fs/binfmt_misc        binfmt_misc            binfmt_misc rw,nosuid,nodev,noexec,relatime
        |-/dev                                udev                   devtmpfs    rw,nosuid,noexec,relatime,size=4034392k,nr_inodes=1008598,mode=755
        | |-/dev/pts                          devpts                 devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | |-/dev/shm                          tmpfs                  tmpfs       rw,nosuid,nodev
        | |-/dev/hugepages                    hugetlbfs              hugetlbfs   rw,relatime,pagesize=2M
        | `-/dev/mqueue                       mqueue                 mqueue      rw,nosuid,nodev,noexec,relatime
        |-/run                                tmpfs                  tmpfs       rw,nosuid,nodev,noexec,relatime,size=589176k,mode=755
        | |-/run/lock                         tmpfs                  tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs                   sunrpc                 rpc_pipefs  rw,relatime
        | |-/run/user/0                       tmpfs                  tmpfs       rw,nosuid,nodev,relatime,size=589172k,mode=700
        | `-/run/snapd/ns                     tmpfs[/snapd/ns]       tmpfs       rw,nosuid,nodev,noexec,relatime,size=589176k,mode=755
        |   `-/run/snapd/ns/lxd.mnt           nsfs[mnt:[4026532400]] nsfs        rw
        |-/snap/core20/2318                   /dev/loop1             squashfs    ro,nodev,relatime
        |-/snap/core20/2264                   /dev/loop0             squashfs    ro,nodev,relatime
        |-/snap/snapd/21465                   /dev/loop2             squashfs    ro,nodev,relatime
        |-/snap/snapd/21759                   /dev/loop3             squashfs    ro,nodev,relatime
        |-/snap/lxd/29619                     /dev/loop4             squashfs    ro,nodev,relatime
        |-/snap/lxd/24061                     /dev/loop5             squashfs    ro,nodev,relatime
        `-/var/lib/lxcfs                      lxcfs                  fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        /var:
        6.2G    /var/
        3.2G    /var/log
        3.1G    /var/log/journal/e828ff4079780bc5c3f6a57759dbd61f
        2.9G    /var/lib
        Archived and active journals take up 3.0G in the file system.
        /opt/iobroker/backups:
        5.9M    /opt/iobroker/backups/
        180K    /opt/iobroker/backups/module
        100K    /opt/iobroker/backups/module/node_modules
        96K     /opt/iobroker/backups/module/node_modules/async
        48K     /opt/iobroker/backups/module/lib
        /opt/iobroker/iobroker-data:
        4.8G    /opt/iobroker/iobroker-data/
        3.4G    /opt/iobroker/iobroker-data/history
        951M    /opt/iobroker/iobroker-data/files
        442M    /opt/iobroker/iobroker-data/files/javascript.admin
        410M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        48M     /opt/iobroker/iobroker-data/objects.json.migrated
        48M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        42M     /opt/iobroker/iobroker-data/states.jsonl
        41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.16.0
        /usr/bin/node           v20.16.0
        /usr/bin/npm            10.8.1
        /usr/bin/npx            10.8.1
        /usr/bin/corepack       0.28.2
        nodejs:
         Installed: 20.16.0-1nodesource1
         Candidate: 20.16.0-1nodesource1
         Version table:
        *** 20.16.0-1nodesource1 1001
               500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
               100 /var/lib/dpkg/status
            20.15.1-1nodesource1 1001
            20.15.0-1nodesource1 1001
            20.14.0-1nodesource1 1001
            20.13.1-1nodesource1 1001
            20.13.0-1nodesource1 1001
            20.12.2-1nodesource1 1001
            20.12.1-1nodesource1 1001
            20.12.0-1nodesource1 1001
            20.11.1-1nodesource1 1001
            20.11.0-1nodesource1 1001
            20.10.0-1nodesource1 1001
            20.9.0-1nodesource1 1001
            20.8.1-1nodesource1 1001
            20.8.0-1nodesource1 1001
            20.7.0-1nodesource1 1001
            20.6.1-1nodesource1 1001
            20.6.0-1nodesource1 1001
            20.5.1-1nodesource1 1001
            20.5.0-1nodesource1 1001
            20.4.0-1nodesource1 1001
            20.3.1-1nodesource1 1001
            20.3.0-1nodesource1 1001
            20.2.0-1nodesource1 1001
            20.1.0-1nodesource1 1001
            20.0.0-1nodesource1 1001
            10.19.0~dfsg-3ubuntu1.6 500
               500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
               500 http://security.ubuntu.com/ubuntu focal-security/universe amd64 Packages
            10.19.0~dfsg-3ubuntu1 500
               500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.0.22
        javascript:     8.7.6
        nodejs modules from github:     2
        |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
        | | +-- browser-serialport@2.0.3 invalid: "https://github.com/noopkat/browser-serialport#c8628c41c11890d3058875994c15f83f2df8185b" from node_modules/avrgirl-arduino
        Adapter State
        + system.adapter.admin.0                  : admin                 : automation                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : automation                               -  enabled
        + system.adapter.backitup.0               : backitup              : automation                               -  enabled
         system.adapter.cloud.0                  : cloud                 : automation                               - disabled
        + system.adapter.denon.0                  : denon                 : automation                               -  enabled
        + system.adapter.discovery.0              : discovery             : automation                               -  enabled
         system.adapter.ds18b20.0                : ds18b20               : gartenhaus                               - disabled
        + system.adapter.email.0                  : email                 : automation                               -  enabled
        + system.adapter.ems-esp.0                : ems-esp               : automation                               -  enabled
        + system.adapter.firetv.0                 : firetv                : automation                               -  enabled
         system.adapter.flot.0                   : flot                  : automation                               -  enabled
         system.adapter.ham.0                    : ham                   : automation                               - disabled
        + system.adapter.history.0                : history               : automation                               -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : automation                               -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : automation                               -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : automation                               -  enabled, port: 0
         system.adapter.icons-icons8.0           : icons-icons8          : automation                               -  enabled
         system.adapter.icons-material-png.0     : icons-material-png    : automation                               -  enabled
         system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: automation                               -  enabled
        + system.adapter.info.0                   : info                  : automation                               -  enabled
        + system.adapter.iot.0                    : iot                   : automation                               -  enabled
        + system.adapter.javascript.0             : javascript            : automation                               -  enabled
         system.adapter.km200.0                  : km200                 : automation                               - disabled
        + system.adapter.kostal-piko-ba.0         : kostal-piko-ba        : automation                               -  enabled
        + system.adapter.lovelace.0               : lovelace              : automation                               -  enabled, port: 80, bind: 0.0.0.0, run as: admin
         system.adapter.material.0               : material              : automation                               -  enabled
        + system.adapter.mihome.0                 : mihome                : automation                               -  enabled, port: 9898, bind: 192.168.69.227
         system.adapter.mobile.0                 : mobile                : automation                               -  enabled
        + system.adapter.modbus.0                 : modbus                : automation                               -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : automation                               -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.mysensors.0              : mysensors             : automation                               -  enabled, port: 5003, bind: 0.0.0.0
         system.adapter.node-red.0               : node-red              : automation                               - disabled, port: 1880, bind: 0.0.0.0
         system.adapter.parser.0                 : parser                : automation                               - disabled
        + system.adapter.ping.0                   : ping                  : automation                               -  enabled
        + system.adapter.rflink.0                 : rflink                : automation                               -  enabled
         system.adapter.rickshaw.0               : rickshaw              : automation                               -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : powercount                               -  enabled
         system.adapter.rpi2.1                   : rpi2                  : gartenhaus                               -  enabled
        + system.adapter.scenes.0                 : scenes                : automation                               -  enabled
        + system.adapter.shelly.0                 : shelly                : automation                               -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : automation                               -  enabled, port: 1885, bind: 192.168.69.227
        + system.adapter.simple-api.0             : simple-api            : automation                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.smartmeter.0             : smartmeter            : powercount                               -  enabled
        + system.adapter.sonoff.0                 : sonoff                : automation                               -  enabled, port: 1884, bind: 0.0.0.0
         system.adapter.sony-bravia.0            : sony-bravia           : automation                               - disabled
        + system.adapter.sourceanalytix.0         : sourceanalytix        : automation                               -  enabled
        + system.adapter.sql.0                    : sql                   : automation                               -  enabled, port: 0
        + system.adapter.statistics.0             : statistics            : automation                               -  enabled
        + system.adapter.telegram.0               : telegram              : automation                               -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : automation                               -  enabled
        + system.adapter.unifi.0                  : unifi                 : automation                               -  enabled
         system.adapter.vis-bars.0               : vis-bars              : automation                               -  enabled
         system.adapter.vis-colorpicker.0        : vis-colorpicker       : automation                               -  enabled
         system.adapter.vis-history.0            : vis-history           : automation                               -  enabled
         system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : automation                               -  enabled
         system.adapter.vis-icontwo.0            : vis-icontwo           : automation                               -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : automation                               -  enabled
         system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : automation                               -  enabled
         system.adapter.vis-plumb.0              : vis-plumb             : automation                               -  enabled
         system.adapter.vis-rgraph.0             : vis-rgraph            : automation                               -  enabled
         system.adapter.vis-weather.0            : vis-weather           : automation                               -  enabled
         system.adapter.vis.0                    : vis                   : automation                               -  enabled
        + system.adapter.web.0                    : web                   : automation                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.web.1                    : web                   : automation                               -  enabled, port: 443, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.yahka.0                  : yahka                 : automation                               -  enabled
        + system.adapter.yeelight-2.0             : yeelight-2            : automation                               -  enabled
         system.adapter.yr.0                     : yr                    : automation                               -  enabled
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name     │ url                                              │ auto upgrade │
        │ 0       │ 'Stable' │ 'http://download.iobroker.net/sources-dist.json' │ false        │
        │ 1       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false        │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.0.23   , installed 7.0.22 [Updatable]
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 3.0.19   , installed 3.0.16 [Updatable]
        Adapter    "cloud"        : 5.0.1    , installed 5.0.1
        Adapter    "daswetter"    : 3.1.15   , installed 3.1.16
        Adapter    "denon"        : 1.15.12  , installed 1.15.12
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "email"        : 1.3.1    , installed 1.3.1
        Adapter    "ems-esp"      : 3.5.0    , installed 3.5.0
        Adapter    "firetv"       : 2.1.0    , installed 2.1.0
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
        Adapter    "icons-material-png": 0.1.0, installed 0.1.0
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
        Controller "js-controller": 6.0.9    , installed 6.0.11
        Adapter    "kostal-piko-ba": 4.0.1   , installed 4.0.1
        Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
        Adapter    "material"     : 1.3.1    , installed 1.3.1
        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "modbus"       : 6.2.3    , installed 6.2.3
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "mysensors"    : 3.0.0    , installed 3.0.0
        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
        Adapter    "parser"       : 2.2.2    , installed 2.2.2
        Adapter    "ping"         : 1.6.2    , installed 1.7.0
        Adapter    "rflink"       : 2.1.12   , installed 2.1.12
        Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
        Adapter    "scenes"       : 3.2.1    , installed 3.2.1
        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "solarwetter"  : 1.2.0    , installed 1.2.0
        Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
        Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
        Adapter    "sql"          : 3.0.1    , installed 3.0.1
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "telegram"     : 3.9.0    , installed 3.9.0
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
        Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
        Adapter    "yr"           : 5.3.0    , installed 5.3.0
        Objects and States
        Objects:        29630
        States:         25048
        Hit:1 http://security.ubuntu.com/ubuntu focal-security InRelease
        Hit:2 http://de.archive.ubuntu.com/ubuntu focal InRelease
        Hit:3 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:5 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
        Hit:6 https://esm.ubuntu.com/infra/ubuntu focal-infra-security InRelease
        Hit:7 https://esm.ubuntu.com/infra/ubuntu focal-infra-updates InRelease
        Reading package lists...
        Pending Updates: 1
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       126423     10494/iobroker.js-c
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       126420     10494/iobroker.js-c
        tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      111        27072      1096/mysqld
        tcp        0      0 0.0.0.0:5003            0.0.0.0:*               LISTEN      1001       131713     11817/io.mysensors.
        tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       129857     11581/adb
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14720      1/init
        tcp        0      0 0.0.0.0:34257           0.0.0.0:*               LISTEN      1001       138389     14000/io.yahka.0
        tcp        0      0 192.168.66.227:2001     0.0.0.0:*               LISTEN      1001       130853     11629/io.hm-rpc.0
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        17327      676/systemd-resolve
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25658      1016/sshd: /usr/sbi
        tcp        0      0 192.168.66.227:2010     0.0.0.0:*               LISTEN      1001       131491     11693/io.hm-rpc.1
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       130772     11589/io.mqtt.0
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       131643     11767/io.sonoff.0
        tcp        0      0 192.168.69.227:1885     0.0.0.0:*               LISTEN      1001       132347     11871/io.shelly.1
        tcp        0      0 127.0.0.1:33060         0.0.0.0:*               LISTEN      111        27070      1096/mysqld
        tcp        0      0 127.0.0.1:39813         0.0.0.0:*               LISTEN      1001       138398     14000/io.yahka.0
        tcp6       0      0 :::111                  :::*                    LISTEN      0          14724      1/init
        tcp6       0      0 :::80                   :::*                    LISTEN      1001       133655     12457/io.lovelace.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       125831     11215/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       132133     11760/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          25660      1016/sshd: /usr/sbi
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       137095     13953/io.simple-api
        tcp6       0      0 :::443                  :::*                    LISTEN      1001       132372     11883/io.web.1
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        22817      876/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       132162     11790/io.shelly.0
        udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       130593     11452/io.mihome.0
        udp        0      0 0.0.0.0:34580           0.0.0.0:*                           112        22819      876/avahi-daemon: r
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        17326      676/systemd-resolve
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14721      1/init
        udp6       0      0 :::45938                :::*                                112        22820      876/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                112        22818      876/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          15661      1/init
        • J JanGa
          Skript v.2024-05-22
          *** BASE SYSTEM ***
                    Chassis: vm
             Virtualization: kvm
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 3
                       NTP service: active
                   RTC in local TZ: no
          root
          HOME=/root
          GROUPS=root
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
                  5753 M total memory
                  2822 M used memory
                   922 M free memory
                   325 M buffer memory
                  1683 M swap cache
                  2047 M total swap
                     2 M used swap
                  2045 M free swap
          *** FILESYSTEM ***
          /var:
          6.2G    /var/
          3.2G    /var/log
          2.9G    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            10.8.1
          /usr/bin/npx            10.8.1
          nodejs:
           Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          7.0.22
          javascript:     8.7.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        29630
          States:         25048
          Pending Updates: 1
          @janga
          Nichts weglassen...
          Außer persönliche Infos oder Passworte und sowas.
          • J JanGa
            Skript v.2024-05-22
            *** BASE SYSTEM ***
                      Chassis: vm
               Virtualization: kvm
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
            CPU threads: 3
                         NTP service: active
                     RTC in local TZ: no
            root
            HOME=/root
            GROUPS=root
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
                    5753 M total memory
                    2822 M used memory
                     922 M free memory
                     325 M buffer memory
                    1683 M swap cache
                    2047 M total swap
                       2 M used swap
                    2045 M free swap
            *** FILESYSTEM ***
            /var:
            6.2G    /var/
            3.2G    /var/log
            2.9G    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            10.8.1
            /usr/bin/npx            10.8.1
            nodejs:
             Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          7.0.22
            javascript:     8.7.6
            Adapter State
            + instance is alive
            Objects and States
            Objects:        29630
            States:         25048
            Pending Updates: 1
            @janga sagte in Update von Adapter führt zu Deinstallation von js-controller:
            root
            HOME=/root
            GROUPS=root
            Und dann ist auch schon Schluß...
              @janga
              Nichts weglassen...
              JanGa
              War echt nur Ausgaben vom Shelly Adapter, die im Diag angezeigt wurden. Und zwei von MQTT. Denke nichts relevantes.
                root
                HOME=/root
                GROUPS=root
                JanGa
                @thomas-braun Ist nur eine private Kiste und ich hab ein Backup. Ich weiß, es ist falsch...
                • J JanGa
                  @janga
                  Es ist EGAL was das für eine Kiste ist. ES WIRD NICHT ALS ROOT HERUMGEHAMPELT, VERDAMMT NOCH EINS!!!!!!
                    @janga
                    JanGa
                    @thomas-braun Was soll ich sagen, seit 20 Jahren Windows Admin und Linux 10 Minuten im Monat als Hobby.
                    • J JanGa
                      @janga
                      Und wie und warum kommt man dann auf den Schwachsinn?
                      Eigentlich alle Distributionen richten dir gar keinen root mehr ein bei der Installation.
                      Schnubbibuntu schon gerade gar nicht.
                      Jedenfalls ergibt sich so ein merkwüdiges Verhalten fast immer durch das herumgerutsche als root.
                      Sind nämlich auch immer genau die user, die eh schon wenig bis gar keine Ahnung wie das alles funktioniert.
                      Je weniger $Ahnung desto mehr $root muss man sein, oder was ist die Logik dahinter?
                        @janga
                        JanGa
                        @thomas-braun Naja, ich melde mich an der Kiste ja nur für administrative Tätigkeiten an und für nichts anderes. Ob ich da jetzt vor jeden Befehl ein sudo hänge oder direkt root bin macht dann auch keinen riesigen Unterschied mehr. Spart halt 20 mal sudo tippen. Ist ja mein kalkuliertes Risiko, was ich nicht eingehe, weil ich nicht weiß wie es anders geht, sondern weil ich die möglichen Folgen kenne und damit leben kann. Baue ich Mist, wird das backup wiederhergestellt und gut. Ich hab da keine professionellen Ansprüche.
                        Meinst du das hat wirklich was mit den inhaltlichen Problemen meine IOBroker Installation zu tun?
                        • J JanGa
                          Ja.
                          Und im weiteren interessiert mich dann die verootete Kiste auch nicht mehr.
                            Ja.
                            JanGa
                            @thomas-braun Wenn du weiter so aggro bist, bearbeite ich gleich die sudoers mit nano! ;)
                            Thomas BraunT liv-in-skyL 2 Antworten Letzte Antwort
                            • J JanGa
                              @janga
                              Wie gesagt: Dein System und deine Probleme damit interessieren mich nicht.
                              • J JanGa
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                liv-in-sky
                                @janga lass dich nicht ärgern - in der "wurzel" seines herzens ist er ein ganz lieber :-)
                                ich hoffe du hast ein backup - dann würde ich mal einen user anegen (wie, findest du auch im forum)
                                wenn du weißt, wie du die backup datei wegsichern kannst, würde ich das ganze ding neu aufsetzen, einen user einrichten und iob neu installieren und dann das backup einspielen - dann bist du auf der sicheren seite
                                ich persönlich bevorzuge debian ohne gui
                                edit:
                                user anlegen findest du z.b hier:
                                https://www.iobroker.net/#de/documentation/install/proxmox.md
                                • liv-in-skyL liv-in-sky
                                  edit:
                                  JanGa
                                  @liv-in-sky
                                  Wenn man sieht wie vielen er hier hilft, liegt es mir auch fern seine gute Seele in Frage zu stellen. :D Ich weiß ja auch, dass sich jeder richtige Linux Admin die Haare rauft, wenn er sieht wie ich arbeite. Ich werde mal versuchen, da disziplinierter zu werden. Grundsätzlich kann ich das, weil ich im beruflichen Umfeld auch eine kleine Anzahl Linux-Server mit betreue. Da erfolgt die Anmeldung auch nicht per Passwort, sondern per Key usw..
                                  Wie man einen Benutzer anlegt weiß ich entsprechend. Es existiert auch entsprechender Benutzer auf dem IOBroker-Server. Ich habe trotzdem immer eine leichte Tendenz als erstes ein sudo su zu machen. Ist vielleicht auch nicht schlecht dafür zwischendurch mal beschimpft zu werden, hat mich schon nachdenklich gemacht. :)
                                  Neu aufsetzen ist eventuell gar keine schlechte Idee. Dann habe ich den Backup Adapter mal getestet und mein Ubuntu auf der Kiste ist ja auch nicht mehr ganz taufrisch. Die Frage ist nur, ob mein Problem damit behoben ist. Für mich sieht das ja nach einem Fehler in den Abhängigkeiten vom Kostal Adapter aus. Eventuell schmeiße ich den einfach mal raus und schaue, ob es dann geht.
                                  Ich habe früher auch immer nur Debian genutzt, bin dann aber in meiner privaten Umgebung irgendwann einheitlich auf Ubuntu gewechselt, weil die Pakete unter Debian immer ein gewisses Alter haben (wenn man nicht gerade Testing nutzt) und man dadurch automatisch öfter selbst kompiliert oder andere Quellen von Dritten hinzufügt. Bei Ubuntu habe ich das deutlich seltener und da ich die Server-Version verwende (die auch keine GUI hat), musste ich mich von der Bedienung her kaum umgewöhnen.
                                  • J JanGa
                                    @liv-in-sky
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    liv-in-sky
                                    hast du auf github nachgesehen, ob dieser fehler beim adapter ein issue ist ? oder evtl ml ein issue erstellt
                                    • crunchipC Offline
                                      crunchipC Offline
                                      dann schmeiß den doch mal runter und installier ihn neu
                                        JanGa
                                        @liv-in-sky Hatte ich geguckt, gibt kein Issue, aber ich glaube mit dem Adapter passiert eh nicht mehr viel.
                                        @crunchip Werde ich machen.
                                        • J JanGa
                                          node v20.16.0
                                          npm  10.8.1
                                          Ubuntu 20.04.6 LTS
                                          Da sehe ich erst einmal keinen kausalen Zusammenhang.
                                          Was ich sehe
                                          Virtualization: kvm
                                          und
                                          Intel(R) Xeon(R)
                                          dazu klingelt irgendwas in meinem Hinterkopf!
                                          doch!
                                          zum Thema Rechteverbiegung und ominöse Fehler durch root-Nutzung gibt es bereits drölfhundert Threads.
                                          J crunchipC 2 Antworten Letzte Antwort
