  4. Probleme beim Update Host node.js
66 Beiträge 7 Kommentatoren 11.3k Aufrufe 3 Beobachtet
  • K keineAhnungvonProgrmieren
    @keineahnungvonprogrmieren said in Probleme beim Update Host node.js:
    @thomas-braun said in Probleme beim Update Host node.js:
    Zuvor:
    iob stop
    iob fix
    dann dürfte es funktionieren.
    hat zuerst funktioniert
    nach ca 10min war die weboberfläche noch nicht erreichbar im anschluss von mir
    iob reboot
    danach
    SmartHome@SmartHome:~ $ iob reboot
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
      iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
      iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub, if a package name is provided instead of an url, it will be installed from npm
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    Options:
      --help  Show help  [boolean]
    jetzt:
    C:\Users\Benutzer1> ssh SmartHome@Smarthome
    Warning: Permanently added the ECDSA host key for IP address 'fd00::669a:fed7:8333:5b02' to the list of known hosts.
    SmartHome@smarthome password:
    ssh_dispatch_run_fatal: Connection to fd00::669a:fed7:8333:5b02 port 22: Connection timed out
    Warten oder über die IP versuchen. Da hat es deine ssh keys verwürfelt. Hat aber mit dem nodejs Update nix zu tun, das packt die nämlich nicht an.
    K 2 Antworten Letzte Antwort
      puh läuft wieder
      Danke euch allen für die Konstruktiven antworten👏
        schrieb am zuletzt editiert von keineAhnungvonProgrmieren
        @thomas-braun said in Probleme beim Update Host node.js [gelöst]:
        ok scheinbar habe ich mir ein neues Problem eingefangen
        bin mir nicht sicher ob es was mit dem update was zu tun hat allerding lief bis zu dem Update der letzten Tage der IO Broker sehr stabil.
        Nun zu meinen Beobachtungen:
        wenn ich über comand auf den Raspberry zugreifen möchte dann wird diese verbindung sehr schnell wieder unterbrochen. manchmal reicht die Zeit um befehle plazieren zu können und mit etwas Glück reicht es für die eigendiagnose mit folgendem inhalt
        *** iob diag is starting up, please wait ***
        client_loop: send disconnect: Connection reset
        C:\Users\Benutzer1>ssh SmartHome@Smarthome
        Linux SmartHome 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Tue Aug  6 19:53:43 2024 from 192.168.178.71
        Wi-Fi is currently blocked by rfkill.
        Use raspi-config to set the country before use.
        SmartHome@SmartHome:~ $ sudoclient_loop: send disconnect: Connection reset
        C:\Users\Benutzer1>ssh SmartHome@smarthome
        SmartHome@SmartHome:~ $ iob start admin.0
        SmartHome@SmartHome:~ $ client_loop: send disconnect: Connection reset
        SmartHomeRohlik@smarthomerohlik's password:
        Permission denied, please try again.
        Last login: Wed Aug  7 05:17:40 2024 from 192.168.178.71
        SmartHome@SmartHome:~ $ iob stop
        SmartHome@SmartHome:~ $ sudo apt update
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
        Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [276 kB]
        Get:7 http://security.debian.org/debian-security bullseye-security/main armhf Packages [277 kB]
        Get:8 http://security.debian.org/debian-security bullseye-security/main Translation-en [181 kB]
        Fetched 827 kB in 1s (557 kB/s)
        Reading package lists... Done
        Building dependency tree... Done
        1 package can be upgraded. Run 'apt list --upgradable' to see it.
        SmartHome@SmartHome:~ $ sudo apt upgrade
        Calculating upgrade... Done
        The following packages will be upgraded:
          wpasupplicant
        1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        Need to get 1,189 kB of archives.
        After this operation, 10.2 kB disk space will be freed.
        Do you want to continue? [Y/n] y
        Get:1 http://security.debian.org/debian-security bullseye-security/main arm64 wpasupplicant arm64 2:2.9.0-21+deb11u2 [1,189 kB]
        Fetched 1,189 kB in 1s (1,588 kB/s)
        Reading changelogs... Done
        (Reading database ... 50170 files and directories currently installed.)
        Preparing to unpack .../wpasupplicant_2%3a2.9.0-21+deb11u2_arm64.deb ...
        Unpacking wpasupplicant (2:2.9.0-21+deb11u2) over (2:2.9.0-21) ...
        Setting up wpasupplicant (2:2.9.0-21+deb11u2) ...
        Processing triggers for man-db (2.9.4-2) ...
        Processing triggers for dbus (1.12.28-0+deb11u1) ...
        SmartHomeRohlik@SmartHomeRohlik:~ $ sudo reboot
        Connection to smarthomerohlik closed by remote host.
        Connection to smarthomerohlik closed.
        Linux SmartHomeRohlik 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
        Last login: Wed Aug  7 05:20:31 2024 from 192.168.178.71
        SmartHome@SmartHome:~ $ iob update
        Used repository: stable
        Adapter    "admin"        : 7.0.22   , installed 7.0.22
        Adapter    "backitup"     : 3.0.16   , installed 2.11.0 [Updatable]
        Adapter    "bshb"         : 0.2.8    , installed 0.2.8
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
        Controller "js-controller": 6.0.9    , installed 6.0.9
        Adapter    "mihome-cloud" : 0.1.0    , installed 0.1.0
        Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
        Adapter    "modbus"       : 6.2.3    , installed 6.2.3
        Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.0  [Updatable]
        Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.2.3  [Updatable]
        Adapter    "ws"           : 2.6.2    , installed 2.6.1  [Updatable]
        SmartHomeRohlik@SmartHomeRohlik:~ $ client_loop: send disconnect: Connection reset
        Auf die web oberfläche kann ich fast garnicht zugreifen, wenn es mal klappt dann kommt gelegentlich folgende Fehlermeldung:
        wenn ich dem link folge dann soll ich die Admin updaten was aber schwer ist da ich ständig die verbindung via Comand verliere.
        Hat jemand eine Idee was ich jetzt machen kann?
            wpasupplicant
          @keineahnungvonprogrmieren sagte in Probleme beim Update Host node.js:
          Du hast eine Knoten im Netzwerk.
          K 1 Antwort Letzte Antwort
              wpasupplicant
            das was im popup steht!
            F12 -> Konsole -> Error posten
              @homoran said in Probleme beim Update Host node.js:
              Diese Seite verwendet die nicht standardisierte Eigenschaft "zoom". Stattdessen sollte calc() in den entsprechenden Eigenschaftswerten oder "transform" zusammen mit "transform-origin: 0 0" verwendet werden. 23
              unreachable code after return statement
              button.js:12:5
              Missing key in translation token "global:" for language "en-GB"
              der Screeshot ist von heute Morgen, denke das der Fehler aktuell nicht eingetragen ist.
              Im Popup steht das ich die Admin instanz updaten soll was aber nicht möglich ist da ich via comand auch nicht zugreifen kann und wenn nur ganz kurz
                woher kann der kommen?
                viel wichtiger wie bekomme ich den wieder raus?
                  Keine Ahnung. Ich kenn dein Netzwerk ja nicht.
                    IP ist auf jedenfall nicht doppelt vergeben
                    kann auch nicht via IP adresse darauf zugreifen
                    C:\Users\Benutzer1>192.168.178.52
                    Der Befehl "192.168.178.52" ist entweder falsch geschrieben oder
                    konnte nicht gefunden werden.
                    C:\Users\Benutzer1>ssh 192.168.178.52
                    benutzer1@192.168.178.52's password:
                    Connection reset by 192.168.178.52 port 22
                    ssh: connect to host 192.168.178.52 port 22: Connection timed out
                    ssh_dispatch_run_fatal: Connection to 192.168.178.52 port 22: Connection timed out
                      ??? Der user heißt doch SmartHome und nicht benutzer1
                        normalerweise greife ich über
                        ssh smartHome@smartHome
                        zu habe jetzt versucht via
                        ssh 192.168.178.52
                        also der IP adresse zuzugreifen oder gibt es da noch andere Möglichkeiten?
                        benutzer1 müsst eigendlich mein Windows laptop sein oder?
                          ssh 192.168.178.52
                          Aber auch da gehört der username rein.
                          Also
                          ssh smartHome@192.168.178.52
                            Also
                            C:\Users\Benutzer1>ssh SmartHome@192.168.178.52
                            C:\Users\Benutzer1>
                            bis die Antwort da ist dauert es auch extrem lange
                            ist der Port der richtige sollte bei mir der Standart sein da ich daran nix geändert habe
                              C:\Users\Benutzer1>
                              22 ist der Standardport für SSH.
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                @keineAhnungvonProgrmieren
                                Was ist mit dieser Aussage
                                • haselchenH haselchen
                                  @haselchen
                                  Da ist halt WLAN nie eingestellt worden. Muss ja auch nicht, wenn die Kiste per Kabel angebunden ist. Empfiehlt sich für einen Server ja eh.
                                    @haselchen
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    Naja, wenn das so als einziger Hinweis kommt beim Verbindungsaufbau, dann kann man schonmal nachfragen 😉
                                      C:\Users\Benutzer1>
                                      Da spukt auch noch irgendwas anderes umher:
                                      Was ist denn das für ein user und hostname?
                                      Tip am Rande: usernames und hostnames am besten ausschließlich in Kleinbuchstaben verwenden. Alles andere führt früher oder später immer zu Verwirrung.
                                        gut aufgepasst das ist der eigentliche Name habe ihn versucht überall zu ändern ( habe offensichtlich einen übersehen)
                                        #bringt es etwas das teil mal vom strom zu nehmen und ihn somit zu einem neustart zu zwingen?
                                          Eine Neustart machst du per
                                          sudo reboot
                                          Nicht per Strom weg wegsensen.
