  4. Update von Adapter führt zu Deinstallation von js-controller
30 Beiträge 5 Kommentatoren 4.0k Aufrufe 4 Beobachtet
  • J JanGa
    Immer wenn ich Adapter hinzufüge, oder update (hier beispielhaft Update vom Telegramm Adapter), zerlegt es meine IOBroker Installation und am Ende muss ich den js-controller neu installieren, weil dieser fehlt. Im Log finde ich sowas:
    2024-08-21 20:52:24.145  - ^[[31merror^[[39m: kostal-piko-ba.0 (1595) Error: Cannot find module '/opt/iobroker/node_modules/axios/dist/node/axios.cjs'
        at createEsmNotFoundErr (node:internal/modules/cjs/loader:1182:15)
        at finalizeEsmResolution (node:internal/modules/cjs/loader:1170:15)
        at resolveExports (node:internal/modules/cjs/loader:592:14)
        at Function.Module._findPath (node:internal/modules/cjs/loader:669:31)
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1131:27)
        at Function.Module._load (node:internal/modules/cjs/loader:986:27)
        at Module.require (node:internal/modules/cjs/loader:1233:19)
        at require (node:internal/modules/helpers:179:18)
        at KostalPikoBA.ReadPiko (/opt/iobroker/node_modules/iobroker.kostal-piko-ba/main.js:377:23)
        at KostalPikoBA.Scheduler (/opt/iobroker/node_modules/iobroker.kostal-piko-ba/main.js:300:14)
    2024-08-21 20:52:24.145  - ^[[31merror^[[39m: kostal-piko-ba.0 (1595) Exception-Code: MODULE_NOT_FOUND: Cannot find module '/opt/iobroker/node_modules/axios/dist/node/axios.cjs'
    2024-08-21 20:52:24.160  - ^[[32minfo^[[39m: shelly.0 (1570) [authEnabled] 192.168.69.15 (shellyswitch25 / shellyswitch25-10521C45DF27 / SHSW-25#10521C45DF27#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-21 20:52:24.181  - ^[[32minfo^[[39m: kostal-piko-ba.0 (1595) Adapter Kostal-Piko-BA cleaned up everything...
    2024-08-21 20:52:24.181  - ^[[32minfo^[[39m: kostal-piko-ba.0 (1595) terminating
    2024-08-21 20:52:24.182  - ^[[33mwarn^[[39m: kostal-piko-ba.0 (1595) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-08-21 20:52:24.282  - ^[[32minfo^[[39m: shelly.0 (1570) [authEnabled] 192.168.69.32 (shellyplug-s / shellyplug-s-0CB80C / SHPLG-S#0CB80C#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/axios/dist/node/axios.cjs'
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at createEsmNotFoundErr (node:internal/modules/cjs/loader:1182:15)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at finalizeEsmResolution (node:internal/modules/cjs/loader:1170:15)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at resolveExports (node:internal/modules/cjs/loader:592:14)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at Function.Module._findPath (node:internal/modules/cjs/loader:669:31)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1131:27)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:986:27)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
    2024-08-21 20:52:24.341  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at KostalPikoBA.ReadPiko (/opt/iobroker/node_modules/iobroker.kostal-piko-ba/main.js:377:23)
    2024-08-21 20:52:24.342  - ^[[31merror^[[39m: host.automation Caught by controller[0]:     at KostalPikoBA.Scheduler (/opt/iobroker/node_modules/iobroker.kostal-piko-ba/main.js:300:14) {
    2024-08-21 20:52:24.342  - ^[[31merror^[[39m: host.automation Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2024-08-21 20:52:24.342  - ^[[31merror^[[39m: host.automation Caught by controller[0]:   path: '/opt/iobroker/node_modules/axios/package.json'
    2024-08-21 20:52:24.342  - ^[[31merror^[[39m: host.automation Caught by controller[0]: }
    2024-08-21 20:52:24.342  - ^[[31merror^[[39m: host.automation instance system.adapter.kostal-piko-ba.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-08-21 20:52:24.342  - ^[[32minfo^[[39m: host.automation Adapter system.adapter.kostal-piko-ba.0 needs rebuild and will be restarted afterwards.
    2024-08-21 20:52:24.342  - ^[[32minfo^[[39m: host.automation system.adapter.kostal-piko-ba.0 will be rebuilt
    2024-08-21 20:52:24.342  - ^[[33mwarn^[[39m: host.automation adapter "kostal-piko-ba" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
    2024-08-21 20:52:24.345  - ^[[31merror^[[39m: host.automation uncaught exception: Could not determine controller directory
    2024-08-21 20:52:24.345  - ^[[31merror^[[39m: host.automation Error: Could not determine controller directory
        at Module.getControllerDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1853:11)
        at installAdapters (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:2900:42)
        at processMessage (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:2373:46)
        at file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:3470:37
        at Immediate.<anonymous> (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:1042:31)
        at processImmediate (node:internal/timers:485:21)
    2024-08-21 20:52:24.346  - ^[[32minfo^[[39m: host.automation stopInstance system.adapter.admin.0 (force=false, process=true)
    2024-08-21 20:52:24.346  - ^[[32minfo^[[39m: host.automation stopInstance system.adapter.javascript.0 (force=false, process=true)
    2024-08-21 20:52:24.346  - ^[[32minfo^[[39m: host.automation stopInstance system.adapter.node-red.0 (force=false, process=false)
    2024-08-21 20:52:24.346  - ^[[32minfo^[[39m: host.automation stopInstance system.adapter.history.0 (force=false, process=true)
    2024-08-21 20:52:24.347  - ^[[32minfo^[[39m: host.automation stopInstance system.adapter.scenes.0 (force=false, process=true)
    2024-08-21 20:52:24.347  - ^[[32minfo^[[39m: host.automation stopInstance system.adapter.telegram.0 (force=false, process=true)
    2024-08-21 20:52:24.347  - ^[[32minfo^[[39m: host.automation stopInstance system.adapter.email.0 (force=false, process=true)
    2024-08-21 20:52:24.347  - ^[[32minfo^[[39m: host.automation stopInstance system.adapter.sql.0 (force=false, process=true)
    Danach werden auch alle anderen Instanzen, Skripte usw. beendet und dann endet das log und startet erst wieder nach Neuinstallation des JS-Controllers. Das ist mir jetzt schon mehrmals im letzten Jahr passiert und jedes Update wird zum Abenteuer. Kann mir eventuell jemand einen Tipp geben, wie ich das richten kann?
    Ein paar Daten zur Installation:
    node v20.16.0
    npm  10.8.1
    js-controller 6.0.11
    Ubuntu 20.04.6 LTS
    Da immer das Modul axios zu fehlen scheint, hatte ich das schonmal mit npm -i axios installiert und danach sah es eigentlich ok aus. Aber heute ist das gleiche jetzt erneut aufgetreten. Ich habe auch schonmal den ganzen node_modules Ordner gelöscht und mit npm -i alles neu installiert. Das lief fehlerfrei durch.
    @janga
    iob diag
    in der Langfassung sagt?
      @janga
      iob diag
      JanGa
      Danke für die schnelle Reaktion! Hier die Ausgabe, das Log am Ende habe ich weg gelassen, weil da nur steht wie unsicher ich meine Shellys eingerichtet habe. :D
      Skript v.2024-05-22
      *** BASE SYSTEM ***
        Static hostname: automation
              Icon name: computer-vm
                Chassis: vm
         Virtualization: kvm
       Operating System: Ubuntu 20.04.6 LTS
                 Kernel: Linux 5.4.0-193-generic
           Architecture: x86-64
      model name      : Intel(R) Xeon(R) CPU E3-1245 v6 @ 3.70GHz
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
      22:26:02 up  1:21,  2 users,  load average: 0.31, 0.26, 0.30
      CPU threads: 3
      *** Time and Time Zones ***
                    Local time: Wed 2024-08-21 22:26:03 CEST
                Universal time: Wed 2024-08-21 20:26:03 UTC
                      RTC time: Wed 2024-08-21 20:26:04
                   NTP service: active
               RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      root
      HOME=/root
      GROUPS=root
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           5.8G        2.8G        922M        1.0M        2.0G        2.6G
      Swap:          2.0G        2.0M        2.0G
      Total:         7.8G        2.8G        3.0G
      Active iob-Instances:   42
              5753 M total memory
              2822 M used memory
              2934 M active memory
              1410 M inactive memory
               922 M free memory
               325 M buffer memory
              1683 M swap cache
              2047 M total swap
                 2 M used swap
              2045 M free swap
      top - 22:26:03 up  1:21,  2 users,  load average: 0.31, 0.26, 0.30
      Tasks: 185 total,   1 running, 184 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  2.1 sy,  0.0 ni, 95.7 id,  2.1 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   5753.6 total,    922.7 free,   2821.9 used,   2009.0 buff/cache
      MiB Swap:   2048.0 total,   2045.2 free,      2.8 used.   2624.1 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     576M  1.2M  575M   1% /run
      /dev/sda1      ext4       32G   25G  5.9G  81% /
      tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     2.9G     0  2.9G   0% /sys/fs/cgroup
      /dev/loop1     squashfs   64M   64M     0 100% /snap/core20/2318
      /dev/loop0     squashfs   64M   64M     0 100% /snap/core20/2264
      /dev/loop2     squashfs   39M   39M     0 100% /snap/snapd/21465
      /dev/loop3     squashfs   39M   39M     0 100% /snap/snapd/21759
      /dev/loop4     squashfs   92M   92M     0 100% /snap/lxd/29619
      /dev/loop5     squashfs   92M   92M     0 100% /snap/lxd/24061
      tmpfs          tmpfs     576M     0  576M   0% /run/user/0
      [Wed Aug 21 21:04:10 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Wed Aug 21 21:04:10 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      Show mounted filesystems:
      TARGET                                SOURCE                 FSTYPE      OPTIONS
      /                                     /dev/sda1              ext4        rw,relatime,errors=remount-ro
      |-/sys                                sysfs                  sysfs       rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security              securityfs             securityfs  rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                    tmpfs                  tmpfs       ro,nosuid,nodev,noexec,mode=755
      | | |-/sys/fs/cgroup/unified          cgroup2                cgroup2     rw,nosuid,nodev,noexec,relatime
      | | |-/sys/fs/cgroup/systemd          cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
      | | |-/sys/fs/cgroup/cpuset           cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,cpuset
      | | |-/sys/fs/cgroup/rdma             cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,rdma
      | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
      | | |-/sys/fs/cgroup/pids             cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,pids
      | | |-/sys/fs/cgroup/devices          cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,devices
      | | |-/sys/fs/cgroup/memory           cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,memory
      | | |-/sys/fs/cgroup/freezer          cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,freezer
      | | |-/sys/fs/cgroup/hugetlb          cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,hugetlb
      | | |-/sys/fs/cgroup/net_cls,net_prio cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
      | | |-/sys/fs/cgroup/perf_event       cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,perf_event
      | | `-/sys/fs/cgroup/blkio            cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,blkio
      | |-/sys/fs/pstore                    pstore                 pstore      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                       none                   bpf         rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                 debugfs                debugfs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing               tracefs                tracefs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections          fusectl                fusectl     rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config                configfs               configfs    rw,nosuid,nodev,noexec,relatime
      |-/proc                               proc                   proc        rw,nosuid,nodev,noexec,relatime
      | `-/proc/sys/fs/binfmt_misc          systemd-1              autofs      rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=13195
      |   `-/proc/sys/fs/binfmt_misc        binfmt_misc            binfmt_misc rw,nosuid,nodev,noexec,relatime
      |-/dev                                udev                   devtmpfs    rw,nosuid,noexec,relatime,size=4034392k,nr_inodes=1008598,mode=755
      | |-/dev/pts                          devpts                 devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                          tmpfs                  tmpfs       rw,nosuid,nodev
      | |-/dev/hugepages                    hugetlbfs              hugetlbfs   rw,relatime,pagesize=2M
      | `-/dev/mqueue                       mqueue                 mqueue      rw,nosuid,nodev,noexec,relatime
      |-/run                                tmpfs                  tmpfs       rw,nosuid,nodev,noexec,relatime,size=589176k,mode=755
      | |-/run/lock                         tmpfs                  tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs                   sunrpc                 rpc_pipefs  rw,relatime
      | |-/run/user/0                       tmpfs                  tmpfs       rw,nosuid,nodev,relatime,size=589172k,mode=700
      | `-/run/snapd/ns                     tmpfs[/snapd/ns]       tmpfs       rw,nosuid,nodev,noexec,relatime,size=589176k,mode=755
      |   `-/run/snapd/ns/lxd.mnt           nsfs[mnt:[4026532400]] nsfs        rw
      |-/snap/core20/2318                   /dev/loop1             squashfs    ro,nodev,relatime
      |-/snap/core20/2264                   /dev/loop0             squashfs    ro,nodev,relatime
      |-/snap/snapd/21465                   /dev/loop2             squashfs    ro,nodev,relatime
      |-/snap/snapd/21759                   /dev/loop3             squashfs    ro,nodev,relatime
      |-/snap/lxd/29619                     /dev/loop4             squashfs    ro,nodev,relatime
      |-/snap/lxd/24061                     /dev/loop5             squashfs    ro,nodev,relatime
      `-/var/lib/lxcfs                      lxcfs                  fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      6.2G    /var/
      3.2G    /var/log
      3.1G    /var/log/journal/e828ff4079780bc5c3f6a57759dbd61f
      2.9G    /var/lib
      Archived and active journals take up 3.0G in the file system.
      /opt/iobroker/backups:
      5.9M    /opt/iobroker/backups/
      180K    /opt/iobroker/backups/module
      100K    /opt/iobroker/backups/module/node_modules
      96K     /opt/iobroker/backups/module/node_modules/async
      48K     /opt/iobroker/backups/module/lib
      /opt/iobroker/iobroker-data:
      4.8G    /opt/iobroker/iobroker-data/
      3.4G    /opt/iobroker/iobroker-data/history
      951M    /opt/iobroker/iobroker-data/files
      442M    /opt/iobroker/iobroker-data/files/javascript.admin
      410M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      48M     /opt/iobroker/iobroker-data/objects.json.migrated
      48M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      42M     /opt/iobroker/iobroker-data/states.jsonl
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.16.0
      /usr/bin/node           v20.16.0
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      /usr/bin/corepack       0.28.2
      nodejs:
       Installed: 20.16.0-1nodesource1
       Candidate: 20.16.0-1nodesource1
       Version table:
      *** 20.16.0-1nodesource1 1001
             500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
          20.15.1-1nodesource1 1001
          20.15.0-1nodesource1 1001
          20.14.0-1nodesource1 1001
          20.13.1-1nodesource1 1001
          20.13.0-1nodesource1 1001
          20.12.2-1nodesource1 1001
          20.12.1-1nodesource1 1001
          20.12.0-1nodesource1 1001
          20.11.1-1nodesource1 1001
          20.11.0-1nodesource1 1001
          20.10.0-1nodesource1 1001
          20.9.0-1nodesource1 1001
          20.8.1-1nodesource1 1001
          20.8.0-1nodesource1 1001
          20.7.0-1nodesource1 1001
          20.6.1-1nodesource1 1001
          20.6.0-1nodesource1 1001
          20.5.1-1nodesource1 1001
          20.5.0-1nodesource1 1001
          20.4.0-1nodesource1 1001
          20.3.1-1nodesource1 1001
          20.3.0-1nodesource1 1001
          20.2.0-1nodesource1 1001
          20.1.0-1nodesource1 1001
          20.0.0-1nodesource1 1001
          10.19.0~dfsg-3ubuntu1.6 500
             500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
             500 http://security.ubuntu.com/ubuntu focal-security/universe amd64 Packages
          10.19.0~dfsg-3ubuntu1 500
             500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.0.22
      javascript:     8.7.6
      nodejs modules from github:     2
      |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
      | | +-- browser-serialport@2.0.3 invalid: "https://github.com/noopkat/browser-serialport#c8628c41c11890d3058875994c15f83f2df8185b" from node_modules/avrgirl-arduino
      Adapter State
      + system.adapter.admin.0                  : admin                 : automation                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : automation                               -  enabled
      + system.adapter.backitup.0               : backitup              : automation                               -  enabled
       system.adapter.cloud.0                  : cloud                 : automation                               - disabled
      + system.adapter.denon.0                  : denon                 : automation                               -  enabled
      + system.adapter.discovery.0              : discovery             : automation                               -  enabled
       system.adapter.ds18b20.0                : ds18b20               : gartenhaus                               - disabled
      + system.adapter.email.0                  : email                 : automation                               -  enabled
      + system.adapter.ems-esp.0                : ems-esp               : automation                               -  enabled
      + system.adapter.firetv.0                 : firetv                : automation                               -  enabled
       system.adapter.flot.0                   : flot                  : automation                               -  enabled
       system.adapter.ham.0                    : ham                   : automation                               - disabled
      + system.adapter.history.0                : history               : automation                               -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : automation                               -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : automation                               -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : automation                               -  enabled, port: 0
       system.adapter.icons-icons8.0           : icons-icons8          : automation                               -  enabled
       system.adapter.icons-material-png.0     : icons-material-png    : automation                               -  enabled
       system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: automation                               -  enabled
      + system.adapter.info.0                   : info                  : automation                               -  enabled
      + system.adapter.iot.0                    : iot                   : automation                               -  enabled
      + system.adapter.javascript.0             : javascript            : automation                               -  enabled
       system.adapter.km200.0                  : km200                 : automation                               - disabled
      + system.adapter.kostal-piko-ba.0         : kostal-piko-ba        : automation                               -  enabled
      + system.adapter.lovelace.0               : lovelace              : automation                               -  enabled, port: 80, bind: 0.0.0.0, run as: admin
       system.adapter.material.0               : material              : automation                               -  enabled
      + system.adapter.mihome.0                 : mihome                : automation                               -  enabled, port: 9898, bind: 192.168.69.227
       system.adapter.mobile.0                 : mobile                : automation                               -  enabled
      + system.adapter.modbus.0                 : modbus                : automation                               -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : automation                               -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mysensors.0              : mysensors             : automation                               -  enabled, port: 5003, bind: 0.0.0.0
       system.adapter.node-red.0               : node-red              : automation                               - disabled, port: 1880, bind: 0.0.0.0
       system.adapter.parser.0                 : parser                : automation                               - disabled
      + system.adapter.ping.0                   : ping                  : automation                               -  enabled
      + system.adapter.rflink.0                 : rflink                : automation                               -  enabled
       system.adapter.rickshaw.0               : rickshaw              : automation                               -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : powercount                               -  enabled
       system.adapter.rpi2.1                   : rpi2                  : gartenhaus                               -  enabled
      + system.adapter.scenes.0                 : scenes                : automation                               -  enabled
      + system.adapter.shelly.0                 : shelly                : automation                               -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : automation                               -  enabled, port: 1885, bind: 192.168.69.227
      + system.adapter.simple-api.0             : simple-api            : automation                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartmeter.0             : smartmeter            : powercount                               -  enabled
      + system.adapter.sonoff.0                 : sonoff                : automation                               -  enabled, port: 1884, bind: 0.0.0.0
       system.adapter.sony-bravia.0            : sony-bravia           : automation                               - disabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : automation                               -  enabled
      + system.adapter.sql.0                    : sql                   : automation                               -  enabled, port: 0
      + system.adapter.statistics.0             : statistics            : automation                               -  enabled
      + system.adapter.telegram.0               : telegram              : automation                               -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : automation                               -  enabled
      + system.adapter.unifi.0                  : unifi                 : automation                               -  enabled
       system.adapter.vis-bars.0               : vis-bars              : automation                               -  enabled
       system.adapter.vis-colorpicker.0        : vis-colorpicker       : automation                               -  enabled
       system.adapter.vis-history.0            : vis-history           : automation                               -  enabled
       system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : automation                               -  enabled
       system.adapter.vis-icontwo.0            : vis-icontwo           : automation                               -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : automation                               -  enabled
       system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : automation                               -  enabled
       system.adapter.vis-plumb.0              : vis-plumb             : automation                               -  enabled
       system.adapter.vis-rgraph.0             : vis-rgraph            : automation                               -  enabled
       system.adapter.vis-weather.0            : vis-weather           : automation                               -  enabled
       system.adapter.vis.0                    : vis                   : automation                               -  enabled
      + system.adapter.web.0                    : web                   : automation                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.web.1                    : web                   : automation                               -  enabled, port: 443, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.yahka.0                  : yahka                 : automation                               -  enabled
      + system.adapter.yeelight-2.0             : yeelight-2            : automation                               -  enabled
       system.adapter.yr.0                     : yr                    : automation                               -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name     │ url                                              │ auto upgrade │
      │ 0       │ 'Stable' │ 'http://download.iobroker.net/sources-dist.json' │ false        │
      │ 1       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false        │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.0.23   , installed 7.0.22 [Updatable]
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.19   , installed 3.0.16 [Updatable]
      Adapter    "daswetter"    : 3.1.15   , installed 3.1.16
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "ems-esp"      : 3.5.0    , installed 3.5.0
      Adapter    "firetv"       : 2.1.0    , installed 2.1.0
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.9    , installed 6.0.11
      Adapter    "kostal-piko-ba": 4.0.1   , installed 4.0.1
      Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "modbus"       : 6.2.3    , installed 6.2.3
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "mysensors"    : 3.0.0    , installed 3.0.0
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "parser"       : 2.2.2    , installed 2.2.2
      Adapter    "ping"         : 1.6.2    , installed 1.7.0
      Adapter    "rflink"       : 2.1.12   , installed 2.1.12
      Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
      Adapter    "scenes"       : 3.2.1    , installed 3.2.1
      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "solarwetter"  : 1.2.0    , installed 1.2.0
      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
      Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Objects and States
      Objects:        29630
      States:         25048
      Hit:1 http://security.ubuntu.com/ubuntu focal-security InRelease
      Hit:2 http://de.archive.ubuntu.com/ubuntu focal InRelease
      Hit:3 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:5 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
      Hit:6 https://esm.ubuntu.com/infra/ubuntu focal-infra-security InRelease
      Hit:7 https://esm.ubuntu.com/infra/ubuntu focal-infra-updates InRelease
      Reading package lists...
      Pending Updates: 1
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       126423     10494/iobroker.js-c
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       126420     10494/iobroker.js-c
      tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      111        27072      1096/mysqld
      tcp        0      0 0.0.0.0:5003            0.0.0.0:*               LISTEN      1001       131713     11817/io.mysensors.
      tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       129857     11581/adb
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14720      1/init
      tcp        0      0 0.0.0.0:34257           0.0.0.0:*               LISTEN      1001       138389     14000/io.yahka.0
      tcp        0      0 192.168.66.227:2001     0.0.0.0:*               LISTEN      1001       130853     11629/io.hm-rpc.0
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        17327      676/systemd-resolve
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25658      1016/sshd: /usr/sbi
      tcp        0      0 192.168.66.227:2010     0.0.0.0:*               LISTEN      1001       131491     11693/io.hm-rpc.1
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       130772     11589/io.mqtt.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       131643     11767/io.sonoff.0
      tcp        0      0 192.168.69.227:1885     0.0.0.0:*               LISTEN      1001       132347     11871/io.shelly.1
      tcp        0      0 127.0.0.1:33060         0.0.0.0:*               LISTEN      111        27070      1096/mysqld
      tcp        0      0 127.0.0.1:39813         0.0.0.0:*               LISTEN      1001       138398     14000/io.yahka.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          14724      1/init
      tcp6       0      0 :::80                   :::*                    LISTEN      1001       133655     12457/io.lovelace.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       125831     11215/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       132133     11760/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          25660      1016/sshd: /usr/sbi
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       137095     13953/io.simple-api
      tcp6       0      0 :::443                  :::*                    LISTEN      1001       132372     11883/io.web.1
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        22817      876/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       132162     11790/io.shelly.0
      udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       130593     11452/io.mihome.0
      udp        0      0 0.0.0.0:34580           0.0.0.0:*                           112        22819      876/avahi-daemon: r
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        17326      676/systemd-resolve
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14721      1/init
      udp6       0      0 :::45938                :::*                                112        22820      876/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                112        22818      876/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          15661      1/init
      • J JanGa
        Skript v.2024-05-22
        *** BASE SYSTEM ***
                  Chassis: vm
           Virtualization: kvm
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 3
                     NTP service: active
                 RTC in local TZ: no
        root
        HOME=/root
        GROUPS=root
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
                5753 M total memory
                2822 M used memory
                 922 M free memory
                 325 M buffer memory
                1683 M swap cache
                2047 M total swap
                   2 M used swap
                2045 M free swap
        *** FILESYSTEM ***
        /var:
        6.2G    /var/
        3.2G    /var/log
        2.9G    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            10.8.1
        /usr/bin/npx            10.8.1
        nodejs:
         Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          7.0.22
        javascript:     8.7.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        29630
        States:         25048
        Pending Updates: 1
        @janga
        Nichts weglassen...
        Außer persönliche Infos oder Passworte und sowas.
        • J JanGa
          Skript v.2024-05-22
          *** BASE SYSTEM ***
                    Chassis: vm
             Virtualization: kvm
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 3
                       NTP service: active
                   RTC in local TZ: no
          root
          HOME=/root
          GROUPS=root
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
                  5753 M total memory
                  2822 M used memory
                   922 M free memory
                   325 M buffer memory
                  1683 M swap cache
                  2047 M total swap
                     2 M used swap
                  2045 M free swap
          *** FILESYSTEM ***
          /var:
          6.2G    /var/
          3.2G    /var/log
          2.9G    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            10.8.1
          /usr/bin/npx            10.8.1
          nodejs:
           Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          7.0.22
          javascript:     8.7.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        29630
          States:         25048
          Pending Updates: 1
          @janga sagte in Update von Adapter führt zu Deinstallation von js-controller:
          root
          HOME=/root
          GROUPS=root
          Und dann ist auch schon Schluß...
            @janga
            Nichts weglassen...
            JanGa
            War echt nur Ausgaben vom Shelly Adapter, die im Diag angezeigt wurden. Und zwei von MQTT. Denke nichts relevantes.
              root
              HOME=/root
              GROUPS=root
              JanGa
              @thomas-braun Ist nur eine private Kiste und ich hab ein Backup. Ich weiß, es ist falsch...
              • J JanGa
                @janga
                Es ist EGAL was das für eine Kiste ist. ES WIRD NICHT ALS ROOT HERUMGEHAMPELT, VERDAMMT NOCH EINS!!!!!!
                  @janga
                  JanGa
                  @thomas-braun Was soll ich sagen, seit 20 Jahren Windows Admin und Linux 10 Minuten im Monat als Hobby.
                  • J JanGa
                    @janga
                    Und wie und warum kommt man dann auf den Schwachsinn?
                    Eigentlich alle Distributionen richten dir gar keinen root mehr ein bei der Installation.
                    Schnubbibuntu schon gerade gar nicht.
                    Jedenfalls ergibt sich so ein merkwüdiges Verhalten fast immer durch das herumgerutsche als root.
                    Sind nämlich auch immer genau die user, die eh schon wenig bis gar keine Ahnung wie das alles funktioniert.
                    Je weniger $Ahnung desto mehr $root muss man sein, oder was ist die Logik dahinter?
                      @janga
                      JanGa
                      @thomas-braun Naja, ich melde mich an der Kiste ja nur für administrative Tätigkeiten an und für nichts anderes. Ob ich da jetzt vor jeden Befehl ein sudo hänge oder direkt root bin macht dann auch keinen riesigen Unterschied mehr. Spart halt 20 mal sudo tippen. Ist ja mein kalkuliertes Risiko, was ich nicht eingehe, weil ich nicht weiß wie es anders geht, sondern weil ich die möglichen Folgen kenne und damit leben kann. Baue ich Mist, wird das backup wiederhergestellt und gut. Ich hab da keine professionellen Ansprüche.
                      Meinst du das hat wirklich was mit den inhaltlichen Problemen meine IOBroker Installation zu tun?
                      • J JanGa
                        Ja.
                        Und im weiteren interessiert mich dann die verootete Kiste auch nicht mehr.
                          Ja.
                          JanGa
                          @thomas-braun Wenn du weiter so aggro bist, bearbeite ich gleich die sudoers mit nano! ;)
                          Thomas BraunT liv-in-skyL 2 Antworten Letzte Antwort
                          • J JanGa
                            @janga
                            Wie gesagt: Dein System und deine Probleme damit interessieren mich nicht.
                            • J JanGa
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              @janga lass dich nicht ärgern - in der "wurzel" seines herzens ist er ein ganz lieber :-)
                              ich hoffe du hast ein backup - dann würde ich mal einen user anegen (wie, findest du auch im forum)
                              wenn du weißt, wie du die backup datei wegsichern kannst, würde ich das ganze ding neu aufsetzen, einen user einrichten und iob neu installieren und dann das backup einspielen - dann bist du auf der sicheren seite
                              ich persönlich bevorzuge debian ohne gui
                              edit:
                              user anlegen findest du z.b hier:
                              https://www.iobroker.net/#de/documentation/install/proxmox.md
                              • liv-in-skyL liv-in-sky
                                edit:
                                JanGa
                                @liv-in-sky
                                Wenn man sieht wie vielen er hier hilft, liegt es mir auch fern seine gute Seele in Frage zu stellen. :D Ich weiß ja auch, dass sich jeder richtige Linux Admin die Haare rauft, wenn er sieht wie ich arbeite. Ich werde mal versuchen, da disziplinierter zu werden. Grundsätzlich kann ich das, weil ich im beruflichen Umfeld auch eine kleine Anzahl Linux-Server mit betreue. Da erfolgt die Anmeldung auch nicht per Passwort, sondern per Key usw..
                                Wie man einen Benutzer anlegt weiß ich entsprechend. Es existiert auch entsprechender Benutzer auf dem IOBroker-Server. Ich habe trotzdem immer eine leichte Tendenz als erstes ein sudo su zu machen. Ist vielleicht auch nicht schlecht dafür zwischendurch mal beschimpft zu werden, hat mich schon nachdenklich gemacht. :)
                                Neu aufsetzen ist eventuell gar keine schlechte Idee. Dann habe ich den Backup Adapter mal getestet und mein Ubuntu auf der Kiste ist ja auch nicht mehr ganz taufrisch. Die Frage ist nur, ob mein Problem damit behoben ist. Für mich sieht das ja nach einem Fehler in den Abhängigkeiten vom Kostal Adapter aus. Eventuell schmeiße ich den einfach mal raus und schaue, ob es dann geht.
                                Ich habe früher auch immer nur Debian genutzt, bin dann aber in meiner privaten Umgebung irgendwann einheitlich auf Ubuntu gewechselt, weil die Pakete unter Debian immer ein gewisses Alter haben (wenn man nicht gerade Testing nutzt) und man dadurch automatisch öfter selbst kompiliert oder andere Quellen von Dritten hinzufügt. Bei Ubuntu habe ich das deutlich seltener und da ich die Server-Version verwende (die auch keine GUI hat), musste ich mich von der Bedienung her kaum umgewöhnen.
                                • J JanGa
                                  @liv-in-sky
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  hast du auf github nachgesehen, ob dieser fehler beim adapter ein issue ist ? oder evtl ml ein issue erstellt
                                  • crunchipC Offline
                                    crunchipC Offline
                                    dann schmeiß den doch mal runter und installier ihn neu
                                      JanGa
                                      @liv-in-sky Hatte ich geguckt, gibt kein Issue, aber ich glaube mit dem Adapter passiert eh nicht mehr viel.
                                      @crunchip Werde ich machen.
                                      • J JanGa
                                        node v20.16.0
                                        npm  10.8.1
                                        Ubuntu 20.04.6 LTS
                                        Da sehe ich erst einmal keinen kausalen Zusammenhang.
                                        Was ich sehe
                                        Virtualization: kvm
                                        und
                                        Intel(R) Xeon(R)
                                        dazu klingelt irgendwas in meinem Hinterkopf!
                                        doch!
                                        zum Thema Rechteverbiegung und ominöse Fehler durch root-Nutzung gibt es bereits drölfhundert Threads.
                                        J crunchipC 2 Antworten Letzte Antwort
                                          Was ich sehe
                                          Virtualization: kvm
                                          und
                                          Intel(R) Xeon(R)
                                          doch!
                                          JanGa
                                          @homoran KVM (Proxmox) auf einem Server mit Xeon CPU ist eigentlich nichts exotisches. Den kausalen Zusammenhang sehe bzw. verstehe ich ja auch nicht, aber trotzdem ist es jetzt schon mehrfach genau so abgelaufen. Im Admin eine Aktion ausgelöst wie Update oder Installation und danach war der Controller weg.
